[PULL next] u-boot-at91-2023.01-a
Hello Tom,
Please pull tag u-boot-2023.01-a , the first set of new at91 features for the next cycle 2023.01 .
This feature set includes the important update on PIO4 pinctrl driver that solves a long time mismatch between Linux and U-boot, related on the unification of pinctrl and gpio driver support, now respecting the pinctrl bindings ABI; and also support for pinctrl subnodes. The feature set also adds support for PDA screen detection for sam9x60_curiosity board , one fix for SD-Card reinsertion and one fix for sam9x60 clocks.
Thanks, Eugen
The following changes since commit b6c50e5831f6ce3800d4b3cf3c7aa35dde8c48d9:
Merge branch 'next' of https://source.denx.de/u-boot/custodians/u-boot-watchdog into next (2022-09-18 08:34:31 -0400)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-2023.01-a
for you to fetch changes up to 7086defa048cc5303291b592192a18d69c6510cf:
pinctrl: at91-pio4: Add support for pinctrl config subnodes (2022-09-19 09:51:04 +0300)
---------------------------------------------------------------- First set of u-boot-at91 features for the 2023.01 cycle
---------------------------------------------------------------- Durai Manickam KR (3): configs: sama9x60_curiosity: add onewire and eeprom drivers board: sam9x60_curiosity: add pda detect call at init time ARM: dts: at91: sam9x60_curiosity: add onewire support
Mihai Sain (1): clk: at91: sam9x60: change parent clock from mck_pres to mck_div
Sergiu Moga (5): mmc: atmel_sdhci: re-enable sdhci after SD Card re-insertion ARM: dts: at91: sama5: Align with Linux Devicetree ARM: dts: at91: sama7: Align with Linux Devicetree pinctrl: at91-pio4: Bind GPIO driver to the pinctrl DT node pinctrl: at91-pio4: Add support for pinctrl config subnodes
arch/arm/dts/at91-sam9x60_curiosity.dts | 17 ++ arch/arm/dts/at91-sama5d27_giantboard.dts | 59 +++---- arch/arm/dts/at91-sama5d27_som1_ek.dts | 80 +++++---- arch/arm/dts/at91-sama5d27_wlsom1_ek-u-boot.dtsi | 6 +- arch/arm/dts/at91-sama5d27_wlsom1_ek.dts | 92 +++++----- arch/arm/dts/at91-sama5d2_icp.dts | 134 +++++++------- arch/arm/dts/at91-sama5d2_ptc_ek.dts | 98 ++++++----- arch/arm/dts/at91-sama5d2_xplained.dts | 204 +++++++++++----------- arch/arm/dts/at91-sama7g5ek-u-boot.dtsi | 2 +- arch/arm/dts/at91-sama7g5ek.dts | 85 +++++---- arch/arm/dts/sama5d2.dtsi | 9 +- arch/arm/dts/sama5d27_som1.dtsi | 94 +++++----- arch/arm/dts/sama5d27_wlsom1.dtsi | 54 +++--- arch/arm/dts/sama7g5.dtsi | 16 +- board/atmel/sam9x60_curiosity/sam9x60_curiosity.c | 4 + configs/sam9x60_curiosity_mmc_defconfig | 4 + drivers/clk/at91/sam9x60.c | 4 +- drivers/gpio/atmel_pio4.c | 2 - drivers/mmc/atmel_sdhci.c | 12 ++ drivers/pinctrl/pinctrl-at91-pio4.c | 138 +++++++++++++-- 20 files changed, 631 insertions(+), 483 deletions(-)
On Mon, Sep 19, 2022 at 08:29:58AM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks, Eugen
