[U-Boot] [PATCH] arm: socfpga: stratix10: Enable EMAC to FPGA bridge based on handoff
Code checking and setting EMAC use fpga is in populate_sysmgr_fpgaintf_module(). So, call to sysmgr_pinmux_init() instead of populate_sysmgr_pinmux(). In sysmgr_pinmux_init(), it will call to both populate_sysmgr_pinmux() and populate_sysmgr_fpgaintf_module().
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/spl_s10.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index 69d6e91..cc5dc4f 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -136,7 +136,7 @@ void board_init_f(ulong dummy) socfpga_per_reset(SOCFPGA_RESET(OSC1TIMER0), 0); timer_init();
- populate_sysmgr_pinmux(); + sysmgr_pinmux_init();
/* configuring the HPS clocks */ cm_basic_init(cm_default_cfg);
According to mailbox spec, software should send urgent command with urgent register instead of COUT location. This patch write urgent command index to urgent register.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/mailbox_s10.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index cccd1a4..0d906c3 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -160,15 +160,15 @@ static __always_inline int mbox_send_cmd_common(u8 id, u32 cmd, u8 is_indirect, u32 buf_len; int ret;
- ret = mbox_prepare_cmd_only(id, cmd, is_indirect, len, arg); - if (ret) - return ret; - if (urgent) { /* Read status because it is toggled */ status = MBOX_READL(MBOX_STATUS) & MBOX_STATUS_UA_MSK; - /* Send command as urgent command */ - MBOX_WRITEL(1, MBOX_URG); + /* Write urgent command to urgent register */ + MBOX_WRITEL(cmd, MBOX_URG); + } else { + ret = mbox_prepare_cmd_only(id, cmd, is_indirect, len, arg); + if (ret) + return ret; }
/* write doorbell */ @@ -188,8 +188,7 @@ static __always_inline int mbox_send_cmd_common(u8 id, u32 cmd, u8 is_indirect,
if (urgent) { u32 new_status = MBOX_READL(MBOX_STATUS); - /* urgent command doesn't have response */ - MBOX_WRITEL(0, MBOX_URG); + /* Urgent ACK is toggled */ if ((new_status & MBOX_STATUS_UA_MSK) ^ status) return 0;
- if (ret)
return ret;
} else {
if (ret)
return ret;
Applied, thanks.
Applied, thanks.
Ley Foon Tan
