[U-Boot] [PATCH] i2c: fix: Add support for the Arm's Versatile Express I2C controller
accidentially while fixing merge errors for patch: https://lists.denx.de/pipermail/u-boot/2018-September/342278.html
missed to add files:
MAINTAINERS drivers/i2c/Kconfig drivers/i2c/Makefile
add them with this patch.
Signed-off-by: Heiko Schocher hs@denx.de ---
MAINTAINERS | 1 + drivers/i2c/Kconfig | 7 +++++++ drivers/i2c/Makefile | 1 + 3 files changed, 9 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index ace7d9a4b6..cc71a8f6be 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -453,6 +453,7 @@ M: Liviu Dudau liviu.dudau@foss.arm.com S: Supported T: git git://github.com/ARM-software/u-boot.git F: drivers/video/mali_dp.c +F: drivers/i2c/i2c-versatile.c
MICROBLAZE M: Michal Simek monstr@monstr.eu diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index ae3b501555..1ef22e6bcd 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -416,6 +416,13 @@ config SYS_I2C_UNIPHIER_F Support for UniPhier FIFO-builtin I2C controller driver. This I2C controller is used on PH1-Pro4 or newer UniPhier SoCs.
+config SYS_I2C_VERSATILE + bool "Arm Ltd Versatile I2C bus driver" + depends on DM_I2C && (TARGET_VEXPRESS_CA15_TC2 || TARGET_VEXPRESS64_JUNO) + help + Add support for the Arm Ltd Versatile Express I2C driver. The I2C host + controller is present in the development boards manufactured by Arm Ltd. + config SYS_I2C_MVTWSI bool "Marvell I2C driver" depends on DM_I2C diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index f2cbe78c53..d3637bcd8d 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -36,6 +36,7 @@ obj-$(CONFIG_SYS_I2C_STM32F7) += stm32f7_i2c.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o obj-$(CONFIG_SYS_I2C_UNIPHIER) += i2c-uniphier.o obj-$(CONFIG_SYS_I2C_UNIPHIER_F) += i2c-uniphier-f.o +obj-$(CONFIG_SYS_I2C_VERSATILE) += i2c-versatile.o obj-$(CONFIG_SYS_I2C_ZYNQ) += zynq_i2c.o obj-$(CONFIG_TEGRA186_BPMP_I2C) += tegra186_bpmp_i2c.o
Acked-by: Liviu Dudau liviu.dudau@foss.arm.com
- bool "Arm Ltd Versatile I2C bus driver"
- depends on DM_I2C && (TARGET_VEXPRESS_CA15_TC2 || TARGET_VEXPRESS64_JUNO)
- help
-- 2.14.4
Hello Heiko,
Am 11.10.2018 um 07:26 schrieb Heiko Schocher:
applied to u-boot-i2c.git master
bye, Heiko
- help
- config SYS_I2C_MVTWSI bool "Marvell I2C driver" depends on DM_I2C
Heiko Schocher
Liviu Dudau
