[U-Boot] [PATCH v4] armv8: Add workaround for USB erratum A-050106
USB3.0 Receiver needs to enable fixed equalization for each of PHY instances in an SOC. This is similar to erratum A-009007, but this one is for LX2160A, and the register value is different.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v4: - Include defines of USB_PHY_RX_EQ_VAL_3 and USB_PHY_RX_EQ_VAL_4 for LS1028A to fix compile failure.
Change in v3: - Rebase patch for latest U-Boot (v2019.10)
Change in v2: - Move function erratum_a050106() under the scope of CONFIG_FSL_LSCH3 to avoid compilation warning of 'defined but not used'.
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 12 +++++++++++- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 6 ++++++ 3 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f1578b1..c7f28b6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -219,6 +219,7 @@ config ARCH_LX2160A select SYS_FSL_DDR_VER_50 select SYS_FSL_EC1 select SYS_FSL_EC2 + select SYS_FSL_ERRATUM_A050106 select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508 @@ -348,6 +349,9 @@ config SYS_FSL_ERRATUM_A009008 config SYS_FSL_ERRATUM_A009798 bool "Workaround for USB PHY erratum A009798"
+config SYS_FSL_ERRATUM_A050106 + bool "Workaround for USB PHY erratum A050106" + config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index f0df88c..909df5c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -146,7 +146,7 @@ static void erratum_a008997(void) out_be16((phy) + SCFG_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_4)
#elif defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) || \ - defined(CONFIG_ARCH_LS1028A) + defined(CONFIG_ARCH_LS1028A) || defined(CONFIG_ARCH_LX2160A)
#define PROGRAM_USB_PHY_RX_OVRD_IN_HI(phy) \ out_le16((phy) + DCSR_USB_PHY_RX_OVRD_IN_HI, USB_PHY_RX_EQ_VAL_1); \ @@ -180,6 +180,15 @@ static void erratum_a009007(void) }
#if defined(CONFIG_FSL_LSCH3) +static void erratum_a050106(void) +{ +#if defined(CONFIG_ARCH_LX2160A) + void __iomem *dcsr = (void __iomem *)DCSR_BASE; + + PROGRAM_USB_PHY_RX_OVRD_IN_HI(dcsr + DCSR_USB_PHY1); + PROGRAM_USB_PHY_RX_OVRD_IN_HI(dcsr + DCSR_USB_PHY2); +#endif +} /* * This erratum requires setting a value to eddrtqcr1 to * optimal the DDR performance. @@ -331,6 +340,7 @@ void fsl_lsch3_early_init_f(void) erratum_a009798(); erratum_a008997(); erratum_a009007(); + erratum_a050106(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index d46477d..7670b56 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -252,8 +252,14 @@ #define DCSR_USB_PHY_RX_OVRD_IN_HI 0x200C #define USB_PHY_RX_EQ_VAL_1 0x0000 #define USB_PHY_RX_EQ_VAL_2 0x0080 +#if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) || \ + defined(CONFIG_ARCH_LS1028A) #define USB_PHY_RX_EQ_VAL_3 0x0380 #define USB_PHY_RX_EQ_VAL_4 0x0b80 +#elif defined(CONFIG_ARCH_LX2160A) +#define USB_PHY_RX_EQ_VAL_3 0x0080 +#define USB_PHY_RX_EQ_VAL_4 0x0880 +#endif #define DCSR_USB_IOCR1 0x108004 #define DCSR_USB_PCSTXSWINGFULL 0x71
-----Original Message----- From: Ran Wang ran.wang_1@nxp.com Sent: Wednesday, November 13, 2019 11:20 AM To: Priyanka Jain priyanka.jain@nxp.com; Albert Aribaud albert.u.boot@aribaud.net Cc: u-boot@lists.denx.de; Ran Wang ran.wang_1@nxp.com Subject: [PATCH v4] armv8: Add workaround for USB erratum A-050106
Change in v4:
Change in v3:
Change in v2:
- select SYS_FSL_ERRATUM_A050106 select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508
- bool "Workaround for USB PHY erratum A050106"
Please fix checkpatch warning WARNING: please write a paragraph that describes the config symbol fully #35: FILE: arch/arm/cpu/armv8/fsl-layerscape/Kconfig:352: +config SYS_FSL_ERRATUM_A050106
total: 0 errors, 1 warnings, 0 checks, 60 lines checked
-priyankajain
<snip>
Hi Priyanka,
Change in v4:
Change in v3:
Change in v2:
Actually I followed the history erratum workaround patches to do this. And it seems to be OK to ignore that warning,
Please check: http://patchwork.ozlabs.org/patch/809597/ http://patchwork.ozlabs.org/patch/809598/ http://patchwork.ozlabs.org/patch/809603/ http://patchwork.ozlabs.org/patch/809599/ http://patchwork.ozlabs.org/patch/809604/ http://patchwork.ozlabs.org/patch/809600/ http://patchwork.ozlabs.org/patch/809601/ http://patchwork.ozlabs.org/patch/809602/ http://patchwork.ozlabs.org/patch/817358/ http://patchwork.ozlabs.org/patch/1098612/
Thanks & Regards, Ran
-----Original Message----- From: Ran Wang ran.wang_1@nxp.com Sent: Thursday, November 21, 2019 12:26 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Albert Aribaud albert.u.boot@aribaud.net Subject: RE: [PATCH v4] armv8: Add workaround for USB erratum A-050106
Hi Priyanka,
Change in v4:
Change in v3:
Change in v2:
Even though in past , this warning might not have exist or we have ignore this, But such details help in better code readability. -priyankajain
Hi Priyanka,
-----Original Message----- From: Priyanka Jain priyanka.jain@nxp.com Sent: Monday, November 25, 2019 11:54 To: Ran Wang ran.wang_1@nxp.com Cc: u-boot@lists.denx.de; Albert Aribaud albert.u.boot@aribaud.net Subject: RE: [PATCH v4] armv8: Add workaround for USB erratum A-050106
Hi Priyanka,
Change in v4:
Change in v3:
Change in v2:
OK, let me add more details in next version.
Priyanka Jain
Ran Wang
