[PATCH 01/14] rk3308: Remove unused NAND defines
These platforms do not currently enable NAND, remove these references.
Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Tom Rini trini@konsulko.com --- Please note that this file isn't listed in any MAINTAINERS file, but should be, thanks! --- include/configs/rk3308_common.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index edaf78a6e81a..496f4628d34f 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -9,11 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) #define CONFIG_SPL_MAX_SIZE 0x20000 #define CONFIG_SPL_BSS_START_ADDR 0x00400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000
Typically platforms will define CONFIG_SYS_NAND_PAGE_COUNT based on CONFIG_SYS_NAND_BLOCK_SIZE / CONFIG_SYS_NAND_PAGE_SIZE. Switch to this in preparation for migrating CONFIG_SYS_NAND namespace to Kconfig.
Cc: Marek Vasut marex@denx.de Cc: Olaf Mandel o.mandel@menlosystems.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/m53menlo.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 813d326cdaf5..11c8a87c95ad 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -140,9 +140,11 @@ #define CONFIG_SPL_STACK 0x70004000
#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
This converts the following to Kconfig: CONFIG_NAND_LPC32XX_MLC
Signed-off-by: Tom Rini trini@konsulko.com --- configs/work_92105_defconfig | 1 + drivers/mtd/nand/raw/Kconfig | 5 +++++ include/configs/work_92105.h | 1 - 3 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index b09c855ed4b9..d67ec056fa50 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x56 # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_LPC32XX_MLC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_SMSC=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index f7b1334ddb47..a0602e391607 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -118,6 +118,11 @@ config NAND_DENALI_DT Enable the driver for NAND flash on platforms using a Denali NAND controller as a DT device.
+config NAND_LPC32XX_MLC + bool "Support LPC32XX_MLC controller" + help + Enable the LPC32XX MLC NAND controller. + config NAND_LPC32XX_SLC bool "Support LPC32XX_SLC controller" help diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 83b24a7dcc8f..d6addf957b10 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -59,7 +59,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_MAX_NAND_CHIPS 1 #define CONFIG_SYS_NAND_BASE MLC_NAND_BASE -#define CONFIG_NAND_LPC32XX_MLC
/* * GPIO
This converts the following to Kconfig: CONFIG_SPL_NAND_LOAD CONFIG_SYS_NAND_BLOCK_SIZE CONFIG_SYS_NAND_PAGE_SIZE CONFIG_SYS_NAND_OOBSIZE
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-lpc32xx/config.h | 6 ------ configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/am335x_baltos_defconfig | 3 +++ configs/am335x_evm_defconfig | 3 +++ configs/am335x_evm_spiboot_defconfig | 2 ++ configs/am335x_guardian_defconfig | 3 +++ configs/am335x_hs_evm_defconfig | 2 ++ configs/am335x_hs_evm_uart_defconfig | 2 ++ configs/am335x_igep003x_defconfig | 3 +++ configs/am3517_evm_defconfig | 3 +++ configs/am43xx_evm_defconfig | 3 +++ configs/am43xx_evm_rtconly_defconfig | 3 +++ configs/am43xx_evm_usbhost_boot_defconfig | 3 +++ configs/am43xx_hs_evm_defconfig | 3 +++ configs/at91sam9n12ek_nandflash_defconfig | 2 ++ configs/at91sam9x5ek_dataflash_defconfig | 2 ++ configs/at91sam9x5ek_nandflash_defconfig | 2 ++ configs/axm_defconfig | 3 +++ configs/brppt1_nand_defconfig | 3 +++ configs/chiliboard_defconfig | 3 +++ configs/cm_t335_defconfig | 3 +++ configs/cm_t43_defconfig | 2 ++ configs/corvus_defconfig | 3 +++ configs/da850evm_nand_defconfig | 3 +++ configs/devkit3250_defconfig | 3 +++ configs/devkit8000_defconfig | 3 +++ configs/dra7xx_evm_defconfig | 3 +++ configs/dra7xx_hs_evm_defconfig | 2 ++ configs/draco_defconfig | 3 +++ configs/etamin_defconfig | 3 +++ configs/gardena-smart-gateway-at91sam_defconfig | 3 +++ configs/igep00x0_defconfig | 3 +++ configs/ls1021aqds_nand_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/m53menlo_defconfig | 3 +++ configs/omap35_logic_defconfig | 3 +++ configs/omap35_logic_somlv_defconfig | 3 +++ configs/omap3_beagle_defconfig | 3 +++ configs/omap3_evm_defconfig | 3 +++ configs/omap3_logic_defconfig | 3 +++ configs/omap3_logic_somlv_defconfig | 3 +++ configs/omapl138_lcdk_defconfig | 3 +++ configs/phycore-am335x-r2-regor_defconfig | 3 +++ configs/phycore-am335x-r2-wega_defconfig | 3 +++ configs/pxm2_defconfig | 3 +++ configs/rastaban_defconfig | 3 +++ configs/rut_defconfig | 3 +++ configs/sama5d36ek_cmp_nandflash_defconfig | 2 ++ configs/sama5d3_xplained_nandflash_defconfig | 3 +++ configs/sama5d3xek_nandflash_defconfig | 3 +++ configs/sama5d4_xplained_nandflash_defconfig | 3 +++ configs/sama5d4ek_nandflash_defconfig | 3 +++ configs/smartweb_defconfig | 3 +++ configs/taurus_defconfig | 3 +++ configs/thuban_defconfig | 3 +++ configs/ti816x_evm_defconfig | 3 +++ drivers/mtd/nand/raw/Kconfig | 17 ++++++++++++++--- include/configs/P1010RDB.h | 2 -- include/configs/P2041RDB.h | 3 +-- include/configs/T102xRDB.h | 10 ---------- include/configs/T104xRDB.h | 6 ------ include/configs/T208xQDS.h | 3 --- include/configs/T208xRDB.h | 3 --- include/configs/T4240RDB.h | 4 ---- include/configs/am335x_evm.h | 5 ----- include/configs/am335x_guardian.h | 3 --- include/configs/am335x_igep003x.h | 3 --- include/configs/am3517_evm.h | 3 --- include/configs/am43xx_evm.h | 3 --- include/configs/at91sam9m10g45ek.h | 3 --- include/configs/at91sam9n12ek.h | 3 --- include/configs/at91sam9x5ek.h | 3 --- include/configs/baltos.h | 3 --- include/configs/brppt1.h | 3 --- include/configs/chiliboard.h | 3 --- include/configs/cm_t335.h | 3 --- include/configs/cm_t43.h | 3 --- include/configs/corenet_ds.h | 3 +-- include/configs/corvus.h | 3 --- include/configs/da850evm.h | 4 ---- include/configs/devkit3250.h | 3 --- include/configs/devkit8000.h | 3 --- include/configs/dra7xx_evm.h | 3 --- include/configs/etamin.h | 6 ------ include/configs/gardena-smart-gateway-at91sam.h | 3 --- include/configs/ids8313.h | 2 -- include/configs/km/pg-wcom-ls102xa.h | 1 - include/configs/ls1021aqds.h | 3 --- include/configs/ls1043a_common.h | 5 +---- include/configs/ls1043aqds.h | 2 -- include/configs/ls1043ardb.h | 2 -- include/configs/ls1046a_common.h | 2 +- include/configs/ls1046afrwy.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/ls1046ardb.h | 2 -- include/configs/ls1088aqds.h | 2 -- include/configs/ls1088ardb.h | 2 -- include/configs/ls2080aqds.h | 2 -- include/configs/ls2080ardb.h | 1 - include/configs/m53menlo.h | 3 --- include/configs/omap3_beagle.h | 3 --- include/configs/omap3_evm.h | 3 --- include/configs/omap3_igep00x0.h | 3 --- include/configs/omap3_logic.h | 3 --- include/configs/omapl138_lcdk.h | 4 ---- include/configs/p1_p2_rdb_pc.h | 5 ----- include/configs/phycore_am335x_r2.h | 5 ----- include/configs/pm9g45.h | 3 --- include/configs/sama5d3_xplained.h | 3 --- include/configs/sama5d3xek.h | 3 --- include/configs/sama5d4_xplained.h | 3 --- include/configs/sama5d4ek.h | 3 --- include/configs/siemens-am33x-common.h | 3 --- include/configs/smartweb.h | 3 --- include/configs/tam3517-common.h | 3 --- include/configs/taurus.h | 3 --- include/configs/ti816x_evm.h | 4 ---- 134 files changed, 185 insertions(+), 195 deletions(-)
diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 45e46f99463e..00987b5bf5db 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -34,18 +34,12 @@ #define NAND_LARGE_BLOCK_PAGE_SIZE 0x800 #define NAND_SMALL_BLOCK_PAGE_SIZE 0x200
-#if !defined(CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE NAND_LARGE_BLOCK_PAGE_SIZE -#endif - #if (CONFIG_SYS_NAND_PAGE_SIZE == NAND_LARGE_BLOCK_PAGE_SIZE) -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #elif (CONFIG_SYS_NAND_PAGE_SIZE == NAND_SMALL_BLOCK_PAGE_SIZE) -#define CONFIG_SYS_NAND_OOBSIZE 16 #define CONFIG_SYS_NAND_ECCPOS { 10, 11, 12, 13, 14, 15, } #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #else diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 9c09a9e61b54..5e20a07f1b69 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 9bd62ce6228d..ba1c2f9cf239 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 5ba090bdaf16..7bc527dc7aa3 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index e47a277b82ae..8ec6ce56fd6c 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 0ff1f41b842b..8307cce1a138 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 95d97ed735ef..8342c725b903 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 17a1ab962a90..93d02c7abf3a 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index d34a129b52c6..a8cb0845d97a 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 3b57b0c1a640..89294acc9e40 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index dd12941f837e..16445e1ab6ae 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -80,6 +80,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index e92c98c61f02..cccbb647558c 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -74,6 +74,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 0e37eb748f89..652f0fd4827c 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 4b0b78a0f254..5edf6ee94631 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -78,6 +78,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 7255b525a8c3..2d18bcbfae5c 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -79,6 +79,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 3b67e0193768..bf7bb7675abb 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -59,6 +59,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP_HS_ADMA=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x00080000 CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 7fd90ce9fe56..7f986bfb29c4 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -63,6 +63,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 94ea4ecab644..bf5f7d2de7c1 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -62,6 +62,8 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 # CONFIG_SPL_NAND_AM33XX_BCH is not set CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index fe8ddf61e64e..19647a964ee3 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -88,6 +88,9 @@ CONFIG_MISC=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0x100 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x100000 CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x200000 diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 9f96b78fffa0..769c9560c0bd 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -56,6 +56,8 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index a1ee1412bfee..6e8a9191171a 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -58,6 +58,8 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index af94cc090cfb..835a4889b7c8 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -72,6 +72,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHY_SMSC=y CONFIG_MII=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 1234aa2251e4..8f87c0661f97 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -57,6 +57,9 @@ CONFIG_DM_PCA953X=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 4960ec2168f3..4ee678a28164 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -60,6 +60,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 5a170455878d..f6578c58a679 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -47,6 +47,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 14148b209402..e6e54388b8a0 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -63,6 +63,9 @@ CONFIG_MISC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 820fc0754707..e2fb58c98169 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -65,6 +65,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index ab51b702789a..b67cc5716301 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -43,6 +43,8 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index dfbac625d29b..be2d49b51513 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -50,6 +50,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 4ff4f1080f04..ae5368af1068 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -48,6 +48,8 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index a01333847786..4b422df062b6 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -73,6 +73,9 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 88f281c11f82..8ac36de9cbb1 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -89,6 +89,9 @@ CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_PHY_NATSEMI=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f6ae494b8ee4..9efadedbda5a 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -53,6 +53,9 @@ CONFIG_MISC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHY_SMSC=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index fd4e36393b85..2ed83578fbde 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -61,6 +61,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHY_ATHEROS=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 18fbcf0e5821..05a60a5b0639 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -69,6 +69,8 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 72f4310d3cfb..2bbaddf0a903 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -61,6 +61,9 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 6d59cc5d9f84..9555dd34a5d1 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -68,6 +68,9 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 CONFIG_DM_SPI_FLASH=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index a1d277914167..33248e4de1cb 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -53,6 +53,9 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_LPC32XX_SLC=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ADDR=31 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 0ec943a4ae32..be658ce28e42 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -41,6 +41,9 @@ CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_CONS_INDEX=3 CONFIG_OF_LIBFDT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 53e4d82795eb..c4ef0d815f80 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -92,6 +92,9 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 59d5a912cde9..44c189a60f11 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -95,6 +95,8 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/draco_defconfig b/configs/draco_defconfig index dfb98c6daed2..25fcfbd12ed3 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -84,6 +84,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index f60ce5b8fa4d..25a3f6b0d65b 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -85,6 +85,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 9f9d1009a35b..f35ae6077ea7 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -75,6 +75,9 @@ CONFIG_LED_GPIO=y CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index da0d5982b9ab..9e5ea9e379e5 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -60,6 +60,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_SMC911X=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 6fff54b8c581..18da0bd66404 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -86,6 +86,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 57908b43a606..69b07b70a797 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 8e47f8127739..f5e77225bbe1 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 5b839bcc1403..f4e4d958f6d8 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -69,6 +69,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 3976284ac962..90e4a2252f38 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -61,6 +61,7 @@ CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_PHYLIB=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index cd2cab4a08d5..b9f7353298da 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -63,6 +63,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index a0fceb357302..720c2b08f523 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -78,6 +78,9 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index d699efb2faca..452ecfd4d247 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -57,6 +57,9 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 4e31f77049a3..b6c9862ebb69 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -62,6 +62,9 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 89b2bff5925a..d29ff226a856 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -74,6 +74,9 @@ CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 9a86beb6b40f..8baa5641d086 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -62,6 +62,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 9424755b31bc..c442cf7ea0bf 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -57,6 +57,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 96f9c6bcaaaa..760a7db540c0 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -63,6 +63,9 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 80e90230b455..6dcb33b97c4b 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -65,6 +65,9 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index 3de815c0b2ce..af517c527e2f 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -66,6 +66,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_DM_SPI_FLASH=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 5137bec8a0a7..bc6340452bd8 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -66,6 +66,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 624e98ce1bdd..6faf8b3ce8d9 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -84,6 +84,9 @@ CONFIG_SYS_I2C_SPEED=400000 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 1e9def2bb21f..9292935c2b79 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -84,6 +84,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 39f9a0cd3731..0285808c78bc 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -84,6 +84,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index e6418138d69e..81127d80408b 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -49,6 +49,8 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 0fd2c4259c42..14beb803055e 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -69,6 +69,9 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 2e1fdf7b6f1f..b8557aab71a3 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -71,6 +71,9 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index e64240926d9f..94a2e8e344b2 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -66,6 +66,9 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index a3cd8c5300e3..2ab899074605 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -64,6 +64,9 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_SIZE=0x1000 +CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 386963581511..187a001f584d 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -63,6 +63,9 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 0bb28d4d12f7..6ae291299057 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -79,6 +79,9 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 5daa63a14642..b7656d6446d7 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -84,6 +84,9 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index dc24bb852700..bf512ffce416 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -59,6 +59,9 @@ CONFIG_SYS_I2C_OMAP24XX=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_SIZE=0x800 +CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index a0602e391607..5d90983135b5 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -105,6 +105,10 @@ config NAND_DAVINCI Enable this driver for NAND flash controllers available in TI Davinci and Keystone2 platforms
+config SPL_NAND_LOAD + def_bool y + depends on NAND_DAVINCI && ARCH_DAVINCI && SPL_NAND_SUPPORT + config NAND_DENALI bool select SYS_NAND_SELF_INIT @@ -355,7 +359,8 @@ comment "Generic NAND options"
config SYS_NAND_BLOCK_SIZE hex "NAND chip eraseblock size" - depends on ARCH_SUNXI + depends on ARCH_SUNXI || SPL_NAND_SUPPORT || TPL_NAND_SUPPORT + depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC help Number of data bytes in one eraseblock for the NAND chip on the board. This is the multiple of NAND_PAGE_SIZE and the number of @@ -363,14 +368,20 @@ config SYS_NAND_BLOCK_SIZE
config SYS_NAND_PAGE_SIZE hex "NAND chip page size" - depends on ARCH_SUNXI + depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ + SPL_NAND_SIMPLE || (NAND_MXC && SPL_NAND_SUPPORT) || \ + (NAND_ATMEL && SPL_NAND_SUPPORT) || SPL_GENERATE_ATMEL_PMECC_HEADER + depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC help Number of data bytes in one page for the NAND chip on the board, not including the OOB area.
config SYS_NAND_OOBSIZE hex "NAND chip OOB size" - depends on ARCH_SUNXI + depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ + SPL_NAND_SIMPLE || (NAND_MXC && SPL_NAND_SUPPORT) || \ + (NAND_ATMEL && SPL_NAND_SUPPORT) || SPL_GENERATE_ATMEL_PMECC_HEADER + depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC help Number of bytes in the Out-Of-Band area for the NAND chip on the board. diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 02b0b71ada56..edcbc89fa65d 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -309,7 +309,6 @@ extern unsigned long get_sdram_size(void); | CSOR_NAND_PGS_512 /* Page Size = 512b */ \ | CSOR_NAND_SPRZ_16 /* Spare size = 16 */ \ | CSOR_NAND_PB(32)) /* 32 Pages Per Block */ -#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024)
#elif defined(CONFIG_TARGET_P1010RDB_PB) #define CONFIG_SYS_NAND_ONFI_DETECTION @@ -320,7 +319,6 @@ extern unsigned long get_sdram_size(void); | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(128)) /*Pages Per Block = 128 */ -#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) #endif
#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 6da44e7ab828..9bae36ed8f38 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -171,7 +171,6 @@ unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_NAND_BASE_LIST {CONFIG_SYS_NAND_BASE} #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
/* NAND flash config */ #define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ @@ -379,7 +378,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * (128 * 1024)) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 3ae8a14c9445..dc338104bc12 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -264,7 +264,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ -#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) #elif defined(CONFIG_TARGET_T1023RDB) #define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ @@ -273,7 +272,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ | CSOR_NAND_SPRZ_128 /* Spare size = 128 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #endif
#define CONFIG_SYS_NAND_ONFI_DETECTION @@ -520,14 +518,6 @@ unsigned long get_board_sys_clk(void); */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) -#elif defined(CONFIG_MTD_RAW_NAND) -#if defined(CONFIG_TARGET_T1024RDB) -#define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) -#define CONFIG_SYS_QE_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_TARGET_T1023RDB) -#define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) -#define CONFIG_SYS_QE_FW_ADDR (12 * CONFIG_SYS_NAND_BLOCK_SIZE) -#endif #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 910baef00c47..950bcc1d037e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -275,8 +275,6 @@ #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1
-#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) - #if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR @@ -520,8 +518,6 @@ * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (5 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif @@ -530,8 +526,6 @@ #define CONFIG_SYS_QE_FW_ADDR 0x130000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) -#elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_QE_FW_ADDR (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FW_ADDR 0xEFF10000 #endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 315d1f7b01a5..3924e821941d 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -252,7 +252,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_DDR_LAW 11 #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT @@ -500,8 +499,6 @@ unsigned long get_board_sys_clk(void); * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 6824be9e758f..f68a3d7159bb 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -226,7 +226,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_DDR_LAW 11 #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024)
#if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT @@ -454,8 +453,6 @@ unsigned long get_board_sys_clk(void); */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820)
-#elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 54db021ec9ad..3039cc0cd335 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -329,8 +329,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1
-#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) - #if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR @@ -479,8 +477,6 @@ unsigned long get_board_sys_clk(void); * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) -#elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 0f6ffd9ba7c2..31b149ee5791 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -183,9 +183,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ @@ -261,8 +258,6 @@ /* SPL related */ #elif defined(CONFIG_EMMC_BOOT) #define CONFIG_SYS_MMC_MAX_DEVICE 2 -#elif defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif
/* Network. */ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index d93db09c9b5e..1af81ae53ccf 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -110,9 +110,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 4096 -#define CONFIG_SYS_NAND_OOBSIZE 256 -#define CONFIG_SYS_NAND_BLOCK_SIZE (256 * 1024)
#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 95ba949b217b..f11972f91cc1 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -109,9 +109,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index edfd890767d1..e6dc40f2c96e 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -36,9 +36,6 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ 11, 12, 13, 14, 16, 17, 18, 19, 20, \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index ff1949e7e008..cc8e4b79eb07 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -160,9 +160,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_PAGE_SIZE 4096 -#define CONFIG_SYS_NAND_OOBSIZE 224 -#define CONFIG_SYS_NAND_BLOCK_SIZE (256*1024) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 78ff57776707..fb2d120b7da3 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -97,13 +97,10 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 4ae6b66a3b26..8dd84ba9013d 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -116,10 +116,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 33481dc0459f..ea9ddfd8bd32 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -99,10 +99,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 2fe6c8639392..501e8d3ba303 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -212,9 +212,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 9fb861b9a0d1..5786b37d81cf 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -147,11 +147,8 @@ NANDTGTS \ /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 86cac236f96b..812115261f13 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -126,9 +126,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 4ca4f35eb3ff..80a7209d52dc 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -90,9 +90,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index a290cf0cbcc7..91457a601848 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -25,9 +25,6 @@ /* NAND support */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 2a0a6beaf629..afe5f96c860e 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -172,7 +172,6 @@
/* NAND flash config */ #define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ @@ -382,7 +381,7 @@ */ #define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_MTD_RAW_NAND) -#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * (128 * 1024)) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 32f4a10cf56b..fbabfc94b414 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -99,14 +99,11 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_SIZE SZ_2K -#define CONFIG_SYS_NAND_BLOCK_SIZE (SZ_128K) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 34683f60c7a8..6c3e2df1a94c 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -122,8 +122,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define CONFIG_SYS_NAND_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE (2 << 10) -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x40000 #define CONFIG_SYS_NAND_U_BOOT_DST 0xc1080000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST @@ -141,8 +139,6 @@ #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SPL_NAND_LOAD
#ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index c2340b265075..d90e944f0604 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -64,9 +64,6 @@ #define CONFIG_LPC32XX_NAND_SLC_RHOLD 200000000 #define CONFIG_LPC32XX_NAND_SLC_RSETUP 50000000
-#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 -#define CONFIG_SYS_NAND_PAGE_SIZE NAND_LARGE_BLOCK_PAGE_SIZE - /* * USB */ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index a2a1d93faa91..de4c74c65190 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -135,9 +135,6 @@ /* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 46138348a300..a7fe95b921b5 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -85,9 +85,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 47617c2ab39c..4a2b2dbe945a 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -14,9 +14,6 @@
#include "siemens-am33x-common.h" /* NAND specific changes for etamin due to different page size */ -#undef CONFIG_SYS_NAND_PAGE_SIZE -#undef CONFIG_SYS_NAND_OOBSIZE -#undef CONFIG_SYS_NAND_BLOCK_SIZE #undef CONFIG_SYS_NAND_ECCPOS #undef CONFIG_SYS_NAND_U_BOOT_OFFS #undef CONFIG_SYS_ENV_SECT_SIZE @@ -24,9 +21,6 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW
#define CONFIG_SYS_ENV_SECT_SIZE (512 << 10) /* 512 KiB */ -#define CONFIG_SYS_NAND_PAGE_SIZE 4096 -#define CONFIG_SYS_NAND_OOBSIZE 224 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, \ diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 72852a0d91f2..676b9dd413ab 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -61,10 +61,7 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
#define CONFIG_SPL_PAD_TO CONFIG_SYS_NAND_U_BOOT_OFFS diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index e759db2ff2fb..5bd4f3bc8ca4 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -131,8 +131,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_NAND_FSL_ELBC -#define CONFIG_SYS_NAND_PAGE_SIZE (2048) -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) #define NAND_CACHE_PAGES 64
diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 75d109a88d40..f3c3f508ff10 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -141,7 +141,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
/* QRIO FPGA Definitions */ #define CONFIG_SYS_QRIO_BASE 0x70000000 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index a164796dd87a..edd72b3563d6 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -47,7 +47,6 @@ unsigned long get_board_sys_clk(void);
#define CONFIG_SYS_NAND_U_BOOT_SIZE (400 << 10) #define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
@@ -163,8 +162,6 @@ unsigned long get_board_sys_clk(void);
#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 - -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #endif
/* diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index f6909d05a043..5481d100ada8 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -176,10 +176,7 @@
#else -#ifdef CONFIG_NAND_BOOT -/* Store Fman ucode at offeset 0x900000(72 blocks). */ -#define CONFIG_SYS_FMAN_FW_ADDR (72 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SD_BOOT) +#if defined(CONFIG_SD_BOOT) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is * about 1MB (2040 blocks), Env is stored after the image, and the env size is diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 4ef4cacd97d3..6383a3dab68a 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -149,8 +149,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE - -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #endif
#ifdef CONFIG_NAND_BOOT diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 906cd09f6ebb..00a839b10f98 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -112,8 +112,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ #define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 1d8adf97d3c4..242334051c48 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -168,7 +168,7 @@ #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_FMAN_FW_ADDR 0x40900000 #elif defined(CONFIG_NAND_BOOT) -#define CONFIG_SYS_FMAN_FW_ADDR (36 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (36 * (256 * 1024)) #else #define CONFIG_SYS_FMAN_FW_ADDR 0x60900000 #endif diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index 7da08605f5ab..b7db2804c99e 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -60,8 +60,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - /* IFC Timing Params */ #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index b6bbc01304a7..c17430315a5e 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -164,8 +164,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE - -#define CONFIG_SYS_NAND_BLOCK_SIZE (256 * 1024) #endif
#ifdef CONFIG_NAND_BOOT diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index d3f5d8ce95ea..29dd927612aa 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -72,8 +72,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - /* * CPLD */ diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index a7d8cb50fcc1..5e341821596e 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -134,8 +134,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - #define CONFIG_FSL_QIXIS #define CONFIG_SYS_I2C_FPGA_ADDR 0x66 #define QIXIS_LBMAP_SWITCH 6 diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 4a61345db2e5..567f67c5b116 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -113,8 +113,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - #ifndef SPL_NO_QIXIS #define CONFIG_FSL_QIXIS #endif diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index e831d3797d18..6839ba77bb5a 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -139,8 +139,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - #define CONFIG_FSL_QIXIS /* use common QIXIS code */ #define QIXIS_LBMAP_SWITCH 0x06 #define QIXIS_LBMAP_MASK 0x0f diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 5568a48ced9c..1e3ba4f78d7e 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -147,7 +147,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE
-#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) #define CONFIG_FSL_QIXIS /* use common QIXIS code */ #define QIXIS_LBMAP_SWITCH 0x06 #define QIXIS_LBMAP_MASK 0x0f diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 11c8a87c95ad..c7c6dad5fa72 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -140,9 +140,6 @@ #define CONFIG_SPL_STACK 0x70004000
#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 5d300b13f34e..e37c2afbf04c 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -24,9 +24,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index b12e3a402857..65b3ae5703f5 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -29,9 +29,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 0fee2ed921ca..c14a7ac13155 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -77,9 +77,6 @@ /* NAND config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 886f2e9d86f8..03b48253c5fe 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -37,9 +37,6 @@ /* NAND devices */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \ 13, 14, 16, 17, 18, 19, 20, 21, 22, \ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index f60d15b9db12..0420616c9655 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -124,8 +124,6 @@ #define CONFIG_SYS_NAND_HW_ECC_OOBFIRST #define CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE (2 << 10) -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_DST 0xc1080000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST @@ -142,8 +140,6 @@ #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SPL_NAND_LOAD #endif
/* diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 49dbbf07f889..fb1c78ba1273 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -290,11 +290,6 @@
#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#if defined(CONFIG_TARGET_P1020RDB_PD) -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) -#else -#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024) -#endif
#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index 4925fcc8cfd0..a128ace6deee 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -88,9 +88,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ @@ -116,8 +113,6 @@
#ifdef CONFIG_SPI_BOOT #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 -#elif defined(CONFIG_ENV_IS_IN_NAND) -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif
#endif /* ! __CONFIG_PHYCORE_AM335x_R2_H */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index c22f698d31d7..50c8f44e3abd 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -87,13 +87,10 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 20d1d34044aa..6f8716b31b3b 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -71,10 +71,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
/* Falcon boot support on raw MMC */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index ac52e272174c..235e66847436 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -83,10 +83,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 3032297731a0..a0a8e6aea2ea 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -47,10 +47,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x1000 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 224 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x40000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 4e8fe8693ccd..11723dfa71e3 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -47,10 +47,7 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_SIZE 0x1000 #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_OOBSIZE 224 -#define CONFIG_SYS_NAND_BLOCK_SIZE 0x40000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 6ccba95f3052..903919d3a166 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -76,9 +76,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 5bcc3a66d3a6..eac6e23f2f1d 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -169,14 +169,11 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (SZ_256M) -#define CONFIG_SYS_NAND_PAGE_SIZE SZ_2K -#define CONFIG_SYS_NAND_BLOCK_SIZE (SZ_128K) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 166b8397adac..985e22118a4c 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -129,9 +129,6 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 23f1e378e62e..349344cbe1a0 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -171,14 +171,11 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (256 * SZ_1M) -#define CONFIG_SYS_NAND_PAGE_SIZE SZ_2K -#define CONFIG_SYS_NAND_BLOCK_SIZE (SZ_128K) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index cffa79416f90..f039557cd711 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -60,9 +60,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ @@ -78,7 +75,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE
/* SPL */ /* Defines for SPL */
On Wed, Sep 22, 2021 at 02:50:29PM -0400, Tom Rini wrote:
This converts the following to Kconfig: CONFIG_SPL_NAND_LOAD CONFIG_SYS_NAND_BLOCK_SIZE CONFIG_SYS_NAND_PAGE_SIZE CONFIG_SYS_NAND_OOBSIZE
Signed-off-by: Tom Rini trini@konsulko.com
This converts the following to Kconfig: CONFIG_SYS_NAND_PAGE_COUNT
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-lpc32xx/config.h | 2 -- configs/am335x_baltos_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_guardian_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/axm_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/corvus_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/gardena-smart-gateway-at91sam_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/phycore-am335x-r2-regor_defconfig | 1 + configs/phycore-am335x-r2-wega_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/taurus_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + drivers/mtd/nand/raw/Kconfig | 7 +++++++ include/configs/am335x_evm.h | 2 -- include/configs/am335x_guardian.h | 2 -- include/configs/am335x_igep003x.h | 2 -- include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 2 -- include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 2 -- include/configs/brppt1.h | 2 -- include/configs/chiliboard.h | 2 -- include/configs/cm_t335.h | 2 -- include/configs/cm_t43.h | 2 -- include/configs/corvus.h | 2 -- include/configs/da850evm.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 2 -- include/configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/m53menlo.h | 2 -- include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/phycore_am335x_r2.h | 2 -- include/configs/pm9g45.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 -- include/configs/smartweb.h | 2 -- include/configs/tam3517-common.h | 1 - include/configs/taurus.h | 2 -- include/configs/ti816x_evm.h | 2 -- scripts/config_whitelist.txt | 1 - 81 files changed, 50 insertions(+), 55 deletions(-)
diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 00987b5bf5db..22f39cad5916 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -48,8 +48,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 0x100 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #endif /* CONFIG_NAND_LPC32XX_SLC */
/* NOR Flash */ diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index bf7bb7675abb..2e944dc160bb 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -60,6 +60,7 @@ CONFIG_MMC_OMAP_HS_ADMA=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 7f986bfb29c4..2d34dd7c6f4d 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -64,6 +64,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 19647a964ee3..93218dd176c8 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -89,6 +89,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0x100 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 835a4889b7c8..d9b860c624ec 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -73,6 +73,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 8f87c0661f97..665c54a88189 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -58,6 +58,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 4ee678a28164..7bac2dfbbc8f 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -61,6 +61,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index f6578c58a679..187221dccf4b 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -48,6 +48,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index e6e54388b8a0..71456459cbac 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -64,6 +64,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index e2fb58c98169..f6d9493e254f 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -66,6 +66,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_SF_DEFAULT_SPEED=48000000 diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 4b422df062b6..520e2ffcac02 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -74,6 +74,7 @@ CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 8ac36de9cbb1..b681d7005f84 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -90,6 +90,7 @@ CONFIG_MISC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 9efadedbda5a..05c8d890d32f 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -54,6 +54,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHY_SMSC=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 2ed83578fbde..e651677f7f3e 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -62,6 +62,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHY_ATHEROS=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 2bbaddf0a903..7704d08357c5 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -62,6 +62,7 @@ CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 9555dd34a5d1..d6e2a0a292eb 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -69,6 +69,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 33248e4de1cb..4e90af6fdadd 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -54,6 +54,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_LPC32XX_SLC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index be658ce28e42..2a32e54424fb 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -42,6 +42,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index c4ef0d815f80..c5c831e5608b 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -93,6 +93,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 25fcfbd12ed3..a94936b015cd 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 25a3f6b0d65b..53ede52d99ac 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -86,6 +86,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_PAGE_COUNT=0x80 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index f35ae6077ea7..6484ac761056 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -76,6 +76,7 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_ETH=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 9e5ea9e379e5..17e793c313e2 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -61,6 +61,7 @@ CONFIG_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 720c2b08f523..186abd25e906 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 452ecfd4d247..fe37a981e43f 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -58,6 +58,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index b6c9862ebb69..435e0f7e2bb3 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -63,6 +63,7 @@ CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index d29ff226a856..c0830dcfc1e6 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -75,6 +75,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 8baa5641d086..0174b3a669ae 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -63,6 +63,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index c442cf7ea0bf..18e87f125cc5 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -58,6 +58,7 @@ CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 760a7db540c0..1c093162d334 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -64,6 +64,7 @@ CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 6dcb33b97c4b..d48c744f009f 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -66,6 +66,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index af517c527e2f..9425416dce0a 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index bc6340452bd8..dc4ff1c25f88 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 6faf8b3ce8d9..0e12959abaef 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 9292935c2b79..de99506afbb0 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 0285808c78bc..eb00a538ca58 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 14beb803055e..c9484d3c3b36 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -70,6 +70,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_ETH=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index b8557aab71a3..62edd2d49c79 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -72,6 +72,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 94a2e8e344b2..7a3d6fb24d6b 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -67,6 +67,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 2ab899074605..7b633d7959a2 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -65,6 +65,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 CONFIG_DM_SPI_FLASH=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 187a001f584d..bc0d9c048ac1 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -64,6 +64,7 @@ CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_PHYLIB=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 6ae291299057..9e4cdc451859 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -80,6 +80,7 @@ CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index b7656d6446d7..1e5053a104ba 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index bf512ffce416..28ee76318923 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -60,6 +60,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 5d90983135b5..1e94cccbdecc 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -366,6 +366,13 @@ config SYS_NAND_BLOCK_SIZE board. This is the multiple of NAND_PAGE_SIZE and the number of pages.
+config SYS_NAND_PAGE_COUNT + hex "NAND chip page count" + depends on SPL_NAND_SUPPORT && (NAND_ATMEL || NAND_MXC || \ + SPL_NAND_AM33XX_BCH || SPL_NAND_LOAD || SPL_NAND_SIMPLE) + help + Number of pages in the NAND chip. + config SYS_NAND_PAGE_SIZE hex "NAND chip page size" depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 31b149ee5791..c6ef96ec1c8e 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -181,8 +181,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 1af81ae53ccf..903543c678d0 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -108,8 +108,6 @@ #ifdef CONFIG_MTD_RAW_NAND
#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index f11972f91cc1..10a0ed6a3fb5 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -107,8 +107,6 @@
/* NAND config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index e6dc40f2c96e..0a9122fb24c6 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -35,7 +35,6 @@ /* Board NAND Info. */ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ 11, 12, 13, 14, 16, 17, 18, 19, 20, \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index cc8e4b79eb07..49994861d3c3 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -160,8 +160,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index fb2d120b7da3..d322e816b326 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 8dd84ba9013d..6fe1a8353dd8 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -116,7 +116,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index ea9ddfd8bd32..dc5265604cce 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -99,7 +99,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 501e8d3ba303..31aa110d1bae 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -210,8 +210,6 @@
#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 5786b37d81cf..a9b37abad925 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -147,8 +147,6 @@ NANDTGTS \ /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 812115261f13..36dad6cf99fb 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -124,8 +124,6 @@
/* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 80a7209d52dc..70c8f08b0547 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -88,8 +88,6 @@
/* NAND support */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 91457a601848..dc9b40d9c6f2 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index fbabfc94b414..b8411c7a72fd 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -99,8 +99,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 6c3e2df1a94c..8d5831d8d2b1 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -135,7 +135,6 @@ 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, \ 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, \ 59, 60, 61, 62, 63 } -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10 diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index de4c74c65190..c87d9e3dc26f 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -134,7 +134,6 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index a7fe95b921b5..fdc291d25e0d 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -85,8 +85,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 676b9dd413ab..b721ac45ad31 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
#define CONFIG_SPL_PAD_TO CONFIG_SYS_NAND_U_BOOT_OFFS diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index c7c6dad5fa72..5a3eb1e33ee1 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -140,8 +140,6 @@ #define CONFIG_SPL_STACK 0x70004000
#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index e37c2afbf04c..69de19311f5f 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 65b3ae5703f5..6e087fbc9096 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index c14a7ac13155..99d61721d270 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -76,7 +76,6 @@
/* NAND config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 03b48253c5fe..3207eb5c6d77 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \ 13, 14, 16, 17, 18, 19, 20, 21, 22, \ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 0420616c9655..4f7e1a392d58 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -136,7 +136,6 @@ 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, \ 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, \ 54, 55, 56, 57, 58, 59, 60, 61, 62, 63 } -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10 diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index a128ace6deee..099c210e4136 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -86,8 +86,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 50c8f44e3abd..f6fd9a265f96 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 6f8716b31b3b..74cfa93cd933 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -71,7 +71,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
/* Falcon boot support on raw MMC */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 235e66847436..1cada669e077 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -83,7 +83,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index a0a8e6aea2ea..185128ebd8ee 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -47,7 +47,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 11723dfa71e3..e9cf542f9158 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -47,7 +47,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 903919d3a166..aed0ce29f590 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -74,8 +74,6 @@
#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index eac6e23f2f1d..ad8937cca8b7 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -169,8 +169,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (SZ_256M) -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 985e22118a4c..bc2a5d6dc35a 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */
/* NAND boot config */ -#define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 349344cbe1a0..197458eb3917 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -171,8 +171,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (256 * SZ_1M) -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index f039557cd711..4d07a0531c94 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -58,8 +58,6 @@
/* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) /* NAND: driver related configs */ #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 36b8cc1db016..3181c984d00a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2484,7 +2484,6 @@ CONFIG_SYS_NAND_ONFI_DETECTION CONFIG_SYS_NAND_OR_PRELIM CONFIG_SYS_NAND_PAGE_2K CONFIG_SYS_NAND_PAGE_4K -CONFIG_SYS_NAND_PAGE_COUNT CONFIG_SYS_NAND_QUIET CONFIG_SYS_NAND_READY_PIN CONFIG_SYS_NAND_REGS_BASE
This code is unused, drop it.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/mtd/nand/raw/nand_spl_simple.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/drivers/mtd/nand/raw/nand_spl_simple.c b/drivers/mtd/nand/raw/nand_spl_simple.c index 09e053541a9d..ede7dbf15b90 100644 --- a/drivers/mtd/nand/raw/nand_spl_simple.c +++ b/drivers/mtd/nand/raw/nand_spl_simple.c @@ -39,11 +39,6 @@ static int nand_command(int block, int page, uint32_t offs, this->cmd_ctrl(mtd, page_addr & 0xff, NAND_CTRL_ALE); /* A[16:9] */ this->cmd_ctrl(mtd, (page_addr >> 8) & 0xff, NAND_CTRL_ALE); /* A[24:17] */ -#ifdef CONFIG_SYS_NAND_4_ADDR_CYCLE - /* One more address cycle for devices > 32MiB */ - this->cmd_ctrl(mtd, (page_addr >> 16) & 0x0f, - NAND_CTRL_ALE); /* A[28:25] */ -#endif /* Latch in address */ this->cmd_ctrl(mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE);
This converts the following to Kconfig: CONFIG_SYS_NAND_BAD_BLOCK_POS
In order to do this, introduce a choice for HAS_LARGE/SMALL_BADBLOCK_POS as those are the only valid values. Use LARGE as the default as no in-tree boards use SMALL, but it is possible.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-lpc32xx/config.h | 2 -- drivers/mtd/nand/raw/Kconfig | 21 +++++++++++++++++++ include/configs/am335x_evm.h | 1 - include/configs/am335x_guardian.h | 2 -- include/configs/am335x_igep003x.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 1 - include/configs/brppt1.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_t335.h | 1 - include/configs/cm_t43.h | 1 - include/configs/corvus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 1 - .../configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/m53menlo.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/pm9g45.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/smartweb.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/taurus.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/uniphier.h | 1 - 39 files changed, 21 insertions(+), 40 deletions(-)
diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 22f39cad5916..653792c610cb 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -38,10 +38,8 @@ #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, } -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #elif (CONFIG_SYS_NAND_PAGE_SIZE == NAND_SMALL_BLOCK_PAGE_SIZE) #define CONFIG_SYS_NAND_ECCPOS { 10, 11, 12, 13, 14, 15, } -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #else #error "CONFIG_SYS_NAND_PAGE_SIZE set to an invalid value" #endif diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 1e94cccbdecc..006ed80a1112 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -421,6 +421,27 @@ config SYS_NAND_MAX_CHIPS
if SPL
+choice + prompt "NAND bad block marker/indicator positon in the OOB" + depends on SPL_NAND_AM33XX_BCH || SPL_NAND_DENALI || SPL_NAND_SIMPLE || \ + SPL_NAND_SUPPORT && (NAND_ATMEL || NAND_MXC) + default HAS_NAND_LARGE_BADBLOCK_POS + help + In the OOB, which position contains the badblock information. + +config HAS_NAND_LARGE_BADBLOCK_POS + bool "Set the bad block marker/indicator to the 'large' position" + +config HAS_NAND_SMALL_BADBLOCK_POS + bool "Set the bad block marker/indicator to the 'small' position" + +endchoice + +config SYS_NAND_BAD_BLOCK_POS + int + default 0 if HAS_NAND_LARGE_BADBLOCK_POS + default 5 if HAS_NAND_SMALL_BADBLOCK_POS + config SYS_NAND_U_BOOT_LOCATIONS bool "Define U-boot binaries locations in NAND" help diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index c6ef96ec1c8e..a8ee559825cf 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -182,7 +182,6 @@ /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 903543c678d0..087b2d0e6dc6 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -137,8 +137,6 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define MTDIDS_DEFAULT "nand0=nand.0"
-#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS - #endif /* CONFIG_MTD_RAW_NAND */
#define CONFIG_AM335X_USB0 diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 10a0ed6a3fb5..71ecd554b015 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -107,7 +107,6 @@
/* NAND config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 0a9122fb24c6..b70c64f1b2af 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -35,7 +35,6 @@ /* Board NAND Info. */ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ 11, 12, 13, 14, 16, 17, 18, 19, 20, \ 21, 22, 23, 24, 25, 26, 27, 28, 30, \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 49994861d3c3..32b42559602a 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -164,7 +164,6 @@ /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, \ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index d322e816b326..714710327c89 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 6fe1a8353dd8..2611f5b16a0f 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -116,6 +116,5 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index dc5265604cce..08ce67a5e6c8 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -99,6 +99,5 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 31aa110d1bae..8c5d1e77314f 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -210,7 +210,6 @@
#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index a9b37abad925..2f499b39945d 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -147,7 +147,6 @@ NANDTGTS \ /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 36dad6cf99fb..704b2e61a8ac 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -125,7 +125,6 @@ /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 70c8f08b0547..c531ab4ae0ac 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -88,7 +88,6 @@
/* NAND support */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index dc9b40d9c6f2..256a0d01f411 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -25,7 +25,6 @@ /* NAND support */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW diff --git a/include/configs/corvus.h b/include/configs/corvus.h index b8411c7a72fd..027a1c334121 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -99,7 +99,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 8d5831d8d2b1..068e5f6f03be 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -135,7 +135,6 @@ 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, \ 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, \ 59, 60, 61, 62, 63 } -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index c87d9e3dc26f..89221a8429ac 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -134,7 +134,6 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13}
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index fdc291d25e0d..b047dcce0b12 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -89,7 +89,6 @@ /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index b721ac45ad31..d69f2a0dc954 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
#define CONFIG_SPL_PAD_TO CONFIG_SYS_NAND_U_BOOT_OFFS #define CONFIG_SYS_SPL_LEN CONFIG_SPL_PAD_TO diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 5a3eb1e33ee1..6d107a9a9e49 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -141,7 +141,6 @@
#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
/* * Extra Environments diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 69de19311f5f..7c4bbe101a89 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 6e087fbc9096..88590efe71c6 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 99d61721d270..8f3c7d184dc5 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -76,7 +76,6 @@
/* NAND config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 3207eb5c6d77..28406bfbf496 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \ 13, 14, 16, 17, 18, 19, 20, 21, 22, \ 23, 24, 25, 26, 27, 28, 30, 31, 32, \ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 4f7e1a392d58..ab095524fe01 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -136,7 +136,6 @@ 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, \ 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, \ 54, 55, 56, 57, 58, 59, 60, 61, 62, 63 } -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 10 #endif diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index 099c210e4136..02d124549b69 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -87,7 +87,6 @@ /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index f6fd9a265f96..029a7cb62ac0 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 74cfa93cd933..44fc16404ba3 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -71,7 +71,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
/* Falcon boot support on raw MMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x100 /* 128 KiB */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 1cada669e077..b54e63903def 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -83,6 +83,5 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 185128ebd8ee..4aba68eb1bef 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -47,6 +47,5 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index e9cf542f9158..64113b4c763d 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -47,6 +47,5 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0
#endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index aed0ce29f590..4d613c43614b 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -74,7 +74,6 @@
#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index ad8937cca8b7..41881ea050cd 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -169,7 +169,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (SZ_256M) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index ed3aac7f3acb..187d0bb75bb0 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -123,7 +123,6 @@ * NAND Support */ #ifdef CONFIG_NAND_DENALI -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_REGS_BASE SOCFPGA_NANDREGS_ADDRESS diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index bc2a5d6dc35a..6cc8986a1c5a 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -129,7 +129,6 @@
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 #define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ 48, 49, 50, 51, 52, 53, 54, 55,\ 56, 57, 58, 59, 60, 61, 62, 63} diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 197458eb3917..fef55d850c25 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -171,7 +171,6 @@ #define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (256 * SZ_1M) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 4d07a0531c94..74dc9fe15566 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -59,7 +59,6 @@ /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index d419db1fa4bf..88dac390cedc 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_REGS_BASE 0x68100000 #define CONFIG_SYS_NAND_DATA_BASE 0x68000000 -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
/* * Network Configuration
This converts the following to Kconfig: CONFIG_SYS_NAND_5_ADDR_CYCLE
Signed-off-by: Tom Rini trini@konsulko.com --- configs/devkit3250_defconfig | 1 + drivers/mtd/nand/raw/Kconfig | 9 +++++++++ include/configs/am335x_evm.h | 1 - include/configs/am335x_guardian.h | 3 --- include/configs/am335x_igep003x.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 1 - include/configs/brppt1.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_t335.h | 1 - include/configs/cm_t43.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/corvus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/gardena-smart-gateway-at91sam.h | 2 -- include/configs/imx6-engicam.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/pm9g45.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/smartweb.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/taurus.h | 1 - include/configs/ti816x_evm.h | 1 - scripts/config_whitelist.txt | 1 - 44 files changed, 10 insertions(+), 45 deletions(-)
diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 4e90af6fdadd..dc85a8419831 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -57,6 +57,7 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +# CONFIG_SYS_NAND_5_ADDR_CYCLE is not set CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ADDR=31 diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 006ed80a1112..98d09f1e64e5 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -421,6 +421,15 @@ config SYS_NAND_MAX_CHIPS
if SPL
+config SYS_NAND_5_ADDR_CYCLE + bool "Wait 5 address cycles during NAND commands" + depends on SPL_NAND_AM33XX_BCH || SPL_NAND_SIMPLE || \ + (SPL_NAND_SUPPORT && NAND_ATMEL) + default y + help + Some controllers require waiting for 5 address cycles when issuing + some commands, on NAND chips larger than 128MiB. + choice prompt "NAND bad block marker/indicator positon in the OOB" depends on SPL_NAND_AM33XX_BCH || SPL_NAND_DENALI || SPL_NAND_SIMPLE || \ diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index a8ee559825cf..ec34992b2dfe 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -180,7 +180,6 @@
#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 087b2d0e6dc6..43b83630004c 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -106,9 +106,6 @@ #define CONFIG_SYS_BOOTCOUNT_LE
#ifdef CONFIG_MTD_RAW_NAND - -#define CONFIG_SYS_NAND_5_ADDR_CYCLE - #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, \ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 71ecd554b015..ed2685d19e3c 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -106,7 +106,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION 1
/* NAND config */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index b70c64f1b2af..1e9dfaf7e898 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -34,7 +34,6 @@
/* Board NAND Info. */ #ifdef CONFIG_MTD_RAW_NAND -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ 11, 12, 13, 14, 16, 17, 18, 19, 20, \ 21, 22, 23, 24, 25, 26, 27, 28, 30, \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 32b42559602a..38eeeedeef97 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -160,7 +160,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 714710327c89..6f75ca5dcee7 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -95,7 +95,6 @@ #define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 2611f5b16a0f..48ec065a341d 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -115,6 +115,5 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 08ce67a5e6c8..798a10041194 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -98,6 +98,5 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#endif diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 8c5d1e77314f..8ada88dbf85f 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -209,7 +209,6 @@ #ifndef CONFIG_NOR_BOOT
#ifdef CONFIG_MTD_RAW_NAND -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 2f499b39945d..1dfe7d0473bd 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -146,7 +146,6 @@ NANDTGTS \ #define CONFIG_SYS_NAND_BASE 0x8000000 /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 704b2e61a8ac..ed918a7cf254 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_BOOTCOUNT_BE
/* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index c531ab4ae0ac..5ffb760b2fc7 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -87,7 +87,6 @@ /* Network. */
/* NAND support */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 256a0d01f411..6e1ac192e64a 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -24,7 +24,6 @@
/* NAND support */ #define CONFIG_SYS_NAND_ONFI_DETECTION -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 650936643966..298442057c56 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -188,7 +188,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES #endif diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 027a1c334121..de432a4ff78e 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 068e5f6f03be..f7c5d400cf92 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -121,7 +121,6 @@ #undef CONFIG_SYS_NAND_HW_ECC #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define CONFIG_SYS_NAND_HW_ECC_OOBFIRST -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x40000 #define CONFIG_SYS_NAND_U_BOOT_DST 0xc1080000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 89221a8429ac..66c8cd2b6217 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -133,7 +133,6 @@ /* Defines for SPL */
/* NAND boot config */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13}
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index b047dcce0b12..3056a19f4706 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -85,7 +85,6 @@ /* NAND support */ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index d69f2a0dc954..45414f9e61fe 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -60,8 +60,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE
-#define CONFIG_SYS_NAND_5_ADDR_CYCLE - #define CONFIG_SPL_PAD_TO CONFIG_SYS_NAND_U_BOOT_OFFS #define CONFIG_SYS_SPL_LEN CONFIG_SPL_PAD_TO
diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index cf46b54718a6..3435be95bd6f 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -137,7 +137,6 @@ #ifdef CONFIG_NAND_MXS # define CONFIG_SYS_MAX_NAND_DEVICE 1 # define CONFIG_SYS_NAND_BASE 0x40000000 -# define CONFIG_SYS_NAND_5_ADDR_CYCLE # define CONFIG_SYS_NAND_ONFI_DETECTION # define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE # define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index e49370305c6c..520cc176012b 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -129,7 +129,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 5cd51a4af06f..48b8a3091956 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -52,7 +52,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ONFI_DETECTION
/* DMA stuff, needed for GPMI/MXS NAND support */ diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 62b8de3c1aa4..7d8b80efdb54 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -106,7 +106,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ONFI_DETECTION
/* DMA stuff, needed for GPMI/MXS NAND support */ diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 42b729b40bc8..83a94f49c2d3 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -111,7 +111,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ONFI_DETECTION
/* DMA stuff, needed for GPMI/MXS NAND support */ diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 64f017ab77f8..b5c525dc786b 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -114,7 +114,6 @@ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x60000000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #endif
/* OCOTP */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 7c4bbe101a89..113c4ee0120d 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -22,7 +22,6 @@ #if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 88590efe71c6..8d1233c075eb 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -27,7 +27,6 @@ #if defined(CONFIG_MTD_RAW_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 8f3c7d184dc5..ced449d7ad39 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -75,7 +75,6 @@ #define CONFIG_SYS_ONENAND_BLOCK_SIZE (128*1024)
/* NAND config */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 28406bfbf496..f6b5b5f986db 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -35,7 +35,6 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \ 13, 14, 16, 17, 18, 19, 20, 21, 22, \ 23, 24, 25, 26, 27, 28, 30, 31, 32, \ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index ab095524fe01..963cc4fd8fed 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define CONFIG_SYS_NAND_HW_ECC_OOBFIRST #define CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_DST 0xc1080000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index 02d124549b69..e398a018c58c 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -85,7 +85,6 @@
#ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 029a7cb62ac0..6f4bae31cd44 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -85,7 +85,6 @@ #define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 44fc16404ba3..198d8dac7318 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -70,7 +70,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
/* Falcon boot support on raw MMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x100 /* 128 KiB */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index b54e63903def..1bca98c662b1 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -82,6 +82,5 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 4aba68eb1bef..652c4df4d501 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -46,6 +46,5 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 64113b4c763d..4278e17afa68 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -46,6 +46,5 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 4d613c43614b..8fea6073d6ed 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -73,7 +73,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#define CONFIG_SYS_NAND_ONFI_DETECTION -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 41881ea050cd..cc5f5380cfaf 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -166,7 +166,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (SZ_256M) #define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 6cc8986a1c5a..3d540978e968 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */
/* NAND boot config */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47,\ 48, 49, 50, 51, 52, 53, 54, 55,\ 56, 57, 58, 59, 60, 61, 62, 63} diff --git a/include/configs/taurus.h b/include/configs/taurus.h index fef55d850c25..fa4b6f40d77f 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -168,7 +168,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_5_ADDR_CYCLE
#define CONFIG_SYS_NAND_SIZE (256 * SZ_1M) #define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 74dc9fe15566..3124c783cacd 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -57,7 +57,6 @@ /* NAND: SPL related configs */
/* NAND: device related configs */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3181c984d00a..add47458ab48 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2433,7 +2433,6 @@ CONFIG_SYS_MX7_HCLK CONFIG_SYS_MXS_VDD5V_ONLY CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST CONFIG_SYS_NAND_4_ADDR_CYCLE -CONFIG_SYS_NAND_5_ADDR_CYCLE CONFIG_SYS_NAND_ACTL_ALE CONFIG_SYS_NAND_ACTL_CLE CONFIG_SYS_NAND_ACTL_DELAY
This converts the following to Kconfig: CONFIG_SYS_NAND_ONFI_DETECTION
Signed-off-by: Tom Rini trini@konsulko.com --- configs/CHIP_pro_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/am335x_baltos_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_guardian_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/bcm963158_ram_defconfig | 1 + configs/bcm968360bg_ram_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 1 + configs/bcm968580xref_ram_defconfig | 1 + configs/bitmain_antminer_s9_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/comtrend_vr3032u_ram_defconfig | 1 + configs/cortina_presidio-asic-pnand_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/db-xc3-24g4xg_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/harmony_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/kmcent2_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_qspi_spl_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/mvebu_db_cn9130_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/phycore-am335x-r2-regor_defconfig | 1 + configs/phycore-am335x-r2-wega_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/socfpga_secu1_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + configs/tec_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/x530_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + configs/zynq_cse_nand_defconfig | 1 + doc/README.nand | 5 ----- drivers/mtd/nand/raw/Kconfig | 9 ++++++++- include/configs/P1010RDB.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 2 -- include/configs/T208xRDB.h | 2 -- include/configs/T4240RDB.h | 2 -- include/configs/am335x_evm.h | 1 - include/configs/am335x_guardian.h | 1 - include/configs/am335x_igep003x.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/bk4r1.h | 1 - include/configs/broadcom_bcm963158.h | 1 - include/configs/broadcom_bcm968360bg.h | 1 - include/configs/broadcom_bcm968380gerg.h | 1 - include/configs/broadcom_bcm968580xref.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t335.h | 1 - include/configs/cm_t43.h | 1 - include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/comtrend_vr3032u.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/db-xc3-24g4xg.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/etamin.h | 1 - include/configs/imx6-engicam.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/km/pg-wcom-ls102xa.h | 2 -- include/configs/kmcent2.h | 2 -- include/configs/ls1021aqds.h | 2 -- include/configs/ls1043aqds.h | 2 -- include/configs/ls1043ardb.h | 2 -- include/configs/ls1046afrwy.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/ls1046ardb.h | 2 -- include/configs/ls1088aqds.h | 2 -- include/configs/ls1088ardb.h | 2 -- include/configs/ls2080aqds.h | 2 -- include/configs/ls2080ardb.h | 2 -- include/configs/mvebu_armada-8k.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/octeontx_common.h | 1 - include/configs/pcm052.h | 1 - include/configs/pcm058.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/presidio_asic.h | 1 - include/configs/sam9x60ek.h | 1 - include/configs/sama5d2_ptc_ek.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/stm32mp1.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tegra20-common.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/uniphier.h | 1 - include/configs/vf610twr.h | 1 - include/configs/x530.h | 2 -- include/configs/xilinx_zynqmp.h | 1 - include/configs/zynq-common.h | 1 - 237 files changed, 174 insertions(+), 92 deletions(-)
diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 34f609a61d22..29179601907a 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_I2C_SPEED=400000 CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0x100 CONFIG_AXP_ALDO3_VOLT=3300 diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 38efde812a89..72e9725c9ab8 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 7bc527dc7aa3..c811122863a2 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 8ec6ce56fd6c..cc5eb26788c8 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -70,6 +70,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 16445e1ab6ae..8630323b9fbf 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -81,6 +81,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index cccbb647558c..ea563567f04a 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -75,6 +75,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 652f0fd4827c..032145fd0bfd 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 5edf6ee94631..d2330e67646a 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -79,6 +79,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 2d18bcbfae5c..9e1e0a83531f 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 2e944dc160bb..279c28e5ce5a 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -60,6 +60,7 @@ CONFIG_MMC_OMAP_HS_ADMA=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 2d34dd7c6f4d..06ee4c8482bb 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -64,6 +64,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index bf5f7d2de7c1..f6006c518573 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 # CONFIG_SPL_NAND_AM33XX_BCH is not set diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 93218dd176c8..272d5b877514 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -89,6 +89,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0x100 diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 769c9560c0bd..a1958764cbde 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 6e8a9191171a..5038468f88b4 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index d9b860c624ec..9a6f71dc6cf2 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -73,6 +73,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 7bac2dfbbc8f..5f6ec1a48083 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -61,6 +61,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 187221dccf4b..ce77d698aae0 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -48,6 +48,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 71456459cbac..f15f4ebd7241 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -64,6 +64,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index f6d9493e254f..31678f10898e 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -66,6 +66,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 5b6af9e215af..b0ced6cce7e1 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_63158=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPECIFY_CONSOLE_INDEX=y diff --git a/configs/bcm968360bg_ram_defconfig b/configs/bcm968360bg_ram_defconfig index bdc2e1ead79e..36fed4933b54 100644 --- a/configs/bcm968360bg_ram_defconfig +++ b/configs/bcm968360bg_ram_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_68360=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 855f1c24366a..7eb23bdc62b7 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6838=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY=y CONFIG_BCM6368_USBH_PHY=y CONFIG_PINCTRL=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index c5ab9761cef0..b43396f063fd 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6858=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 79cff7505f4d..4cd6a7c102d8 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -66,6 +66,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y CONFIG_NAND_ZYNQ_USE_BOOTLOADER1_TIMINGS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 7691eec0b429..0ed262147947 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -65,6 +65,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 05c8d890d32f..e2560e55025e 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -54,6 +54,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index f6c0daac4235..c0bc6202e242 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -78,6 +78,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index e651677f7f3e..c59dfa6d0d21 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -62,6 +62,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 05a60a5b0639..73ce871f6676 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -69,6 +69,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index f5fd4815d45e..0af56f438a1e 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index c22332c489e9..88d6994153eb 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index c9fb555341dc..88ee270a3228 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -48,6 +48,7 @@ CONFIG_SYS_I2C_TEGRA=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 3fb13ea20cb6..db105cb534b5 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -73,6 +73,7 @@ CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 2cb0bac6c802..c5573264a869 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -49,6 +49,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6368=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_ETH=y CONFIG_BCM6368_ETH=y CONFIG_PHY=y diff --git a/configs/cortina_presidio-asic-pnand_defconfig b/configs/cortina_presidio-asic-pnand_defconfig index 51451fbc43c3..d635891b03db 100644 --- a/configs/cortina_presidio-asic-pnand_defconfig +++ b/configs/cortina_presidio-asic-pnand_defconfig @@ -29,6 +29,7 @@ CONFIG_CORTINA_GPIO=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_CORTINA_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SERIAL=y CONFIG_CORTINA_UART=y CONFIG_WDT=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index af8c372b84b1..0bb0d5931f62 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -59,6 +59,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 26aa5d080a2b..976460a1ce01 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -59,6 +59,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index c32a48a97de6..b2ee2c284313 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -45,6 +45,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index c5c831e5608b..4d24f3a9f784 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -93,6 +93,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 44c189a60f11..09f84190560e 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -95,6 +95,7 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index a94936b015cd..d960ddf6bfec 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 53ede52d99ac..5efadb81305b 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -86,6 +86,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x80 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 2372d17f5fae..6ce4f559e13e 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PCI=y CONFIG_DM_PMIC=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 70d5edf7dae3..29496ef571aa 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -51,6 +51,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 3c2fee90ffa3..c82814a42c5c 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -52,6 +52,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 1200311c330a..e3159ccc2aa2 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -81,6 +81,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index b80f28af01df..d663d38d63db 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -68,6 +68,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 3c2fee90ffa3..c82814a42c5c 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -52,6 +52,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index fcfdb21c3542..90121773eff6 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -52,6 +52,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index d60905758bea..3a2d919dc91c 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -52,6 +52,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index dafd5dacbcea..703db9fba719 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -59,6 +59,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y CONFIG_PHY_MARVELL=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index fea76a0d093f..af181cd91d5d 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -65,6 +65,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 59790da8a754..de4d8dfcac56 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 18da0bd66404..3e23b718e660 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -87,6 +87,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 734e9cd98522..f7d655177b75 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index ae96127392c4..911f8fcc9e7e 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index e3b506dc0e2e..e8d1f8e042f8 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index c7dd54c4b79f..e6a89a009013 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -85,6 +85,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 4c799628603b..dca4023018c8 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 6df098382db9..53648916b3e7 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 69b07b70a797..238c7a34a75f 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 09edcd9600eb..6b22732b96af 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index ae89982b781c..2e8d42414ef6 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 327dc8f3590e..1eb3e1bbef7b 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 7855c7b287c0..fc9106e646b8 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 394ae1e21077..c90c4c600c93 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index cc9bc5a778e5..ccd9afdd578f 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -50,6 +50,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index f5e77225bbe1..edb568b53088 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -62,6 +62,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index f4e4d958f6d8..acf92801f85c 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index fef8121da7f7..0abcaa4c8181 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index a625ec753ad9..23d58befaa73 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index b48d5f49f1e1..2acf64ba5fdd 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index f785d990c23e..52749b443936 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -55,6 +55,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index ebca3c79b87c..16dcdc5b7032 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x52 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 6816fb3ff006..7c83837d60c2 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x52 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 32ed2aa108bd..14847bc186a1 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -57,6 +57,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 240bd0759635..3bc2c871b142 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 27632812bfe8..f69c55db0d6b 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 597938139db4..fb6b0bf4c829 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -71,6 +71,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 7bf63bbf093d..97e8a4218f86 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 8b75fe8aba81..d079baad240a 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index ff0d8ffec075..12304bafaa2b 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index e5402a24a644..06759db40e87 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -69,6 +69,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index cd9e3a464164..e15c6deeec4b 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 93f0e88e3a1d..7f38df088f30 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index a88baafd1e34..56a00fc83d33 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -73,6 +73,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index c4a931589025..a8364a378b94 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -66,6 +66,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 9ed24bb554cd..7da661aa78bf 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -67,6 +67,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index a14df4dc9f09..0b361f63c735 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 85491a37e46f..11a5b10633a4 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index bb7321ddb407..95e88ca2d6c1 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -58,6 +58,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index 70b4a70f303e..a35863e77b88 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 45e8d30374f7..6e3c2cbf3789 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 20efb7510714..067cac4f7ba8 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y CONFIG_PHY_REALTEK=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index e724e8be0de9..3d8bd9c64e13 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -64,6 +64,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 1b32f1f54116..7e63e74ae490 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 5af7d53c4764..f159baaeee04 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -55,6 +55,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 1133dde4dd32..361ec6a5495c 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 7301a09b4dfc..bdb9ff571698 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -68,6 +68,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 17c4c6a794d5..7f9038dccee8 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -68,6 +68,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index dca0cf693056..5f59adca1e6d 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index eeb45cee9414..670bf9ee2380 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 67c8481268d4..64d10ecc46d4 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 61a073dc153f..a516b3a39f69 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -54,6 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 90e4a2252f38..9e988ccbc147 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_PHYLIB=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 51c15637d4fe..673a9b502b74 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_PHYLIB=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index ff953a7bbe4b..46462ab78274 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_PHYLIB=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 6706aa847417..75552b046bf4 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 5d079473a23f..9e2803fc8276 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -54,6 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index b9f7353298da..d6727941e8f7 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -64,6 +64,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 72115712a27c..84bcf8fb5048 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index daf459d136c4..4c957663a12b 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -58,6 +58,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 16d373c4b463..4a6fedca06c3 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -65,6 +65,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index c50d077d2386..2a6f8d09d99d 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/mvebu_db_cn9130_defconfig b/configs/mvebu_db_cn9130_defconfig index ec020ab1dd5c..e0470ce7ab72 100644 --- a/configs/mvebu_db_cn9130_defconfig +++ b/configs/mvebu_db_cn9130_defconfig @@ -55,6 +55,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 4427079422ed..5819fe6d8ea7 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -78,6 +78,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index c9691e1f1f9c..957dc45b298b 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -42,6 +42,7 @@ CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=40000000 diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 59cebf89bf3d..2328403d525c 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -49,6 +49,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 0adfb985f533..aefd91a48d77 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -68,6 +68,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index 6426a332a0af..030aaae4da64 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 05ba20d52b95..90036d0f68db 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index 9425416dce0a..3fd061ae950c 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index dc4ff1c25f88..70b7d9effd4d 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 4000de193975..fc339d56b845 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 0e12959abaef..8f50ecf49854 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index de99506afbb0..c0209f8d5166 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/rut_defconfig b/configs/rut_defconfig index eb00a538ca58..8052f4fae250 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index b262332a7595..ba78ad294dd9 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -59,6 +59,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index 14a809419f4d..bba44e0e4aa4 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -60,6 +60,7 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index a23f1c25b5a1..20cef1167f51 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -70,6 +70,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 5f7dbc6a04a9..94e916db4ad1 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -58,6 +58,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index e7b48d687286..9da97b36821e 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -58,6 +58,7 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 828a79e46a98..908a259e86ef 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -49,6 +49,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 81127d80408b..2bd56d8fbc04 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -49,6 +49,7 @@ CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_DM_SPI_FLASH=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 35241fd75a6a..d39f11e5d848 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -51,6 +51,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 2833717386d4..11ca60f619f3 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -70,6 +70,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index c9484d3c3b36..08be37bc5ef3 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -70,6 +70,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index e1a8ab702547..a39743fc3b41 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -73,6 +73,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 62edd2d49c79..6822f7dc03c4 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -72,6 +72,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 2d22e2d229f1..2bda3e5f44b4 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -74,6 +74,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 4e5c513c4dc7..c25e556357e1 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -66,6 +66,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 7a3d6fb24d6b..16cec8bd0cc5 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -67,6 +67,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index ba529db3b617..a73ef20979d9 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -72,6 +72,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index bfd4d89d23f8..c0fd3ec0f3af 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -64,6 +64,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7b633d7959a2..7f02d4640427 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -65,6 +65,7 @@ CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 9896076e2d53..3d084e521314 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -67,6 +67,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 7a32f36ff4ca..f915b5b00364 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_I2C_TEGRA=y CONFIG_TEGRA_KEYBOARD=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index 963215d14327..2c6a0a143122 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -71,6 +71,7 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DENALI_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=2 # CONFIG_DM_SPI_FLASH is not set diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index b9a9cdc450cd..77ed82c99f79 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -112,6 +112,7 @@ CONFIG_DM_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_SPI_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index 74a7c12d379c..701b1510c5b3 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -92,6 +92,7 @@ CONFIG_DM_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_SPI_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 04564e21fa99..b4ed090e3f03 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -93,6 +93,7 @@ CONFIG_DM_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_STM32_FMC2=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_MTD_SPI_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index b235784a4c0b..7e2aef2dbfb2 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 1e5053a104ba..faa6ea5f1d3e 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -85,6 +85,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 28ee76318923..581203d46808 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -60,6 +60,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 1c2533cc41cb..23fc05a6a2cb 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -46,6 +46,7 @@ CONFIG_MMC_UNIPHIER=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SMC911X=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 19701c278bcc..4ac1f94f51c8 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -47,6 +47,7 @@ CONFIG_MMC_UNIPHIER=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SNI_AVE=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 946665b3b32e..e684291a3f9d 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -47,6 +47,7 @@ CONFIG_MMC_SDHCI_CADENCE=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SNI_AVE=y CONFIG_PINCONF=y CONFIG_SPI=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index add1a071df76..0a7b663ec6b4 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -46,6 +46,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 3544833ae6ae..00df6fe5e593 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -46,6 +46,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index fcc384dcae0c..0f94b54bf619 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -60,6 +60,7 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 3730fcc2230e..84ac43166bad 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -91,6 +91,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 8cc90c6b41c3..a4dabf6191c0 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -54,6 +54,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_MAX_CHIPS=2 CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index fe467f315166..78ddb11adb78 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -54,6 +54,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_ARM_DCC=y CONFIG_PANIC_HANG=y # CONFIG_GZIP is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 278eaae8bffd..78ebff7155c3 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -135,6 +135,7 @@ CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ARASAN=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_MAX_CHIPS=2 CONFIG_SPI_FLASH_BAR=y CONFIG_SF_DUAL_FLASH=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 7774b2751922..c82f13078fa9 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -60,5 +60,6 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ZYNQ=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_ARM_DCC=y # CONFIG_GZIP is not set diff --git a/doc/README.nand b/doc/README.nand index ec461b2dc933..f6460dba6031 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -175,11 +175,6 @@ Configuration Options: flexibility, so that one day we can eliminate the old mechanism.
- CONFIG_SYS_NAND_ONFI_DETECTION - Enables detection of ONFI compliant devices during probe. - And fetching device parameters flashed on device, by parsing - ONFI parameter page. - Platform specific options ========================= CONFIG_NAND_OMAP_GPMC diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 98d09f1e64e5..68f909db4c0e 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -366,6 +366,13 @@ config SYS_NAND_BLOCK_SIZE board. This is the multiple of NAND_PAGE_SIZE and the number of pages.
+config SYS_NAND_ONFI_DETECTION + bool "Enable detection of ONFI compliant devices during probe" + help + Enables detection of ONFI compliant devices during probe. + And fetching device parameters flashed on device, by parsing + ONFI parameter page. + config SYS_NAND_PAGE_COUNT hex "NAND chip page count" depends on SPL_NAND_SUPPORT && (NAND_ATMEL || NAND_MXC || \ @@ -431,7 +438,7 @@ config SYS_NAND_5_ADDR_CYCLE some commands, on NAND chips larger than 128MiB.
choice - prompt "NAND bad block marker/indicator positon in the OOB" + prompt "NAND bad block marker/indicator position in the OOB" depends on SPL_NAND_AM33XX_BCH || SPL_NAND_DENALI || SPL_NAND_SIMPLE || \ SPL_NAND_SUPPORT && (NAND_ATMEL || NAND_MXC) default HAS_NAND_LARGE_BADBLOCK_POS diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index edcbc89fa65d..a826f0bd32c5 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -311,7 +311,6 @@ extern unsigned long get_sdram_size(void); | CSOR_NAND_PB(32)) /* 32 Pages Per Block */
#elif defined(CONFIG_TARGET_P1010RDB_PB) -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index dc338104bc12..0ec10fe79459 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -274,7 +274,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ #endif
-#define CONFIG_SYS_NAND_ONFI_DETECTION /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 950bcc1d037e..0892c4723fb6 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -255,8 +255,6 @@ | CSOR_NAND_SPRZ_224/* Spare size = 224 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 3924e821941d..061338cd15ee 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -233,8 +233,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64 /* Spare size = 64 */\ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index f68a3d7159bb..7c2b45f44cf8 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -207,8 +207,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64 /* Spare size = 64 */\ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 3039cc0cd335..eecdb4b8f24c 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -309,8 +309,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(128)) /*Page Per Block = 128*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ec34992b2dfe..2599d32051cc 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -191,7 +191,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 43b83630004c..fd7d589dd6ce 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -130,7 +130,6 @@ } #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 26 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define MTDIDS_DEFAULT "nand0=nand.0"
diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index ed2685d19e3c..4a303b702c59 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -103,7 +103,6 @@ /* Ethernet support */
/* NAND support */ -#define CONFIG_SYS_NAND_ONFI_DETECTION 1
/* NAND config */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 38eeeedeef97..2f48d5dd2f9e 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -161,7 +161,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 8ada88dbf85f..f55f57ce22e9 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -219,7 +219,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #endif diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 84ea032e2fb7..c377094f11c1 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -61,7 +61,6 @@ #include <linux/sizes.h>
/* NAND support */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 1
#define IMX_FEC1_BASE ENET1_BASE_ADDR diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index 6bdca174a664..3cde48eb04c0 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -29,7 +29,6 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif /* CONFIG_MTD_RAW_NAND */
/* diff --git a/include/configs/broadcom_bcm968360bg.h b/include/configs/broadcom_bcm968360bg.h index 66c12675e6d0..0391f0621819 100644 --- a/include/configs/broadcom_bcm968360bg.h +++ b/include/configs/broadcom_bcm968360bg.h @@ -28,7 +28,6 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif /* CONFIG_MTD_RAW_NAND */
/* diff --git a/include/configs/broadcom_bcm968380gerg.h b/include/configs/broadcom_bcm968380gerg.h index 8d572f6b7636..866de2527d0b 100644 --- a/include/configs/broadcom_bcm968380gerg.h +++ b/include/configs/broadcom_bcm968380gerg.h @@ -9,5 +9,4 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif /* CONFIG_MTD_RAW_NAND */ diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index ba5c3d8bb4da..2a79b6aeb2a3 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -28,7 +28,6 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif /* CONFIG_MTD_RAW_NAND */
/* diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index ed918a7cf254..3ab973f02153 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -134,7 +134,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index a22fd0ee1fe9..1d6c77ee8094 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -145,7 +145,6 @@ #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION /* APBH DMA is required for NAND support */ #endif
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 5ffb760b2fc7..a769fd1672c6 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -104,7 +104,6 @@ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x500000 #endif diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 6e1ac192e64a..9ad883d9ffb1 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -23,7 +23,6 @@ #endif
/* NAND support */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index d95c838eeb97..a2f2de7ea1c8 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -121,7 +121,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* used to initialize CONFIG_SYS_NAND_BASE_LIST which is unused */ #define CONFIG_SYS_NAND_BASE -1 -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* USB Configs */ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 298442057c56..07c26e3d0bab 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -188,7 +188,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES #endif
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index f9d0d926eed9..25a772914a27 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -26,7 +26,6 @@ #endif
#define CONFIG_IPADDR 192.168.10.2 diff --git a/include/configs/comtrend_vr3032u.h b/include/configs/comtrend_vr3032u.h index c4c7029c70a3..fc890af915a7 100644 --- a/include/configs/comtrend_vr3032u.h +++ b/include/configs/comtrend_vr3032u.h @@ -11,5 +11,4 @@ #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif /* CONFIG_MTD_RAW_NAND */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 83f5b71839e2..41216b8b4fce 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -23,7 +23,6 @@ #endif
/* NAND */ -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 9f5e665e6f66..48471993b88f 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -38,7 +38,6 @@ #endif
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/db-xc3-24g4xg.h b/include/configs/db-xc3-24g4xg.h index f04ae487b76a..2c543fe12a80 100644 --- a/include/configs/db-xc3-24g4xg.h +++ b/include/configs/db-xc3-24g4xg.h @@ -18,7 +18,6 @@ /* Environment in SPI NOR flash */
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 3056a19f4706..c0a855f0d328 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -86,7 +86,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ /* NAND: driver related configs */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 4a2b2dbe945a..e1d27ac0c844 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -59,7 +59,6 @@ #define CONFIG_SYS_NAND_BASE_LIST {CONFIG_SYS_NAND_BASE, \ CONFIG_SYS_NAND_BASE2}
-#define CONFIG_SYS_NAND_ONFI_DETECTION #define DDR_PLL_FREQ 303
/* FWD Button = 27 diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 3435be95bd6f..f0c19efb1f06 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -137,7 +137,6 @@ #ifdef CONFIG_NAND_MXS # define CONFIG_SYS_MAX_NAND_DEVICE 1 # define CONFIG_SYS_NAND_BASE 0x40000000 -# define CONFIG_SYS_NAND_ONFI_DETECTION # define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE # define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 520cc176012b..c14ce837acf4 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -129,7 +129,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00500000 diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index f3c3f508ff10..1ce6ac967634 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -115,8 +115,6 @@ | CSOR_NAND_TRHZ_40 \ | CSOR_NAND_BCTLD)
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x3) | \ FTIM0_NAND_TWP(0x8) | \ FTIM0_NAND_TWCHT(0x3) | \ diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index bf876df554f9..93a22555c533 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -278,8 +278,6 @@ CSOR_NAND_TRHZ_40 | /**/ \ CSOR_NAND_BCTLD) /**/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x3) | \ FTIM0_NAND_TWP(0x8) | \ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index edd72b3563d6..4fb6ec490e5e 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -145,8 +145,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 6383a3dab68a..597745bc48d6 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -131,8 +131,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 00a839b10f98..e9cd74d2a12e 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -93,8 +93,6 @@ | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index b7db2804c99e..4bebc31463d8 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -41,8 +41,6 @@ | CSOR_NAND_SPRZ_128 /* Spare size = 128 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index c17430315a5e..c581f5c1b19e 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -146,8 +146,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 29dd927612aa..52c2368a3136 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -53,8 +53,6 @@ | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(64)) /* 64 Pages Per Block */
-#define CONFIG_SYS_NAND_ONFI_DETECTION - #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ FTIM0_NAND_TWP(0x18) | \ FTIM0_NAND_TWCHT(0x7) | \ diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 5e341821596e..27fe2f8f1b62 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -114,8 +114,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 567f67c5b116..875bc1e4a5d8 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -93,8 +93,6 @@ | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 6839ba77bb5a..d2832a67b3ad 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -119,8 +119,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 1e3ba4f78d7e..45f70b18d000 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -127,8 +127,6 @@ unsigned long get_board_sys_clk(void); | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(128)) /* Pages Per Block 128*/
-#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x0e) | \ FTIM0_NAND_TWP(0x30) | \ diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index beecf1838e47..cb8ccb32f593 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -34,7 +34,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_MAX_CHIPS 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* * Ethernet Driver configuration diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 48b8a3091956..5e8446088b1e 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -52,7 +52,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* DMA stuff, needed for GPMI/MXS NAND support */
diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 7d8b80efdb54..df02c523084f 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -106,7 +106,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_ONFI_DETECTION
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 83a94f49c2d3..397af53bec39 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -111,7 +111,6 @@ /* NAND stuff */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* DMA stuff, needed for GPMI/MXS NAND support */ #endif diff --git a/include/configs/octeontx_common.h b/include/configs/octeontx_common.h index 3ceedef1c6ee..83dccf7d8ea2 100644 --- a/include/configs/octeontx_common.h +++ b/include/configs/octeontx_common.h @@ -95,7 +95,6 @@ #if defined(CONFIG_NAND_OCTEONTX) /*#define CONFIG_MTD_CONCAT */ #define CONFIG_SYS_MAX_NAND_DEVICE 8 -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
#endif /* __OCTEONTX_COMMON_H__ */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 5b2e084a2245..244d373843c1 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -13,7 +13,6 @@ #include <linux/stringify.h>
diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 3ca03774506c..a0bb2b505056 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -16,7 +16,6 @@
/* Enable NAND support */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION
/* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index e398a018c58c..935bb7a07c0f 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -96,7 +96,6 @@
/* NAND: SPL related configs */ diff --git a/include/configs/presidio_asic.h b/include/configs/presidio_asic.h index 8606eb1ee727..b22e676ee00e 100644 --- a/include/configs/presidio_asic.h +++ b/include/configs/presidio_asic.h @@ -77,7 +77,6 @@
/* nand driver parameters */ #ifdef CONFIG_TARGET_PRESIDIO_ASIC - #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_BASE CONFIG_SYS_FLASH_BASE diff --git a/include/configs/sam9x60ek.h b/include/configs/sam9x60ek.h index 774ecb419383..df30d4868bd2 100644 --- a/include/configs/sam9x60ek.h +++ b/include/configs/sam9x60ek.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_NAND_MASK_CLE BIT(22) #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD4 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5 -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
#ifdef CONFIG_SD_BOOT diff --git a/include/configs/sama5d2_ptc_ek.h b/include/configs/sama5d2_ptc_ek.h index 1001bbcf930f..1ffe35bd8757 100644 --- a/include/configs/sama5d2_ptc_ek.h +++ b/include/configs/sama5d2_ptc_ek.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_NAND_MASK_ALE BIT(21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE BIT(22) -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 198d8dac7318..f6806f63a0c1 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
/* USB */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 1bca98c662b1..7a50069f1c7f 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -56,7 +56,6 @@ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
/* USB */ diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 652c4df4d501..9aaafc164a5d 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
/* SPL */ diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 4278e17afa68..c39674d89952 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
/* SPL */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 8fea6073d6ed..2c8bda162048 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -72,7 +72,6 @@
#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 187d0bb75bb0..28495bcf18a2 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -124,7 +124,6 @@ */ #ifdef CONFIG_NAND_DENALI #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_REGS_BASE SOCFPGA_NANDREGS_ADDRESS #define CONFIG_SYS_NAND_DATA_BASE SOCFPGA_NANDDATA_ADDRESS #endif diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 4ccaab5b4731..06cd153d135c 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_MMC_MAX_DEVICE 3
/* Ethernet need */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index f7d0a7ef95cc..5d8b6052e4ff 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -91,7 +91,6 @@
#ifdef CONFIG_NAND_SUNXI #define CONFIG_SYS_NAND_MAX_ECCPOS 1664 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 8 #endif
diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index e99e65fd2f47..19934a4cf0b3 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -81,6 +81,5 @@ #define CONFIG_EHCI_IS_TDI
#endif /* _TEGRA20_COMMON_H_ */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 3124c783cacd..3962df5c6160 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -68,7 +68,6 @@
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 88dac390cedc..cc6b96fcd66c 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -54,7 +54,6 @@ #endif
#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_REGS_BASE 0x68100000 #define CONFIG_SYS_NAND_DATA_BASE 0x68000000
diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 49053ce2d79e..29d6c3576b83 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -14,7 +14,6 @@ #define CONFIG_SYS_FSL_CLK
#ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/x530.h b/include/configs/x530.h index 1e5d7381052a..d6aec6d7f255 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -29,7 +29,6 @@ */
/* NAND */ -#define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 1
#define BBT_CUSTOM_SCAN @@ -59,7 +58,6 @@ #endif
#include <asm/arch/config.h>
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index e10d90cdc77b..f8607b761728 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -37,7 +37,6 @@
#ifdef CONFIG_NAND_ARASAN # define CONFIG_SYS_MAX_NAND_DEVICE 1 -# define CONFIG_SYS_NAND_ONFI_DETECTION #endif
#if defined(CONFIG_SPL_BUILD) diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 9b4c54b5e6a0..0c87f19ac366 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -52,7 +52,6 @@
#ifdef CONFIG_NAND_ZYNQ #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION #endif
#ifdef CONFIG_USB_EHCI_ZYNQ
On Wed, Sep 22, 2021 at 02:50:34PM -0400, Tom Rini wrote:
This converts the following to Kconfig: CONFIG_SYS_NAND_ONFI_DETECTION
Signed-off-by: Tom Rini trini@konsulko.com
We only include <linux/mtd/rawnand.h> in <nand.h> for the forward declaration of struct nand_chip, so do that directly. Then, include <linux/mtd/rawnand.h> where required directly.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/ti-common/davinci_nand.h | 1 - arch/arm/mach-imx/cmd_nandbcb.c | 1 + board/cssi/MCR3000/nand.c | 1 + board/freescale/m5329evb/nand.c | 1 + board/freescale/m5373evb/nand.c | 1 + board/socrates/nand.c | 1 + board/xes/common/actl_nand.c | 1 + cmd/nand.c | 1 + drivers/mtd/nand/raw/am335x_spl_bch.c | 1 + drivers/mtd/nand/raw/atmel_nand.c | 1 + drivers/mtd/nand/raw/brcmnand/brcmnand.c | 1 + drivers/mtd/nand/raw/cortina_nand.c | 1 + drivers/mtd/nand/raw/davinci_nand.c | 1 + drivers/mtd/nand/raw/fsl_elbc_spl.c | 1 + drivers/mtd/nand/raw/fsl_upm.c | 1 + drivers/mtd/nand/raw/fsmc_nand.c | 1 + drivers/mtd/nand/raw/kb9202_nand.c | 1 + drivers/mtd/nand/raw/kirkwood_nand.c | 1 + drivers/mtd/nand/raw/kmeter1_nand.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_mlc.c | 1 + drivers/mtd/nand/raw/lpc32xx_nand_slc.c | 1 + drivers/mtd/nand/raw/mxc_nand.c | 1 + drivers/mtd/nand/raw/mxc_nand_spl.c | 1 + drivers/mtd/nand/raw/mxs_nand_spl.c | 1 + drivers/mtd/nand/raw/nand.c | 1 + drivers/mtd/nand/raw/nand_plat.c | 1 + drivers/mtd/nand/raw/nand_spl_simple.c | 1 + drivers/mtd/nand/raw/nand_util.c | 1 + drivers/mtd/nand/raw/octeontx_nand.c | 1 + drivers/mtd/nand/raw/omap_gpmc.c | 1 + drivers/mtd/nand/raw/rockchip_nfc.c | 1 + drivers/mtd/nand/raw/stm32_fmc2_nand.c | 1 + drivers/mtd/nand/raw/sunxi_nand_spl.c | 1 + drivers/mtd/nand/raw/tegra_nand.c | 1 + fs/yaffs2/yaffs_uboot_glue.c | 1 + include/mxs_nand.h | 1 + include/nand.h | 3 ++- 37 files changed, 37 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/ti-common/davinci_nand.h b/arch/arm/include/asm/ti-common/davinci_nand.h index 28842c3b1552..222dd705cd10 100644 --- a/arch/arm/include/asm/ti-common/davinci_nand.h +++ b/arch/arm/include/asm/ti-common/davinci_nand.h @@ -9,7 +9,6 @@ #ifndef _DAVINCI_NAND_H_ #define _DAVINCI_NAND_H_
-#include <linux/mtd/rawnand.h> #include <asm/arch/hardware.h>
#define NAND_READ_START 0x00 diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index cd5134459787..09622c13c980 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -23,6 +23,7 @@ #include <jffs2/jffs2.h> #include <linux/bch.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h>
#include <asm/arch/sys_proto.h> #include <asm/mach-imx/imx-nandbcb.h> diff --git a/board/cssi/MCR3000/nand.c b/board/cssi/MCR3000/nand.c index 15a10bffadc1..11aca4ff7363 100644 --- a/board/cssi/MCR3000/nand.c +++ b/board/cssi/MCR3000/nand.c @@ -8,6 +8,7 @@ #include <config.h> #include <common.h> #include <nand.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h>
#define BIT_CLE ((unsigned short)0x0800) diff --git a/board/freescale/m5329evb/nand.c b/board/freescale/m5329evb/nand.c index 58b8ee51d378..a10c365ec378 100644 --- a/board/freescale/m5329evb/nand.c +++ b/board/freescale/m5329evb/nand.c @@ -15,6 +15,7 @@ #if defined(CONFIG_CMD_NAND) #include <nand.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h>
#define SET_CLE 0x10 #define SET_ALE 0x08 diff --git a/board/freescale/m5373evb/nand.c b/board/freescale/m5373evb/nand.c index 4c30d5100181..fdf3e0ac1b1b 100644 --- a/board/freescale/m5373evb/nand.c +++ b/board/freescale/m5373evb/nand.c @@ -15,6 +15,7 @@ #if defined(CONFIG_CMD_NAND) #include <nand.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h>
#define SET_CLE 0x10 #define SET_ALE 0x08 diff --git a/board/socrates/nand.c b/board/socrates/nand.c index 07c493679bf0..9b7ffee83a41 100644 --- a/board/socrates/nand.c +++ b/board/socrates/nand.c @@ -9,6 +9,7 @@ #if defined(CONFIG_SYS_NAND_BASE) #include <nand.h> #include <linux/errno.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h>
static int state; diff --git a/board/xes/common/actl_nand.c b/board/xes/common/actl_nand.c index 4e52838c9095..2d8a57576a6c 100644 --- a/board/xes/common/actl_nand.c +++ b/board/xes/common/actl_nand.c @@ -8,6 +8,7 @@
/* diff --git a/cmd/nand.c b/cmd/nand.c index d381053c6ac6..df5a4b1db1a0 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -24,6 +24,7 @@ #include <image.h> #include <asm/cache.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h> #include <command.h> #include <console.h> #include <env.h> diff --git a/drivers/mtd/nand/raw/am335x_spl_bch.c b/drivers/mtd/nand/raw/am335x_spl_bch.c index b6fc5f29c7a8..83590a63ccaf 100644 --- a/drivers/mtd/nand/raw/am335x_spl_bch.c +++ b/drivers/mtd/nand/raw/am335x_spl_bch.c @@ -14,6 +14,7 @@ #include <asm/io.h> #include <linux/delay.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h>
static int nand_ecc_pos[] = CONFIG_SYS_NAND_ECCPOS; static struct mtd_info *mtd; diff --git a/drivers/mtd/nand/raw/atmel_nand.c b/drivers/mtd/nand/raw/atmel_nand.c index 6541c3bea851..06bf5ac18ffc 100644 --- a/drivers/mtd/nand/raw/atmel_nand.c +++ b/drivers/mtd/nand/raw/atmel_nand.c @@ -24,6 +24,7 @@ #include <nand.h> #include <watchdog.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h>
#ifdef CONFIG_ATMEL_NAND_HWECC
diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c index 99a1c2e6e2e8..f8434ca88db0 100644 --- a/drivers/mtd/nand/raw/brcmnand/brcmnand.c +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -26,6 +26,7 @@ #include <linux/completion.h> #include <linux/errno.h> #include <linux/log2.h> +#include <linux/mtd/rawnand.h> #include <asm/processor.h> #include <dm.h>
diff --git a/drivers/mtd/nand/raw/cortina_nand.c b/drivers/mtd/nand/raw/cortina_nand.c index 81fa8788a498..c5e97da5e05f 100644 --- a/drivers/mtd/nand/raw/cortina_nand.c +++ b/drivers/mtd/nand/raw/cortina_nand.c @@ -16,6 +16,7 @@ #include <linux/delay.h> #include <linux/iopoll.h> #include <linux/errno.h> +#include <linux/mtd/rawnand.h> #include <asm/gpio.h> #include <fdtdec.h> #include <bouncebuf.h> diff --git a/drivers/mtd/nand/raw/davinci_nand.c b/drivers/mtd/nand/raw/davinci_nand.c index 9ad3a57690e5..0e0b0583db35 100644 --- a/drivers/mtd/nand/raw/davinci_nand.c +++ b/drivers/mtd/nand/raw/davinci_nand.c @@ -30,6 +30,7 @@
#include <common.h> #include <log.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <nand.h> #include <dm/uclass.h> diff --git a/drivers/mtd/nand/raw/fsl_elbc_spl.c b/drivers/mtd/nand/raw/fsl_elbc_spl.c index a62ab69ee1e0..e55b40f8f13c 100644 --- a/drivers/mtd/nand/raw/fsl_elbc_spl.c +++ b/drivers/mtd/nand/raw/fsl_elbc_spl.c @@ -11,6 +11,7 @@
#include <common.h> #include <cpu_func.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/fsl_lbc.h> #include <nand.h> diff --git a/drivers/mtd/nand/raw/fsl_upm.c b/drivers/mtd/nand/raw/fsl_upm.c index 6c86a7e76712..91cc13395372 100644 --- a/drivers/mtd/nand/raw/fsl_upm.c +++ b/drivers/mtd/nand/raw/fsl_upm.c @@ -13,6 +13,7 @@ #include <linux/delay.h> #include <linux/errno.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/fsl_upm.h> #include <nand.h>
diff --git a/drivers/mtd/nand/raw/fsmc_nand.c b/drivers/mtd/nand/raw/fsmc_nand.c index 1c24710b2db6..5d197ce0c51c 100644 --- a/drivers/mtd/nand/raw/fsmc_nand.c +++ b/drivers/mtd/nand/raw/fsmc_nand.c @@ -13,6 +13,7 @@ #include <linux/bitops.h> #include <linux/err.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h> #include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h>
diff --git a/drivers/mtd/nand/raw/kb9202_nand.c b/drivers/mtd/nand/raw/kb9202_nand.c index 0f68f1cd867c..9d26532c7807 100644 --- a/drivers/mtd/nand/raw/kb9202_nand.c +++ b/drivers/mtd/nand/raw/kb9202_nand.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/AT91RM9200.h> #include <asm/arch/hardware.h> diff --git a/drivers/mtd/nand/raw/kirkwood_nand.c b/drivers/mtd/nand/raw/kirkwood_nand.c index 0757fa840b88..621d2d232c88 100644 --- a/drivers/mtd/nand/raw/kirkwood_nand.c +++ b/drivers/mtd/nand/raw/kirkwood_nand.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <asm/arch/soc.h> #include <asm/arch/mpp.h> diff --git a/drivers/mtd/nand/raw/kmeter1_nand.c b/drivers/mtd/nand/raw/kmeter1_nand.c index cf33f2863e1b..b838164bf2e4 100644 --- a/drivers/mtd/nand/raw/kmeter1_nand.c +++ b/drivers/mtd/nand/raw/kmeter1_nand.c @@ -8,6 +8,7 @@ #include <nand.h> #include <asm/io.h> #include <linux/delay.h> +#include <linux/mtd/rawnand.h>
#define CONFIG_NAND_MODE_REG (void *)(CONFIG_SYS_NAND_BASE + 0x20000) #define CONFIG_NAND_DATA_REG (void *)(CONFIG_SYS_NAND_BASE + 0x30000) diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c index b3232ed59d53..5bc5301d6349 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_mlc.c @@ -23,6 +23,7 @@ #include <nand.h> #include <linux/delay.h> #include <linux/errno.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #include <nand.h> #include <asm/arch/clk.h> diff --git a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c index 9cca3c55cc09..3d6cb1dc6350 100644 --- a/drivers/mtd/nand/raw/lpc32xx_nand_slc.c +++ b/drivers/mtd/nand/raw/lpc32xx_nand_slc.c @@ -15,6 +15,7 @@ #include <nand.h> #include <linux/bug.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h> #include <linux/errno.h> #include <asm/io.h> #include <asm/arch/config.h> diff --git a/drivers/mtd/nand/raw/mxc_nand.c b/drivers/mtd/nand/raw/mxc_nand.c index 59cef205754b..6640dc67bd8c 100644 --- a/drivers/mtd/nand/raw/mxc_nand.c +++ b/drivers/mtd/nand/raw/mxc_nand.c @@ -10,6 +10,7 @@ #include <nand.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX35) || \ defined(CONFIG_MX51) || defined(CONFIG_MX53) diff --git a/drivers/mtd/nand/raw/mxc_nand_spl.c b/drivers/mtd/nand/raw/mxc_nand_spl.c index 2f054b60ed72..0fea307ea461 100644 --- a/drivers/mtd/nand/raw/mxc_nand_spl.c +++ b/drivers/mtd/nand/raw/mxc_nand_spl.c @@ -13,6 +13,7 @@ #include <common.h> #include <hang.h> #include <nand.h> +#include <linux/mtd/rawnand.h> #include <asm/arch/imx-regs.h> #include <asm/io.h> #include "mxc_nand.h" diff --git a/drivers/mtd/nand/raw/mxs_nand_spl.c b/drivers/mtd/nand/raw/mxs_nand_spl.c index 17f46ae5e919..b85cb9f4d30f 100644 --- a/drivers/mtd/nand/raw/mxs_nand_spl.c +++ b/drivers/mtd/nand/raw/mxs_nand_spl.c @@ -13,6 +13,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <linux/mtd/rawnand.h>
static struct mtd_info *mtd; static struct nand_chip nand_chip; diff --git a/drivers/mtd/nand/raw/nand.c b/drivers/mtd/nand/raw/nand.c index 026419e4e646..59ad1392b0e6 100644 --- a/drivers/mtd/nand/raw/nand.c +++ b/drivers/mtd/nand/raw/nand.c @@ -9,6 +9,7 @@ #include <nand.h> #include <errno.h> #include <linux/mtd/concat.h> +#include <linux/mtd/rawnand.h>
#ifndef CONFIG_SYS_NAND_BASE_LIST #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } diff --git a/drivers/mtd/nand/raw/nand_plat.c b/drivers/mtd/nand/raw/nand_plat.c index 335c3e34714c..81e7aa218d54 100644 --- a/drivers/mtd/nand/raw/nand_plat.c +++ b/drivers/mtd/nand/raw/nand_plat.c @@ -15,6 +15,7 @@ */
#include <common.h> +#include <linux/mtd/rawnand.h> #include <asm/io.h> #ifdef NAND_PLAT_GPIO_DEV_READY # include <asm/gpio.h> diff --git a/drivers/mtd/nand/raw/nand_spl_simple.c b/drivers/mtd/nand/raw/nand_spl_simple.c index ede7dbf15b90..727861c8f7ee 100644 --- a/drivers/mtd/nand/raw/nand_spl_simple.c +++ b/drivers/mtd/nand/raw/nand_spl_simple.c @@ -8,6 +8,7 @@ #include <nand.h> #include <asm/io.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h>
static int nand_ecc_pos[] = CONFIG_SYS_NAND_ECCPOS; static struct mtd_info *mtd; diff --git a/drivers/mtd/nand/raw/nand_util.c b/drivers/mtd/nand/raw/nand_util.c index 00c3c6c41226..ea246c486d3e 100644 --- a/drivers/mtd/nand/raw/nand_util.c +++ b/drivers/mtd/nand/raw/nand_util.c @@ -30,6 +30,7 @@
#include <linux/errno.h> #include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h> #include <nand.h> #include <jffs2/jffs2.h>
diff --git a/drivers/mtd/nand/raw/octeontx_nand.c b/drivers/mtd/nand/raw/octeontx_nand.c index e0ccc7b0d90d..75476c098fe9 100644 --- a/drivers/mtd/nand/raw/octeontx_nand.c +++ b/drivers/mtd/nand/raw/octeontx_nand.c @@ -23,6 +23,7 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/nand_bch.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h> #include <asm/global_data.h> #include <asm/io.h> #include <asm/types.h> diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index 97fd5690f518..530574898ce6 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -11,6 +11,7 @@ #include <asm/arch/mem.h> #include <linux/mtd/omap_gpmc.h> #include <linux/mtd/nand_ecc.h> +#include <linux/mtd/rawnand.h> #include <linux/bch.h> #include <linux/compiler.h> #include <nand.h> diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 21776f3b14ce..d016d2557531 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -21,6 +21,7 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/nand.h> #include <linux/mtd/partitions.h> +#include <linux/mtd/rawnand.h> #include <memalign.h> #include <nand.h>
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index fd81a9500b8b..0e59c9ef5644 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -19,6 +19,7 @@ #include <linux/err.h> #include <linux/iopoll.h> #include <linux/ioport.h> +#include <linux/mtd/rawnand.h>
/* Bad block marker length */ #define FMC2_BBM_LEN 2 diff --git a/drivers/mtd/nand/raw/sunxi_nand_spl.c b/drivers/mtd/nand/raw/sunxi_nand_spl.c index 85d8013b1a6b..a29a76c58d3a 100644 --- a/drivers/mtd/nand/raw/sunxi_nand_spl.c +++ b/drivers/mtd/nand/raw/sunxi_nand_spl.c @@ -12,6 +12,7 @@ #include <linux/bitops.h> #include <linux/ctype.h> #include <linux/delay.h> +#include <linux/mtd/rawnand.h>
/* registers */ #define NFC_CTL 0x00000000 diff --git a/drivers/mtd/nand/raw/tegra_nand.c b/drivers/mtd/nand/raw/tegra_nand.c index 6310253efa6a..8e70c8e73b63 100644 --- a/drivers/mtd/nand/raw/tegra_nand.c +++ b/drivers/mtd/nand/raw/tegra_nand.c @@ -19,6 +19,7 @@ #include <linux/bug.h> #include <linux/delay.h> #include <linux/errno.h> +#include <linux/mtd/rawnand.h> #include <asm/gpio.h> #include <fdtdec.h> #include <bouncebuf.h> diff --git a/fs/yaffs2/yaffs_uboot_glue.c b/fs/yaffs2/yaffs_uboot_glue.c index 7a15a02974d0..ec8d028316a0 100644 --- a/fs/yaffs2/yaffs_uboot_glue.c +++ b/fs/yaffs2/yaffs_uboot_glue.c @@ -35,6 +35,7 @@ #else #include "malloc.h" #endif +#include <linux/mtd/rawnand.h>
unsigned yaffs_trace_mask = 0x0; /* Disable logging */ static int yaffs_errno; diff --git a/include/mxs_nand.h b/include/mxs_nand.h index c0cefaca90b6..66c909318d1f 100644 --- a/include/mxs_nand.h +++ b/include/mxs_nand.h @@ -8,6 +8,7 @@ */
#include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h> #include <asm/cache.h> #include <nand.h> #include <asm/mach-imx/dma.h> diff --git a/include/nand.h b/include/nand.h index 80dd6469bc05..75c605193ab1 100644 --- a/include/nand.h +++ b/include/nand.h @@ -31,7 +31,6 @@ unsigned long nand_size(void);
#include <linux/compat.h> #include <linux/mtd/mtd.h> -#include <linux/mtd/rawnand.h>
int nand_mtd_to_devnum(struct mtd_info *mtd);
@@ -39,6 +38,8 @@ int nand_mtd_to_devnum(struct mtd_info *mtd); void board_nand_init(void); int nand_register(int devnum, struct mtd_info *mtd); #else +struct nand_chip; + extern int board_nand_init(struct nand_chip *nand); #endif
This converts the following to Kconfig: CONFIG_SYS_NAND_MAX_CHIPS
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/mtd/Kconfig | 8 ++++++++ drivers/mtd/nand/raw/Kconfig | 7 ------- include/configs/MCR3000.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/etamin.h | 2 -- include/configs/ids8313.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/presidio_asic.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - include/linux/mtd/bbm.h | 5 ----- 10 files changed, 8 insertions(+), 20 deletions(-)
diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index b303fabe0f05..83c055a26ef5 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -111,6 +111,14 @@ config HBMC_AM654
source "drivers/mtd/nand/Kconfig"
+config SYS_NAND_MAX_CHIPS + int "NAND max chips" + depends on MTD_RAW_NAND || CMD_ONENAND || TARGET_S5PC210_UNIVERSAL || \ + SPL_OMAP3_ID_NAND + default 1 + help + The maximum number of NAND chips per device to be supported. + source "drivers/mtd/spi/Kconfig"
source "drivers/mtd/ubi/Kconfig" diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 68f909db4c0e..2d67b1b1284e 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -419,13 +419,6 @@ config SYS_NAND_BUSWIDTH_16BIT not available while configuring controller. So a static CONFIG_NAND_xx is needed to know the device's bus-width in advance.
-config SYS_NAND_MAX_CHIPS - int "NAND max chips" - default 1 - depends on NAND_ARASAN - help - The maximum number of NAND chips per device to be supported. - if SPL
config SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 65c16380ee52..73858c56e515 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -95,7 +95,6 @@
/* NAND configuration part */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_BASE 0x0C000000
#endif /* __CONFIG_H */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 1d6c77ee8094..c1b6847ef844 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -143,7 +143,6 @@ /* NAND */ #ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* APBH DMA is required for NAND support */ #endif diff --git a/include/configs/etamin.h b/include/configs/etamin.h index e1d27ac0c844..229a695c12eb 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -51,8 +51,6 @@
-#define CONFIG_SYS_NAND_MAX_CHIPS 1 - #undef CONFIG_SYS_MAX_NAND_DEVICE #define CONFIG_SYS_MAX_NAND_DEVICE 3 #define CONFIG_SYS_NAND_BASE2 (0x18000000) /* physical address */ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 5bd4f3bc8ca4..5e2f377749f0 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -129,7 +129,6 @@ */ #define CONFIG_SYS_NAND_BASE 0xE1000000 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_NAND_FSL_ELBC #define NAND_CACHE_PAGES 64
diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index cb8ccb32f593..2f8be2ee4948 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -33,7 +33,6 @@ /* When runtime detection fails this is the default */
/* * Ethernet Driver configuration diff --git a/include/configs/presidio_asic.h b/include/configs/presidio_asic.h index b22e676ee00e..8d689d9e4be1 100644 --- a/include/configs/presidio_asic.h +++ b/include/configs/presidio_asic.h @@ -78,7 +78,6 @@ /* nand driver parameters */ #ifdef CONFIG_TARGET_PRESIDIO_ASIC #define CONFIG_SYS_MAX_NAND_DEVICE 1 - #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #endif diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 690ef0e14471..50d6cef84c25 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -131,7 +131,6 @@ #define CONFIG_SYS_NAND_LARGEPAGE #define CONFIG_SYS_NAND_BASE_LIST { 0x30000000, } #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_SYS_NAND_NO_SUBPAGE_WRITE
#define DFU_ALT_INFO_MMC \ diff --git a/include/linux/mtd/bbm.h b/include/linux/mtd/bbm.h index 7239eb1125c7..fb86f1ddef9c 100644 --- a/include/linux/mtd/bbm.h +++ b/include/linux/mtd/bbm.h @@ -15,11 +15,6 @@ #ifndef __LINUX_MTD_BBM_H #define __LINUX_MTD_BBM_H
-/* The maximum number of NAND chips in an array */ -#ifndef CONFIG_SYS_NAND_MAX_CHIPS -#define CONFIG_SYS_NAND_MAX_CHIPS 1 -#endif - /** * struct nand_bbt_descr - bad block table descriptor * @options: options for this descriptor
This converts the following to Kconfig: CONFIG_NAND_FSL_ELBC CONFIG_NAND_FSL_IFC
Note that a number of PowerPC platforms had previously enabled CONFIG_NAND_FSL_ELBC without CONFIG_MTD_RAW_NAND, and now they no longer enable the option, reducing the size of a few functions.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/include/asm/config_mpc85xx.h | 2 -- configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/kmcent2_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_qspi_spl_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + drivers/mtd/nand/raw/Kconfig | 11 +++++++++++ include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/P3041DS.h | 1 - include/configs/P5040DS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/ids8313.h | 1 - include/configs/km/pg-wcom-ls102xa.h | 1 - include/configs/kmcent2.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 3 --- include/configs/ls1046afrwy.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls1088aqds.h | 1 - include/configs/ls1088ardb.h | 4 ---- include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/p1_p2_rdb_pc.h | 11 ++--------- 108 files changed, 96 insertions(+), 38 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index cfe74bcb84a2..7eb45664e69c 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -167,7 +167,6 @@ #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 -#define CONFIG_NAND_FSL_IFC #define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_ARCH_BSC9132) @@ -179,7 +178,6 @@ #define CONFIG_SYS_FSL_DSP_M3_RAM_ADDR 0xc0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_ESDHC_HC_BLK_ADDR diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 5e20a07f1b69..628880ae0bec 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index ba1c2f9cf239..caac1e5e6dfe 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index c811122863a2..99dbf2c9caa6 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index cc5eb26788c8..76a81b6dad6c 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 8307cce1a138..3abcb7178dff 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -68,6 +68,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 8342c725b903..cd573cbc5d3a 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 93d02c7abf3a..3b5a14b1ac0a 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -71,6 +71,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index a8cb0845d97a..3d72d46ee27e 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 89294acc9e40..c700ee42cc07 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x4000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index d979b14c9c18..5e6f3be59449 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 7d6164de33d3..6d1f346b4a2a 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 9707f0c80be0..87e88d427cab 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -50,6 +50,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 8630323b9fbf..9330f71f3124 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -80,6 +80,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index ea563567f04a..b4a5ff735de5 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -74,6 +74,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 032145fd0bfd..5f3ec9c8a2c9 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index d2330e67646a..72e3d50a76fa 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -78,6 +78,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 9e1e0a83531f..c7482d6e7c5c 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -79,6 +79,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 8435de16338d..1237edcd7350 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -170,6 +170,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_ELBC=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index 703db9fba719..66262d5e5f53 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -59,6 +59,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index af181cd91d5d..0cd9208a511a 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -65,6 +65,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index de4d8dfcac56..8ebb5e902b47 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 3e23b718e660..2d5059b5dd71 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -86,6 +86,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index f7d655177b75..370fd4eb04e8 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 911f8fcc9e7e..cd681906bfc3 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -66,6 +66,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index e8d1f8e042f8..0e77ee1e1465 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index e6a89a009013..7538d1a22538 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -85,6 +85,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index dca4023018c8..582276c12226 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 53648916b3e7..7b916993a6b7 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 238c7a34a75f..806c38ee46b9 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -79,6 +79,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 6b22732b96af..71fc4a609cf5 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 2e8d42414ef6..18aee4f16d3b 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 1eb3e1bbef7b..bb4a5f2c21a1 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index fc9106e646b8..50ac7d00f75e 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index c90c4c600c93..f79bb3f5503d 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index ccd9afdd578f..62f71b149d67 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -50,6 +50,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index edb568b53088..50da8eb5deb0 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index acf92801f85c..a03e3d0665da 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -69,6 +69,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 0abcaa4c8181..118bbe0b66ad 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -64,6 +64,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 23d58befaa73..82508f651a73 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 2acf64ba5fdd..c23a8d84cbb0 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 52749b443936..e8e11c36207f 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -55,6 +55,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index 16dcdc5b7032..c8310b6bb2b3 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x52 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 7c83837d60c2..9c04bfc421c5 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x52 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 14847bc186a1..9daae250ff0a 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -57,6 +57,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 3bc2c871b142..d273aa30d5a7 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index f69c55db0d6b..76fb0af53f62 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -61,6 +61,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index fb6b0bf4c829..c325ee3b39ce 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -71,6 +71,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 97e8a4218f86..706704bdde0d 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -80,6 +80,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index d079baad240a..3f2641fa67cf 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 12304bafaa2b..a93ce1935bb1 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 06759db40e87..3c1a914641a0 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -69,6 +69,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index e15c6deeec4b..8b19b8706b9c 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 7f38df088f30..923466892ccb 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 56a00fc83d33..4b1befee8283 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -73,6 +73,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index a8364a378b94..8322baa0dde7 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -66,6 +66,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 7da661aa78bf..4af65b5bbc72 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -67,6 +67,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index 0b361f63c735..3177ec4d07d6 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 11a5b10633a4..28000fa7e36b 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x53 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 95e88ca2d6c1..6438194b0e99 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -58,6 +58,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index a35863e77b88..bb9c4ec3cb98 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 6e3c2cbf3789..cf84f2a603b4 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 067cac4f7ba8..867481426ccc 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -69,6 +69,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 3d8bd9c64e13..210e59c97476 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -64,6 +64,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 7e63e74ae490..2c343cb63593 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -70,6 +70,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index f159baaeee04..c06a24a7e209 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -55,6 +55,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 361ec6a5495c..cc3e92214865 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index bdb9ff571698..59e602f6999b 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -68,6 +68,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 7f9038dccee8..10e994b2697b 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -68,6 +68,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index 5f59adca1e6d..076394e55ad2 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 670bf9ee2380..2393e4d0dd9e 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 64d10ecc46d4..4f1302adeb09 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index a516b3a39f69..3007802c40e0 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -54,6 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 9e988ccbc147..f4072db11a6e 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -61,6 +61,7 @@ CONFIG_SYS_I2C_EARLY_INIT=y CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 673a9b502b74..0dd53830bdef 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 46462ab78274..7e0a7ea841dc 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x57 CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 75552b046bf4..b5e85f450cc5 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 9e2803fc8276..4d6594ac61ab 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -54,6 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index d6727941e8f7..e26acc50c39f 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -63,6 +63,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHYLIB=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 84bcf8fb5048..323fbdf1f283 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -67,6 +67,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 4c957663a12b..00b9ee271db9 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -58,6 +58,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 4a6fedca06c3..a0f096159036 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -65,6 +65,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index 030aaae4da64..1a11879a055a 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 90036d0f68db..c5da04773ceb 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 2d67b1b1284e..df7a5513d085 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -122,6 +122,17 @@ config NAND_DENALI_DT Enable the driver for NAND flash on platforms using a Denali NAND controller as a DT device.
+config NAND_FSL_ELBC + bool "Support Freescale Enhanced Local Bus Controller FCM NAND driver" + depends on FSL_ELBC + help + Enable the Freescale Enhanced Local Bus Controller FCM NAND driver. + +config NAND_FSL_IFC + bool "Support Freescale Integrated Flash Controller NAND driver" + help + Enable the Freescale Integrated Flash Controller NAND driver. + config NAND_LPC32XX_MLC bool "Support LPC32XX_MLC controller" help diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index a826f0bd32c5..7be88cee124d 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -14,7 +14,6 @@ #include <linux/stringify.h>
#include <asm/config_mpc85xx.h> -#define CONFIG_NAND_FSL_IFC
#ifdef CONFIG_SDCARD #define CONFIG_SPL_FLUSH_IMAGE diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 9bae36ed8f38..bcd66133f80b 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -159,7 +159,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_RAMBOOT #endif
-#define CONFIG_NAND_FSL_ELBC /* Nand Flash */ #ifdef CONFIG_NAND_FSL_ELBC #define CONFIG_SYS_NAND_BASE 0xffa00000 diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index 2f6cc5d8e14d..f1417b1bfc15 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -9,7 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_NAND_FSL_ELBC #define CONFIG_FSL_SATA_V2 #define CONFIG_PCIE3 #define CONFIG_PCIE4 diff --git a/include/configs/P5040DS.h b/include/configs/P5040DS.h index 12666d6ee6f4..fc2a07b97410 100644 --- a/include/configs/P5040DS.h +++ b/include/configs/P5040DS.h @@ -9,7 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_NAND_FSL_ELBC #define CONFIG_PCIE3 #define CONFIG_FSL_SATA_V2 #define CONFIG_SYS_FSL_RAID_ENGINE diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 0ec10fe79459..92c1a02a95c0 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -242,7 +242,6 @@ unsigned long get_board_sys_clk(void); #endif
/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_BASE 0xff800000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 0892c4723fb6..f664eaf1a7e6 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -236,7 +236,6 @@ #define CONFIG_SYS_CS2_FTIM3 0x0
/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_BASE 0xff800000 #define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE)
diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 061338cd15ee..68d44ff08bd3 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -214,7 +214,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS3_FTIM3 0x0
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 7c2b45f44cf8..d1809bd7137b 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -188,7 +188,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS2_FTIM3 0x0
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index eecdb4b8f24c..cafedacdc272 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -288,7 +288,6 @@ unsigned long get_board_sys_clk(void); + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2 #define CONFIG_SYS_NAND_BASE 0xff800000 diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 5e2f377749f0..370f7ed2bcb6 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -129,7 +129,6 @@ */ #define CONFIG_SYS_NAND_BASE 0xE1000000 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC #define NAND_CACHE_PAGES 64
diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 1ce6ac967634..a5bc6895575f 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -94,7 +94,6 @@ #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3
/* NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_BASE 0x68000000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE
diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index 93a22555c533..91b50cb29af5 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -256,7 +256,6 @@ #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS}
/* NAND Flash on IFC CS1*/ -#define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_BASE 0xfa000000 #define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE)
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 4fb6ec490e5e..795c8e599499 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -125,7 +125,6 @@ unsigned long get_board_sys_clk(void); /* * NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 597745bc48d6..5df42d93ae2e 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -111,7 +111,6 @@ unsigned long get_board_sys_clk(void); /* * NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index e9cd74d2a12e..f367ad69e208 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -72,9 +72,6 @@ /* * NAND Flash Definitions */ -#ifndef SPL_NO_IFC -#define CONFIG_NAND_FSL_IFC -#endif
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index 4bebc31463d8..5b78c5f7ab6a 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -22,7 +22,6 @@ /* * NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index c581f5c1b19e..ca4b856ec91a 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -126,7 +126,6 @@ unsigned long get_board_sys_clk(void); /* * NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 52c2368a3136..d06f3380a783 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -33,7 +33,6 @@ /* * NAND Flash Definitions */ -#define CONFIG_NAND_FSL_IFC #endif
#define CONFIG_SYS_NAND_BASE 0x7e800000 diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 27fe2f8f1b62..8923e3295770 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -95,7 +95,6 @@ unsigned long get_board_sys_clk(void); #endif #endif
diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 875bc1e4a5d8..f82b618e651e 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -71,10 +71,6 @@ #endif #endif
-#ifndef SPL_NO_IFC -#define CONFIG_NAND_FSL_IFC -#endif - #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index d2832a67b3ad..27fd397e9ca8 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -100,7 +100,6 @@ unsigned long get_board_sys_clk(void); CONFIG_SYS_FLASH_BASE + 0x40000000} #endif
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 45f70b18d000..928747f1d6f5 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -108,7 +108,6 @@ unsigned long get_board_sys_clk(void); CONFIG_SYS_FLASH_BASE + 0x40000000} #endif
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index fb1c78ba1273..1575189a6112 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -14,7 +14,6 @@
#if defined(CONFIG_TARGET_P1020RDB_PC) #define CONFIG_BOARDNAME "P1020RDB-PC" -#define CONFIG_NAND_FSL_ELBC #define CONFIG_VSC7385_ENET #define CONFIG_SLIC #define __SW_BOOT_MASK 0x03 @@ -41,7 +40,6 @@ */ #if defined(CONFIG_TARGET_P1020RDB_PD) #define CONFIG_BOARDNAME "P1020RDB-PD" -#define CONFIG_NAND_FSL_ELBC #define CONFIG_VSC7385_ENET #define CONFIG_SLIC #define __SW_BOOT_MASK 0x03 @@ -58,7 +56,6 @@
#if defined(CONFIG_TARGET_P2020RDB) #define CONFIG_BOARDNAME "P2020RDB-PC" -#define CONFIG_NAND_FSL_ELBC #define CONFIG_VSC7385_ENET #define __SW_BOOT_MASK 0x03 #define __SW_BOOT_NOR 0xc8 @@ -85,9 +82,7 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_COMMON_INIT_DDR #endif -#endif - -#ifdef CONFIG_SPIFLASH +#elif defined(CONFIG_SPIFLASH) #define CONFIG_SPL_SPI_FLASH_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" @@ -101,9 +96,7 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_COMMON_INIT_DDR #endif -#endif - -#ifdef CONFIG_MTD_RAW_NAND +#elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_NAND_INIT
This converts the following to Kconfig: CONFIG_SYS_NAND_U_BOOT_LOCATIONS CONFIG_SYS_NAND_U_BOOT_OFFS
Signed-off-by: Tom Rini trini@konsulko.com --- README | 3 --- configs/am335x_baltos_defconfig | 2 +- configs/am335x_evm_defconfig | 2 ++ configs/am335x_evm_spiboot_defconfig | 2 ++ configs/am335x_hs_evm_defconfig | 2 ++ configs/am335x_hs_evm_uart_defconfig | 2 ++ configs/am43xx_evm_defconfig | 2 ++ configs/am43xx_evm_rtconly_defconfig | 2 ++ configs/am43xx_evm_usbhost_boot_defconfig | 2 ++ configs/am43xx_hs_evm_defconfig | 2 ++ configs/axm_defconfig | 2 ++ configs/chiliboard_defconfig | 2 ++ configs/cm_t335_defconfig | 2 ++ configs/corvus_defconfig | 2 ++ configs/devkit3250_defconfig | 2 ++ configs/devkit8000_defconfig | 2 ++ configs/dra7xx_evm_defconfig | 2 ++ configs/dra7xx_hs_evm_defconfig | 2 ++ configs/draco_defconfig | 2 ++ configs/etamin_defconfig | 2 ++ configs/gardena-smart-gateway-at91sam_defconfig | 2 ++ configs/gwventana_nand_defconfig | 2 ++ configs/imx6dl_icore_nand_defconfig | 2 ++ configs/imx6q_icore_nand_defconfig | 2 ++ configs/imx6q_logic_defconfig | 2 ++ configs/imx6qdl_icore_mmc_defconfig | 2 ++ configs/imx6qdl_icore_nand_defconfig | 2 ++ configs/imx6ul_geam_nand_defconfig | 2 ++ configs/imx6ul_isiot_nand_defconfig | 2 ++ configs/ls1021aqds_nand_defconfig | 2 ++ configs/ls1043aqds_nand_defconfig | 2 ++ configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 ++ configs/ls1043ardb_nand_defconfig | 2 ++ configs/ls1046aqds_nand_defconfig | 2 ++ configs/ls2080aqds_nand_defconfig | 2 ++ configs/ls2080ardb_nand_defconfig | 2 ++ configs/m53menlo_defconfig | 2 ++ configs/pxm2_defconfig | 2 ++ configs/rastaban_defconfig | 2 ++ configs/rut_defconfig | 2 ++ configs/sama5d3_xplained_mmc_defconfig | 2 ++ configs/sama5d3_xplained_nandflash_defconfig | 2 ++ configs/sama5d3xek_mmc_defconfig | 2 ++ configs/sama5d3xek_nandflash_defconfig | 2 ++ configs/sama5d3xek_spiflash_defconfig | 2 ++ configs/sama5d4_xplained_mmc_defconfig | 2 ++ configs/sama5d4_xplained_nandflash_defconfig | 2 ++ configs/sama5d4_xplained_spiflash_defconfig | 2 ++ configs/sama5d4ek_mmc_defconfig | 2 ++ configs/sama5d4ek_nandflash_defconfig | 2 ++ configs/sama5d4ek_spiflash_defconfig | 2 ++ configs/smartweb_defconfig | 2 ++ configs/socfpga_secu1_defconfig | 2 ++ configs/taurus_defconfig | 2 ++ configs/thuban_defconfig | 2 ++ configs/ti816x_evm_defconfig | 2 ++ configs/uniphier_ld4_sld8_defconfig | 2 ++ configs/uniphier_v7_defconfig | 2 ++ configs/work_92105_defconfig | 2 ++ include/configs/am335x_evm.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/brppt1.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_t335.h | 3 --- include/configs/corvus.h | 1 - include/configs/devkit3250.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/etamin.h | 3 --- include/configs/gardena-smart-gateway-at91sam.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/imx6-engicam.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/m53menlo.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/pm9g45.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 -- include/configs/smartweb.h | 1 - include/configs/socfpga_arria5_secu1.h | 5 ----- include/configs/socfpga_common.h | 7 ------- include/configs/tam3517-common.h | 1 - include/configs/taurus.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/uniphier.h | 2 -- include/configs/work_92105.h | 1 - 99 files changed, 115 insertions(+), 60 deletions(-)
diff --git a/README b/README index bbfc4bc50e21..006f3f63c667 100644 --- a/README +++ b/README @@ -2091,9 +2091,6 @@ The following options need to be configured: Defines the size and behavior of the NAND that SPL uses to read U-Boot
- CONFIG_SYS_NAND_U_BOOT_OFFS - Location in NAND to read U-Boot from - CONFIG_SYS_NAND_U_BOOT_DST Location in memory to load U-Boot to
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 279c28e5ce5a..492f7b98d44a 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -65,7 +65,7 @@ CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y -CONFIG_SYS_NAND_U_BOOT_OFFS=0x00080000 +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_SMSC=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 06ee4c8482bb..0f938e7de35c 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -68,6 +68,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index f6006c518573..a85645793ee1 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -65,6 +65,8 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 # CONFIG_SPL_NAND_AM33XX_BCH is not set CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index a1958764cbde..21ef885aaf2c 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -59,6 +59,8 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 5038468f88b4..bca18897d306 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -61,6 +61,8 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 5f6ec1a48083..59256c1894d8 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -65,6 +65,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x180000 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index ce77d698aae0..8b35144164b2 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -52,6 +52,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x180000 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index f15f4ebd7241..119392d84826 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -68,6 +68,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x180000 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 31678f10898e..2ab15c975b99 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -70,6 +70,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x180000 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 520e2ffcac02..971930143a97 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -77,6 +77,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index e2560e55025e..a024fe754082 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -58,6 +58,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 CONFIG_PHY_SMSC=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index c59dfa6d0d21..0600bf555dec 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -66,6 +66,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHY_ATHEROS=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 7704d08357c5..aca3e51c716c 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -65,6 +65,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index dc85a8419831..8f98fc5cfee6 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -58,6 +58,8 @@ CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 # CONFIG_SYS_NAND_5_ADDR_CYCLE is not set +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ADDR=31 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 2a32e54424fb..1c067fd7dfbc 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -46,5 +46,7 @@ CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_CONS_INDEX=3 CONFIG_OF_LIBFDT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 4d24f3a9f784..e7ba7530ec7b 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -98,6 +98,8 @@ CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x140000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=76800000 diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 09f84190560e..8e45f844eaa0 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -99,6 +99,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x140000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=76800000 diff --git a/configs/draco_defconfig b/configs/draco_defconfig index d960ddf6bfec..aee48b2a3eb4 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 5efadb81305b..65bdcf6bf73f 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -90,6 +90,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x80 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 6484ac761056..7a1994c30e2c 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -79,6 +79,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index ff5001ef9611..8ff8ab472eb3 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -100,6 +100,8 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xe00000 CONFIG_PHYLIB=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 29496ef571aa..fb9ba0838e16 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -52,6 +52,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index c82814a42c5c..c9915a7dc9be 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -53,6 +53,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index e3159ccc2aa2..f9d472eacd04 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -82,6 +82,8 @@ CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_MXS=y CONFIG_NAND_MXS_DT=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index d663d38d63db..f17e472a5833 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -69,6 +69,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index c82814a42c5c..c9915a7dc9be 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -53,6 +53,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 90121773eff6..f1860978d6ec 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -53,6 +53,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 3a2d919dc91c..34c0bb7eeb0d 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -53,6 +53,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_MXS=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x200000 CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 2d5059b5dd71..b91b412ba446 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x1c000 CONFIG_PHY_REALTEK=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 806c38ee46b9..4dbe928fd1b7 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -82,6 +82,8 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 50da8eb5deb0..be058b78dddf 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -64,6 +64,8 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index a03e3d0665da..c778c78ea11a 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -72,6 +72,8 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index c325ee3b39ce..8168b6e585f8 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -73,6 +73,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHYLIB_10G=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index f4072db11a6e..ae0fab8070a9 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -64,6 +64,8 @@ CONFIG_MTD=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_PHYLIB=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index e26acc50c39f..7f9583d23760 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -66,6 +66,8 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_NAND_FSL_IFC=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x100000 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 186abd25e906..5500d8eaf03e 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -82,6 +82,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x8000 CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 8f50ecf49854..da6665964a59 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index c0209f8d5166..1f2edd8682bc 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 8052f4fae250..e9f4929c6262 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 11ca60f619f3..450ebe0bcb0f 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -71,6 +71,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 08be37bc5ef3..b26e1899faa8 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -74,6 +74,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index a39743fc3b41..4068f10937b7 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -74,6 +74,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 6822f7dc03c4..3a8f2f455070 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -76,6 +76,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 2bda3e5f44b4..6d28600ae8f7 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -75,6 +75,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=4 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index c25e556357e1..083fa57e8f10 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -67,6 +67,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 16cec8bd0cc5..58f359cc035b 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -71,6 +71,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index a73ef20979d9..1cb8657a5d63 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -73,6 +73,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index c0fd3ec0f3af..e7dcc03693f8 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -65,6 +65,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7f02d4640427..c33187eefca8 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -69,6 +69,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x1000 CONFIG_SYS_NAND_OOBSIZE=0xe0 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 3d084e521314..0884f4e0c0d8 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -68,6 +68,8 @@ CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HW_PMECC=y CONFIG_PMECC_CAP=8 CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index bc0d9c048ac1..3d2d64ff6e7e 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -67,6 +67,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index 2c6a0a143122..58e63d23587d 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -72,6 +72,8 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NAND_USE_FLASH_BBT=y CONFIG_NAND_DENALI_DT=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=2 # CONFIG_DM_SPI_FLASH is not set diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 9e4cdc451859..ea36c867da66 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -83,6 +83,8 @@ CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index faa6ea5f1d3e..b83c99061276 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -89,6 +89,8 @@ CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 581203d46808..9e2613a03c1a 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -65,6 +65,8 @@ CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0xc0000 CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_EMAC=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 23fc05a6a2cb..97ee693334bd 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -47,6 +47,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SMC911X=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index 4ac1f94f51c8..9089be0190c2 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -48,6 +48,8 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_DENALI_DT=y CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x20000 CONFIG_SPL_NAND_DENALI=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_SNI_AVE=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index d67ec056fa50..0102baf36b1e 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -55,6 +55,8 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x56 CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_LPC32XX_MLC=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x40000 CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_SMSC=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 2599d32051cc..dc8c3e2a5d1d 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -192,7 +192,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 1e9dfaf7e898..547d27322e17 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_NAND_MAX_OOBFREE 2 #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 /* NAND block size is 128 KiB. Synchronize these values with * corresponding Device Tree entries in Linux: diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 2f48d5dd2f9e..56b85df4cf82 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -186,7 +186,6 @@ } #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 26 -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00180000 /* NAND: SPL related configs */ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 6f75ca5dcee7..500c9ae3951e 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -93,7 +93,6 @@
#elif CONFIG_NAND_BOOT #define CONFIG_SPL_NAND_SOFTECC -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000
#define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 48ec065a341d..43f985207226 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -114,6 +114,5 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
#endif diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 798a10041194..f15711ba2b1b 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -97,6 +97,5 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
#endif diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 1dfe7d0473bd..caedd3004b95 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -46,7 +46,6 @@
#ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #endif /* CONFIG_MTD_RAW_NAND */
#ifdef CONFIG_MTD_RAW_NAND diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 3ab973f02153..c7b2131c26c0 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -135,7 +135,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */
/* USB configuration */ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index a769fd1672c6..3de22045b7d9 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -100,9 +100,6 @@
-#undef CONFIG_SYS_NAND_U_BOOT_OFFS -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 - #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x500000 diff --git a/include/configs/corvus.h b/include/configs/corvus.h index de432a4ff78e..f0e5bcefe39e 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -93,7 +93,6 @@
#define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_SOFTECC -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index d90e944f0604..8e8ea56f3cfa 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -127,7 +127,6 @@ #define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE
/* U-Boot will be 0x60000 bytes, loaded and run at CONFIG_SYS_TEXT_BASE */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x60000
#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 66c8cd2b6217..8113d759cf91 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW
-#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x200000
/* SPL OS boot options */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index c0a855f0d328..1e3a66f9d9e8 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -96,7 +96,6 @@ 50, 51, 52, 53, 54, 55, 56, 57, } #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00140000 /* NAND: SPL related configs */ /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 229a695c12eb..245119db6781 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -15,7 +15,6 @@ #include "siemens-am33x-common.h" /* NAND specific changes for etamin due to different page size */ #undef CONFIG_SYS_NAND_ECCPOS -#undef CONFIG_SYS_NAND_U_BOOT_OFFS #undef CONFIG_SYS_ENV_SECT_SIZE #undef CONFIG_NAND_OMAP_ECCSCHEME #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW @@ -49,8 +48,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 26
-#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 - #undef CONFIG_SYS_MAX_NAND_DEVICE #define CONFIG_SYS_MAX_NAND_DEVICE 3 #define CONFIG_SYS_NAND_BASE2 (0x18000000) /* physical address */ diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 45414f9e61fe..9d96dfcc31e4 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -55,7 +55,6 @@ #define CONFIG_SYS_MCKR_CSS 0x1302
#define CONFIG_SPL_NAND_RAW_ONLY -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0xa0000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index f0289582609f..3f6afc1646fd 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -8,7 +8,6 @@
/* SPL */ /* Location in NAND to read U-Boot from */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS (14 * SZ_1M)
/* Falcon Mode */ #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000 diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index f0c19efb1f06..b9c17dd557b0 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -138,7 +138,6 @@ # define CONFIG_SYS_MAX_NAND_DEVICE 1 # define CONFIG_SYS_NAND_BASE 0x40000000 # define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -# define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
/* MTD device */ #endif diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index c14ce837acf4..f1b78c6751a8 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -130,7 +130,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000 #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00500000
/* MTD device */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 795c8e599499..748c04ba69f1 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -46,7 +46,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SPL_PAD_TO 0x1c000
#define CONFIG_SYS_NAND_U_BOOT_SIZE (400 << 10) -#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 5df42d93ae2e..1d15f2fc5853 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -150,7 +150,6 @@ unsigned long get_board_sys_clk(void);
#ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) #endif
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index f367ad69e208..0d071c4ab748 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -109,7 +109,6 @@
#ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_U_BOOT_SIZE (1024 << 10) #endif
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index ca4b856ec91a..2e3824041c9b 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -165,7 +165,6 @@ unsigned long get_board_sys_clk(void);
#ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PAD_TO 0x40000 /* block aligned */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #endif
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 27fd397e9ca8..e67dee0f00b9 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -208,7 +208,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
#define CONFIG_SPL_PAD_TO 0x20000 -#define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) #endif #else diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 928747f1d6f5..54fab54609ea 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -202,7 +202,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
#define CONFIG_SPL_PAD_TO 0x80000 -#define CONFIG_SYS_NAND_U_BOOT_OFFS (1024 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 6d107a9a9e49..5dd5ddac172f 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -139,7 +139,6 @@ #define CONFIG_SPL_PAD_TO 0x8000 #define CONFIG_SPL_STACK 0x70004000
-#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024)
/* diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 113c4ee0120d..e8f455a5ca2f 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_ENV_SECT_SIZE SZ_128K /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 6f4bae31cd44..3d039b60a869 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -83,7 +83,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 256 diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index f6806f63a0c1..119b4a652cc2 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -68,7 +68,6 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
/* Falcon boot support on raw MMC */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x100 /* 128 KiB */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 7a50069f1c7f..67640f441516 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -80,6 +80,5 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
#endif diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 9aaafc164a5d..e0e0bc6beb7c 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -44,6 +44,5 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
#endif diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index c39674d89952..2549d4c1a19a 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -44,6 +44,5 @@ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #endif -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000
#endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 2c8bda162048..fd74d5735e53 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -90,8 +90,6 @@
-#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 - /* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM * 64 bytes before this address should be set aside for u-boot.img's diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index cc5f5380cfaf..2538287e4cfd 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -162,7 +162,6 @@ #define CONFIG_SYS_USE_NANDFLASH 1 #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_SOFTECC -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/socfpga_arria5_secu1.h b/include/configs/socfpga_arria5_secu1.h index 0b37efeafa3c..fc1d451b8f8e 100644 --- a/include/configs/socfpga_arria5_secu1.h +++ b/include/configs/socfpga_arria5_secu1.h @@ -111,11 +111,6 @@ /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
-#ifdef CONFIG_SPL_NAND_SUPPORT -#undef CONFIG_SYS_NAND_U_BOOT_OFFS -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#endif - #undef CONFIG_WATCHDOG_TIMEOUT_MSECS #define CONFIG_WATCHDOG_TIMEOUT_MSECS 60000
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 28495bcf18a2..31f95f52f8c6 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -196,13 +196,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* SPL QSPI boot support */
/* SPL NAND boot support */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x100000 -#endif -#endif
/* Extra Environment */ #ifndef CONFIG_SPL_BUILD diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 3d540978e968..34e4309dad7c 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -137,7 +137,6 @@
-#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000
/* Setup MTD for NAND on the SOM */ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index fa4b6f40d77f..1dd78238947f 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -164,7 +164,6 @@ #define CONFIG_SYS_USE_NANDFLASH 1 #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_SOFTECC -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 3962df5c6160..5964b59da825 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000
/* SPL */ /* Defines for SPL */ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index cc6b96fcd66c..dbd4a0089ec8 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -193,8 +193,6 @@ /* only for SPL */ #define CONFIG_SPL_STACK (0x00100000)
-#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 - /* subtract sizeof(struct image_header) */ #define CONFIG_SYS_UBOOT_BASE (0x130000 - 0x40)
diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index d6addf957b10..a45d3b4547b4 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -86,7 +86,6 @@ /* Use the framework and generic lib */ /* SPL will use serial */ /* SPL will load U-Boot from NAND offset 0x40000 */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00040000 #define CONFIG_SPL_PAD_TO 0x20000 /* U-Boot will be 0x40000 bytes, loaded and run at CONFIG_SYS_TEXT_BASE */ #define CONFIG_SYS_MONITOR_LEN 0x40000 /* actually, MAX size */
The values of CONFIG_NAND_OMAP_ECCSCHEME map to the enum in include/linux/mtd/omap_gpmc.h for valid ECC schemes. Make which one we will use be a choice statement, enumerating the ones which we have implemented.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am335x_guardian_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/etamin_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + doc/README.nand | 66 -------------- drivers/mtd/nand/raw/Kconfig | 103 +++++++++++++++++++++- include/configs/am335x_evm.h | 1 - include/configs/am335x_guardian.h | 1 - include/configs/am335x_igep003x.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/brppt1.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_t43.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/etamin.h | 2 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/phycore_am335x_r2.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/ti816x_evm.h | 1 - 37 files changed, 116 insertions(+), 89 deletions(-)
diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 272d5b877514..ea4032fe1ff0 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -88,6 +88,7 @@ CONFIG_MISC=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 665c54a88189..17b301756d9c 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -57,6 +57,7 @@ CONFIG_DM_PCA953X=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 59256c1894d8..443bdca096bb 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -60,6 +60,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 8b35144164b2..183801120296 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 119392d84826..c5a6a07b3240 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -63,6 +63,7 @@ CONFIG_MISC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 2ab15c975b99..1eb394cbd8df 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -65,6 +65,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x40 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 1c067fd7dfbc..ccdd4f606f43 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -41,6 +41,7 @@ CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_HAM1_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 65bdcf6bf73f..59a919becebb 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -85,6 +85,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SYS_NAND_PAGE_COUNT=0x80 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 17e793c313e2..8f6e13e2a87b 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -60,6 +60,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_SYS_MTDPARTS_RUNTIME=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index fe37a981e43f..9d8ac94d2a5e 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -57,6 +57,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR=0x50 CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 435e0f7e2bb3..e54646c21cef 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -62,6 +62,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index c0830dcfc1e6..206118e6aff6 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -74,6 +74,7 @@ CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_HAM1_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 0174b3a669ae..b89ab392d0a7 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -62,6 +62,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 18e87f125cc5..becf862dcbe2 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -57,6 +57,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 1c093162d334..f8518a01bc2a 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -63,6 +63,7 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x20000 CONFIG_SYS_NAND_PAGE_COUNT=0x40 CONFIG_SYS_NAND_PAGE_SIZE=0x800 diff --git a/doc/README.nand b/doc/README.nand index f6460dba6031..ffcea9079990 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -200,72 +200,6 @@ Platform specific options so those platforms should use CONFIG_SPL_NAND_SIMPLE for enabling SPL-NAND driver with software ECC correction support.
- CONFIG_NAND_OMAP_ECCSCHEME - On OMAP platforms, this CONFIG specifies NAND ECC scheme. - It can take following values: - OMAP_ECC_HAM1_CODE_SW - 1-bit Hamming code using software lib. - (for legacy devices only) - OMAP_ECC_HAM1_CODE_HW - 1-bit Hamming code using GPMC hardware. - (for legacy devices only) - OMAP_ECC_BCH4_CODE_HW_DETECTION_SW - 4-bit BCH code (unsupported) - OMAP_ECC_BCH4_CODE_HW - 4-bit BCH code (unsupported) - OMAP_ECC_BCH8_CODE_HW_DETECTION_SW - 8-bit BCH code with - - ecc calculation using GPMC hardware engine, - - error detection using software library. - - requires CONFIG_BCH to enable software BCH library - (For legacy device which do not have ELM h/w engine) - OMAP_ECC_BCH8_CODE_HW - 8-bit BCH code with - - ecc calculation using GPMC hardware engine, - - error detection using ELM hardware engine. - OMAP_ECC_BCH16_CODE_HW - 16-bit BCH code with - - ecc calculation using GPMC hardware engine, - - error detection using ELM hardware engine. - - How to select ECC scheme on OMAP and AMxx platforms ? - ----------------------------------------------------- - Though higher ECC schemes have more capability to detect and correct - bit-flips, but still selection of ECC scheme is dependent on following - - hardware engines present in SoC. - Some legacy OMAP SoC do not have ELM h/w engine thus such - SoC cannot support BCHx_HW ECC schemes. - - size of OOB/Spare region - With higher ECC schemes, more OOB/Spare area is required to - store ECC. So choice of ECC scheme is limited by NAND oobsize. - - In general following expression can help: - NAND_OOBSIZE >= 2 + (NAND_PAGESIZE / 512) * ECC_BYTES - where - NAND_OOBSIZE = number of bytes available in - OOB/spare area per NAND page. - NAND_PAGESIZE = bytes in main-area of NAND page. - ECC_BYTES = number of ECC bytes generated to - protect 512 bytes of data, which is: - 3 for HAM1_xx ecc schemes - 7 for BCH4_xx ecc schemes - 14 for BCH8_xx ecc schemes - 26 for BCH16_xx ecc schemes - - example to check for BCH16 on 2K page NAND - NAND_PAGESIZE = 2048 - NAND_OOBSIZE = 64 - 2 + (2048 / 512) * 26 = 106 > NAND_OOBSIZE - Thus BCH16 cannot be supported on 2K page NAND. - - However, for 4K pagesize NAND - NAND_PAGESIZE = 4096 - NAND_OOBSIZE = 224 - ECC_BYTES = 26 - 2 + (4096 / 512) * 26 = 210 < NAND_OOBSIZE - Thus BCH16 can be supported on 4K page NAND. - - CONFIG_NAND_OMAP_GPMC_PREFETCH On OMAP platforms that use the GPMC controller (CONFIG_NAND_OMAP_GPMC_PREFETCH), this options enables the code that diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index df7a5513d085..e8f54d54bdd7 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -152,9 +152,10 @@ config NAND_OMAP_GPMC do ECC calculation (not ECC error detection) for HAM1, BCH4, BCH8 and BCH16 ECC algorithms.
+if NAND_OMAP_GPMC + config NAND_OMAP_GPMC_PREFETCH bool "Enable GPMC Prefetch" - depends on NAND_OMAP_GPMC default y help On OMAP platforms that use the GPMC controller @@ -163,7 +164,7 @@ config NAND_OMAP_GPMC_PREFETCH
config NAND_OMAP_ELM bool "Enable ELM driver for OMAPxx and AMxx platforms." - depends on NAND_OMAP_GPMC && !OMAP34XX + depends on !OMAP34XX help ELM controller is used for ECC error detection (not ECC calculation) of BCH4, BCH8 and BCH16 ECC algorithms. @@ -172,6 +173,104 @@ config NAND_OMAP_ELM detection. However ECC calculation on such plaforms would still be done by GPMC controller.
+choice + prompt "ECC scheme" + default NAND_OMAP_ECCSCHEME_BCH8_CODE_HW + help + On OMAP platforms, this CONFIG specifies NAND ECC scheme. + It can take following values: + OMAP_ECC_HAM1_CODE_SW + 1-bit Hamming code using software lib. + (for legacy devices only) + OMAP_ECC_HAM1_CODE_HW + 1-bit Hamming code using GPMC hardware. + (for legacy devices only) + OMAP_ECC_BCH4_CODE_HW_DETECTION_SW + 4-bit BCH code (unsupported) + OMAP_ECC_BCH4_CODE_HW + 4-bit BCH code (unsupported) + OMAP_ECC_BCH8_CODE_HW_DETECTION_SW + 8-bit BCH code with + - ecc calculation using GPMC hardware engine, + - error detection using software library. + - requires CONFIG_BCH to enable software BCH library + (For legacy device which do not have ELM h/w engine) + OMAP_ECC_BCH8_CODE_HW + 8-bit BCH code with + - ecc calculation using GPMC hardware engine, + - error detection using ELM hardware engine. + OMAP_ECC_BCH16_CODE_HW + 16-bit BCH code with + - ecc calculation using GPMC hardware engine, + - error detection using ELM hardware engine. + + How to select ECC scheme on OMAP and AMxx platforms ? + ----------------------------------------------------- + Though higher ECC schemes have more capability to detect and correct + bit-flips, but still selection of ECC scheme is dependent on following + - hardware engines present in SoC. + Some legacy OMAP SoC do not have ELM h/w engine thus such + SoC cannot support BCHx_HW ECC schemes. + - size of OOB/Spare region + With higher ECC schemes, more OOB/Spare area is required to + store ECC. So choice of ECC scheme is limited by NAND oobsize. + + In general following expression can help: + NAND_OOBSIZE >= 2 + (NAND_PAGESIZE / 512) * ECC_BYTES + where + NAND_OOBSIZE = number of bytes available in + OOB/spare area per NAND page. + NAND_PAGESIZE = bytes in main-area of NAND page. + ECC_BYTES = number of ECC bytes generated to + protect 512 bytes of data, which is: + 3 for HAM1_xx ecc schemes + 7 for BCH4_xx ecc schemes + 14 for BCH8_xx ecc schemes + 26 for BCH16_xx ecc schemes + + example to check for BCH16 on 2K page NAND + NAND_PAGESIZE = 2048 + NAND_OOBSIZE = 64 + 2 + (2048 / 512) * 26 = 106 > NAND_OOBSIZE + Thus BCH16 cannot be supported on 2K page NAND. + + However, for 4K pagesize NAND + NAND_PAGESIZE = 4096 + NAND_OOBSIZE = 224 + ECC_BYTES = 26 + 2 + (4096 / 512) * 26 = 210 < NAND_OOBSIZE + Thus BCH16 can be supported on 4K page NAND. + +config NAND_OMAP_ECCSCHEME_HAM1_CODE_SW + bool "1-bit Hamming code using software lib" + +config NAND_OMAP_ECCSCHEME_HAM1_CODE_HW + bool "1-bit Hamming code using GPMC hardware" + +config NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW + bool "8-bit BCH code with HW calculation SW error detection" + +config NAND_OMAP_ECCSCHEME_BCH8_CODE_HW + bool "8-bit BCH code with HW calculation and error detection" + +config NAND_OMAP_ECCSCHEME_BCH16_CODE_HW + bool "16-bit BCH code with HW calculation and error detection" + +endchoice + +config NAND_OMAP_ECCSCHEME + int + default 1 if NAND_OMAP_ECCSCHEME_HAM1_CODE_SW + default 2 if NAND_OMAP_ECCSCHEME_HAM1_CODE_HW + default 5 if NAND_OMAP_ECCSCHEME_BCH8_CODE_HW_DETECTION_SW + default 6 if NAND_OMAP_ECCSCHEME_BCH8_CODE_HW + default 7 if NAND_OMAP_ECCSCHEME_BCH16_CODE_HW + help + This must be kept in sync with the enum in + include/linux/mtd/omap_gpmc.h + +endif + config NAND_VF610_NFC bool "Support for Freescale NFC for VF610" select SYS_NAND_SELF_INIT diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index dc8c3e2a5d1d..7fb1b3a3e3fa 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -191,7 +191,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW /* NAND: SPL related configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index fd7d589dd6ce..68b4e4f59033 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -130,7 +130,6 @@ } #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 26 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define MTDIDS_DEFAULT "nand0=nand.0"
#endif /* CONFIG_MTD_RAW_NAND */ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 4a303b702c59..339a975c74cc 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -115,6 +115,5 @@
#endif /* ! __CONFIG_IGEP003X_H */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 547d27322e17..ab410faff626 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -43,7 +43,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 13 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_NAND_MAX_OOBFREE 2 #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 56b85df4cf82..9342d2063df4 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -161,7 +161,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, \ 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, \ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index f55f57ce22e9..32f2174641a8 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -219,7 +219,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #endif #endif diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index caedd3004b95..4c56a8a59b07 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -144,7 +144,6 @@ NANDTGTS \ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x8000000 /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index c7b2131c26c0..49a8d7103180 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -134,7 +134,6 @@
/* USB configuration */ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 9ad883d9ffb1..9708768a6891 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -25,7 +25,6 @@ /* NAND support */ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 8113d759cf91..591a33fca68f 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -138,7 +138,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 1e3a66f9d9e8..a023332203c1 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -86,7 +86,6 @@ #ifdef CONFIG_MTD_RAW_NAND /* NAND: device related configs */ /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ 18, 19, 20, 21, 22, 23, 24, 25, \ diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 245119db6781..b04e5266e36e 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -16,8 +16,6 @@ /* NAND specific changes for etamin due to different page size */ #undef CONFIG_SYS_NAND_ECCPOS #undef CONFIG_SYS_ENV_SECT_SIZE -#undef CONFIG_NAND_OMAP_ECCSCHEME -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW
#define CONFIG_SYS_ENV_SECT_SIZE (512 << 10) /* 512 KiB */ #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index e8f455a5ca2f..270c328ff7af 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -26,7 +26,6 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_ENV_SECT_SIZE SZ_128K /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 8d1233c075eb..eeb9ef8c741a 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -31,7 +31,6 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_ENV_SECT_SIZE SZ_128K /* NAND: SPL falcon mode configs */ #if defined(CONFIG_SPL_OS_BOOT) diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index ced449d7ad39..c1ef040ce360 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -84,6 +84,5 @@ 50, 51, 52, 53, 54, 55, 56, 57, } #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW
#endif /* __IGEP00X0_H */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index f6b5b5f986db..908114e2a92a 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -44,7 +44,6 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 13 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_SYS_NAND_MAX_OOBFREE 2 #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #endif diff --git a/include/configs/phycore_am335x_r2.h b/include/configs/phycore_am335x_r2.h index 935bb7a07c0f..af6f7e14dfde 100644 --- a/include/configs/phycore_am335x_r2.h +++ b/include/configs/phycore_am335x_r2.h @@ -96,7 +96,6 @@
/* NAND: SPL related configs */ #ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index fd74d5735e53..615458cde8bc 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -82,7 +82,6 @@
#define CONFIG_SYS_NAND_ECCSTEPS 4 #define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 34e4309dad7c..0a2309144a06 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -133,7 +133,6 @@ 56, 57, 58, 59, 60, 61, 62, 63} #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_SW
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 5964b59da825..fa99152d6f6d 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -68,7 +68,6 @@
On Wed, Sep 22, 2021 at 02:50:26PM -0400, Tom Rini wrote:
These platforms do not currently enable NAND, remove these references.
Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Tom Rini trini@konsulko.com
