[PATCH v2] test/cmd/wget.c: move net_test_wget() to the cmd test suite
Since net_test_wget() is testing a command and is in test/cmd it should be in the 'cmd' test suite, not 'lib'.
Saving and restoring the values of the environment variables that the test manipulates is necessary to avoid a regression when running the whole ut test suite. A minimal reproducer is:
$ ./u-boot -T -c "ut cmd net_test_wget; ut dm dm_test_eth_act" | \ grep -E "(Test:|Failures:)"
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- test/cmd/wget.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/test/cmd/wget.c b/test/cmd/wget.c index fe26fee54c9..7570c065a10 100644 --- a/test/cmd/wget.c +++ b/test/cmd/wget.c @@ -19,7 +19,7 @@ #include <dm/test.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> -#include <test/lib.h> +#include <test/cmd.h> #include <test/test.h> #include <test/ut.h>
@@ -206,6 +206,10 @@ static int sb_http_handler(struct udevice *dev, void *packet,
static int net_test_wget(struct unit_test_state *uts) { + char *prev_ethact = env_get("ethact"); + char *prev_ethrotate = env_get("ethrotate"); + char *prev_loadaddr = env_get("loadaddr"); + sandbox_eth_set_tx_handler(0, sb_http_handler); sandbox_eth_set_priv(0, uts);
@@ -223,6 +227,10 @@ static int net_test_wget(struct unit_test_state *uts) ut_assert_nextline("md5 for 00020000 ... 0002001f ==> 234af48e94b0085060249ecb5942ab57"); ut_assert_console_end();
+ env_set("ethact", prev_ethact); + env_set("ethrotate", prev_ethrotate); + env_set("loadaddr", prev_loadaddr); + return 0; } -LIB_TEST(net_test_wget, UTF_CONSOLE); +CMD_TEST(net_test_wget, UTF_CONSOLE);
- char *prev_ethact = env_get("ethact");
- char *prev_ethrotate = env_get("ethrotate");
- char *prev_loadaddr = env_get("loadaddr");
- sandbox_eth_set_tx_handler(0, sb_http_handler); sandbox_eth_set_priv(0, uts);
- env_set("ethact", prev_ethact);
- env_set("ethrotate", prev_ethrotate);
- env_set("loadaddr", prev_loadaddr);
I don't know why / how, but now this causes the "hash" unit test to fail, in both Azure and GitLab.
CI passed on https://github.com/u-boot/u-boot/pull/700. How do I reproduce the problem?
Thanks,
Sigh. I think we managed to hit one of those bugs that disappears when we re-order objects slightly. This is also passing for me now, so I'll apply this later today.
Jerome Forissier
