[U-Boot] [PATCH] Revert "imx: mx7: implement reset_misc"
Commit 9f8fa184fc1ac ("imx: mx7: implement reset_misc") says it needs to to power down lcdif to make 'reset' can pass stress test.
However I see 100% of reset failures with this commit applied, so better revert it for now.
This reverts commit 9f8fa184fc1acb6fe8e15e3bbbfcb916e6bc4cc1.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- arch/arm/cpu/armv7/mx7/soc.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c index dead1d3..b1d0e21 100644 --- a/arch/arm/cpu/armv7/mx7/soc.c +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -455,11 +455,3 @@ void s_init(void)
return; } - -void reset_misc(void) -{ -#ifdef CONFIG_VIDEO_MXS - lcdif_power_down(); -#endif -} -
Hi Stefano and Peng,
I realized that the reset failure always happen only when 'videomode' variable is not present:
=> setenv videomode => saveenv => reset
Then reset hangs.
If I do the check like this, then it does not hang:
--- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -135,6 +135,11 @@ void lcdif_power_down(void) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; int timeout = 1000000; + char *penv; + + penv = getenv("videomode"); + if (!penv) + return;
writel(panel.frameAdrs, ®s->hw_lcdif_cur_buf_reg); writel(panel.frameAdrs, ®s->hw_lcdif_next_buf_reg);
What do you think of such proposal instead of doing the revert?
Hi Fabio,
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: Wednesday, February 22, 2017 5:34 PM To: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com; U-Boot-Denx u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; Fabio Estevam fabio.estevam@nxp.com Subject: Re: [PATCH] Revert "imx: mx7: implement reset_misc"
Then reset hangs.
char *penv;
if (!penv)
return; writel(panel.frameAdrs, ®s->hw_lcdif_cur_buf_reg); writel(panel.frameAdrs, ®s->hw_lcdif_next_buf_reg);
If no videomode set, that means lcd will not be initialized. So there is no need to power down the lcdif, agree with your new approach. Because when lcdif is initialized, there is also a risk that system hang if lcdif is not powered down, so no revert.
Regards, Peng.
Ouch ! Wrong access ?
Then reset hangs.
char *penv;
if (!penv)
Fully agree !
Best regards, Stefano
Then reset hangs.
char *penv;
if (!penv)
Sorry for repost, my outlook seems work abnormally.
No revert. When videomode is set, lcdif will be initialized, then when reset, need to power down lcdif to avoid reset failure.
If no videomode, lcdif will not be initialized, no need to powerdown.
Agree with your new approach.
Regards, Peng.
Fabio Estevam
Peng Fan
Peng Fan
Stefano Babic
