[U-Boot] Please pull u-boot-sunxi/master into master
Hi Tom,
Please pull u-boot-sunxi/master into master, highlights:
1) Kconfig cleanup by Ian 2) device-model support for gpio and uarts by Simon
The following changes since commit 26f195c71252e98aebfffd5cfa994a4475559370:
ARM: kwimage: fix v0 format (2014-11-04 15:03:07 -0500)
http://git.denx.de/u-boot-sunxi.git
for you to fetch changes up to 44fd5914fb08ffcd96c9db7e448787f1d2aed801:
dm: sunxi: Request USB vbus gpio (2014-11-05 13:10:22 +0100)
---------------------------------------------------------------- Chen-Yu Tsai (1): ARM: sunxi: Fix Ippo-q8h-v5 defconfig filename
Hans de Goede (2): dm: sunxi: Request card detect gpio dm: sunxi: Request USB vbus gpio
Ian Campbell (7): sunxi: kconfig: Add top-level ARCH_SUNXI sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I. sunxi: Kconfig: Make SPL_FEL a toplevel Kconfig option sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?I sunxi: Drop FEL variants of defconfigs. sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD> sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.
Simon Glass (6): dm: sunxi: dts: Add sun7i device tree files dm: sunxi: Add a new config for an FDT-based pcDuino3 dm: sunxi: Add pinmux functions which take a bank parameter dm: sunxi: Make sure that GPIOs are requested dm: sunxi: Modify the GPIO driver to support driver model dm: sunxi: Add support for serial using driver model
Makefile | 3 +- arch/arm/Kconfig | 26 +- arch/arm/cpu/armv7/sunxi/Makefile | 20 +- arch/arm/cpu/armv7/sunxi/board.c | 20 +- arch/arm/cpu/armv7/sunxi/clock_sun4i.c | 2 +- arch/arm/cpu/armv7/sunxi/cpu_info.c | 10 +- arch/arm/cpu/armv7/sunxi/dram.c | 34 +- arch/arm/cpu/armv7/sunxi/pinmux.c | 32 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-pcduino3.dts | 177 ++++++ arch/arm/dts/sun7i-a20.dtsi | 988 +++++++++++++++++++++++++++++ arch/arm/dts/sunxi-common-regulators.dtsi | 89 +++ arch/arm/include/asm/arch-sunxi/clock.h | 2 +- arch/arm/include/asm/arch-sunxi/gpio.h | 6 +- arch/arm/include/asm/arch-sunxi/mmc.h | 2 +- arch/arm/include/asm/arch-sunxi/timer.h | 4 +- arch/arm/include/asm/arch-sunxi/watchdog.h | 2 +- board/sunxi/Kconfig | 146 ++++- board/sunxi/MAINTAINERS | 3 +- board/sunxi/Makefile | 44 +- board/sunxi/ahci.c | 1 + configs/A10-OLinuXino-Lime_defconfig | 6 +- configs/A10s-OLinuXino-M_defconfig | 6 +- configs/A13-OLinuXinoM_defconfig | 6 +- configs/A13-OLinuXino_defconfig | 6 +- configs/A20-OLinuXino-Lime2_defconfig | 6 +- configs/A20-OLinuXino-Lime_defconfig | 6 +- configs/A20-OLinuXino_MICRO_defconfig | 6 +- configs/Auxtek-T004_defconfig | 6 +- configs/Bananapi_defconfig | 6 +- configs/Colombus_defconfig | 5 +- configs/Cubieboard2_FEL_defconfig | 5 - configs/Cubieboard2_defconfig | 6 +- configs/Cubieboard_defconfig | 6 +- configs/Cubietruck_FEL_defconfig | 5 - configs/Cubietruck_defconfig | 6 +- configs/Ippo_q8h_defconfig | 4 - configs/Ippo_q8h_v5_defconfig | 6 + configs/Linksprite_pcDuino3_defconfig | 6 +- configs/Linksprite_pcDuino3_fdt_defconfig | 11 + configs/Mele_A1000G_defconfig | 6 +- configs/Mele_A1000_defconfig | 6 +- configs/Mele_M3_defconfig | 6 +- configs/Mini-X-1Gb_defconfig | 6 +- configs/Mini-X_defconfig | 6 +- configs/ba10_tv_box_defconfig | 6 +- configs/i12-tvbox_defconfig | 6 +- configs/qt840a_defconfig | 6 +- configs/r7-tv-dongle_defconfig | 6 +- drivers/gpio/sunxi_gpio.c | 170 +++++ drivers/mmc/sunxi_mmc.c | 36 +- drivers/serial/Makefile | 1 + drivers/serial/serial_dw.c | 39 ++ drivers/usb/host/ehci-sunxi.c | 12 +- include/configs/sun4i.h | 1 - include/configs/sun5i.h | 1 - include/configs/sun6i.h | 1 - include/configs/sun7i.h | 1 - include/configs/sun8i.h | 1 - include/configs/sunxi-common.h | 22 +- include/dt-bindings/input/input.h | 525 +++++++++++++++ scripts/multiconfig.sh | 12 + 62 files changed, 2403 insertions(+), 199 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-pcduino3.dts create mode 100644 arch/arm/dts/sun7i-a20.dtsi create mode 100644 arch/arm/dts/sunxi-common-regulators.dtsi delete mode 100644 configs/Cubieboard2_FEL_defconfig delete mode 100644 configs/Cubietruck_FEL_defconfig delete mode 100644 configs/Ippo_q8h_defconfig create mode 100644 configs/Ippo_q8h_v5_defconfig create mode 100644 configs/Linksprite_pcDuino3_fdt_defconfig create mode 100644 drivers/serial/serial_dw.c create mode 100644 include/dt-bindings/input/input.h
Regards,
Hans
On Wed, Nov 05, 2014 at 01:19:18PM +0100, Hans de Goede wrote:
Hi Tom,
- Kconfig cleanup by Ian
- device-model support for gpio and uarts by Simon
Hans de Goede
