[PATCH v2] fs: fat: Handle 'FAT sector size mismatch'
Do FAT read and write based on the device sector size instead of the size recorded in the FAT meta data.
FAT code issues i/o in terms of the sector size. Convert that to device sector size before doing the actual i/o. Additionally, handle leading/trailing blocks when the meta data based block no and i/o size is not an exact multiple of the device sector size or vice versa.
Tested on UFS device with sector size 4096 and meta data recorded sector size 512.
Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- fs/fat/fat.c | 218 ++++++++++++++++++++++++++++++++++++++++++--- fs/fat/fat_write.c | 19 ---- 2 files changed, 205 insertions(+), 32 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index e2570e8167..efbf892c7a 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -44,24 +44,214 @@ static void downcase(char *str, size_t len)
static struct blk_desc *cur_dev; static struct disk_partition cur_part_info; +static int fat_sect_size;
#define DOS_BOOT_MAGIC_OFFSET 0x1fe #define DOS_FS_TYPE_OFFSET 0x36 #define DOS_FS32_TYPE_OFFSET 0x52
-static int disk_read(__u32 block, __u32 nr_blocks, void *buf) +inline __u32 sect_to_block(__u32 sect, __u32 *off) { - ulong ret; + *off = 0; + if (fat_sect_size && fat_sect_size < cur_part_info.blksz) { + int div = cur_part_info.blksz / fat_sect_size; + + *off = sect % div; + return sect / div; + } else if (fat_sect_size && (fat_sect_size > cur_part_info.blksz)) { + return sect * (fat_sect_size / cur_part_info.blksz); + }
- if (!cur_dev) - return -1; + return sect; +}
- ret = blk_dread(cur_dev, cur_part_info.start + block, nr_blocks, buf); +inline __u32 size_to_blocks(__u32 size) +{ + return (size + (cur_part_info.blksz - 1)) / cur_part_info.blksz; +}
- if (ret != nr_blocks) - return -1; +static int disk_read(__u32 sect, __u32 nr_sect, void *buf) +{ + int ret; + __u8 *block = NULL; + __u32 rem, size; + __u32 s, n;
- return ret; + rem = nr_sect * fat_sect_size; + /* + * block N block N + 1 block N + 2 + * +-+-+--+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ + * | | | | |s|e|c|t|o|r| | |s|e|c|t|o|r| | |s|e|c|t|o|r| | | | | + * +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ + * . . . | | | | . . . + * ------+---------------+---------------+---------------+------ + * |<--- FAT reads in sectors --->| + * + * | part 1 | part 2 | part 3 | + * + */ + + /* Do part 1 */ + if (fat_sect_size) { + __u32 offset; + + /* Read one block and copy out the leading sectors */ + block = malloc_cache_aligned(cur_dev->blksz); + if (!block) { + printf("Error: allocating block: %lu\n", cur_dev->blksz); + return -1; + } + + s = sect_to_block(sect, &offset); + offset = offset * fat_sect_size; + + ret = blk_dread(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } + + if (rem > (cur_part_info.blksz - offset)) + size = cur_part_info.blksz - offset; + else + size = rem; + + memcpy(buf, block + offset, size); + rem -= size; + buf += size; + s++; + } else { + /* + * fat_sect_size not being set implies, this is the first read + * to partition. The first sector is being read to get the + * FS meta data. The FAT sector size is got from this meta data. + */ + ret = blk_dread(cur_dev, cur_part_info.start + s, 1, buf); + if (ret != 1) + return -1; + } + + /* Do part 2, read directly into the given buffer */ + if (rem > cur_part_info.blksz) { + n = rem / cur_part_info.blksz; + ret = blk_dread(cur_dev, cur_part_info.start + s, n, buf); + if (ret != n) { + ret = -1; + goto exit; + } + buf += n * cur_part_info.blksz; + rem = rem % cur_part_info.blksz; + s += n; + } + + /* Do part 3, read a block and copy the trailing sectors */ + if (rem) { + ret = blk_dread(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } else { + memcpy(buf, block, rem); + } + } +exit: + if (block) + free(block); + + return (ret == -1) ? -1 : nr_sect; +} + +int disk_write(__u32 sect, __u32 nr_sect, void *buf) +{ + int ret; + __u8 *block = NULL; + __u32 rem, size; + __u32 s, n; + + rem = nr_sect * fat_sect_size; + /* + * block N block N + 1 block N + 2 + * +-+-+--+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ + * | | | | |s|e|c|t|o|r| | |s|e|c|t|o|r| | |s|e|c|t|o|r| | | | | + * +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ + * . . . | | | | . . . + * ------+---------------+---------------+---------------+------ + * |<--- FAT reads in sectors --->| + * + * | part 1 | part 2 | part 3 | + * + */ + + /* Do part 1 */ + if (fat_sect_size) { + __u32 offset; + + /* Read one block and overwrite the leading sectors */ + block = malloc_cache_aligned(cur_dev->blksz); + if (!block) { + printf("Error: allocating block: %lu\n", cur_dev->blksz); + return -1; + } + + s = sect_to_block(sect, &offset); + offset = offset * fat_sect_size; + + ret = blk_dread(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } + + if (rem > (cur_part_info.blksz - offset)) + size = cur_part_info.blksz - offset; + else + size = rem; + + memcpy(block + offset, buf, size); + ret = blk_dwrite(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } + + rem -= size; + buf += size; + s++; + } + + /* Do part 2, write directly from the given buffer */ + if (rem > cur_part_info.blksz) { + n = rem / cur_part_info.blksz; + ret = blk_dwrite(cur_dev, cur_part_info.start + s, n, buf); + if (ret != n) { + ret = -1; + goto exit; + } + buf += n * cur_part_info.blksz; + rem = rem % cur_part_info.blksz; + s += n; + } + + /* Do part 3, read a block and copy the trailing sectors */ + if (rem) { + ret = blk_dread(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } else { + memcpy(block, buf, rem); + } + ret = blk_dwrite(cur_dev, cur_part_info.start + s, 1, block); + if (ret != 1) { + ret = -1; + goto exit; + } + } +exit: + if (block) + free(block); + + return (ret == -1) ? -1 : nr_sect; }
int fat_set_blk_dev(struct blk_desc *dev_desc, struct disk_partition *info) @@ -575,6 +765,8 @@ read_bootsectandvi(boot_sector *bs, volume_info *volinfo, int *fatsize) return -1; }
+ fat_sect_size = 0; + if (disk_read(0, 1, block) < 0) { debug("Error: reading block\n"); ret = -1; @@ -645,12 +837,12 @@ static int get_fs_info(fsdata *mydata) mydata->rootdir_sect = mydata->fat_sect + mydata->fatlength * bs.fats;
mydata->sect_size = get_unaligned_le16(bs.sector_size); + fat_sect_size = mydata->sect_size; mydata->clust_size = bs.cluster_size; - if (mydata->sect_size != cur_part_info.blksz) { - log_err("FAT sector size mismatch (fs=%u, dev=%lu)\n", - mydata->sect_size, cur_part_info.blksz); - return -1; - } + if (mydata->sect_size != cur_part_info.blksz) + log_info("FAT sector size mismatch (fs=%u, dev=%lu)\n", + mydata->sect_size, cur_part_info.blksz); + if (mydata->clust_size == 0) { log_err("FAT cluster size not set\n"); return -1; diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index ea877ee917..f7a210d790 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -192,25 +192,6 @@ out: }
static int total_sector; -static int disk_write(__u32 block, __u32 nr_blocks, void *buf) -{ - ulong ret; - - if (!cur_dev) - return -1; - - if (cur_part_info.start + block + nr_blocks > - cur_part_info.start + total_sector) { - printf("error: overflow occurs\n"); - return -1; - } - - ret = blk_dwrite(cur_dev, cur_part_info.start + block, nr_blocks, buf); - if (nr_blocks && ret == 0) - return -1; - - return ret; -}
/* * Write fat buffer into block device
Hi Varadarajan,
Thanks for re-spinning this.
I'd appreciate it if you could just CC me in the v2, then you don't have to reply to the v1 thread.
It would also be great if you could include a changelog so we can keep track of things across versions. Just for future reference.
Kind regards,
- ulong ret;
- *off = 0;
- if (fat_sect_size && fat_sect_size < cur_part_info.blksz) {
*off = sect % div;
return sect / div;
- } else if (fat_sect_size && (fat_sect_size > cur_part_info.blksz)) {
- if (!cur_dev)
return -1;
- return sect;
- return (size + (cur_part_info.blksz - 1)) / cur_part_info.blksz;
return -1;
- int ret;
- __u8 *block = NULL;
- __u32 rem, size;
- __u32 s, n;
- return ret;
- rem = nr_sect * fat_sect_size;
- /* Do part 1 */
- if (fat_sect_size) {
__u32 offset;
if (!block) {
return -1;
if (ret != 1) {
ret = -1;
goto exit;
else
size = rem;
rem -= size;
buf += size;
s++;
- } else {
if (ret != 1)
return -1;
- /* Do part 2, read directly into the given buffer */
- if (rem > cur_part_info.blksz) {
if (ret != n) {
ret = -1;
goto exit;
s += n;
- /* Do part 3, read a block and copy the trailing sectors */
- if (rem) {
if (ret != 1) {
ret = -1;
goto exit;
} else {
+exit:
- if (block)
free(block);
- return (ret == -1) ? -1 : nr_sect;
- int ret;
- __u32 rem, size;
- __u32 s, n;
- /* Do part 1 */
__u32 offset;
if (!block) {
return -1;
if (ret != 1) {
ret = -1;
goto exit;
else
size = rem;
if (ret != 1) {
ret = -1;
goto exit;
rem -= size;
buf += size;
s++;
- /* Do part 2, write directly from the given buffer */
if (ret != n) {
ret = -1;
goto exit;
s += n;
- if (rem) {
if (ret != 1) {
ret = -1;
goto exit;
} else {
if (ret != 1) {
ret = -1;
goto exit;
+exit:
- if (block)
free(block);
- fat_sect_size = 0;
- if (disk_read(0, 1, block) < 0) { debug("Error: reading block\n"); ret = -1;
- fat_sect_size = mydata->sect_size; mydata->clust_size = bs.cluster_size;
return -1;
- if (mydata->clust_size == 0) { log_err("FAT cluster size not set\n"); return -1;
- ulong ret;
- if (!cur_dev)
return -1;
return -1;
return -1;
- return ret;
- Write fat buffer into block device
On Mon, Nov 25, 2024 at 06:47:48PM +0100, Caleb Connolly wrote:
Hi Varadarajan,
Sure, will do it from next version.
Main motivation for this respin to address the comments of V1 * Updated commit description with better explanation * Changed 'fat_sect_size' to be static * Removed the incorrect read related code in write function
Does this suffice, or should I update this in the commit log and post a v3? Please let me know.
Thanks Varada
Kind regards,
- ulong ret;
- *off = 0;
*off = sect % div;
return sect / div;
- if (!cur_dev)
return -1;
- return sect;
return -1;
- int ret;
- __u32 rem, size;
- __u32 s, n;
- return ret;
- /* Do part 1 */
__u32 offset;
if (!block) {
return -1;
if (ret != 1) {
ret = -1;
goto exit;
else
size = rem;
rem -= size;
buf += size;
s++;
- } else {
if (ret != 1)
return -1;
if (ret != n) {
ret = -1;
goto exit;
s += n;
- if (rem) {
if (ret != 1) {
ret = -1;
goto exit;
} else {
+exit:
- if (block)
free(block);
- int ret;
- __u32 rem, size;
- __u32 s, n;
- /* Do part 1 */
__u32 offset;
if (!block) {
return -1;
if (ret != 1) {
ret = -1;
goto exit;
else
size = rem;
if (ret != 1) {
ret = -1;
goto exit;
rem -= size;
buf += size;
s++;
if (ret != n) {
ret = -1;
goto exit;
s += n;
- if (rem) {
if (ret != 1) {
ret = -1;
goto exit;
} else {
if (ret != 1) {
ret = -1;
goto exit;
+exit:
- if (block)
free(block);
return -1;
- ulong ret;
- if (!cur_dev)
return -1;
return -1;
return -1;
- return ret;
-- // Caleb (they/them)
Caleb Connolly
