[U-Boot] [PATCH v5 0/6] Improve default environment for easy use
This patchset improves the default environment of machines currently supported in OpenEmbedded and Yocto to make it compatible with mainline and Freescale BSP Linux kernel.
A new patch has been add to change the format in mx6qsabrelite in environment setting and already merged patches removed from this new pull request.
Changes in v5: - Change subject - Reword the warning
Changes in v4: - Use a warning, instead of error when failing to fetch fdt - Drop exit use - Fix netboot - Use fdt instead of ftd
Changes in v3: - Add loadfdt - Use loadfdt - Call exit to abort script
Changes in v2: - New patch - reformat environment change to fit in 80 cols - Allow use of dynamic/static ip - Allow force use, or not, of fdt - Change 'auto' to 'try'
Otavio Salvador (6): mx6qsabrelite: Use tabs to environment setting mx28evk: We shouldn't hardcode a rootfs filesystem type mx28evk: Add support to dynamically choose between fdt use or not mx53loco: Add support to dynamically choose between fdt use or not mx6qsabrelite: Add support to dynamically choose between fdt use or not mx6qsabre{auto,sd}: Add support to dynamically choose between fdt use or not
include/configs/mx28evk.h | 47 ++++++++++++++--- include/configs/mx53loco.h | 40 +++++++++++++- include/configs/mx6qsabre_common.h | 41 +++++++++++++-- include/configs/mx6qsabreauto.h | 1 + include/configs/mx6qsabrelite.h | 101 ++++++++++++++++++++++++------------ include/configs/mx6qsabresd.h | 1 + 6 files changed, 186 insertions(+), 45 deletions(-)
This rework the environment to use tabs for environment setting as done in other boards.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - New patch
include/configs/mx6qsabrelite.h | 66 +++++++++++++++++++-------------------- 1 file changed, 33 insertions(+), 33 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 0f6bbb4..ee86f9b 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -152,43 +152,43 @@ #define CONFIG_SYS_TEXT_BASE 0x17800000
#define CONFIG_EXTRA_ENV_SETTINGS \ - "script=boot.scr\0" \ - "uimage=uImage\0" \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ "console=ttymxc1\0" \ - "fdt_high=0xffffffff\0" \ + "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "mmcdev=0\0" \ - "mmcpart=2\0" \ - "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ - "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootm\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0"
#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev};" \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loaduimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "else run netboot; fi" + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi"
#define CONFIG_ARP_TIMEOUT 200UL
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Otavio Salvador Sent: Wednesday, January 09, 2013 7:58 PM To: U-Boot Mailing List Cc: Estevam Fabio-R49496; Otavio Salvador Subject: [U-Boot] [PATCH v5 1/6] mx6qsabrelite: Use tabs to environment setting
- New patch
Acked-by: Jason Liu r64343@freescale.com
"uimage=uImage\0" \
- "uimage=uImage\0" \ "console=ttymxc1\0" \
- "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \
"mmcdev=0\0" \
"mmcpart=2\0" \
"loadbootscript=" \
"source\0" \
${uimage}\0" \
"run mmcargs; " \
"bootm\0" \
"root=/dev/nfs " \
"run netargs; " \
- "mmcdev=0\0" \
- "mmcpart=2\0" \
"source\0" \
${uimage}\0" \
"run mmcargs; " \
"bootm\0" \
"root=/dev/nfs " \
"run netargs; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
-- 1.7.10.4
For a generic environment, we shouldn't have a fixed rootfs filesystem so we drop it from env.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - reformat environment change to fit in 80 cols
include/configs/mx28evk.h | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 8b89b25..ac9522f 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -292,11 +292,9 @@ "console_mainline=ttyAMA0\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ - "mmcroot=/dev/mmcblk0p3 rw\0" \ - "mmcrootfstype=ext3 rootwait\0" \ - "mmcargs=setenv bootargs console=${console_mainline},${baudrate} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ + "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ + "mmcargs=setenv bootargs console=${console_mainline},${baudrate} " + "root=${mmcroot}\0" \ "loadbootscript=" \ "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v5: - Change subject - Reword the warning
Changes in v2: - Allow use of dynamic/static ip - Allow force use, or not, of fdt - Change 'auto' to 'try'
include/configs/mx28evk.h | 39 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 37 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index ac9522f..4a95156 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -290,6 +290,10 @@ "uimage=uImage\0" \ "console_fsl=ttyAM0\0" \ "console_mainline=ttyAMA0\0" \ + "fdt_file=imx28-evk.dtb\0" \ + "fdt_addr=0x41000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ @@ -300,15 +304,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console_mainline},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi;" \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \
include/configs/mx53loco.h | 40 ++++++++++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 996396b..cbc3a82 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -119,6 +119,10 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "uimage=uImage\0" \ + "fdt_file=imx53-qsb.dtb\0" \ + "fdt_addr=0x71000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ @@ -128,15 +132,47 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo ERROR: Cannot load the DT; " \ + "exit; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Otavio Salvador Sent: Wednesday, January 09, 2013 7:58 PM To: U-Boot Mailing List Cc: Estevam Fabio-R49496; Otavio Salvador Subject: [U-Boot] [PATCH v5 4/6] mx53loco: Add support to dynamically choose between fdt use or not
Changes in v5:
- Change subject
Changes in v4:
- Drop exit use
- Fix netboot
Changes in v3:
- Add loadfdt
- Use loadfdt
Changes in v2:
- "fdt_file=imx53-qsb.dtb\0" \
- "fdt_addr=0x71000000\0" \
- "boot_fdt=try\0" \
- "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ @@ -128,15 +132,47
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr}
"bootm\0" \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"netargs=setenv bootargs console=ttymxc0,${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \"fi;\0" \
"else " \
"fi; " \
"else " \
"bootm; " \
"else " \
"exit; " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \ -- 1.7.10.4
Hi Otavio,
Changes in v5:
- Change subject
Changes in v4:
- Drop exit use
- Fix netboot
Changes in v3:
- Add loadfdt
- Use loadfdt
Changes in v2:
I get some problems: - loadbootscript is not correctly set. In fact:
env default -f -a ## Resetting to default environment MX53LOCO U-Boot > pri mmcargs mmcargs=setenv bootargs console=ttymxc0,${baudrate} root=${mmcroot} loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
There is still a '0' missing for mmcargs, and loadbootscript is not set.
Then there is a problem with netboot. It is set correctly, but "pri netboot" crashes:
pri netboot netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${uimage}; if test ${boot_fdt} = yes; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootm ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootm; else echo ERROR: Cannot load the DT; exit; fi; fi; else bootm; fi; prefetch abort pc : [<203b6d78>] lr : [<203b6d74>] sp : af565e00 ip : 00000000 fp : 00000000 r10: 00000002 r9 : 00000000 r8 : af565f58 r7 : af568c7c r6 : 00000001 r5 : 00000000 r4 : 6f6f6220 r3 : 00000083 r2 : 00000060 r1 : af565cc0 r0 : 00000173 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
Then I do not understand the boot_fdt when set to try. I have imagined that it tries to start a DT kernel, and if no fdt find is found, it tries with a legacy kernel without fdt. But it does not try to load the FDT file, because this is done only when boot_fdt = yes. When boot_fdt = try, it starts always a legacy kernel.
Best regards, Stefano Babic
include/configs/mx6qsabrelite.h | 39 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 37 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index ee86f9b..fbcab2f 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -157,6 +157,10 @@ "console=ttymxc1\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ + "fdt_file=imx6q-sabrelite.dtb\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ @@ -167,15 +171,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev};" \
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Otavio Salvador Sent: Wednesday, January 09, 2013 7:58 PM To: U-Boot Mailing List Cc: Estevam Fabio-R49496; Otavio Salvador Subject: [U-Boot] [PATCH v5 5/6] mx6qsabrelite: Add support to dynamically choose between fdt use or not
Changes in v5:
- Change subject
Changes in v4:
- Drop exit use
- Fix netboot
Changes in v3:
- Add loadfdt
- Use loadfdt
Changes in v2:
- "fdt_file=imx6q-sabrelite.dtb\0" \
- "fdt_addr=0x11000000\0" \
- "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ @@ -167,15 +171,46
"bootm\0" \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \"fi;\0" \
"else " \
"fi; " \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev};" \ -- 1.7.10.4
include/configs/mx6qsabre_common.h | 41 +++++++++++++++++++++++++++++++++--- include/configs/mx6qsabreauto.h | 1 + include/configs/mx6qsabresd.h | 1 + 3 files changed, 40 insertions(+), 3 deletions(-)
diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6qsabre_common.h index bd2fb10..0f0e51f 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6qsabre_common.h @@ -83,6 +83,10 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "uimage=uImage\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "console=" CONFIG_CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ @@ -96,15 +100,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "mmcboot=echo Booting from mmc ...; " \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev};" \ diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index f1ff201..f4a082a 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -15,6 +15,7 @@ #define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE #define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONFIG_DEFAULT_FDT_FILE "imx6q-sabreauto.dtb" #define CONFIG_MMCROOT "/dev/mmcblk0p2" #define PHYS_SDRAM_SIZE (2u * 1024 * 1024 * 1024)
diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index a1d9285..b64e925 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -21,6 +21,7 @@ #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_CONSOLE_DEV "ttymxc0" #define CONFIG_MMCROOT "/dev/mmcblk1p2" +#define CONFIG_DEFAULT_FDT_FILE "imx6q-sabresd.dtb" #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#include "mx6qsabre_common.h"
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Otavio Salvador Sent: Wednesday, January 09, 2013 7:58 PM To: U-Boot Mailing List Cc: Estevam Fabio-R49496; Otavio Salvador Subject: [U-Boot] [PATCH v5 6/6] mx6qsabre{auto, sd}: Add support to dynamically choose between fdt use or not
Changes in v5:
- Change subject
Changes in v4:
- Drop exit use
- Fix netboot
Changes in v3:
- Add loadfdt
- Use loadfdt
Changes in v2:
- "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "ip_dyn=yes\0" \ "console=" CONFIG_CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \
${fdt_file}\0" \
- "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \
"bootm\0" \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"else " \
"fi; " \
"else " \
"bootm; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootm; " \
"fi;\0"
1.7.10.4
Liu Hui-R64343
Otavio Salvador
Stefano Babic
