[U-Boot] [PATCH v6 1/2] QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and CONFIG_SYS_QE_FW_ADDR
CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address.
Signed-off-by: Zhao Qiang B45475@freescale.com --- Changes for v2: - no Changes for v3: - no Changes for v4: - no Changes for v5: - modify CONFIG_SYS_QE_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR for kmp204x Changes for v6: - rebase
README | 9 +++++++-- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- drivers/net/fm/fm.c | 12 ++++++------ drivers/qe/qe.c | 2 +- include/configs/B4860QDS.h | 10 +++++----- include/configs/MPC8569MDS.h | 2 +- include/configs/P1023RDB.h | 2 +- include/configs/P1023RDS.h | 4 ++-- include/configs/P2041RDB.h | 10 +++++----- include/configs/T1040QDS.h | 8 ++++---- include/configs/T1040RDB.h | 8 ++++---- include/configs/T1042RDB_PI.h | 8 ++++---- include/configs/T208xQDS.h | 10 +++++----- include/configs/T208xRDB.h | 10 +++++----- include/configs/T4240EMU.h | 2 +- include/configs/T4240QDS.h | 10 +++++----- include/configs/corenet_ds.h | 10 +++++----- include/configs/km/km8309-common.h | 2 +- include/configs/km/kmp204x-common.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/p1_twr.h | 2 +- 21 files changed, 66 insertions(+), 61 deletions(-)
diff --git a/README b/README index 216f0c7..c49efee 100644 --- a/README +++ b/README @@ -4485,8 +4485,13 @@ This firmware often needs to be loaded during U-Boot booting, so macros are used to identify the storage device (NOR flash, SPI, etc) and the address within that device.
-- CONFIG_SYS_QE_FMAN_FW_ADDR - The address in the storage device where the firmware is located. The +- CONFIG_SYS_FMAN_FW_ADDR + The address in the storage device where the FMAN microcode is located. The + meaning of this address depends on which CONFIG_SYS_QE_FW_IN_xxx macro + is also specified. + +- CONFIG_SYS_QE_FW_ADDR + The address in the storage device where the QE microcode is located. The meaning of this address depends on which CONFIG_SYS_QE_FW_IN_xxx macro is also specified.
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 81aeadd..e0fb3e5 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -805,7 +805,7 @@ void cpu_secondary_init_r(void)
/* load QE firmware from NAND flash to DDR first */ ret = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_QE_FMAN_FW_IN_NAND, - &fw_length, (u_char *)CONFIG_SYS_QE_FMAN_FW_ADDR); + &fw_length, (u_char *)CONFIG_SYS_QE_FW_ADDR);
if (ret && ret == -EUCLEAN) { printf ("NAND read for QE firmware at offset %x failed %d\n", diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index bca20b3..400e9dd 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -350,16 +350,16 @@ int fm_init_common(int index, struct ccsr_fman *reg) { int rc; #if defined(CONFIG_SYS_QE_FMAN_FW_IN_NOR) - void *addr = (void *)CONFIG_SYS_QE_FMAN_FW_ADDR; + void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR; #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_NAND) size_t fw_length = CONFIG_SYS_QE_FMAN_FW_LENGTH; void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH);
- rc = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_QE_FMAN_FW_ADDR, + rc = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_FMAN_FW_ADDR, &fw_length, (u_char *)addr); if (rc == -EUCLEAN) { printf("NAND read of FMAN firmware at offset 0x%x failed %d\n", - CONFIG_SYS_QE_FMAN_FW_ADDR, rc); + CONFIG_SYS_FMAN_FW_ADDR, rc); } #elif defined(CONFIG_SYS_QE_FW_IN_SPIFLASH) struct spi_flash *ucode_flash; @@ -371,7 +371,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) if (!ucode_flash) printf("SF: probe for ucode failed\n"); else { - ret = spi_flash_read(ucode_flash, CONFIG_SYS_QE_FMAN_FW_ADDR, + ret = spi_flash_read(ucode_flash, CONFIG_SYS_FMAN_FW_ADDR, CONFIG_SYS_QE_FMAN_FW_LENGTH, addr); if (ret) printf("SF: read for ucode failed\n"); @@ -381,7 +381,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) int dev = CONFIG_SYS_MMC_ENV_DEV; void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); u32 cnt = CONFIG_SYS_QE_FMAN_FW_LENGTH / 512; - u32 blk = CONFIG_SYS_QE_FMAN_FW_ADDR / 512; + u32 blk = CONFIG_SYS_FMAN_FW_ADDR / 512; struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV);
if (!mmc) @@ -395,7 +395,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) flush_cache((ulong)addr, cnt * 512); } #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) - void *addr = (void *)CONFIG_SYS_QE_FMAN_FW_ADDR; + void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR; #else void *addr = NULL; #endif diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index b5ddc4b..b1da75e 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -165,7 +165,7 @@ void qe_init(uint qe_base) /* * Upload microcode to IRAM for those SOCs which do not have ROM in QE. */ - qe_upload_firmware((const void *)CONFIG_SYS_QE_FMAN_FW_ADDR); + qe_upload_firmware((const void *)CONFIG_SYS_QE_FW_ADDR);
/* enable the microcode in IRAM */ out_be32(&qe_immr->iram.iready,QE_IRAM_READY); diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index b248302..b9ec957 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -596,7 +596,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -604,10 +604,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1130) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -617,10 +617,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 58b9c26..5165a45 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -493,7 +493,7 @@ extern unsigned long get_clock_freq(void);
/* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xfff00000 +#define CONFIG_SYS_QE_FW_ADDR 0xfff00000
/* * BOOTP options diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index b41cb4a..d7274f1 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -360,7 +360,7 @@ extern unsigned long get_clock_freq(void); /* Default address of microcode for the Linux Fman driver */ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index 2ffa354..0ee75dc 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -500,10 +500,10 @@ extern unsigned long get_clock_freq(void); /* Default address of microcode for the Linux Fman driver */ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x1f00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x1f00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index b3880f1..f024c29 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -506,7 +506,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -514,10 +514,10 @@ unsigned long get_board_sys_clk(unsigned long dummy); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -527,10 +527,10 @@ unsigned long get_board_sys_clk(unsigned long dummy); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 993f9ae..84213b8 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -602,7 +602,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -610,13 +610,13 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1040RDB.h b/include/configs/T1040RDB.h index 395845b..7420db9 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T1040RDB.h @@ -517,7 +517,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -525,13 +525,13 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index 68656e6..a2af6b0 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -525,7 +525,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -533,13 +533,13 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 399ddbb..04527e3 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -552,7 +552,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -560,10 +560,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -573,10 +573,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 743eee3..66f8a4c 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -510,7 +510,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #define CONFIG_CORTINA_FW_ADDR 0x120000
#elif defined(CONFIG_SDCARD) @@ -520,12 +520,12 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #define CONFIG_CORTINA_FW_ADDR (512 * 1808)
#elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_CORTINA_FW_ADDR (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* @@ -536,11 +536,11 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #define CONFIG_CORTINA_FW_ADDR 0xFFE10000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #define CONFIG_CORTINA_FW_ADDR 0xEFE00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h index c81c457..ad5a9a6 100644 --- a/include/configs/T4240EMU.h +++ b/include/configs/T4240EMU.h @@ -98,7 +98,7 @@ #define CONFIG_SYS_INTERLAKEN
diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 56e1293..1b98cfd 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -375,7 +375,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -383,10 +383,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -396,10 +396,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 1e4bfc4..ca14558 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -509,7 +509,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -517,10 +517,10 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -530,10 +530,10 @@ * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/km/km8309-common.h b/include/configs/km/km8309-common.h index 29c6f60..c8df23b 100644 --- a/include/configs/km/km8309-common.h +++ b/include/configs/km/km8309-common.h @@ -27,7 +27,7 @@ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR /* at end of uboot partition, before env */ -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xF00B0000 +#define CONFIG_SYS_QE_FW_ADDR 0xF00B0000
/* * System IO Config diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 582978a..418e3d1 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -350,7 +350,7 @@ int get_scl(void); * ucode is stored after env, so we got 0x120000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x120000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x120000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 07b6179..d3a792a 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -772,7 +772,7 @@ #ifdef CONFIG_QE /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xefec0000 +#define CONFIG_SYS_QE_FW_ADDR 0xefec0000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #endif /* CONFIG_QE */
diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index c296a07..97ec593 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -348,7 +348,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #ifdef CONFIG_QE /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xefec0000 +#define CONFIG_SYS_QE_FW_ADDR 0xefec0000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #endif /* CONFIG_QE */
The u-qe of T1040 has addresses different from qe, modify those addresses value for both u-qe and qe.
Add function qe_board_setup to mux the bus to tdm or uart according to hwconfig.
Signed-off-by: Zhao Qiang B45475@freescale.com --- Changes for v2: - modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and CONFIG_SYS_QE_FW_ADDR Changes for v3: - use CONFIG_U_QE instead of CONFIG_PPC_T1040 Changes for v4: - ifdef CONFIG_U_QE, include "../../../../drivers/qe/qe.h" Changes for v5: - no Changes for v6: - rebase
arch/powerpc/cpu/mpc85xx/cpu_init.c | 11 +++++++++++ arch/powerpc/cpu/mpc85xx/qe_io.c | 2 +- arch/powerpc/cpu/mpc85xx/speed.c | 6 ++++++ arch/powerpc/cpu/mpc85xx/t1040_ids.c | 1 + arch/powerpc/include/asm/config_mpc85xx.h | 3 +++ arch/powerpc/include/asm/fsl_liodn.h | 4 ++++ arch/powerpc/include/asm/immap_85xx.h | 5 ++++- board/freescale/t1040qds/t1040qds.c | 31 +++++++++++++++++++++++++++++++ drivers/qe/qe.h | 2 ++ include/configs/T1040QDS.h | 3 +++ 10 files changed, 66 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index e0fb3e5..ec17745 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -33,6 +33,9 @@ #endif
#include "../../../../drivers/block/fsl_sata.h" +#ifdef CONFIG_U_QE +#include "../../../../drivers/qe/qe.h" +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -85,6 +88,7 @@ void fsl_erratum_a006261_workaround(struct ccsr_usb_phy __iomem *usb_phy)
#ifdef CONFIG_QE +#ifndef CONFIG_U_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign); @@ -107,6 +111,7 @@ static void config_qe_ioports(void) } } #endif +#endif
#ifdef CONFIG_CPM2 void config_8560_ioports (volatile ccsr_cpm_t * cpm) @@ -310,9 +315,11 @@ void cpu_init_f (void) m8560_cpm_reset(); #endif #ifdef CONFIG_QE +#ifndef CONFIG_U_QE /* Config QE ioports */ config_qe_ioports(); #endif +#endif #if defined(CONFIG_FSL_DMA) dma_init(); #endif @@ -798,7 +805,11 @@ int sata_initialize(void) void cpu_secondary_init_r(void) { #ifdef CONFIG_QE +#ifdef CONFIG_U_QE + uint qe_base = CONFIG_SYS_IMMR + 0x00140000; /* QE immr base */ +#else uint qe_base = CONFIG_SYS_IMMR + 0x00080000; /* QE immr base */ +#endif #ifdef CONFIG_SYS_QE_FMAN_FW_IN_NAND int ret; size_t fw_length = CONFIG_SYS_QE_FMAN_FW_LENGTH; diff --git a/arch/powerpc/cpu/mpc85xx/qe_io.c b/arch/powerpc/cpu/mpc85xx/qe_io.c index 76c60da..d2825ec 100644 --- a/arch/powerpc/cpu/mpc85xx/qe_io.c +++ b/arch/powerpc/cpu/mpc85xx/qe_io.c @@ -12,7 +12,7 @@ #include "asm/io.h" #include "asm/immap_85xx.h"
-#if defined(CONFIG_QE) +#if defined(CONFIG_QE) && !defined(CONFIG_U_QE) #define NUM_OF_PINS 32 void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign) { diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index adf09ef..25b967d 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -336,6 +336,12 @@ void get_sys_info(sys_info_t *sys_info)
#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
+#ifdef CONFIG_QE +#if defined(CONFIG_PPC_T1040) + sys_info->freq_qe = sys_info->freq_systembus / 2; +#endif +#endif + #else /* CONFIG_FSL_CORENET */ uint plat_ratio, e500_ratio, half_freq_systembus; int i; diff --git a/arch/powerpc/cpu/mpc85xx/t1040_ids.c b/arch/powerpc/cpu/mpc85xx/t1040_ids.c index 68160a9..1034cd4 100644 --- a/arch/powerpc/cpu/mpc85xx/t1040_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t1040_ids.c @@ -46,6 +46,7 @@ struct liodn_id_table liodn_tbl[] = { SET_DMA_LIODN(2, 227),
/* SET_NEXUS_LIODN(557), -- not yet implemented */ + SET_QE_LIODN(559), }; int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 9a20b97..943ca6f 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -734,6 +734,9 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_A006261 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 +#define QE_MURAM_SIZE 0x6000UL +#define MAX_QE_RISC 1 +#define QE_NUM_OF_SNUM 28
#elif defined(CONFIG_PPC_T2080) || defined(CONFIG_PPC_T2081) #define CONFIG_E6500 diff --git a/arch/powerpc/include/asm/fsl_liodn.h b/arch/powerpc/include/asm/fsl_liodn.h index 44bc88d..f658bcb 100644 --- a/arch/powerpc/include/asm/fsl_liodn.h +++ b/arch/powerpc/include/asm/fsl_liodn.h @@ -99,6 +99,10 @@ extern void fdt_fixup_liodn(void *blob); SET_GUTS_LIODN("fsl,esdhc", liodn, sdmmc##sdhcNum##liodnr,\ CONFIG_SYS_MPC85xx_ESDHC_OFFSET)
+#define SET_QE_LIODN(liodn) \ + SET_GUTS_LIODN("fsl,qe", liodn, qeliodnr,\ + CONFIG_SYS_MPC85xx_QE_OFFSET) + #define SET_QMAN_LIODN(liodn) \ SET_LIODN_ENTRY_1("fsl,qman", liodn, offsetof(ccsr_qman_t, liodnr) + \ CONFIG_SYS_FSL_QMAN_OFFSET, \ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 4b6f9d0..4bda0f1 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1889,7 +1889,9 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) u32 sata2liodnr; /* SATA 2 LIODN */ u32 sata3liodnr; /* SATA 3 LIODN */ u32 sata4liodnr; /* SATA 4 LIODN */ - u8 res22[32]; + u8 res22[24]; + u32 qeliodnr; /* QE LIODN */ + u8 res_57c[4]; u32 dma1liodnr; /* DMA 1 LIODN */ u32 dma2liodnr; /* DMA 2 LIODN */ u32 dma3liodnr; /* DMA 3 LIODN */ @@ -2877,6 +2879,7 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_IFC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 +#define CONFIG_SYS_MPC85xx_QE_OFFSET 0x140000 #define CONFIG_SYS_FSL_CORENET_RMAN_OFFSET 0x1e0000 #if defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) && !defined(CONFIG_PPC_B4860)\ && !defined(CONFIG_PPC_B4420) diff --git a/board/freescale/t1040qds/t1040qds.c b/board/freescale/t1040qds/t1040qds.c index 3dec447..a2a498a 100644 --- a/board/freescale/t1040qds/t1040qds.c +++ b/board/freescale/t1040qds/t1040qds.c @@ -18,6 +18,7 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h> #include <fm_eth.h> +#include <hwconfig.h>
#include "../common/qixis.h" #include "t1040qds.h" @@ -89,6 +90,32 @@ int select_i2c_ch_pca9547(u8 ch) return 0; }
+#ifdef CONFIG_T1040QDS +static void qe_board_setup(void) +{ + u8 brdcfg15, brdcfg9; + + if (hwconfig("qe") && hwconfig("tdm")) { + brdcfg15 = QIXIS_READ(brdcfg[15]); + /* + * TDMRiser uses QE-TDM + * Route QE_TDM signals to TDM Riser slot + */ + QIXIS_WRITE(brdcfg[15], brdcfg15 | 7); + } else if (hwconfig("qe") && hwconfig("uart")) { + brdcfg15 = QIXIS_READ(brdcfg[15]); + brdcfg9 = QIXIS_READ(brdcfg[9]); + /* + * Route QE_TDM signals to UCC + * ProfiBus controlled by UCC3 + */ + brdcfg15 &= 0xfc; + QIXIS_WRITE(brdcfg[15], brdcfg15 | 2); + QIXIS_WRITE(brdcfg[9], brdcfg9 | 4); + } +} +#endif + int board_early_init_r(void) { #ifdef CONFIG_SYS_FLASH_BASE @@ -196,6 +223,10 @@ int misc_init_r(void) } }
+#if defined(CONFIG_T1040QDS) + qe_board_setup(); +#endif + return 0; }
diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index c82ac7b..ebb7c5f 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -282,5 +282,7 @@ int qe_set_mii_clk_src(int ucc_num); int qe_upload_firmware(const struct qe_firmware *firmware); struct qe_firmware_info *qe_get_firmware_info(void); void ft_qe_setup(void *blob); +void qe_init(uint qe_base); +void qe_reset(void);
#endif /* __QE_H__ */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 84213b8..0340bb4 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -595,6 +595,8 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_DPAA_PME
+#define CONFIG_QE +#define CONFIG_U_QE /* Default address of microcode for the Linux Fman driver */ #if defined(CONFIG_SPIFLASH) /* @@ -617,6 +619,7 @@ unsigned long get_board_ddr_clk(void); #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_QE_FW_ADDR 0xEFF10000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
Zhao Qiang
