[U-Boot] [PATCH v3] armv8: errata: Implement workaround for Cortex-A53 Erratum 855873
855873: An eviction might overtake a cache clean operation Workaround: The erratum can be avoided by upgrading cache clean by address operations to cache clean and invalidate operations. For Cortex-A53 r0p3 and later release, this can be achieved by setting CPUACTLR.ENDCCASCI to 1.
This patch is to implement the workaround for this erratum.
Signed-off-by: Alison Wang alison.wang@nxp.com --- Changes in v3: - Check the major revision of Cortex-A53.
Changes in v2: - Check the revision of Cortex-A53 and apply the erratum to r0p3 and later release. - Fix the mistake in the commit description.
arch/arm/Kconfig | 3 +++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 +++ arch/arm/cpu/armv8/start.S | 24 +++++++++++++++++++++++- 3 files changed, 29 insertions(+), 1 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f2c35e3..de323bf 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -122,6 +122,9 @@ config ARM_ERRATA_852421 config ARM_ERRATA_852423 bool
+config ARM_ERRATA_855873 + bool + config CPU_ARM720T bool select SYS_CACHE_SHIFT_5 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 66bc32c..76a4d8b 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -1,6 +1,7 @@ config ARCH_LS1012A bool select ARMV8_SET_SMPEN + select ARM_ERRATA_855873 select FSL_LSCH2 select SYS_FSL_DDR_BE select SYS_FSL_MMDC @@ -15,6 +16,7 @@ config ARCH_LS1012A config ARCH_LS1043A bool select ARMV8_SET_SMPEN + select ARM_ERRATA_855873 select FSL_LSCH2 select SYS_FSL_DDR select SYS_FSL_DDR_BE @@ -67,6 +69,7 @@ config ARCH_LS1046A config ARCH_LS1088A bool select ARMV8_SET_SMPEN + select ARM_ERRATA_855873 select FSL_LSCH3 select SYS_FSL_DDR select SYS_FSL_DDR_LE diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 03e744e..f385ed4 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -196,7 +196,10 @@ reset_sctrl: WEAK(apply_core_errata)
mov x29, lr /* Save LR */ - /* For now, we support Cortex-A57 specific errata only */ + /* For now, we support Cortex-A53, Cortex-A57 specific errata */ + + /* Check if we are running on a Cortex-A53 core */ + branch_if_a53_core x0, apply_a53_core_errata
/* Check if we are running on a Cortex-A57 core */ branch_if_a57_core x0, apply_a57_core_errata @@ -204,6 +207,25 @@ WEAK(apply_core_errata) mov lr, x29 /* Restore LR */ ret
+apply_a53_core_errata: + +#ifdef CONFIG_ARM_ERRATA_855873 + mrs x0, midr_el1 + tst x0, #(0xf << 20) + b.ne 0b + + mrs x0, midr_el1 + and x0, x0, #0xf + cmp x0, #3 + b.lt 0b + + mrs x0, S3_1_c15_c2_0 /* cpuactlr_el1 */ + /* Enable data cache clean as data cache clean/invalidate */ + orr x0, x0, #1 << 44 + msr S3_1_c15_c2_0, x0 /* cpuactlr_el1 */ +#endif + b 0b + apply_a57_core_errata:
#ifdef CONFIG_ARM_ERRATA_828024
Changes in v3:
Changes in v2:
Applied to fsl-qoriq master. Thanks.
York
Changes in v3:
Changes in v2:
Just a note if this is just for a53 should we consider to place these Kconfigs to arch/arm/cpu/armv8/Kconfig?
M
Changes in v3:
Changes in v2:
We were following Tom Rini's move in commit 8dda2e2f9. I am not against moving ARMv8 related config options, if no single erratum applies to both ARMv8 and legacy cores.
York
Changes in v3:
Changes in v2:
ok. Good.
Thanks, Michal
Alison Wang
Michal Simek
York Sun
