[U-Boot] [PATCH] common: cli_readline: Improve command line editing
This improves the cread_line() function so that it will correctly process the 'Home', 'End', 'Delete' and arrow key escape sequences produced by various terminal emulators. This makes command line editing a more pleasant experience.
The previous code only supported the cursor keys and the 'Home' key, and only for certain terminal emulator configurations. This adds support for the 'End and 'Delete' keys, and recognises a wider range of escape sequences. For example, the left arrow key can be 'ESC O D' instead of 'ESC [ D', and the 'Home' key can be 'ESC [ H', 'ESC O H', 'ESC 1 ~' or 'ESC 7 ~', depending on what terminal emulator you use and how it is configured.
Signed-off-by: James Byrne james.byrne@origamienergy.com ---
common/cli_readline.c | 108 ++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 78 insertions(+), 30 deletions(-)
diff --git a/common/cli_readline.c b/common/cli_readline.c index c1476e4..0d4ad49 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -283,46 +283,94 @@ static int cread_line(const char *const prompt, char *buf, unsigned int *len, * handle standard linux xterm esc sequences for arrow key, etc. */ if (esc_len != 0) { + enum { ESC_REJECT, ESC_SAVE, ESC_CONVERTED } act; + if (esc_len == 1) { - if (ichar == '[') { - esc_save[esc_len] = ichar; - esc_len = 2; + if (ichar == '[' || ichar == 'O') + act = ESC_SAVE; + else + act = ESC_REJECT; + } else if (esc_len == 2) { + switch (ichar) { + case 'D': /* <- key */ + ichar = CTL_CH('b'); + act = ESC_CONVERTED; + break; /* pass off to ^B handler */ + case 'C': /* -> key */ + ichar = CTL_CH('f'); + act = ESC_CONVERTED; + break; /* pass off to ^F handler */ + case 'H': /* Home key */ + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass off to ^A handler */ + case 'F': /* End key */ + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass off to ^E handler */ + case 'A': /* up arrow */ + ichar = CTL_CH('p'); + act = ESC_CONVERTED; + break; /* pass off to ^P handler */ + case 'B': /* down arrow */ + ichar = CTL_CH('n'); + act = ESC_CONVERTED; + break; /* pass off to ^N handler */ + case '1': + case '3': + case '4': + case '7': + case '8': + if (esc_save[1] == '[') { + /* see if next character is ~ */ + act = ESC_SAVE; + } else { + act = ESC_REJECT; + } + break; + default: + act = ESC_REJECT; + break; + } + } else if (esc_len == 3) { + if (ichar == '~') { + switch (esc_save[2]) { + case '3': /* Delete key */ + ichar = CTL_CH('d'); + act = ESC_CONVERTED; + break; /* pass to ^D handler */ + case '1': /* Home key */ + case '7': + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass to ^A handler */ + case '4': /* End key */ + case '8': + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass to ^E handler */ + default: + act = ESC_REJECT; + break; + } } else { - cread_add_str(esc_save, esc_len, - insert, &num, &eol_num, - buf, *len); - esc_len = 0; + act = ESC_REJECT; } - continue; }
- switch (ichar) { - case 'D': /* <- key */ - ichar = CTL_CH('b'); - esc_len = 0; - break; - case 'C': /* -> key */ - ichar = CTL_CH('f'); - esc_len = 0; - break; /* pass off to ^F handler */ - case 'H': /* Home key */ - ichar = CTL_CH('a'); - esc_len = 0; - break; /* pass off to ^A handler */ - case 'A': /* up arrow */ - ichar = CTL_CH('p'); - esc_len = 0; - break; /* pass off to ^P handler */ - case 'B': /* down arrow */ - ichar = CTL_CH('n'); - esc_len = 0; - break; /* pass off to ^N handler */ - default: + switch (act) { + case ESC_SAVE: + esc_save[esc_len++] = ichar; + continue; + case ESC_REJECT: esc_save[esc_len++] = ichar; cread_add_str(esc_save, esc_len, insert, &num, &eol_num, buf, *len); esc_len = 0; continue; + case ESC_CONVERTED: + esc_len = 0; + break; } }
This introduces a new warning: common/cli_readline.c: In function ‘cli_readline_into_buffer’: common/cli_readline.c:361:4: warning: ‘act’ may be used uninitialized in this function [-Wmaybe-uninitialized]
Signed-off-by: James Byrne james.byrne@origamienergy.com --- Changes for v2 - Explicitly initialize variable to avoid spurious compiler warning.
diff --git a/common/cli_readline.c b/common/cli_readline.c index c1476e4..6690c13 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -283,46 +283,94 @@ static int cread_line(const char *const prompt, char *buf, unsigned int *len, * handle standard linux xterm esc sequences for arrow key, etc. */ if (esc_len != 0) { + enum { ESC_REJECT, ESC_SAVE, ESC_CONVERTED } act = ESC_REJECT; + if (esc_len == 1) { - if (ichar == '[') { - esc_save[esc_len] = ichar; - esc_len = 2; + if (ichar == '[' || ichar == 'O') + act = ESC_SAVE; + else + act = ESC_REJECT; + } else if (esc_len == 2) { + switch (ichar) { + case 'D': /* <- key */ + ichar = CTL_CH('b'); + act = ESC_CONVERTED; + break; /* pass off to ^B handler */ + case 'C': /* -> key */ + ichar = CTL_CH('f'); + act = ESC_CONVERTED; + break; /* pass off to ^F handler */ + case 'H': /* Home key */ + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass off to ^A handler */ + case 'F': /* End key */ + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass off to ^E handler */ + case 'A': /* up arrow */ + ichar = CTL_CH('p'); + act = ESC_CONVERTED; + break; /* pass off to ^P handler */ + case 'B': /* down arrow */ + ichar = CTL_CH('n'); + act = ESC_CONVERTED; + break; /* pass off to ^N handler */ + case '1': + case '3': + case '4': + case '7': + case '8': + if (esc_save[1] == '[') { + /* see if next character is ~ */ + act = ESC_SAVE; + } else { + act = ESC_REJECT; + } + break; + default: + act = ESC_REJECT; + break; + } + } else if (esc_len == 3) { + if (ichar == '~') { + switch (esc_save[2]) { + case '3': /* Delete key */ + ichar = CTL_CH('d'); + act = ESC_CONVERTED; + break; /* pass to ^D handler */ + case '1': /* Home key */ + case '7': + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass to ^A handler */ + case '4': /* End key */ + case '8': + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass to ^E handler */ + default: + act = ESC_REJECT; + break; + } } else { - cread_add_str(esc_save, esc_len, - insert, &num, &eol_num, - buf, *len); - esc_len = 0; + act = ESC_REJECT; } - continue; }
Changes for v2
Thanks. But now:
if (esc_len == 1) {
if (ichar == '[') {
esc_len = 2;
act = ESC_SAVE;
else
act = ESC_REJECT;
Since act is ESC_REJECT to start with, we can kill the else.
switch (ichar) {
case '1':
case '3':
case '4':
case '7':
case '8':
act = ESC_SAVE;
} else {
act = ESC_REJECT;
And here too.
break;
default:
act = ESC_REJECT;
break;
And then we can drop the default case too.
if (ichar == '~') {
case '7':
case '8':
default:
act = ESC_REJECT;
break;
Same.
} } else {
buf, *len);
esc_len = 0;
act = ESC_REJECT; }
And this is also redundant.
Thanks!
Signed-off-by: James Byrne james.byrne@origamienergy.com Changes for v2 - Explicitly initialize variable to avoid spurious compiler warning. Changes for v3 - Remove unnecessary setting of 'act' to ESC_REJECT (now its default value).
--- common/cli_readline.c | 98 +++++++++++++++++++++++++++++++++++---------------- 1 file changed, 67 insertions(+), 31 deletions(-)
diff --git a/common/cli_readline.c b/common/cli_readline.c index c1476e4..ecded11 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -283,46 +283,82 @@ static int cread_line(const char *const prompt, char *buf, unsigned int *len, * handle standard linux xterm esc sequences for arrow key, etc. */ if (esc_len != 0) { + enum { ESC_REJECT, ESC_SAVE, ESC_CONVERTED } act = ESC_REJECT; + if (esc_len == 1) { - if (ichar == '[') { - esc_save[esc_len] = ichar; - esc_len = 2; - } else { - cread_add_str(esc_save, esc_len, - insert, &num, &eol_num, - buf, *len); - esc_len = 0; + if (ichar == '[' || ichar == 'O') + act = ESC_SAVE; + } else if (esc_len == 2) { + switch (ichar) { + case 'D': /* <- key */ + ichar = CTL_CH('b'); + act = ESC_CONVERTED; + break; /* pass off to ^B handler */ + case 'C': /* -> key */ + ichar = CTL_CH('f'); + act = ESC_CONVERTED; + break; /* pass off to ^F handler */ + case 'H': /* Home key */ + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass off to ^A handler */ + case 'F': /* End key */ + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass off to ^E handler */ + case 'A': /* up arrow */ + ichar = CTL_CH('p'); + act = ESC_CONVERTED; + break; /* pass off to ^P handler */ + case 'B': /* down arrow */ + ichar = CTL_CH('n'); + act = ESC_CONVERTED; + break; /* pass off to ^N handler */ + case '1': + case '3': + case '4': + case '7': + case '8': + if (esc_save[1] == '[') { + /* see if next character is ~ */ + act = ESC_SAVE; + } + break; + } + } else if (esc_len == 3) { + if (ichar == '~') { + switch (esc_save[2]) { + case '3': /* Delete key */ + ichar = CTL_CH('d'); + act = ESC_CONVERTED; + break; /* pass to ^D handler */ + case '1': /* Home key */ + case '7': + ichar = CTL_CH('a'); + act = ESC_CONVERTED; + break; /* pass to ^A handler */ + case '4': /* End key */ + case '8': + ichar = CTL_CH('e'); + act = ESC_CONVERTED; + break; /* pass to ^E handler */ + } } - continue; }
Changes for v3
James Byrne
