[U-Boot] TI:OMAP: [ PATCH 2/4 ] Configure PRCM registers to support 720 Mhz
From 1bb1a2441e6f54f3fe7d71e30da3bc22732aa7d3 Mon Sep 17 00:00:00 2001
From: Syed Mohammed Khasim khasim@ti.com Date: Tue, 5 Jan 2010 20:28:01 +0530 Subject: [PATCH] Configure PRCM registers to support 720 Mhz on Beagle REV C4 and Latest OMAP3530 ES version
Signed-off-by: Syed Mohammed Khasim khasim@ti.com --- board/ti/beagle/beagle.c | 9 +++++++-- cpu/arm_cortexa8/omap3/clock.c | 22 ++++++++++++++++++++++ drivers/power/twl4030.c | 21 +++++++++++++++++++++ 3 files changed, 50 insertions(+), 2 deletions(-)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 17840cf..d76df30 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -122,9 +122,16 @@ int misc_init_r(void) struct gpio *gpio5_base = (struct gpio *)OMAP34XX_GPIO5_BASE; struct gpio *gpio6_base = (struct gpio *)OMAP34XX_GPIO6_BASE;
+ beagle_identify(); + twl4030_power_init(); twl4030_led_init();
+ if (beagle_revision == REVISION_C4) { + twl4030_power_init_es3_720(); + prcm_config_720mhz(); + } + /* Configure GPIOs to output */ writel(~(GPIO23 | GPIO10 | GPIO8 | GPIO2 | GPIO1), &gpio6_base->oe); writel(~(GPIO31 | GPIO30 | GPIO29 | GPIO28 | GPIO22 | GPIO21 | @@ -136,8 +143,6 @@ int misc_init_r(void) writel(GPIO31 | GPIO30 | GPIO29 | GPIO28 | GPIO22 | GPIO21 | GPIO15 | GPIO14 | GPIO13 | GPIO12, &gpio5_base->setdataout);
- beagle_identify(); - dieid_num_r();
return 0; diff --git a/cpu/arm_cortexa8/omap3/clock.c b/cpu/arm_cortexa8/omap3/clock.c index 174c453..ab96a46 100644 --- a/cpu/arm_cortexa8/omap3/clock.c +++ b/cpu/arm_cortexa8/omap3/clock.c @@ -402,3 +402,25 @@ void per_clocks_enable(void)
sdelay(1000); } + +/* + * Configure PRCM registers to get 720 Mhz + * + * NOTE: N value doesn't change, only M gets affected + */ + +void prcm_config_720mhz (void) +{ + struct prcm *prcm_base = (struct prcm *)PRCM_BASE; + + /* Unlock MPU DPLL (slows things down, and needed later) */ + sr32(&prcm_base->clken_pll_mpu, 0, 3, PLL_LOW_POWER_BYPASS); + wait_on_value(ST_MPU_CLK, 0, &prcm_base->idlest_pll_mpu, LDELAY); + + /* Set M */ + sr32(&prcm_base->clksel1_pll_mpu, 8, 11, 0x2D0); + + /* lock mode */ + sr32(&prcm_base->clken_pll_mpu, 0, 3, PLL_LOCK); + wait_on_value(ST_MPU_CLK, 1, &prcm_base->idlest_pll_mpu, LDELAY); +} diff --git a/drivers/power/twl4030.c b/drivers/power/twl4030.c index eb066cb..fa1c7d5 100644 --- a/drivers/power/twl4030.c +++ b/drivers/power/twl4030.c @@ -68,6 +68,8 @@ void twl4030_power_reset_init(void) #define DEV_GRP_ALL 0xE0 #define VPLL2_VSEL_18 0x05 #define VDAC_VSEL_18 0x03 +#define VAUX2_VSEL_18 0x05 +#define VDD1_VSEL_14 0x40
void twl4030_power_init(void) { @@ -113,3 +115,22 @@ void twl4030_power_mmc_init(void) twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte, TWL4030_PM_RECEIVER_VMMC1_DEDICATED); } + +void twl4030_power_init_es3_720(void) +{ + unsigned char byte; + + /* VAUX2 needs to be 1.8v */ + byte = DEV_GRP_P1; + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte, + TWL4030_PM_RECEIVER_VAUX2_DEV_GRP); + + byte = VAUX2_VSEL_18; + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte, + TWL4030_PM_RECEIVER_VAUX2_DEDICATED); + + /* Put VSEL for VDD1 to 1.4v to get 720Mhz */ + byte = VDD1_VSEL_14; + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte, + TWL4030_PM_RECEIVER_VDD1_VSEL); +}
On Tue, Jan 5, 2010 at 10:11 AM, Khasim Syed Mohammed khasim@beagleboard.org wrote:
From 1bb1a2441e6f54f3fe7d71e30da3bc22732aa7d3 Mon Sep 17 00:00:00 2001 From: Syed Mohammed Khasim khasim@ti.com Date: Tue, 5 Jan 2010 20:28:01 +0530 Subject: [PATCH] Configure PRCM registers to support 720 Mhz on Beagle REV C4 and Latest OMAP3530 ES version
watch the subject length ;)..
no commit message?
Why do you need to bump up to 720Mhz in u-boot? can't you do that as part of dvfs in kernel? wont that be better? can't you do a standard boot or is this device never capable of OPP3?
- if (beagle_revision == REVISION_C4) {
- twl4030_power_init_es3_720();
- prcm_config_720mhz();
dieid_num_r();
sdelay(1000); }
- Configure PRCM registers to get 720 Mhz
- NOTE: N value doesn't change, only M gets affected
unwanted EOL?
you are assuming 3430 ONLY support here, how abt 3630 and family?
- struct prcm *prcm_base = (struct prcm *)PRCM_BASE;
- /* Unlock MPU DPLL (slows things down, and needed later) */
- sr32(&prcm_base->clken_pll_mpu, 0, 3, PLL_LOW_POWER_BYPASS);
- wait_on_value(ST_MPU_CLK, 0, &prcm_base->idlest_pll_mpu, LDELAY);
- /* Set M */
- sr32(&prcm_base->clksel1_pll_mpu, 8, 11, 0x2D0);
- /* lock mode */
- sr32(&prcm_base->clken_pll_mpu, 0, 3, PLL_LOCK);
- wait_on_value(ST_MPU_CLK, 1, &prcm_base->idlest_pll_mpu, LDELAY);
naming is confusing - is it 4030 or 3530 ES you are trying to describe here?
- unsigned char byte;
- /* VAUX2 needs to be 1.8v */
- byte = DEV_GRP_P1;
- twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte,
- TWL4030_PM_RECEIVER_VAUX2_DEV_GRP);
- byte = VAUX2_VSEL_18;
- TWL4030_PM_RECEIVER_VAUX2_DEDICATED);
- /* Put VSEL for VDD1 to 1.4v to get 720Mhz */
- byte = VDD1_VSEL_14;
- TWL4030_PM_RECEIVER_VDD1_VSEL);
huh? you may want to NOT do this, instead introduce a generic voltage rail API which is called from silicon/board specific file.
-- 1.5.6.3
Regards, Nishanth Menon
On Wed, Jan 6, 2010 at 12:48 AM, Nishanth Menon menon.nishanth@gmail.com wrote:
no commit message?
Will correct these :)
Question is why not in u-boot as well ?? Kernel can do its own stuff later and this device supports the same.
dieid_num_r();
sdelay(1000); }
unwanted EOL?
noted, will change.
Not sure, I don't have a 3630 version of a board, if some one wants to add support for the same, I am open. For now I will focus on 3430 / 3530 versions.
- /* Set M */
- /* lock mode */
yeah, looks bit confusing. Will change it to an appropriate one.
Already there are three levels of APIs, I don't mind adding another one. Will do that.
Thanks a lot for the review. will re-submit this patch.
Regards, Khasim
On Wed, Jan 6, 2010 at 12:28 PM, Khasim Syed Mohammed khasim@beagleboard.org wrote:
no commit message?
dieid_num_r();
sdelay(1000); }
unwanted EOL?
noted, will change.
- /* Set M */
- /* lock mode */
I have resubmitted this patch after incorporating review comments with the subject,
TI:OMAP:[PATCH 2/4] Support 720Mhz configuration for OMAP35xx
Regards, Khasim
Nishanth Menon
