[U-Boot] [PATCH] riscv:Add Microchip MPFS Icicle Board support
This patch adds Microchip MPFS Icicle Board support. For now, NS16550 serial driver is only enabled. The Microchip MPFS Icicle defconfig by default builds U-Boot for M-Mode with SMP support.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- arch/riscv/Kconfig | 4 ++ board/microchip/mpfs-icicle/Kconfig | 20 ++++++++++ board/microchip/mpfs-icicle/MAINTAINERS | 7 ++++ board/microchip/mpfs-icicle/Makefile | 7 ++++ board/microchip/mpfs-icicle/mpfs-icicle.c | 31 +++++++++++++++ configs/microchip-mpfs-icicle_defconfig | 16 ++++++++ include/configs/microchip-mpfs-icicle.h | 63 +++++++++++++++++++++++++++++++ 7 files changed, 148 insertions(+) create mode 100644 board/microchip/mpfs-icicle/Kconfig create mode 100644 board/microchip/mpfs-icicle/MAINTAINERS create mode 100644 board/microchip/mpfs-icicle/Makefile create mode 100644 board/microchip/mpfs-icicle/mpfs-icicle.c create mode 100644 configs/microchip-mpfs-icicle_defconfig create mode 100644 include/configs/microchip-mpfs-icicle.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index ae8ff7b..df9b2ea 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -17,12 +17,16 @@ config TARGET_QEMU_VIRT config TARGET_SIFIVE_FU540 bool "Support SiFive FU540 Board"
+config TARGET_MICROCHIP_MPFS + bool "Support Microchip PolarFire-SoC Icicle Board" + endchoice
# board-specific options below source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/sifive/fu540/Kconfig" +source "board/microchip/mpfs-icicle/Kconfig"
# platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" diff --git a/board/microchip/mpfs-icicle/Kconfig b/board/microchip/mpfs-icicle/Kconfig new file mode 100644 index 0000000..e17ba78 --- /dev/null +++ b/board/microchip/mpfs-icicle/Kconfig @@ -0,0 +1,20 @@ +if TARGET_MICROCHIP_MPFS + +config SYS_BOARD + default "mpfs-icicle" + +config SYS_VENDOR + default "microchip" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "microchip-mpfs-icicle" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select GENERIC_RISCV + imply SMP + +endif diff --git a/board/microchip/mpfs-icicle/MAINTAINERS b/board/microchip/mpfs-icicle/MAINTAINERS new file mode 100644 index 0000000..9987efe --- /dev/null +++ b/board/microchip/mpfs-icicle/MAINTAINERS @@ -0,0 +1,7 @@ +Microchip MPFS icicle +M: Padmarao Begari padmarao.begari@microchip.com +M: Cyril Jean cyril.jean@microchip.com +S: Maintained +F: board/microchip/mpfs-icicle/ +F: include/configs/microchip-mpfs-icicle.h +F: configs/microchip-mpfs-icicle_defconfig diff --git a/board/microchip/mpfs-icicle/Makefile b/board/microchip/mpfs-icicle/Makefile new file mode 100644 index 0000000..4706586 --- /dev/null +++ b/board/microchip/mpfs-icicle/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Microchip Technology Inc. +# Padmarao Begari padmarao.begari@microchip.com +# + +obj-y += mpfs-icicle.o diff --git a/board/microchip/mpfs-icicle/mpfs-icicle.c b/board/microchip/mpfs-icicle/mpfs-icicle.c new file mode 100644 index 0000000..5a23a7d --- /dev/null +++ b/board/microchip/mpfs-icicle/mpfs-icicle.c @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> + +#define MPFS_SYSREG_SOFT_RESET ((unsigned int *)0x20002088) + +int board_init(void) +{ + /* For now nothing to do here. */ + + return 0; +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + unsigned int val; + /* Reset uart peripheral */ + val = readl(MPFS_SYSREG_SOFT_RESET); + val = (val & ~(1u << 5u)); + writel(val, MPFS_SYSREG_SOFT_RESET); + + return 0; +} +#endif diff --git a/configs/microchip-mpfs-icicle_defconfig b/configs/microchip-mpfs-icicle_defconfig new file mode 100644 index 0000000..2d1bd4a --- /dev/null +++ b/configs/microchip-mpfs-icicle_defconfig @@ -0,0 +1,16 @@ +CONFIG_RISCV=y +CONFIG_SYS_TEXT_BASE=0x80000000 +CONFIG_ARCH_RV64I=y +CONFIG_NR_CPUS=5 +CONFIG_TARGET_MICROCHIP_MPFS=y +CONFIG_BOOTDELAY=3 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_PROMPT="RISC-V # " +CONFIG_FIT=y +CONFIG_DM=y +CONFIG_BAUDRATE=57600 +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_PRIOR_STAGE=y +CONFIG_BOARD_EARLY_INIT_F=y diff --git a/include/configs/microchip-mpfs-icicle.h b/include/configs/microchip-mpfs-icicle.h new file mode 100644 index 0000000..82c7fbb --- /dev/null +++ b/include/configs/microchip-mpfs-icicle.h @@ -0,0 +1,63 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * CPU and Board Configuration Options + */ +#define CONFIG_BOOTP_SEND_HOSTNAME + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +/* + * Print Buffer Size + */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* + * max number of command args + */ +#define CONFIG_SYS_MAXARGS 16 + +/* + * Boot Argument Buffer Size + */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * Size of malloc() pool + * 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough + */ +#define CONFIG_SYS_MALLOC_LEN (512 << 10) + +/* + * Physical Memory Map + */ +#define PHYS_SDRAM_0 0x80000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_0_SIZE 0x40000000 /* 1 GB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_0 + +/* Init Stack Pointer */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x200000) + +#define CONFIG_SYS_LOAD_ADDR 0x80000000 /* SDRAM */ + +/* + * memtest works on DRAM + */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_0 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) + +/* When we use RAM as ENV */ +#define CONFIG_ENV_SIZE 0x2000 + +#endif /* __CONFIG_H */
Hi Padmarao,
On Thu, Apr 18, 2019 at 2:21 AM Padmarao Begari padmarao.begari@microchip.com wrote:
nits: Board->board. Please fix the commit message too.
I assume MPFS stands for Microchip PolarFire-SoC? And the board is called Icicle? If yes, shouldn't this be TARGET_MICROCHIP_ICICLE?
nits: TARGET_MICROCHIP_xxx should come before TARGET_SIFIVE_
endchoice
nits: please put it in the alphabetical order
For naming convention, please use mpfs_icicle (_ instead of -)
+config SYS_BOARD
+config SYS_VENDOR
default "microchip"
+config SYS_CPU
default "generic"
nits: use _ instead of -
def_bool y
imply SMP
- Copyright (C) 2019 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
Can this be optionally turned off? If not, please select it in BOARD_SPECIFIC_OPTIONS, and remove the #ifdef here.
unsigned int val;
nits: should have a blank line here
- CPU and Board Configuration Options
- Miscellaneous configurable options
- Print Buffer Size
- max number of command args
- Boot Argument Buffer Size
- Size of malloc() pool
- 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough
- Physical Memory Map
- memtest works on DRAM
Regards, Bin
Hi Bin,
On Tue, Apr 23, 2019 at 6:42 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Padmarao,
Ok
yes, I will use TARGET_MICROCHIP_ICICLE
Ok
endchoice
Ok
Ok
+config SYS_BOARD
+config SYS_VENDOR
default "microchip"
+config SYS_CPU
default "generic"
Ok
def_bool y
imply SMP
Ok
unsigned int val;
Ok
Thanks for review. Padmarao
- Print Buffer Size
0x200000)
PHYS_SDRAM_0_SIZE)
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Bin Meng
Padmarao Begari
Padmarao Begari
