[U-Boot] u boot error
i am trying to build the uboot for at91sam9xeek board.But while building the uboot by using cross compiler it gives some error from start.s file.Please let me know how can I correct it.
I tried the same for at91sam9260 board also.I gives the same error.
arm-linux-as -o start.o start.s start.s: Assembler messages: start.s:387: Error: symbol `irq' is already defined start.s:393: Error: symbol `fiq' is already defined make[1]: *** [start.o] Error 1 make[1]: Leaving directory `/root/test/ubootAtmel/uBootNew/u-boot-1.3.4/u-boot-1.3.4/cpu/arm926ejs
Dear VOC,
I cannot confirm this. Current code builds just fine:
MAKEALL_LOGDIR=/work/wd/tmp-arm-LOG \ BUILD_DIR=/work/wd/tmp-arm \ ./MAKEALL at91sam9xeek ... with environment variable in SPI DATAFLASH CS1 Configuring for at91sam9xeek board... cpu.c:26:2: warning: #warning Your board is using legacy SoC access. Please update! text data bss dec hex filename 170718 7563 267520 445801 6cd69 /work/wd/tmp-arm/u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings or errors: 1 ( at91sam9xeek ) ----------------------------------------------------------
I am using uboot and atmel patch from http://://www.at91.com/linux4sam/bin/view/Linux4SAM/U-Boot http://://www.at91.com/linux4sam/bin/view/Linux4SAM/U-Boot . I hope I' not doing some mistakes.
wd wrote:
Dear VOC,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The biggest difference between time and space is that you can't reuse time. - Merrick Furst _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
http://old.nabble.com/file/p29023668/UBOOTERROR UBOOTERROR
Dear VOC,
Please do not top post / full quote. Make sure to read http://www.netmeister.org/news/learn2quote.html
Well, as I told you, the code builds fine in mainline, which is what we support here.
Please either use mainline code, or direct your complaints to the responsible developers at www.at91.com, but not here.
Thanks.
VOC
