[U-Boot] [PATCH] sunxi: Use the available Kconfig option for AHCI
Use the already available Kconfig option for AHCI. Tested on the BananaPi.
Signed-off-by: Jelle van der Waa jelle@vdwaa.nl --- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubieboard_defconfig | 3 ++- configs/Cubietruck_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Marsboard_A10_defconfig | 3 ++- configs/Mele_A1000_defconfig | 3 ++- configs/Mele_M5_defconfig | 3 ++- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- 20 files changed, 40 insertions(+), 20 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 04b720d..bb7eaf8 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -8,7 +8,8 @@ CONFIG_SYS_CLK_FREQ=912000000 CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 4751fe0..d48e35d 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -8,7 +8,8 @@ CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 024dc2d..7c5d84d 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -6,7 +6,8 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 5809345..9eb5f1b 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -9,7 +9,8 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 7a14a7b..a6bf45f 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -11,7 +11,8 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 366ef24..3da1cf7 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -7,7 +7,8 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 9b39124..2b9c865 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -9,7 +9,8 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index ad6eb62..9212a17 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -6,7 +6,8 @@ CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 9b4f483..6e7e741 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -6,7 +6,8 @@ CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 927ccd4..37b60b85 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -11,7 +11,8 @@ CONFIG_VIDEO_VGA=y CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 1a8fad7..d544d50 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -6,7 +6,8 @@ CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index c2fc2b3..58bc5a2 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -7,7 +7,8 @@ CONFIG_MMC0_CD_PIN="PH10" CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUNXI_GPB(3)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index a916e5d..8cbe9c3 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -8,7 +8,8 @@ CONFIG_USB1_VBUS_PIN="PH11" CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 8eea214..5d155b4 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -6,7 +6,8 @@ CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index b1d6b23..6a88238 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -3,7 +3,8 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index eae5ead..d678ffb 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -6,7 +6,8 @@ CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 124dc22..fffc332 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -8,7 +8,8 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,STATUSLED=234" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index c3eaae2..052ca83 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -10,7 +10,8 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 2903d83..63db70d 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -12,7 +12,8 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index d83cee7..d847fc7 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -11,7 +11,8 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" +CONFIG_AHCI=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Patch LGTM:
Reviewed-by: Hans de Goede hdegoede@redhat.com
Regards,
Hans
Hans de Goede
Jelle van der Waa
