[U-Boot-Users] commit 22069215 - [MIPS] Fix $gp usage
Dear Shinya,
I think we need your help with the current MIPS code; it seems that this commit is causing problems:
commit 22069215eb7adf5a3888bf7c7784ea9d70a72cd0 Author: Shinya Kuribayashi shinya.kuribayashi@necel.com Date: Sun Oct 21 10:55:36 2007 +0900
The issue is with "cpu/mips/start.S"; with older toolchains (like ELDK 3.1.1 which uses binutils 2.14, we get:
start.S: Assembler messages: start.S:348: Error: relocation out of range make[1]: *** [start.o] Error 1
With ELDK 4.0 and 4.1 (binutils 2.16.1) we get no erros, but these warnigns:
cache.S: Assembler messages: cache.S:243: Warning: Pretending global symbol used as branch target is local. cache.S:250: Warning: Pretending global symbol used as branch target is local.
Jean-Christophe Plagniol-Villard reports that he sees no problems (no errors nor warnings) with binutils 2.18
I wonder if it was possible to come up with a version of the code that builds with somewhat older versions of the toolchains, too?
Thanks in advance.
Confirmed both error and warning. I'll look into them.
Yes, it seems.
I have no idea at the moment.
Shinya
Dear Shinya,
Thanks a lot. May I ask which toolchain you have been using?
I ggogled a bit, and found a couple of related entries, but nothing that looked like an immediate solution. But then I'm no MIPS expert...
GNU assembler version 2.14 (mips-linux) using BFD version 2.14 20030612 That is from ELDK 3.1.1 (binutils 2.14-6), I definitely get the error.
GNU assembler version 2.14.90.0.6 (mips-linux) using BFD version 2.14.90.0.6 20030820 uClibc This works, but the warning is present. There's a 3 months difference here.
Yes, it seems.
The warning seems harmless.
We can somewhat revert the changes made, that's the only way it would work with that particular version. Apparently, .gpword was supposed to work only on local symbols (this comes from the MIPSpro tools), but this was relaxed in later versions of gas. See http://wwweic.eri.u-tokyo.ac.jp/computer/manual/lx/SGI_Developer/books/MProA...
Patch to follow.
Regards, Vlad
Shinya Kuribayashi
Vlad Lungu
