[PATCH v3 0/2] SPL EBBR - EFI System Partition support
This series adds support to locate an EFI System Partition on a disk and boot the next stage from such a parition if found. The next stage image is expected to be under the FIRMWARE directory as described in the EBBR specification [1]. Also update the spl_blk_fs and spl_fat drivers to prefer booting from ESP and fall back to the configured parition in case of a failure.
Changes in v3: - Revert fallback change from v2 - Fix part_get_esp signature and header in part.h - Add RB tag
Changes in v2: - Rebase on latest next branch - Enable SPL_ESP_BOOT by default - For NVMe boot, remove fallback in case of ESP boot failure
Mayuresh Chitale (2): part: Add a function to find ESP partition spl: Add support for booting from ESP
common/spl/Kconfig | 8 ++++++ common/spl/spl_blk_fs.c | 60 ++++++++++++++++++++++++++++++----------- common/spl/spl_fat.c | 34 ++++++++++++++++++++--- disk/part.c | 16 +++++++++++ include/part.h | 13 +++++++++ 5 files changed, 111 insertions(+), 20 deletions(-)
If a disk has an EFI system partition (ESP) then it can be used to locate the boot files. Add a function to find the ESP.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- Changes in v3: - Fix part_get_esp signature and header in part.h
disk/part.c | 16 ++++++++++++++++ include/part.h | 13 +++++++++++++ 2 files changed, 29 insertions(+)
diff --git a/disk/part.c b/disk/part.c index 36b88205eca..6b1fbc18637 100644 --- a/disk/part.c +++ b/disk/part.c @@ -848,3 +848,19 @@ int part_get_bootable(struct blk_desc *desc)
return 0; } + +int part_get_esp(struct blk_desc *desc) +{ + struct disk_partition info; + int p; + + for (p = 1; p <= MAX_SEARCH_PARTITIONS; p++) { + int ret; + + ret = part_get_info(desc, p, &info); + if (!ret && (info.bootable & PART_EFI_SYSTEM_PARTITION)) + return p; + } + + return 0; +} diff --git a/include/part.h b/include/part.h index db34bc6bb7d..1aa6fe44ffb 100644 --- a/include/part.h +++ b/include/part.h @@ -690,6 +690,14 @@ int part_get_type_by_name(const char *name); */ int part_get_bootable(struct blk_desc *desc);
+/** + * part_get_esp() - Find the EFI system partition + * + * @desc: Block-device descriptor + * Return: the EFI system partition, or 0 if there is none + */ +int part_get_esp(struct blk_desc *desc); + #else static inline int part_driver_get_count(void) { return 0; } @@ -700,6 +708,11 @@ static inline struct part_driver *part_driver_get_first(void) static inline bool part_get_bootable(struct blk_desc *desc) { return false; }
+static inline int part_get_esp(struct blk_desc *desc) +{ + return 0; +} + #endif /* CONFIG_PARTITIONS */
#endif /* _PART_H */
Some platforms as described by EBBR specification may store images in the FIRMWARE directory of the UEFI system partition(ESP). Add support to boot from the EFI system partition if it is enabled for a platform.
Signed-off-by: Mayuresh Chitale mchitale@ventanamicro.com Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- Changes in v3: - Revert fallback change from v2 - Add RB tag
common/spl/Kconfig | 8 ++++++ common/spl/spl_blk_fs.c | 60 ++++++++++++++++++++++++++++++----------- common/spl/spl_fat.c | 34 ++++++++++++++++++++--- 3 files changed, 82 insertions(+), 20 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index cf7ffc9b112..48e4e43196a 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1292,6 +1292,14 @@ config SPL_SATA_RAW_U_BOOT_SECTOR Sector on the SATA disk to load U-Boot from, when the SATA disk is being used in raw mode. Units: SATA disk sectors (1 sector = 512 bytes).
+config SPL_ESP_BOOT + bool "Load next stage boot image from the UEFI system partition" + default y if BOOT_DEFAULTS + select SPL_PARTITION_TYPE_GUID + help + When enabled, first try to boot from the UEFI system partition as + described in the Ch.4 of the EBBR specification. + config SPL_NVME bool "NVM Express device support" depends on BLK diff --git a/common/spl/spl_blk_fs.c b/common/spl/spl_blk_fs.c index 04eac6f306b..ff48285653c 100644 --- a/common/spl/spl_blk_fs.c +++ b/common/spl/spl_blk_fs.c @@ -10,12 +10,15 @@ #include <spl_load.h> #include <image.h> #include <fs.h> +#include <part.h> #include <asm/cache.h> #include <asm/io.h>
struct blk_dev { const char *ifname; const char *filename; + int devnum; + int partnum; char dev_part_str[8]; };
@@ -44,16 +47,37 @@ static ulong spl_fit_read(struct spl_load_info *load, ulong file_offset, return actlen; }
+static int spl_blk_file_size(struct blk_dev *dev, loff_t *filesize) +{ + int ret; + + snprintf(dev->dev_part_str, sizeof(dev->dev_part_str) - 1, "%x:%x", + dev->devnum, dev->partnum); + debug("Loading file %s from %s %s\n", dev->filename, dev->ifname, + dev->dev_part_str); + ret = fs_set_blk_dev(dev->ifname, dev->dev_part_str, FS_TYPE_ANY); + if (ret) { + printf("spl: unable to set blk_dev %s %s. Err - %d\n", + dev->ifname, dev->dev_part_str, ret); + return ret; + } + + ret = fs_size(dev->filename, filesize); + if (ret) + printf("spl: unable to get size, file: %s. Err - %d\n", + dev->filename, ret); + return ret; +} + int spl_blk_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev, enum uclass_id uclass_id, int devnum, int partnum) { - const char *filename = CONFIG_SPL_FS_LOAD_PAYLOAD_NAME; struct blk_desc *blk_desc; loff_t filesize; struct blk_dev dev; struct spl_load_info load; - int ret; + int ret, part;
blk_desc = blk_get_devnum_by_uclass_id(uclass_id, devnum); if (!blk_desc) { @@ -63,24 +87,28 @@ int spl_blk_load_image(struct spl_image_info *spl_image,
blk_show_device(uclass_id, devnum);
- dev.filename = filename; + dev.filename = CONFIG_SPL_FS_LOAD_PAYLOAD_NAME; dev.ifname = blk_get_uclass_name(uclass_id); - snprintf(dev.dev_part_str, sizeof(dev.dev_part_str) - 1, "%x:%x", - devnum, partnum); - ret = fs_set_blk_dev(dev.ifname, dev.dev_part_str, FS_TYPE_ANY); - if (ret) { - printf("spl: unable to set blk_dev %s %s. Err - %d\n", - dev.ifname, dev.dev_part_str, ret); - return ret; + dev.devnum = devnum; + /* + * First try to boot from EFI System partition. In case of failure, + * fall back to the configured partition. + */ + if (IS_ENABLED(CONFIG_SPL_ESP_BOOT)) { + part = part_get_esp(blk_desc); + if (part) { + dev.partnum = part; + ret = spl_blk_file_size(&dev, &filesize); + if (!ret) + goto out; + } }
- ret = fs_size(filename, &filesize); - if (ret) { - printf("spl: unable to get file size: %s. Err - %d\n", - filename, ret); + dev.partnum = partnum; + ret = spl_blk_file_size(&dev, &filesize); + if (ret) return ret; - } - +out: load.read = spl_fit_read; if (IS_ENABLED(CONFIG_SPL_FS_FAT_DMA_ALIGN)) spl_set_bl_len(&load, ARCH_DMA_MINALIGN); diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index a52f9e178e6..8c426a3f3e7 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -60,10 +60,10 @@ static ulong spl_fit_read(struct spl_load_info *load, ulong file_offset, return actread; }
-int spl_load_image_fat(struct spl_image_info *spl_image, - struct spl_boot_device *bootdev, - struct blk_desc *block_dev, int partition, - const char *filename) +int spl_load_image_fat_one(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, + struct blk_desc *block_dev, int partition, + const char *filename) { int err; loff_t size; @@ -103,6 +103,32 @@ end: return err; }
+int spl_load_image_fat(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, + struct blk_desc *block_dev, int partition, + const char *filename) +{ + int err, part; + + /* + * First try to boot from EFI System partition. In case of failure, + * fall back to the configured partition. + */ + if (IS_ENABLED(CONFIG_SPL_ESP_BOOT)) { + part = part_get_esp(block_dev); + if (part) { + err = spl_load_image_fat_one(spl_image, bootdev, + block_dev, part, + filename); + if (!err) + return err; + } + } + + return spl_load_image_fat_one(spl_image, bootdev, block_dev, + partition, filename); +} + #if CONFIG_IS_ENABLED(OS_BOOT) int spl_load_image_fat_os(struct spl_image_info *spl_image, struct spl_boot_device *bootdev,
[snip]
- bool "Load next stage boot image from the UEFI system partition"
- default y if BOOT_DEFAULTS
- select SPL_PARTITION_TYPE_GUID
- help
This introduces: WARNING: unmet direct dependencies detected for SPL_PARTITION_TYPE_GUID Depends on [n]: SPL_EFI_PARTITION [=n] Selected by [y]: - SPL_ESP_BOOT [=y] && SPL [=y]
On for example coreboot64.
Mayuresh Chitale
