[U-Boot] [PATCH] armv8: fsl-layerscape: Add DPAA1 QBMan support
Add Queue Manager and Buffer Manager support for NXP Layerscape devices based on DPAA1. This includes LS1043A and LS1046A devices.
Roy Pledge (1): fsl_qman: Implement device tree fixup for QBMan on ARM processors
arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 89 ++++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 3 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 + include/configs/ls1043a_common.h | 2 + 4 files changed, 96 insertions(+)
-- 1.7.9.5
Add support for device tree fixup for the DPAA1 QBMan nodes in ARM platforms
Signed-off-by: Roy Pledge roy.pledge@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 89 ++++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 3 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 + include/configs/ls1043a_common.h | 2 + 4 files changed, 96 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 1a8321b..aedf0e7 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -25,6 +25,8 @@ #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #include <asm/armv8/sec_firmware.h> #endif +#include <asm/io.h> +#include <asm/arch/speed.h>
int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -32,6 +34,80 @@ int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) phy_string_for_interface(phyc)); }
+#if defined(CONFIG_SYS_DPAA_QBMAN) + +#define BMAN_IP_REV_1 0xBF8 +#define BMAN_IP_REV_2 0xBFC +void fdt_fixup_bportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + + u32 rev_1 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_1); + u32 rev_2 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal"); + while (off != -FDT_ERR_NOTFOUND) { + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + + off = fdt_node_offset_by_compatible(blob, off, + "fsl,bman-portal"); + } +} + +#define QMAN_IP_REV_1 0xBF8 +#define QMAN_IP_REV_2 0xBFC +void fdt_fixup_qportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + u32 rev_1 = in_be32(CONFIG_SYS_FSL_QMAN_ADDR + QMAN_IP_REV_1); + u32 rev_2 = in_be32(CONFIG_SYS_FSL_QMAN_ADDR + QMAN_IP_REV_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,qman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); + while (off != -FDT_ERR_NOTFOUND) { + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + off = fdt_node_offset_by_compatible(blob, off, + "fsl,qman-portal"); + } +} +#endif + #ifdef CONFIG_MP void ft_fixup_cpu(void *blob) { @@ -145,6 +221,12 @@ void ft_cpu_setup(void *blob, bd_t *bd) #endif #endif
+#if defined(CONFIG_SYS_DPAA_QBMAN) + struct sys_info sysinfo; + + get_sys_info(&sysinfo); +#endif + #ifdef CONFIG_MP ft_fixup_cpu(blob); #endif @@ -165,6 +247,13 @@ void ft_cpu_setup(void *blob, bd_t *bd) fdt_fixup_esdhc(blob, bd); #endif
+#if defined(CONFIG_SYS_DPAA_QBMAN) + fdt_fixup_bportals(blob); + fdt_fixup_qportals(blob); + do_fixup_by_compat_u32(blob, "fsl,qman", + "clock-frequency", sysinfo.freq_qman, 1); +#endif + #ifdef CONFIG_SYS_DPAA_FMAN fdt_fixup_fman_firmware(blob); #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 55005f0..cf10a78 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -158,6 +158,9 @@ void get_sys_info(struct sys_info *sys_info)
sys_info->freq_localbus = sys_info->freq_systembus / ccr; #endif +#ifdef CONFIG_SYS_DPAA_QBMAN + sys_info->freq_qman = sys_info->freq_systembus; +#endif }
int get_clocks(void) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d88543d..b85ef3a 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -23,6 +23,8 @@ #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00ee00b0) #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) +#define CONFIG_SYS_FSL_BMAN_ADDR (CONFIG_SYS_IMMR + 0x00890000) +#define CONFIG_SYS_FSL_QMAN_ADDR (CONFIG_SYS_IMMR + 0x00880000) #define CONFIG_SYS_FSL_FMAN_ADDR (CONFIG_SYS_IMMR + 0x00a00000) #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_DCFG_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 0fd69bf..faf79eb 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -176,6 +176,8 @@
#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */
+#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ + /* FMan ucode */ #define CONFIG_SYS_DPAA_FMAN #ifdef CONFIG_SYS_DPAA_FMAN
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 1a8321b..aedf0e7 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -25,6 +25,8 @@ #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #include <asm/armv8/sec_firmware.h> #endif +#include <asm/io.h> +#include <asm/arch/speed.h> int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -32,6 +34,80 @@ int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) phy_string_for_interface(phyc)); } +#if defined(CONFIG_SYS_DPAA_QBMAN)
- int off, err;
- unsigned int maj, min;
- unsigned int ip_cfg;
- u32 rev_1 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_1);
- u32 rev_2 = in_be32(CONFIG_SYS_FSL_BMAN_ADDR + BMAN_IP_REV_2);
- char compat[64];
- int compat_len;
- maj = (rev_1 >> 8) & 0xff;
- min = rev_1 & 0xff;
- ip_cfg = rev_2 & 0xff;
- compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u",
- compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1;
- off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal");
- while (off != -FDT_ERR_NOTFOUND) {
compat_len);
if (err < 0) {
%s\n",
fdt_strerror(err));
return;
"fsl,bman-portal");
Please share code with PPC rather than duplicating it.
-Scott
Roy Pledge
Scott Wood
