[PATCH] ARM: meson: Add S905Y2 SOC ID
Add the SOC ID for the S905Y2 to board info, see below for before/after tested with a Radxa Zero board:
SoC: Amlogic Meson G12A (Unknown) Revision 28:b (30:2) SoC: Amlogic Meson G12A (S905Y2) Revision 28:b (30:2)
Signed-off-by: Christian Hewitt christianshewitt@gmail.com --- arch/arm/mach-meson/board-info.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index d16d3f194d..2421acd817 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -64,6 +64,7 @@ static const struct meson_gx_package_id { { "A113X", 0x25, 0x37, 0xff }, { "A113D", 0x25, 0x22, 0xff }, { "S905D2", 0x28, 0x10, 0xf0 }, + { "S905Y2", 0x28, 0x30, 0xf0 }, { "S905X2", 0x28, 0x40, 0xf0 }, { "A311D", 0x29, 0x10, 0xf0 }, { "S922X", 0x29, 0x40, 0xf0 },
- { "S905Y2", 0x28, 0x30, 0xf0 }, { "S905X2", 0x28, 0x40, 0xf0 }, { "A311D", 0x29, 0x10, 0xf0 }, { "S922X", 0x29, 0x40, 0xf0 },
Reviewed-by: Neil Armstrong narmstrong@baylibre.com
Applied to u-boot-amlogic
Thanks, Neil
Christian Hewitt
Neil Armstrong
