[U-Boot] [PATCH 0/5] Introducing TI's New SoC/board AM3517EVM
AM3517 device is high-performance, industrial applications processor designed and developed keeping Software Compatible with OMAP3 Processors.
Below are some of the useful links - AM3517 device is high-performance, industrial applications processor designed and developed keeping Software Compatible with OMAP3 Processors.
Migration from OMAP35x to AM35x :- http://focus.ti.com/lit/an/sprab91/sprab91.pdf
Specs/TRM :- http://focus.ti.com/docs/prod/folders/print/am3517.html
EVM Link -: http://www.logicpd.com/products/development-kits/zoom-am3517-experimenter-ki...
Vaibhav Hiremath (5): Introducing AM3517EVM support am3517_evm_config options added to Makfile Added configuration file for AM3517EVM Added AM3517EVM specific mux configuration to omap3/mux.h AM3517: Add support for EMIF4
Makefile | 3 + board/ti/am3517evm/Makefile | 46 ++++ board/ti/am3517evm/am3517evm.c | 76 +++++++ board/ti/am3517evm/am3517evm.h | 388 ++++++++++++++++++++++++++++++++ board/ti/am3517evm/config.mk | 29 +++ cpu/arm_cortexa8/omap3/board.c | 11 +- cpu/arm_cortexa8/omap3/mem.c | 110 ++++++++-- cpu/arm_cortexa8/omap3/sys_info.c | 12 +- include/asm-arm/arch-omap3/cpu.h | 26 +++ include/asm-arm/arch-omap3/mem.h | 66 ++++++- include/asm-arm/arch-omap3/mux.h | 35 +++ include/asm-arm/arch-omap3/sys_proto.h | 4 + include/configs/am3517_evm.h | 299 ++++++++++++++++++++++++ include/configs/devkit8000.h | 4 + include/configs/omap3_beagle.h | 4 + include/configs/omap3_evm.h | 4 + include/configs/omap3_overo.h | 4 + include/configs/omap3_pandora.h | 4 + include/configs/omap3_sdp3430.h | 4 + include/configs/omap3_zoom1.h | 4 + include/configs/omap3_zoom2.h | 4 + 21 files changed, 1112 insertions(+), 25 deletions(-) create mode 100644 board/ti/am3517evm/Makefile create mode 100644 board/ti/am3517evm/am3517evm.c create mode 100644 board/ti/am3517evm/am3517evm.h create mode 100644 board/ti/am3517evm/config.mk create mode 100644 include/configs/am3517_evm.h
EVM Link -: http://www.logicpd.com/products/development-kits/zoom-am3517-experimenter- kit
Vaibhav,
We will need entries to MAINTAINERS and MAKEALL as well.
Please submit it when you submit the next set of patches. I am sure you will receive some comments.
I hope you made the patches against the current u-boot-ti/master
Thanks, Sandeep
-----Original Message----- From: Paulraj, Sandeep Sent: Monday, November 23, 2009 7:20 PM To: Hiremath, Vaibhav; u-boot@lists.denx.de Subject: RE: [PATCH 0/5] Introducing TI's New SoC/board AM3517EVM
processor
processor
experimenter-
kit
Vaibhav,
[Hiremath, Vaibhav] Ok, will do that.
[Hiremath, Vaibhav] I hope so.
[Hiremath, Vaibhav] Yes that's correct.
Thanks, Vaibhav
Thanks, Sandeep
Dear "Paulraj, Sandeep",
In message 0554BEF07D437848AF01B9C9B5F0BC5D942DC993@dlee01.ent.ti.com you wrote:
Please note that this is a tendency I seriously dislike.
Please do NOT do this.
Please see bullet # 3 at http://www.denx.de/wiki/U-Boot/Patches :
Please use the "master" branch of the mainline U-Boot git repository (git://git.denx.de/u-boot.git) as reference, unless (usually late in a release cycle) there has been an announcement to use the "next" branch of this repository instead.
If we see patches againt any of 30 or so custodian trees, which don't apply against the "official" master tree, we will see chaos pretty soon. Please let's make sure there is only minimal difference between custdian trees and "master" (or "next"), so there is no reason to use custodian tress as reference for patches instead.
Please _always_ use "master" (or "next") as base for patches!
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Tuesday, November 24, 2009 1:33 AM To: Paulraj, Sandeep Cc: Hiremath, Vaibhav; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 0/5] Introducing TI's New SoC/board AM3517EVM
[Hiremath, Vaibhav] Before submitting patch I conformed that the patches gets applied on master branch cleanly.
Thanks, Vaibhav
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A Perl script is correct if it's halfway readable and gets the job done before your boss fires you. - L. Wall & R. L. Schwartz, _Programming Perl_
On the next revision of your patch set, please run it through the linux kernel's checkpatch.pl script. It is a good automated tool to check basic whitespace issues.
I use checkpatch first when I have to review a large patch set.
Tom
participants (5)
Hiremath, Vaibhav
hvaibhav@ti.com
Paulraj, Sandeep
Tom
