[U-Boot] Please pull from u-boot-i2c/next
Hello Tom,
please pull from u-boot-i2c next
There is patch "[v2] bootcounter: add DM support for memory based bootcounter" http://patchwork.ozlabs.org/patch/1247674/
which was assigned to me, not really i2c related, but I added it to this pull request. If you think, you should pick it up, I can remove it.
Travis build: https://travis-ci.org/github/hsdenx/u-boot-i2c/builds/662944932
The following changes since commit e24f0a39d0daa2d8c597650aeb3f559d44a195ae:
Merge branch '2020-03-12-rsa-improvements' into next (2020-03-12 12:45:27 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-i2c.git tags/20200316-for-next
for you to fetch changes up to 80e8b8add057d2c947394d9d57fc2dcc7ff886d1:
bootcounter: add DM support for memory based bootcounter (2020-03-16 08:05:00 +0100)
---------------------------------------------------------------- i2c: for next - i2c-gpio: make it possible to run deblock sequence on driver probe - i2c-gpio: add clock stretching support - updates the Designware I2C driver for high speed mode, fix a bug and add some improvements. - add DM support for memory based bootcounter driver
---------------------------------------------------------------- Heiko Schocher (1): bootcounter: add DM support for memory based bootcounter
Jun Chen (4): i2c: designware_i2c: Fix IC_CON register setting for high speed mode i2c: designware_i2c: check is high speed possible support i2c: designware_i2c: remove 'has_high_speed' i2c: designware_i2c: add 'hs_hcnt' and 'hs_lcnt' for high speed
Marek Vasut (5): i2c: Make deblock delay and SCL clock configurable i2c: Export i2c_deblock_gpio_loop() i2c: Add option to send start condition after deblocking i2c: gpio: Run deblock sequence on probe doc: i2c: gpio: Document deblock sequence on probe
Masahiro Yamada (2): misc: i2c_eeprom: remove pagewidth field from i2c_eeprom misc: i2c_eeprom: store pagesize instead of pagewidth in i2c_eeprom_drv_data
Michael Auchter (2): dm: i2c-gpio: add support for clock stretching dm: i2c-gpio: rework gpio get/set functions
doc/device-tree-bindings/i2c/i2c-gpio.txt | 4 +++ doc/device-tree-bindings/misc/bootcounter.txt | 21 +++++++++++++++ drivers/bootcount/Kconfig | 7 +++++ drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount.c | 92 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/designware_i2c.c | 18 ++++++++++--- drivers/i2c/designware_i2c.h | 9 +++++-- drivers/i2c/i2c-gpio.c | 170 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------------ drivers/i2c/i2c-uclass.c | 44 ++++++++++++++++++++++--------- drivers/misc/i2c_eeprom.c | 38 +++++++++++++------------- include/i2c.h | 18 +++++++++++++ include/i2c_eeprom.h | 2 -- 12 files changed, 315 insertions(+), 109 deletions(-) create mode 100644 doc/device-tree-bindings/misc/bootcounter.txt
On Tue, Mar 17, 2020 at 06:26:28AM +0100, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
