[U-Boot] [PATCH v3 0/7] Provide SPL support for bootcount (in the case of using falcon boot mode)
This patch series provides support for controlling bootcount limits in SPL. Moreover, the common code has been identified and reused in the common/autoboot.c file. It also enables this feature on display5 board to present usage patterns.
This patch has been applied on top of u-boot/master: SHA1 : v2018.05-rc3
Test HW: Beagle Bone Black (am335x) , Display5 (imx6q) Travis-Ci: https://travis-ci.org/lmajewski/u-boot-dfu/builds/373639971
Lukasz Majewski (7): bootcount: spl: Enable bootcount support in SPL bootcount: Add include guards into bootcount.h file bootcount: Add function wrappers to handle bootcount increment and error checking bootcount: Rewrite autoboot to use wrapper functions from bootcount.h bootcount: spl: Extend SPL to support bootcount incrementation bootcount: display5: spl: Extend DISPLAY5 board SPL to support bootcount checking bootcount: display5: config: Enable boot count feature in the display5 board
board/liebherr/display5/spl.c | 3 ++- common/autoboot.c | 23 +++++--------------- common/spl/Kconfig | 9 ++++++++ common/spl/spl.c | 3 +++ configs/display5_defconfig | 4 ++++ drivers/Makefile | 1 + include/bootcount.h | 50 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 74 insertions(+), 19 deletions(-)
New, SPL related config option - CONFIG_SPL_BOOTCOUNT_LIMIT has been added to allow drivers/bootcount code re-usage in SPL.
This code is necessary to use and setup bootcount in SPL in the case of falcon boot mode.
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Tom Rini trini@konsulko.com
Changes in v4: - None
Changes in v3: - None
Changes in v2: - None
common/spl/Kconfig | 9 +++++++++ drivers/Makefile | 1 + 2 files changed, 10 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 259f96607e..431710a93b 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -54,6 +54,15 @@ config SPL_BOOTROM_SUPPORT BOOT_DEVICE_BOOTROM (or fall-through to the next boot device in the boot device list, if not implemented for a given board)
+config SPL_BOOTCOUNT_LIMIT + bool "Support bootcount in SPL" + depends on SPL_ENV_SUPPORT + help + On some boards, which use 'falcon' mode, it is necessary to check + and increment the number of boot attempts. Such boards do not + use proper U-Boot for normal boot flow and hence needs those + adjustments to be done in the SPL. + config SPL_RAW_IMAGE_SUPPORT bool "Support SPL loading and booting of RAW images" default n if (ARCH_MX6 && (SPL_MMC_SUPPORT || SPL_SATA_SUPPORT)) diff --git a/drivers/Makefile b/drivers/Makefile index 6846d181aa..061331eadd 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_$(SPL_TPL_)TIMER) += timer/ ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_BUILD
+obj-$(CONFIG_SPL_BOOTCOUNT_LIMIT) += bootcount/ obj-$(CONFIG_SPL_CPU_SUPPORT) += cpu/ obj-$(CONFIG_SPL_CRYPTO_SUPPORT) += crypto/ obj-$(CONFIG_SPL_GPIO_SUPPORT) += gpio/
This patch adds missing include guards for bootcount.h file.
Changes in v2: - New patch
include/bootcount.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/bootcount.h b/include/bootcount.h index 06fb4d3578..e3b3f7028e 100644 --- a/include/bootcount.h +++ b/include/bootcount.h @@ -4,6 +4,8 @@ * * SPDX-License-Identifier: GPL-2.0+ */ +#ifndef _BOOTCOUNT_H__ +#define _BOOTCOUNT_H__
#include <common.h> #include <asm/io.h> @@ -38,3 +40,4 @@ static inline u32 raw_bootcount_load(volatile u32 *addr) return in_be32(addr); } #endif +#endif /* _BOOTCOUNT_H__ */
Those two functions can be used to provide easy bootcount management.
Changes in v4: - Remove enum bootcount_context and replace it with checking gd_t->flags (The GD_FLG_SPL_INIT is only set in SPL, it is cleared in u-boot proper, so can be used as indication if we are in u-boot or SPL). - Do not call bootcount_store() twice when it is not needed. - Call env_set_ulong("bootcount", bootcount); only in NON SPL context - Boards with TINY_PRINTF (in newest mainline) will build break as this function requires simple_itoa() from vsprintf.c (now not always build in SPL).
Changes in v3: - Unify those functions to also work with common/autoboot.c code - Add enum bootcount_context to distinguish between u-boot proper and SPL
include/bootcount.h | 47 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/include/bootcount.h b/include/bootcount.h index e3b3f7028e..919735c19a 100644 --- a/include/bootcount.h +++ b/include/bootcount.h @@ -11,6 +11,8 @@ #include <asm/io.h> #include <asm/byteorder.h>
+#if defined CONFIG_SPL_BOOTCOUNT_LIMIT || defined CONFIG_BOOTCOUNT_LIMIT + #if !defined(CONFIG_SYS_BOOTCOUNT_LE) && !defined(CONFIG_SYS_BOOTCOUNT_BE) # if __BYTE_ORDER == __LITTLE_ENDIAN # define CONFIG_SYS_BOOTCOUNT_LE @@ -40,4 +42,49 @@ static inline u32 raw_bootcount_load(volatile u32 *addr) return in_be32(addr); } #endif + +DECLARE_GLOBAL_DATA_PTR; +static inline int bootcount_error(void) +{ + unsigned long bootcount = bootcount_load(); + unsigned long bootlimit = env_get_ulong("bootlimit", 10, 0); + + if (bootlimit && bootcount > bootlimit) { + printf("Warning: Bootlimit (%lu) exceeded.", bootlimit); + if (!(gd->flags & GD_FLG_SPL_INIT)) + printf(" Using altbootcmd."); + printf("\n"); + + return 1; + } + + return 0; +} + +static inline void bootcount_inc(void) +{ + unsigned long bootcount = bootcount_load(); + + if (gd->flags & GD_FLG_SPL_INIT) { + bootcount_store(++bootcount); + return; + } + +#ifndef CONFIG_SPL_BUILD + /* Only increment bootcount when no bootcount support in SPL */ +#ifndef CONFIG_SPL_BOOTCOUNT_LIMIT + bootcount_store(++bootcount); +#endif + env_set_ulong("bootcount", bootcount); +#endif /* !CONFIG_SPL_BUILD */ +} + +#if defined CONFIG_SPL_BUILD && !defined CONFIG_SPL_BOOTCOUNT_LIMIT +void bootcount_store(ulong a) {}; +ulong bootcount_load(void) { return 0; } +#endif /* CONFIG_SPL_BUILD && !CONFIG_SPL_BOOTCOUNT_LIMIT */ +#else +static inline int bootcount_error(void) { return 0; } +static inline void bootcount_inc(void) {} +#endif /* CONFIG_SPL_BOOTCOUNT_LIMIT || CONFIG_BOOTCOUNT_LIMIT */ #endif /* _BOOTCOUNT_H__ */
Changes in v4:
Changes in v3:
Changes in v2:
None
- #if !defined(CONFIG_SYS_BOOTCOUNT_LE) && !defined(CONFIG_SYS_BOOTCOUNT_BE) # if __BYTE_ORDER == __LITTLE_ENDIAN # define CONFIG_SYS_BOOTCOUNT_LE
- unsigned long bootcount = bootcount_load();
- unsigned long bootlimit = env_get_ulong("bootlimit", 10, 0);
- if (bootlimit && bootcount > bootlimit) {
printf("\n");
return 1;
- if (gd->flags & GD_FLG_SPL_INIT) {
return;
- /* Only increment bootcount when no bootcount support in SPL */
- bootcount_store(++bootcount);
- env_set_ulong("bootcount", bootcount);
Looks better this way. Thanks for working on this:
Thanks, Stefan
[snip]
Style problem. We have a few places where we don't use parens in the code today, but this is the first time I've noticed and had to check quickly to see that. Please follow the normal convention of if defined(FOO) .... Otherwise:
And, erm, since you'll need to repost this one, please v5 the whole series since you accidentally did v3 again in the subject just to make it extra easy to see what version I should pull in later? Thanks!
Hi Tom,
[snip]
I've just sent the corrected v5 to ML.
I suppose that this code shall be applied to -next anyway (as it is already too late in the current release cycle (rc3)).
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
The code has been refactored to use common wrappers from bootcount.h header.
Changes in v4: - Use global data pointer (gd_t *) instead of bootcount specific enum
Changes in v3: - New patch
common/autoboot.c | 23 +++++------------------ 1 file changed, 5 insertions(+), 18 deletions(-)
diff --git a/common/autoboot.c b/common/autoboot.c index 2eef7a04cc..a0f7822c9e 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -14,6 +14,7 @@ #include <menu.h> #include <post.h> #include <u-boot/sha256.h> +#include <bootcount.h>
@@ -291,18 +292,8 @@ const char *bootdelay_process(void) { char *s; int bootdelay; -#ifdef CONFIG_BOOTCOUNT_LIMIT - unsigned long bootcount = 0; - unsigned long bootlimit = 0; -#endif /* CONFIG_BOOTCOUNT_LIMIT */ - -#ifdef CONFIG_BOOTCOUNT_LIMIT - bootcount = bootcount_load(); - bootcount++; - bootcount_store(bootcount); - env_set_ulong("bootcount", bootcount); - bootlimit = env_get_ulong("bootlimit", 10, 0); -#endif /* CONFIG_BOOTCOUNT_LIMIT */ + + bootcount_inc();
s = env_get("bootdelay"); bootdelay = s ? (int)simple_strtol(s, NULL, 10) : CONFIG_BOOTDELAY; @@ -324,13 +315,9 @@ const char *bootdelay_process(void) s = env_get("failbootcmd"); } else #endif /* CONFIG_POST */ -#ifdef CONFIG_BOOTCOUNT_LIMIT - if (bootlimit && (bootcount > bootlimit)) { - printf("Warning: Bootlimit (%u) exceeded. Using altbootcmd.\n", - (unsigned)bootlimit); + if (bootcount_error()) s = env_get("altbootcmd"); - } else -#endif /* CONFIG_BOOTCOUNT_LIMIT */ + else s = env_get("bootcmd");
process_fdt_options(gd->fdt_blob);
This patch adds support for incrementation of the bootcount in SPL. Such feature is necessary when we do want to use this feature with 'falcon' boot mode (which loads OS directly in SPL).
Changes in v4: - Use gd_t global data pointer instead of bootcount specific enum
Changes in v3: - Remove not needed #ifdefs - Add enum bootcount_context parameter to bootcount_inc() function
Changes in v2: - New patch - as suggested by Stefan Roese - bootcount_inc() is called in common SPL code (./common/spl/spl.c), so other boards can also reuse it without modification
common/spl/spl.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 794dbd0312..6eb50f3534 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -20,6 +20,7 @@ #include <dm/root.h> #include <linux/compiler.h> #include <fdt_support.h> +#include <bootcount.h>
@@ -417,6 +418,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) spl_board_init(); #endif
+ bootcount_inc(); + memset(&spl_image, '\0', sizeof(spl_image)); #ifdef CONFIG_SYS_SPL_ARGS_ADDR spl_image.arg = (void *)CONFIG_SYS_SPL_ARGS_ADDR;
This patch is necessary for providing basic bootcount checking in the case of using "falcon" boot mode in that board.
It forces u-boot proper boot, when we exceed the number of errors.
Changes in v4: - Use global data pointer (gd) instead of bootcount specific enum (SPL)
Changes in v3: - The bootcount_error now accepts enum bootcount_error input parameter
Changes in v2: - Remove bootcount_init() from SPL specific board code
board/liebherr/display5/spl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/liebherr/display5/spl.c b/board/liebherr/display5/spl.c index 437963e225..7712e5bc3f 100644 --- a/board/liebherr/display5/spl.c +++ b/board/liebherr/display5/spl.c @@ -20,6 +20,7 @@ #include <environment.h> #include <fsl_esdhc.h> #include <netdev.h> +#include <bootcount.h> #include "common.h"
DECLARE_GLOBAL_DATA_PTR; @@ -214,7 +215,7 @@ void board_boot_order(u32 *spl_boot_list) env_load();
s = env_get("BOOT_FROM"); - if (s && strcmp(s, "ACTIVE") == 0) { + if (s && !bootcount_error() && strcmp(s, "ACTIVE") == 0) { spl_boot_list[0] = BOOT_DEVICE_MMC1; spl_boot_list[1] = spl_boot_device(); }
The boot count is enabled in both SPL and proper u-boot.
configs/display5_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/display5_defconfig b/configs/display5_defconfig index e52f4e00af..db8212ca7c 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SPL_BOOTCOUNT_LIMIT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y @@ -53,6 +54,9 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y
Lukasz Majewski
Stefan Roese
