[U-Boot] [PATCH 00/47] powerpc: Enable PCIe DM drvier for some platforms
Enable PCIe DM driver for some PowerPC platforms which has supported device tree.
Depends on the following 2 series: http://patchwork.ozlabs.org/project/uboot/list/?series=120960 http://patchwork.ozlabs.org/project/uboot/list/?series=115008
Hou Zhiqiang (47): powerpc: T208xRDB: Compile legacy PCIe routines conditionally powerpc: T208xRDB: Disable legacy PCIe driver when DM_PCI is enabled configs: T2080RDB: Enable PCIe driver powerpc: T4RDB: Compile legacy PCIe routines conditionally dm: pcie_fsl: Add T4240 PCIe support t4240: dts: Added PCIe DT nodes powerpc: T4240RDB: Disable legacy PCIe driver when DM_PCI is enabled configs: T4240RDB: Enable PCIe driver powerpc: T102xRDB: Compile legacy PCIe routines conditionally dm: pcie_fsl: Add T102x PCIe support t102x: dts: Added PCIe DT nodes powerpc: T102xRDB: Remove the useless macro CONFIG_ARCH_T1040 powerpc: T102xRDB: Disable legacy PCIe driver when DM_PCI is enabled configs: T1024RDB: Enable PCIe driver powerpc: T104xRDB: Compile legacy PCIe routines conditionally dm: pcie_fsl: Add T104x PCIe support t104x: dts: Added PCIe DT nodes powerpc: T104xRDB: Disable legacy PCIe driver when DM_PCI is enabled configs: T1042D4RDB: Enable PCIe driver powerpc: p1_p2_rdb: Compile legacy PCIe routines conditionally dm: pcie_fsl: Add PCIe support for P1 and P2 series SoCs P1020: dts: Added PCIe DT nodes powerpc: p1_p2_rdb: Disable legacy PCIe driver when DM_PCI is enabled configs: P1020RDB: Enable PCIe driver P2020: dts: Added PCIe DT nodes configs: P2020RDB: Enable PCIe driver powerpc: p_corenet: Compile legacy PCIe routines conditionally dm: pcie_fsl: Add P2041 PCIe support P2041: dts: Added PCIe DT nodes powerpc: P2041RDB: Disable legacy PCIe driver when DM_PCI is enabled configs: P2041RDB: Enable PCIe driver dm: pcie_fsl: Add P3041 PCIe support P3041: dts: Added PCIe DT nodes powerpc: corenet_ds: Disable legacy PCIe driver when DM_PCI is enabled configs: P3041DS: Enable PCIe driver dm: pcie_fsl: Add P4080 PCIe support P4080: dts: Added PCIe DT nodes configs: P4080DS: Enable PCIe driver dm: pcie_fsl: Add P5040 PCIe support P5040: dts: Added PCIe DT nodes configs: P5040DS: Enable PCIe driver powerpc: MPC8548CDS: Compile legacy PCIe routines conditionally powerpc: MPC85xxCDS: Disable legacy PCI fixup when DM_PCI is selected dm: pcie_fsl: Add MPC8548 PCIe support MPC8548: dts: Added PCIe DT node powerpc: MPC8548CDS: Disable legacy PCIe driver when DM_PCI is enabled configs: MPC8548CDS: Enable PCIe driver
arch/powerpc/dts/mpc8548-post.dtsi | 9 ++++ arch/powerpc/dts/mpc8548cds.dts | 6 +++ arch/powerpc/dts/mpc8548cds_36b.dts | 6 +++ arch/powerpc/dts/p1020-post.dtsi | 20 +++++++ arch/powerpc/dts/p1020rdb-pc.dts | 12 +++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 12 +++++ arch/powerpc/dts/p1020rdb-pd.dts | 12 +++++ arch/powerpc/dts/p2020-post.dtsi | 30 +++++++++++ arch/powerpc/dts/p2020rdb-pc.dts | 17 ++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 17 ++++++ arch/powerpc/dts/p2041.dtsi | 36 +++++++++++++ arch/powerpc/dts/p3041.dtsi | 48 +++++++++++++++++ arch/powerpc/dts/p4080.dtsi | 36 +++++++++++++ arch/powerpc/dts/p5040.dtsi | 36 +++++++++++++ arch/powerpc/dts/t102x.dtsi | 36 +++++++++++++ arch/powerpc/dts/t104x.dtsi | 48 +++++++++++++++++ arch/powerpc/dts/t4240.dtsi | 48 +++++++++++++++++ board/freescale/common/cds_pci_ft.c | 4 +- board/freescale/common/p_corenet/pci.c | 2 + board/freescale/mpc8548cds/mpc8548cds.c | 6 ++- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 4 +- board/freescale/t102xrdb/pci.c | 2 + board/freescale/t104xrdb/pci.c | 2 + board/freescale/t208xrdb/pci.c | 2 + board/freescale/t4rdb/pci.c | 2 + configs/MPC8548CDS_36BIT_defconfig | 4 ++ configs/MPC8548CDS_defconfig | 4 ++ configs/MPC8548CDS_legacy_defconfig | 4 ++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 4 ++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 4 ++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++ configs/P1020RDB-PC_36BIT_defconfig | 4 ++ configs/P1020RDB-PC_NAND_defconfig | 4 ++ configs/P1020RDB-PC_SDCARD_defconfig | 4 ++ configs/P1020RDB-PC_SPIFLASH_defconfig | 4 ++ configs/P1020RDB-PC_defconfig | 4 ++ configs/P1020RDB-PD_NAND_defconfig | 4 ++ configs/P1020RDB-PD_SDCARD_defconfig | 4 ++ configs/P1020RDB-PD_SPIFLASH_defconfig | 4 ++ configs/P1020RDB-PD_defconfig | 4 ++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 4 ++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 4 ++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++ configs/P2020RDB-PC_36BIT_defconfig | 4 ++ configs/P2020RDB-PC_NAND_defconfig | 4 ++ configs/P2020RDB-PC_SDCARD_defconfig | 4 ++ configs/P2020RDB-PC_SPIFLASH_defconfig | 4 ++ configs/P2020RDB-PC_defconfig | 4 ++ configs/P2041RDB_NAND_defconfig | 4 ++ configs/P2041RDB_SDCARD_defconfig | 4 ++ configs/P2041RDB_SPIFLASH_defconfig | 4 ++ configs/P2041RDB_defconfig | 4 ++ configs/P3041DS_NAND_defconfig | 4 ++ configs/P3041DS_SDCARD_defconfig | 4 ++ configs/P3041DS_SPIFLASH_defconfig | 4 ++ configs/P3041DS_defconfig | 4 ++ configs/P4080DS_SDCARD_defconfig | 4 ++ configs/P4080DS_SPIFLASH_defconfig | 4 ++ configs/P4080DS_defconfig | 4 ++ configs/P5040DS_NAND_defconfig | 4 ++ configs/P5040DS_SDCARD_defconfig | 4 ++ configs/P5040DS_SPIFLASH_defconfig | 4 ++ configs/P5040DS_defconfig | 4 ++ configs/T1024RDB_NAND_defconfig | 4 ++ configs/T1024RDB_SDCARD_defconfig | 4 ++ configs/T1024RDB_SPIFLASH_defconfig | 4 ++ configs/T1024RDB_defconfig | 4 ++ configs/T1042D4RDB_NAND_defconfig | 4 ++ configs/T1042D4RDB_SDCARD_defconfig | 4 ++ configs/T1042D4RDB_SPIFLASH_defconfig | 4 ++ configs/T1042D4RDB_defconfig | 4 ++ configs/T2080RDB_NAND_defconfig | 4 ++ configs/T2080RDB_SDCARD_defconfig | 4 ++ configs/T2080RDB_SPIFLASH_defconfig | 4 ++ configs/T2080RDB_defconfig | 4 ++ configs/T4240RDB_SDCARD_defconfig | 4 ++ configs/T4240RDB_defconfig | 4 ++ drivers/pci/pcie_fsl.c | 21 ++++++++ include/configs/MPC8548CDS.h | 22 +++++--- include/configs/P2041RDB.h | 55 ++++++-------------- include/configs/T102xRDB.h | 78 ++++++---------------------- include/configs/T104xRDB.h | 38 +++++++------- include/configs/T208xRDB.h | 36 +++++++------ include/configs/T4240RDB.h | 35 +++++++------ include/configs/corenet_ds.h | 63 +++++++--------------- include/configs/p1_p2_rdb_pc.h | 36 ++++++++----- 86 files changed, 822 insertions(+), 223 deletions(-)
Compile the legacy PCIe initialization reoutines only when DM_PCI is not enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/t208xrdb/pci.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/t208xrdb/pci.c b/board/freescale/t208xrdb/pci.c index 161b8cb..adc128d 100644 --- a/board/freescale/t208xrdb/pci.c +++ b/board/freescale/t208xrdb/pci.c @@ -11,6 +11,7 @@ #include <fdt_support.h> #include <asm/fsl_serdes.h>
+#if !defined(CONFIG_DM_PCI) void pci_init_board(void) { fsl_pcie_init_board(0); @@ -20,3 +21,4 @@ void pci_of_setup(void *blob, bd_t *bd) { FT_FSL_PCI_SETUP; } +#endif
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/T208xRDB.h | 36 +++++++++++++++++++----------------- 1 file changed, 19 insertions(+), 17 deletions(-)
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 1a5a93e..b1ae050 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -439,49 +439,51 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ #define CONFIG_PCIE4 /* PCIE controller 4 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ /* controller 1, direct to uli, tgtid 3, Base address 20000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */
/* controller 4, Base address 203000 */ #define CONFIG_SYS_PCIE4_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc40000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
#ifdef CONFIG_PCI +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ #define CONFIG_PCI_INDIRECT_BRIDGE +#endif #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif
Enable the DM PCIe driver in T2080RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/T2080RDB_NAND_defconfig | 4 ++++ configs/T2080RDB_SDCARD_defconfig | 4 ++++ configs/T2080RDB_SPIFLASH_defconfig | 4 ++++ configs/T2080RDB_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 7eb7058..30ec72b 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -57,6 +57,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 9ea6698..22c2e05 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -56,6 +56,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 988897b..e70fa0d 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -56,6 +56,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 3f7e282..b620349 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -45,6 +45,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y
Hi Zhiqiang,
Why do we need this option? I vaguely remember I commented in as similar patch for some other board (maybe layerscape arm?)
+CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 9ea6698..22c2e05 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -56,6 +56,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 988897b..e70fa0d 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -56,6 +56,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 3f7e282..b620349 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -45,6 +45,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y --
Regards, Bin
Hi Bin,
Thanks a lot for your comments!
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:48 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 03/47] configs: T2080RDB: Enable PCIe driver
Hi Zhiqiang,
We discussed this during adding PCIe DM driver on T2080QDS, so it's the same reason.
Thanks, Zhiqiang
CONFIG_PHYLIB=y
Regards, Bin
Hi Zhiqiang,
On Tue, Aug 27, 2019 at 10:05 AM Z.q. Hou zhiqiang.hou@nxp.com wrote:
Hi Bin,
Hi Zhiqiang,
I dug into the mailing list archive, and I see: https://lists.denx.de/pipermail/u-boot/2019-May/370756.html
In that thread, you wrote:
"I will submit a patch to remove the DM_PCI_COMPAT when all driver has been converted."
So I believe you guys have not converted all PowerPC drivers to DM, hence it's still left there?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月27日 10:51 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 03/47] configs: T2080RDB: Enable PCIe driver
Hi Zhiqiang,
Hi Bin,
Priyanka
Hi Zhiqiang,
100644
I dug into the mailing list archive, and I see: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.d enx.de%2Fpipermail%2Fu-boot%2F2019-May%2F370756.html&data=0 2%7C01%7Czhiqiang.hou%40nxp.com%7C7e2ca21c87dd4d497e4008d72a99 626b%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63702471058 1230533&sdata=Ams8RKheHQcU9pgTAuTugXcLCrzbRFk5xOm6ubu84R Y%3D&reserved=0
Yes, I will remove it when DM_ETH is added, otherwise there will be build errors.
Thanks, Zhiqiang
Regards, Bin
Hi Zhiqiang,
On Tue, Aug 27, 2019 at 11:09 AM Z.q. Hou zhiqiang.hou@nxp.com wrote:
Hi Bin,
Hi Zhiqiang,
Hi Bin,
Priyanka
Hi Zhiqiang,
100644
Great!, so, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/t4rdb/pci.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/t4rdb/pci.c b/board/freescale/t4rdb/pci.c index 4100370..7d670e1 100644 --- a/board/freescale/t4rdb/pci.c +++ b/board/freescale/t4rdb/pci.c @@ -11,6 +11,7 @@ #include <fdt_support.h> #include <asm/fsl_serdes.h>
Add compatible string for T4240 PCIe.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_fsl.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index e13e5a6..961d8e3 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -616,6 +616,7 @@ static struct fsl_pcie_data t2080_data = {
static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data }, + { .compatible = "fsl,pcie-t4240", .data = (ulong)&t2080_data }, { } };
T4240 integrated 4 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 3.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/t4240.dtsi | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/arch/powerpc/dts/t4240.dtsi b/arch/powerpc/dts/t4240.dtsi index 4d8fc71..fc34974 100644 --- a/arch/powerpc/dts/t4240.dtsi +++ b/arch/powerpc/dts/t4240.dtsi @@ -99,4 +99,52 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe240000 { + compatible = "fsl,pcie-t4240", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe240000 0x0 0x4000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe250000 { + compatible = "fsl,pcie-t4240", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe250000 0x0 0x4000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe260000 { + compatible = "fsl,pcie-t4240", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe260000 0x0 0x4000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x40000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe270000 { + compatible = "fsl,pcie-t4240", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe270000 0x0 0x4000>; /* registers */ + law_trgt_if = <3>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8030000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x60000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/T4240RDB.h | 35 +++++++++++++++++++---------------- 1 file changed, 19 insertions(+), 16 deletions(-)
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index a818f0c..8cdc17c 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -63,7 +63,6 @@ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
#define CONFIG_ENV_OVERWRITE @@ -178,44 +177,48 @@
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */
/* controller 4, Base address 203000 */ #define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc60000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
#ifdef CONFIG_PCI +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ #define CONFIG_PCI_INDIRECT_BRIDGE +#endif
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
Enable the DM PCIe driver in T4240RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/T4240RDB_SDCARD_defconfig | 4 ++++ configs/T4240RDB_defconfig | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index a70c237..cce4872 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -50,6 +50,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index d4ce176..bdadfa8 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -39,6 +39,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y
Again, why is this option needed?
+CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index d4ce176..bdadfa8 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -39,6 +39,10 @@ CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y --
Regards, Bin
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/t102xrdb/pci.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/t102xrdb/pci.c b/board/freescale/t102xrdb/pci.c index 161b8cb..adc128d 100644 --- a/board/freescale/t102xrdb/pci.c +++ b/board/freescale/t102xrdb/pci.c @@ -11,6 +11,7 @@ #include <fdt_support.h> #include <asm/fsl_serdes.h>
Add compatible string for T102x PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index 961d8e3..25df84d 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -615,6 +615,7 @@ static struct fsl_pcie_data t2080_data = { };
static const struct udevice_id fsl_pcie_ids[] = { + { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t4240", .data = (ulong)&t2080_data }, { }
T102x integrated 3 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/t102x.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/powerpc/dts/t102x.dtsi b/arch/powerpc/dts/t102x.dtsi index 2393e31..c49fd21 100644 --- a/arch/powerpc/dts/t102x.dtsi +++ b/arch/powerpc/dts/t102x.dtsi @@ -49,4 +49,40 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe240000 { + compatible = "fsl,pcie-t102x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe240000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; + + pcie@ffe250000 { + compatible = "fsl,pcie-t102x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe250000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x10000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; + + pcie@ffe260000 { + compatible = "fsl,pcie-t102x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe260000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; };
Remove the macro CONFIG_ARCH_T1040 from the T102xRDB.h and the PCIE4 related macros, as there are only 3 PCIe controllers on T102x SoCs.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/T102xRDB.h | 24 ------------------------ 1 file changed, 24 deletions(-)
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index cce65f5..3715e25 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -500,9 +500,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ -#ifdef CONFIG_ARCH_T1040 -#define CONFIG_PCIE4 /* PCIE controller 4 */ -#endif #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ #define CONFIG_PCI_INDIRECT_BRIDGE @@ -571,27 +568,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ #endif
-/* controller 4, Base address 203000, to be removed */ -#ifdef CONFIG_PCIE4 -#define CONFIG_SYS_PCIE4_MEM_VIRT 0xb0000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc30000000ull -#else -#define CONFIG_SYS_PCIE4_MEM_BUS 0xb0000000 -#define CONFIG_SYS_PCIE4_MEM_PHYS 0xb0000000 -#endif -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_VIRT 0xf8030000 -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#else -#define CONFIG_SYS_PCIE4_IO_PHYS 0xf8030000 -#endif -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/T102xRDB.h | 54 +++++++++++++--------------------------------- 1 file changed, 15 insertions(+), 39 deletions(-)
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 3715e25..4fb1709 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -500,72 +500,48 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -#define CONFIG_PCI_INDIRECT_BRIDGE
#ifdef CONFIG_PCI /* controller 1, direct to uli, tgtid 3, Base address 20000 */ #ifdef CONFIG_PCIE1 #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 -#endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#else -#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 -#endif -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ #endif
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #ifdef CONFIG_PCIE2 #define CONFIG_SYS_PCIE2_MEM_VIRT 0x90000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc10000000ull -#else -#define CONFIG_SYS_PCIE2_MEM_BUS 0x90000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0x90000000 -#endif -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#else -#define CONFIG_SYS_PCIE2_IO_PHYS 0xf8010000 -#endif -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ #endif
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #ifdef CONFIG_PCIE3 #define CONFIG_SYS_PCIE3_MEM_VIRT 0xa0000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc20000000ull -#else -#define CONFIG_SYS_PCIE3_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xa0000000 -#endif -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#else -#define CONFIG_SYS_PCIE3_IO_PHYS 0xf8020000 #endif + +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_PCI_INDIRECT_BRIDGE #endif
Hi Zhiqiang,
What about the #ifdef CONFIG_PHYS_64BIT part?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:49 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 13/47] powerpc: T102xRDB: Disable legacy PCIe driver when DM_PCI is enabled
Hi Zhiqiang,
0xc00000000ull
256M */
256M */
256M */
In the arch/powerpc/cpu/mpc85xx/Kconfig, all the T102x boards selected the CONFIG_PHYS_64BIT, so removed the #else...#endif part.
Thanks, Zhiqiang
256M */
256M */
startup */
Regards, Bin
Hi Zhiqiang,
On Tue, Aug 27, 2019 at 10:33 AM Z.q. Hou zhiqiang.hou@nxp.com wrote:
Hi Bin,
Hi Zhiqiang,
0xc00000000ull
256M */
256M */
256M */
Thanks for the clarification. With that info, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
Enable the DM PCIe driver in T1024RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/T1024RDB_NAND_defconfig | 4 ++++ configs/T1024RDB_SDCARD_defconfig | 4 ++++ configs/T1024RDB_SPIFLASH_defconfig | 4 ++++ configs/T1024RDB_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 30acd0e..faea7d2 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -60,6 +60,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 7569e4e..bce2fc3 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -59,6 +59,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 470674b..55f80f8 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -60,6 +60,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 146551d..f8b3227 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -48,6 +48,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/t104xrdb/pci.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/t104xrdb/pci.c b/board/freescale/t104xrdb/pci.c index 9fd6659..6b666ba 100644 --- a/board/freescale/t104xrdb/pci.c +++ b/board/freescale/t104xrdb/pci.c @@ -11,6 +11,7 @@ #include <fdt_support.h> #include <asm/fsl_serdes.h>
Add compatible string for T104x PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index 25df84d..c4b4ace 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -616,6 +616,7 @@ static struct fsl_pcie_data t2080_data = {
static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, + { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t4240", .data = (ulong)&t2080_data }, { }
T104x integrated 4 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/t104x.dtsi | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/arch/powerpc/dts/t104x.dtsi b/arch/powerpc/dts/t104x.dtsi index ff0da93..5998967 100644 --- a/arch/powerpc/dts/t104x.dtsi +++ b/arch/powerpc/dts/t104x.dtsi @@ -59,4 +59,52 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe240000 { + compatible = "fsl,pcie-t104x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe240000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; + + pcie@ffe250000 { + compatible = "fsl,pcie-t104x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe250000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x10000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; + + pcie@ffe260000 { + compatible = "fsl,pcie-t104x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe260000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; + + pcie@ffe270000 { + compatible = "fsl,pcie-t104x", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe270000 0x0 0x1000>; /* registers */ + law_trgt_if = <3>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8030000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x30000000 0x0 0x10000000>; /* non-prefetchable memory */ + }; };
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/T104xRDB.h | 38 ++++++++++++++++++++------------------ 1 file changed, 20 insertions(+), 18 deletions(-)
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 470f60a..5d9dd10 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -151,13 +151,11 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ #define CONFIG_PCIE4 /* PCIE controller 4 */
#define CONFIG_ENV_OVERWRITE @@ -530,51 +528,55 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg /* controller 1, direct to uli, tgtid 3, Base address 20000 */ #ifdef CONFIG_PCIE1 #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ #endif
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #ifdef CONFIG_PCIE2 #define CONFIG_SYS_PCIE2_MEM_VIRT 0x90000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc10000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ #endif
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #ifdef CONFIG_PCIE3 #define CONFIG_SYS_PCIE3_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ #endif
/* controller 4, Base address 203000 */ #ifdef CONFIG_PCIE4 #define CONFIG_SYS_PCIE4_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCIE4_IO_VIRT 0xf8030000 -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ #endif
+#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_PCI_INDIRECT_BRIDGE +#endif #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
Enable the DM PCIe driver in T1042D4RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/T1042D4RDB_NAND_defconfig | 4 ++++ configs/T1042D4RDB_SDCARD_defconfig | 4 ++++ configs/T1042D4RDB_SPIFLASH_defconfig | 4 ++++ configs/T1042D4RDB_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 2edd3b3..e51124b 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -58,6 +58,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index f5a8613..fa9b3e3 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -57,6 +57,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 945740a..fdec9a2 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -58,6 +58,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 3be988c..86c0a7f 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -46,6 +46,10 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Compile the legacy PCIe initialization reoutines for P1020, P1021, P1024, P1025 and P2020 RDB boards only when DM_PCI is not enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 4b151e8..5982a91 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -277,7 +277,7 @@ int checkboard(void) return 0; }
-#ifdef CONFIG_PCI +#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) void pci_init_board(void) { fsl_pcie_init_board(0); @@ -443,7 +443,9 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory(blob, (u64)base, (u64)size);
+#if !defined(CONFIG_DM_PCI) FT_FSL_PCI_SETUP; +#endif
#ifdef CONFIG_QE do_fixup_by_compat(blob, "fsl,qe", "status", "okay",
Add compatible string for PCIe of P1020, P1021, P1024, P1025 and P2020 SoCs.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_fsl.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index c4b4ace..c8b8e3b 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -608,6 +608,12 @@ static const struct dm_pci_ops fsl_pcie_ops = { .write_config = fsl_pcie_write_config, };
+static struct fsl_pcie_data p1_p2_data = { + .block_offset = 0xa000, + .block_offset_mask = 0xffff, + .stride = 0x1000, +}; + static struct fsl_pcie_data t2080_data = { .block_offset = 0x240000, .block_offset_mask = 0x3fffff, @@ -615,6 +621,7 @@ static struct fsl_pcie_data t2080_data = { };
static const struct udevice_id fsl_pcie_ids[] = { + { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data },
P1020 integrated 2 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 1.0a, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p1020-post.dtsi | 20 ++++++++++++++++++++ arch/powerpc/dts/p1020rdb-pc.dts | 12 ++++++++++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 12 ++++++++++++ arch/powerpc/dts/p1020rdb-pd.dts | 12 ++++++++++++ 4 files changed, 56 insertions(+)
diff --git a/arch/powerpc/dts/p1020-post.dtsi b/arch/powerpc/dts/p1020-post.dtsi index e1a4f50..1e5e678 100644 --- a/arch/powerpc/dts/p1020-post.dtsi +++ b/arch/powerpc/dts/p1020-post.dtsi @@ -25,3 +25,23 @@ last-interrupt-source = <255>; }; }; + +/* PCIe controller base address 0x9000 */ +&pci1 { + compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; + +/* PCIe controller base address 0xa000 */ +&pci0 { + compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; diff --git a/arch/powerpc/dts/p1020rdb-pc.dts b/arch/powerpc/dts/p1020rdb-pc.dts index fd68b8b..7ebaa61 100644 --- a/arch/powerpc/dts/p1020rdb-pc.dts +++ b/arch/powerpc/dts/p1020rdb-pc.dts @@ -18,6 +18,18 @@ soc: soc@ffe00000 { ranges = <0x0 0x0 0xffe00000 0x100000>; }; + + pci1: pcie@ffe09000 { + reg = <0x0 0xffe09000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc10000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xa0000000 0x0 0xa0000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pci0: pcie@ffe0a000 { + reg = <0x0 0xffe0a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc00000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0x80000000 0x0 0x80000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
/include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pc_36b.dts b/arch/powerpc/dts/p1020rdb-pc_36b.dts index a23d031..c0e5ef4 100644 --- a/arch/powerpc/dts/p1020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p1020rdb-pc_36b.dts @@ -18,6 +18,18 @@ soc: soc@fffe00000 { ranges = <0x0 0xf 0xffe00000 0x100000>; }; + + pci1: pcie@fffe09000 { + reg = <0xf 0xffe09000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0xf 0xffc10000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xc0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pci0: pcie@fffe0a000 { + reg = <0xf 0xffe0a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0xf 0xffc00000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0x80000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
/include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pd.dts b/arch/powerpc/dts/p1020rdb-pd.dts index 81f25a3..21174a0 100644 --- a/arch/powerpc/dts/p1020rdb-pd.dts +++ b/arch/powerpc/dts/p1020rdb-pd.dts @@ -18,6 +18,18 @@ soc: soc@ffe00000 { ranges = <0x0 0x0 0xffe00000 0x100000>; }; + + pci1: pcie@ffe09000 { + reg = <0x0 0xffe09000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc10000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xa0000000 0x0 0xa0000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pci0: pcie@ffe0a000 { + reg = <0x0 0xffe0a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc00000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0x80000000 0x0 0x80000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Hi Zhiqiang,
law_trgt_if = <1>;
#size-cells = <2>;
law_trgt_if = <2>;
#size-cells = <2>;
Why this is named as pci1?
Shouldn't the <reg> property be put in the dtsi file?
and this is pci0?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:50 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 22/47] P1020: dts: Added PCIe DT nodes
Hi Zhiqiang,
law_trgt_if = <1>;
#size-cells = <2>;
law_trgt_if = <2>;
#size-cells = <2>;
The P1020 reference manual said the first controller registers offset begin at 0xa000 and the second begin at 0x9000.
The registers starting addresses are different between 32bit and 36bit dts.
Thanks, Zhiqiang
and this is pci0?
Regards, Bin
Hi Zhiqiang,
On Tue, Aug 27, 2019 at 10:46 AM Z.q. Hou zhiqiang.hou@nxp.com wrote:
Hi Bin,
Hi Zhiqiang,
law_trgt_if = <1>;
#size-cells = <2>;
law_trgt_if = <2>;
#size-cells = <2>;
I see. But looks they are inconsistent. Some of the platforms put the reg in the dtsi, and some do not. I believe it's because some platforms force to select CONFIG_PHYS_64BIT hence no need to have two version of <reg> in DT?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月27日 10:59 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 22/47] P1020: dts: Added PCIe DT nodes
Hi Zhiqiang,
Hi Bin,
Priyanka
Hi Zhiqiang,
law_trgt_if = <1>;
#size-cells = <2>;
law_trgt_if = <2>;
#size-cells = <2>;
registers
Yes, you're right.
Thanks, Zhiqiang
Regards, Bin
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled for P1020, P1021, P1024, P1025 and P2020 RDB boards.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/p1_p2_rdb_pc.h | 36 +++++++++++++++++++++++------------- 1 file changed, 23 insertions(+), 13 deletions(-)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index b1367a9..d3fb3da 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -215,8 +215,6 @@
#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
#define CONFIG_ENV_OVERWRITE @@ -580,44 +578,56 @@ */
/* controller 2, direct to uli, tgtid 2, Base address 9000 */ -#define CONFIG_SYS_PCIE2_NAME "PCIe SLOT" #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull #else -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 #endif -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_IO_PHYS 0xfffc10000ull #else #define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 #endif -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */
/* controller 1, Slot 2, tgtid 1, Base address a000 */ -#define CONFIG_SYS_PCIE1_NAME "mini PCIe SLOT" #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull #else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 #endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xffc00000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_IO_PHYS 0xfffc00000ull #else #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 #endif + +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_SYS_PCIE2_NAME "PCIe SLOT" +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 +#else +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#endif +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +#define CONFIG_SYS_PCIE1_NAME "mini PCIe SLOT" +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#endif
Enable the DM PCIe driver in P1020RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P1020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_defconfig | 4 ++++ configs/P1020RDB-PC_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_defconfig | 4 ++++ configs/P1020RDB-PD_NAND_defconfig | 4 ++++ configs/P1020RDB-PD_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PD_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PD_defconfig | 4 ++++ 12 files changed, 48 insertions(+)
diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 8fce49d..557fb49 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -55,6 +55,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 80a4a0a..28ec227 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -52,6 +52,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index ee565d4..84b88ae 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -53,6 +53,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 7d7c55f..fea964d 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -42,6 +42,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index b729089..62199b9 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -54,6 +54,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 4622efd..f10e4fa 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -51,6 +51,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 9cd897f..bacae37 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -52,6 +52,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 595ff5f..0a6f974 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -41,6 +41,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index b45122d..2c41054 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -58,6 +58,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index c559879..7f0c7d4 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -55,6 +55,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 1de88fc..d664a09 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -56,6 +56,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 0963553..db78cf4 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -45,6 +45,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y
P2020 integrated 3 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 1.0a, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p2020-post.dtsi | 30 ++++++++++++++++++++++++++++++ arch/powerpc/dts/p2020rdb-pc.dts | 17 +++++++++++++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 17 +++++++++++++++++ 3 files changed, 64 insertions(+)
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index f20d1fa..f696f35 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -25,3 +25,33 @@ last-interrupt-source = <255>; }; }; + +/* PCIe controller base address 0x8000 */ +&pci2 { + compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; + +/* PCIe controller base address 0x9000 */ +&pci1 { + compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; + +/* PCIe controller base address 0xa000 */ +&pci0 { + compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; diff --git a/arch/powerpc/dts/p2020rdb-pc.dts b/arch/powerpc/dts/p2020rdb-pc.dts index 4800b76..08befd4 100644 --- a/arch/powerpc/dts/p2020rdb-pc.dts +++ b/arch/powerpc/dts/p2020rdb-pc.dts @@ -18,6 +18,23 @@ soc: soc@ffe00000 { ranges = <0x0 0x0 0xffe00000 0x100000>; }; + + pci2: pcie@ffe08000 { + reg = <0x0 0xffe08000 0x0 0x1000>; /* registers */ + status = "disabled"; + }; + + pci1: pcie@ffe09000 { + reg = <0x0 0xffe09000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc10000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xa0000000 0x0 0xa0000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pci0: pcie@ffe0a000 { + reg = <0x0 0xffe0a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xffc00000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0x80000000 0x0 0x80000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
/include/ "p2020-post.dtsi" diff --git a/arch/powerpc/dts/p2020rdb-pc_36b.dts b/arch/powerpc/dts/p2020rdb-pc_36b.dts index 8323b90..04b2519 100644 --- a/arch/powerpc/dts/p2020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p2020rdb-pc_36b.dts @@ -18,6 +18,23 @@ soc: soc@fffe00000 { ranges = <0x0 0xf 0xffe00000 0x100000>; }; + + pci2: pcie@fffe08000 { + reg = <0xf 0xffe08000 0x0 0x1000>; /* registers */ + status = "disabled"; + }; + + pci1: pcie@fffe09000 { + reg = <0xf 0xffe09000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0xf 0xffc10000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xc0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pci0: pcie@fffe0a000 { + reg = <0xf 0xffe0a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0xf 0xffc00000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0x80000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
pci0?
law_trgt_if = <0>;
#size-cells = <2>;
law_trgt_if = <1>;
#size-cells = <2>;
pci2?
law_trgt_if = <2>;
#size-cells = <2>;
put <reg> in dtsi?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:50 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 25/47] P2020: dts: Added PCIe DT nodes
pci0?
Describe the controller index and starting address according to P2020 RM.
law_trgt_if = <0>;
#size-cells = <2>;
law_trgt_if = <1>;
#size-cells = <2>;
pci2?
law_trgt_if = <2>;
#size-cells = <2>;
put <reg> in dtsi?
The same reason as P1020, see #22 of this series.
Thanks, Zhiqiang
Regards, Bin
Hi Zhiqiang,
On Tue, Aug 27, 2019 at 10:52 AM Z.q. Hou zhiqiang.hou@nxp.com wrote:
Hi Bin,
pci0?
OK, so will this weird index number (2, 1, 0) break the index calculation log in the following patch? http://patchwork.ozlabs.org/patch/1152811/
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月27日 10:56 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 25/47] P2020: dts: Added PCIe DT nodes
Hi Zhiqiang,
Hi Bin,
Priyanka
pci0?
No, the code handled this.
Thanks, Zhiqiang
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatch work.ozlabs.org%2Fpatch%2F1152811%2F&data=02%7C01%7Czhiqian g.hou%40nxp.com%7Cb20f64bf19f445e50ce108d72a9a160a%7C686ea1d3b c2b4c6fa92cd99c5c301635%7C0%7C0%7C637024713598549064&sdat a=WG5PXoeY0zriaxdITqzOJ%2BnT65uzrQ%2FUtwi4JuykXnA%3D&reser ved=0
Regards, Bin
Enable the DM PCIe driver in P2020RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P2020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_defconfig | 4 ++++ configs/P2020RDB-PC_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_defconfig | 4 ++++ 8 files changed, 32 insertions(+)
diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index d8c04e2..a51a34c 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -60,6 +60,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 7c45996..9c97b3d 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -57,6 +57,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 5372d98..fee83e5 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -58,6 +58,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 79f4f3c..bb5c6bd 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -47,6 +47,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 2f91691..610bd96 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -59,6 +59,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index a5cee06..46d430c 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -56,6 +56,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index a2f9d87..f3eb66e 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -57,6 +57,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 4000459..b94c67e 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -46,6 +46,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_SYS_NS16550=y
Compile the legacy PCIe initialization reoutines for P2041RDB, P3041, P4080, P5020 and P5040 DS boards only when DM_PCI is not enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/common/p_corenet/pci.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/common/p_corenet/pci.c b/board/freescale/common/p_corenet/pci.c index a2df928..a6abe66 100644 --- a/board/freescale/common/p_corenet/pci.c +++ b/board/freescale/common/p_corenet/pci.c @@ -11,6 +11,7 @@ #include <fdt_support.h> #include <asm/fsl_serdes.h>
+#if !defined(CONFIG_DM_PCI) void pci_init_board(void) { fsl_pcie_init_board(0); @@ -20,3 +21,4 @@ void pci_of_setup(void *blob, bd_t *bd) { FT_FSL_PCI_SETUP; } +#endif
Add compatible string for P2041 PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index c8b8e3b..61f08e7 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -614,6 +614,12 @@ static struct fsl_pcie_data p1_p2_data = { .stride = 0x1000, };
+static struct fsl_pcie_data p2041_data = { + .block_offset = 0x200000, + .block_offset_mask = 0x3fffff, + .stride = 0x1000, +}; + static struct fsl_pcie_data t2080_data = { .block_offset = 0x240000, .block_offset_mask = 0x3fffff, @@ -622,6 +628,7 @@ static struct fsl_pcie_data t2080_data = {
static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, + { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data },
P2041 integrated 3 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p2041.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/powerpc/dts/p2041.dtsi b/arch/powerpc/dts/p2041.dtsi index 9aa0422..55f7adc 100644 --- a/arch/powerpc/dts/p2041.dtsi +++ b/arch/powerpc/dts/p2041.dtsi @@ -60,4 +60,40 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe200000 { + compatible = "fsl,pcie-p2041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe200000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe201000 { + compatible = "fsl,pcie-p2041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe201000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe202000 { + compatible = "fsl,pcie-p2041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe202000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x40000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/P2041RDB.h | 55 +++++++++++++--------------------------------- 1 file changed, 15 insertions(+), 40 deletions(-)
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index b433308..ba670d7 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -37,7 +37,6 @@ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
#define CONFIG_SYS_SRIO @@ -354,60 +353,21 @@ unsigned long get_board_sys_clk(unsigned long dummy);
/* controller 1, direct to uli, tgtid 3, Base address 20000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 -#endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#else -#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 -#endif -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#else -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 -#endif -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#else -#define CONFIG_SYS_PCIE2_IO_PHYS 0xf8010000 -#endif -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull -#else -#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc0000000 -#endif -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#else -#define CONFIG_SYS_PCIE3_IO_PHYS 0xf8020000 -#endif -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */
/* Qman/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 @@ -489,7 +449,22 @@ unsigned long get_board_sys_clk(unsigned long dummy); #endif
#ifdef CONFIG_PCI +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#endif
missing CONFIG_PHYS_64BIT?
Regards, Bin
Hi Bin,
Thanks a lot for your comments!
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:50 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 30/47] powerpc: P2041RDB: Disable legacy PCIe driver when DM_PCI is enabled
code */
resources */
512M */
512M */
512M */
The P2041RDB board selected CONFIG_PHYS_64BIT, so removed these unused macros.
Thanks, Zhiqiang
512M */
512M */
512M */
startup */
Regards, Bin
Enable the DM PCIe driver in P2041RDB defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P2041RDB_NAND_defconfig | 4 ++++ configs/P2041RDB_SDCARD_defconfig | 4 ++++ configs/P2041RDB_SPIFLASH_defconfig | 4 ++++ configs/P2041RDB_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 73baf49..43434aa 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -41,6 +41,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index d75f8b1..8d0efa4 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 925f0cd..eadb35b 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 1923b7a..8208907 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -39,6 +39,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Add compatible string for P3041 PCIe.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/pci/pcie_fsl.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index 61f08e7..a4e0cd1 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -629,6 +629,7 @@ static struct fsl_pcie_data t2080_data = { static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, + { .compatible = "fsl,pcie-p3041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data },
P3041 integrated 4 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p3041.dtsi | 48 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/arch/powerpc/dts/p3041.dtsi b/arch/powerpc/dts/p3041.dtsi index 7d5c713..197896d 100644 --- a/arch/powerpc/dts/p3041.dtsi +++ b/arch/powerpc/dts/p3041.dtsi @@ -60,4 +60,52 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe200000 { + compatible = "fsl,pcie-p3041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe200000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe201000 { + compatible = "fsl,pcie-p3041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe201000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe202000 { + compatible = "fsl,pcie-p3041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe202000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x40000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe203000 { + compatible = "fsl,pcie-p3041", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe203000 0x0 0x1000>; /* registers */ + law_trgt_if = <3>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8030000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x60000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/corenet_ds.h | 63 +++++++++++++------------------------------- 1 file changed, 19 insertions(+), 44 deletions(-)
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index f974291..07844c1 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
#define CONFIG_ENV_OVERWRITE @@ -362,68 +361,25 @@
/* controller 4, Base address 203000 */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc60000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
/* Qman/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 @@ -505,7 +461,26 @@ #endif
#ifdef CONFIG_PCI +#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ +#endif
CONFIG_PHYS_64BIT?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 22:50 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Wolfgang Denk wd@denx.de; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [U-Boot] [PATCH 34/47] powerpc: corenet_ds: Disable legacy PCIe driver when DM_PCI is enabled
code */
resources */
512M */
512M */
512M */
512M */
CONFIG_PHYS_64BIT?
All CORENET DS boards selected PHYS_64BIT, so removed these unused macros.
Thanks, Zhiqiang
512M */
512M */
512M */
512M */
startup */
Regards, Bin
Enable the DM PCIe driver in P3041DS defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P3041DS_NAND_defconfig | 4 ++++ configs/P3041DS_SDCARD_defconfig | 4 ++++ configs/P3041DS_SPIFLASH_defconfig | 4 ++++ configs/P3041DS_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index b315840..87958db 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -41,6 +41,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 50dee40..90a0efe 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 984ff5f..7682877 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 5728cbb..ce9289f 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -39,6 +39,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Add compatible string for P4080 PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index a4e0cd1..f61e39e 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -630,6 +630,7 @@ static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-p3041", .data = (ulong)&p2041_data }, + { .compatible = "fsl,pcie-p4080", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data },
P4080 integrated 3 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p4080.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/powerpc/dts/p4080.dtsi b/arch/powerpc/dts/p4080.dtsi index 7c8dbae..ab76680 100644 --- a/arch/powerpc/dts/p4080.dtsi +++ b/arch/powerpc/dts/p4080.dtsi @@ -80,4 +80,40 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe200000 { + compatible = "fsl,pcie-p4080", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe200000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe201000 { + compatible = "fsl,pcie-p4080", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe201000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe202000 { + compatible = "fsl,pcie-p4080", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe202000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x40000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Enable the DM PCIe driver in P4080DS defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P4080DS_SDCARD_defconfig | 4 ++++ configs/P4080DS_SPIFLASH_defconfig | 4 ++++ configs/P4080DS_defconfig | 4 ++++ 3 files changed, 12 insertions(+)
diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 0aaf09a..5e5b30c 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 3a91df2..29560f3 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index d89d69f..aa42a0b 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -39,6 +39,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Add compatible string for P5040 PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index f61e39e..1411b1f 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -631,6 +631,7 @@ static const struct udevice_id fsl_pcie_ids[] = { { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-p3041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-p4080", .data = (ulong)&p2041_data }, + { .compatible = "fsl,pcie-p5040", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-t102x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t104x", .data = (ulong)&t2080_data }, { .compatible = "fsl,pcie-t2080", .data = (ulong)&t2080_data },
P5040 integrated 3 PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 2.0, and this patch is to add DT node for each PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p5040.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/powerpc/dts/p5040.dtsi b/arch/powerpc/dts/p5040.dtsi index b6f6c5d..8ab123d 100644 --- a/arch/powerpc/dts/p5040.dtsi +++ b/arch/powerpc/dts/p5040.dtsi @@ -59,4 +59,40 @@ clock-frequency = <0x0>; }; }; + + pcie@ffe200000 { + compatible = "fsl,pcie-p5040", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe200000 0x0 0x1000>; /* registers */ + law_trgt_if = <0>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8000000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x00000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe201000 { + compatible = "fsl,pcie-p5040", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe201000 0x0 0x1000>; /* registers */ + law_trgt_if = <1>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8010000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; + + pcie@ffe202000 { + compatible = "fsl,pcie-p5040", "fsl,pcie-fsl-qoriq"; + reg = <0xf 0xfe202000 0x0 0x1000>; /* registers */ + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; + ranges = <0x01000000 0x0 0x00000000 0xf 0xf8020000 0x0 0x00010000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x40000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Enable the DM PCIe driver in P5040DS defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P5040DS_NAND_defconfig | 4 ++++ configs/P5040DS_SDCARD_defconfig | 4 ++++ configs/P5040DS_SPIFLASH_defconfig | 4 ++++ configs/P5040DS_defconfig | 4 ++++ 4 files changed, 16 insertions(+)
diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index cbccb4c..bab7561 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -42,6 +42,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index cdefb2d..517708a 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -41,6 +41,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index c636b16..cb019f2 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -41,6 +41,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 6572ff1..31a8fca 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -40,6 +40,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_SPI=y
Compile the legacy PCIe initialization reoutines only when DM_PCI is not enabled.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/mpc8548cds/mpc8548cds.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 7d819d8..2799b5b 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -164,7 +164,7 @@ void lbc_sdram_init(void) #endif /* enable SDRAM init */ }
-#if defined(CONFIG_PCI) || defined(CONFIG_PCI1) +#if (defined(CONFIG_PCI) || defined(CONFIG_PCI1)) && !defined(CONFIG_DM_PCI) /* For some reason the Tundra PCI bridge shows up on itself as a * different device. Work around that by refusing to configure it. */ @@ -189,6 +189,7 @@ static struct pci_config_table pci_mpc85xxcds_config_table[] = { static struct pci_controller pci1_hose; #endif /* CONFIG_PCI */
+#if !defined(CONFIG_DM_PCI) void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -268,6 +269,7 @@ void pci_init_board(void)
fsl_pcie_init_board(first_free_busno); } +#endif
void configure_rgmii(void) { @@ -349,7 +351,7 @@ int board_eth_init(bd_t *bis) return pci_eth_init(bis); }
-#if defined(CONFIG_OF_BOARD_SETUP) +#if defined(CONFIG_OF_BOARD_SETUP) && !defined(CONFIG_DM_PCI) void ft_pci_setup(void *blob, bd_t *bd) { FT_FSL_PCI_SETUP;
Disable legacy PCI and PCIe fixup when CONFIG_DM_PCI is selected.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/common/cds_pci_ft.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/freescale/common/cds_pci_ft.c b/board/freescale/common/cds_pci_ft.c index 3ff2fa4..fb2e5c7 100644 --- a/board/freescale/common/cds_pci_ft.c +++ b/board/freescale/common/cds_pci_ft.c @@ -9,6 +9,7 @@ #include "cadmus.h"
#if defined(CONFIG_OF_BOARD_SETUP) +#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) static void cds_pci_fixup(void *blob) { int node; @@ -61,11 +62,12 @@ static void cds_pci_fixup(void *blob) } } } +#endif
int ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); -#ifdef CONFIG_PCI +#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) ft_pci_setup(blob, bd); cds_pci_fixup(blob); #endif
Add compatible string for MPC8548 PCIe.
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index 1411b1f..112f3b9 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -627,6 +627,7 @@ static struct fsl_pcie_data t2080_data = { };
static const struct udevice_id fsl_pcie_ids[] = { + { .compatible = "fsl,pcie-mpc8548", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, { .compatible = "fsl,pcie-p3041", .data = (ulong)&p2041_data },
MPC8548 integrated a PCIe controllers, which is compatible with the PCI Express™ Base Specification, Revision 1.0a, and this patch is to add DT node for the PCIe controller.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/mpc8548-post.dtsi | 9 +++++++++ arch/powerpc/dts/mpc8548cds.dts | 6 ++++++ arch/powerpc/dts/mpc8548cds_36b.dts | 6 ++++++ 3 files changed, 21 insertions(+)
diff --git a/arch/powerpc/dts/mpc8548-post.dtsi b/arch/powerpc/dts/mpc8548-post.dtsi index 5533a4b..2206f2d 100644 --- a/arch/powerpc/dts/mpc8548-post.dtsi +++ b/arch/powerpc/dts/mpc8548-post.dtsi @@ -25,3 +25,12 @@ last-interrupt-source = <255>; }; }; + +&pcie { + compatible = "fsl,pcie-mpc8548", "fsl,pcie-fsl-qoriq"; + law_trgt_if = <2>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + bus-range = <0x0 0xff>; +}; diff --git a/arch/powerpc/dts/mpc8548cds.dts b/arch/powerpc/dts/mpc8548cds.dts index cceea34..3b927bd 100644 --- a/arch/powerpc/dts/mpc8548cds.dts +++ b/arch/powerpc/dts/mpc8548cds.dts @@ -18,6 +18,12 @@ soc: soc8548@e0000000 { ranges = <0x0 0x0 0xe0000000 0x100000>; }; + + pcie: pcie@e000a000 { + reg = <0x0 0xe000a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0x0 0xe3000000 0x0 0x00100000 /* downstream I/O */ + 0x02000000 0x0 0xa0000000 0x0 0xa0000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
/include/ "mpc8548-post.dtsi" diff --git a/arch/powerpc/dts/mpc8548cds_36b.dts b/arch/powerpc/dts/mpc8548cds_36b.dts index faff35c..98d7c24 100644 --- a/arch/powerpc/dts/mpc8548cds_36b.dts +++ b/arch/powerpc/dts/mpc8548cds_36b.dts @@ -18,6 +18,12 @@ soc: soc8548@fe0000000 { ranges = <0x0 0xf 0xe0000000 0x100000>; }; + + pcie: pcie@fe000a000 { + reg = <0xf 0xe000a000 0x0 0x1000>; /* registers */ + ranges = <0x01000000 0x0 0x00000000 0xf 0xe3000000 0x0 0x00100000 /* downstream I/O */ + 0x02000000 0x0 0xe0000000 0xc 0x20000000 0x0 0x20000000>; /* non-prefetchable memory */ + }; };
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/MPC8548CDS.h | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 4252fbe..4809bbd 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -18,8 +18,6 @@ #define CONFIG_PCI1 /* PCI controller 1 */ #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #undef CONFIG_PCI2 -#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE 1 /* indirect PCI bridge support */ #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
#define CONFIG_ENV_OVERWRITE @@ -343,24 +341,18 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
#ifdef CONFIG_PCIE1 -#define CONFIG_SYS_PCIE1_NAME "Slot" #define CONFIG_SYS_PCIE1_MEM_VIRT 0xa0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc20000000ull #else -#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xa0000000 #endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xe3000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_IO_PHYS 0xfe3000000ull #else #define CONFIG_SYS_PCIE1_IO_PHYS 0xe3000000 #endif -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */ #endif
/* @@ -386,6 +378,20 @@ extern unsigned long get_clock_freq(void); #undef CONFIG_EEPRO100 #undef CONFIG_TULIP
+#if !defined(CONFIG_DM_PCI) +#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_PCI_INDIRECT_BRIDGE 1 +#define CONFIG_SYS_PCIE1_NAME "Slot" +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */ +#endif + #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
Enable the DM PCIe driver in MPC8548CDS defconfig.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/MPC8548CDS_36BIT_defconfig | 4 ++++ configs/MPC8548CDS_defconfig | 4 ++++ configs/MPC8548CDS_legacy_defconfig | 4 ++++ 3 files changed, 12 insertions(+)
diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index f259f19..102716b 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -26,6 +26,10 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_CONS_INDEX=2 diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 72239da..9cccb60 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -25,6 +25,10 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_CONS_INDEX=2 diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index f2420c3..782f827 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -25,6 +25,10 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_CONS_INDEX=2
Bin Meng
Hou Zhiqiang
Z.q. Hou
