[U-Boot-Users] Mixing CFI and non-CFI flashs?
I am currently porting u-boot to multiple IXP425-based boards that have accumulated here over the time. One of them has a slight problem, because it uses a combination of two flash roms: - one 8-bit SST 39VF020 boot flash on a 8-bit chip select as boot flash - one 16-bit Intel 64MBit flash on a 16-bit chip select.
The intel flash is CFI, while the SST flash is not. I want to use both flash roms, and I want to use as much of the existing flash code as possible. It seems that when using the CFI code, there is no easy way to add a non-CFI flash - right?
What would be the best way to use both flash roms? I have come up with:
(1) provide a hook in cfi_flash.c to insert hardcoded values into the flash_info structure for the non-CFI flash rom. Due to differences between CFI-AMD and non-CFI AMD flash command cycles, I need to add a new commandset (eg. CFI_CMDSET_AMD_LEGACY) plus a bit of handler code.
(2) rename all external-visible functions in flash_cfi.c and add wrapper functions that call either the CFI code or my own code for the non-CFI flash. This has the disadvantage that I need to duplicate code that is already present in cfi_flash.c, but is not exported. I have ssen this done on one chip vendor's u-boot port, and it does not really look nice.
(3) extend the code in cfi_flash.c so that external functions can be added via function pointers for non-CFI flashs. Same disadvantage as (2).
I have implemented solution (1) now, and it seems to work quite well, with minimal code needed in the board-setup file, but maybe there are better ways to do this - comments?
cu Michael
Hi Michael,
Correct. This is currently known limitation.
I remember a discussion we had a while ago, about supporting non-CFI chips in a common driver, but I can't find the mails right now. IIRC, the idea was to add something close to the Linux JEDEC probe (drivers/mtd/chips/jedec_probe.c) for this.
I suggest that you post your current version for review. This sounds like a start in the correct direction.
Thanks.
Best regards, Stefan
Good idea. I currently hard-coded the flash parameters for the boot flash, since I know there is exactly one type on the boards, but having jedec-probing would be nicer.
I think the CFI driver is a good start as a framework - all the infrastructure for handling mutliple banks, different chip/bus mappings etc. is there and could be used by jedec-flash code. For now, it is probably easiest to add the JEDEC code to cfi_flash.c, to get access to the static functions defined there, and then later split it out if necessary.
Fine. Here is what I have got now - it works for my board, but would probably need some cleanup/renaming of symbols. The basic idea is that the board-specific code provides a function "flash_detect_legacy" that is called for every flash bank, which can provide hardcoded (or in the future jedec-probed) flash information. If the function returns 0, the normal CFI code is called.
Since that code is board-specific anyway, I think the board-specific code can supply the information about chipwidth, buswidth etc. - there is no real benefit in autoprobing these, and there is less probability for problems (like 8-bit accesses to a 16-bit bus causing problems, etc.).
I have included one non-conditional patch I made: @@ -1282,6 +1310,8 @@ ulong flash_get_size (ulong base, int banknum) which causes the CFI code to stop in case CFG_MAX_FLASH_SECT is defined too small - without that patch, u-boot overwrites other data and crashes silently during startup.
cu Michael
Signed-off-by: Michael Schwingen michael@schwingen.org
diff --git a/include/flash.h b/include/flash.h index b0bf733..f0ef6f7 100644 --- a/include/flash.h +++ b/include/flash.h @@ -101,6 +101,11 @@ extern void flash_read_user_serial(flash_info_t * info, void * buffer, int offse extern void flash_read_factory_serial(flash_info_t * info, void * buffer, int offset, int len); #endif /* CFG_FLASH_PROTECTION */
+#ifdef CFG_FLASH_CFI_LEGACY +extern ulong flash_detect_legacy(ulong base, int banknum); +#define CFI_CMDSET_AMD_LEGACY 0xFFF0 +#endif + /*----------------------------------------------------------------------- * return codes from flash_write(): */
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index 5579a1e..20ccc3a 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -345,7 +345,13 @@ unsigned long flash_init (void) /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; - size += flash_info[i].size = flash_get_size (bank_base[i], i); + +#ifdef CFG_FLASH_CFI_LEGACY + flash_info[i].size = flash_detect_legacy (bank_base[i], i); + if (flash_info[i].size == 0) +#endif + flash_info[i].size = flash_get_size (bank_base[i], i); + size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", @@ -488,6 +494,16 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_ERASE_START); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); + break; +#endif default: debug ("Unkown flash vendor %d\n", info->vendor); @@ -518,8 +534,12 @@ void flash_print_info (flash_info_t * info)
printf ("CFI conformant FLASH (%d x %d)", (info->portwidth << 3), (info->chipwidth << 3)); - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); + if (info->size < 1024*1024) + printf (" Size: %ld kB in %d Sectors\n", + info->size >> 10, info->sector_count); + else + printf (" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); printf (" "); switch (info->vendor) { case CFI_CMDSET_INTEL_STANDARD: @@ -534,6 +554,11 @@ void flash_print_info (flash_info_t * info) case CFI_CMDSET_AMD_EXTENDED: printf ("AMD Extended"); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + printf ("AMD (non-CFI)"); + break; +#endif default: printf ("Unknown (%d)", info->vendor); break; @@ -777,6 +802,9 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif retval = flash_toggle (info, sect, 0, AMD_STATUS_TOGGLE); break; default: @@ -1282,6 +1310,8 @@ ulong flash_get_size (ulong base, int banknum) debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) + break; info->start[sect_cnt] = sector; sector += (erase_region_size * size_ratio);
@@ -1387,6 +1417,12 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, flash_unlock_seq (info, 0); flash_write_cmd (info, 0, AMD_ADDR_START, AMD_CMD_WRITE); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_WRITE); +#endif }
switch (info->portwidth) {
and then in the board-init code:
extern flash_info_t flash_info[]; #define AMD_CMD_RESET 0xF0
ulong flash_detect_legacy(ulong base, int banknum) { if (banknum == 0) { flash_info_t *info = &flash_info[banknum]; int i; unsigned long sector;
info->portwidth = 1; info->chipwidth = 1; info->ext_addr = 0; info->cfi_version = 0; info->legacy_unlock = 0; info->start[0] = base; info->cmd_reset = AMD_CMD_RESET; info->vendor = CFI_CMDSET_AMD_LEGACY; info->flash_id = FLASH_MAN_CFI;
info->sector_count = 64;
for (i = 0, sector = base; i < info->sector_count; i++) { info->protect[i] = 0; info->start[i] = sector; sector += 4096; }
info->buffer_size = 1; info->erase_blk_tout = 10000; info->buffer_write_tout = 1000; info->write_tout = 100; return 256*1024; } else return 0; }
Hi Michael,
Yes, I think this is ok for now.
Good catch. I remember seeing a patch dealing with this problem before.
Please find some first comments below.
cu Michael
- return codes from flash_write():
I don't like the indentation problem we get from this #ifdef here. Perhaps we should add a __weak__ function flash_detect_legacy() in this file, that can be overridden by board specific functions. Like this:
ulong __flash_detect_legacy(ulong base, int banknum) { return 0; } ulong flash_detect_legacy(ulong base, int banknum) __attribute__((weak, alias("__flash_detect_legacy")));
This way we get rid of the #ifdef too.
break;
- if (info->size < 1024*1024)
- else
printf (" "); switch (info->vendor) { case CFI_CMDSET_INTEL_STANDARD:info->size >> 20, info->sector_count);
break;
- case CFI_CMDSET_AMD_LEGACY:
break;
Please add an error output here too.
Looks good otherwise. Thanks.
Hm - I need some common code at that point, which would otherwise be duplicated in every board code. I have now moved the code to a function flash_detect_legacy.
break;
Done.
Okey, next version. The board-specific code may either fill out the complete flash_info struct as in the previous patch, or (preferred), only set info->portwidth, info->chipwidth and info->interface, in which case the code will probe the flash by jedec IDs and look up a table in jedec_flash.c. The table is a near copy of the table in the Linux jedec_flash.c, with the removal of some unused fields.
There is one problem with the AMD_ADDR_* definitions: I believe they are only correct for 16-bit flash ROMS (in 8/16 bit mode), but are wrong for 8-bit flashs. I think the CFI "interface" parameter should be the correct way to distinguish these cases. What is left is the number of bits in the unlock addresses - I have used 0x2AAA/0x5555, since all flash roms I know treat the upper bits as "don't care" (and specify that behaviour in the datasheet), so if the flash datasheet specifies 0xAAA/0x555, using the longer constants should do no harm. However, there are probably lots of flash roms I do *not* know, so I would appreciate feedback on this. If different addresses are really necessary, we would need to add them to the flash_info struct.
This currently works on my IXP425 board (big endian) with one SST39VF020 and one Intel TE28F640J3. I am not sure if the jedec flash code is correct in case of 16-bit JEDEC flashs or multiple 8-bit flash roms on a wider data bus.
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index 5579a1e..399deab 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -98,9 +98,9 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
-#define AMD_ADDR_ERASE_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_ACK ((info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA) +#define AMD_ADDR_ERASE_START ((info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) ? 0x2AAA : 0x5555) +#define AMD_ADDR_START ((info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) ? 0x2AAA : 0x5555) +#define AMD_ADDR_ACK ((info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) ? 0x5555 : 0x2AAA)
#define FLASH_OFFSET_MANUFACTURER_ID 0x00 #define FLASH_OFFSET_DEVICE_ID 0x01 @@ -331,6 +331,43 @@ ulong flash_read_long (flash_info_t * info, flash_sect_t sect, uint offset) }
+#ifdef CFG_FLASH_CFI_LEGACY +ulong flash_detect_legacy(ulong base, int banknum) +{ + flash_info_t *info = &flash_info[banknum]; + if (board_flash_get_legacy(base, banknum, info)) { + /* board code may have filled info completely. If not, we + use JEDEC ID probing. */ + if (!info->vendor) { + int modes[] = { CFI_CMDSET_AMD_STANDARD, CFI_CMDSET_INTEL_STANDARD }; + int i; + + for(i=0; i<sizeof(modes)/sizeof(modes[0]); i++) { + info->vendor = modes[i]; + info->start[0] = base; + flash_read_jedec_ids(info); + debug("JEDEC PROBE: ID %x %x %x\n", info->manufacturer_id, info->device_id, info->device_id2); + if (jedec_flash_match(info, base)) + break; + } + } + switch(info->vendor) { + case CFI_CMDSET_AMD_LEGACY: + info->cmd_reset = AMD_CMD_RESET; + break; + } + info->flash_id = FLASH_MAN_CFI; + } + return info->size; +} +#else +ulong inline flash_detect_legacy(ulong base, int banknum) +{ + return 0; +} +#endif + + /*----------------------------------------------------------------------- */ unsigned long flash_init (void) @@ -345,7 +382,11 @@ unsigned long flash_init (void) /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; - size += flash_info[i].size = flash_get_size (bank_base[i], i); + + flash_detect_legacy (bank_base[i], i); + if (flash_info[i].size == 0) + flash_info[i].size = flash_get_size (bank_base[i], i); + size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", @@ -488,6 +529,16 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_ERASE_START); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); + break; +#endif default: debug ("Unkown flash vendor %d\n", info->vendor); @@ -518,8 +569,12 @@ void flash_print_info (flash_info_t * info)
printf ("CFI conformant FLASH (%d x %d)", (info->portwidth << 3), (info->chipwidth << 3)); - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); + if (info->size < 1024*1024) + printf (" Size: %ld kB in %d Sectors\n", + info->size >> 10, info->sector_count); + else + printf (" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); printf (" "); switch (info->vendor) { case CFI_CMDSET_INTEL_STANDARD: @@ -534,6 +589,11 @@ void flash_print_info (flash_info_t * info) case CFI_CMDSET_AMD_EXTENDED: printf ("AMD Extended"); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + printf ("AMD (non-CFI)"); + break; +#endif default: printf ("Unknown (%d)", info->vendor); break; @@ -777,6 +837,9 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif retval = flash_toggle (info, sect, 0, AMD_STATUS_TOGGLE); break; default: @@ -1282,6 +1345,10 @@ ulong flash_get_size (ulong base, int banknum) debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } info->start[sect_cnt] = sector; sector += (erase_region_size * size_ratio);
@@ -1387,6 +1454,12 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, flash_unlock_seq (info, 0); flash_write_cmd (info, 0, AMD_ADDR_START, AMD_CMD_WRITE); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_write_cmd (info, 0, 0x5555, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, 0, 0x2AAA, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, 0, 0x5555, AMD_CMD_WRITE); +#endif }
switch (info->portwidth) { diff --git a/include/flash.h b/include/flash.h index b0bf733..c4d8ded 100644 --- a/include/flash.h +++ b/include/flash.h @@ -101,6 +101,12 @@ extern void flash_read_user_serial(flash_info_t * info, void * buffer, int offse extern void flash_read_factory_serial(flash_info_t * info, void * buffer, int offset, int len); #endif /* CFG_FLASH_PROTECTION */
+#ifdef CFG_FLASH_CFI_LEGACY +extern ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info); +extern int jedec_flash_match(flash_info_t *info, ulong base); +#define CFI_CMDSET_AMD_LEGACY 0xFFF0 +#endif + /*----------------------------------------------------------------------- * return codes from flash_write(): */
new file jedec_flash.c:
/* * (C) Copyright 2007 * Michael Schwingen, michael@schwingen.org * * based in great part on jedec_probe.c from linux kernel: * (C) 2000 Red Hat. GPL'd. * Occasionally maintained by Thayne Harbaugh tharbaugh at lnxi dot com * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA * */
/* The DEBUG define must be before common to enable debugging */ #define DEBUG
#include <common.h> #include <asm/processor.h> #include <asm/io.h> #include <asm/byteorder.h> #include <environment.h>
#if defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY
#define P_ID_AMD_STD CFI_CMDSET_AMD_LEGACY
/* Manufacturers */ #define MANUFACTURER_SST 0x00BF
/* SST */ #define SST39LF800 0x2781 #define SST39LF160 0x2782 #define SST39VF1601 0x234b #define SST39LF512 0x00D4 #define SST39LF010 0x00D5 #define SST39LF020 0x00D6 #define SST39LF040 0x00D7 #define SST39SF010A 0x00B5 #define SST39SF020A 0x00B6
struct amd_flash_info { const __u16 mfr_id; const __u16 dev_id; const char *name; const int NumEraseRegions; const int CmdSet; const ulong regions[6]; };
#define ERASEINFO(size,blocks) (size<<8)|(blocks-1)
/* * Please keep this list ordered by manufacturer! * Fortunately, the list isn't searched often and so a * slow, linear search isn't so bad. */ static const struct amd_flash_info jedec_table[] = { { .mfr_id = MANUFACTURER_SST, .dev_id = SST39LF010, .name = "SST 39LF010", .CmdSet = P_ID_AMD_STD, .NumEraseRegions= 1, .regions = { ERASEINFO(0x01000,32), } }, { .mfr_id = MANUFACTURER_SST, .dev_id = SST39LF020, .name = "SST 39LF020", .CmdSet = P_ID_AMD_STD, .NumEraseRegions= 1, .regions = { ERASEINFO(0x01000,64), } }, { .mfr_id = MANUFACTURER_SST, .dev_id = SST39LF040, .name = "SST 39LF040", .CmdSet = P_ID_AMD_STD, .NumEraseRegions= 1, .regions = { ERASEINFO(0x01000,128), } } };
#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0]))
static inline void fill_info(flash_info_t *info, const struct amd_flash_info *jedec_entry, ulong base) { int i,j; int sect_cnt; int size_ratio; int total_size;
size_ratio = info->portwidth / info->chipwidth;
debug("Found JEDEC Flash: %s\n", jedec_entry->name); info->vendor = jedec_entry->CmdSet; /* Todo: do we need device-specific timeouts? */ info->erase_blk_tout = 30000; info->buffer_write_tout = 1000; info->write_tout = 100;
sect_cnt = 0; total_size = 0; for (i = 0; i < jedec_entry->NumEraseRegions; i++) { ulong erase_region_size = jedec_entry->regions[i] >> 8; ulong erase_region_count = (jedec_entry->regions[i] & 0xff) + 1;
total_size += erase_region_size * erase_region_count; debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { if (sect_cnt >= CFG_MAX_FLASH_SECT) { printf("ERROR: too many flash sectors\n"); break; } info->start[sect_cnt] = base; base += (erase_region_size * size_ratio); sect_cnt++; } } info->sector_count = sect_cnt; info->size = total_size * size_ratio; }
/*----------------------------------------------------------------------- * match jedec ids against table. If a match is found, fill flash_info entry */ int jedec_flash_match(flash_info_t *info, ulong base) { int ret = 0; int i; ulong mask = 0xFFFF; if (info->chipwidth == 1) mask = 0xFF;
for (i = 0; i < ARRAY_SIZE(jedec_table); i++) { if ( (jedec_table[i].mfr_id & mask) == (info->manufacturer_id & mask) && (jedec_table[i].dev_id & mask) == (info->device_id & mask)) { fill_info(info, &jedec_table[i], base); ret = 1; break; } } return ret; }
#endif /* defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY */
And finally, the board-specific code:
ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) { if (banknum == 0) { info->portwidth = 1; info->chipwidth = 1; info->interface = FLASH_CFI_X8; return 1; } else return 0; }
cu Michael
OK.
break;
Done.
Wouldn't it be better not to remove those unused fields? This way porting of new devices from Linux to U-Boot would be easier.
Correct. And this is the case in the current Linux implementation. So we should not remove it, even if we don't use it for now.
Thanks. Very nice work.
Right. I was concerned about the size of the table - the complete table from Linux contains *lots* of devices and may take up quite some space, so stripping out unused fields should help a bit. If there is a consensus to keep the fields to ease porting new parts, that is fine with me.
I think in the future we may need some ifdefs in the table to select sub-sets of supported parts - if a board has a 29LV040, it is useful to have support for other flash ROMS with similar layout and pinout that may be used as alternatives, but completely different parts (eg. 29LV160) may be left out.
cu Michael
I vote for keeping the fields in. From my point of view, it's better to only enable a small part of the available FLASH definitions, than to strip some fields from the struct and make porting more difficult.
ACK.
Okay. I changed the patch so that the device table entries can now be copied 1:1 from the Linux source.
Since there still is the problem of the different unlock addresses, I have moved the unlock address values to the flash_info_t struct - this gets rid of the non-abvious code in the AMD_ADDR_* macros, and allows to override these values without changing the behaviour of the CFI driver. I also added a name field so that the correct name can be printed in flinfo.
Now the only problem I see is the code in flash_erase, which is the only place where CFI_CMDSET_AMD_LEGACY needs different behaviour: the CFI code does the unlock sequence to the current sector address, while the jedec flash needs the unlock sequence to the flash base address. I believe the CFI behaviour is wrong (but works because the CFI flashs ignore the extra address bits), but I left the special case in - that way, there should be no change in the existing CFI code behaviour, so the patch should be safe to apply that way without breaking existing boards.
I will post the patch in a separate mail with PATCH: in the subject, so it is not lost deep in this thread.
The resulting output now looks like this:
Flash: 8.3 MB => flinfo
Bank # 1: SST 39LF020 FLASH (8 x 8) Size: 256 kB in 64 Sectors AMD Legacy command set, Manufacturer ID: 0xBF, Device ID: 0xD6 Erase timeout: 30000 ms, write timeout: 100 ms
Sector Start Addresses: 50000000 RO 50001000 RO 50002000 RO 50003000 RO 50004000 RO 50005000 RO 50006000 RO 50007000 RO 50008000 RO 50009000 RO 5000A000 RO 5000B000 RO 5000C000 RO 5000D000 RO 5000E000 RO 5000F000 RO 50010000 RO 50011000 RO 50012000 RO 50013000 RO 50014000 RO 50015000 RO 50016000 RO 50017000 RO 50018000 RO 50019000 RO 5001A000 RO 5001B000 RO 5001C000 RO 5001D000 RO 5001E000 RO 5001F000 RO 50020000 RO 50021000 RO 50022000 RO 50023000 RO 50024000 RO 50025000 RO 50026000 RO 50027000 RO 50028000 RO 50029000 RO 5002A000 RO 5002B000 RO 5002C000 RO 5002D000 RO 5002E000 RO 5002F000 RO 50030000 RO 50031000 RO 50032000 RO 50033000 RO 50034000 RO 50035000 RO 50036000 RO 50037000 E 50038000 E 50039000 E 5003A000 E 5003B000 E 5003C000 E 5003D000 E 5003E000 E 5003F000 RO
Bank # 2: CFI conformant FLASH (16 x 16) Size: 8 MB in 64 Sectors Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x17 Erase timeout: 16384 ms, write timeout: 2 ms Buffer write timeout: 2 ms, buffer size: 32 bytes
Sector Start Addresses: 51000000 51020000 51040000 51060000 51080000 510A0000 510C0000 510E0000 51100000 51120000 51140000 51160000 51180000 511A0000 511C0000 511E0000 51200000 51220000 51240000 51260000 51280000 512A0000 512C0000 512E0000 51300000 51320000 51340000 51360000 51380000 513A0000 513C0000 513E0000 51400000 51420000 51440000 51460000 51480000 514A0000 514C0000 514E0000 51500000 51520000 51540000 51560000 51580000 515A0000 515C0000 515E0000 51600000 51620000 51640000 51660000 51680000 516A0000 516C0000 516E0000 51700000 51720000 51740000 51760000 51780000 517A0000 517C0000 517E0000 =>
cu Michael
Michael Schwingen
rincewind@discworld.dascon.de
Stefan Roese
