Re: [U-Boot] [PATCH 2/2] ARM: board: meson: add p200 and p201 boards
Hi Mohammad,
This look very good,
can you split the into 2 patches ? 1 for the p200 defconfig and a separate one for p201 ?
Thanks, Neil
On 14/03/2019 14:54, Mohammad Rasim wrote:
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com
board/amlogic/odroid-c2/README.p200 | 103 ++++++++++++++++++++++++++++ board/amlogic/p201/MAINTAINERS | 6 ++ board/amlogic/p201/Makefile | 5 ++ board/amlogic/p201/README.p201 | 103 ++++++++++++++++++++++++++++ board/amlogic/p201/p201.c | 43 ++++++++++++ configs/p200_defconfig | 41 +++++++++++ configs/p201_defconfig | 41 +++++++++++ 7 files changed, 342 insertions(+) create mode 100644 board/amlogic/odroid-c2/README.p200 create mode 100644 board/amlogic/p201/MAINTAINERS create mode 100644 board/amlogic/p201/Makefile create mode 100644 board/amlogic/p201/README.p201 create mode 100644 board/amlogic/p201/p201.c create mode 100644 configs/p200_defconfig create mode 100644 configs/p201_defconfig
diff --git a/board/amlogic/odroid-c2/README.p200 b/board/amlogic/odroid-c2/README.p200 new file mode 100644 index 0000000000..01d82d1e79 --- /dev/null +++ b/board/amlogic/odroid-c2/README.p200 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P200 +=======================
+P200 is a reference board manufactured by Amlogic with the following +specifications:
- Amlogic S905 ARM Cortex-A53 quad-core SoC @ 1.5GHz
- ARM Mali 450 GPU
- 2GB DDR3 SDRAM
- Gigabit Ethernet
- HDMI 2.0 4K/60Hz display
- 2 x USB 2.0 Host
- eMMC, microSD
- Infrared receiver
- SDIO WiFi Module
- CVBS+Stereo Audio Jack
+Schematics are available from Amlogic on demand.
+Currently the u-boot port supports the following devices:
- serial
- eMMC, microSD
- Ethernet
- I2C
- Regulators
- Reset controller
- Clock controller
- USB Host
- ADC
+u-boot compilation +==================
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p200_defconfig make+Image creation +==============
+Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor:
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot cd amlogic-u-boot make gxb_p200_v1_defconfig make export FIPDIR=$PWD/fip+Go back to mainline U-boot source tree then :
mkdir fip cp $FIPDIR/gxl/bl2.bin fip/ cp $FIPDIR/gxl/acs.bin fip/ cp $FIPDIR/gxl/bl21.bin fip/ cp $FIPDIR/gxl/bl30.bin fip/ cp $FIPDIR/gxl/bl301.bin fip/ cp $FIPDIR/gxl/bl31.img fip/ cp u-boot.bin fip/bl33.bin $FIPDIR/blx_fix.sh \- fip/bl30.bin \
- fip/zero_tmp \
- fip/bl30_zero.bin \
- fip/bl301.bin \
- fip/bl301_zero.bin \
- fip/bl30_new.bin \
- bl30
$FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 $FIPDIR/blx_fix.sh \- fip/bl2_acs.bin \
- fip/zero_tmp \
- fip/bl2_zero.bin \
- fip/bl21.bin \
- fip/bl21_zero.bin \
- fip/bl2_new.bin \
- bl2
$FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig $FIPDIR/gxl/aml_encrypt_gxl --bootmk \--output fip/u-boot.bin \
--bl2 fip/bl2.n.bin.sig \
--bl30 fip/bl30_new.bin.enc \
--bl31 fip/bl31.img.enc \
--bl33 fip/bl33.bin.enc
+and then write the image to SD with:
DEV=/dev/your_sd_device dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444diff --git a/board/amlogic/p201/MAINTAINERS b/board/amlogic/p201/MAINTAINERS new file mode 100644 index 0000000000..6ebb5f6396 --- /dev/null +++ b/board/amlogic/p201/MAINTAINERS @@ -0,0 +1,6 @@ +P201 +M: Beniamino Galvani b.galvani@gmail.com +M: Neil Armstrong narmstrong@baylibre.com +S: Maintained +F: board/amlogic/p201/ +F: configs/p201_defconfig diff --git a/board/amlogic/p201/Makefile b/board/amlogic/p201/Makefile new file mode 100644 index 0000000000..11de5396ab --- /dev/null +++ b/board/amlogic/p201/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com
+obj-y := p201.o diff --git a/board/amlogic/p201/README.p201 b/board/amlogic/p201/README.p201 new file mode 100644 index 0000000000..c251096ce1 --- /dev/null +++ b/board/amlogic/p201/README.p201 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P201 +=======================
+P201 is a reference board manufactured by Amlogic with the following +specifications:
- ARM Mali 450 GPU
- 2GB DDR3 SDRAM
- 10/100 Ethernet
- 2 x USB 2.0 Host
- eMMC, microSD
- Infrared receiver
- SDIO WiFi Module
- serial
- eMMC, microSD
- Ethernet
- I2C
- Regulators
- Reset controller
- Clock controller
- USB Host
- ADC
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p201_defconfig make+Image creation +==============
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot cd amlogic-u-boot make gxb_p201_v1_defconfig make export FIPDIR=$PWD/fip+Go back to mainline U-boot source tree then :
- fip/zero_tmp \
- fip/bl301.bin \
- bl30
- fip/zero_tmp \
- fip/bl21.bin \
- fip/bl2_new.bin \
- bl2
DEV=/dev/your_sd_device dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444diff --git a/board/amlogic/p201/p201.c b/board/amlogic/p201/p201.c new file mode 100644 index 0000000000..ef0c65cd9f --- /dev/null +++ b/board/amlogic/p201/p201.c @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com
+#include <common.h> +#include <dm.h> +#include <environment.h> +#include <asm/io.h> +#include <asm/arch/gx.h> +#include <asm/arch/sm.h> +#include <asm/arch/eth.h> +#include <asm/arch/mem.h>
+#define EFUSE_SN_OFFSET 20 +#define EFUSE_SN_SIZE 16 +#define EFUSE_MAC_OFFSET 52 +#define EFUSE_MAC_SIZE 6
+int misc_init_r(void) +{
- u8 mac_addr[EFUSE_MAC_SIZE];
- char serial[EFUSE_SN_SIZE];
- ssize_t len;
- meson_eth_init(PHY_INTERFACE_MODE_RMII, 0);
- if (!eth_env_get_enetaddr("ethaddr", mac_addr)) {
len = meson_sm_read_efuse(EFUSE_MAC_OFFSET,
mac_addr, EFUSE_MAC_SIZE);
if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr))
eth_env_set_enetaddr("ethaddr", mac_addr);
- if (!env_get("serial#")) {
len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial,
EFUSE_SN_SIZE);
if (len == EFUSE_SN_SIZE)
env_set("serial#", serial);
+} diff --git a/configs/p200_defconfig b/configs/p200_defconfig new file mode 100644 index 0000000000..4011866140 --- /dev/null +++ b/configs/p200_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p200" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="odroid-c2" diff --git a/configs/p201_defconfig b/configs/p201_defconfig new file mode 100644 index 0000000000..f6a821cf32 --- /dev/null +++ b/configs/p201_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p201" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p201" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y
+CONFIG_SYS_BOARD="p201"
2.21.0
Neil Armstrong
