[U-Boot] [PATCH v3 3/4] c6x: Add suport build davinci SOC with c674x CPUs
C674x CPUs has same peripherals(uart,emac,nand contoller) like sitara processors (am1705/am1707/omapl137/omapl138). In u-boot this peripheral known as davinci SOC, and placed in arch/arm/cpu/arm926ejs/davinci This patch allow compile davinci SOC code whith c674x CPU.
Reset code rewritten in C for compile not only for arm.
Signed-off-by: Dmitry Bondar bond@inmys.ru Cc: Tom Rini trini@ti.com --- Makefile | 1 + arch/arm/cpu/arm926ejs/davinci/Makefile | 5 ++++ arch/arm/cpu/arm926ejs/davinci/reset_c.c | 32 ++++++++++++++++++++++++++++++ mkconfig | 7 +++++- 4 files changed, 44 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/reset_c.c
diff --git a/Makefile b/Makefile index 0197239..33e12cf 100644 --- a/Makefile +++ b/Makefile @@ -779,6 +779,7 @@ clobber: tidy @rm -f $(obj)arch/powerpc/cpu/mpc824x/bedbug_603e.c @rm -f $(obj)arch/powerpc/cpu/mpc83xx/ddr-gen?.c @rm -fr $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm + @rm -f ${obj}arch/c6x/cpu/c674x/davinci @rm -fr $(obj)include/generated @[ ! -d $(obj)nand_spl ] || find $(obj)nand_spl -name "*" -type l -print | xargs rm -f @[ ! -d $(obj)onenand_ipl ] || find $(obj)onenand_ipl -name "*" -type l -print | xargs rm -f diff --git a/arch/arm/cpu/arm926ejs/davinci/Makefile b/arch/arm/cpu/arm926ejs/davinci/Makefile index da7efac..54f096d 100644 --- a/arch/arm/cpu/arm926ejs/davinci/Makefile +++ b/arch/arm/cpu/arm926ejs/davinci/Makefile @@ -42,7 +42,12 @@ COBJS-$(CONFIG_SOC_DM365) += dm365_lowlevel.o COBJS-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o endif
+ +ifeq ($(CPU),c674x) +COBJS-y += reset_c.o +else SOBJS = reset.o +endif
ifndef CONFIG_SKIP_LOWLEVEL_INIT SOBJS += lowlevel_init.o diff --git a/arch/arm/cpu/arm926ejs/davinci/reset_c.c b/arch/arm/cpu/arm926ejs/davinci/reset_c.c new file mode 100644 index 0000000..44ae364 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/davinci/reset_c.c @@ -0,0 +1,32 @@ +/* + * Processor reset using WDT. + * + * Copyright (C) 2012 Dmitry Bondar bond@inmys.ru + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This file is released under the terms of GPL v2 and any later version. + * See the file COPYING in the root directory of the source tree for details. +*/ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/timer_defs.h> + +void reset_cpu(unsigned long a) +{ + struct davinci_timer *const wdttimer = + (struct davinci_timer *)DAVINCI_TIMER1_BASE; + writel(0x08, &wdttimer->tgcr); + writel(readl(&wdttimer->tgcr) | 0x03, &wdttimer->tgcr); + writel(0, &wdttimer->tim12); + writel(0, &wdttimer->tim34); + writel(0, &wdttimer->prd12); + writel(0, &wdttimer->prd34); + writel(readl(&wdttimer->tcr) | 0x40, &wdttimer->tcr); + writel(readl(&wdttimer->wdtcr) | 0x4000, &wdttimer->wdtcr); + writel(0xa5c64000, &wdttimer->wdtcr); + writel(0xda7e4000, &wdttimer->wdtcr); + writel(0x4000, &wdttimer->wdtcr); + while (1) + /*nothing*/; +} diff --git a/mkconfig b/mkconfig index daa1810..c80625e 100755 --- a/mkconfig +++ b/mkconfig @@ -119,7 +119,12 @@ rm -f asm/arch if [ -z "${soc}" ] ; then ln -s ${LNPREFIX}arch-${cpu} asm/arch else - ln -s ${LNPREFIX}arch-${soc} asm/arch + if [ "${arch}" == "c6x" -a "$soc" == "davinci" ]; then + ln -s ${SRCTREE}/arch/arm/include/asm/arch-davinci asm/arch + ln -s ${SRCTREE}/arch/arm/cpu/arm926ejs/davinci ${SRCTREE}/arch/c6x/cpu/c674x/davinci + else + ln -s ${LNPREFIX}arch-${soc} asm/arch + fi fi
if [ "${arch}" = "arm" ] ; then
The symlink comments I posted before are for this specific patch. Also, anyone out there that could easily test if this reset in C code is fine on their arm9 davinci platform?
We can safely use the same reset code written in C for both Davinci and C6X platforms. In addition the C version of the code is marginally smaller on Davinci.
Tested-by: Matt Porter mporter@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/arm926ejs/davinci/Makefile | 9 +--- arch/arm/cpu/arm926ejs/davinci/reset.S | 81 ------------------------------ arch/arm/cpu/arm926ejs/davinci/reset.c | 32 ++++++++++++ arch/arm/cpu/arm926ejs/davinci/reset_c.c | 32 ------------ 4 files changed, 33 insertions(+), 121 deletions(-) delete mode 100644 arch/arm/cpu/arm926ejs/davinci/reset.S create mode 100644 arch/arm/cpu/arm926ejs/davinci/reset.c delete mode 100644 arch/arm/cpu/arm926ejs/davinci/reset_c.c
diff --git a/arch/arm/cpu/arm926ejs/davinci/Makefile b/arch/arm/cpu/arm926ejs/davinci/Makefile index 54f096d..c91928e 100644 --- a/arch/arm/cpu/arm926ejs/davinci/Makefile +++ b/arch/arm/cpu/arm926ejs/davinci/Makefile @@ -27,7 +27,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-COBJS-y += cpu.o misc.o timer.o psc.o pinmux.o +COBJS-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o COBJS-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o COBJS-$(CONFIG_SOC_DM355) += dm355.o COBJS-$(CONFIG_SOC_DM365) += dm365.o @@ -42,13 +42,6 @@ COBJS-$(CONFIG_SOC_DM365) += dm365_lowlevel.o COBJS-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o endif
- -ifeq ($(CPU),c674x) -COBJS-y += reset_c.o -else -SOBJS = reset.o -endif - ifndef CONFIG_SKIP_LOWLEVEL_INIT SOBJS += lowlevel_init.o endif diff --git a/arch/arm/cpu/arm926ejs/davinci/reset.S b/arch/arm/cpu/arm926ejs/davinci/reset.S deleted file mode 100644 index ba0a7c3..0000000 --- a/arch/arm/cpu/arm926ejs/davinci/reset.S +++ /dev/null @@ -1,81 +0,0 @@ -/* - * Processor reset using WDT for TI TMS320DM644x SoC. - * - * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net - * - * ----------------------------------------------------- - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -.globl reset_cpu -reset_cpu: - ldr r0, WDT_TGCR - mov r1, $0x08 - str r1, [r0] - ldr r1, [r0] - orr r1, r1, $0x03 - str r1, [r0] - mov r1, $0 - ldr r0, WDT_TIM12 - str r1, [r0] - ldr r0, WDT_TIM34 - str r1, [r0] - ldr r0, WDT_PRD12 - str r1, [r0] - ldr r0, WDT_PRD34 - str r1, [r0] - ldr r0, WDT_TCR - ldr r1, [r0] - orr r1, r1, $0x40 - str r1, [r0] - ldr r0, WDT_WDTCR - ldr r1, [r0] - orr r1, r1, $0x4000 - str r1, [r0] - ldr r1, WDTCR_VAL1 - str r1, [r0] - ldr r1, WDTCR_VAL2 - str r1, [r0] - /* Write an invalid value to the WDKEY field to trigger - * an immediate watchdog reset */ - mov r1, $0x4000 - str r1, [r0] - nop - nop - nop - nop -reset_cpu_loop: - b reset_cpu_loop - -WDT_TGCR: - .word 0x01c21c24 -WDT_TIM12: - .word 0x01c21c10 -WDT_TIM34: - .word 0x01c21c14 -WDT_PRD12: - .word 0x01c21c18 -WDT_PRD34: - .word 0x01c21c1c -WDT_TCR: - .word 0x01c21c20 -WDT_WDTCR: - .word 0x01c21c28 -WDTCR_VAL1: - .word 0xa5c64000 -WDTCR_VAL2: - .word 0xda7e4000 diff --git a/arch/arm/cpu/arm926ejs/davinci/reset.c b/arch/arm/cpu/arm926ejs/davinci/reset.c new file mode 100644 index 0000000..44ae364 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/davinci/reset.c @@ -0,0 +1,32 @@ +/* + * Processor reset using WDT. + * + * Copyright (C) 2012 Dmitry Bondar bond@inmys.ru + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This file is released under the terms of GPL v2 and any later version. + * See the file COPYING in the root directory of the source tree for details. +*/ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/timer_defs.h> + +void reset_cpu(unsigned long a) +{ + struct davinci_timer *const wdttimer = + (struct davinci_timer *)DAVINCI_TIMER1_BASE; + writel(0x08, &wdttimer->tgcr); + writel(readl(&wdttimer->tgcr) | 0x03, &wdttimer->tgcr); + writel(0, &wdttimer->tim12); + writel(0, &wdttimer->tim34); + writel(0, &wdttimer->prd12); + writel(0, &wdttimer->prd34); + writel(readl(&wdttimer->tcr) | 0x40, &wdttimer->tcr); + writel(readl(&wdttimer->wdtcr) | 0x4000, &wdttimer->wdtcr); + writel(0xa5c64000, &wdttimer->wdtcr); + writel(0xda7e4000, &wdttimer->wdtcr); + writel(0x4000, &wdttimer->wdtcr); + while (1) + /*nothing*/; +} diff --git a/arch/arm/cpu/arm926ejs/davinci/reset_c.c b/arch/arm/cpu/arm926ejs/davinci/reset_c.c deleted file mode 100644 index 44ae364..0000000 --- a/arch/arm/cpu/arm926ejs/davinci/reset_c.c +++ /dev/null @@ -1,32 +0,0 @@ -/* - * Processor reset using WDT. - * - * Copyright (C) 2012 Dmitry Bondar bond@inmys.ru - * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net - * - * This file is released under the terms of GPL v2 and any later version. - * See the file COPYING in the root directory of the source tree for details. -*/ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/timer_defs.h> - -void reset_cpu(unsigned long a) -{ - struct davinci_timer *const wdttimer = - (struct davinci_timer *)DAVINCI_TIMER1_BASE; - writel(0x08, &wdttimer->tgcr); - writel(readl(&wdttimer->tgcr) | 0x03, &wdttimer->tgcr); - writel(0, &wdttimer->tim12); - writel(0, &wdttimer->tim34); - writel(0, &wdttimer->prd12); - writel(0, &wdttimer->prd34); - writel(readl(&wdttimer->tcr) | 0x40, &wdttimer->tcr); - writel(readl(&wdttimer->wdtcr) | 0x4000, &wdttimer->wdtcr); - writel(0xa5c64000, &wdttimer->wdtcr); - writel(0xda7e4000, &wdttimer->wdtcr); - writel(0x4000, &wdttimer->wdtcr); - while (1) - /*nothing*/; -}
In the next go-round of the c6x patches please just fold this (and the tested-by) into the patch you add that creates the C version of the reset code. Thanks!
Dmitry Bondar
Mike Frysinger
