[PATCH 1/2] ARM: mediatek: Add MT8183 support
Add the MT8183 SoC support.
Signed-off-by: Fabien Parent fparent@baylibre.com --- arch/arm/dts/mt8183.dtsi | 274 +++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 9 + arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8183/Makefile | 3 + arch/arm/mach-mediatek/mt8183/init.c | 80 ++++++++ 5 files changed, 367 insertions(+) create mode 100644 arch/arm/dts/mt8183.dtsi create mode 100644 arch/arm/mach-mediatek/mt8183/Makefile create mode 100644 arch/arm/mach-mediatek/mt8183/init.c
diff --git a/arch/arm/dts/mt8183.dtsi b/arch/arm/dts/mt8183.dtsi new file mode 100644 index 000000000000..294aa2b89796 --- /dev/null +++ b/arch/arm/dts/mt8183.dtsi @@ -0,0 +1,274 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2021 MediaTek Inc. + * Copyright (C) 2021 BayLibre, SAS + * Author: Ben Ho ben.ho@mediatek.com + * Erin Lo erin.lo@mediatek.com + * Fabien Parent fparent@baylibre.com + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/mt8183-clk.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "mediatek,mt8183"; + interrupt-parent = <&sysirq>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu0>; + }; + core1 { + cpu = <&cpu1>; + }; + core2 { + cpu = <&cpu2>; + }; + core3 { + cpu = <&cpu3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu4>; + }; + core1 { + cpu = <&cpu5>; + }; + core2 { + cpu = <&cpu6>; + }; + core3 { + cpu = <&cpu7>; + }; + }; + }; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x000>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x001>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x002>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x003>; + enable-method = "psci"; + capacity-dmips-mhz = <741>; + }; + + cpu4: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x100>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu5: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x101>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu6: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x102>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + + cpu7: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a73"; + reg = <0x103>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + }; + }; + + clk26m: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + clock-output-names = "clk26m"; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + + watchdog: watchdog@10007000 { + compatible = "mediatek,mt8183-wdt", + "mediatek,wdt"; + reg = <0 0x10007000 0 0x100>; + status = "disabled"; + }; + + gic: interrupt-controller@c000000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <4>; + interrupt-parent = <&gic>; + interrupt-controller; + reg = <0 0x0c000000 0 0x40000>, /* GICD */ + <0 0x0c100000 0 0x200000>, /* GICR */ + <0 0x0c400000 0 0x2000>, /* GICC */ + <0 0x0c410000 0 0x1000>, /* GICH */ + <0 0x0c420000 0 0x2000>; /* GICV */ + + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu0 &cpu1 &cpu2 &cpu3>; + }; + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu4 &cpu5 &cpu6 &cpu7>; + }; + }; + }; + + sysirq: interrupt-controller@c530a80 { + compatible = "mediatek,mt8183-sysirq", + "mediatek,mt6577-sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0 0x0c530a80 0 0x50>; + }; + + topckgen: syscon@10000000 { + compatible = "mediatek,mt8183-topckgen", "syscon"; + reg = <0 0x10000000 0 0x1000>; + #clock-cells = <1>; + }; + + infracfg: syscon@10001000 { + compatible = "mediatek,mt8183-infracfg", "syscon"; + reg = <0 0x10001000 0 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: syscon@1000c000 { + compatible = "mediatek,mt8183-apmixedsys", "syscon"; + reg = <0 0x1000c000 0 0x1000>; + #clock-cells = <1>; + }; + + uart0: serial@11002000 { + compatible = "mediatek,mt8183-uart", + "mediatek,hsuart"; + reg = <0 0x11002000 0 0x1000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_LOW>; + clock-frequency = <26000000>; + clocks = <&clk26m>, <&infracfg CLK_INFRA_UART0>; + clock-names = "baud", "bus"; + status = "disabled"; + }; + + mmc0: mmc@11230000 { + compatible = "mediatek,mt8183-mmc"; + reg = <0 0x11230000 0 0x1000>, + <0 0x11f50000 0 0x1000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_LOW>; + clocks = <&topckgen CLK_TOP_MUX_MSDC50_0>, + <&infracfg CLK_INFRA_MSDC0>, + <&infracfg CLK_INFRA_MSDC0_SCK>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + u3phy: usb-phy@11f40000 { + compatible = "mediatek,generic-tphy-v2"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "okay"; + + u2port0: usb-phy2@11f40000 { + reg = <0 0x11f40000 0 0x700>; + clocks = <&clk26m>; + clock-names = "ref"; + #phy-cells = <1>; + status = "okay"; + }; + + u3port0: usb-phy3@11f40700 { + reg = <0 0x11f40700 0 0x900>; + clocks = <&clk26m>; + clock-names = "ref"; + #phy-cells = <1>; + status = "okay"; + }; + }; + + usb: usb@11200000 { + compatible ="mediatek,mt8183-mtu3", "mediatek,mtu3"; + reg = <0 0x11200000 0 0x3e00>, + <0 0x11203e00 0 0x0100>; + reg-names = "mac", "ippc"; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_LOW>; + phys = <&u2port0 PHY_TYPE_USB2>; + clocks = <&infracfg CLK_INFRA_UNIPRO_SCK>, + <&infracfg CLK_INFRA_USB>; + clock-names = "sys_ck", "ref_ck"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + status = "disabled"; + + ssusb: ssusb@11200000 { + compatible = "mediatek,ssusb"; + reg = <0 0x11200000 0 0x3e00>; + reg-names = "mac"; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_LOW>; + status = "disabled"; + }; + + usb_host: xhci@11200000 { + compatible = "mediatek,mtk-xhci"; + reg = <0 0x11200000 0 0x1000>; + reg-names = "mac"; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_LOW>; + clocks = <&infracfg CLK_INFRA_UNIPRO_SCK>, + <&infracfg CLK_INFRA_USB>; + clock-names = "sys_ck", "ref_ck"; + status = "disabled"; + }; + }; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 2791b3dbda2b..a035471374b6 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -42,6 +42,15 @@ config TARGET_MT7629 including DDR3, crypto engine, 3x3 11n/ac Wi-Fi, Gigabit Ethernet, switch, USB3.0, PCIe, UART, SPI, I2C and PWM.
+config TARGET_MT8183 + bool "MediaTek MT8183 SoC" + select ARM64 + help + The MediaTek MT8183 is a ARM64-based SoC with a quad-core Cortex-A73 and + a quad-core Cortex-A53. It is including UART, SPI, USB3.0 dual role, + SD and MMC cards, UFS, PWM, I2C, I2S, S/PDIF, and several LPDDR3 + and LPDDR4 options. + config TARGET_MT8512 bool "MediaTek MT8512 M1 Board" select ARM64 diff --git a/arch/arm/mach-mediatek/Makefile b/arch/arm/mach-mediatek/Makefile index 290d2c709fa3..0f5b0c16d2cb 100644 --- a/arch/arm/mach-mediatek/Makefile +++ b/arch/arm/mach-mediatek/Makefile @@ -7,5 +7,6 @@ obj-$(CONFIG_MT8512) += mt8512/ obj-$(CONFIG_TARGET_MT7622) += mt7622/ obj-$(CONFIG_TARGET_MT7623) += mt7623/ obj-$(CONFIG_TARGET_MT7629) += mt7629/ +obj-$(CONFIG_TARGET_MT8183) += mt8183/ obj-$(CONFIG_TARGET_MT8516) += mt8516/ obj-$(CONFIG_TARGET_MT8518) += mt8518/ diff --git a/arch/arm/mach-mediatek/mt8183/Makefile b/arch/arm/mach-mediatek/mt8183/Makefile new file mode 100644 index 000000000000..886ab7e4eb9f --- /dev/null +++ b/arch/arm/mach-mediatek/mt8183/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += init.o diff --git a/arch/arm/mach-mediatek/mt8183/init.c b/arch/arm/mach-mediatek/mt8183/init.c new file mode 100644 index 000000000000..877f387102d5 --- /dev/null +++ b/arch/arm/mach-mediatek/mt8183/init.c @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 MediaTek Inc. + * Copyright (C) 2021 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <ram.h> +#include <asm/arch/misc.h> +#include <asm/armv8/mmu.h> +#include <asm/sections.h> +#include <asm/system.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/mt8516-clk.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = gd->ram_base; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int mtk_pll_early_init(void) +{ + return 0; +} + +int mtk_soc_early_init(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ + psci_system_reset(); +} + +int print_cpuinfo(void) +{ + printf("CPU: MediaTek MT8183\n"); + return 0; +} + +static struct mm_region mt8183_mem_map[] = { + { + /* DDR */ + .virt = 0x40000000UL, + .phys = 0x40000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_OUTER_SHARE, + }, { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + 0, + } +}; +struct mm_region *mem_map = mt8183_mem_map;
Add the MT8183 pumpkin board support.
Signed-off-by: Fabien Parent fparent@baylibre.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/mt8183-pumpkin.dts | 99 ++++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 1 + board/mediatek/mt8183/Kconfig | 13 ++++ board/mediatek/mt8183/MAINTAINERS | 6 ++ board/mediatek/mt8183/Makefile | 3 + board/mediatek/mt8183/mt8183_pumpkin.c | 28 ++++++++ configs/mt8183_pumpkin_defconfig | 81 +++++++++++++++++++++ include/configs/mt8183.h | 41 +++++++++++ 9 files changed, 273 insertions(+) create mode 100644 arch/arm/dts/mt8183-pumpkin.dts create mode 100644 board/mediatek/mt8183/Kconfig create mode 100644 board/mediatek/mt8183/MAINTAINERS create mode 100644 board/mediatek/mt8183/Makefile create mode 100644 board/mediatek/mt8183/mt8183_pumpkin.c create mode 100644 configs/mt8183_pumpkin_defconfig create mode 100644 include/configs/mt8183.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index af2842a0f8bf..782d99316424 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1000,6 +1000,7 @@ dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7622-bananapi-bpi-r64.dtb \ mt7623n-bananapi-bpi-r2.dtb \ mt7629-rfb.dtb \ + mt8183-pumpkin.dtb \ mt8512-bm1-emmc.dtb \ mt8516-pumpkin.dtb \ mt8518-ap1-emmc.dtb diff --git a/arch/arm/dts/mt8183-pumpkin.dts b/arch/arm/dts/mt8183-pumpkin.dts new file mode 100644 index 000000000000..470a7693997d --- /dev/null +++ b/arch/arm/dts/mt8183-pumpkin.dts @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright (C) 2021 BayLibre SAS. + * Author: Fabien Parent fparent@baylibre.com + */ + +/dts-v1/; + +#include <config.h> +#include "mt8183.dtsi" + +/ { + model = "MediaTek MT8183 pumpkin board"; + compatible = "mediatek,mt8183-pumpkin", "mediatek,mt8183"; + + memory@40000000 { + device_type = "memory"; + reg = <0 0x40000000 0 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 192 KiB reserved for ARM Trusted Firmware (BL31) */ + bl31_secmon_reserved: secmon@54600000 { + no-map; + reg = <0 0x54600000 0x0 0x30000>; + }; + + /* 12 MiB reserved for OP-TEE (BL32) + * +-----------------------+ 0x43e0_0000 + * | SHMEM 2MiB | + * +-----------------------+ 0x43c0_0000 + * | | TA_RAM 8MiB | + * + TZDRAM +--------------+ 0x4340_0000 + * | | TEE_RAM 2MiB | + * +-----------------------+ 0x4320_0000 + */ + optee_reserved: optee@43200000 { + no-map; + reg = <0 0x43200000 0 0x00c00000>; + }; + }; + + chosen { + stdout-path = &uart0; + }; + + reg_1p8v: regulator-1p8v { + compatible = "regulator-fixed"; + regulator-name = "fixed-1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + reg_3p3v: regulator-3p3v { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; +}; + +&watchdog { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&mmc0 { + bus-width = <4>; + max-frequency = <200000000>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + cap-mmc-hw-reset; + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_1p8v>; + non-removable; + status = "okay"; +}; + +&usb { + status = "okay"; +}; + +&ssusb { + mediatek,force-vbus; + maximum-speed = "high-speed"; + dr_mode = "peripheral"; + status = "okay"; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index a035471374b6..18b7756bdf5b 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -84,6 +84,7 @@ endchoice source "board/mediatek/mt7622/Kconfig" source "board/mediatek/mt7623/Kconfig" source "board/mediatek/mt7629/Kconfig" +source "board/mediatek/mt8183/Kconfig" source "board/mediatek/mt8512/Kconfig" source "board/mediatek/mt8516/Kconfig" source "board/mediatek/mt8518/Kconfig" diff --git a/board/mediatek/mt8183/Kconfig b/board/mediatek/mt8183/Kconfig new file mode 100644 index 000000000000..b75c3b8d8069 --- /dev/null +++ b/board/mediatek/mt8183/Kconfig @@ -0,0 +1,13 @@ +if TARGET_MT8183 + +config SYS_BOARD + default "mt8183" + +config SYS_CONFIG_NAME + default "mt8183" + +config MTK_BROM_HEADER_INFO + string + default "media=emmc" + +endif diff --git a/board/mediatek/mt8183/MAINTAINERS b/board/mediatek/mt8183/MAINTAINERS new file mode 100644 index 000000000000..a49995e1bfe5 --- /dev/null +++ b/board/mediatek/mt8183/MAINTAINERS @@ -0,0 +1,6 @@ +MT8183 Pumpkin +M: Fabien Parent fparent@baylibre.com +S: Maintained +F: board/mediatek/mt8183 +F: include/configs/mt8183.h +F: configs/mt8183_pumpkin_defconfig diff --git a/board/mediatek/mt8183/Makefile b/board/mediatek/mt8183/Makefile new file mode 100644 index 000000000000..90b5b72323c9 --- /dev/null +++ b/board/mediatek/mt8183/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += mt8183_pumpkin.o diff --git a/board/mediatek/mt8183/mt8183_pumpkin.c b/board/mediatek/mt8183/mt8183_pumpkin.c new file mode 100644 index 000000000000..db613ebdc4f4 --- /dev/null +++ b/board/mediatek/mt8183/mt8183_pumpkin.c @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 BayLibre SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <common.h> +#include <dm.h> +#include <net.h> + +int board_init(void) +{ + struct udevice *dev; + int ret; + + if (CONFIG_IS_ENABLED(USB_GADGET)) { + ret = uclass_get_device(UCLASS_USB_GADGET_GENERIC, 0, &dev); + if (ret) { + pr_err("%s: Cannot find USB device\n", __func__); + return ret; + } + } + + if (CONFIG_IS_ENABLED(USB_ETHER)) + usb_ether_init(); + + return 0; +} diff --git a/configs/mt8183_pumpkin_defconfig b/configs/mt8183_pumpkin_defconfig new file mode 100644 index 000000000000..b0bdcb39388b --- /dev/null +++ b/configs/mt8183_pumpkin_defconfig @@ -0,0 +1,81 @@ +CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_MEDIATEK=y +CONFIG_SYS_TEXT_BASE=0x4c000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x0 +CONFIG_DM_GPIO=y +CONFIG_TARGET_MT8183=y +CONFIG_DEBUG_UART_BASE=0x11002000 +CONFIG_DEBUG_UART_CLOCK=26000000 +# CONFIG_PSCI_RESET is not set +CONFIG_DEFAULT_DEVICE_TREE="mt8183-pumpkin" +CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_DEFAULT_FDT_FILE="mt8183-pumpkin" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_MEMORY is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_BLOCK_CACHE is not set +CONFIG_CMD_EXT4=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DEVRES=y +CONFIG_CLK=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x4d000000 +CONFIG_FASTBOOT_BUF_SIZE=0x8000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_MMC_BOOT1_SUPPORT=y +# CONFIG_INPUT is not set +CONFIG_DM_MMC=y +# CONFIG_MMC_QUIRKS is not set +CONFIG_MMC_MTK=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_MTK_TPHY=y +CONFIG_BAUDRATE=921600 +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_MTK_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_MTU3=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0e8d +CONFIG_USB_GADGET_PRODUCT_NUM=0x201c +CONFIG_USB_ETHER=y +CONFIG_WDT=y +CONFIG_WDT_MTK=y +# CONFIG_REGEX is not set +CONFIG_OF_LIBFDT_OVERLAY=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/mt8183.h b/include/configs/mt8183.h new file mode 100644 index 000000000000..8e7afbb48a77 --- /dev/null +++ b/include/configs/mt8183.h @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration for MT8183 based boards + * + * Copyright (C) 2021 BayLibre, SAS + * Author: Fabien Parent <fparent@baylibre.com + */ + +#ifndef __MT8183_H +#define __MT8183_H + +#include <linux/sizes.h> + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_MALLOC_LEN SZ_4M + +#define CONFIG_CPU_ARMV8 +#define COUNTER_FREQUENCY 13000000 + +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_COM1 0x11005200 +#define CONFIG_SYS_NS16550_CLK 26000000 + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_2M - \ + GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_BOOTM_LEN SZ_64M + +/* Environment settings */ +#include <config_distro_bootcmd.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "scriptaddr=0x40000000\0" \ + BOOTENV + +#endif
Fabien Parent
