[U-Boot] [GIT PULL v2] Please pull u-boot-rockchip/master
Tom,
Here’s another pull-request for u-boot-rockchip. This one shows no regressions with Travis after fixing up a few more defconfig files and adjusting the target-list when the mxs-variant of the SPL ldscript should be used.
Regards, Phil.
The following changes since commit da0227f7d2568c0cb0e435ed3caf780f9846d9a0:
arm: omap: Fix 'get_device_type()' for OMAP34XX (2017-08-12 18:56:26 -0400)
git://git.denx.de/u-boot-rockchip.git master
for you to fetch changes up to 217273cd441fe3d00a1bdad143dcb656854963f9:
rockchip: clk: remove RATE_TO_DIV (2017-08-13 17:15:09 +0200)
---------------------------------------------------------------- Andy Yan (3): rockchip: add u-boot specific dts for rk3368 based boards rockchip: set Pre-reloc malloc pool size to 4kb for rk3368 based boards rockchip: remove the hard coded uart iomux setting for px5 evb
Kever Yang (6): rockchip: rk3288: fix EMMC_DIV_MASK definition in header rockchip: rk322x: set the DDR region as non-secure in SPL rockchip: dts: rk322x: add sdmmc device node rockchip: rk322x: update max-frequency for mmc node rockchip: clk: update dwmmc clock div rockchip: clk: remove RATE_TO_DIV
Klaus Goger (1): rockchip: board: puma_rk3399: rename ATF firmware
Philipp Tomsich (77): spl: add a 'return to bootrom' boot method spl: configure 'return to bootrom' separately for SPL and TPL rockchip: back-to-bootrom: add 'back-to-bootrom' support for AArch64 rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPL rockchip: back-to-bootrom: simplify the #ifdef-check for LIBCOMMON in TPL/SPL spl: use TPL_SYS_MALLOC_F_LEN for TPL spl: dm: Kconfig: fix help text for SPL/TPL confusion spl: dm: Kconfig: use more specific prereqs for SPL_REGMAP and SPL_SYSCON spl: dm: Kconfig: split REGMAP/SYSCON support for TPL from SPL spl: dm: Kconfig: SPL_RAM depends on SPL_DM spl: dm: Kconfig: introduce TPL_RAM (in analogy to SPL_RAM) spl: dm: Kconfig: SPL_CLK depends on SPL_DM spl: dm: Kconfig: split CLK support for SPL and TPL spl: dm: Kconfig: split OF_CONTROL and OF_PLATDATA between SPL and TPL spl: dm: use CONFIG_IS_ENABLED to test for the DM option armv8: move low-level assembly functions into function-sections armv8: spl: Support separate stack for TPL spl: allow a separate TEXT_BASE, LDSCRIPT and MAX_SIZE for TPL spl: Kconfig: split SYS_MALLOC_SIMPLE for TPL and SPL lib: spl: differentiate between TPL and SPL for libfdt/of_control/of_platdata spl: consistently use $(SPL_TPL_) to select features for SPL and TPL builds spl: add TPL_DRIVER_MISC_SUPPORT option drivers: spl: consistently use the $(SPL_TPL_) macro rockchip: Makefile: allow selective inclusion of sdram_common.o from TPL/SPL/U-Boot rockchip: rk3368: improve Kconfig text for the RK3368 rockchip: rk3368: mkimage: add support for the RK3368 rockchip: rk3368: pmugrf: add definitions for os_reg[0..3] rockchip: rk3368: spl: define COUNTER_FREQUENCY to 24MHz rockchip: rk3368: spl: add memory layout for TPL and SPL rockchip: rk3368: syscon: MSCH/PMUGRF/GRF support for OF_PLATDATA rockchip: rk3368: syscon: SGRF support for OF_PLATDATA rockchip: rk3368: grf: use shifted-constants rockchip: rk3368: dts: add sgrf node rockchip: pinctrl: rk3368: add GMAC (RGMII only) support rockchip: pinctrl: rk3368: add support for configuring the MMC pins rockchip: pinctrl: rk3368: move IOMUX bit-definitions to pinctrl driver rockchip: pinctrl: rk3368: add SPI support rockchip: clk: rk3368: implement bandwidth adjust for PLLs rockchip: clk: rk3368: support OF_PLATDATA for the RK3368 clk driver rockchip: clk: rk3368: do not change CPLL/GPLL before returning to BROM rockchip: clk: rk3368: implement DPLL (DRAM PLL) support rockchip: clk: rk3368: define DMA1_SRST_REQ and DMA2_SRST_REQ rockchip: clk: rk3368: implement MMC/SD clock reparenting rockchip: clk: rk3368: support configuring the DRAM PLL (from TPL) rockchip: clk: rk3368: add support for GMAC (SLCK_MAC) clock rockchip: clk: rk3368: mark 'priv' __maybe_unused in rk3368_clk_set_rate() rockchip: clk: rk3368: add support for configuring the SPI clocks net: gmac_rockchip: Add support for the RK3368 GMAC rockchip: Makefile: streamline SPL/TPL configuration rockchip: rk3368: add DRAM controller driver with DRAM initialisation rockchip: rk3368: dts: add DMC node in rk3368.dtsi rockchip: rk3368: spl: enable SPL_FRAMEWORK in rk3368_common.h rockchip: rk3368: spl: add TPL support rockchip: spl: make spl-boot-order code reusable (split from rk3399) rockchip: rk3368: spl: add SPL support rockchip: rk3368: spl: mark SPL and TPL as supported for ROCKCHIP_RK3368 rockchip: spi: enable support for the rk_spi driver for the RK3368 rockchip: board: lion-rk3368: add support for the RK3368-uQ7 spl: Kconfig: migrate $(SPL_TPL_)LDSCRIPT to Kconfig rockchip: Kconfig: preset TPL_LDSCRIPT via Kconfig for the RK3368 spl: support TPL_STACK, TPL_MAX_SIZE and TPL_TEXT_BASE via Kconfig armv8: TPL_STACK will always be defined, so test CONFIG_TPL_NEEDS_SEPARATE_STACK rockchip: rk3368: mark TPL as not inheriting its stack, text-base and size from SPL moveconfig: migrate TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZE rockchip: board: puma-rk3399: fix warnings in puma_rk3399/fit_spl_atf.its configs: mpc85xx: fix fallout from SPL/TPL changes timer: add OF_PLATDATA support for timer-uclass dm: timer: normalise SPL and TPL support rockchip: timer: add device-model timer driver for RK3368 (and similar) dts: rk3368: make timer0 accessible for SPL and TPL rockchip: lion-rk3368: defconfig: enable DM timer for all stages rockchip: rk3368: remove setup of secure timer from TPL/SPL rockchip: rk3188: rock: adjust for SPL/TPL split spl: add hierarchical defaults for SPL_LDSCRIPT spl: moveconfig: remove SPL_LDSCRIPT definitions for header-files rockchip: rk3368: spl: move SPL_LDSCRIPT to Kconfig scripts: setlocalversion: safely extract variables from auto.conf using awk
Kconfig | 12 +- Makefile | 3 +- arch/arm/Kconfig | 12 ++ arch/arm/cpu/armv8/Makefile | 2 + arch/arm/cpu/armv8/cache.S | 22 +++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 + arch/arm/cpu/armv8/tlb.S | 4 +- arch/arm/cpu/armv8/transition.S | 6 + arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3229-evb.dts | 11 ++ arch/arm/dts/rk322x.dtsi | 66 ++++++- arch/arm/dts/rk3368-geekbox-u-boot.dtsi | 34 ++++ arch/arm/dts/rk3368-lion-u-boot.dtsi | 93 ++++++++++ arch/arm/dts/rk3368-lion.dts | 195 +++++++++++++++++++ arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 34 ++++ arch/arm/dts/rk3368-sheep-u-boot.dtsi | 34 ++++ arch/arm/dts/rk3368.dtsi | 30 ++- arch/arm/include/asm/arch-rockchip/cru_rk3288.h | 2 +- arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 15 +- arch/arm/include/asm/arch-rockchip/ddr_rk3368.h | 187 +++++++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 326 +------------------------------- arch/arm/include/asm/spl.h | 1 + arch/arm/lib/crt0_64.S | 4 +- arch/arm/mach-at91/Kconfig | 4 + arch/arm/mach-davinci/Kconfig | 4 + arch/arm/mach-exynos/Kconfig | 3 + arch/arm/mach-omap2/Kconfig | 3 + arch/arm/mach-orion5x/Kconfig | 3 + arch/arm/mach-rockchip/Kconfig | 55 +++++- arch/arm/mach-rockchip/Makefile | 47 +++-- arch/arm/mach-rockchip/bootrom.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 5 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3188/Kconfig | 3 - arch/arm/mach-rockchip/rk322x-board-spl.c | 4 + arch/arm/mach-rockchip/rk3288-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3288-board.c | 4 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 78 ++++++++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 157 ++++++++++++++++ arch/arm/mach-rockchip/rk3368/Kconfig | 24 +++ arch/arm/mach-rockchip/rk3368/Makefile | 1 - arch/arm/mach-rockchip/rk3368/sdram_rk3368.c | 60 ------ arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 44 +++++ arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds | 13 ++ arch/arm/mach-rockchip/rk3399-board-spl.c | 106 +---------- arch/arm/mach-rockchip/save_boot_param.S | 37 ++++ arch/arm/mach-rockchip/spl-boot-order.c | 108 +++++++++++ arch/arm/mach-sunxi/Kconfig | 3 + arch/arm/mach-zynq/Kconfig | 3 + arch/microblaze/Kconfig | 3 + board/armadeus/apf27/Kconfig | 3 + board/freescale/mx31pdk/Kconfig | 3 + board/rockchip/evb_px5/evb-px5.c | 24 --- board/spear/x600/Kconfig | 3 + board/theobroma-systems/lion_rk3368/Kconfig | 15 ++ board/theobroma-systems/lion_rk3368/MAINTAINERS | 10 + board/theobroma-systems/lion_rk3368/Makefile | 7 + board/theobroma-systems/lion_rk3368/README | 60 ++++++ board/theobroma-systems/lion_rk3368/fit_spl_atf.its | 51 +++++ board/theobroma-systems/lion_rk3368/lion_rk3368.c | 25 +++ board/theobroma-systems/puma_rk3399/README | 2 +- board/theobroma-systems/puma_rk3399/fit_spl_atf.its | 20 +- common/Makefile | 10 +- common/spl/Kconfig | 116 ++++++++++-- common/spl/Makefile | 35 ++-- common/spl/spl.c | 7 +- common/spl/spl_bootrom.c | 27 +++ configs/C29XPCIE_NAND_defconfig | 3 +- configs/P1010RDB-PA_36BIT_NAND_defconfig | 4 +- configs/P1010RDB-PA_NAND_defconfig | 4 +- configs/P1010RDB-PB_36BIT_NAND_defconfig | 4 +- configs/P1010RDB-PB_NAND_defconfig | 3 +- configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 +- configs/P1020RDB-PC_NAND_defconfig | 3 +- configs/P1020RDB-PD_NAND_defconfig | 3 +- configs/P1021RDB-PC_36BIT_NAND_defconfig | 3 +- configs/P1021RDB-PC_NAND_defconfig | 3 +- configs/P1022DS_36BIT_NAND_defconfig | 3 +- configs/P1022DS_NAND_defconfig | 2 +- configs/P1024RDB_NAND_defconfig | 3 +- configs/P1025RDB_NAND_defconfig | 2 +- configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P2020RDB-PC_NAND_defconfig | 3 +- configs/chromebook_link64_defconfig | 2 +- configs/evb-px5_defconfig | 1 + configs/evb-rk3229_defconfig | 2 +- configs/evb-rk3288_defconfig | 2 +- configs/fennec-rk3288_defconfig | 2 +- configs/firefly-rk3288_defconfig | 2 +- configs/geekbox_defconfig | 1 + configs/lion-rk3368_defconfig | 95 ++++++++++ configs/miqi-rk3288_defconfig | 2 +- configs/phycore-rk3288_defconfig | 2 +- configs/popmetal-rk3288_defconfig | 2 +- configs/qemu-x86_64_defconfig | 2 +- configs/rock2_defconfig | 2 +- configs/rock_defconfig | 4 +- configs/sheep-rk3368_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 +- doc/README.rockchip | 2 +- doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt | 67 +++++++ drivers/Makefile | 39 ++-- drivers/clk/Kconfig | 12 +- drivers/clk/Makefile | 2 +- drivers/clk/rockchip/clk_rk3036.c | 9 +- drivers/clk/rockchip/clk_rk3188.c | 15 +- drivers/clk/rockchip/clk_rk322x.c | 14 +- drivers/clk/rockchip/clk_rk3288.c | 12 +- drivers/clk/rockchip/clk_rk3328.c | 9 +- drivers/clk/rockchip/clk_rk3368.c | 306 ++++++++++++++++++++++++++---- drivers/clk/rockchip/clk_rk3399.c | 27 +-- drivers/clk/rockchip/clk_rv1108.c | 3 - drivers/core/Kconfig | 23 ++- drivers/core/Makefile | 4 +- drivers/net/gmac_rockchip.c | 78 ++++++++ drivers/pinctrl/rockchip/pinctrl_rk3368.c | 577 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++- drivers/ram/Kconfig | 11 +- drivers/ram/Makefile | 2 + drivers/ram/rockchip/Makefile | 7 + drivers/ram/rockchip/dmc-rk3368.c | 1007 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/rk_spi.c | 9 + drivers/timer/Kconfig | 25 +++ drivers/timer/Makefile | 3 +- drivers/timer/rockchip_timer.c | 107 +++++++++++ drivers/timer/timer-uclass.c | 8 +- dts/Kconfig | 29 +++ include/configs/am335x_evm.h | 2 - include/configs/am335x_igep003x.h | 1 - include/configs/am335x_shc.h | 2 - include/configs/am335x_sl50.h | 2 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 2 - include/configs/apf27.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 2 - include/configs/bav335x.h | 2 - include/configs/bur_am335x_common.h | 1 - include/configs/chiliboard.h | 2 - include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t43.h | 2 - include/configs/da850evm.h | 1 - include/configs/edminiv2.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/imx6_spl.h | 1 - include/configs/ipam390.h | 1 - include/configs/kc1.h | 2 - include/configs/lion_rk3368.h | 18 ++ include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 2 - include/configs/ls1046a_common.h | 2 - include/configs/ls2080a_common.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/microblaze-generic.h | 2 - include/configs/mx31pdk.h | 1 - include/configs/mxs.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/origen.h | 1 - include/configs/pcm051.h | 2 - include/configs/pengwyn.h | 2 - include/configs/pepper.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/rk3188_common.h | 2 +- include/configs/rk3288_common.h | 2 +- include/configs/rk3368_common.h | 8 + include/configs/rock.h | 2 +- include/configs/rockchip-common.h | 2 +- include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 - include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/sniper.h | 2 - include/configs/sunxi-common.h | 4 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 2 - include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/ti_omap5_common.h | 1 - include/configs/tricorder.h | 1 - include/configs/woodburn_sd.h | 1 - include/configs/x600.h | 1 - include/configs/zynq-common.h | 2 - include/dt-bindings/memory/rk3368-dmc.h | 30 +++ include/linux/kconfig.h | 13 ++ include/spl.h | 10 + lib/Kconfig | 9 + lib/Makefile | 10 +- scripts/Makefile.spl | 19 +- scripts/config_whitelist.txt | 2 - scripts/setlocalversion | 6 +- tools/rkcommon.c | 1 + 203 files changed, 4234 insertions(+), 860 deletions(-) create mode 100644 arch/arm/dts/rk3368-geekbox-u-boot.dtsi create mode 100644 arch/arm/dts/rk3368-lion-u-boot.dtsi create mode 100644 arch/arm/dts/rk3368-lion.dts create mode 100644 arch/arm/dts/rk3368-px5-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3368-sheep-u-boot.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3368.h create mode 100644 arch/arm/mach-rockchip/rk3368-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c delete mode 100644 arch/arm/mach-rockchip/rk3368/sdram_rk3368.c create mode 100644 arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds create mode 100644 arch/arm/mach-rockchip/spl-boot-order.c create mode 100644 board/theobroma-systems/lion_rk3368/Kconfig create mode 100644 board/theobroma-systems/lion_rk3368/MAINTAINERS create mode 100644 board/theobroma-systems/lion_rk3368/Makefile create mode 100644 board/theobroma-systems/lion_rk3368/README create mode 100644 board/theobroma-systems/lion_rk3368/fit_spl_atf.its create mode 100644 board/theobroma-systems/lion_rk3368/lion_rk3368.c create mode 100644 common/spl/spl_bootrom.c create mode 100644 configs/lion-rk3368_defconfig create mode 100644 doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt create mode 100644 drivers/ram/rockchip/Makefile create mode 100644 drivers/ram/rockchip/dmc-rk3368.c create mode 100644 drivers/timer/rockchip_timer.c create mode 100644 include/configs/lion_rk3368.h create mode 100644 include/dt-bindings/memory/rk3368-dmc.h
While it is likely that this entire case is superfluous and can be removed, correct the test now to match what is in rockchip-common.h and makes sense based on context of the code. Otherwise we get a large number of warnings.
Cc: hilipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/rock.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/rock.h b/include/configs/rock.h index 6b0788be9db5..8d845d95e378 100644 --- a/include/configs/rock.h +++ b/include/configs/rock.h @@ -12,7 +12,7 @@
#define CONFIG_SYS_MMC_ENV_DEV 0
-#if defined(ROCKCHIP_BACK_TO_BROM) +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) /* SPL @ 32k for 34k * u-boot directly after @ 68k for 400k or so * ENV @ 992k
Reviewed-by: Philipp Tomsich < philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Tom Rini trini@konsulko.com
On Sun, Aug 13, 2017 at 06:37:05PM +0200, Dr. Philipp Tomsich wrote:
Tom,
Regards, Phil.
Dr. Philipp Tomsich
