[U-Boot] [PATCH 0/6] AM43xx OP-TEE support
Hello all,
This series brings our firewall and OP-TEE support from DRA7xx/AM57xx family devices to the AM43xx class devices. We do this by factoring out code common code from omap5/ into common mach-omap2/ sources. Then add the hooks for the AM43xx boards.
Thanks, Andrew
Andrew F. Davis (6): arm: mach-omap2: Move omap5/sec-fxns.c into sec-common.c arm: mach-omap2: Factor out common FDT fixup suport arm: mach-omap2: fdt-common: Add OP-TEE node when firmware node is defined arm: mach-omap2: am33xx: Add FDT fixup suport for AM33xx/AM43xx boards board: ti: am43xx: Add TEE loading and firewall setup board: ti: am43xx: Add FDT fixup for HS devices
arch/arm/include/asm/omap_common.h | 5 + arch/arm/include/asm/omap_sec_common.h | 6 + arch/arm/mach-omap2/Kconfig | 26 ++++ arch/arm/mach-omap2/Makefile | 2 + arch/arm/mach-omap2/am33xx/Makefile | 1 + arch/arm/mach-omap2/am33xx/fdt.c | 43 ++++++ arch/arm/mach-omap2/fdt-common.c | 168 +++++++++++++++++++++ arch/arm/mach-omap2/omap5/Kconfig | 26 ---- arch/arm/mach-omap2/omap5/Makefile | 1 - arch/arm/mach-omap2/omap5/fdt.c | 119 --------------- .../mach-omap2/{omap5/sec-fxns.c => sec-common.c} | 157 ++++++++++++++++++- board/ti/am43xx/board.c | 16 ++ configs/am43xx_hs_evm_defconfig | 4 + 13 files changed, 420 insertions(+), 154 deletions(-) create mode 100644 arch/arm/mach-omap2/am33xx/fdt.c create mode 100644 arch/arm/mach-omap2/fdt-common.c rename arch/arm/mach-omap2/{omap5/sec-fxns.c => sec-common.c} (64%)
TEE loading and firewall setup are common to all omap2 devices, move these function out of omap5 and into mach-omap2. This allows us to use these functions from other omap class devices.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/mach-omap2/Kconfig | 26 ++++ arch/arm/mach-omap2/omap5/Kconfig | 26 ---- arch/arm/mach-omap2/omap5/Makefile | 1 - .../mach-omap2/{omap5/sec-fxns.c => sec-common.c} | 155 ++++++++++++++++++++- 4 files changed, 174 insertions(+), 34 deletions(-) rename arch/arm/mach-omap2/{omap5/sec-fxns.c => sec-common.c} (64%)
diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 683cdb9296..013586edd9 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -119,6 +119,32 @@ config TI_SECURE_DEVICE authenticated) and the code. See the doc/README.ti-secure file for further details.
+config TI_SECURE_EMIF_REGION_START + hex "Reserved EMIF region start address" + depends on TI_SECURE_DEVICE + default 0x0 + help + Reserved EMIF region start address. Set to "0" to auto-select + to be at the end of the external memory region. + +config TI_SECURE_EMIF_TOTAL_REGION_SIZE + hex "Reserved EMIF region size" + depends on TI_SECURE_DEVICE + default 0x0 + help + Total reserved EMIF region size. Default is 0, which means no reserved EMIF + region on secure devices. + +config TI_SECURE_EMIF_PROTECTED_REGION_SIZE + hex "Size of protected region within reserved EMIF region" + depends on TI_SECURE_DEVICE + default 0x0 + help + This config option is used to specify the size of the portion of the total + reserved EMIF region set aside for secure OS needs that will be protected + using hardware memory firewalls. This value must be smaller than the + TI_SECURE_EMIF_TOTAL_REGION_SIZE value. + source "arch/arm/mach-omap2/omap3/Kconfig"
source "arch/arm/mach-omap2/omap4/Kconfig" diff --git a/arch/arm/mach-omap2/omap5/Kconfig b/arch/arm/mach-omap2/omap5/Kconfig index 1a66abdeb2..7e8e532d4c 100644 --- a/arch/arm/mach-omap2/omap5/Kconfig +++ b/arch/arm/mach-omap2/omap5/Kconfig @@ -37,32 +37,6 @@ endchoice config SYS_SOC default "omap5"
-config TI_SECURE_EMIF_REGION_START - hex "Reserved EMIF region start address" - depends on TI_SECURE_DEVICE - default 0x0 - help - Reserved EMIF region start address. Set to "0" to auto-select - to be at the end of the external memory region. - -config TI_SECURE_EMIF_TOTAL_REGION_SIZE - hex "Reserved EMIF region size" - depends on TI_SECURE_DEVICE - default 0x0 - help - Total reserved EMIF region size. Default is 0, which means no reserved EMIF - region on secure devices. - -config TI_SECURE_EMIF_PROTECTED_REGION_SIZE - hex "Size of protected region within reserved EMIF region" - depends on TI_SECURE_DEVICE - default 0x0 - help - This config option is used to specify the size of the portion of the total - reserved EMIF region set aside for secure OS needs that will be protected - using hardware memory firewalls. This value must be smaller than the - TI_SECURE_EMIF_TOTAL_REGION_SIZE value. - config OMAP_PLATFORM_RESET_TIME_MAX_USEC int "Something" range 0 31219 diff --git a/arch/arm/mach-omap2/omap5/Makefile b/arch/arm/mach-omap2/omap5/Makefile index af17a3deab..a6a5d17ff6 100644 --- a/arch/arm/mach-omap2/omap5/Makefile +++ b/arch/arm/mach-omap2/omap5/Makefile @@ -14,5 +14,4 @@ obj-y += hw_data.o obj-y += abb.o obj-y += fdt.o obj-$(CONFIG_IODELAY_RECALIBRATION) += dra7xx_iodelay.o -obj-$(CONFIG_TI_SECURE_DEVICE) += sec-fxns.o obj-$(CONFIG_DRA7XX) += sec_entry_cpu1.o diff --git a/arch/arm/mach-omap2/omap5/sec-fxns.c b/arch/arm/mach-omap2/sec-common.c similarity index 64% rename from arch/arm/mach-omap2/omap5/sec-fxns.c rename to arch/arm/mach-omap2/sec-common.c index 7fab57592e..f230c9ea4e 100644 --- a/arch/arm/mach-omap2/omap5/sec-fxns.c +++ b/arch/arm/mach-omap2/sec-common.c @@ -1,12 +1,14 @@ /* * - * Security related functions for OMAP5 class devices + * Common security related functions for OMAP devices * - * (C) Copyright 2016 + * (C) Copyright 2016-2017 * Texas Instruments, <www.ti.com> * * Daniel Allred d-allred@ti.com + * Andreas Dannenberg dannenberg@ti.com * Harinarayan Bhatta harinarayan@ti.com + * Andrew F. Davis afd@ti.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -15,14 +17,22 @@ #include <stdarg.h>
#include <asm/arch/sys_proto.h> +#include <asm/cache.h> #include <asm/omap_common.h> #include <asm/omap_sec_common.h> #include <asm/spl.h> -#include <spl.h> -#include <asm/cache.h> +#include <asm/ti-common/sys_proto.h> #include <mapmem.h> +#include <spl.h> #include <tee/optee.h>
+/* Index for signature verify ROM API */ +#ifdef CONFIG_AM33XX +#define API_HAL_KM_VERIFYCERTIFICATESIGNATURE_INDEX (0x0000000C) +#else +#define API_HAL_KM_VERIFYCERTIFICATESIGNATURE_INDEX (0x0000000E) +#endif + /* Index for signature PPA-based TI HAL APIs */ #define PPA_HAL_SERVICES_START_INDEX (0x200) #define PPA_SERV_HAL_TEE_LOAD_MASTER (PPA_HAL_SERVICES_START_INDEX + 23) @@ -43,6 +53,129 @@ struct ppa_tee_load_info { u32 tee_arg0; /* argument to TEE jump function, in r0 */ };
+static uint32_t secure_rom_call_args[5] __aligned(ARCH_DMA_MINALIGN); + +u32 secure_rom_call(u32 service, u32 proc_id, u32 flag, ...) +{ + int i; + u32 num_args; + va_list ap; + + va_start(ap, flag); + + num_args = va_arg(ap, u32); + + if (num_args > 4) { + va_end(ap); + return 1; + } + + /* Copy args to aligned args structure */ + for (i = 0; i < num_args; i++) + secure_rom_call_args[i + 1] = va_arg(ap, u32); + + secure_rom_call_args[0] = num_args; + + va_end(ap); + + /* if data cache is enabled, flush the aligned args structure */ + flush_dcache_range( + (unsigned int)&secure_rom_call_args[0], + (unsigned int)&secure_rom_call_args[0] + + roundup(sizeof(secure_rom_call_args), ARCH_DMA_MINALIGN)); + + return omap_smc_sec(service, proc_id, flag, secure_rom_call_args); +} + +static u32 find_sig_start(char *image, size_t size) +{ + char *image_end = image + size; + char *sig_start_magic = "CERT_"; + int magic_str_len = strlen(sig_start_magic); + char *ch; + + while (--image_end > image) { + if (*image_end == '_') { + ch = image_end - magic_str_len + 1; + if (!strncmp(ch, sig_start_magic, magic_str_len)) + return (u32)ch; + } + } + return 0; +} + +int secure_boot_verify_image(void **image, size_t *size) +{ + int result = 1; + u32 cert_addr, sig_addr; + size_t cert_size; + + /* Perform cache writeback on input buffer */ + flush_dcache_range( + (u32)*image, + (u32)*image + roundup(*size, ARCH_DMA_MINALIGN)); + + cert_addr = (uint32_t)*image; + sig_addr = find_sig_start((char *)*image, *size); + + if (sig_addr == 0) { + printf("No signature found in image!\n"); + result = 1; + goto auth_exit; + } + + *size = sig_addr - cert_addr; /* Subtract out the signature size */ + cert_size = *size; + + /* Check if image load address is 32-bit aligned */ + if (!IS_ALIGNED(cert_addr, 4)) { + printf("Image is not 4-byte aligned!\n"); + result = 1; + goto auth_exit; + } + + /* Image size also should be multiple of 4 */ + if (!IS_ALIGNED(cert_size, 4)) { + printf("Image size is not 4-byte aligned!\n"); + result = 1; + goto auth_exit; + } + + /* Call ROM HAL API to verify certificate signature */ + debug("%s: load_addr = %x, size = %x, sig_addr = %x\n", __func__, + cert_addr, cert_size, sig_addr); + + result = secure_rom_call( + API_HAL_KM_VERIFYCERTIFICATESIGNATURE_INDEX, 0, 0, + 4, cert_addr, cert_size, sig_addr, 0xFFFFFFFF); + + /* Perform cache writeback on output buffer */ + flush_dcache_range( + (u32)*image, + (u32)*image + roundup(*size, ARCH_DMA_MINALIGN)); + +auth_exit: + if (result != 0) { + printf("Authentication failed!\n"); + printf("Return Value = %08X\n", result); + hang(); + } + + /* + * Output notification of successful authentication as well the name of + * the signing certificate used to re-assure the user that the secure + * code is being processed as expected. However suppress any such log + * output in case of building for SPL and booting via YMODEM. This is + * done to avoid disturbing the YMODEM serial protocol transactions. + */ + if (!(IS_ENABLED(CONFIG_SPL_BUILD) && + IS_ENABLED(CONFIG_SPL_YMODEM_SUPPORT) && + spl_boot_device() == BOOT_DEVICE_UART)) + printf("Authentication passed: %s\n", (char *)sig_addr); + + return result; +} + static u32 get_sec_mem_start(void) { u32 sec_mem_start = CONFIG_TI_SECURE_EMIF_REGION_START; @@ -55,8 +188,14 @@ static u32 get_sec_mem_start(void) */ if (sec_mem_start == 0) sec_mem_start = - (CONFIG_SYS_SDRAM_BASE + - (omap_sdram_size() - sec_mem_size)); + (CONFIG_SYS_SDRAM_BASE + ( +#if defined(CONFIG_OMAP54XX) + omap_sdram_size() +#else + get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_MAX_RAM_BANK_SIZE) +#endif + - sec_mem_size)); return sec_mem_start; }
@@ -151,7 +290,6 @@ int secure_tee_install(u32 addr) u32 tee_file_size; u32 sec_mem_start = get_sec_mem_start(); const u32 size = CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE; - u32 *smc_cpu1_params; u32 ret;
/* If there is no protected region, there is no place to put the TEE */ @@ -211,7 +349,9 @@ int secure_tee_install(u32 addr) } printf("TEE_LOAD_MASTER Done\n");
+#if defined(CONFIG_OMAP54XX) if (!is_dra72x()) { + u32 *smc_cpu1_params; /* Reuse the tee_info buffer for SMC params */ smc_cpu1_params = (u32 *)&tee_info; smc_cpu1_params[0] = 0; @@ -227,6 +367,7 @@ int secure_tee_install(u32 addr) } printf("TEE_LOAD_SLAVE Done\n"); } +#endif
tee_loaded = 1;
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Some of the fixups currently done for OMAP5 class boards are common to other OMAP family devices, move these to fdt-common.c.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/include/asm/omap_common.h | 5 ++ arch/arm/include/asm/omap_sec_common.h | 6 ++ arch/arm/mach-omap2/Makefile | 2 + arch/arm/mach-omap2/fdt-common.c | 160 +++++++++++++++++++++++++++++++++ arch/arm/mach-omap2/omap5/fdt.c | 119 ------------------------ arch/arm/mach-omap2/sec-common.c | 2 +- 6 files changed, 174 insertions(+), 120 deletions(-) create mode 100644 arch/arm/mach-omap2/fdt-common.c
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d2ca277772..ef5c481349 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -680,6 +680,11 @@ void omap_die_id(unsigned int *die_id); /* Initialize general purpose I2C(0) on the SoC */ void gpi2c_init(void);
+/* Common FDT Fixups */ +int ft_hs_disable_rng(void *fdt, bd_t *bd); +int ft_hs_fixup_dram(void *fdt, bd_t *bd); +int ft_hs_add_tee(void *fdt, bd_t *bd); + /* ABB */ #define OMAP_ABB_NOMINAL_OPP 0 #define OMAP_ABB_FAST_OPP 1 diff --git a/arch/arm/include/asm/omap_sec_common.h b/arch/arm/include/asm/omap_sec_common.h index 79f1fbd2c1..76d0862270 100644 --- a/arch/arm/include/asm/omap_sec_common.h +++ b/arch/arm/include/asm/omap_sec_common.h @@ -28,6 +28,12 @@ u32 secure_rom_call(u32 service, u32 proc_id, u32 flag, ...); int secure_boot_verify_image(void **p_image, size_t *p_size);
/* + * Return the start of secure reserved RAM, if a default start address has + * not been configured then return a region at the end of the external DRAM. + */ +u32 get_sec_mem_start(void); + +/* * Invoke a secure HAL API that allows configuration of the external memory * firewall regions. */ diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile index d43085ca98..d86643db34 100644 --- a/arch/arm/mach-omap2/Makefile +++ b/arch/arm/mach-omap2/Makefile @@ -45,4 +45,6 @@ obj-y += lowlevel_init.o
obj-y += mem-common.o
+obj-y += fdt-common.o + obj-$(CONFIG_TI_SECURE_DEVICE) += sec-common.o diff --git a/arch/arm/mach-omap2/fdt-common.c b/arch/arm/mach-omap2/fdt-common.c new file mode 100644 index 0000000000..297d4d4df5 --- /dev/null +++ b/arch/arm/mach-omap2/fdt-common.c @@ -0,0 +1,160 @@ +/* + * Copyright 2016-2017 Texas Instruments, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> + +#include <asm/omap_common.h> +#include <asm/omap_sec_common.h> + +#ifdef CONFIG_TI_SECURE_DEVICE + +/* Give zero values if not already defined */ +#ifndef TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ +#define TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ (0) +#endif +#ifndef CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ +#define CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ (0) +#endif + +int ft_hs_disable_rng(void *fdt, bd_t *bd) +{ + const char *path; + int offs; + int ret; + + /* Make HW RNG reserved for secure world use */ + path = "/ocp/rng"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + debug("Node %s not found.\n", path); + return 0; + } + ret = fdt_setprop_string(fdt, offs, + "status", "disabled"); + if (ret < 0) { + printf("Could not add status property to node %s: %s\n", + path, fdt_strerror(ret)); + return ret; + } + return 0; +} + +#if (CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE != 0) +/* + * fdt_pack_reg - pack address and size array into the "reg"-suitable stream + */ +static int fdt_pack_reg(const void *fdt, void *buf, u64 address, u64 size) +{ + int address_cells = fdt_address_cells(fdt, 0); + int size_cells = fdt_size_cells(fdt, 0); + char *p = buf; + + if (address_cells == 2) + *(fdt64_t *)p = cpu_to_fdt64(address); + else + *(fdt32_t *)p = cpu_to_fdt32(address); + p += 4 * address_cells; + + if (size_cells == 2) + *(fdt64_t *)p = cpu_to_fdt64(size); + else + *(fdt32_t *)p = cpu_to_fdt32(size); + p += 4 * size_cells; + + return p - (char *)buf; +} + +int ft_hs_fixup_dram(void *fdt, bd_t *bd) +{ + const char *path, *subpath; + int offs, len; + u32 sec_mem_start = get_sec_mem_start(); + u32 sec_mem_size = CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE; + fdt32_t address_cells = cpu_to_fdt32(fdt_address_cells(fdt, 0)); + fdt32_t size_cells = cpu_to_fdt32(fdt_size_cells(fdt, 0)); + u8 temp[16]; /* Up to 64-bit address + 64-bit size */ + + /* Delete any original secure_reserved node */ + path = "/reserved-memory/secure_reserved"; + offs = fdt_path_offset(fdt, path); + if (offs >= 0) + fdt_del_node(fdt, offs); + + /* Add new secure_reserved node */ + path = "/reserved-memory"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + debug("Node %s not found\n", path); + path = "/"; + subpath = "reserved-memory"; + offs = fdt_path_offset(fdt, path); + offs = fdt_add_subnode(fdt, offs, subpath); + if (offs < 0) { + printf("Could not create %s%s node.\n", path, subpath); + return 1; + } + path = "/reserved-memory"; + offs = fdt_path_offset(fdt, path); + + fdt_setprop(fdt, offs, "#address-cells", &address_cells, sizeof(address_cells)); + fdt_setprop(fdt, offs, "#size-cells", &size_cells, sizeof(size_cells)); + fdt_setprop(fdt, offs, "ranges", NULL, 0); + } + + subpath = "secure_reserved"; + offs = fdt_add_subnode(fdt, offs, subpath); + if (offs < 0) { + printf("Could not create %s%s node.\n", path, subpath); + return 1; + } + + fdt_setprop_string(fdt, offs, "compatible", "ti,secure-memory"); + fdt_setprop_string(fdt, offs, "status", "okay"); + fdt_setprop(fdt, offs, "no-map", NULL, 0); + len = fdt_pack_reg(fdt, temp, sec_mem_start, sec_mem_size); + fdt_setprop(fdt, offs, "reg", temp, len); + + return 0; +} +#else +int ft_hs_fixup_dram(void *fdt, bd_t *bd) { return 0; } +#endif + +int ft_hs_add_tee(void *fdt, bd_t *bd) +{ + const char *path, *subpath; + int offs; + + extern int tee_loaded; + if (!tee_loaded) + return 0; + + path = "/"; + offs = fdt_path_offset(fdt, path); + + subpath = "firmware"; + offs = fdt_add_subnode(fdt, offs, subpath); + if (offs < 0) { + printf("Could not create %s node.\n", subpath); + return 1; + } + + subpath = "optee"; + offs = fdt_add_subnode(fdt, offs, subpath); + if (offs < 0) { + printf("Could not create %s node.\n", subpath); + return 1; + } + + fdt_setprop_string(fdt, offs, "compatible", "linaro,optee-tz"); + fdt_setprop_string(fdt, offs, "method", "smc"); + + return 0; +} + +#endif diff --git a/arch/arm/mach-omap2/omap5/fdt.c b/arch/arm/mach-omap2/omap5/fdt.c index 7a3a8db517..1e556da9be 100644 --- a/arch/arm/mach-omap2/omap5/fdt.c +++ b/arch/arm/mach-omap2/omap5/fdt.c @@ -90,29 +90,6 @@ static int ft_hs_fixup_crossbar(void *fdt, bd_t *bd) return 0; }
-static int ft_hs_disable_rng(void *fdt, bd_t *bd) -{ - const char *path; - int offs; - int ret; - - /* Make HW RNG reserved for secure world use */ - path = "/ocp/rng"; - offs = fdt_path_offset(fdt, path); - if (offs < 0) { - debug("Node %s not found.\n", path); - return 0; - } - ret = fdt_setprop_string(fdt, offs, - "status", "disabled"); - if (ret < 0) { - printf("Could not add status property to node %s: %s\n", - path, fdt_strerror(ret)); - return ret; - } - return 0; -} - #if ((TI_OMAP5_SECURE_BOOT_RESV_SRAM_SZ != 0) || \ (CONFIG_SECURE_RUNTIME_RESV_SRAM_SZ != 0)) static int ft_hs_fixup_sram(void *fdt, bd_t *bd) @@ -153,102 +130,6 @@ static int ft_hs_fixup_sram(void *fdt, bd_t *bd) static int ft_hs_fixup_sram(void *fdt, bd_t *bd) { return 0; } #endif
-#if (CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE != 0) -static int ft_hs_fixup_dram(void *fdt, bd_t *bd) -{ - const char *path, *subpath; - int offs; - u32 sec_mem_start = CONFIG_TI_SECURE_EMIF_REGION_START; - u32 sec_mem_size = CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE; - fdt64_t temp[2]; - fdt32_t two; - - /* If start address is zero, place at end of DRAM */ - if (0 == sec_mem_start) - sec_mem_start = - (CONFIG_SYS_SDRAM_BASE + - (omap_sdram_size() - sec_mem_size)); - - /* Delete any original secure_reserved node */ - path = "/reserved-memory/secure_reserved"; - offs = fdt_path_offset(fdt, path); - if (offs >= 0) - fdt_del_node(fdt, offs); - - /* Add new secure_reserved node */ - path = "/reserved-memory"; - offs = fdt_path_offset(fdt, path); - if (offs < 0) { - debug("Node %s not found\n", path); - path = "/"; - subpath = "reserved-memory"; - offs = fdt_path_offset(fdt, path); - offs = fdt_add_subnode(fdt, offs, subpath); - if (offs < 0) { - printf("Could not create %s%s node.\n", path, subpath); - return 1; - } - path = "/reserved-memory"; - offs = fdt_path_offset(fdt, path); - two = cpu_to_fdt32(2); - fdt_setprop(fdt, offs, "#address-cells", &two, sizeof(two)); - fdt_setprop(fdt, offs, "#size-cells", &two, sizeof(two)); - fdt_setprop(fdt, offs, "ranges", NULL, 0); - } - - subpath = "secure_reserved"; - offs = fdt_add_subnode(fdt, offs, subpath); - if (offs < 0) { - printf("Could not create %s%s node.\n", path, subpath); - return 1; - } - - temp[0] = cpu_to_fdt64(((u64)sec_mem_start)); - temp[1] = cpu_to_fdt64(((u64)sec_mem_size)); - fdt_setprop_string(fdt, offs, "compatible", - "ti,dra7-secure-memory"); - fdt_setprop_string(fdt, offs, "status", "okay"); - fdt_setprop(fdt, offs, "no-map", NULL, 0); - fdt_setprop(fdt, offs, "reg", temp, sizeof(temp)); - - return 0; -} -#else -static int ft_hs_fixup_dram(void *fdt, bd_t *bd) { return 0; } -#endif - -static int ft_hs_add_tee(void *fdt, bd_t *bd) -{ - const char *path, *subpath; - int offs; - - extern int tee_loaded; - if (!tee_loaded) - return 0; - - path = "/"; - offs = fdt_path_offset(fdt, path); - - subpath = "firmware"; - offs = fdt_add_subnode(fdt, offs, subpath); - if (offs < 0) { - printf("Could not create %s node.\n", subpath); - return 1; - } - - subpath = "optee"; - offs = fdt_add_subnode(fdt, offs, subpath); - if (offs < 0) { - printf("Could not create %s node.\n", subpath); - return 1; - } - - fdt_setprop_string(fdt, offs, "compatible", "linaro,optee-tz"); - fdt_setprop_string(fdt, offs, "method", "smc"); - - return 0; -} - static void ft_hs_fixups(void *fdt, bd_t *bd) { /* Check we are running on an HS/EMU device type */ diff --git a/arch/arm/mach-omap2/sec-common.c b/arch/arm/mach-omap2/sec-common.c index f230c9ea4e..030b36f332 100644 --- a/arch/arm/mach-omap2/sec-common.c +++ b/arch/arm/mach-omap2/sec-common.c @@ -176,7 +176,7 @@ auth_exit: return result; }
-static u32 get_sec_mem_start(void) +u32 get_sec_mem_start(void) { u32 sec_mem_start = CONFIG_TI_SECURE_EMIF_REGION_START; u32 sec_mem_size = CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE;
If a firmware node is already present in the FDT we will fail to create one and so fail to add our OP-TEE node, make this fixup first check for a firmware node and then only try to add one if it is not found.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/mach-omap2/fdt-common.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-omap2/fdt-common.c b/arch/arm/mach-omap2/fdt-common.c index 297d4d4df5..9297e9db48 100644 --- a/arch/arm/mach-omap2/fdt-common.c +++ b/arch/arm/mach-omap2/fdt-common.c @@ -134,14 +134,22 @@ int ft_hs_add_tee(void *fdt, bd_t *bd) if (!tee_loaded) return 0;
- path = "/"; + path = "/firmware"; offs = fdt_path_offset(fdt, path); - - subpath = "firmware"; - offs = fdt_add_subnode(fdt, offs, subpath); if (offs < 0) { - printf("Could not create %s node.\n", subpath); - return 1; + path = "/"; + offs = fdt_path_offset(fdt, path); + if (offs < 0) { + printf("Could not find root node.\n"); + return 1; + } + + subpath = "firmware"; + offs = fdt_add_subnode(fdt, offs, subpath); + if (offs < 0) { + printf("Could not create %s node.\n", subpath); + return 1; + } }
subpath = "optee";
Similar to what is done with OMAP5 class boards we need to perform fixups common to this SoC class, add support for this here and add HS fixups.
Signed-off-by: Andrew F. Davis afd@ti.com --- arch/arm/mach-omap2/am33xx/Makefile | 1 + arch/arm/mach-omap2/am33xx/fdt.c | 43 +++++++++++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+) create mode 100644 arch/arm/mach-omap2/am33xx/fdt.c
diff --git a/arch/arm/mach-omap2/am33xx/Makefile b/arch/arm/mach-omap2/am33xx/Makefile index b2f8158e73..9d4f83cb75 100644 --- a/arch/arm/mach-omap2/am33xx/Makefile +++ b/arch/arm/mach-omap2/am33xx/Makefile @@ -23,6 +23,7 @@ obj-y += board.o obj-y += mux.o obj-y += prcm-regs.o obj-y += hw_data.o +obj-y += fdt.o
obj-$(CONFIG_CLOCK_SYNTHESIZER) += clk_synthesizer.o
diff --git a/arch/arm/mach-omap2/am33xx/fdt.c b/arch/arm/mach-omap2/am33xx/fdt.c new file mode 100644 index 0000000000..02e8243800 --- /dev/null +++ b/arch/arm/mach-omap2/am33xx/fdt.c @@ -0,0 +1,43 @@ +/* + * Copyright 2017 Texas Instruments, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <malloc.h> + +#include <asm/omap_common.h> +#include <asm/arch-am33xx/sys_proto.h> + +#ifdef CONFIG_TI_SECURE_DEVICE + +static void ft_hs_fixups(void *fdt, bd_t *bd) +{ + /* Check we are running on an HS/EMU device type */ + if (GP_DEVICE != get_device_type()) { + if ((ft_hs_disable_rng(fdt, bd) == 0) && + (ft_hs_fixup_dram(fdt, bd) == 0) && + (ft_hs_add_tee(fdt, bd) == 0)) + return; + } else { + printf("ERROR: Incorrect device type (GP) detected!"); + } + /* Fixup failed or wrong device type */ + hang(); +} +#else +static void ft_hs_fixups(void *fdt, bd_t *bd) { } +#endif /* #ifdef CONFIG_TI_SECURE_DEVICE */ + +/* + * Place for general cpu/SoC FDT fixups. Board specific + * fixups should remain in the board files which is where + * this function should be called from. + */ +void ft_cpu_setup(void *fdt, bd_t *bd) +{ + ft_hs_fixups(fdt, bd); +}
Add support for loading a TEE and setting up firewalled regions to AM43xx HS boards.
Signed-off-by: Andrew F. Davis afd@ti.com --- board/ti/am43xx/board.c | 7 +++++++ configs/am43xx_hs_evm_defconfig | 3 +++ 2 files changed, 10 insertions(+)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 54f40e64a4..96032215a6 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -859,4 +859,11 @@ void board_fit_image_post_process(void **p_image, size_t *p_size) { secure_boot_verify_image(p_image, p_size); } + +void board_tee_image_process(ulong tee_image, size_t tee_size) +{ + secure_tee_install((u32)tee_image); +} + +U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_TEE, board_tee_image_process); #endif diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 6f3cb516fd..37d8e484db 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -4,6 +4,9 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_AM43XX=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TI_SECURE_DEVICE=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 CONFIG_TARGET_AM43XX_EVM=y CONFIG_ISW_ENTRY_ADDR=0x403018e0 CONFIG_SPL_STACK_R_ADDR=0x82000000
- secure_tee_install((u32)tee_image);
You might want to include CONFIG_PRAM inorder to not overlap relocation with this region?
I think I'll add this in a separate patch, I'm still not sure that is the best solution to avoid relocation overlap just yet.
Thanks, Andrew
Disable RNG and add TEE to FDT used on HS devices.
Signed-off-by: Andrew F. Davis afd@ti.com --- board/ti/am43xx/board.c | 9 +++++++++ configs/am43xx_hs_evm_defconfig | 1 + 2 files changed, 10 insertions(+)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 96032215a6..933596d59c 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -838,6 +838,15 @@ int board_eth_init(bd_t *bis) } #endif
+#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} +#endif + #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 37d8e484db..699d4cc0de 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -12,6 +12,7 @@ CONFIG_ISW_ENTRY_ADDR=0x403018e0 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,NAND"
Andrew F. Davis
Lokesh Vutla
