[PATCH 0/4] xilinx: Add SoC Xilinx driver for zynqmp & versal
This patch series adds support for SoC Xilinx driver to get SoC family and revision. Print SoC info using print_cpuinfo() at booting stage.
Thanks, Michal
T Karthik Reddy (4): soc: xilinx: zynqmp: Add soc_xilinx_zynqmp driver soc: xilinx: versal: Add soc_xilinx_versal driver xilinx: common: Add function to print SoC info xilinx: Enable config to display cpuinfo
MAINTAINERS | 2 + arch/arm/Kconfig | 2 + arch/arm/mach-versal/cpu.c | 5 ++ arch/arm/mach-versal/include/mach/hardware.h | 4 + arch/arm/mach-zynqmp/cpu.c | 5 ++ arch/arm/mach-zynqmp/include/mach/hardware.h | 3 + board/xilinx/common/board.c | 26 +++++++ configs/xilinx_versal_virt_defconfig | 2 +- configs/xilinx_zynqmp_virt_defconfig | 2 +- drivers/soc/Kconfig | 16 ++++ drivers/soc/Makefile | 2 + drivers/soc/soc_xilinx_versal.c | 76 +++++++++++++++++++ drivers/soc/soc_xilinx_zynqmp.c | 78 ++++++++++++++++++++ 13 files changed, 221 insertions(+), 2 deletions(-) create mode 100644 drivers/soc/soc_xilinx_versal.c create mode 100644 drivers/soc/soc_xilinx_zynqmp.c
soc_xilinx_zynqmp driver allows identification of family & revision of zynqmp SoC. This driver is selected by CONFIG_SOC_XILINX_ZYNQMP. Add this config to xilinx_zynqmp_virt_defconfig file. Probe this driver using platdata U_BOOT_DEVICE structure which is specified in mach-zynqmp/cpu.c.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Reviewed-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
MAINTAINERS | 1 + arch/arm/Kconfig | 1 + arch/arm/mach-zynqmp/cpu.c | 5 ++ arch/arm/mach-zynqmp/include/mach/hardware.h | 3 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/soc/Kconfig | 8 ++ drivers/soc/Makefile | 1 + drivers/soc/soc_xilinx_zynqmp.c | 78 ++++++++++++++++++++ 8 files changed, 98 insertions(+) create mode 100644 drivers/soc/soc_xilinx_zynqmp.c
diff --git a/MAINTAINERS b/MAINTAINERS index 868d4e145ca2..af5a1fedf1d3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -602,6 +602,7 @@ F: drivers/net/zynq_gem.c F: drivers/serial/serial_zynq.c F: drivers/reset/reset-zynqmp.c F: drivers/rtc/zynqmp_rtc.c +F: drivers/soc/soc_xilinx_zynqmp.c F: drivers/spi/zynq_qspi.c F: drivers/spi/zynq_spi.c F: drivers/timer/cadence-ttc.c diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3a745ce126aa..3e8a31f8ad56 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1133,6 +1133,7 @@ config ARCH_ZYNQMP select SPL_SEPARATE_BSS if SPL select SUPPORT_SPL select ZYNQMP_IPI + select SOC_DEVICE imply BOARD_LATE_INIT imply CMD_DM imply ENV_VARS_UBOOT_RUNTIME_CONFIG diff --git a/arch/arm/mach-zynqmp/cpu.c b/arch/arm/mach-zynqmp/cpu.c index 29743cae5aab..26e285c24fe0 100644 --- a/arch/arm/mach-zynqmp/cpu.c +++ b/arch/arm/mach-zynqmp/cpu.c @@ -15,6 +15,7 @@ #include <asm/io.h> #include <zynqmp_firmware.h> #include <asm/cache.h> +#include <dm/platdata.h>
#define ZYNQ_SILICON_VER_MASK 0xF000 #define ZYNQ_SILICON_VER_SHIFT 12 @@ -218,3 +219,7 @@ int zynqmp_mmio_read(const u32 address, u32 *value)
return ret; } + +U_BOOT_DRVINFO(soc_xilinx_zynqmp) = { + .name = "soc_xilinx_zynqmp", +}; diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index 37764990707c..eebf38551c2f 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -69,6 +69,9 @@ struct iou_scntr_secure {
#define iou_scntr_secure ((struct iou_scntr_secure *)ZYNQMP_IOU_SCNTR_SECURE)
+#define ZYNQMP_PS_VERSION 0xFFCA0044 +#define ZYNQMP_PS_VER_MASK GENMASK(1, 0) + /* Bootmode setting values */ #define BOOT_MODES_MASK 0x0000000F #define QSPI_MODE_24BIT 0x00000001 diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 2c888130fa59..5b2f2f69e461 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -160,6 +160,7 @@ CONFIG_DM_SCSI=y CONFIG_ARM_DCC=y CONFIG_XILINX_UARTLITE=y CONFIG_ZYNQ_SERIAL=y +CONFIG_SOC_XILINX_ZYNQMP=y CONFIG_SPI=y CONFIG_ZYNQ_SPI=y CONFIG_ZYNQMP_GQSPI=y diff --git a/drivers/soc/Kconfig b/drivers/soc/Kconfig index 864d00a88538..17fb4c4d65e5 100644 --- a/drivers/soc/Kconfig +++ b/drivers/soc/Kconfig @@ -16,6 +16,14 @@ config SOC_DEVICE_TI_K3 This allows Texas Instruments Keystone 3 SoCs to identify specifics about the SoC in use.
+config SOC_XILINX_ZYNQMP + bool "Enable SoC Device ID driver for Xilinx ZynqMP" + depends on SOC_DEVICE && ARCH_ZYNQMP + help + Enable this option to select SoC device id driver for Xilinx ZynqMP. + This allows other drivers to verify the SoC familiy & revision + using matching SoC attributes. + source "drivers/soc/ti/Kconfig"
endmenu diff --git a/drivers/soc/Makefile b/drivers/soc/Makefile index 9ef20ca5066f..9b26573c71c8 100644 --- a/drivers/soc/Makefile +++ b/drivers/soc/Makefile @@ -6,3 +6,4 @@ obj-$(CONFIG_SOC_TI) += ti/ obj-$(CONFIG_SOC_DEVICE) += soc-uclass.o obj-$(CONFIG_SOC_DEVICE_TI_K3) += soc_ti_k3.o obj-$(CONFIG_SANDBOX) += soc_sandbox.o +obj-$(CONFIG_SOC_XILINX_ZYNQMP) += soc_xilinx_zynqmp.o diff --git a/drivers/soc/soc_xilinx_zynqmp.c b/drivers/soc/soc_xilinx_zynqmp.c new file mode 100644 index 000000000000..7d33ce2163d8 --- /dev/null +++ b/drivers/soc/soc_xilinx_zynqmp.c @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Xilinx ZynqMP SOC driver + * + * Copyright (C) 2021 Xilinx, Inc. + */ + +#include <common.h> +#include <dm.h> +#include <asm/cache.h> +#include <soc.h> +#include <zynqmp_firmware.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> + +/* + * Zynqmp has 4 silicon revisions + * v0 -> 0(XCZU9EG-ES1) + * v1 -> 1(XCZU3EG-ES1, XCZU15EG-ES1) + * v2 -> 2(XCZU7EV-ES1, XCZU9EG-ES2, XCZU19EG-ES1) + * v3 -> 3(Production Level) + */ +static const char zynqmp_family[] = "ZynqMP"; + +struct soc_xilinx_zynqmp_priv { + const char *family; + char revision; +}; + +static int soc_xilinx_zynqmp_get_family(struct udevice *dev, char *buf, int size) +{ + struct soc_xilinx_zynqmp_priv *priv = dev_get_priv(dev); + + return snprintf(buf, size, "%s", priv->family); +} + +static int soc_xilinx_zynqmp_get_revision(struct udevice *dev, char *buf, int size) +{ + struct soc_xilinx_zynqmp_priv *priv = dev_get_priv(dev); + + return snprintf(buf, size, "v%d", priv->revision); +} + +static const struct soc_ops soc_xilinx_zynqmp_ops = { + .get_family = soc_xilinx_zynqmp_get_family, + .get_revision = soc_xilinx_zynqmp_get_revision, +}; + +static int soc_xilinx_zynqmp_probe(struct udevice *dev) +{ + struct soc_xilinx_zynqmp_priv *priv = dev_get_priv(dev); + u32 ret_payload[4]; + int ret; + + priv->family = zynqmp_family; + + if (IS_ENABLED(CONFIG_SPL_BUILD) || current_el() == 3 || + !IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) + ret = zynqmp_mmio_read(ZYNQMP_PS_VERSION, &ret_payload[2]); + else + ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, + ret_payload); + if (ret < 0) + return ret; + + priv->revision = ret_payload[2] & ZYNQMP_PS_VER_MASK; + + return 0; +} + +U_BOOT_DRIVER(soc_xilinx_zynqmp) = { + .name = "soc_xilinx_zynqmp", + .id = UCLASS_SOC, + .ops = &soc_xilinx_zynqmp_ops, + .probe = soc_xilinx_zynqmp_probe, + .priv_auto = sizeof(struct soc_xilinx_zynqmp_priv), + .flags = DM_FLAG_PRE_RELOC, +};
soc_xilinx_versal driver allows identification of family & revision of versal SoC. This driver is selected by CONFIG_SOC_XILINX_VERSAL. Probe this driver using platdata U_BOOT_DEVICE structure which is defined at mach-versal/cpu.c. Add this config to xilinx_versal_virt_defconfig & xilinx_versal_mini_ospi_defconfig file to select this driver.
MAINTAINERS | 1 + arch/arm/Kconfig | 1 + arch/arm/mach-versal/cpu.c | 5 ++ arch/arm/mach-versal/include/mach/hardware.h | 4 ++ configs/xilinx_versal_virt_defconfig | 1 + drivers/soc/Kconfig | 8 +++ drivers/soc/Makefile | 1 + drivers/soc/soc_xilinx_versal.c | 76 ++++++++++++++++++++ 8 files changed, 97 insertions(+) create mode 100644 drivers/soc/soc_xilinx_versal.c
diff --git a/MAINTAINERS b/MAINTAINERS index af5a1fedf1d3..4cf0c33c5d58 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -546,6 +546,7 @@ S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-microblaze.git F: arch/arm/mach-versal/ F: drivers/net/xilinx_axi_mrmac.* +F: drivers/soc/soc_xilinx_versal.c F: drivers/watchdog/xilinx_wwdt.c N: (?<!uni)versal
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3e8a31f8ad56..0cc4326f2564 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1055,6 +1055,7 @@ config ARCH_VERSAL select DM_SERIAL select GPIO_EXTRA_HEADER select OF_CONTROL + select SOC_DEVICE imply BOARD_LATE_INIT imply ENV_VARS_UBOOT_RUNTIME_CONFIG
diff --git a/arch/arm/mach-versal/cpu.c b/arch/arm/mach-versal/cpu.c index a35aac2c02c2..9dc308bbc3d9 100644 --- a/arch/arm/mach-versal/cpu.c +++ b/arch/arm/mach-versal/cpu.c @@ -13,6 +13,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> #include <asm/cache.h> +#include <dm/platdata.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -120,3 +121,7 @@ int arm_reserve_mmu(void) return 0; } #endif + +U_BOOT_DRVINFO(soc_xilinx_versal) = { + .name = "soc_xilinx_versal", +}; diff --git a/arch/arm/mach-versal/include/mach/hardware.h b/arch/arm/mach-versal/include/mach/hardware.h index 9af5afd3f3f4..7b728ac11018 100644 --- a/arch/arm/mach-versal/include/mach/hardware.h +++ b/arch/arm/mach-versal/include/mach/hardware.h @@ -65,6 +65,10 @@ struct crp_regs {
#define crp_base ((struct crp_regs *)VERSAL_CRP_BASEADDR)
+#define VERSAL_PS_PMC_VERSION 0xF11A0004 +#define VERSAL_PS_VER_MASK GENMASK(7, 0) +#define VERSAL_PS_VER_SHIFT 12 + /* Bootmode setting values */ #define BOOT_MODES_MASK 0x0000000F #define QSPI_MODE_24BIT 0x00000001 diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index c894d32a9259..15fa5b9900c9 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -96,6 +96,7 @@ CONFIG_ZYNQ_GEM=y CONFIG_ARM_DCC=y CONFIG_PL01X_SERIAL=y CONFIG_XILINX_UARTLITE=y +CONFIG_SOC_XILINX_VERSAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ZYNQ_SPI=y diff --git a/drivers/soc/Kconfig b/drivers/soc/Kconfig index 17fb4c4d65e5..292dc41b6fa2 100644 --- a/drivers/soc/Kconfig +++ b/drivers/soc/Kconfig @@ -24,6 +24,14 @@ config SOC_XILINX_ZYNQMP This allows other drivers to verify the SoC familiy & revision using matching SoC attributes.
+config SOC_XILINX_VERSAL + bool "Enable SoC Device ID driver for Xilinx Versal" + depends on SOC_DEVICE && ARCH_VERSAL + help + Enable this option to select SoC device id driver for Xilinx Versal. + This allows other drivers to verify the SoC familiy & revision using + matching SoC attributes. + source "drivers/soc/ti/Kconfig"
endmenu diff --git a/drivers/soc/Makefile b/drivers/soc/Makefile index 9b26573c71c8..031fa7612f48 100644 --- a/drivers/soc/Makefile +++ b/drivers/soc/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_SOC_DEVICE) += soc-uclass.o obj-$(CONFIG_SOC_DEVICE_TI_K3) += soc_ti_k3.o obj-$(CONFIG_SANDBOX) += soc_sandbox.o obj-$(CONFIG_SOC_XILINX_ZYNQMP) += soc_xilinx_zynqmp.o +obj-$(CONFIG_SOC_XILINX_VERSAL) += soc_xilinx_versal.o diff --git a/drivers/soc/soc_xilinx_versal.c b/drivers/soc/soc_xilinx_versal.c new file mode 100644 index 000000000000..f8bcd9ab404d --- /dev/null +++ b/drivers/soc/soc_xilinx_versal.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Xilinx Versal SOC driver + * + * Copyright (C) 2021 Xilinx, Inc. + */ + +#include <common.h> +#include <dm.h> +#include <soc.h> +#include <zynqmp_firmware.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* + * v1 -> 0x10 - ES1 + * v2 -> 0x20 - Production + */ +static const char versal_family[] = "Versal"; + +struct soc_xilinx_versal_priv { + const char *family; + char revision; +}; + +static int soc_xilinx_versal_get_family(struct udevice *dev, char *buf, int size) +{ + struct soc_xilinx_versal_priv *priv = dev_get_priv(dev); + + return snprintf(buf, size, "%s", priv->family); +} + +static int soc_xilinx_versal_get_revision(struct udevice *dev, char *buf, int size) +{ + struct soc_xilinx_versal_priv *priv = dev_get_priv(dev); + + return snprintf(buf, size, "v%d", priv->revision); +} + +static const struct soc_ops soc_xilinx_versal_ops = { + .get_family = soc_xilinx_versal_get_family, + .get_revision = soc_xilinx_versal_get_revision, +}; + +static int soc_xilinx_versal_probe(struct udevice *dev) +{ + struct soc_xilinx_versal_priv *priv = dev_get_priv(dev); + u32 ret_payload[4]; + int ret; + + priv->family = versal_family; + + if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { + ret = xilinx_pm_request(PM_GET_CHIPID, 0, 0, 0, 0, + ret_payload); + if (ret) + return ret; + } else { + ret_payload[2] = readl(VERSAL_PS_PMC_VERSION); + if (!ret_payload[2]) + return -EINVAL; + } + + priv->revision = ret_payload[2] >> VERSAL_PS_VER_SHIFT; + + return 0; +} + +U_BOOT_DRIVER(soc_xilinx_versal) = { + .name = "soc_xilinx_versal", + .id = UCLASS_SOC, + .ops = &soc_xilinx_versal_ops, + .probe = soc_xilinx_versal_probe, + .priv_auto = sizeof(struct soc_xilinx_versal_priv), + .flags = DM_FLAG_PRE_RELOC, +};
Add print_cpuinfo() to print SoC info like family & revision. This function depends on CONFIG_DISPLAY_CPUINFO config.
board/xilinx/common/board.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 92b61d83ca47..90c87bab5cff 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -18,6 +18,7 @@ #include <i2c_eeprom.h> #include <net.h> #include <generated/dt.h> +#include <soc.h>
#include "fru.h"
@@ -440,3 +441,28 @@ int __maybe_unused board_fit_config_name_match(const char *name)
return -1; } + +#if defined(CONFIG_DISPLAY_CPUINFO) && !defined(CONFIG_ARCH_ZYNQ) +int print_cpuinfo(void) +{ + struct udevice *soc; + char name[SOC_MAX_STR_SIZE]; + int ret; + + ret = soc_get(&soc); + if (ret) { + printf("CPU: UNKNOWN\n"); + return 0; + } + + ret = soc_get_family(soc, name, SOC_MAX_STR_SIZE); + if (ret) + printf("CPU: %s\n", name); + + ret = soc_get_revision(soc, name, SOC_MAX_STR_SIZE); + if (ret) + printf("Silicon: %s\n", name); + + return 0; +} +#endif
Enable CONFIG_DISPLAY_CPUINFO to display SoC family & revision.
configs/xilinx_versal_virt_defconfig | 1 - configs/xilinx_zynqmp_virt_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 15fa5b9900c9..590a2171c114 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTDELAY=5 CONFIG_USE_PREBOOT=y -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="Versal> " CONFIG_CMD_BOOTMENU=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 5b2f2f69e461..2d3402857f48 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="scsi reset;usb reset" -# CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_FPGA=y
Ășt 10. 8. 2021 v 15:45 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.32.0
Applied. M
Michal Simek
Michal Simek
