[U-Boot] [U-BOOT PATCH] sf: Fix sf read for memory-mapped SPI flashes
Missing return after memcpy is done for memory-mapped SPI flashes, hence added retun 0 after memcpy done.
The return is missing in below patch "sf: Enable FDT-based configuration and memory mapping" (sha1: bb8215f437a7c948eec82a6abe754c226978bd6d)
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/spi_flash.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index aeb1ccb..1d45e3b 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -148,8 +148,10 @@ int spi_flash_cmd_read_fast(struct spi_flash *flash, u32 offset, u8 cmd[5];
/* Handle memory-mapped SPI */ - if (flash->memory_map) + if (flash->memory_map) { memcpy(data, flash->memory_map + offset, len); + return 0; + }
cmd[0] = CMD_READ_ARRAY_FAST; spi_flash_addr(offset, cmd);
Hi Simon,
Can you please check this change.
Thanks, Jagan.
On Tue, May 28, 2013 at 1:44 AM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
} cmd[0] = CMD_READ_ARRAY_FAST; spi_flash_addr(offset, cmd);
-- 1.7.4
On Mon, May 27, 2013 at 1:14 PM, Jagannadha Sutradharudu Teki < jagannadha.sutradharudu-teki@xilinx.com> wrote:
Thanks for fixing it.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Acked-by: Simon Glass sjg@chromium.org
Applied to u-boot-spi/master
-- Thanks, Jagan.
Jagan Teki
