Re: [U-Boot] [linux-sunxi] [UBOOT] Both Linux-Sunxi and Mainline Uboot have issues
On 19-02-15 07:29, TsvetanUsunov wrote:
Hi
For A13-OLinuxino till now we conservatively used the Linux-Sunxi uboot, but we recently got new lot of Samsung memories and we decided to tweak some parameters for this DDR in Linux-Sunxi uboot and found problems. As this uboot is with status not maintained anymore I will not discuss the problems, as probably no one will spend time on it, so we wisely decided to move to mainline uboot :) but it seems there are other issues to address.
First of all let me say that it is a good decision to move to upstream u-boot, as one of the upstream u-boot Allwinner support maintainers I believe that that is a very good decision.
In case you've not noticed yet upstream u-boot will give you a console on hdmi (or lcd if configured in the configs/A*-OLinuxIno*_defconfig file) and supports usb keyboards, so you can interact with u-boot without needing to hook up a serial console, and it supports booting from sata disks, and ... lets just say it is much better :)
The PLL5 and PLL6 values are changed and this cause problems, this is what we found so far:
- mainline u-boot
================= 1.1 pll5 address 0x01c20020, value 0xb1049091 - P=1, N=16, K=2, M=2. The PLL5 output for DDR = (24MHz*N*K)/M. DDR=24*16*2/2 = 384MHz The PLL5 output for other module = (24MHz*N*K)/P. DDR=24*16*2/1 = 768MHz - This high frequency cause LCDs connected to the board to flicker
pll5's clock was doubled in upstream u-boot to give downstream users more flexibility in which clocks they can get by dividing it.
Unfortunately the allwinner derived linux-sunxi kernels have some hardcoded assumptions about pll5 speed left and right, so you must make sure that your kernel has these 2 commits:
https://github.com/linux-sunxi/linux-sunxi/commit/9a1cd034181af628d414520228... https://github.com/linux-sunxi/linux-sunxi/commit/ade08aa6e5249a9e75a97393e8...
Alternatively you can enable the old kernel compat option in u-boot's config, so you would do the following:
make -j4 CROSS_COMPILE=arm-linux-gnu- A13-OLinuXino_defconfig make -j4 CROSS_COMPILE=arm-linux-gnu- menuconfig -> goto "ARM architecture" -> select "Enable workarounds for booting old kernels" -> exit -> exit -> save make -j4 CROSS_COMPILE=arm-linux-gnu- spl/menuconfig Do the same as for the normal menuconfig
This will remove the doubling of the PLL5 speed.
Note assuming you're using linux-sunxi kernels and not upstream kernels you also need "Enable workarounds for booting old kernels" for things to boot at all on A20 based devices, because the new u-boot by default boots the kernel in non secure mode (so that it can be a hypervisor and hw accelerated qemu-kvm works on the A20), but the old kernels do not work when booted in non secure mode (another bug in the old kernels, for which no fix is available).
1.2 pll6 address 0x01c20028, value 0xA1009900 - N=25, K=1, M=1 The PLL6 output is (24MHz*N*K)/M/2 = 24*25*1/1/2 = 300MHz
Actually with upstream u-boot the value is 0xA1009911, but the end result is the same: 24*25*2/2/2 = 300MHz
1.3 MBUS clock address 0x01c2015c, value 0x81000001 - MBUS clock source is PLL6/2 = 300/2 = 150MHz - This is connected to PLL6 setup, at this 150 Mhz the board cant play video smoothly and sometimes drop video packets when the video is playing
Hmm, interesting so it seems that PLL6 is different on the A13 compared to the A10/A20 and both upstream u-boot and the kernel get this wrong, and miss the extra /2 which is being done on the A13 only, causing this.
I'll work on a fix for this and get back to you.
Regards,
Hans
- sunxi u-boot
================= 1.1 pll5 address 0x01c20020, value 0xb1049091 - P=2, N=17, K=2, M=2. The PLL5 output for DDR = (24MHz*N*K)/M. DDR=24*17*2/2 = 408MHz The PLL5 output for other module = (24MHz*N*K)/P. DDR=24*16*2/2 = 408MHz - this frequency was OK, There is no problem with LCD flickering, why the frequency increase was necessary? 1.2 pll6 address 0x01c20028, value 0xA1009900 - N=25, K=1, M=1 The PLL6 output is (24MHz*N*K)/M/2 = 24*25*1/1/2 = 300MHz 1.3 about MBUS clock address 0x01c2015c, value 0x82000001 - MBUS clock source is PLL5/2 = 408/2 = 204MHz - at this frequency No packet drop when the video is playing
Can you tell me the reasons for the PLL5 and PLL6 frequency changes to mainline uboot?
Best regards Tsvetan
IIRC there is also an env var which can be set to force booting in secure mode?
(probably some mainline commits to head.S to handle boot in hyp mode could be backported, ignoring the actual KVM stuff)
Ian.
Correct, doing:
setenv bootm_boot_mode sec
Before calling "bootm" also is a way to boot old kernels on A20 devices.
IIRC someone took a quick look and this was non trivial, but yeah this would really be the best thing to do, so that we can drop the old kernel compat u-boot config at one point.
Regards,
Hans
Hans de Goede
Ian Campbell
