[PATCH 00/16] stm32mp: add STM32MP13x support
Add the minimal support of the new STM32MP13x in mach-stm32mp to allow boot from SD Card.
STM32MP13x is a single Cortex-A7 MPU aimed at various applications. The discovery board is supported with stm32mp13_defconfig and the device tree stm32mp135f-dk.dts.
The supported boot sequence is: - TF-A BL2 - OP-TEE - U-Boot - Linux Kernel
The console over UART and boot from SD Card is functional with this serie.
The RCC driver, with support of reset and clock, is not yet provided today and the SCMI is not yet activated in device tree as in Linux kernel.
Patrick Delaunay (16): ARM: dts: stm32: add STM32MP13 SoCs support configs: stm32mp1: move SUPPORT_SPL in STM32MP15x arm: stm32mp: move the get_otp helper function in bsec arm: stm32mp: move code for STM32MP15x arm: stm32mp: add choice for STM32MP SOC family arm: stm32mp: add sub config Kconfig.15x arm: stm32mp: add CONFIG_STM32MP15_PWR arm: stm32mp: add support of STM32MP13x arm: stm32mp: support 2 MAC address for STM32MP13 pinctrl: stm32: add support of STM32MP135 board: stm32pm1: add stm32mp13 board support ram: stm32mp1: add support of STM32MP13x mmc: stm32_sdmmc2: make reset property optional arm: dts: stm32mp: add stm32mp13 device tree for U-Boot configs: add stm32mp13 defconfig doc: st: stm32mp1: add STM32MP13x support
arch/arm/Kconfig | 1 - arch/arm/dts/Makefile | 3 + arch/arm/dts/stm32mp13-pinctrl.dtsi | 123 ++++++ arch/arm/dts/stm32mp13-u-boot.dtsi | 91 ++++ arch/arm/dts/stm32mp131.dtsi | 358 ++++++++++++++++ arch/arm/dts/stm32mp133.dtsi | 37 ++ arch/arm/dts/stm32mp135.dtsi | 12 + arch/arm/dts/stm32mp135f-dk-u-boot.dtsi | 30 ++ arch/arm/dts/stm32mp135f-dk.dts | 57 +++ arch/arm/dts/stm32mp13xc.dtsi | 17 + arch/arm/dts/stm32mp13xf.dtsi | 17 + arch/arm/mach-stm32mp/Kconfig | 146 ++----- arch/arm/mach-stm32mp/Kconfig.13x | 57 +++ arch/arm/mach-stm32mp/Kconfig.15x | 135 ++++++ arch/arm/mach-stm32mp/Makefile | 5 +- arch/arm/mach-stm32mp/bsec.c | 17 + arch/arm/mach-stm32mp/cpu.c | 392 ++---------------- arch/arm/mach-stm32mp/fdt.c | 11 +- arch/arm/mach-stm32mp/include/mach/stm32.h | 26 ++ .../arm/mach-stm32mp/include/mach/sys_proto.h | 34 +- arch/arm/mach-stm32mp/spl.c | 1 + arch/arm/mach-stm32mp/stm32mp13x.c | 135 ++++++ arch/arm/mach-stm32mp/stm32mp15x.c | 350 ++++++++++++++++ board/st/stm32mp1/Kconfig | 15 + board/st/stm32mp1/MAINTAINERS | 4 + board/st/stm32mp1/stm32mp1.c | 27 +- configs/stm32mp13_defconfig | 54 +++ configs/stm32mp15_basic_defconfig | 6 +- configs/stm32mp15_defconfig | 6 +- configs/stm32mp15_trusted_defconfig | 8 +- doc/board/st/stm32mp1.rst | 181 +++++--- .../memory-controllers/st,stm32mp1-ddr.txt | 49 ++- drivers/mmc/stm32_sdmmc2.c | 14 +- drivers/pinctrl/pinctrl_stm32.c | 1 + drivers/ram/stm32mp1/stm32mp1_ram.c | 28 +- include/configs/stm32mp13_common.h | 106 +++++ include/configs/stm32mp13_st_common.h | 17 + include/configs/stm32mp15_common.h | 4 +- 38 files changed, 1992 insertions(+), 583 deletions(-) create mode 100644 arch/arm/dts/stm32mp13-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp13-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp131.dtsi create mode 100644 arch/arm/dts/stm32mp133.dtsi create mode 100644 arch/arm/dts/stm32mp135.dtsi create mode 100644 arch/arm/dts/stm32mp135f-dk-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp135f-dk.dts create mode 100644 arch/arm/dts/stm32mp13xc.dtsi create mode 100644 arch/arm/dts/stm32mp13xf.dtsi create mode 100644 arch/arm/mach-stm32mp/Kconfig.13x create mode 100644 arch/arm/mach-stm32mp/Kconfig.15x create mode 100644 arch/arm/mach-stm32mp/stm32mp13x.c create mode 100644 arch/arm/mach-stm32mp/stm32mp15x.c create mode 100644 configs/stm32mp13_defconfig create mode 100644 include/configs/stm32mp13_common.h create mode 100644 include/configs/stm32mp13_st_common.h
Add initial support of STM32MP13 family based on v5.18-rc2
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/dts/stm32mp13-pinctrl.dtsi | 123 ++++++++++ arch/arm/dts/stm32mp131.dtsi | 358 ++++++++++++++++++++++++++++ arch/arm/dts/stm32mp133.dtsi | 37 +++ arch/arm/dts/stm32mp135.dtsi | 12 + arch/arm/dts/stm32mp135f-dk.dts | 57 +++++ arch/arm/dts/stm32mp13xc.dtsi | 17 ++ arch/arm/dts/stm32mp13xf.dtsi | 17 ++ board/st/stm32mp1/MAINTAINERS | 1 + 8 files changed, 622 insertions(+) create mode 100644 arch/arm/dts/stm32mp13-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp131.dtsi create mode 100644 arch/arm/dts/stm32mp133.dtsi create mode 100644 arch/arm/dts/stm32mp135.dtsi create mode 100644 arch/arm/dts/stm32mp135f-dk.dts create mode 100644 arch/arm/dts/stm32mp13xc.dtsi create mode 100644 arch/arm/dts/stm32mp13xf.dtsi
diff --git a/arch/arm/dts/stm32mp13-pinctrl.dtsi b/arch/arm/dts/stm32mp13-pinctrl.dtsi new file mode 100644 index 0000000000..d2472cd8f1 --- /dev/null +++ b/arch/arm/dts/stm32mp13-pinctrl.dtsi @@ -0,0 +1,123 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com + */ +#include <dt-bindings/pinctrl/stm32-pinfunc.h> + +&pinctrl { + sdmmc1_b4_pins_a: sdmmc1-b4-0 { + pins { + pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ + <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + }; + + sdmmc1_b4_od_pins_a: sdmmc1-b4-od-0 { + pins1 { + pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, AF12)>; /* SDMMC1_D3 */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ + slew-rate = <1>; + drive-open-drain; + bias-disable; + }; + }; + + sdmmc1_b4_sleep_pins_a: sdmmc1-b4-sleep-0 { + pins { + pinmux = <STM32_PINMUX('C', 8, ANALOG)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, ANALOG)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, ANALOG)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, ANALOG)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, ANALOG)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 2, ANALOG)>; /* SDMMC1_CMD */ + }; + }; + + sdmmc1_clk_pins_a: sdmmc1-clk-0 { + pins { + pinmux = <STM32_PINMUX('C', 12, AF12)>; /* SDMMC1_CK */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + }; + + sdmmc2_b4_pins_a: sdmmc2-b4-0 { + pins { + pinmux = <STM32_PINMUX('B', 14, AF10)>, /* SDMMC2_D0 */ + <STM32_PINMUX('B', 15, AF10)>, /* SDMMC2_D1 */ + <STM32_PINMUX('B', 3, AF10)>, /* SDMMC2_D2 */ + <STM32_PINMUX('B', 4, AF10)>, /* SDMMC2_D3 */ + <STM32_PINMUX('G', 6, AF10)>; /* SDMMC2_CMD */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + }; + + sdmmc2_b4_od_pins_a: sdmmc2-b4-od-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 14, AF10)>, /* SDMMC2_D0 */ + <STM32_PINMUX('B', 15, AF10)>, /* SDMMC2_D1 */ + <STM32_PINMUX('B', 3, AF10)>, /* SDMMC2_D2 */ + <STM32_PINMUX('B', 4, AF10)>; /* SDMMC2_D3 */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + pins2 { + pinmux = <STM32_PINMUX('G', 6, AF10)>; /* SDMMC2_CMD */ + slew-rate = <1>; + drive-open-drain; + bias-pull-up; + }; + }; + + sdmmc2_b4_sleep_pins_a: sdmmc2-b4-sleep-0 { + pins { + pinmux = <STM32_PINMUX('B', 14, ANALOG)>, /* SDMMC2_D0 */ + <STM32_PINMUX('B', 15, ANALOG)>, /* SDMMC2_D1 */ + <STM32_PINMUX('B', 3, ANALOG)>, /* SDMMC2_D2 */ + <STM32_PINMUX('B', 4, ANALOG)>, /* SDMMC2_D3 */ + <STM32_PINMUX('E', 3, ANALOG)>, /* SDMMC2_CK */ + <STM32_PINMUX('G', 6, ANALOG)>; /* SDMMC2_CMD */ + }; + }; + + sdmmc2_clk_pins_a: sdmmc2-clk-0 { + pins { + pinmux = <STM32_PINMUX('E', 3, AF10)>; /* SDMMC2_CK */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + }; + + uart4_pins_a: uart4-0 { + pins1 { + pinmux = <STM32_PINMUX('D', 6, AF8)>; /* UART4_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 8, AF8)>; /* UART4_RX */ + bias-disable; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp131.dtsi b/arch/arm/dts/stm32mp131.dtsi new file mode 100644 index 0000000000..950e172e45 --- /dev/null +++ b/arch/arm/dts/stm32mp131.dtsi @@ -0,0 +1,358 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>; + interrupt-parent = <&intc>; + }; + + clocks { + clk_axi: clk-axi { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <266500000>; + }; + + clk_hse: clk-hse { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + }; + + clk_hsi: clk-hsi { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <64000000>; + }; + + clk_lsi: clk-lsi { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32000>; + }; + + clk_pclk3: clk-pclk3 { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <104438965>; + }; + + clk_pclk4: clk-pclk4 { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <133250000>; + }; + + clk_pll4_p: clk-pll4_p { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + + clk_pll4_r: clk-pll4_r { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <99000000>; + }; + }; + + intc: interrupt-controller@a0021000 { + compatible = "arm,cortex-a7-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xa0021000 0x1000>, + <0xa0022000 0x2000>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; + interrupt-parent = <&intc>; + always-on; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + ranges; + + uart4: serial@40010000 { + compatible = "st,stm32h7-uart"; + reg = <0x40010000 0x400>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_hsi>; + status = "disabled"; + }; + + dma1: dma-controller@48000000 { + compatible = "st,stm32-dma"; + reg = <0x48000000 0x400>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_pclk4>; + #dma-cells = <4>; + st,mem2mem; + dma-requests = <8>; + }; + + dma2: dma-controller@48001000 { + compatible = "st,stm32-dma"; + reg = <0x48001000 0x400>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_pclk4>; + #dma-cells = <4>; + st,mem2mem; + dma-requests = <8>; + }; + + dmamux1: dma-router@48002000 { + compatible = "st,stm32h7-dmamux"; + reg = <0x48002000 0x40>; + clocks = <&clk_pclk4>; + #dma-cells = <3>; + dma-masters = <&dma1 &dma2>; + dma-requests = <128>; + dma-channels = <16>; + }; + + exti: interrupt-controller@5000d000 { + compatible = "st,stm32mp13-exti", "syscon"; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x5000d000 0x400>; + }; + + syscfg: syscon@50020000 { + compatible = "st,stm32mp157-syscfg", "syscon"; + reg = <0x50020000 0x400>; + clocks = <&clk_pclk3>; + }; + + mdma: dma-controller@58000000 { + compatible = "st,stm32h7-mdma"; + reg = <0x58000000 0x1000>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_pclk4>; + #dma-cells = <5>; + dma-channels = <32>; + dma-requests = <48>; + }; + + sdmmc1: mmc@58005000 { + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x20253180>; + reg = <0x58005000 0x1000>, <0x58006000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cmd_irq"; + clocks = <&clk_pll4_p>; + clock-names = "apb_pclk"; + cap-sd-highspeed; + cap-mmc-highspeed; + max-frequency = <130000000>; + status = "disabled"; + }; + + sdmmc2: mmc@58007000 { + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x20253180>; + reg = <0x58007000 0x1000>, <0x58008000 0x1000>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cmd_irq"; + clocks = <&clk_pll4_p>; + clock-names = "apb_pclk"; + cap-sd-highspeed; + cap-mmc-highspeed; + max-frequency = <130000000>; + status = "disabled"; + }; + + iwdg2: watchdog@5a002000 { + compatible = "st,stm32mp1-iwdg"; + reg = <0x5a002000 0x400>; + clocks = <&clk_pclk4>, <&clk_lsi>; + clock-names = "pclk", "lsi"; + status = "disabled"; + }; + + bsec: efuse@5c005000 { + compatible = "st,stm32mp13-bsec"; + reg = <0x5c005000 0x400>; + #address-cells = <1>; + #size-cells = <1>; + + part_number_otp: part_number_otp@4 { + reg = <0x4 0x2>; + }; + ts_cal1: calib@5c { + reg = <0x5c 0x2>; + }; + ts_cal2: calib@5e { + reg = <0x5e 0x2>; + }; + }; + + /* + * Break node order to solve dependency probe issue between + * pinctrl and exti. + */ + pinctrl: pin-controller@50002000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,stm32mp135-pinctrl"; + ranges = <0 0x50002000 0x8400>; + pins-are-numbered; + + gpioa: gpio@50002000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x0 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOA"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@50003000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x1000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOB"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@50004000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x2000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOC"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@50005000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x3000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOD"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@50006000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x4000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOE"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@50007000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x5000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOF"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 80 16>; + }; + + gpiog: gpio@50008000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x6000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOG"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 96 16>; + }; + + gpioh: gpio@50009000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x7000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOH"; + ngpios = <15>; + gpio-ranges = <&pinctrl 0 112 15>; + }; + + gpioi: gpio@5000a000 { + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x8000 0x400>; + clocks = <&clk_pclk4>; + st,bank-name = "GPIOI"; + ngpios = <8>; + gpio-ranges = <&pinctrl 0 128 8>; + }; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp133.dtsi b/arch/arm/dts/stm32mp133.dtsi new file mode 100644 index 0000000000..0fb1386257 --- /dev/null +++ b/arch/arm/dts/stm32mp133.dtsi @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ + +#include "stm32mp131.dtsi" + +/ { + soc { + m_can1: can@4400e000 { + compatible = "bosch,m_can"; + reg = <0x4400e000 0x400>, <0x44011000 0x1400>; + reg-names = "m_can", "message_ram"; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "int0", "int1"; + clocks = <&clk_hse>, <&clk_pll4_r>; + clock-names = "hclk", "cclk"; + bosch,mram-cfg = <0x0 0 0 32 0 0 2 2>; + status = "disabled"; + }; + + m_can2: can@4400f000 { + compatible = "bosch,m_can"; + reg = <0x4400f000 0x400>, <0x44011000 0x2800>; + reg-names = "m_can", "message_ram"; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "int0", "int1"; + clocks = <&clk_hse>, <&clk_pll4_r>; + clock-names = "hclk", "cclk"; + bosch,mram-cfg = <0x1400 0 0 32 0 0 2 2>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp135.dtsi b/arch/arm/dts/stm32mp135.dtsi new file mode 100644 index 0000000000..abf2acd37b --- /dev/null +++ b/arch/arm/dts/stm32mp135.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ + +#include "stm32mp133.dtsi" + +/ { + soc { + }; +}; diff --git a/arch/arm/dts/stm32mp135f-dk.dts b/arch/arm/dts/stm32mp135f-dk.dts new file mode 100644 index 0000000000..ee100d108e --- /dev/null +++ b/arch/arm/dts/stm32mp135f-dk.dts @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ + +/dts-v1/; + +#include "stm32mp135.dtsi" +#include "stm32mp13xf.dtsi" +#include "stm32mp13-pinctrl.dtsi" + +/ { + model = "STMicroelectronics STM32MP135F-DK Discovery Board"; + compatible = "st,stm32mp135f-dk", "st,stm32mp135"; + + aliases { + serial0 = &uart4; + }; + + memory@c0000000 { + device_type = "memory"; + reg = <0xc0000000 0x20000000>; + }; + + vdd_sd: vdd-sd { + compatible = "regulator-fixed"; + regulator-name = "vdd_sd"; + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + regulator-always-on; + }; +}; + +&iwdg2 { + timeout-sec = <32>; + status = "okay"; +}; + +&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_clk_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_clk_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>; + broken-cd; + disable-wp; + st,neg-edge; + bus-width = <4>; + vmmc-supply = <&vdd_sd>; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins_a>; + status = "okay"; +}; diff --git a/arch/arm/dts/stm32mp13xc.dtsi b/arch/arm/dts/stm32mp13xc.dtsi new file mode 100644 index 0000000000..fa6889e305 --- /dev/null +++ b/arch/arm/dts/stm32mp13xc.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ + +/ { + soc { + cryp: crypto@54002000 { + compatible = "st,stm32mp1-cryp"; + reg = <0x54002000 0x400>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_axi>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp13xf.dtsi b/arch/arm/dts/stm32mp13xf.dtsi new file mode 100644 index 0000000000..fa6889e305 --- /dev/null +++ b/arch/arm/dts/stm32mp13xf.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics. + */ + +/ { + soc { + cryp: crypto@54002000 { + compatible = "st,stm32mp1-cryp"; + reg = <0x54002000 0x400>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk_axi>; + status = "disabled"; + }; + }; +}; diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index 6451195269..d57a49820e 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -3,6 +3,7 @@ M: Patrick Delaunay patrick.delaunay@foss.st.com L: uboot-stm32@st-md-mailman.stormreply.com (moderated for non-subscribers) T: git https://source.denx.de/u-boot/custodians/u-boot-stm.git S: Maintained +F: arch/arm/dts/stm32mp13* F: arch/arm/dts/stm32mp15* F: board/st/stm32mp1/ F: configs/stm32mp15_defconfig
Hi Patrick
- Copyright (C) STMicroelectronics 2021 - All Rights Reserved
- Author: Alexandre Torgue alexandre.torgue@foss.st.com
+&pinctrl {
- sdmmc1_b4_pins_a: sdmmc1-b4-0 {
pins {
slew-rate = <1>;
drive-push-pull;
bias-disable;
- sdmmc1_b4_od_pins_a: sdmmc1-b4-od-0 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins2 {
slew-rate = <1>;
drive-open-drain;
bias-disable;
- sdmmc1_b4_sleep_pins_a: sdmmc1-b4-sleep-0 {
pins {
- sdmmc1_clk_pins_a: sdmmc1-clk-0 {
pins {
slew-rate = <1>;
drive-push-pull;
bias-disable;
- sdmmc2_b4_pins_a: sdmmc2-b4-0 {
pins {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
- sdmmc2_b4_od_pins_a: sdmmc2-b4-od-0 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
pins2 {
slew-rate = <1>;
drive-open-drain;
bias-pull-up;
- sdmmc2_b4_sleep_pins_a: sdmmc2-b4-sleep-0 {
pins {
- sdmmc2_clk_pins_a: sdmmc2-clk-0 {
pins {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
- uart4_pins_a: uart4-0 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- Author: Alexandre Torgue alexandre.torgue@foss.st.com for STMicroelectronics.
- #address-cells = <1>;
- #size-cells = <1>;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
- arm-pmu {
- clocks {
clk_axi: clk-axi {
#clock-cells = <0>;
clk_hse: clk-hse {
#clock-cells = <0>;
clk_hsi: clk-hsi {
#clock-cells = <0>;
clk_lsi: clk-lsi {
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
- intc: interrupt-controller@a0021000 {
- psci {
method = "smc";
- timer {
always-on;
- soc {
#size-cells = <1>;
ranges;
#dma-cells = <4>;
st,mem2mem;
dma-requests = <8>;
#dma-cells = <4>;
st,mem2mem;
dma-requests = <8>;
#dma-cells = <3>;
#dma-cells = <5>;
cap-sd-highspeed;
cap-mmc-highspeed;
cap-sd-highspeed;
cap-mmc-highspeed;
#size-cells = <1>;
reg = <0x4 0x2>;
ts_cal1: calib@5c {
reg = <0x5c 0x2>;
ts_cal2: calib@5e {
reg = <0x5e 0x2>;
* pinctrl and exti.
#size-cells = <1>;
pins-are-numbered;
gpio-controller;
#gpio-cells = <2>;
reg = <0x0 0x400>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <16>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <15>;
gpio-controller;
#gpio-cells = <2>;
ngpios = <8>;
- soc {
- soc {
+/dts-v1/;
- model = "STMicroelectronics STM32MP135F-DK Discovery Board";
- compatible = "st,stm32mp135f-dk", "st,stm32mp135";
- aliases {
serial0 = &uart4;
- memory@c0000000 {
- vdd_sd: vdd-sd {
+&iwdg2 {
- timeout-sec = <32>;
- status = "okay";
+&sdmmc1 {
- pinctrl-names = "default", "opendrain", "sleep";
- pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_clk_pins_a>;
- pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_clk_pins_a>;
- pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>;
- broken-cd;
- disable-wp;
- st,neg-edge;
- bus-width = <4>;
- vmmc-supply = <&vdd_sd>;
- status = "okay";
+&uart4 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart4_pins_a>;
- status = "okay";
- soc {
- soc {
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Applied to u-boot-stm/next, thanks!
Regards Patrick
The SPL is only supported by STM32MP15x not by all the SOC with STM32MP arch. Only TFABOOT is supported in next products.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/Kconfig | 1 - arch/arm/mach-stm32mp/Kconfig | 1 + 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 57946f61fa..82d6274c92 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1939,7 +1939,6 @@ config ARCH_STM32MP select OF_SYSTEM_SETUP select PINCTRL select REGMAP - select SUPPORT_SPL select SYSCON select SYSRESET select SYS_THUMB_BUILD diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index e48f98ba29..be0d74b4ac 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -46,6 +46,7 @@ config STM32MP15x select STM32_RCC select STM32_RESET select STM32_SERIAL + select SUPPORT_SPL select SYS_ARCH_TIMER imply CMD_NVEDIT_INFO help
Hi Patrick
- select SUPPORT_SPL select SYS_ARCH_TIMER imply CMD_NVEDIT_INFO help
Thanks Patrice
Regards Patrick
As the get_otp() helper function in bsec are common for all STM32MP family, move this function in bsec driver
arch/arm/mach-stm32mp/bsec.c | 17 +++++++++++++++++ arch/arm/mach-stm32mp/cpu.c | 17 ----------------- arch/arm/mach-stm32mp/include/mach/sys_proto.h | 3 +++ 3 files changed, 20 insertions(+), 17 deletions(-)
diff --git a/arch/arm/mach-stm32mp/bsec.c b/arch/arm/mach-stm32mp/bsec.c index 506caa0a31..c00130b08b 100644 --- a/arch/arm/mach-stm32mp/bsec.c +++ b/arch/arm/mach-stm32mp/bsec.c @@ -632,3 +632,20 @@ bool bsec_dbgswenable(void)
return false; } + +u32 get_otp(int index, int shift, int mask) +{ + int ret; + struct udevice *dev; + u32 otp = 0; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(stm32mp_bsec), + &dev); + + if (!ret) + ret = misc_read(dev, STM32_BSEC_SHADOW(index), + &otp, sizeof(otp)); + + return (otp >> shift) & mask; +} diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 0ad5f307db..6f44c75515 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -349,23 +349,6 @@ u32 get_cpu_rev(void) return (read_idc() & DBGMCU_IDC_REV_ID_MASK) >> DBGMCU_IDC_REV_ID_SHIFT; }
-static u32 get_otp(int index, int shift, int mask) -{ - int ret; - struct udevice *dev; - u32 otp = 0; - - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_DRIVER_GET(stm32mp_bsec), - &dev); - - if (!ret) - ret = misc_read(dev, STM32_BSEC_SHADOW(index), - &otp, sizeof(otp)); - - return (otp >> shift) & mask; -} - /* Get Device Part Number (RPN) from OTP */ static u32 get_cpu_rpn(void) { diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index b91f98eb45..dc98f0c5a4 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -52,3 +52,6 @@ int setup_mac_address(void);
/* board power management : configure vddcore according OPP */ void board_vddcore_init(u32 voltage_mv); + +/* helper function: read data from OTP */ +u32 get_otp(int index, int shift, int mask);
HI Patrick
return false; }
- int ret;
- u32 otp = 0;
&dev);
- if (!ret)
&otp, sizeof(otp));
- int ret;
- u32 otp = 0;
&dev);
- if (!ret)
&otp, sizeof(otp));
Thanks Patrice
Regards Patrick
Move code and defines only needed for CONFIG_STM32MP15x in stm32mp15x.c when low level init without TFABOOT is supported.
arch/arm/mach-stm32mp/Makefile | 2 + arch/arm/mach-stm32mp/cpu.c | 331 +---------------- arch/arm/mach-stm32mp/fdt.c | 8 +- .../arm/mach-stm32mp/include/mach/sys_proto.h | 14 +- arch/arm/mach-stm32mp/spl.c | 1 + arch/arm/mach-stm32mp/stm32mp15x.c | 345 ++++++++++++++++++ 6 files changed, 377 insertions(+), 324 deletions(-) create mode 100644 arch/arm/mach-stm32mp/stm32mp15x.c
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index 391b47cf13..d362104fee 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -8,6 +8,8 @@ obj-y += dram_init.o obj-y += syscon.o obj-y += bsec.o
+obj-$(CONFIG_STM32MP15x) += stm32mp15x.o + ifdef CONFIG_SPL_BUILD obj-y += spl.o obj-y += tzc400.o diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 6f44c75515..b808964d3e 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -16,7 +16,6 @@ #include <misc.h> #include <net.h> #include <asm/io.h> -#include <asm/arch/bsec.h> #include <asm/arch/stm32.h> #include <asm/arch/sys_proto.h> #include <asm/global_data.h> @@ -24,67 +23,6 @@ #include <dm/uclass.h> #include <linux/bitops.h>
-/* RCC register */ -#define RCC_TZCR (STM32_RCC_BASE + 0x00) -#define RCC_DBGCFGR (STM32_RCC_BASE + 0x080C) -#define RCC_BDCR (STM32_RCC_BASE + 0x0140) -#define RCC_MP_APB5ENSETR (STM32_RCC_BASE + 0x0208) -#define RCC_MP_AHB5ENSETR (STM32_RCC_BASE + 0x0210) -#define RCC_BDCR_VSWRST BIT(31) -#define RCC_BDCR_RTCSRC GENMASK(17, 16) -#define RCC_DBGCFGR_DBGCKEN BIT(8) - -/* Security register */ -#define ETZPC_TZMA1_SIZE (STM32_ETZPC_BASE + 0x04) -#define ETZPC_DECPROT0 (STM32_ETZPC_BASE + 0x10) - -#define TZC_GATE_KEEPER (STM32_TZC_BASE + 0x008) -#define TZC_REGION_ATTRIBUTE0 (STM32_TZC_BASE + 0x110) -#define TZC_REGION_ID_ACCESS0 (STM32_TZC_BASE + 0x114) - -#define TAMP_CR1 (STM32_TAMP_BASE + 0x00) - -#define PWR_CR1 (STM32_PWR_BASE + 0x00) -#define PWR_MCUCR (STM32_PWR_BASE + 0x14) -#define PWR_CR1_DBP BIT(8) -#define PWR_MCUCR_SBF BIT(6) - -/* DBGMCU register */ -#define DBGMCU_IDC (STM32_DBGMCU_BASE + 0x00) -#define DBGMCU_APB4FZ1 (STM32_DBGMCU_BASE + 0x2C) -#define DBGMCU_APB4FZ1_IWDG2 BIT(2) -#define DBGMCU_IDC_DEV_ID_MASK GENMASK(11, 0) -#define DBGMCU_IDC_DEV_ID_SHIFT 0 -#define DBGMCU_IDC_REV_ID_MASK GENMASK(31, 16) -#define DBGMCU_IDC_REV_ID_SHIFT 16 - -/* GPIOZ registers */ -#define GPIOZ_SECCFGR 0x54004030 - -/* boot interface from Bootrom - * - boot instance = bit 31:16 - * - boot device = bit 15:0 - */ -#define BOOTROM_PARAM_ADDR 0x2FFC0078 -#define BOOTROM_MODE_MASK GENMASK(15, 0) -#define BOOTROM_MODE_SHIFT 0 -#define BOOTROM_INSTANCE_MASK GENMASK(31, 16) -#define BOOTROM_INSTANCE_SHIFT 16 - -/* Device Part Number (RPN) = OTP_DATA1 lower 8 bits */ -#define RPN_SHIFT 0 -#define RPN_MASK GENMASK(7, 0) - -/* Package = bit 27:29 of OTP16 - * - 100: LBGA448 (FFI) => AA = LFBGA 18x18mm 448 balls p. 0.8mm - * - 011: LBGA354 (LCI) => AB = LFBGA 16x16mm 359 balls p. 0.8mm - * - 010: TFBGA361 (FFC) => AC = TFBGA 12x12mm 361 balls p. 0.5mm - * - 001: TFBGA257 (LCC) => AD = TFBGA 10x10mm 257 balls p. 0.5mm - * - others: Reserved - */ -#define PKG_SHIFT 27 -#define PKG_MASK GENMASK(2, 0) - /* * early TLB into the .data section so that it not get cleared * with 16kB allignment (see TTBR0_BASE_ADDR_MASK) @@ -93,121 +31,6 @@ u8 early_tlb[PGTABLE_SIZE] __section(".data") __aligned(0x4000);
struct lmb lmb;
-static void security_init(void) -{ - /* Disable the backup domain write protection */ - /* the protection is enable at each reset by hardware */ - /* And must be disable by software */ - setbits_le32(PWR_CR1, PWR_CR1_DBP); - - while (!(readl(PWR_CR1) & PWR_CR1_DBP)) - ; - - /* If RTC clock isn't enable so this is a cold boot then we need - * to reset the backup domain - */ - if (!(readl(RCC_BDCR) & RCC_BDCR_RTCSRC)) { - setbits_le32(RCC_BDCR, RCC_BDCR_VSWRST); - while (!(readl(RCC_BDCR) & RCC_BDCR_VSWRST)) - ; - clrbits_le32(RCC_BDCR, RCC_BDCR_VSWRST); - } - - /* allow non secure access in Write/Read for all peripheral */ - writel(GENMASK(25, 0), ETZPC_DECPROT0); - - /* Open SYSRAM for no secure access */ - writel(0x0, ETZPC_TZMA1_SIZE); - - /* enable TZC1 TZC2 clock */ - writel(BIT(11) | BIT(12), RCC_MP_APB5ENSETR); - - /* Region 0 set to no access by default */ - /* bit 0 / 16 => nsaid0 read/write Enable - * bit 1 / 17 => nsaid1 read/write Enable - * ... - * bit 15 / 31 => nsaid15 read/write Enable - */ - writel(0xFFFFFFFF, TZC_REGION_ID_ACCESS0); - /* bit 30 / 31 => Secure Global Enable : write/read */ - /* bit 0 / 1 => Region Enable for filter 0/1 */ - writel(BIT(0) | BIT(1) | BIT(30) | BIT(31), TZC_REGION_ATTRIBUTE0); - - /* Enable Filter 0 and 1 */ - setbits_le32(TZC_GATE_KEEPER, BIT(0) | BIT(1)); - - /* RCC trust zone deactivated */ - writel(0x0, RCC_TZCR); - - /* TAMP: deactivate the internal tamper - * Bit 23 ITAMP8E: monotonic counter overflow - * Bit 20 ITAMP5E: RTC calendar overflow - * Bit 19 ITAMP4E: HSE monitoring - * Bit 18 ITAMP3E: LSE monitoring - * Bit 16 ITAMP1E: RTC power domain supply monitoring - */ - writel(0x0, TAMP_CR1); - - /* GPIOZ: deactivate the security */ - writel(BIT(0), RCC_MP_AHB5ENSETR); - writel(0x0, GPIOZ_SECCFGR); -} - -/* - * Debug init - */ -static void dbgmcu_init(void) -{ - /* - * Freeze IWDG2 if Cortex-A7 is in debug mode - * done in TF-A for TRUSTED boot and - * DBGMCU access is controlled by BSEC_DENABLE.DBGSWENABLE - */ - if (bsec_dbgswenable()) { - setbits_le32(RCC_DBGCFGR, RCC_DBGCFGR_DBGCKEN); - setbits_le32(DBGMCU_APB4FZ1, DBGMCU_APB4FZ1_IWDG2); - } -} - -void spl_board_init(void) -{ - struct udevice *dev; - int ret; - - dbgmcu_init(); - - /* force probe of BSEC driver to shadow the upper OTP */ - ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(stm32mp_bsec), &dev); - if (ret) - log_warning("BSEC probe failed: %d\n", ret); -} - -/* get bootmode from ROM code boot context: saved in TAMP register */ -static void update_bootmode(void) -{ - u32 boot_mode; - u32 bootrom_itf = readl(BOOTROM_PARAM_ADDR); - u32 bootrom_device, bootrom_instance; - - /* enable TAMP clock = RTCAPBEN */ - writel(BIT(8), RCC_MP_APB5ENSETR); - - /* read bootrom context */ - bootrom_device = - (bootrom_itf & BOOTROM_MODE_MASK) >> BOOTROM_MODE_SHIFT; - bootrom_instance = - (bootrom_itf & BOOTROM_INSTANCE_MASK) >> BOOTROM_INSTANCE_SHIFT; - boot_mode = - ((bootrom_device << BOOT_TYPE_SHIFT) & BOOT_TYPE_MASK) | - ((bootrom_instance << BOOT_INSTANCE_SHIFT) & - BOOT_INSTANCE_MASK); - - /* save the boot mode in TAMP backup register */ - clrsetbits_le32(TAMP_BOOT_CONTEXT, - TAMP_BOOT_MODE_MASK, - boot_mode << TAMP_BOOT_MODE_SHIFT); -} - u32 get_bootmode(void) { /* read bootmode from TAMP backup register */ @@ -277,25 +100,24 @@ static void early_enable_caches(void) */ int arch_cpu_init(void) { - u32 boot_mode; - early_enable_caches();
/* early armv7 timer init: needed for polling */ timer_init();
- if (IS_ENABLED(CONFIG_SPL_BUILD)) { - security_init(); - update_bootmode(); - } -/* reset copro state in SPL, when used, or in U-Boot */ - if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_SPL_BUILD)) { - /* Reset Coprocessor state unless it wakes up from Standby power mode */ - if (!(readl(PWR_MCUCR) & PWR_MCUCR_SBF)) { - writel(TAMP_COPRO_STATE_OFF, TAMP_COPRO_STATE); - writel(0, TAMP_COPRO_RSC_TBL_ADDRESS); - } - } + return 0; +} + +/* weak function for SOC specific initialization */ +__weak void stm32mp_cpu_init(void) +{ +} + +int mach_cpu_init(void) +{ + u32 boot_mode; + + stm32mp_cpu_init();
boot_mode = get_bootmode();
@@ -324,122 +146,6 @@ void enable_caches(void) dcache_enable(); }
-static u32 read_idc(void) -{ - /* DBGMCU access is controlled by BSEC_DENABLE.DBGSWENABLE */ - if (bsec_dbgswenable()) { - setbits_le32(RCC_DBGCFGR, RCC_DBGCFGR_DBGCKEN); - - return readl(DBGMCU_IDC); - } - - if (CONFIG_IS_ENABLED(STM32MP15x)) - return CPU_DEV_STM32MP15; /* STM32MP15x and unknown revision */ - else - return 0x0; -} - -u32 get_cpu_dev(void) -{ - return (read_idc() & DBGMCU_IDC_DEV_ID_MASK) >> DBGMCU_IDC_DEV_ID_SHIFT; -} - -u32 get_cpu_rev(void) -{ - return (read_idc() & DBGMCU_IDC_REV_ID_MASK) >> DBGMCU_IDC_REV_ID_SHIFT; -} - -/* Get Device Part Number (RPN) from OTP */ -static u32 get_cpu_rpn(void) -{ - return get_otp(BSEC_OTP_RPN, RPN_SHIFT, RPN_MASK); -} - -u32 get_cpu_type(void) -{ - return (get_cpu_dev() << 16) | get_cpu_rpn(); -} - -/* Get Package options from OTP */ -u32 get_cpu_package(void) -{ - return get_otp(BSEC_OTP_PKG, PKG_SHIFT, PKG_MASK); -} - -static const char * const soc_type[] = { - "????", - "151C", "151A", "151F", "151D", - "153C", "153A", "153F", "153D", - "157C", "157A", "157F", "157D" -}; - -static const char * const soc_pkg[] = { "??", "AD", "AC", "AB", "AA" }; -static const char * const soc_rev[] = { "?", "A", "B", "Z" }; - -static void get_cpu_string_offsets(unsigned int *type, unsigned int *pkg, - unsigned int *rev) -{ - u32 cpu_type = get_cpu_type(); - u32 ct = cpu_type & ~(BIT(7) | BIT(0)); - u32 cm = ((cpu_type & BIT(7)) >> 6) | (cpu_type & BIT(0)); - u32 cp = get_cpu_package(); - - /* Bits 0 and 7 are the ACDF, 00:C 01:A 10:F 11:D */ - switch (ct) { - case CPU_STM32MP151Cxx: - *type = cm + 1; - break; - case CPU_STM32MP153Cxx: - *type = cm + 5; - break; - case CPU_STM32MP157Cxx: - *type = cm + 9; - break; - default: - *type = 0; - break; - } - - /* Package */ - switch (cp) { - case PKG_AA_LBGA448: - case PKG_AB_LBGA354: - case PKG_AC_TFBGA361: - case PKG_AD_TFBGA257: - *pkg = cp; - break; - default: - *pkg = 0; - break; - } - - /* Revision */ - switch (get_cpu_rev()) { - case CPU_REV1: - *rev = 1; - break; - case CPU_REV2: - *rev = 2; - break; - case CPU_REV2_1: - *rev = 3; - break; - default: - *rev = 0; - break; - } -} - -void get_soc_name(char name[SOC_NAME_SIZE]) -{ - unsigned int type, pkg, rev; - - get_cpu_string_offsets(&type, &pkg, &rev); - - snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", - soc_type[type], soc_pkg[pkg], soc_rev[rev]); -} - /* used when CONFIG_DISPLAY_CPUINFO is activated */ int print_cpuinfo(void) { @@ -645,15 +351,8 @@ static int setup_serial_number(void) return 0; }
-static void setup_soc_type_pkg_rev(void) +__weak void stm32mp_misc_init(void) { - unsigned int type, pkg, rev; - - get_cpu_string_offsets(&type, &pkg, &rev); - - env_set("soc_type", soc_type[type]); - env_set("soc_pkg", soc_pkg[pkg]); - env_set("soc_rev", soc_rev[rev]); }
int arch_misc_init(void) @@ -661,7 +360,7 @@ int arch_misc_init(void) setup_boot_mode(); setup_mac_address(); setup_serial_number(); - setup_soc_type_pkg_rev(); + stm32mp_misc_init();
return 0; } diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index 91330a68a4..969e7d94e9 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -309,16 +309,16 @@ int ft_system_setup(void *blob, struct bd_info *bd) }
switch (get_cpu_package()) { - case PKG_AA_LBGA448: + case STM32MP15_PKG_AA_LBGA448: pkg = STM32MP_PKG_AA; break; - case PKG_AB_LBGA354: + case STM32MP15_PKG_AB_LBGA354: pkg = STM32MP_PKG_AB; break; - case PKG_AC_TFBGA361: + case STM32MP15_PKG_AC_TFBGA361: pkg = STM32MP_PKG_AC; break; - case PKG_AD_TFBGA257: + case STM32MP15_PKG_AD_TFBGA257: pkg = STM32MP_PKG_AD; break; default: diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index dc98f0c5a4..8b61135aeb 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -36,10 +36,12 @@ u32 get_cpu_rev(void); /* Get Package options from OTP */ u32 get_cpu_package(void);
-#define PKG_AA_LBGA448 4 -#define PKG_AB_LBGA354 3 -#define PKG_AC_TFBGA361 2 -#define PKG_AD_TFBGA257 1 +/* package used for STM32MP15x */ +#define STM32MP15_PKG_AA_LBGA448 4 +#define STM32MP15_PKG_AB_LBGA354 3 +#define STM32MP15_PKG_AC_TFBGA361 2 +#define STM32MP15_PKG_AD_TFBGA257 1 +#define STM32MP15_PKG_UNKNOWN 0
/* Get SOC name */ #define SOC_NAME_SIZE 20 @@ -53,5 +55,9 @@ int setup_mac_address(void); /* board power management : configure vddcore according OPP */ void board_vddcore_init(u32 voltage_mv);
+/* weak function */ +void stm32mp_cpu_init(void); +void stm32mp_misc_init(void); + /* helper function: read data from OTP */ u32 get_otp(int index, int shift, int mask); diff --git a/arch/arm/mach-stm32mp/spl.c b/arch/arm/mach-stm32mp/spl.c index 78fa9d7edd..19d9fe04e0 100644 --- a/arch/arm/mach-stm32mp/spl.c +++ b/arch/arm/mach-stm32mp/spl.c @@ -190,6 +190,7 @@ void board_init_f(ulong dummy) int ret;
arch_cpu_init(); + mach_cpu_init();
ret = spl_early_init(); if (ret) { diff --git a/arch/arm/mach-stm32mp/stm32mp15x.c b/arch/arm/mach-stm32mp/stm32mp15x.c new file mode 100644 index 0000000000..800fad2f43 --- /dev/null +++ b/arch/arm/mach-stm32mp/stm32mp15x.c @@ -0,0 +1,345 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (C) 2021, STMicroelectronics - All Rights Reserved + */ + +#define LOG_CATEGORY LOGC_ARCH + +#include <common.h> +#include <env.h> +#include <log.h> +#include <asm/io.h> +#include <asm/arch/bsec.h> +#include <asm/arch/stm32.h> +#include <asm/arch/sys_proto.h> +#include <dm/device.h> +#include <dm/uclass.h> + +/* RCC register */ +#define RCC_TZCR (STM32_RCC_BASE + 0x00) +#define RCC_BDCR (STM32_RCC_BASE + 0x0140) +#define RCC_MP_APB5ENSETR (STM32_RCC_BASE + 0x0208) +#define RCC_MP_AHB5ENSETR (STM32_RCC_BASE + 0x0210) +#define RCC_DBGCFGR (STM32_RCC_BASE + 0x080C) + +#define RCC_BDCR_VSWRST BIT(31) +#define RCC_BDCR_RTCSRC GENMASK(17, 16) + +#define RCC_DBGCFGR_DBGCKEN BIT(8) + +/* DBGMCU register */ +#define DBGMCU_IDC (STM32_DBGMCU_BASE + 0x00) +#define DBGMCU_APB4FZ1 (STM32_DBGMCU_BASE + 0x2C) +#define DBGMCU_APB4FZ1_IWDG2 BIT(2) + +/* Security register */ +#define ETZPC_TZMA1_SIZE (STM32_ETZPC_BASE + 0x04) +#define ETZPC_DECPROT0 (STM32_ETZPC_BASE + 0x10) + +#define TZC_GATE_KEEPER (STM32_TZC_BASE + 0x008) +#define TZC_REGION_ATTRIBUTE0 (STM32_TZC_BASE + 0x110) +#define TZC_REGION_ID_ACCESS0 (STM32_TZC_BASE + 0x114) + +#define TAMP_CR1 (STM32_TAMP_BASE + 0x00) + +#define PWR_CR1 (STM32_PWR_BASE + 0x00) +#define PWR_MCUCR (STM32_PWR_BASE + 0x14) +#define PWR_CR1_DBP BIT(8) +#define PWR_MCUCR_SBF BIT(6) + +/* GPIOZ registers */ +#define GPIOZ_SECCFGR 0x54004030 + +/* DBGMCU register */ +#define DBGMCU_IDC (STM32_DBGMCU_BASE + 0x00) +#define DBGMCU_IDC_DEV_ID_MASK GENMASK(11, 0) +#define DBGMCU_IDC_DEV_ID_SHIFT 0 +#define DBGMCU_IDC_REV_ID_MASK GENMASK(31, 16) +#define DBGMCU_IDC_REV_ID_SHIFT 16 + +/* boot interface from Bootrom + * - boot instance = bit 31:16 + * - boot device = bit 15:0 + */ +#define BOOTROM_PARAM_ADDR 0x2FFC0078 +#define BOOTROM_MODE_MASK GENMASK(15, 0) +#define BOOTROM_MODE_SHIFT 0 +#define BOOTROM_INSTANCE_MASK GENMASK(31, 16) +#define BOOTROM_INSTANCE_SHIFT 16 + +/* Device Part Number (RPN) = OTP_DATA1 lower 8 bits */ +#define RPN_SHIFT 0 +#define RPN_MASK GENMASK(7, 0) + +/* Package = bit 27:29 of OTP16 => STM32MP15_PKG defines + * - 100: LBGA448 (FFI) => AA = LFBGA 18x18mm 448 balls p. 0.8mm + * - 011: LBGA354 (LCI) => AB = LFBGA 16x16mm 359 balls p. 0.8mm + * - 010: TFBGA361 (FFC) => AC = TFBGA 12x12mm 361 balls p. 0.5mm + * - 001: TFBGA257 (LCC) => AD = TFBGA 10x10mm 257 balls p. 0.5mm + * - others: Reserved + */ +#define PKG_SHIFT 27 +#define PKG_MASK GENMASK(2, 0) + +static void security_init(void) +{ + /* Disable the backup domain write protection */ + /* the protection is enable at each reset by hardware */ + /* And must be disable by software */ + setbits_le32(PWR_CR1, PWR_CR1_DBP); + + while (!(readl(PWR_CR1) & PWR_CR1_DBP)) + ; + + /* If RTC clock isn't enable so this is a cold boot then we need + * to reset the backup domain + */ + if (!(readl(RCC_BDCR) & RCC_BDCR_RTCSRC)) { + setbits_le32(RCC_BDCR, RCC_BDCR_VSWRST); + while (!(readl(RCC_BDCR) & RCC_BDCR_VSWRST)) + ; + clrbits_le32(RCC_BDCR, RCC_BDCR_VSWRST); + } + + /* allow non secure access in Write/Read for all peripheral */ + writel(GENMASK(25, 0), ETZPC_DECPROT0); + + /* Open SYSRAM for no secure access */ + writel(0x0, ETZPC_TZMA1_SIZE); + + /* enable TZC1 TZC2 clock */ + writel(BIT(11) | BIT(12), RCC_MP_APB5ENSETR); + + /* Region 0 set to no access by default */ + /* bit 0 / 16 => nsaid0 read/write Enable + * bit 1 / 17 => nsaid1 read/write Enable + * ... + * bit 15 / 31 => nsaid15 read/write Enable + */ + writel(0xFFFFFFFF, TZC_REGION_ID_ACCESS0); + /* bit 30 / 31 => Secure Global Enable : write/read */ + /* bit 0 / 1 => Region Enable for filter 0/1 */ + writel(BIT(0) | BIT(1) | BIT(30) | BIT(31), TZC_REGION_ATTRIBUTE0); + + /* Enable Filter 0 and 1 */ + setbits_le32(TZC_GATE_KEEPER, BIT(0) | BIT(1)); + + /* RCC trust zone deactivated */ + writel(0x0, RCC_TZCR); + + /* TAMP: deactivate the internal tamper + * Bit 23 ITAMP8E: monotonic counter overflow + * Bit 20 ITAMP5E: RTC calendar overflow + * Bit 19 ITAMP4E: HSE monitoring + * Bit 18 ITAMP3E: LSE monitoring + * Bit 16 ITAMP1E: RTC power domain supply monitoring + */ + writel(0x0, TAMP_CR1); + + /* GPIOZ: deactivate the security */ + writel(BIT(0), RCC_MP_AHB5ENSETR); + writel(0x0, GPIOZ_SECCFGR); +} + +/* + * Debug init + */ +void dbgmcu_init(void) +{ + /* + * Freeze IWDG2 if Cortex-A7 is in debug mode + * done in TF-A for TRUSTED boot and + * DBGMCU access is controlled by BSEC_DENABLE.DBGSWENABLE + */ + if (bsec_dbgswenable()) { + setbits_le32(RCC_DBGCFGR, RCC_DBGCFGR_DBGCKEN); + setbits_le32(DBGMCU_APB4FZ1, DBGMCU_APB4FZ1_IWDG2); + } +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + dbgmcu_init(); + + /* force probe of BSEC driver to shadow the upper OTP */ + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(stm32mp_bsec), &dev); + if (ret) + log_warning("BSEC probe failed: %d\n", ret); +} + +/* get bootmode from ROM code boot context: saved in TAMP register */ +static void update_bootmode(void) +{ + u32 boot_mode; + u32 bootrom_itf = readl(BOOTROM_PARAM_ADDR); + u32 bootrom_device, bootrom_instance; + + /* enable TAMP clock = RTCAPBEN */ + writel(BIT(8), RCC_MP_APB5ENSETR); + + /* read bootrom context */ + bootrom_device = + (bootrom_itf & BOOTROM_MODE_MASK) >> BOOTROM_MODE_SHIFT; + bootrom_instance = + (bootrom_itf & BOOTROM_INSTANCE_MASK) >> BOOTROM_INSTANCE_SHIFT; + boot_mode = + ((bootrom_device << BOOT_TYPE_SHIFT) & BOOT_TYPE_MASK) | + ((bootrom_instance << BOOT_INSTANCE_SHIFT) & + BOOT_INSTANCE_MASK); + + /* save the boot mode in TAMP backup register */ + clrsetbits_le32(TAMP_BOOT_CONTEXT, + TAMP_BOOT_MODE_MASK, + boot_mode << TAMP_BOOT_MODE_SHIFT); +} + +/* weak function: STM32MP15x mach init for boot without TFA */ +void stm32mp_cpu_init(void) +{ + if (IS_ENABLED(CONFIG_SPL_BUILD)) { + security_init(); + update_bootmode(); + } + + /* reset copro state in SPL, when used, or in U-Boot */ + if (!IS_ENABLED(CONFIG_SPL) || IS_ENABLED(CONFIG_SPL_BUILD)) { + /* Reset Coprocessor state unless it wakes up from Standby power mode */ + if (!(readl(PWR_MCUCR) & PWR_MCUCR_SBF)) { + writel(TAMP_COPRO_STATE_OFF, TAMP_COPRO_STATE); + writel(0, TAMP_COPRO_RSC_TBL_ADDRESS); + } + } +} + +static u32 read_idc(void) +{ + /* DBGMCU access is controlled by BSEC_DENABLE.DBGSWENABLE */ + if (bsec_dbgswenable()) { + setbits_le32(RCC_DBGCFGR, RCC_DBGCFGR_DBGCKEN); + + return readl(DBGMCU_IDC); + } + + return CPU_DEV_STM32MP15; /* STM32MP15x and unknown revision */ +} + +u32 get_cpu_dev(void) +{ + return (read_idc() & DBGMCU_IDC_DEV_ID_MASK) >> DBGMCU_IDC_DEV_ID_SHIFT; +} + +u32 get_cpu_rev(void) +{ + return (read_idc() & DBGMCU_IDC_REV_ID_MASK) >> DBGMCU_IDC_REV_ID_SHIFT; +} + +/* Get Device Part Number (RPN) from OTP */ +static u32 get_cpu_rpn(void) +{ + return get_otp(BSEC_OTP_RPN, RPN_SHIFT, RPN_MASK); +} + +u32 get_cpu_type(void) +{ + return (get_cpu_dev() << 16) | get_cpu_rpn(); +} + +/* Get Package options from OTP */ +u32 get_cpu_package(void) +{ + return get_otp(BSEC_OTP_PKG, PKG_SHIFT, PKG_MASK); +} + +static const char * const soc_type[] = { + "????", + "151C", "151A", "151F", "151D", + "153C", "153A", "153F", "153D", + "157C", "157A", "157F", "157D" +}; + +static const char * const soc_pkg[] = { "??", "AD", "AC", "AB", "AA" }; +static const char * const soc_rev[] = { "?", "A", "B", "Z" }; + +static void get_cpu_string_offsets(unsigned int *type, unsigned int *pkg, + unsigned int *rev) +{ + u32 cpu_type = get_cpu_type(); + u32 ct = cpu_type & ~(BIT(7) | BIT(0)); + u32 cm = ((cpu_type & BIT(7)) >> 6) | (cpu_type & BIT(0)); + u32 cp = get_cpu_package(); + + /* Bits 0 and 7 are the ACDF, 00:C 01:A 10:F 11:D */ + switch (ct) { + case CPU_STM32MP151Cxx: + *type = cm + 1; + break; + case CPU_STM32MP153Cxx: + *type = cm + 5; + break; + case CPU_STM32MP157Cxx: + *type = cm + 9; + break; + default: + *type = 0; + break; + } + + /* Package */ + switch (cp) { + case STM32MP15_PKG_AA_LBGA448: + case STM32MP15_PKG_AB_LBGA354: + case STM32MP15_PKG_AC_TFBGA361: + case STM32MP15_PKG_AD_TFBGA257: + *pkg = cp; + break; + default: + *pkg = 0; + break; + } + + /* Revision */ + switch (get_cpu_rev()) { + case CPU_REV1: + *rev = 1; + break; + case CPU_REV2: + *rev = 2; + break; + case CPU_REV2_1: + *rev = 3; + break; + default: + *rev = 0; + break; + } +} + +void get_soc_name(char name[SOC_NAME_SIZE]) +{ + unsigned int type, pkg, rev; + + get_cpu_string_offsets(&type, &pkg, &rev); + + snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", + soc_type[type], soc_pkg[pkg], soc_rev[rev]); +} + +static void setup_soc_type_pkg_rev(void) +{ + unsigned int type, pkg, rev; + + get_cpu_string_offsets(&type, &pkg, &rev); + + env_set("soc_type", soc_type[type]); + env_set("soc_pkg", soc_pkg[pkg]); + env_set("soc_rev", soc_rev[rev]); +} + +/* weak function called in arch_misc_init */ +void stm32mp_misc_init(void) +{ + setup_soc_type_pkg_rev(); +}
Hi Patrick
- others: Reserved
- early TLB into the .data section so that it not get cleared
- with 16kB allignment (see TTBR0_BASE_ADDR_MASK)
struct lmb lmb;
- Debug init
- int ret;
- dbgmcu_init();
- if (ret)
- u32 boot_mode;
- bootrom_device =
- boot_mode =
u32 boot_mode;
security_init();
update_bootmode();
u32 boot_mode;
stm32mp_cpu_init();
- else
return 0x0;
unsigned int *rev)
- switch (ct) {
*type = cm + 1;
break;
*type = cm + 5;
break;
*type = cm + 9;
break;
- default:
*type = 0;
break;
- /* Package */
- switch (cp) {
*pkg = cp;
break;
- default:
*pkg = 0;
break;
- /* Revision */
- case CPU_REV1:
*rev = 1;
break;
- case CPU_REV2:
*rev = 2;
break;
- case CPU_REV2_1:
*rev = 3;
break;
- default:
*rev = 0;
break;
- case STM32MP15_PKG_AA_LBGA448: pkg = STM32MP_PKG_AA; break;
- case STM32MP15_PKG_AB_LBGA354: pkg = STM32MP_PKG_AB; break;
- case STM32MP15_PKG_AC_TFBGA361: pkg = STM32MP_PKG_AC; break;
- case STM32MP15_PKG_AD_TFBGA257: pkg = STM32MP_PKG_AD; break; default:
arch_cpu_init();
mach_cpu_init();
- Copyright (C) 2021, STMicroelectronics - All Rights Reserved
- others: Reserved
- Debug init
- int ret;
- dbgmcu_init();
- if (ret)
- u32 boot_mode;
- bootrom_device =
- boot_mode =
security_init();
update_bootmode();
- /* reset copro state in SPL, when used, or in U-Boot */
unsigned int *rev)
- switch (ct) {
*type = cm + 1;
break;
*type = cm + 5;
break;
*type = cm + 9;
break;
- default:
*type = 0;
break;
- /* Package */
- switch (cp) {
*pkg = cp;
break;
- default:
*pkg = 0;
break;
- /* Revision */
- case CPU_REV1:
*rev = 1;
break;
- case CPU_REV2:
*rev = 2;
break;
- case CPU_REV2_1:
*rev = 3;
break;
- default:
*rev = 0;
break;
Thanks Patrice
Regards Patrick
Add mandatory choice for SOC support in ARCH_STM32MP.
This patch is a preliminary step for new SOC introduction in STM32MP family.
arch/arm/mach-stm32mp/Kconfig | 23 +++++++++++++---------- configs/stm32mp15_basic_defconfig | 4 ++-- configs/stm32mp15_defconfig | 4 ++-- configs/stm32mp15_trusted_defconfig | 4 ++-- 4 files changed, 19 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index be0d74b4ac..446d3258c9 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -33,6 +33,10 @@ config SYS_MALLOC_LEN config ENV_SIZE default 0x2000
+choice + prompt "Select STMicroelectronics STM32MPxxx Soc" + default STM32MP15x + config STM32MP15x bool "Support STMicroelectronics STM32MP15x Soc" select ARCH_SUPPORT_PSCI @@ -54,11 +58,13 @@ config STM32MP15x STM32MP157, STM32MP153 or STM32MP151 STMicroelectronics MPU with core ARMv7 dual core A7 for STM32MP157/3, monocore for STM32MP151 - target all the STMicroelectronics board with SOC STM32MP1 family +endchoice + +if STM32MP15x
config STM32MP15x_STM32IMAGE bool "Support STM32 image for generated U-Boot image" - depends on STM32MP15x && TFABOOT + depends on TFABOOT help Support of STM32 image generation for SOC STM32MP15x for TF-A boot when FIP container is not used @@ -69,7 +75,6 @@ choice
config TARGET_ST_STM32MP15x bool "STMicroelectronics STM32MP15x boards" - select STM32MP15x imply BOOTSTAGE imply CMD_BOOTSTAGE imply CMD_CLS if CMD_BMP @@ -84,7 +89,6 @@ config TARGET_ST_STM32MP15x
config TARGET_MICROGEA_STM32MP1 bool "Engicam MicroGEA STM32MP1 SOM" - select STM32MP15x imply BOOTSTAGE imply CMD_BOOTSTAGE imply CMD_CLS if CMD_BMP @@ -109,7 +113,6 @@ config TARGET_MICROGEA_STM32MP1
config TARGET_ICORE_STM32MP1 bool "Engicam i.Core STM32MP1 SOM" - select STM32MP15x imply BOOTSTAGE imply CMD_BOOTSTAGE imply CMD_CLS if CMD_BMP @@ -131,12 +134,16 @@ config TARGET_ICORE_STM32MP1
config TARGET_DH_STM32MP1_PDK2 bool "DH STM32MP1 PDK2" - select STM32MP15x help Target the DH PDK2 development kit with STM32MP15x SoM.
endchoice
+source "board/st/stm32mp1/Kconfig" +source "board/dhelectronics/dh_stm32mp1/Kconfig" +source "board/engicam/stm32mp1/Kconfig" +endif + config SYS_TEXT_BASE default 0xC0100000
@@ -221,8 +228,4 @@ config DEBUG_UART_CLOCK endif
source "arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig" -source "board/dhelectronics/dh_stm32mp1/Kconfig" -source "board/engicam/stm32mp1/Kconfig" -source "board/st/stm32mp1/Kconfig" - endif diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 5d1b2e0fd7..46b1cee5e7 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -9,10 +9,10 @@ CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC=y CONFIG_SPL=y CONFIG_TARGET_ST_STM32MP15x=y +CONFIG_TYPEC_STUSB160X=y +CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y -CONFIG_ENV_OFFSET_REDUND=0x2C0000 -CONFIG_TYPEC_STUSB160X=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y # CONFIG_ARMV7_VIRT is not set diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index f6e7fc81b0..8bb8e4624d 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -6,11 +6,11 @@ CONFIG_ENV_OFFSET=0x480000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_TARGET_ST_STM32MP15x=y +CONFIG_TYPEC_STUSB160X=y +CONFIG_ENV_OFFSET_REDUND=0x4C0000 CONFIG_DDR_CACHEABLE_SIZE=0x10000000 CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y -CONFIG_ENV_OFFSET_REDUND=0x4C0000 -CONFIG_TYPEC_STUSB160X=y # CONFIG_ARMV7_NONSEC is not set CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 855a394893..4f73930924 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -7,11 +7,11 @@ CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_STM32MP15x_STM32IMAGE=y CONFIG_TARGET_ST_STM32MP15x=y +CONFIG_TYPEC_STUSB160X=y +CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_DDR_CACHEABLE_SIZE=0x10000000 CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y -CONFIG_ENV_OFFSET_REDUND=0x2C0000 -CONFIG_TYPEC_STUSB160X=y # CONFIG_ARMV7_NONSEC is not set CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000
HI Patrick
+choice
- prompt "Select STMicroelectronics STM32MPxxx Soc"
- default STM32MP15x
+endchoice
+if STM32MP15x
- depends on TFABOOT help Support of STM32 image generation for SOC STM32MP15x for TF-A boot when FIP container is not used
endchoice
Thanks Patrice
Regards Patrick
Add sub Kconfig for each SOC in the STM32 CPU family.
It is a preliminary step to introduce a new SOC in the STM32MP family.
arch/arm/mach-stm32mp/Kconfig | 119 +--------------------------- arch/arm/mach-stm32mp/Kconfig.15x | 119 ++++++++++++++++++++++++++++ configs/stm32mp15_basic_defconfig | 2 +- configs/stm32mp15_defconfig | 4 +- configs/stm32mp15_trusted_defconfig | 4 +- 5 files changed, 125 insertions(+), 123 deletions(-) create mode 100644 arch/arm/mach-stm32mp/Kconfig.15x
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 446d3258c9..3b4936c326 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -60,93 +60,6 @@ config STM32MP15x dual core A7 for STM32MP157/3, monocore for STM32MP151 endchoice
-if STM32MP15x - -config STM32MP15x_STM32IMAGE - bool "Support STM32 image for generated U-Boot image" - depends on TFABOOT - help - Support of STM32 image generation for SOC STM32MP15x - for TF-A boot when FIP container is not used - -choice - prompt "STM32MP15x board select" - optional - -config TARGET_ST_STM32MP15x - bool "STMicroelectronics STM32MP15x boards" - imply BOOTSTAGE - imply CMD_BOOTSTAGE - imply CMD_CLS if CMD_BMP - imply DISABLE_CONSOLE - imply PRE_CONSOLE_BUFFER - imply SILENT_CONSOLE - help - target the STMicroelectronics board with SOC STM32MP15x - managed by board/st/stm32mp1: - Evalulation board (EV1) or Discovery board (DK1 and DK2). - The difference between board are managed with devicetree - -config TARGET_MICROGEA_STM32MP1 - bool "Engicam MicroGEA STM32MP1 SOM" - imply BOOTSTAGE - imply CMD_BOOTSTAGE - imply CMD_CLS if CMD_BMP - imply DISABLE_CONSOLE - imply PRE_CONSOLE_BUFFER - imply SILENT_CONSOLE - help - MicroGEA STM32MP1 is a STM32MP157A based Micro SOM. - - MicroGEA STM32MP1 MicroDev 2.0: - * MicroDev 2.0 is a general purpose miniature carrier board with CAN, - LTE and LVDS panel interfaces. - * MicroGEA STM32MP1 needs to mount on top of this MicroDev 2.0 board - for creating complete MicroGEA STM32MP1 MicroDev 2.0 Carrier board. - - MicroGEA STM32MP1 MicroDev 2.0 7" OF: - * 7" OF is a capacitive touch 7" Open Frame panel solutions with LVDS - panel and toucscreen. - * MicroGEA STM32MP1 needs to mount on top of MicroDev 2.0 board with - pluged 7" OF for creating complete MicroGEA STM32MP1 MicroDev 2.0 7" - Open Frame Solution board. - -config TARGET_ICORE_STM32MP1 - bool "Engicam i.Core STM32MP1 SOM" - imply BOOTSTAGE - imply CMD_BOOTSTAGE - imply CMD_CLS if CMD_BMP - imply DISABLE_CONSOLE - imply PRE_CONSOLE_BUFFER - imply SILENT_CONSOLE - help - i.Core STM32MP1 is an EDIMM SOM based on STM32MP157A. - - i.Core STM32MP1 EDIMM2.2: - * EDIMM2.2 is a Form Factor Capacitive Evaluation Board. - * i.Core STM32MP1 needs to mount on top of EDIMM2.2 for - creating complete i.Core STM32MP1 EDIMM2.2 Starter Kit. - - i.Core STM32MP1 C.TOUCH 2.0 - * C.TOUCH 2.0 is a general purpose Carrier board. - * i.Core STM32MP1 needs to mount on top of this Carrier board - for creating complete i.Core STM32MP1 C.TOUCH 2.0 board. - -config TARGET_DH_STM32MP1_PDK2 - bool "DH STM32MP1 PDK2" - help - Target the DH PDK2 development kit with STM32MP15x SoM. - -endchoice - -source "board/st/stm32mp1/Kconfig" -source "board/dhelectronics/dh_stm32mp1/Kconfig" -source "board/engicam/stm32mp1/Kconfig" -endif - -config SYS_TEXT_BASE - default 0xC0100000 - config NR_DRAM_BANKS default 1
@@ -195,37 +108,7 @@ config CMD_STM32KEY This command is used to evaluate the secure boot on stm32mp SOC, it is deactivated by default in real products.
-config PRE_CON_BUF_ADDR - default 0xC02FF000 - -config PRE_CON_BUF_SZ - default 4096 - -config BOOTSTAGE_STASH_ADDR - default 0xC3000000 - -if BOOTCOUNT_GENERIC -config SYS_BOOTCOUNT_SINGLEWORD - default y - -# TAMP_BOOTCOUNT = TAMP_BACKUP_REGISTER(21) -config SYS_BOOTCOUNT_ADDR - default 0x5C00A154 -endif - -if DEBUG_UART - -config DEBUG_UART_BOARD_INIT - default y - -# debug on UART4 by default -config DEBUG_UART_BASE - default 0x40010000 - -# clock source is HSI on reset -config DEBUG_UART_CLOCK - default 64000000 -endif +source "arch/arm/mach-stm32mp/Kconfig.15x"
source "arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig" endif diff --git a/arch/arm/mach-stm32mp/Kconfig.15x b/arch/arm/mach-stm32mp/Kconfig.15x new file mode 100644 index 0000000000..19f161cf5c --- /dev/null +++ b/arch/arm/mach-stm32mp/Kconfig.15x @@ -0,0 +1,119 @@ +if STM32MP15x + +config STM32MP15x_STM32IMAGE + bool "Support STM32 image for generated U-Boot image" + depends on TFABOOT + help + Support of STM32 image generation for SOC STM32MP15x + for TF-A boot when FIP container is not used + +choice + prompt "STM32MP15x board select" + optional + +config TARGET_ST_STM32MP15x + bool "STMicroelectronics STM32MP15x boards" + imply BOOTSTAGE + imply CMD_BOOTSTAGE + imply CMD_CLS if CMD_BMP + imply DISABLE_CONSOLE + imply PRE_CONSOLE_BUFFER + imply SILENT_CONSOLE + help + target the STMicroelectronics board with SOC STM32MP15x + managed by board/st/stm32mp1: + Evalulation board (EV1) or Discovery board (DK1 and DK2). + The difference between board are managed with devicetree + +config TARGET_DH_STM32MP1_PDK2 + bool "DH STM32MP1 PDK2" + help + Target the DH PDK2 development kit with STM32MP15x SoM. + +config TARGET_MICROGEA_STM32MP1 + bool "Engicam MicroGEA STM32MP1 SOM" + imply BOOTSTAGE + imply CMD_BOOTSTAGE + imply CMD_CLS if CMD_BMP + imply DISABLE_CONSOLE + imply PRE_CONSOLE_BUFFER + imply SILENT_CONSOLE + help + MicroGEA STM32MP1 is a STM32MP157A based Micro SOM. + + MicroGEA STM32MP1 MicroDev 2.0: + * MicroDev 2.0 is a general purpose miniature carrier board with CAN, + LTE and LVDS panel interfaces. + * MicroGEA STM32MP1 needs to mount on top of this MicroDev 2.0 board + for creating complete MicroGEA STM32MP1 MicroDev 2.0 Carrier board. + + MicroGEA STM32MP1 MicroDev 2.0 7" OF: + * 7" OF is a capacitive touch 7" Open Frame panel solutions with LVDS + panel and toucscreen. + * MicroGEA STM32MP1 needs to mount on top of MicroDev 2.0 board with + pluged 7" OF for creating complete MicroGEA STM32MP1 MicroDev 2.0 7" + Open Frame Solution board. + +config TARGET_ICORE_STM32MP1 + bool "Engicam i.Core STM32MP1 SOM" + imply BOOTSTAGE + imply CMD_BOOTSTAGE + imply CMD_CLS if CMD_BMP + imply DISABLE_CONSOLE + imply PRE_CONSOLE_BUFFER + imply SILENT_CONSOLE + help + i.Core STM32MP1 is an EDIMM SOM based on STM32MP157A. + + i.Core STM32MP1 EDIMM2.2: + * EDIMM2.2 is a Form Factor Capacitive Evaluation Board. + * i.Core STM32MP1 needs to mount on top of EDIMM2.2 for + creating complete i.Core STM32MP1 EDIMM2.2 Starter Kit. + + i.Core STM32MP1 C.TOUCH 2.0 + * C.TOUCH 2.0 is a general purpose Carrier board. + * i.Core STM32MP1 needs to mount on top of this Carrier board + for creating complete i.Core STM32MP1 C.TOUCH 2.0 board. + +endchoice + +config SYS_TEXT_BASE + default 0xC0100000 + +config PRE_CON_BUF_ADDR + default 0xC02FF000 + +config PRE_CON_BUF_SZ + default 4096 + +config BOOTSTAGE_STASH_ADDR + default 0xC3000000 + +if BOOTCOUNT_GENERIC +config SYS_BOOTCOUNT_SINGLEWORD + default y + +# TAMP_BOOTCOUNT = TAMP_BACKUP_REGISTER(21) +config SYS_BOOTCOUNT_ADDR + default 0x5C00A154 +endif + +if DEBUG_UART + +config DEBUG_UART_BOARD_INIT + default y + +# debug on UART4 by default +config DEBUG_UART_BASE + default 0x40010000 + +# clock source is HSI on reset +config DEBUG_UART_CLOCK + default 64000000 +endif + +source "board/st/stm32mp1/Kconfig" +source "board/dhelectronics/dh_stm32mp1/Kconfig" +source "board/engicam/stm32mp1/Kconfig" + +endif diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 46b1cee5e7..998947fe3d 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -8,10 +8,10 @@ CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC=y CONFIG_SPL=y +CONFIG_CMD_STM32KEY=y CONFIG_TARGET_ST_STM32MP15x=y CONFIG_TYPEC_STUSB160X=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 -CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index 8bb8e4624d..c4f06af732 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -5,11 +5,11 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_OFFSET=0x480000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" +CONFIG_DDR_CACHEABLE_SIZE=0x10000000 +CONFIG_CMD_STM32KEY=y CONFIG_TARGET_ST_STM32MP15x=y CONFIG_TYPEC_STUSB160X=y CONFIG_ENV_OFFSET_REDUND=0x4C0000 -CONFIG_DDR_CACHEABLE_SIZE=0x10000000 -CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y # CONFIG_ARMV7_NONSEC is not set CONFIG_SYS_LOAD_ADDR=0xc2000000 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 4f73930924..7c2adb3eb0 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -5,12 +5,12 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_OFFSET=0x280000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" +CONFIG_DDR_CACHEABLE_SIZE=0x10000000 +CONFIG_CMD_STM32KEY=y CONFIG_STM32MP15x_STM32IMAGE=y CONFIG_TARGET_ST_STM32MP15x=y CONFIG_TYPEC_STUSB160X=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 -CONFIG_DDR_CACHEABLE_SIZE=0x10000000 -CONFIG_CMD_STM32KEY=y CONFIG_CMD_STM32PROG=y # CONFIG_ARMV7_NONSEC is not set CONFIG_SYS_LOAD_ADDR=0xc2000000
Hi Patrick
-if STM32MP15x
- help
-choice
- optional
- imply BOOTSTAGE
- help
- imply BOOTSTAGE
- help
- imply BOOTSTAGE
- help
- help
-endchoice
- default 4096
- default y
-endif
-if DEBUG_UART
- default y
- default 64000000
- help
+choice
- optional
- imply BOOTSTAGE
- help
- help
- imply BOOTSTAGE
- help
- imply BOOTSTAGE
- help
+endchoice
- default 4096
- default y
+endif
+if DEBUG_UART
- default y
- default 64000000
+endif
Thanks Patrice
Regards Patrick
Add config CONFIG_STM32MP15_PWR to handle the access on regulators managed by the PWR driver defined in pwr_regulator.c
This driver is only used in U-Boot by STM32MP15x family.
arch/arm/mach-stm32mp/Kconfig.15x | 16 ++++++++++++++++ arch/arm/mach-stm32mp/Makefile | 2 +- 2 files changed, 17 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig.15x b/arch/arm/mach-stm32mp/Kconfig.15x index 19f161cf5c..d516270292 100644 --- a/arch/arm/mach-stm32mp/Kconfig.15x +++ b/arch/arm/mach-stm32mp/Kconfig.15x @@ -77,6 +77,22 @@ config TARGET_ICORE_STM32MP1
endchoice
+config STM32MP15_PWR + bool "Enable driver for STM32MP15x PWR" + depends on DM_REGULATOR && DM_PMIC + default y + help + This config enables implementation of driver-model pmic and + regulator uclass features for access to STM32MP15x PWR. + +config SPL_STM32MP15_PWR + bool "Enable driver for STM32MP15x PWR in SPL" + depends on SPL && SPL_DM_REGULATOR && SPL_DM_PMIC + default y + help + This config enables implementation of driver-model pmic and + regulator uclass features for access to STM32MP15x PWR in SPL. + config SYS_TEXT_BASE default 0xC0100000
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index d362104fee..0ffec6e02f 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -21,5 +21,5 @@ obj-$(CONFIG_ARMV7_PSCI) += psci.o obj-$(CONFIG_TFABOOT) += boot_params.o endif
-obj-$(CONFIG_$(SPL_)DM_REGULATOR) += pwr_regulator.o +obj-$(CONFIG_$(SPL_)STM32MP15_PWR) += pwr_regulator.o obj-$(CONFIG_OF_SYSTEM_SETUP) += fdt.o
Hi Patrick
s/the access on/the access to
pwr_regulator.c
endchoice
- bool "Enable driver for STM32MP15x PWR"
- depends on DM_REGULATOR && DM_PMIC
- default y
- help
- bool "Enable driver for STM32MP15x PWR in SPL"
- depends on SPL && SPL_DM_REGULATOR && SPL_DM_PMIC
- default y
- help
Regards Patrick
Introduce the code in mach-stm32mp and the configuration file stm32mp13_defconfig for the new STM32MP family.
arch/arm/mach-stm32mp/Kconfig | 21 +++- arch/arm/mach-stm32mp/Kconfig.13x | 57 +++++++++ arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/cpu.c | 3 + arch/arm/mach-stm32mp/fdt.c | 3 + arch/arm/mach-stm32mp/include/mach/stm32.h | 26 ++++ .../arm/mach-stm32mp/include/mach/sys_proto.h | 16 ++- arch/arm/mach-stm32mp/stm32mp13x.c | 115 ++++++++++++++++++ board/st/stm32mp1/Kconfig | 15 +++ board/st/stm32mp1/MAINTAINERS | 2 + configs/stm32mp15_basic_defconfig | 2 +- configs/stm32mp15_defconfig | 2 +- configs/stm32mp15_trusted_defconfig | 2 +- include/configs/stm32mp13_common.h | 106 ++++++++++++++++ include/configs/stm32mp13_st_common.h | 17 +++ include/configs/stm32mp15_common.h | 4 +- 16 files changed, 385 insertions(+), 7 deletions(-) create mode 100644 arch/arm/mach-stm32mp/Kconfig.13x create mode 100644 arch/arm/mach-stm32mp/stm32mp13x.c create mode 100644 include/configs/stm32mp13_common.h create mode 100644 include/configs/stm32mp13_st_common.h
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 3b4936c326..db47baba6d 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -37,6 +37,24 @@ choice prompt "Select STMicroelectronics STM32MPxxx Soc" default STM32MP15x
+config STM32MP13x + bool "Support STMicroelectronics STM32MP13x Soc" + select ARM_SMCCC + select CPU_V7A + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select OF_BOARD + select OF_BOARD_SETUP + select PINCTRL_STM32 + select STM32_RCC + select STM32_RESET + select STM32_SERIAL + select SYS_ARCH_TIMER + imply CMD_NVEDIT_INFO + help + support of STMicroelectronics SOC STM32MP13x family + STMicroelectronics MPU with core ARMv7 + config STM32MP15x bool "Support STMicroelectronics STM32MP15x Soc" select ARCH_SUPPORT_PSCI @@ -85,7 +103,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_MMC2
config STM32_ETZPC bool "STM32 Extended TrustZone Protection" - depends on STM32MP15x + depends on STM32MP15x || STM32MP13x default y imply BOOTP_SERVERIP help @@ -108,6 +126,7 @@ config CMD_STM32KEY This command is used to evaluate the secure boot on stm32mp SOC, it is deactivated by default in real products.
+source "arch/arm/mach-stm32mp/Kconfig.13x" source "arch/arm/mach-stm32mp/Kconfig.15x"
source "arch/arm/mach-stm32mp/cmd_stm32prog/Kconfig" diff --git a/arch/arm/mach-stm32mp/Kconfig.13x b/arch/arm/mach-stm32mp/Kconfig.13x new file mode 100644 index 0000000000..5fc000986e --- /dev/null +++ b/arch/arm/mach-stm32mp/Kconfig.13x @@ -0,0 +1,57 @@ +if STM32MP13x + +choice + prompt "STM32MP13x board select" + optional + +config TARGET_ST_STM32MP13x + bool "STMicroelectronics STM32MP13x boards" + imply BOOTSTAGE + imply CMD_BOOTSTAGE + imply CMD_CLS if CMD_BMP + imply DISABLE_CONSOLE + imply PRE_CONSOLE_BUFFER + imply SILENT_CONSOLE + help + target the STMicroelectronics board with SOC STM32MP13x + managed by board/st/stm32mp1. + The difference between board are managed with devicetree + +endchoice + +config SYS_TEXT_BASE + default 0xC0000000 + +config PRE_CON_BUF_ADDR + default 0xC0800000 + +config PRE_CON_BUF_SZ + default 4096 + +config BOOTSTAGE_STASH_ADDR + default 0xC3000000 + +if BOOTCOUNT_GENERIC +config SYS_BOOTCOUNT_SINGLEWORD + default y + +# TAMP_BOOTCOUNT = TAMP_BACKUP_REGISTER(31) +config SYS_BOOTCOUNT_ADDR + default 0x5C00A17C +endif + +if DEBUG_UART + +# debug on UART4 by default +config DEBUG_UART_BASE + default 0x40010000 + +# clock source is HSI on reset +config DEBUG_UART_CLOCK + default 48000000 if STM32_FPGA + default 64000000 +endif + +source "board/st/stm32mp1/Kconfig" + +endif diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index 0ffec6e02f..1db9057e04 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -8,6 +8,7 @@ obj-y += dram_init.o obj-y += syscon.o obj-y += bsec.o
+obj-$(CONFIG_STM32MP13x) += stm32mp13x.o obj-$(CONFIG_STM32MP15x) += stm32mp15x.o
ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index b808964d3e..240960ada4 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -52,8 +52,11 @@ void dram_bank_mmu_setup(int bank) enum dcache_option option;
if (IS_ENABLED(CONFIG_SPL_BUILD)) { +/* STM32_SYSRAM_BASE exist only when SPL is supported */ +#ifdef CONFIG_SPL start = ALIGN_DOWN(STM32_SYSRAM_BASE, MMU_SECTION_SIZE); size = ALIGN(STM32_SYSRAM_SIZE, MMU_SECTION_SIZE); +#endif } else if (gd->flags & GD_FLG_RELOC) { /* bd->bi_dram is available only after relocation */ start = bd->bi_dram[bank].start; diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index 969e7d94e9..ad45728949 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -259,6 +259,9 @@ int ft_system_setup(void *blob, struct bd_info *bd) u32 pkg, cpu; char name[SOC_NAME_SIZE];
+ if (IS_ENABLED(CONFIG_STM32MP13x)) + return 0; + soc = fdt_path_offset(blob, "/soc"); if (soc < 0) return soc; diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index 47e88fc3dc..cdb58fd40e 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -17,7 +17,9 @@ #define STM32_RCC_BASE 0x50000000 #define STM32_PWR_BASE 0x50001000 #define STM32_SYSCFG_BASE 0x50020000 +#ifdef CONFIG_STM32MP15x #define STM32_DBGMCU_BASE 0x50081000 +#endif #define STM32_FMC2_BASE 0x58002000 #define STM32_DDRCTRL_BASE 0x5A003000 #define STM32_DDRPHYC_BASE 0x5A004000 @@ -26,8 +28,14 @@ #define STM32_STGEN_BASE 0x5C008000 #define STM32_TAMP_BASE 0x5C00A000
+#ifdef CONFIG_STM32MP15x #define STM32_USART1_BASE 0x5C000000 #define STM32_USART2_BASE 0x4000E000 +#endif +#ifdef CONFIG_STM32MP13x +#define STM32_USART1_BASE 0x4c000000 +#define STM32_USART2_BASE 0x4c001000 +#endif #define STM32_USART3_BASE 0x4000F000 #define STM32_UART4_BASE 0x40010000 #define STM32_UART5_BASE 0x40011000 @@ -39,8 +47,10 @@ #define STM32_SDMMC2_BASE 0x58007000 #define STM32_SDMMC3_BASE 0x48004000
+#ifdef CONFIG_STM32MP15x #define STM32_SYSRAM_BASE 0x2FFC0000 #define STM32_SYSRAM_SIZE SZ_256K +#endif
#define STM32_DDR_BASE 0xC0000000 #define STM32_DDR_SIZE SZ_1G @@ -98,6 +108,8 @@ enum boot_device {
/* TAMP registers */ #define TAMP_BACKUP_REGISTER(x) (STM32_TAMP_BASE + 0x100 + 4 * x) + +#ifdef CONFIG_STM32MP15x #define TAMP_BACKUP_MAGIC_NUMBER TAMP_BACKUP_REGISTER(4) #define TAMP_BACKUP_BRANCH_ADDRESS TAMP_BACKUP_REGISTER(5) #define TAMP_COPRO_RSC_TBL_ADDRESS TAMP_BACKUP_REGISTER(17) @@ -111,6 +123,12 @@ enum boot_device { #define TAMP_COPRO_STATE_CSTOP 3 #define TAMP_COPRO_STATE_STANDBY 4 #define TAMP_COPRO_STATE_CRASH 5 +#endif + +#ifdef CONFIG_STM32MP13x +#define TAMP_BOOTCOUNT TAMP_BACKUP_REGISTER(31) +#define TAMP_BOOT_CONTEXT TAMP_BACKUP_REGISTER(30) +#endif
#define TAMP_BOOT_MODE_MASK GENMASK(15, 8) #define TAMP_BOOT_MODE_SHIFT 8 @@ -138,11 +156,19 @@ enum forced_boot_mode { #define STM32_BSEC_LOCK(id) (STM32_BSEC_LOCK_OFFSET + (id) * 4)
/* BSEC OTP index */ +#ifdef CONFIG_STM32MP15x #define BSEC_OTP_RPN 1 #define BSEC_OTP_SERIAL 13 #define BSEC_OTP_PKG 16 #define BSEC_OTP_MAC 57 #define BSEC_OTP_BOARD 59 +#endif +#ifdef CONFIG_STM32MP13x +#define BSEC_OTP_RPN 1 +#define BSEC_OTP_SERIAL 13 +#define BSEC_OTP_MAC 57 +#define BSEC_OTP_BOARD 60 +#endif
#endif /* __ASSEMBLY__ */ #endif /* _MACH_STM32_H_ */ diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index 8b61135aeb..829b3feebf 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -3,7 +3,7 @@ * Copyright (C) 2015-2017, STMicroelectronics - All Rights Reserved */
-/* ID = Device Version (bit31:16) + Device Part Number (RPN) (bit7:0) */ +/* ID = Device Version (bit31:16) + Device Part Number (RPN) (bit15:0) */ #define CPU_STM32MP157Cxx 0x05000000 #define CPU_STM32MP157Axx 0x05000001 #define CPU_STM32MP153Cxx 0x05000024 @@ -17,10 +17,24 @@ #define CPU_STM32MP151Fxx 0x050000AE #define CPU_STM32MP151Dxx 0x050000AF
+#define CPU_STM32MP135Cxx 0x05010000 +#define CPU_STM32MP135Axx 0x05010001 +#define CPU_STM32MP133Cxx 0x050100C0 +#define CPU_STM32MP133Axx 0x050100C1 +#define CPU_STM32MP131Cxx 0x050106C8 +#define CPU_STM32MP131Axx 0x050106C9 +#define CPU_STM32MP135Fxx 0x05010800 +#define CPU_STM32MP135Dxx 0x05010801 +#define CPU_STM32MP133Fxx 0x050108C0 +#define CPU_STM32MP133Dxx 0x050108C1 +#define CPU_STM32MP131Fxx 0x05010EC8 +#define CPU_STM32MP131Dxx 0x05010EC9 + /* return CPU_STMP32MP...Xxx constants */ u32 get_cpu_type(void);
#define CPU_DEV_STM32MP15 0x500 +#define CPU_DEV_STM32MP13 0x501
/* return CPU_DEV constants */ u32 get_cpu_dev(void); diff --git a/arch/arm/mach-stm32mp/stm32mp13x.c b/arch/arm/mach-stm32mp/stm32mp13x.c new file mode 100644 index 0000000000..38961310dc --- /dev/null +++ b/arch/arm/mach-stm32mp/stm32mp13x.c @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (C) 2020, STMicroelectronics - All Rights Reserved + */ + +#define LOG_CATEGORY LOGC_ARCH + +#include <common.h> +#include <log.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/stm32.h> +#include <asm/arch/sys_proto.h> + +/* SYSCFG register */ +#define SYSCFG_IDC_OFFSET 0x380 +#define SYSCFG_IDC_DEV_ID_MASK GENMASK(11, 0) +#define SYSCFG_IDC_DEV_ID_SHIFT 0 +#define SYSCFG_IDC_REV_ID_MASK GENMASK(31, 16) +#define SYSCFG_IDC_REV_ID_SHIFT 16 + +/* Device Part Number (RPN) = OTP_DATA1 lower 11 bits */ +#define RPN_SHIFT 0 +#define RPN_MASK GENMASK(11, 0) + +static u32 read_idc(void) +{ + void *syscfg = syscon_get_first_range(STM32MP_SYSCON_SYSCFG); + + return readl(syscfg + SYSCFG_IDC_OFFSET); +} + +u32 get_cpu_dev(void) +{ + return (read_idc() & SYSCFG_IDC_DEV_ID_MASK) >> SYSCFG_IDC_DEV_ID_SHIFT; +} + +u32 get_cpu_rev(void) +{ + return (read_idc() & SYSCFG_IDC_REV_ID_MASK) >> SYSCFG_IDC_REV_ID_SHIFT; +} + +/* Get Device Part Number (RPN) from OTP */ +static u32 get_cpu_rpn(void) +{ + return get_otp(BSEC_OTP_RPN, RPN_SHIFT, RPN_MASK); +} + +u32 get_cpu_type(void) +{ + return (get_cpu_dev() << 16) | get_cpu_rpn(); +} + +void get_soc_name(char name[SOC_NAME_SIZE]) +{ + char *cpu_s, *cpu_r; + + /* MPUs Part Numbers */ + switch (get_cpu_type()) { + case CPU_STM32MP135Fxx: + cpu_s = "135F"; + break; + case CPU_STM32MP135Dxx: + cpu_s = "135D"; + break; + case CPU_STM32MP135Cxx: + cpu_s = "135C"; + break; + case CPU_STM32MP135Axx: + cpu_s = "135A"; + break; + case CPU_STM32MP133Fxx: + cpu_s = "133F"; + break; + case CPU_STM32MP133Dxx: + cpu_s = "133D"; + break; + case CPU_STM32MP133Cxx: + cpu_s = "133C"; + break; + case CPU_STM32MP133Axx: + cpu_s = "133A"; + break; + case CPU_STM32MP131Fxx: + cpu_s = "131F"; + break; + case CPU_STM32MP131Dxx: + cpu_s = "131D"; + break; + case CPU_STM32MP131Cxx: + cpu_s = "131C"; + break; + case CPU_STM32MP131Axx: + cpu_s = "131A"; + break; + default: + cpu_s = "????"; + break; + } + + /* REVISION */ + switch (get_cpu_rev()) { + case CPU_REV1: + cpu_r = "A"; + break; + case CPU_REV1_1: + cpu_r = "Z"; + break; + default: + cpu_r = "?"; + break; + } + + snprintf(name, SOC_NAME_SIZE, "STM32MP%s Rev.%s", cpu_s, cpu_r); +} diff --git a/board/st/stm32mp1/Kconfig b/board/st/stm32mp1/Kconfig index 89e97aec2b..6ab8f80fa4 100644 --- a/board/st/stm32mp1/Kconfig +++ b/board/st/stm32mp1/Kconfig @@ -11,3 +11,18 @@ config SYS_CONFIG_NAME
source "board/st/common/Kconfig" endif + +if TARGET_ST_STM32MP13x + +config SYS_BOARD + default "stm32mp1" + +config SYS_VENDOR + default "st" + +config SYS_CONFIG_NAME + default "stm32mp13_st_common" + +source "board/st/common/Kconfig" + +endif diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index d57a49820e..c9252e90f4 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -9,5 +9,7 @@ F: board/st/stm32mp1/ F: configs/stm32mp15_defconfig F: configs/stm32mp15_basic_defconfig F: configs/stm32mp15_trusted_defconfig +F: include/configs/stm32mp13_common.h +F: include/configs/stm32mp13_st_common.h F: include/configs/stm32mp15_common.h F: include/configs/stm32mp15_st_common.h diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 998947fe3d..587b087b99 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -9,8 +9,8 @@ CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC=y CONFIG_SPL=y CONFIG_CMD_STM32KEY=y -CONFIG_TARGET_ST_STM32MP15x=y CONFIG_TYPEC_STUSB160X=y +CONFIG_TARGET_ST_STM32MP15x=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_CMD_STM32PROG=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index c4f06af732..da4013f1c9 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -7,8 +7,8 @@ CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_DDR_CACHEABLE_SIZE=0x10000000 CONFIG_CMD_STM32KEY=y -CONFIG_TARGET_ST_STM32MP15x=y CONFIG_TYPEC_STUSB160X=y +CONFIG_TARGET_ST_STM32MP15x=y CONFIG_ENV_OFFSET_REDUND=0x4C0000 CONFIG_CMD_STM32PROG=y # CONFIG_ARMV7_NONSEC is not set diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 7c2adb3eb0..73279a4cf6 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -7,9 +7,9 @@ CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_DDR_CACHEABLE_SIZE=0x10000000 CONFIG_CMD_STM32KEY=y +CONFIG_TYPEC_STUSB160X=y CONFIG_STM32MP15x_STM32IMAGE=y CONFIG_TARGET_ST_STM32MP15x=y -CONFIG_TYPEC_STUSB160X=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_CMD_STM32PROG=y # CONFIG_ARMV7_NONSEC is not set diff --git a/include/configs/stm32mp13_common.h b/include/configs/stm32mp13_common.h new file mode 100644 index 0000000000..799e3f053b --- /dev/null +++ b/include/configs/stm32mp13_common.h @@ -0,0 +1,106 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause */ +/* + * Copyright (C) 2021, STMicroelectronics - All Rights Reserved + * + * Configuration settings for the STM32MP15x CPU + */ + +#ifndef __CONFIG_STM32MP13_COMMMON_H +#define __CONFIG_STM32MP13_COMMMON_H +#include <linux/sizes.h> +#include <asm/arch/stm32.h> + +/* + * Configuration of the external SRAM memory used by U-Boot + */ +#define CONFIG_SYS_SDRAM_BASE STM32_DDR_BASE +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_4M) + +/* + * Console I/O buffer size + */ +#define CONFIG_SYS_CBSIZE SZ_1K + +/* + * For booting Linux, use the first 256 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ SZ_256M + +/* Extend size of kernel image for uncompression */ +#define CONFIG_SYS_BOOTM_LEN SZ_32M + +/*MMC SD*/ +#define CONFIG_SYS_MMC_MAX_DEVICE 2 + +/* NAND support */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/*****************************************************************************/ +#ifdef CONFIG_DISTRO_DEFAULTS +/*****************************************************************************/ + +#ifdef CONFIG_CMD_MMC +#define BOOT_TARGET_MMC0(func) func(MMC, mmc, 0) +#define BOOT_TARGET_MMC1(func) func(MMC, mmc, 1) +#else +#define BOOT_TARGET_MMC0(func) +#define BOOT_TARGET_MMC1(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_MMC1(func) \ + BOOT_TARGET_MMC0(func) + +/* + * default bootcmd for stm32mp13: + * for mmc boot (eMMC, SD card), distro boot on the same mmc device + */ +#define STM32MP_BOOTCMD "bootcmd_stm32mp=" \ + "echo "Boot over ${boot_device}${boot_instance}!";" \ + "run env_check;" \ + "if test ${boot_device} = mmc;" \ + "then env set boot_targets "mmc${boot_instance}"; fi;" \ + "run distro_bootcmd;" \ + "fi;\0" + +#define STM32MP_EXTRA \ + "env_check=if env info -p -d -q; then env save; fi\0" \ + "boot_net_usb_start=true\0" + +#ifndef STM32MP_BOARD_EXTRA_ENV +#define STM32MP_BOARD_EXTRA_ENV +#endif + +#include <config_distro_bootcmd.h> + +/* + * memory layout for 32M uncompressed/compressed kernel, + * 1M fdt, 1M script, 1M pxe and 1M for overlay + * and the ramdisk at the end. + */ +#define __KERNEL_ADDR_R __stringify(0xc2000000) +#define __FDT_ADDR_R __stringify(0xc4000000) +#define __SCRIPT_ADDR_R __stringify(0xc4100000) +#define __PXEFILE_ADDR_R __stringify(0xc4200000) +#define __FDTOVERLAY_ADDR_R __stringify(0xc4300000) +#define __RAMDISK_ADDR_R __stringify(0xc4400000) + +#define STM32MP_MEM_LAYOUT \ + "kernel_addr_r=" __KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" __FDT_ADDR_R "\0" \ + "scriptaddr=" __SCRIPT_ADDR_R "\0" \ + "pxefile_addr_r=" __PXEFILE_ADDR_R "\0" \ + "fdtoverlay_addr_r=" __FDTOVERLAY_ADDR_R "\0" \ + "ramdisk_addr_r=" __RAMDISK_ADDR_R "\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + STM32MP_MEM_LAYOUT \ + STM32MP_BOOTCMD \ + BOOTENV \ + STM32MP_EXTRA \ + STM32MP_BOARD_EXTRA_ENV + +#endif /* ifdef CONFIG_DISTRO_DEFAULTS*/ + +#endif /* __CONFIG_STM32MP13_COMMMON_H */ diff --git a/include/configs/stm32mp13_st_common.h b/include/configs/stm32mp13_st_common.h new file mode 100644 index 0000000000..d73526f14e --- /dev/null +++ b/include/configs/stm32mp13_st_common.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause */ +/* + * Copyright (C) 2022, STMicroelectronics - All Rights Reserved + * + * Configuration settings for the STMicroelectonics STM32MP15x boards + */ + +#ifndef __CONFIG_STM32MP13_ST_COMMON_H__ +#define __CONFIG_STM32MP13_ST_COMMON_H__ + +#define STM32MP_BOARD_EXTRA_ENV \ + "usb_pgood_delay=1000\0" \ + "console=ttySTM0\0" + +#include <configs/stm32mp13_common.h> + +#endif diff --git a/include/configs/stm32mp15_common.h b/include/configs/stm32mp15_common.h index 6b40cdb017..adfb2898b0 100644 --- a/include/configs/stm32mp15_common.h +++ b/include/configs/stm32mp15_common.h @@ -14,7 +14,7 @@ * Configuration of the external SRAM memory used by U-Boot */ #define CONFIG_SYS_SDRAM_BASE STM32_DDR_BASE -#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE
/* * Console I/O buffer size @@ -97,7 +97,7 @@ BOOT_TARGET_PXE(func)
/* - * default bootcmd for stm32mp1: + * default bootcmd for stm32mp15: * for serial/usb: execute the stm32prog command * for mmc boot (eMMC, SD card), distro boot on the same mmc device * for nand or spi-nand boot, distro boot with ubifs on UBI partition
Hi Patrick
2 minor typo below
Thanks Patrice
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com
+config STM32MP13x
- bool "Support STMicroelectronics STM32MP13x Soc"
- select ARM_SMCCC
- select CPU_V7A
- select CPU_V7_HAS_NONSEC
- select CPU_V7_HAS_VIRT
- select OF_BOARD
- select OF_BOARD_SETUP
- select PINCTRL_STM32
- select STM32_RCC
- select STM32_RESET
- select STM32_SERIAL
- select SYS_ARCH_TIMER
- imply CMD_NVEDIT_INFO
- help
- depends on STM32MP15x || STM32MP13x default y imply BOOTP_SERVERIP help
+choice
- prompt "STM32MP13x board select"
- optional
- bool "STMicroelectronics STM32MP13x boards"
- imply BOOTSTAGE
- help
+endchoice
- default 0xC0000000
- default 0xC0800000
- default 4096
- default y
- default 0x5C00A17C
+endif
+if DEBUG_UART
- default 48000000 if STM32_FPGA
- default 64000000
+endif
- if (IS_ENABLED(CONFIG_STM32MP13x))
- soc = fdt_path_offset(blob, "/soc"); if (soc < 0) return soc;
- Copyright (C) 2015-2017, STMicroelectronics - All Rights Reserved
- Copyright (C) 2020, STMicroelectronics - All Rights Reserved
s/2020/2022
- void *syscfg = syscon_get_first_range(STM32MP_SYSCON_SYSCFG);
- return readl(syscfg + SYSCFG_IDC_OFFSET);
- return (read_idc() & SYSCFG_IDC_DEV_ID_MASK) >> SYSCFG_IDC_DEV_ID_SHIFT;
- return (read_idc() & SYSCFG_IDC_REV_ID_MASK) >> SYSCFG_IDC_REV_ID_SHIFT;
- char *cpu_s, *cpu_r;
- /* MPUs Part Numbers */
- switch (get_cpu_type()) {
- case CPU_STM32MP135Fxx:
cpu_s = "135F";
break;
- case CPU_STM32MP135Dxx:
cpu_s = "135D";
break;
- case CPU_STM32MP135Cxx:
cpu_s = "135C";
break;
- case CPU_STM32MP135Axx:
cpu_s = "135A";
break;
- case CPU_STM32MP133Fxx:
cpu_s = "133F";
break;
- case CPU_STM32MP133Dxx:
cpu_s = "133D";
break;
- case CPU_STM32MP133Cxx:
cpu_s = "133C";
break;
- case CPU_STM32MP133Axx:
cpu_s = "133A";
break;
- case CPU_STM32MP131Fxx:
cpu_s = "131F";
break;
- case CPU_STM32MP131Dxx:
cpu_s = "131D";
break;
- case CPU_STM32MP131Cxx:
cpu_s = "131C";
break;
- case CPU_STM32MP131Axx:
cpu_s = "131A";
break;
- default:
cpu_s = "????";
break;
- /* REVISION */
- case CPU_REV1:
cpu_r = "A";
break;
- case CPU_REV1_1:
cpu_r = "Z";
break;
- default:
cpu_r = "?";
break;
- snprintf(name, SOC_NAME_SIZE, "STM32MP%s Rev.%s", cpu_s, cpu_r);
+config SYS_BOARD
- default "stm32mp1"
+config SYS_VENDOR
- default "st"
- default "stm32mp13_st_common"
s/2021/2022
- Configuration settings for the STM32MP15x CPU
- Configuration of the external SRAM memory used by U-Boot
- Console I/O buffer size
- For booting Linux, use the first 256 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- BOOT_TARGET_MMC1(func) \
- BOOT_TARGET_MMC0(func)
- default bootcmd for stm32mp13:
- for mmc boot (eMMC, SD card), distro boot on the same mmc device
- "echo "Boot over ${boot_device}${boot_instance}!";" \
"run env_check;" \
"then env set boot_targets \"mmc${boot_instance}\"; fi;" \
- "fi;\0"
- "env_check=if env info -p -d -q; then env save; fi\0" \
- "boot_net_usb_start=true\0"
- memory layout for 32M uncompressed/compressed kernel,
- 1M fdt, 1M script, 1M pxe and 1M for overlay
- and the ramdisk at the end.
- "kernel_addr_r=" __KERNEL_ADDR_R "\0" \
- "fdt_addr_r=" __FDT_ADDR_R "\0" \
- "scriptaddr=" __SCRIPT_ADDR_R "\0" \
- "pxefile_addr_r=" __PXEFILE_ADDR_R "\0" \
- "fdtoverlay_addr_r=" __FDTOVERLAY_ADDR_R "\0" \
- "ramdisk_addr_r=" __RAMDISK_ADDR_R "\0"
- STM32MP_MEM_LAYOUT \
- STM32MP_BOOTCMD \
- BOOTENV \
- STM32MP_EXTRA \
- STM32MP_BOARD_EXTRA_ENV
- Copyright (C) 2022, STMicroelectronics - All Rights Reserved
- Configuration settings for the STMicroelectonics STM32MP15x boards
- "usb_pgood_delay=1000\0" \
- "console=ttySTM0\0"
- default bootcmd for stm32mp1:
- default bootcmd for stm32mp15:
- for serial/usb: execute the stm32prog command
- for nand or spi-nand boot, distro boot with ubifs on UBI partition
another typo found below
On 5/20/22 08:49, Patrice CHOTARD wrote:
Hi Patrick
2 minor typo below
Thanks Patrice
+config STM32MP13x
- select ARM_SMCCC
- select CPU_V7A
- select OF_BOARD
- select STM32_RCC
- help
+choice
- optional
- imply BOOTSTAGE
- help
+endchoice
- default 4096
- default y
+endif
+if DEBUG_UART
- default 64000000
+endif
s/2020/2022
cpu_s = "135F";
break;
cpu_s = "135D";
break;
cpu_s = "135C";
break;
cpu_s = "135A";
break;
cpu_s = "133F";
break;
cpu_s = "133D";
break;
cpu_s = "133C";
break;
cpu_s = "133A";
break;
cpu_s = "131F";
break;
cpu_s = "131D";
break;
cpu_s = "131C";
break;
cpu_s = "131A";
break;
- default:
cpu_s = "????";
break;
- /* REVISION */
- case CPU_REV1:
cpu_r = "A";
break;
- case CPU_REV1_1:
cpu_r = "Z";
break;
- default:
cpu_r = "?";
break;
+config SYS_BOARD
+config SYS_VENDOR
- default "st"
s/2021/2022
"run env_check;" \
- "fi;\0"
- STM32MP_BOOTCMD \
- BOOTENV \
- STM32MP_EXTRA \
s/STMicroelectonics/STMicroelectronics
Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
s@STM32MP15x@STM32MP13x@ too ;-)
btw. as a general comment, please do use these [...] to reduce the patch content you comment on. Searching for that one line in a wall of quoted text can be not fun.
Some ad
=> CONFIG_SYS_INIT_SP_ADDR remove and moved in Kconfig
=> CONFIG_SYS_CBSIZE removed and moved in Kconfig
"run env_check;" \
- "fi;\0"
- STM32MP_BOOTCMD \
- BOOTENV \
- STM32MP_EXTRA \
Applied to u-boot-stm/next, with these modification
thanks!
Regards Patrick
Add support of several MAC address in OTP (3 32bits OTP word for 2 MAC address) for SOCs in STM32MP13x family: STM32MP133 and STM32MP135.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/cpu.c | 41 ++++++++++++------- .../arm/mach-stm32mp/include/mach/sys_proto.h | 1 + arch/arm/mach-stm32mp/stm32mp13x.c | 20 +++++++++ arch/arm/mach-stm32mp/stm32mp15x.c | 5 +++ 4 files changed, 52 insertions(+), 15 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 240960ada4..855fc755fe 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -290,16 +290,18 @@ __weak int setup_mac_address(void) { int ret; int i; - u32 otp[2]; + u32 otp[3]; uchar enetaddr[6]; struct udevice *dev; + int nb_eth, nb_otp, index;
if (!IS_ENABLED(CONFIG_NET)) return 0;
- /* MAC already in environment */ - if (eth_env_get_enetaddr("ethaddr", enetaddr)) - return 0; + nb_eth = get_eth_nb(); + + /* 6 bytes for each MAC addr and 4 bytes for each OTP */ + nb_otp = DIV_ROUND_UP(6 * nb_eth, 4);
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(stm32mp_bsec), @@ -307,22 +309,31 @@ __weak int setup_mac_address(void) if (ret) return ret;
- ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_MAC), - otp, sizeof(otp)); + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_MAC), otp, 4 * nb_otp); if (ret < 0) return ret;
- for (i = 0; i < 6; i++) - enetaddr[i] = ((uint8_t *)&otp)[i]; + for (index = 0; index < nb_eth; index++) { + /* MAC already in environment */ + if (eth_env_get_enetaddr_by_index("eth", index, enetaddr)) + continue; + + for (i = 0; i < 6; i++) + enetaddr[i] = ((uint8_t *)&otp)[i + 6 * index];
- if (!is_valid_ethaddr(enetaddr)) { - log_err("invalid MAC address in OTP %pM\n", enetaddr); - return -EINVAL; + if (!is_valid_ethaddr(enetaddr)) { + log_err("invalid MAC address %d in OTP %pM\n", + index, enetaddr); + return -EINVAL; + } + log_debug("OTP MAC address %d = %pM\n", index, enetaddr); + ret = eth_env_set_enetaddr_by_index("eth", index, enetaddr); + if (ret) { + log_err("Failed to set mac address %pM from OTP: %d\n", + enetaddr, ret); + return ret; + } } - log_debug("OTP MAC address = %pM\n", enetaddr); - ret = eth_env_set_enetaddr("ethaddr", enetaddr); - if (ret) - log_err("Failed to set mac address %pM from OTP: %d\n", enetaddr, ret);
return 0; } diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index 829b3feebf..4b564e86dc 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -64,6 +64,7 @@ void get_soc_name(char name[SOC_NAME_SIZE]); /* return boot mode */ u32 get_bootmode(void);
+int get_eth_nb(void); int setup_mac_address(void);
/* board power management : configure vddcore according OPP */ diff --git a/arch/arm/mach-stm32mp/stm32mp13x.c b/arch/arm/mach-stm32mp/stm32mp13x.c index 38961310dc..8a56f381ce 100644 --- a/arch/arm/mach-stm32mp/stm32mp13x.c +++ b/arch/arm/mach-stm32mp/stm32mp13x.c @@ -51,6 +51,26 @@ u32 get_cpu_type(void) return (get_cpu_dev() << 16) | get_cpu_rpn(); }
+int get_eth_nb(void) +{ + int nb_eth = 2; + + switch (get_cpu_type()) { + case CPU_STM32MP131Dxx: + fallthrough; + case CPU_STM32MP131Cxx: + fallthrough; + case CPU_STM32MP131Axx: + nb_eth = 1; + break; + default: + nb_eth = 2; + break; + } + + return nb_eth; +} + void get_soc_name(char name[SOC_NAME_SIZE]) { char *cpu_s, *cpu_r; diff --git a/arch/arm/mach-stm32mp/stm32mp15x.c b/arch/arm/mach-stm32mp/stm32mp15x.c index 800fad2f43..a093e6163e 100644 --- a/arch/arm/mach-stm32mp/stm32mp15x.c +++ b/arch/arm/mach-stm32mp/stm32mp15x.c @@ -247,6 +247,11 @@ u32 get_cpu_type(void) return (get_cpu_dev() << 16) | get_cpu_rpn(); }
+int get_eth_nb(void) +{ + return 1; +} + /* Get Package options from OTP */ u32 get_cpu_package(void) {
Hi Patrick
- u32 otp[2];
otp, sizeof(otp));
- ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_MAC), otp, 4 * nb_otp); if (ret < 0) return ret;
- for (index = 0; index < nb_eth; index++) {
continue;
return -EINVAL;
index, enetaddr);
return -EINVAL;
if (ret) {
enetaddr, ret);
return ret;
if (ret)
- int nb_eth = 2;
fallthrough;
fallthrough;
nb_eth = 1;
break;
- default:
nb_eth = 2;
break;
- return nb_eth;
- return 1;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Applied to u-boot-stm/next, thanks!
Regards Patrick
Add support for "st,stm32mp135-pinctrl" for STM32MP13x
drivers/pinctrl/pinctrl_stm32.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index 5729799b12..b100e56044 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -494,6 +494,7 @@ static const struct udevice_id stm32_pinctrl_ids[] = { { .compatible = "st,stm32h743-pinctrl" }, { .compatible = "st,stm32mp157-pinctrl" }, { .compatible = "st,stm32mp157-z-pinctrl" }, + { .compatible = "st,stm32mp135-pinctrl" }, { } };
Hi Patrick
- { .compatible = "st,stm32mp135-pinctrl" }, { }
Thanks Patrice
HI Patrick
Thanks Patrice
Regards Patrick
Add stm32mp15x prefix to all STM32MP15x board specific function, this patch is a preliminary step for STM32MP13x support.
This patch also add the RCC probe to avoid circular access with usbphyc probe as clk provider.
board/st/stm32mp1/stm32mp1.c | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index fff1880e5b..4ba7201ffb 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -547,8 +547,7 @@ static void sysconf_init(void) clrbits_le32(syscfg + SYSCFG_CMPCR, SYSCFG_CMPCR_SW_CTRL); }
-/* Fix to make I2C1 usable on DK2 for touchscreen usage in kernel */ -static int dk2_i2c1_fix(void) +static int board_stm32mp15x_dk2_init(void) { ofnode node; struct gpio_desc hdmi, audio; @@ -557,6 +556,7 @@ static int dk2_i2c1_fix(void) if (!IS_ENABLED(CONFIG_DM_REGULATOR)) return -ENODEV;
+ /* Fix to make I2C1 usable on DK2 for touchscreen usage in kernel */ node = ofnode_path("/soc/i2c@40012000/hdmi-transmitter@39"); if (!ofnode_valid(node)) { log_debug("no hdmi-transmitter@39 ?\n"); @@ -604,7 +604,7 @@ error: return ret; }
-static bool board_is_dk2(void) +static bool board_is_stm32mp15x_dk2(void) { if (CONFIG_IS_ENABLED(TARGET_ST_STM32MP15x) && of_machine_is_compatible("st,stm32mp157c-dk2")) @@ -613,7 +613,7 @@ static bool board_is_dk2(void) return false; }
-static bool board_is_ev1(void) +static bool board_is_stm32mp15x_ev1(void) { if (CONFIG_IS_ENABLED(TARGET_ST_STM32MP15x) && (of_machine_is_compatible("st,stm32mp157a-ev1") || @@ -637,7 +637,7 @@ U_BOOT_DRIVER(goodix) = { .of_match = goodix_ids, };
-static void board_ev1_init(void) +static void board_stm32mp15x_ev1_init(void) { struct udevice *dev;
@@ -648,13 +648,22 @@ static void board_ev1_init(void) /* board dependent setup after realloc */ int board_init(void) { + struct udevice *dev; + int ret; + + /* probe RCC to avoid circular access with usbphyc probe as clk provider */ + if (IS_ENABLED(CONFIG_CLK_STM32MP13)) { + ret = uclass_get_device_by_driver(UCLASS_CLK, DM_DRIVER_GET(stm32mp1_clock), &dev); + log_debug("Clock init failed: %d\n", ret); + } + board_key_check();
- if (board_is_ev1()) - board_ev1_init(); + if (board_is_stm32mp15x_ev1()) + board_stm32mp15x_ev1_init();
- if (board_is_dk2()) - dk2_i2c1_fix(); + if (board_is_stm32mp15x_dk2()) + board_stm32mp15x_dk2_init();
if (IS_ENABLED(CONFIG_DM_REGULATOR)) regulators_enable_boot_on(_DEBUG);
Hi Patrick
One typo and one remark below
s/add/adds
- /* Fix to make I2C1 usable on DK2 for touchscreen usage in kernel */ node = ofnode_path("/soc/i2c@40012000/hdmi-transmitter@39"); if (!ofnode_valid(node)) { log_debug("no hdmi-transmitter@39 ?\n");
- struct udevice *dev;
- int ret;
- /* probe RCC to avoid circular access with usbphyc probe as clk provider */
- if (IS_ENABLED(CONFIG_CLK_STM32MP13)) {
I am wondering if usage of DM_FLAG_PROBE_AFTER_BIND in flag would avoid this above piece of code ?
- board_key_check();
board_ev1_init();
- if (board_is_stm32mp15x_ev1())
dk2_i2c1_fix();
Hi Patrice
On 5/20/22 09:02, Patrice CHOTARD wrote:
Hi Patrick
s/add/adds
OK
- int ret;
Yes, I think you are right
=> need to be tested when RCC clock driver and USBPHY clock will be upstreamed
and then we will remove these lines
board_ev1_init();
dk2_i2c1_fix();
Regards
Patrick
Accepted with minor modification.
- int ret;
=> this force RCC probed removed to avoid issue when RCC node is not present in
device tree
can be replaced by DM_FLAG_PROBE_AFTER_BIND managed in RCC driver.
board_key_check();
board_ev1_init();
dk2_i2c1_fix();
Regards Patrick
Add support for new compatible "st,stm32mp13-ddr" to manage the DDR sub system (Controller and PHY) in STM32MP13x SOC: - only one AXI port - support of 16 port output (MEMC_DRAM_DATA_WIDTH = 2)
The STM32MP15x SOC have 2 AXI ports and 32 bits support.
.../memory-controllers/st,stm32mp1-ddr.txt | 49 +++++++++++++++---- drivers/ram/stm32mp1/stm32mp1_ram.c | 28 +++++++---- 2 files changed, 57 insertions(+), 20 deletions(-)
diff --git a/doc/device-tree-bindings/memory-controllers/st,stm32mp1-ddr.txt b/doc/device-tree-bindings/memory-controllers/st,stm32mp1-ddr.txt index 926e3e83b3..e6ea8d0ef5 100644 --- a/doc/device-tree-bindings/memory-controllers/st,stm32mp1-ddr.txt +++ b/doc/device-tree-bindings/memory-controllers/st,stm32mp1-ddr.txt @@ -3,7 +3,8 @@ ST,stm32mp1 DDR3/LPDDR2/LPDDR3 Controller (DDRCTRL and DDRPHYC) -------------------- Required properties: -------------------- -- compatible : Should be "st,stm32mp1-ddr" +- compatible : Should be "st,stm32mp1-ddr" for STM32MP15x + Should be "st,stm32mp13-ddr" for STM32MP13x - reg : controleur (DDRCTRL) and phy (DDRPHYC) base address - clocks : controller clocks handle - clock-names : associated controller clock names @@ -13,6 +14,8 @@ Required properties: the next attributes are DDR parameters, they are generated by DDR tools included in STM32 Cube tool
+They are required only in SPL, when TFABOOT is not activated. + info attributes: ---------------- - st,mem-name : name for DDR configuration, simple string for information @@ -24,7 +27,7 @@ controlleur attributes: ----------------------- - st,ctl-reg : controleur values depending of the DDR type (DDR3/LPDDR2/LPDDR3) - for STM32MP15x: 25 values are requested in this order + for STM32MP15x and STM32MP13x: 25 values are requested in this order MSTR MRCTRL0 MRCTRL1 @@ -53,7 +56,7 @@ controlleur attributes:
- st,ctl-timing : controleur values depending of frequency and timing parameter of DDR - for STM32MP15x: 12 values are requested in this order + for STM32MP15x and STM32MP13x: 12 values are requested in this order RFSHTMG DRAMTMG0 DRAMTMG1 @@ -68,7 +71,7 @@ controlleur attributes: ODTCFG
- st,ctl-map : controleur values depending of address mapping - for STM32MP15x: 9 values are requested in this order + for STM32MP15x and STM32MP13x: 9 values are requested in this order ADDRMAP1 ADDRMAP2 ADDRMAP3 @@ -99,6 +102,19 @@ controlleur attributes: PCFGWQOS0_1 PCFGWQOS1_1
+ for STM32MP13x: 11 values are requested in this order + SCHED + SCHED1 + PERFHPR1 + PERFLPR1 + PERFWR1 + PCFGR_0 + PCFGW_0 + PCFGQOS0_0 + PCFGQOS1_0 + PCFGWQOS0_0 + PCFGWQOS1_0 + phyc attributes: ---------------- - st,phy-reg : phy values depending of the DDR type (DDR3/LPDDR2/LPDDR3) @@ -115,8 +131,19 @@ phyc attributes: DX2GCR DX3GCR
+ for STM32MP13x: 9 values are requested in this order + PGCR + ACIOCR + DXCCR + DSGCR + DCR + ODTCR + ZQ0CR1 + DX0GCR + DX1GCR + - st,phy-timing : phy values depending of frequency and timing parameter of DDR - for STM32MP15x: 10 values are requested in this order + for STM32MP15x and STM32MP13x: 10 values are requested in this order PTR0 PTR1 PTR2 @@ -128,16 +155,18 @@ phyc attributes: MR2 MR3
+ for STM32MP13x: 6 values are requested in this order + DX0DLLCR + DX0DQTR + DX0DQSTR + DX1DLLCR + DX1DQTR + DX1DQSTR Example:
/ { soc { - u-boot,dm-spl; - ddr: ddr@0x5A003000{ - u-boot,dm-spl; - u-boot,dm-pre-reloc; - compatible = "st,stm32mp1-ddr";
reg = <0x5A003000 0x550 diff --git a/drivers/ram/stm32mp1/stm32mp1_ram.c b/drivers/ram/stm32mp1/stm32mp1_ram.c index 49b1262461..a6c19af972 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ram.c +++ b/drivers/ram/stm32mp1/stm32mp1_ram.c @@ -230,29 +230,29 @@ static u8 get_nb_col(struct stm32mp1_ddrctl *ctl, u8 data_bus_width)
reg = readl(&ctl->addrmap3); /* addrmap3.addrmap_col_b6 */ - val = (reg & GENMASK(3, 0)) >> 0; + val = (reg & GENMASK(4, 0)) >> 0; if (val <= 7) bits++; /* addrmap3.addrmap_col_b7 */ - val = (reg & GENMASK(11, 8)) >> 8; + val = (reg & GENMASK(12, 8)) >> 8; if (val <= 7) bits++; /* addrmap3.addrmap_col_b8 */ - val = (reg & GENMASK(19, 16)) >> 16; + val = (reg & GENMASK(20, 16)) >> 16; if (val <= 7) bits++; /* addrmap3.addrmap_col_b9 */ - val = (reg & GENMASK(27, 24)) >> 24; + val = (reg & GENMASK(28, 24)) >> 24; if (val <= 7) bits++;
reg = readl(&ctl->addrmap4); /* addrmap4.addrmap_col_b10 */ - val = (reg & GENMASK(3, 0)) >> 0; + val = (reg & GENMASK(4, 0)) >> 0; if (val <= 7) bits++; /* addrmap4.addrmap_col_b11 */ - val = (reg & GENMASK(11, 8)) >> 8; + val = (reg & GENMASK(12, 8)) >> 8; if (val <= 7) bits++;
@@ -296,21 +296,24 @@ static u8 get_nb_row(struct stm32mp1_ddrctl *ctl) reg = readl(&ctl->addrmap6); /* addrmap6.addrmap_row_b12 */ val = (reg & GENMASK(3, 0)) >> 0; - if (val <= 7) + if (val <= 11) bits++; /* addrmap6.addrmap_row_b13 */ val = (reg & GENMASK(11, 8)) >> 8; - if (val <= 7) + if (val <= 11) bits++; /* addrmap6.addrmap_row_b14 */ val = (reg & GENMASK(19, 16)) >> 16; - if (val <= 7) + if (val <= 11) bits++; /* addrmap6.addrmap_row_b15 */ val = (reg & GENMASK(27, 24)) >> 24; - if (val <= 7) + if (val <= 11) bits++;
+ if (reg & BIT(31)) + printf("warning: LPDDR3_6GB_12GB is not supported\n"); + return bits; }
@@ -392,12 +395,17 @@ static struct ram_ops stm32mp1_ddr_ops = { .get_info = stm32mp1_ddr_get_info, };
+static const struct stm32mp1_ddr_cfg stm32mp13x_ddr_cfg = { + .nb_bytes = 2, +}; + static const struct stm32mp1_ddr_cfg stm32mp15x_ddr_cfg = { .nb_bytes = 4, };
static const struct udevice_id stm32mp1_ddr_ids[] = { { .compatible = "st,stm32mp1-ddr", .data = (ulong)&stm32mp15x_ddr_cfg}, + { .compatible = "st,stm32mp13-ddr", .data = (ulong)&stm32mp13x_ddr_cfg}, { } };
HI Patrick
- only one AXI port
info attributes:
- for STM32MP15x and STM32MP13x: 25 values are requested in this order MSTR MRCTRL0 MRCTRL1
- for STM32MP15x and STM32MP13x: 12 values are requested in this order RFSHTMG DRAMTMG0 DRAMTMG1
- for STM32MP15x and STM32MP13x: 9 values are requested in this order ADDRMAP1 ADDRMAP2 ADDRMAP3
- for STM32MP13x: 11 values are requested in this order
SCHED
SCHED1
PERFHPR1
PERFLPR1
PERFWR1
PCFGR_0
PCFGW_0
PCFGQOS0_0
PCFGQOS1_0
PCFGWQOS0_0
PCFGWQOS1_0
phyc attributes:
- for STM32MP13x: 9 values are requested in this order
PGCR
ACIOCR
DXCCR
DSGCR
DCR
ODTCR
ZQ0CR1
DX0GCR
DX1GCR
- for STM32MP15x and STM32MP13x: 10 values are requested in this order PTR0 PTR1 PTR2
- for STM32MP13x: 6 values are requested in this order
DX0DLLCR
DX0DQTR
DX0DQSTR
DX1DLLCR
DX1DQTR
DX1DQSTR
Example:
/ { soc {
u-boot,dm-spl;
u-boot,dm-spl;
compatible = "st,stm32mp1-ddr"; reg = <0x5A003000 0x550
- val = (reg & GENMASK(4, 0)) >> 0; if (val <= 7) bits++; /* addrmap3.addrmap_col_b7 */
- val = (reg & GENMASK(12, 8)) >> 8; if (val <= 7) bits++; /* addrmap3.addrmap_col_b8 */
- val = (reg & GENMASK(20, 16)) >> 16; if (val <= 7) bits++; /* addrmap3.addrmap_col_b9 */
- val = (reg & GENMASK(4, 0)) >> 0; if (val <= 7) bits++; /* addrmap4.addrmap_col_b11 */
- if (val <= 7)
- if (val <= 11) bits++; /* addrmap6.addrmap_row_b13 */ val = (reg & GENMASK(11, 8)) >> 8;
- if (val <= 7)
- if (val <= 11) bits++; /* addrmap6.addrmap_row_b14 */ val = (reg & GENMASK(19, 16)) >> 16;
- if (val <= 7)
- if (val <= 11) bits++; /* addrmap6.addrmap_row_b15 */ val = (reg & GENMASK(27, 24)) >> 24;
- if (val <= 7)
if (reg & BIT(31))
return bits;
- .nb_bytes = 2,
- { .compatible = "st,stm32mp13-ddr", .data = (ulong)&stm32mp13x_ddr_cfg}, { }
Thanks Patrice
- only one AXI port
Regards Patrick
Although not recommended, the reset property could be made optional. This way the driver will probe even if no reset property is provided in an sdmmc node in DT. This reset is already optional in Linux.
Signed-off-by: Yann Gautier yann.gautier@foss.st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
drivers/mmc/stm32_sdmmc2.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/stm32_sdmmc2.c b/drivers/mmc/stm32_sdmmc2.c index 44bfc911af..81b07609a9 100644 --- a/drivers/mmc/stm32_sdmmc2.c +++ b/drivers/mmc/stm32_sdmmc2.c @@ -514,10 +514,12 @@ retry_cmd: */ static void stm32_sdmmc2_reset(struct stm32_sdmmc2_priv *priv) { - /* Reset */ - reset_assert(&priv->reset_ctl); - udelay(2); - reset_deassert(&priv->reset_ctl); + if (reset_valid(&priv->reset_ctl)) { + /* Reset */ + reset_assert(&priv->reset_ctl); + udelay(2); + reset_deassert(&priv->reset_ctl); + }
/* init the needed SDMMC register after reset */ writel(priv->pwr_reg_msk, priv->base + SDMMC_POWER); @@ -735,7 +737,7 @@ static int stm32_sdmmc2_probe(struct udevice *dev)
ret = reset_get_by_index(dev, 0, &priv->reset_ctl); if (ret) - goto clk_disable; + dev_dbg(dev, "No reset provided\n");
gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); @@ -755,8 +757,6 @@ static int stm32_sdmmc2_probe(struct udevice *dev) stm32_sdmmc2_reset(priv); return 0;
-clk_disable: - clk_disable(&priv->clk); clk_free: clk_free(&priv->clk);
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- /* Reset */
- udelay(2);
/* Reset */
udelay(2);
goto clk_disable;
-clk_disable:
Hi Patrick
- /* Reset */
- udelay(2);
/* Reset */
udelay(2);
goto clk_disable;
-clk_disable:
Thanks Patrice
Regards Patrick
Compile the device tree of STM32MP13x boards and add the needed U-Boot add-on.
arch/arm/dts/Makefile | 3 + arch/arm/dts/stm32mp13-u-boot.dtsi | 91 +++++++++++++++++++++++++ arch/arm/dts/stm32mp135f-dk-u-boot.dtsi | 30 ++++++++ 3 files changed, 124 insertions(+) create mode 100644 arch/arm/dts/stm32mp13-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp135f-dk-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1032ce4c85..ba2987197c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1135,6 +1135,9 @@ dtb-$(CONFIG_ASPEED_AST2600) += ast2600-evb.dtb
dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb
+dtb-$(CONFIG_STM32MP13x) += \ + stm32mp135f-dk.dtb + dtb-$(CONFIG_STM32MP15x) += \ stm32mp157a-dk1.dtb \ stm32mp157a-icore-stm32mp1-ctouch2.dtb \ diff --git a/arch/arm/dts/stm32mp13-u-boot.dtsi b/arch/arm/dts/stm32mp13-u-boot.dtsi new file mode 100644 index 0000000000..1b5b358690 --- /dev/null +++ b/arch/arm/dts/stm32mp13-u-boot.dtsi @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (C) 2022, STMicroelectronics - All Rights Reserved + */ + +/ { + aliases { + gpio0 = &gpioa; + gpio1 = &gpiob; + gpio2 = &gpioc; + gpio3 = &gpiod; + gpio4 = &gpioe; + gpio5 = &gpiof; + gpio6 = &gpiog; + gpio7 = &gpioh; + gpio8 = &gpioi; + pinctrl0 = &pinctrl; + }; + + /* need PSCI for sysreset during board_f */ + psci { + u-boot,dm-pre-proper; + }; + + soc { + u-boot,dm-pre-reloc; + + ddr: ddr@5a003000 { + u-boot,dm-pre-reloc; + + compatible = "st,stm32mp13-ddr"; + + reg = <0x5A003000 0x550 + 0x5A004000 0x234>; + + status = "okay"; + }; + }; +}; + +&bsec { + u-boot,dm-pre-reloc; +}; + +&gpioa { + u-boot,dm-pre-reloc; +}; + +&gpiob { + u-boot,dm-pre-reloc; +}; + +&gpioc { + u-boot,dm-pre-reloc; +}; + +&gpiod { + u-boot,dm-pre-reloc; +}; + +&gpioe { + u-boot,dm-pre-reloc; +}; + +&gpiof { + u-boot,dm-pre-reloc; +}; + +&gpiog { + u-boot,dm-pre-reloc; +}; + +&gpioh { + u-boot,dm-pre-reloc; +}; + +&gpioi { + u-boot,dm-pre-reloc; +}; + +&iwdg2 { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&syscfg { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/stm32mp135f-dk-u-boot.dtsi b/arch/arm/dts/stm32mp135f-dk-u-boot.dtsi new file mode 100644 index 0000000000..dfe5bbb2e3 --- /dev/null +++ b/arch/arm/dts/stm32mp135f-dk-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (C) 2022, STMicroelectronics - All Rights Reserved + */ + +#include "stm32mp13-u-boot.dtsi" + +/ { + aliases { + mmc0 = &sdmmc1; + }; + + config { + u-boot,mmc-env-partition = "u-boot-env"; + }; +}; + +&uart4 { + u-boot,dm-pre-reloc; +}; + +&uart4_pins_a { + u-boot,dm-pre-reloc; + pins1 { + u-boot,dm-pre-reloc; + }; + pins2 { + u-boot,dm-pre-reloc; + }; +};
HI Patrick
- stm32mp135f-dk.dtb
- aliases {
gpio0 = &gpioa;
gpio1 = &gpiob;
gpio2 = &gpioc;
gpio3 = &gpiod;
gpio4 = &gpioe;
gpio5 = &gpiof;
gpio6 = &gpiog;
gpio7 = &gpioh;
gpio8 = &gpioi;
- /* need PSCI for sysreset during board_f */
- psci {
- soc {
ddr: ddr@5a003000 {
0x5A004000 0x234>;
status = "okay";
+&bsec {
+&gpioa {
+&gpiob {
+&gpioc {
+&gpiod {
+&gpioe {
+&gpiof {
+&gpiog {
+&gpioh {
+&gpioi {
+&iwdg2 {
+&pinctrl {
+&syscfg {
- aliases {
mmc0 = &sdmmc1;
- config {
+&uart4 {
+&uart4_pins_a {
- pins1 {
- pins2 {
Thanks Patrice
Regards Patrick
Add a initial config for STM32M13x SOC family, using the stm32mp135f-dk device tree.
board/st/stm32mp1/MAINTAINERS | 1 + configs/stm32mp13_defconfig | 54 +++++++++++++++++++++++++++++++++++ 2 files changed, 55 insertions(+) create mode 100644 configs/stm32mp13_defconfig
diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index c9252e90f4..d5a09cdc39 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -6,6 +6,7 @@ S: Maintained F: arch/arm/dts/stm32mp13* F: arch/arm/dts/stm32mp15* F: board/st/stm32mp1/ +F: configs/stm32mp13_defconfig F: configs/stm32mp15_defconfig F: configs/stm32mp15_basic_defconfig F: configs/stm32mp15_trusted_defconfig diff --git a/configs/stm32mp13_defconfig b/configs/stm32mp13_defconfig new file mode 100644 index 0000000000..877c020b4a --- /dev/null +++ b/configs/stm32mp13_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32MP=y +CONFIG_TFABOOT=y +CONFIG_SYS_MALLOC_F_LEN=0x180000 +CONFIG_ENV_OFFSET=0x900000 +CONFIG_DEFAULT_DEVICE_TREE="stm32mp135f-dk" +CONFIG_STM32MP13x=y +CONFIG_DDR_CACHEABLE_SIZE=0x10000000 +CONFIG_TARGET_ST_STM32MP13x=y +CONFIG_ENV_OFFSET_REDUND=0x940000 +# CONFIG_ARMV7_NONSEC is not set +CONFIG_SYS_LOAD_ADDR=0xc2000000 +CONFIG_SYS_MEMTEST_START=0xc0000000 +CONFIG_SYS_MEMTEST_END=0xc4000000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_BOOTDELAY=1 +CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" +CONFIG_SYS_PROMPT="STM32MP> " +CONFIG_CMD_ADTIMG=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_LOG=y +CONFIG_OF_LIVE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=-1 +CONFIG_CLK_SCMI=y +CONFIG_STM32_SDMMC2=y +CONFIG_DM_ETH=y +CONFIG_PINCONF=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_SCMI=y +CONFIG_RESET_SCMI=y +CONFIG_SERIAL_RX_BUFFER=y +CONFIG_SYSRESET_PSCI=y +CONFIG_TEE=y +CONFIG_OPTEE=y +# CONFIG_OPTEE_TA_AVB is not set +CONFIG_ERRNO_STR=y +# CONFIG_LMB_USE_MAX_REGIONS is not set +CONFIG_LMB_MEMORY_REGIONS=2 +CONFIG_LMB_RESERVED_REGIONS=16
Hi Patrick
Thanks Patrice
Hi
some adaptation for Kconfig migration in next branch
with +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc0400000
Regards Patrick
Add in U-Boot documentation the quick instruction for setup the STMicroelectronics STM32MP13x boards.
doc/board/st/stm32mp1.rst | 181 ++++++++++++++++++++++++++------------ 1 file changed, 125 insertions(+), 56 deletions(-)
diff --git a/doc/board/st/stm32mp1.rst b/doc/board/st/stm32mp1.rst index 0c5d3a90f0..25d38d337a 100644 --- a/doc/board/st/stm32mp1.rst +++ b/doc/board/st/stm32mp1.rst @@ -1,41 +1,31 @@ .. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause .. sectionauthor:: Patrick Delaunay patrick.delaunay@foss.st.com
-STM32MP15x boards +STM32MP1xx boards =================
-This is a quick instruction for setup STM32MP15x boards. +This is a quick instruction for setup STMicroelectronics STM32MP1xx boards.
Futher information can be found in STMicrolectronics STM32 WIKI_.
Supported devices -----------------
-U-Boot supports STMP32MP15x SoCs: +U-Boot supports all the STMicroelectronics MPU with the associated boards
- - STM32MP157 - - STM32MP153 - - STM32MP151 + - STMP32MP15x SoCs:
-The STM32MP15x is a Cortex-A MPU aimed at various applications. + - STM32MP157 + - STM32MP153 + - STM32MP151
-It features: - - - Dual core Cortex-A7 application core (Single on STM32MP151) - - 2D/3D image composition with GPU (only on STM32MP157) - - Standard memories interface support - - Standard connectivity, widely inherited from the STM32 MCU family - - Comprehensive security support + - STMP32MP13x SoCs:
-Each line comes with a security option (cryptography & secure boot) and -a Cortex-A frequency option: - - - A : Cortex-A7 @ 650 MHz - - C : Secure Boot + HW Crypto + Cortex-A7 @ 650 MHz - - D : Cortex-A7 @ 800 MHz - - F : Secure Boot + HW Crypto + Cortex-A7 @ 800 MHz + - STM32MP135 + - STM32MP133 + - STM32MP131
-Everything is supported in Linux but U-Boot is limited to: +Everything is supported in Linux but U-Boot is limited to the boot device:
1. UART 2. SD card/MMC controller (SDMMC) @@ -49,7 +39,35 @@ And the necessary drivers 1. I2C 2. STPMIC1 (PMIC and regulator) 3. Clock, Reset, Sysreset - 4. Fuse + 4. Fuse (BSEC) + 5. OP-TEE + 6. ETH + 7. USB host + 8. WATCHDOG + 9. RNG + 10. RTC + +STM32MP15x +`````````` + +The STM32MP15x is a Cortex-A7 MPU aimed at various applications. + +It features: + + - Dual core Cortex-A7 application core (Single on STM32MP151) + - 2D/3D image composition with GPU (only on STM32MP157) + - Standard memories interface support + - Standard connectivity, widely inherited from the STM32 MCU family + - Comprehensive security support + - Cortex M4 coprocessor + +Each line comes with a security option (cryptography & secure boot) and +a Cortex-A frequency option: + + - A : Cortex-A7 @ 650 MHz + - C : Secure Boot + HW Crypto + Cortex-A7 @ 650 MHz + - D : Cortex-A7 @ 800 MHz + - F : Secure Boot + HW Crypto + Cortex-A7 @ 800 MHz
Currently the following boards are supported:
@@ -59,6 +77,16 @@ Currently the following boards are supported: + stm32mp157c-ev1.dts + stm32mp15xx-dhcor-avenger96.dts
+STM32MP13x +`````````` + +The STM32MP13x is a single Cortex-A7 MPU aimed at various applications. + +Currently the following boards are supported: + + + stm32mp135f-dk.dts + + Boot Sequences --------------
@@ -71,12 +99,22 @@ Boot Sequences + +------------------------+-------------------------+--------------+ | | embedded RAM | DDR | +----------+------------------------+-------------------------+--------------+ +| TrustZone| secure monitor | ++----------+------------------------+-------------------------+--------------+ + +The trusted boot chain is recommended with: + +- FSBL = **TF-A BL2** +- Secure monitor = **OP-TEE** +- SSBL = **U-Boot** + +It is the only supported boot chain for STM32MP13x family.
The **Trusted** boot chain with TF-A_ `````````````````````````````````````
defconfig_file : - + **stm32mp15_defconfig** (for TF-A_ with FIP support) + + **stm32mp15_defconfig** and **stm32mp13_defconfig** (for TF-A_ with FIP support) + **stm32mp15_trusted_defconfig** (for TF-A_ without FIP support)
+-------------+--------------------------+------------+-------+ @@ -98,8 +136,8 @@ TF-A_ (BL2) initialize the DDR and loads the next stage binaries from a FIP file the secure monitor to access to secure resources. + HW_CONFIG: The hardware configuration file = the U-Boot device tree
-The **Basic** boot chain with SPL -````````````````````````````````` +The **Basic** boot chain with SPL (for STM32MP15x) +``````````````````````````````````````````````````
defconfig_file : + **stm32mp15_basic_defconfig** @@ -117,16 +155,19 @@ SPL has limited security initialization. U-Boot is running in secure mode and provide a secure monitor to the kernel with only PSCI support (Power State Coordination Interface defined by ARM).
-All the STM32MP15x boards supported by U-Boot use the same generic board -stm32mp1 which support all the bootable devices. +.. warning:: This alternate **basic** boot chain with SPL is not supported/promoted by STMicroelectronics to make product. + +Device Tree +-----------
-Each board is configured only with the associated device tree. +All the STM32MP15x and STM32MP13x boards supported by U-Boot use the same generic board +stm32mp1 which supports all the bootable devices.
-Device Tree Selection ---------------------- +Each STMicroelectronics board is only configured with the associated device tree.
-You need to select the appropriate device tree for your board, -the supported device trees for STM32MP15x are: +STM32MP15x device Tree Selection +```````````````````````````````` +The supported device trees for STM32MP15x (stm32mp15_trusted_defconfig and stm32mp15_basic_defconfig) are:
+ ev1: eval board with pmic stpmic1 (ev1 = mother board + daughter ed1)
@@ -148,6 +189,15 @@ the supported device trees for STM32MP15x are:
+STM32MP13x device Tree Selection +```````````````````````````````` +The supported device trees for STM32MP13x (stm32mp13_defconfig) are: + ++ dk: Discovery board + + + stm32mp135f-dk + + Build Procedure ---------------
@@ -170,6 +220,7 @@ Build Procedure
for example: use one output directory for each configuration::
+ # export KBUILD_OUTPUT=stm32mp13 # export KBUILD_OUTPUT=stm32mp15 # export KBUILD_OUTPUT=stm32mp15_trusted # export KBUILD_OUTPUT=stm32mp15_basic @@ -184,9 +235,10 @@ Build Procedure
with <defconfig_file>:
- - For **trusted** boot mode : **stm32mp15_defconfig** or - stm32mp15_trusted_defconfig - - For basic boot mode: stm32mp15_basic_defconfig + - For **trusted** boot mode : + - For STM32MP13x: **stm32mp13_defconfig** + - For STM32MP15x: **stm32mp15_defconfig** or stm32mp15_trusted_defconfig + - For STM32MP15x basic boot mode: stm32mp15_basic_defconfig
5. Configure the device-tree and build the U-Boot image::
@@ -194,37 +246,42 @@ Build Procedure
Examples:
- a) trusted boot with FIP on ev1:: + a) trusted boot with FIP on STM32MP15x ev1::
# export KBUILD_OUTPUT=stm32mp15 # make stm32mp15_defconfig # make DEVICE_TREE=stm32mp157c-ev1 all
- b) trusted boot without FIP on dk2:: + b) trusted boot on STM32MP13x discovery board::
- # export KBUILD_OUTPUT=stm32mp15_trusted - # make stm32mp15_trusted_defconfig - # make DEVICE_TREE=stm32mp157c-dk2 all + # export KBUILD_OUTPUT=stm32mp13 + # make stm32mp13_defconfig + # make DEVICE_TREE=stm32mp135f-dk all
- c) basic boot on ev1:: + DEVICE_TEE selection is optional as stm32mp135f-dk is the default board of the defconfig:: + + # make stm32mp13_defconfig + # make all + + c) basic boot on STM32MP15x ev1::
# export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157c-ev1 all
- d) basic boot on ed1:: + d) basic boot on STM32MP15x ed1::
# export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157c-ed1 all
- e) basic boot on dk1:: + e) basic boot on STM32MP15x dk1::
# export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157a-dk1 all
- f) basic boot on avenger96:: + f) basic boot on STM32MP15x avenger96::
# export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig @@ -235,6 +292,7 @@ Build Procedure So in the output directory (selected by KBUILD_OUTPUT), you can found the needed U-Boot files:
+ - stm32mp13_defconfig = **u-boot-nodtb.bin** and **u-boot.dtb** - stm32mp15_defconfig = **u-boot-nodtb.bin** and **u-boot.dtb**
- stm32mp15_trusted_defconfig = u-boot.stm32 @@ -325,9 +383,9 @@ the boot pin values = BOOT0, BOOT1, BOOT2 | SPI-NAND | 1 | 1 | 1 | +-------------+---------+---------+---------+
-- on the **daugther board ed1 = MB1263** with the switch SW1 -- on **Avenger96** with switch S3 (NOR and SPI-NAND are not applicable) -- on board **DK1/DK2** with the switch SW1 = BOOT0, BOOT2 +- on the STM32MP15x **daugther board ed1 = MB1263** with the switch SW1 +- on STM32MP15x **Avenger96** with switch S3 (NOR and SPI-NAND are not applicable) +- on board STM32MP15x **DK1/DK2** with the switch SW1 = BOOT0, BOOT2 with only 2 pins available (BOOT1 is forced to 0 and NOR not supported), the possible value becomes:
@@ -355,7 +413,7 @@ The communication between HOST and board is based on Prepare an SD card ------------------
-The minimal requirements for STMP32MP15x boot up to U-Boot are: +The minimal requirements for STMP32MP15x and STM32MP13x boot up to U-Boot are:
- GPT partitioning (with gdisk or with sgdisk) - 2 fsbl partitions, named "fsbl1" and "fsbl2", size at least 256KiB @@ -511,14 +569,25 @@ MAC Address Please read doc/README.enetaddr for the implementation guidelines for mac id usage. Basically, environment has precedence over board specific storage.
-For STMicroelectonics board, it is retrieved in STM32MP15x OTP : +For STMicroelectonics board, it is retrieved in: + + - STM32MP15x OTP:
- - OTP_57[31:0] = MAC_ADDR[31:0] - - OTP_58[15:0] = MAC_ADDR[47:32] + - OTP_57[31:0] = MAC_ADDR[31:0] + - OTP_58[15:0] = MAC_ADDR[47:32]
-To program a MAC address on virgin OTP words above, you can use the fuse command + - STM32MP13x OTP: + + - OTP_57[31:0] = MAC_ADDR0[31:0] + - OTP_58[15:0] = MAC_ADDR0[47:32] + - OTP_58[31:16] = MAC_ADDR1[15:0] + - OTP_59[31:0] = MAC_ADDR1[47:16] + +To program a MAC address on virgin STM32MP15x OTP words above, you can use the fuse command on bank 0 to access to internal OTP and lock them:
+In the next example we are using the 2 OTPs used on STM32MP15x. + Prerequisite: check if a MAC address isn't yet programmed in OTP
1) check OTP: their value must be equal to 0:: @@ -571,8 +640,8 @@ Example to set mac address "12:34:56:78:9a:bc" OTP are protected. It is already done for the board provided by STMicroelectronics.
-Coprocessor firmware --------------------- +Coprocessor firmware on STM32MP15x +----------------------------------
U-Boot can boot the coprocessor before the kernel (coprocessor early boot).
@@ -678,7 +747,7 @@ All the supported device are exported for dfu-util tool::
You can update the boot device:
-- SD card (mmc0) :: +- SD card (mmc0)::
$> dfu-util -d 0483:5720 -a 3 -D tf-a-stm32mp157c-ev1.stm32 $> dfu-util -d 0483:5720 -a 4 -D tf-a-stm32mp157c-ev1.stm32
Hi PAtrick
typos below
s/for/to
-STM32MP15x boards
+STM32MP1xx boards
s/Futher/Further
Supported devices
- STM32MP157
- STM32MP153
- STM32MP151
- STMP32MP15x SoCs:
- STM32MP157
- STM32MP153
- STM32MP151
-It features:
- STMP32MP13x SoCs:
- STM32MP135
- STM32MP133
- STM32MP131
- UART
- SD card/MMC controller (SDMMC)
- I2C
- STPMIC1 (PMIC and regulator)
- Clock, Reset, Sysreset
- Fuse
- Fuse (BSEC)
- OP-TEE
- ETH
- USB host
- WATCHDOG
- RNG
- RTC
+It features:
s/coprocessor/co-processor
- stm32mp157c-ev1.dts
- stm32mp15xx-dhcor-avenger96.dts
- stm32mp135f-dk.dts
Boot Sequences
defconfig_file : - + **stm32mp15_defconfig** (for TF-A_ with FIP support) + + **stm32mp15_defconfig** and **stm32mp13_defconfig** (for TF-A_ with FIP support) + **stm32mp15_trusted_defconfig** (for TF-A_ without FIP support) +-------------+--------------------------+------------+-------+ @@ -98,8 +136,8 @@ TF-A_ (BL2) initialize the DDR and loads the next stage binaries from a FIP file the secure monitor to access to secure resources. + HW_CONFIG: The hardware configuration file = the U-Boot device tree -The **Basic** boot chain with SPL -````````````````````````````````` +The **Basic** boot chain with SPL (for STM32MP15x) +`````````````````````````````````````````````````` defconfig_file : + **stm32mp15_basic_defconfig** @@ -117,16 +155,19 @@ SPL has limited security initialization. U-Boot is running in secure mode and provide a secure monitor to the kernel with only PSCI support (Power State Coordination Interface defined by ARM). -All the STM32MP15x boards supported by U-Boot use the same generic board -stm32mp1 which support all the bootable devices. +.. warning:: This alternate **basic** boot chain with SPL is not supported/promoted by STMicroelectronics to make product. + +Device Tree +----------- -Each board is configured only with the associated device tree. +All the STM32MP15x and STM32MP13x boards supported by U-Boot use the same generic board +stm32mp1 which supports all the bootable devices. -Device Tree Selection ---------------------- +Each STMicroelectronics board is only configured with the associated device tree. -You need to select the appropriate device tree for your board, -the supported device trees for STM32MP15x are: +STM32MP15x device Tree Selection +```````````````````````````````` +The supported device trees for STM32MP15x (stm32mp15_trusted_defconfig and stm32mp15_basic_defconfig) are: + ev1: eval board with pmic stpmic1 (ev1 = mother board + daughter ed1) @@ -148,6 +189,15 @@ the supported device trees for STM32MP15x are: + stm32mp15xx-dhcor-avenger96 +STM32MP13x device Tree Selection +```````````````````````````````` +The supported device trees for STM32MP13x (stm32mp13_defconfig) are: + ++ dk: Discovery board + + + stm32mp135f-dk + + Build Procedure --------------- @@ -170,6 +220,7 @@ Build Procedure for example: use one output directory for each configuration:: + # export KBUILD_OUTPUT=stm32mp13 # export KBUILD_OUTPUT=stm32mp15 # export KBUILD_OUTPUT=stm32mp15_trusted # export KBUILD_OUTPUT=stm32mp15_basic @@ -184,9 +235,10 @@ Build Procedure with <defconfig_file>: - - For **trusted** boot mode : **stm32mp15_defconfig** or - stm32mp15_trusted_defconfig - - For basic boot mode: stm32mp15_basic_defconfig + - For **trusted** boot mode : + - For STM32MP13x: **stm32mp13_defconfig** + - For STM32MP15x: **stm32mp15_defconfig** or stm32mp15_trusted_defconfig + - For STM32MP15x basic boot mode: stm32mp15_basic_defconfig 5. Configure the device-tree and build the U-Boot image:: @@ -194,37 +246,42 @@ Build Procedure Examples: - a) trusted boot with FIP on ev1:: + a) trusted boot with FIP on STM32MP15x ev1:: # export KBUILD_OUTPUT=stm32mp15 # make stm32mp15_defconfig # make DEVICE_TREE=stm32mp157c-ev1 all - b) trusted boot without FIP on dk2:: + b) trusted boot on STM32MP13x discovery board:: - # export KBUILD_OUTPUT=stm32mp15_trusted - # make stm32mp15_trusted_defconfig - # make DEVICE_TREE=stm32mp157c-dk2 all + # export KBUILD_OUTPUT=stm32mp13 + # make stm32mp13_defconfig + # make DEVICE_TREE=stm32mp135f-dk all - c) basic boot on ev1:: + DEVICE_TEE selection is optional as stm32mp135f-dk is the default board of the defconfig:: + + # make stm32mp13_defconfig + # make all + + c) basic boot on STM32MP15x ev1:: # export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157c-ev1 all - d) basic boot on ed1:: + d) basic boot on STM32MP15x ed1:: # export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157c-ed1 all - e) basic boot on dk1:: + e) basic boot on STM32MP15x dk1:: # export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig # make DEVICE_TREE=stm32mp157a-dk1 all - f) basic boot on avenger96:: + f) basic boot on STM32MP15x avenger96:: # export KBUILD_OUTPUT=stm32mp15_basic # make stm32mp15_basic_defconfig @@ -235,6 +292,7 @@ Build Procedure So in the output directory (selected by KBUILD_OUTPUT), you can found the needed U-Boot files: + - stm32mp13_defconfig = **u-boot-nodtb.bin** and **u-boot.dtb** - stm32mp15_defconfig = **u-boot-nodtb.bin** and **u-boot.dtb** - stm32mp15_trusted_defconfig = u-boot.stm32 @@ -325,9 +383,9 @@ the boot pin values = BOOT0, BOOT1, BOOT2 | SPI-NAND | 1 | 1 | 1 | +-------------+---------+---------+---------+ -- on the **daugther board ed1 = MB1263** with the switch SW1 -- on **Avenger96** with switch S3 (NOR and SPI-NAND are not applicable) -- on board **DK1/DK2** with the switch SW1 = BOOT0, BOOT2 +- on the STM32MP15x **daugther board ed1 = MB1263** with the switch SW1
s/daugther/daughter
- STM32MP15x OTP:
- STM32MP13x OTP:
- check OTP: their value must be equal to 0::
s/Coprocessor/Co-processor
On 5/20/22 09:21, Patrice CHOTARD wrote:
Hi PAtrick
typos below
s/for/to
ok
-STM32MP15x boards
+STM32MP1xx boards
s/Futher/Further
ok
Supported devices
- STM32MP157
- STM32MP153
- STM32MP151
+It features:
coprocessor is good for me:
https://en.wikipedia.org/wiki/Coprocessor
it is also used in ST Wiki
https://wiki.st.com/stm32mpu/wiki/Category:Coprocessor_management_Linux
s/daugther/daughter
ok
OK
- STM32MP15x OTP:
- STM32MP13x OTP:
Same
Same
Regards
Patrick
Regards Patrick
participants (5)
Jaehoon Chung
Patrice CHOTARD
Patrick DELAUNAY
Patrick Delaunay
