[U-Boot] [GIT PULL] Pull request: u-boot-imx u-boot-imx-20190923
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 87d5b225585f341ea8e926a2c26fb72585fc9d0c:
MAINTAINERS: Change fsl-qoriq, mpc86xx, mpc85xx maintainers (2019-09-13 10:14:45 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20190923
for you to fetch changes up to 322a967cdf470640cb8cb6b68b6721e63b8c3104:
Merge branch 'for-imx' of https://github.com/OSSystems/u-boot (2019-09-22 15:19:49 +0200)
---------------------------------------------------------------- u-boot-imx-20190923 -------------------
- Fixes i.MX7ULP - No default CSF size in case of SECURE_BOOT - Technexion boards - Nitrogen boards ported to DM - fix for mx53loco - Sync DTS for i.MX6UL(L) - Fuses for i.MX7ULP - i.mx8 : container image, fixes - Fixes for Toradex (apalis) - SPL: allow bigger size for i.MX6Q/D
Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/588095906
---------------------------------------------------------------- Anatolij Gustschin (1): imx: sksimx6_defconfig: remove SPL misc option to fix build error
Bai Ping (2): i.MX7ULP: Fix system reset after a7 rtc alarm expired. i.MX7ULP: Correct the clock index
Breno Matheus Lima (4): Kconfig: Migrate CONFIG_CSF_SIZE to Kconfig imx6: spl: Reduce SPL limit size in case CONFIG_SECURE_BOOT is enabled imx: configs: Cleanup CONFIG_SECURE_BOOT comments habv4: tools: Avoid hardcoded CSF size for SPL targets
Fabio Berton (1): pico-imx7d: Sync pico-hobbit-imx7d_defconfig
Fabio Estevam (15): mx6sabresd: Reduce overall SPL size pico-imx6ul: Increase the CONFIG_ENV_OFFSET size pico-imx6ul: Add LCD support pico-imx6ul: Update the Falcon mode instructions pico-imx6ul: Provide a way to escape the Falcon mode pico-imx7d: Add instructions for booting in Falcon mode pico-imx7d: Provide a way to escape the Falcon mode logos: Add the TechNexion's logo pico: Convert to CONFIG_FSL_USDHC mx53loco: Fix U-Boot corruption after saving the environment mx6: clock: Allow enable_ipu_clock() to be built for SPL code pico-imx6: Add initial support pico-imx6: Add Ethernet support pico-imx6: Add splashscreen support pico-imx6: Add Falcon mode
Joris Offouga (3): ARM: dts: pico-imx7d: Add u-boot.dtsi for uboot specific dts change ARM: dts: pico-imx7d: sync device tree with v5.3-rc6 configs: pico-imx7d: Convert to DM_VIDEO
Otavio Salvador (5): pico-imx6ul: Add DWARF baseboard support pico-imx7d: Add DWARF baseboard support pico-imx7d: Add NYMPH baseboard support configs: Sync all baseboard specific pico-imx7d pico-imx6: Fix bootmenu handling
Peng Fan (39): arm: dts: sync dts for i.MX6UL arm: dts: sync dts for i.MX6ULL arm: dts: import dts for i.MX6ULZ imx: add i.MX6ULZ cpu type imx: add i.MX6ULZ board imx: mx6ul_14x14_evk: Fix SPL boot imx: mx6ul_14x14_evk: convert to DM_VIDEO imx: mx6slevk: enable DM_SPI and DM_SPI_FLASH pinctrl: imx: use devfdt_get_addr_size_index tools: imx8mimage: fix HDMI/FIT parsing serial: Kconfig: make MXC_UART usable for MX7 and IMX8M spl: pass args to board_return_to_bootrom arm: dts: imx: fsl-imx8qm.dtsi: add gpio aliases to fix gpio command imx: i.MX7ULP: add get_boot_device i.MX7ULP: evk: Modify FDT file to disable SD3.0 for usb boot misc: Kconfig: make i.MX7ULP could use MXC_OCOTP i.MX7ULP: evk: Enable fuse comamnd i.MX7ULP: Add CPU revision check for B0 imx: mx6sabresd: fix usb start when DM enabled imx: imx6qdl: dtsi: move U-Boot specific change to u-boot.dtsi imx: imx8qxp_mek: fix CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR imx8: support parsing i.MX8 Container file spl: mmc: support loading i.MX container format file imx: add container target imx8qxp_mek: switch to use container image imx8qm_mek: switch to use container image doc: imx: mkimage: introduce i.MX8 image format imx: sys_proto: add is_imx8qm helper imx8qm: power up SMMU imx8qm: correct fdt_file imx8: disable node when the resource is not owned configs: imx8qm/qxp_mek: enable CONFIG_OF_SYSTEM_SETUP imx: scu_api: add sc_rm_set_master_sid imx8: fdt: configure sid for masters imx8: save args passed from ATF imx8: fdt: add optee node imx: scu_api: add sc_pm_is_partition_started imx8: move i.MX8 cpu desc code to drivers/cpu/imx8_cpu.c imx8: cpu: fix mac fuse word for i.MX8QM
Ricardo Salveti (4): apalis_imx6: add board_fit_config_name_match to support FIT in SPL apalis_imx6: fix broken fsl_esdhc_imx conversion imx: apalis_imx6: select MX6Q via Kconfig spl: imx: only use HAB if spl fit signature is not enabled
Robert Hancock (1): ARM: imx: Support larger SPL size on IMX6DQ
Stefano Babic (5): Merge branch 'nxp-imx-8-13' of https://github.com/MrVan/u-boot into master-next Revert "habv4: tools: Avoid hardcoded CSF size for SPL targets" imx: fix missing MAINTAINERS pico boards board: imx6dl_mamoj: set the value for CSF size Merge branch 'for-imx' of https://github.com/OSSystems/u-boot
Troy Kisky (5): nitrogen6x: migrate to using device tree configs: nitrogen6x: Add DM_MMC/DM_USB/AHCI support nitrogen6x: reserve used gpios configs: nitrogen6x: Add DM_GPIO support configs: nitrogen6x: Add DM_SPI/DM_SPI_FLASH support
Ye Li (8): i.MX7ULP: Fix PCC register bits mask and offset issue i.MX7ULP: Add CONFIG_MX7ULP to kconfig i.MX7ULP: Fix wrong i2c configuration name i.MX7ULP: Fix SPLL/APLL clock rate calculation issue i.MX7ULP: Workaround APLL PFD2 to 345.6Mhz i.MX7ULP: Set A7 core frequency to 500Mhz for B0 chip i.MX7ULP: Change clock rate calculation for NIC1 BUS and EXT imx8: Probe the SCU driver by using uclass function
Makefile | 8 +++ arch/arm/cpu/arm926ejs/spear/spl.c | 5 +- arch/arm/dts/Makefile | 32 ++++++--- arch/arm/dts/fsl-imx8qm.dtsi | 7 ++ arch/arm/dts/imx6dl-nitrogen6x.dts | 15 +++++ arch/arm/dts/imx6dl-pico.dts | 17 +++++ arch/arm/dts/imx6q-nitrogen6x.dts | 19 ++++++ arch/arm/dts/imx6q-pico.dts | 17 +++++ arch/arm/dts/imx6q-sabrelite.dts | 19 ++++++ arch/arm/dts/imx6qdl-nitrogen6x.dtsi | 69 +++++++++++++++++++ arch/arm/dts/imx6qdl-pico.dtsi | 424 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl-sabrelite.dtsi | 384 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl-u-boot.dtsi | 6 ++ arch/arm/dts/imx6qdl.dtsi | 3 - arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 49 +++++++++++++- arch/arm/dts/imx6ul-14x14-evk.dts | 422 ++----------------------------------------------------------------------------------------------------------------- arch/arm/dts/imx6ul-14x14-evk.dtsi | 531 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-pinfunc.h | 175 +++++++++++++++++++++++++++--------------------- arch/arm/dts/imx6ul.dtsi | 301 ++++++++++++++++++++++++++++++++++++++++++++++++++++++---------------------------- arch/arm/dts/imx6ull-14x14-evk.dts | 523 ++-------------------------------------------------------------------------------------------------------------------------------------------- arch/arm/dts/imx6ull-pinfunc-snvs.h | 7 +- arch/arm/dts/imx6ull-pinfunc.h | 116 ++++++++++++++++++++------------ arch/arm/dts/imx6ull.dtsi | 1184 +++++++++++++-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- arch/arm/dts/imx6ulz-14x14-evk.dts | 22 ++++++ arch/arm/dts/imx6ulz.dtsi | 37 +++++++++++ arch/arm/dts/imx7d-pico-u-boot.dtsi | 124 ++++++++++++++++++++++++++++++++++ arch/arm/dts/imx7d-pico.dtsi | 10 +-- arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/arch-imx8/image.h | 56 ++++++++++++++++ arch/arm/include/asm/arch-imx8/sci/rpc.h | 5 +- arch/arm/include/asm/arch-imx8/sci/sci.h | 2 + arch/arm/include/asm/arch-imx8/sys_proto.h | 1 + arch/arm/include/asm/arch-mx7ulp/clock.h | 2 +- arch/arm/include/asm/arch-mx7ulp/imx-regs.h | 20 ++++++ arch/arm/include/asm/arch-mx7ulp/pcc.h | 4 +- arch/arm/include/asm/arch-mx7ulp/scg.h | 1 + arch/arm/include/asm/arch-mx7ulp/sys_proto.h | 1 + arch/arm/include/asm/mach-imx/sys_proto.h | 2 + arch/arm/mach-imx/Kconfig | 7 ++ arch/arm/mach-imx/Makefile | 14 +++- arch/arm/mach-imx/cpu.c | 2 + arch/arm/mach-imx/imx8/Kconfig | 13 ++++ arch/arm/mach-imx/imx8/Makefile | 7 +- arch/arm/mach-imx/imx8/cpu.c | 189 ++++------------------------------------------------ arch/arm/mach-imx/imx8/fdt.c | 292 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/imx8/lowlevel_init.S | 36 ++++++++++ arch/arm/mach-imx/imx8/parse-container.c | 120 +++++++++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 21 ++++++ arch/arm/mach-imx/mx6/clock.c | 32 ++++----- arch/arm/mach-imx/mx6/soc.c | 4 ++ arch/arm/mach-imx/mx7ulp/Kconfig | 6 +- arch/arm/mach-imx/mx7ulp/clock.c | 8 ++- arch/arm/mach-imx/mx7ulp/scg.c | 63 ++++++++++++++++-- arch/arm/mach-imx/mx7ulp/soc.c | 38 ++++++++++- arch/arm/mach-imx/spl.c | 2 + arch/arm/mach-rockchip/spl.c | 5 +- arch/arm/mach-rockchip/tpl.c | 5 +- board/boundary/nitrogen6x/MAINTAINERS | 5 ++ board/boundary/nitrogen6x/nitrogen6x.c | 30 ++++++++- board/freescale/imx8qm_mek/README | 4 +- board/freescale/imx8qm_mek/uboot-container.cfg | 13 ++++ board/freescale/imx8qxp_mek/README | 4 +- board/freescale/imx8qxp_mek/uboot-container.cfg | 13 ++++ board/freescale/mx6slevk/mx6slevk.c | 28 -------- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 73 ++++++-------------- board/freescale/mx6ullevk/MAINTAINERS | 1 + board/freescale/mx6ullevk/mx6ullevk.c | 10 ++- board/freescale/mx7ulp_evk/mx7ulp_evk.c | 47 +++++++++++++ board/technexion/pico-imx6/Kconfig | 15 +++++ board/technexion/pico-imx6/MAINTAINERS | 9 +++ board/technexion/pico-imx6/Makefile | 5 ++ board/technexion/pico-imx6/README | 73 ++++++++++++++++++++ board/technexion/pico-imx6/pico-imx6.c | 362 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/technexion/pico-imx6/spl.c | 314 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/technexion/pico-imx6ul/README | 8 +-- board/technexion/pico-imx6ul/pico-imx6ul.c | 55 ++++++++++++++- board/technexion/pico-imx6ul/spl.c | 4 ++ board/technexion/pico-imx7d/MAINTAINERS | 2 + board/technexion/pico-imx7d/README | 91 +++++++++++++++++++++++++ board/technexion/pico-imx7d/pico-imx7d.c | 48 +++++-------- board/technexion/pico-imx7d/spl.c | 4 ++ board/toradex/apalis_imx6/apalis_imx6.c | 14 +++- common/spl/Kconfig | 3 +- common/spl/spl_bootrom.c | 7 +- common/spl/spl_mmc.c | 10 +++ configs/imx6dl_mamoj_defconfig | 3 +- configs/imx8mq_evk_defconfig | 1 + configs/imx8qm_mek_defconfig | 9 ++- configs/imx8qxp_mek_defconfig | 6 +- configs/mx6qsabrelite_defconfig | 10 ++- configs/mx6sabresd_defconfig | 4 +- configs/mx6slevk_defconfig | 2 + configs/mx6slevk_spinor_defconfig | 2 + configs/mx6slevk_spl_defconfig | 2 + configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/mx6ulz_14x14_evk_defconfig | 44 ++++++++++++ configs/mx7ulp_evk_defconfig | 3 + configs/mx7ulp_evk_plugin_defconfig | 2 + configs/nitrogen6dl2g_defconfig | 11 ++- configs/nitrogen6dl_defconfig | 11 ++- configs/nitrogen6q2g_defconfig | 11 ++- configs/nitrogen6q_defconfig | 11 ++- configs/nitrogen6s1g_defconfig | 11 ++- configs/nitrogen6s_defconfig | 11 ++- configs/pico-dwarf-imx6ul_defconfig | 65 ++++++++++++++++++ configs/pico-dwarf-imx7d_defconfig | 69 +++++++++++++++++++ configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 6 +- configs/pico-imx6_defconfig | 73 ++++++++++++++++++++ configs/pico-imx6ul_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-nymph-imx7d_defconfig | 69 +++++++++++++++++++ configs/pico-pi-imx6ul_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 4 +- configs/sksimx6_defconfig | 1 - doc/imx/mkimage/imx8image.txt | 45 +++++++++++++ drivers/cpu/Makefile | 1 + drivers/cpu/imx8_cpu.c | 182 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/misc/Kconfig | 2 +- drivers/misc/imx8/scu_api.c | 49 ++++++++++++++ drivers/pinctrl/nxp/pinctrl-imx.c | 4 +- drivers/serial/Kconfig | 2 +- include/configs/cl-som-imx7.h | 4 -- include/configs/imx6_spl.h | 28 +++++++- include/configs/imx8mq_evk.h | 4 -- include/configs/imx8qm_mek.h | 2 +- include/configs/imx8qxp_mek.h | 2 +- include/configs/mx53loco.h | 14 +++- include/configs/mx6_common.h | 4 -- include/configs/mx6sllevk.h | 6 -- include/configs/mx6ul_14x14_evk.h | 2 +- include/configs/mx6ullevk.h | 19 ++++-- include/configs/mx7_common.h | 4 -- include/configs/mx7ulp_evk.h | 9 --- include/configs/pico-imx6.h | 164 +++++++++++++++++++++++++++++++++++++++++++++ include/configs/pico-imx6ul.h | 33 ++++++++- include/configs/pico-imx7d.h | 8 ++- include/dt-bindings/clock/imx6ul-clock.h | 50 ++++++++------ include/spl.h | 15 ++++- scripts/config_whitelist.txt | 1 - tools/imx8mimage.c | 7 +- tools/logos/technexion.bmp | Bin 0 -> 22390 bytes tools/spl_size_limit.c | 3 + 145 files changed, 5083 insertions(+), 2770 deletions(-) create mode 100644 arch/arm/dts/imx6dl-nitrogen6x.dts create mode 100644 arch/arm/dts/imx6dl-pico.dts create mode 100644 arch/arm/dts/imx6q-nitrogen6x.dts create mode 100644 arch/arm/dts/imx6q-pico.dts create mode 100644 arch/arm/dts/imx6q-sabrelite.dts create mode 100644 arch/arm/dts/imx6qdl-nitrogen6x.dtsi create mode 100644 arch/arm/dts/imx6qdl-pico.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabrelite.dtsi create mode 100644 arch/arm/dts/imx6ul-14x14-evk.dtsi create mode 100644 arch/arm/dts/imx6ulz-14x14-evk.dts create mode 100644 arch/arm/dts/imx6ulz.dtsi create mode 100644 arch/arm/dts/imx7d-pico-u-boot.dtsi create mode 100644 arch/arm/include/asm/arch-imx8/image.h create mode 100644 arch/arm/mach-imx/imx8/fdt.c create mode 100644 arch/arm/mach-imx/imx8/lowlevel_init.S create mode 100644 arch/arm/mach-imx/imx8/parse-container.c create mode 100644 board/freescale/imx8qm_mek/uboot-container.cfg create mode 100644 board/freescale/imx8qxp_mek/uboot-container.cfg create mode 100644 board/technexion/pico-imx6/Kconfig create mode 100644 board/technexion/pico-imx6/MAINTAINERS create mode 100644 board/technexion/pico-imx6/Makefile create mode 100644 board/technexion/pico-imx6/README create mode 100644 board/technexion/pico-imx6/pico-imx6.c create mode 100644 board/technexion/pico-imx6/spl.c create mode 100644 configs/mx6ulz_14x14_evk_defconfig create mode 100644 configs/pico-dwarf-imx6ul_defconfig create mode 100644 configs/pico-dwarf-imx7d_defconfig create mode 100644 configs/pico-imx6_defconfig create mode 100644 configs/pico-nymph-imx7d_defconfig create mode 100644 doc/imx/mkimage/imx8image.txt create mode 100644 drivers/cpu/imx8_cpu.c create mode 100644 include/configs/pico-imx6.h create mode 100644 tools/logos/technexion.bmp
On Mon, Sep 23, 2019 at 11:05:31AM +0200, Stefano Babic wrote:
Hi Tom,
Sorry, with the video PR from last night now pico-imx7d_bl33 pico-hobbit-imx7d pico-nymph-imx7d mx6ul_9x9_evk pico-imx7d mx6ul_14x14_evk pico-dwarf-imx7d pico-pi-imx7d fail to link.
Also, at this point in the release cycle are all of these changes still things we really want to bring in? Thanks!
Hi Tom and Stefano
I send patch series for fix build for pico-imx7d
Joris Offouga
Hi Tom,
On Mon, Sep 23, 2019 at 9:57 AM Joris Offouga offougajoris@gmail.com wrote:
Hi Tom and Stefano
Those changes are indeed important. Most were sent before and we polished them more lately.
Joris also been promptly on fixing issues, so I'd love to see it all merged.
We are now getting to move more things to DM model and we hope to do more changes for next release.
Hi Tom and Stefano
OK. But we're 2 weeks from v2019.10 release. Will these platforms be better or worse off holding most (all?) of these changes for the next release so they can if not get more "polish" at least more testing before a release and be included once the release happens and merge window opens? Thanks!
Hi Tom and Stefano
PICO 7D changes are fixes. The PICO i.MX6 can wait.
Hello Tom,
On Mon, Sep 23, 2019 at 5:04 PM Otavio Salvador otavio@ossystems.com.br wrote:
I ended redoing the branch and removing Joris patches for this release. Those were breaking the builds and prepared a branch which builds fine.
The following changes since commit 31e086e460fb5de6dd42559babdc1e027ed2fe96:
Prepare v2019.10-rc4 (2019-09-23 12:24:39 -0400)
https://github.com/OSSystems/u-boot imx-fixes-2019.10
for you to fetch changes up to b0902ed95d2a0fa6de15c3adacdcc2965ae6ddc3:
Merge remote-tracking branch 'origin/master' into imx-fixes-2019.10 (2019-09-23 22:39:05 -0300)
Otavio Salvador (6): pico-imx6ul: Add DWARF baseboard support pico-imx7d: Add DWARF baseboard support pico-imx7d: Add NYMPH baseboard support configs: Sync all baseboard specific pico-imx7d pico-imx6: Fix bootmenu handling Merge remote-tracking branch 'origin/master' into imx-fixes-2019.10
Stefano Babic (4): Merge branch 'nxp-imx-8-13' of https://github.com/MrVan/u-boot into master-next Revert "habv4: tools: Avoid hardcoded CSF size for SPL targets" imx: fix missing MAINTAINERS pico boards board: imx6dl_mamoj: set the value for CSF size
Makefile | 8 + arch/arm/cpu/arm926ejs/spear/spl.c | 5 +- arch/arm/dts/Makefile | 32 +- arch/arm/dts/fsl-imx8qm.dtsi | 7 + arch/arm/dts/imx6dl-nitrogen6x.dts | 15 + arch/arm/dts/imx6dl-pico.dts | 17 + arch/arm/dts/imx6q-nitrogen6x.dts | 19 + arch/arm/dts/imx6q-pico.dts | 17 + arch/arm/dts/imx6q-sabrelite.dts | 19 + arch/arm/dts/imx6qdl-nitrogen6x.dtsi | 69 ++ arch/arm/dts/imx6qdl-pico.dtsi | 424 ++++++++ arch/arm/dts/imx6qdl-sabrelite.dtsi | 384 +++++++ arch/arm/dts/imx6qdl-u-boot.dtsi | 6 + arch/arm/dts/imx6qdl.dtsi | 3 - arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 49 +- arch/arm/dts/imx6ul-14x14-evk.dts | 422 +------- arch/arm/dts/imx6ul-14x14-evk.dtsi | 531 +++++++++ arch/arm/dts/imx6ul-pinfunc.h | 175 +-- arch/arm/dts/imx6ul.dtsi | 301 ++++-- arch/arm/dts/imx6ull-14x14-evk.dts | 523 +-------- arch/arm/dts/imx6ull-pinfunc-snvs.h | 7 +- arch/arm/dts/imx6ull-pinfunc.h | 116 +- arch/arm/dts/imx6ull.dtsi | 1184 +-------------------- arch/arm/dts/imx6ulz-14x14-evk.dts | 22 + arch/arm/dts/imx6ulz.dtsi | 37 + arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/arch-imx8/image.h | 56 + arch/arm/include/asm/arch-imx8/sci/rpc.h | 5 +- arch/arm/include/asm/arch-imx8/sci/sci.h | 2 + arch/arm/include/asm/arch-imx8/sys_proto.h | 1 + arch/arm/include/asm/arch-mx7ulp/clock.h | 2 +- arch/arm/include/asm/arch-mx7ulp/imx-regs.h | 20 + arch/arm/include/asm/arch-mx7ulp/pcc.h | 4 +- arch/arm/include/asm/arch-mx7ulp/scg.h | 1 + arch/arm/include/asm/arch-mx7ulp/sys_proto.h | 1 + arch/arm/include/asm/mach-imx/sys_proto.h | 2 + arch/arm/mach-imx/Kconfig | 7 + arch/arm/mach-imx/Makefile | 14 +- arch/arm/mach-imx/cpu.c | 2 + arch/arm/mach-imx/imx8/Kconfig | 13 + arch/arm/mach-imx/imx8/Makefile | 7 +- arch/arm/mach-imx/imx8/cpu.c | 189 +--- arch/arm/mach-imx/imx8/fdt.c | 292 +++++ arch/arm/mach-imx/imx8/lowlevel_init.S | 36 + arch/arm/mach-imx/imx8/parse-container.c | 120 +++ arch/arm/mach-imx/mx6/Kconfig | 21 + arch/arm/mach-imx/mx6/clock.c | 32 +- arch/arm/mach-imx/mx6/soc.c | 4 + arch/arm/mach-imx/mx7ulp/Kconfig | 6 +- arch/arm/mach-imx/mx7ulp/clock.c | 8 +- arch/arm/mach-imx/mx7ulp/scg.c | 63 +- arch/arm/mach-imx/mx7ulp/soc.c | 38 +- arch/arm/mach-imx/spl.c | 2 + arch/arm/mach-rockchip/spl.c | 5 +- arch/arm/mach-rockchip/tpl.c | 5 +- board/boundary/nitrogen6x/MAINTAINERS | 5 + board/boundary/nitrogen6x/nitrogen6x.c | 30 +- board/freescale/imx8qm_mek/README | 4 +- board/freescale/imx8qm_mek/uboot-container.cfg | 13 + board/freescale/imx8qxp_mek/README | 4 +- board/freescale/imx8qxp_mek/uboot-container.cfg | 13 + board/freescale/mx6slevk/mx6slevk.c | 28 - board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 73 +- board/freescale/mx6ullevk/MAINTAINERS | 1 + board/freescale/mx6ullevk/mx6ullevk.c | 10 +- board/freescale/mx7ulp_evk/mx7ulp_evk.c | 47 + board/technexion/pico-imx6/Kconfig | 15 + board/technexion/pico-imx6/MAINTAINERS | 9 + board/technexion/pico-imx6/Makefile | 5 + board/technexion/pico-imx6/README | 73 ++ board/technexion/pico-imx6/pico-imx6.c | 362 +++++++ board/technexion/pico-imx6/spl.c | 314 ++++++ board/technexion/pico-imx6ul/README | 8 +- board/technexion/pico-imx6ul/pico-imx6ul.c | 55 +- board/technexion/pico-imx6ul/spl.c | 4 + board/technexion/pico-imx7d/MAINTAINERS | 2 + board/technexion/pico-imx7d/README | 91 ++ board/technexion/pico-imx7d/spl.c | 4 + board/toradex/apalis_imx6/apalis_imx6.c | 14 +- common/spl/Kconfig | 3 +- common/spl/spl_bootrom.c | 7 +- common/spl/spl_mmc.c | 10 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx8mq_evk_defconfig | 2 +- configs/imx8qm_mek_defconfig | 9 +- configs/imx8qxp_mek_defconfig | 6 +- configs/mx6qsabrelite_defconfig | 10 +- configs/mx6sabresd_defconfig | 4 +- configs/mx6slevk_defconfig | 2 + configs/mx6slevk_spinor_defconfig | 2 + configs/mx6slevk_spl_defconfig | 2 + configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/mx6ulz_14x14_evk_defconfig | 44 + configs/mx7ulp_evk_defconfig | 3 + configs/mx7ulp_evk_plugin_defconfig | 2 + configs/nitrogen6dl2g_defconfig | 11 +- configs/nitrogen6dl_defconfig | 11 +- configs/nitrogen6q2g_defconfig | 11 +- configs/nitrogen6q_defconfig | 11 +- configs/nitrogen6s1g_defconfig | 11 +- configs/nitrogen6s_defconfig | 11 +- configs/pico-dwarf-imx6ul_defconfig | 65 ++ configs/pico-dwarf-imx7d_defconfig | 69 ++ configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6_defconfig | 73 ++ configs/pico-imx6ul_defconfig | 1 + configs/pico-nymph-imx7d_defconfig | 69 ++ configs/pico-pi-imx6ul_defconfig | 1 + configs/sksimx6_defconfig | 1 - doc/imx/mkimage/imx8image.txt | 45 + drivers/cpu/Makefile | 1 + drivers/cpu/imx8_cpu.c | 182 ++++ drivers/misc/Kconfig | 2 +- drivers/misc/imx8/scu_api.c | 49 + drivers/pinctrl/nxp/pinctrl-imx.c | 4 +- drivers/serial/Kconfig | 2 +- include/configs/cl-som-imx7.h | 4 - include/configs/imx6_spl.h | 28 +- include/configs/imx8mq_evk.h | 4 - include/configs/imx8qm_mek.h | 2 +- include/configs/imx8qxp_mek.h | 2 +- include/configs/mx53loco.h | 14 +- include/configs/mx6_common.h | 4 - include/configs/mx6sllevk.h | 6 - include/configs/mx6ul_14x14_evk.h | 2 +- include/configs/mx6ullevk.h | 19 +- include/configs/mx7_common.h | 4 - include/configs/mx7ulp_evk.h | 9 - include/configs/pico-imx6.h | 164 +++ include/configs/pico-imx6ul.h | 33 +- include/configs/pico-imx7d.h | 6 +- include/dt-bindings/clock/imx6ul-clock.h | 50 +- include/spl.h | 15 +- scripts/config_whitelist.txt | 1 - tools/imx8mimage.c | 7 +- tools/logos/technexion.bmp | Bin 0 -> 22390 bytes tools/spl_size_limit.c | 3 + 139 files changed, 4932 insertions(+), 2724 deletions(-) create mode 100644 arch/arm/dts/imx6dl-nitrogen6x.dts create mode 100644 arch/arm/dts/imx6dl-pico.dts create mode 100644 arch/arm/dts/imx6q-nitrogen6x.dts create mode 100644 arch/arm/dts/imx6q-pico.dts create mode 100644 arch/arm/dts/imx6q-sabrelite.dts create mode 100644 arch/arm/dts/imx6qdl-nitrogen6x.dtsi create mode 100644 arch/arm/dts/imx6qdl-pico.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabrelite.dtsi create mode 100644 arch/arm/dts/imx6ul-14x14-evk.dtsi create mode 100644 arch/arm/dts/imx6ulz-14x14-evk.dts create mode 100644 arch/arm/dts/imx6ulz.dtsi create mode 100644 arch/arm/include/asm/arch-imx8/image.h create mode 100644 arch/arm/mach-imx/imx8/fdt.c create mode 100644 arch/arm/mach-imx/imx8/lowlevel_init.S create mode 100644 arch/arm/mach-imx/imx8/parse-container.c create mode 100644 board/freescale/imx8qm_mek/uboot-container.cfg create mode 100644 board/freescale/imx8qxp_mek/uboot-container.cfg create mode 100644 board/technexion/pico-imx6/Kconfig create mode 100644 board/technexion/pico-imx6/MAINTAINERS create mode 100644 board/technexion/pico-imx6/Makefile create mode 100644 board/technexion/pico-imx6/README create mode 100644 board/technexion/pico-imx6/pico-imx6.c create mode 100644 board/technexion/pico-imx6/spl.c create mode 100644 configs/mx6ulz_14x14_evk_defconfig create mode 100644 configs/pico-dwarf-imx6ul_defconfig create mode 100644 configs/pico-dwarf-imx7d_defconfig create mode 100644 configs/pico-imx6_defconfig create mode 100644 configs/pico-nymph-imx7d_defconfig create mode 100644 doc/imx/mkimage/imx8image.txt create mode 100644 drivers/cpu/imx8_cpu.c create mode 100644 include/configs/pico-imx6.h create mode 100644 tools/logos/technexion.bmp
Since recent splash changes common code for splashscreen logo should be used instead of adding duplicated code under board directories. mx6ul_9x9_evk and mx6ul_14x14_evk configurations used old board specific logo code and do not link, fix them.
Signed-off-by: Anatolij Gustschin agust@denx.de --- .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 19 ++----------------- configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + include/configs/mx6ul_14x14_evk.h | 1 + 4 files changed, 5 insertions(+), 17 deletions(-)
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 8e5f365d35..c98e98b485 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -28,10 +28,6 @@ #include "../common/pfuze.h" #include <usb.h> #include <usb/ehci-ci.h> -#ifdef CONFIG_DM_VIDEO -#include <bmp_logo_data.h> -#include <video.h> -#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -449,6 +445,8 @@ static int setup_lcd(void)
return 0; } +#else +static inline int setup_lcd(void) { return 0; } #endif
int board_early_init_f(void) @@ -505,21 +503,8 @@ int board_late_init(void) env_set("board_rev", "14X14"); #endif
-#if defined(CONFIG_DM_VIDEO) - struct udevice *dev; - int ret; - - ret = uclass_get_device(UCLASS_VIDEO, 0, &dev); - if (ret) - return ret; - setup_lcd();
- ret = video_bmp_display(dev, (ulong)bmp_logo_bitmap, 0, 0, true); - if (ret) - return ret; -#endif - return 0; }
diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 526ede34e9..429dff0d35 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -68,3 +68,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 95c6697e62..4b517436c8 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -71,3 +71,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index f8a5fd30f3..87f88693c5 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -60,6 +60,7 @@ "fdt_addr=0x83000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ + "splashimage=" __stringify(CONFIG_LOADADDR) "\0" \ "videomode=video=ctfb:x:480,y:272,depth:24,pclk:108695,le:8,ri:4,up:2,lo:4,hs:41,vs:10,sync:0,vmode:0\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \
Subject: [PATCH] imx: mx6ul_14x14_evk: fix link issue
Acked-by: Peng Fan peng.fan@nxp.com
int ret;
if (ret)
return ret;
setup_lcd();
if (ret)
return ret;
-#endif
o:4,hs:41,vs:10,sync:0,vmode:0\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ -- 2.17.1
participants (6)
Anatolij Gustschin
Joris Offouga
Otavio Salvador
Peng Fan
Stefano Babic
