[U-Boot] [PATCH 0/3] AM335x: Add USB support in u-boot.
These patches add usb support in u-boot for AM335x. I have tested this code on AM335x evm and beaglebone in the host mode using mass storage class.
Gene Zarkhin (1): AM335x : Add USB support for AM335x in u-boot
Harman Sohanpal (2): AM335x : Configs to add USB host support. musb_udc : Fix compile warning.
drivers/usb/musb/Makefile | 1 + drivers/usb/musb/am335x.c | 121 ++++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/am335x.h | 113 +++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/musb_core.h | 2 + drivers/usb/musb/musb_hcd.h | 3 - include/configs/am335x_evm.h | 41 ++++++++++++++ include/usb.h | 3 +- 7 files changed, 280 insertions(+), 4 deletions(-) create mode 100644 drivers/usb/musb/am335x.c create mode 100644 drivers/usb/musb/am335x.h
This patch adds USB support in uboot for AM335x. By default the USB 1 module is enabled. The support for USB 0 can be enabled by changing the USB base address and the phy control register address in the header file am335x.h.
Signed-off-by: Gene Zarkhin gene_zarkhin@bose.com Signed-off-by: Harman Sohanpal harman_sohanpal@ti.com --- drivers/usb/musb/Makefile | 1 + drivers/usb/musb/am335x.c | 121 +++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/am335x.h | 113 ++++++++++++++++++++++++++++++++++++++++++ include/usb.h | 3 +- 4 files changed, 237 insertions(+), 1 deletions(-) create mode 100644 drivers/usb/musb/am335x.c create mode 100644 drivers/usb/musb/am335x.h
diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index 20b5503..d00ec40 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_USB_DAVINCI) += davinci.o COBJS-$(CONFIG_USB_OMAP3) += omap3.o COBJS-$(CONFIG_USB_DA8XX) += da8xx.o COBJS-$(CONFIG_USB_AM35X) += am35x.o +COBJS-$(CONFIG_USB_AM335X) += am335x.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/musb/am335x.c b/drivers/usb/musb/am335x.c new file mode 100644 index 0000000..4b59769 --- /dev/null +++ b/drivers/usb/musb/am335x.c @@ -0,0 +1,121 @@ +/* + * am335x.c - TI's AM335x platform specific usb wrapper functions. + * + * Author: gene Zarkhin gene_zarkhin@bose.com + * Modified by: Harman Sohanpal harman_sohanpal@ti.com + * + * Based on drivers/usb/musb/da8xx.c + * + * Copyright (c) 2012 Texas Instruments Incorporated + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> +#include "am335x.h" + +/* MUSB platform configuration */ +struct musb_config musb_cfg = { + .regs = (struct musb_regs *)(AM335X_USB_OTG_CORE_BASE), + .timeout = AM335X_USB_OTG_TIMEOUT, + .musb_speed = 0, +}; + +/* + * Enable the USB phy + */ +static u8 phy_on(void) +{ + u32 timeout; + u32 regAddr = CM_REGISTERS + USB_CTRL0_REG_OFFSET; + u32 usb_ctrl_reg; + + usb_ctrl_reg = readl(regAddr); + usb_ctrl_reg &= ~(CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + usb_ctrl_reg |= (OTGVDET_EN | OTGSESSENDEN); + writel(usb_ctrl_reg, regAddr); + + timeout = musb_cfg.timeout; + writel(0x1, &am335x_usb_regs->ctrl); + udelay(6000); + while (timeout--) { + if ((readl(&am335x_usb_regs->ctrl) & SOFT_RESET_BIT) == 0) + return 1; + } + /* USB phy was not turned on */ + return 0; +} + +/* + * Disable the USB phy + */ +static void phy_off(void) +{ + u32 regAddr = CM_REGISTERS + USB_CTRL0_REG_OFFSET; + u32 usb_ctrl_reg; + + usb_ctrl_reg = readl(regAddr); + usb_ctrl_reg |= (CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + writel(usb_ctrl_reg, regAddr); + + /* Disable the USB module */ + writel(PRCM_MODULE_DSBL, CM_PER_USB0_CLKCTRL); +} + +/* + * This function performs platform specific initialization for usb0. + */ +int musb_platform_init(void) +{ + u32 timeout; + u32 revision; + + /* USB */ + /* PLL Gate set up */ + writel(DPLL_CLKDCOLDO_GATE_CTRL, CM_CLKDCOLDO_DPLL_PER); + + /* CLOCK */ + writel(PRCM_MOD_EN, CM_PER_USB0_CLKCTRL); + timeout = musb_cfg.timeout; + while (timeout--) { + if (readl(CM_PER_USB0_CLKCTRL) != PRCM_MOD_EN) + continue; + else + break; + } + if (timeout == 0) { + printf("\nUSB module not enabled\nAborting"); + return -1; + } + + /* USB module fully functional */ + /* start the on-chip usb phy and its pll */ + if (phy_on() == 0) + return -1; + /* Returns zero if e.g. not clocked */ + revision = readl(&am335x_usb_regs->revision); + if (revision == 0) + return -1; + + return 0; +} + +/* + * This function performs platform specific deinitialization for usb0. + */ +void musb_platform_deinit(void) +{ + /* Turn off the phy */ + phy_off(); +} diff --git a/drivers/usb/musb/am335x.h b/drivers/usb/musb/am335x.h new file mode 100644 index 0000000..790531e --- /dev/null +++ b/drivers/usb/musb/am335x.h @@ -0,0 +1,113 @@ +/* + * am335x.h - TI's AM335x platform specific usb wrapper definitions. + * + * Author: Gene Zarkhin gene_zarkhin@bose.com + * Modified by: Harman Sohanpal harman_sohanpal@ti.com + * + * Based on drivers/usb/musb/da8xx.h + * + * Copyright (c) 2012 Texas Instruments Incorporated + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __AM335X_USB_H__ +#define __AM335X_USB_H__ + +#include "musb_core.h" +/* PRCM Definitions */ +#define CM_CLKDCOLDO_DPLL_PER (CM_WKUP + 0x7c) +#define CM_PER_USB0_CLKCTRL (CM_PER + 0x1c) +#define PRCM_MOD_EN 0x2 +#define PRCM_MODULE_DSBL 0x0 + + +/* Control Module Registers */ +#define CM_REGISTERS CTRL_BASE +#define USB_CTRL0_REG_OFFSET (0x628) +#define USB_CTRL1_REG_OFFSET (0x680) + +#define PRCM_IDLEST 0x30000 +#define DPLL_CLKDCOLDO_GATE_CTRL 0x300 + +/* Base address of musb wrapper */ +#define AM335X_USB_OTG_BASE 0x47401800 + +/* Base address of musb core */ +#define AM335X_USB_OTG_CORE_BASE (AM335X_USB_OTG_BASE + 0x400) + +/* Timeout for AM35x usb module */ +#define AM335X_USB_OTG_TIMEOUT 0x3FFFFFF + +/* + * AM335x platform USB wrapper register overlay. + */ +struct am335x_usb_regs { + u32 revision; /* 0x00 */ + u32 reserved0[4]; + u32 ctrl; /* 0x14 */ + u32 status; /* 0x18 */ + u32 reserved1[1]; + u32 irqmstat; /* 0x20 */ + u32 irqeoi; /* 0x24 */ + u32 irqstatraw0; /* 0x28 */ + u32 irqstatraw1; /* 0x2c */ + u32 irqstat0; /* 0x30 */ + u32 irqstat1; /* 0x34 */ + u32 irqenableset0; /* 0x38 */ + u32 irqenableset1; /* 0x3c */ + u32 irqenableclr0; /* 0x40 */ + u32 irqenableclr1; /* 0x44 */ + u32 reserved2[10]; + u32 txmode; /* 0x70 */ + u32 rxmode; /* 0x74 */ + u32 reserved3[2]; + u32 genrndisep1; /* 0x80 */ + u32 genrndisep2; /* 0x84 */ + u32 genrndisep3; /* 0x88 */ + u32 genrndisep4; /* 0x8c */ + u32 genrndisep5; /* 0x90 */ + u32 genrndisep6; /* 0x94 */ + u32 genrndisep7; /* 0x98 */ + u32 genrndisep8; /* 0x9c */ + u32 genrndisep9; /* 0xa0 */ + u32 genrndisep10; /* 0xa4 */ + u32 genrndisep11; /* 0xa8 */ + u32 genrndisep12; /* 0xac */ + u32 genrndisep13; /* 0xb0 */ + u32 genrndisep14; /* 0xb4 */ + u32 genrndisep15; /* 0xb8 */ + u32 reserved4[5]; + u32 autoreq; /* 0xd0 */ + u32 srpfixtime; /* 0xd4 */ + u32 tdown; /* 0xd8 */ + u32 reserved5[1]; + u32 utmi; /* 0xe0 */ + u32 utmilb; /* 0xe4 */ + u32 mode; /* 0xe8 */ +}; + +#define am335x_usb_regs ((struct am335x_usb_regs *)AM335X_USB_OTG_BASE) + +/* USB 2.0 PHY Control */ +#define CM_PHY_PWRDN (1 << 0) +#define CM_PHY_OTG_PWRDN (1 << 1) +#define OTGVDET_EN (1 << 19) +#define OTGSESSENDEN (1 << 20) + +/* USB CTRL REG FIELDS */ +#define SOFT_RESET_BIT (1 << 0) + +#endif /* __AM335X_USB_H__ */ diff --git a/include/usb.h b/include/usb.h index 6da91e7..13f5434 100644 --- a/include/usb.h +++ b/include/usb.h @@ -141,7 +141,8 @@ struct usb_device { defined(CONFIG_USB_SL811HS) || defined(CONFIG_USB_ISP116X_HCD) || \ defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) || \ defined(CONFIG_USB_OMAP3) || defined(CONFIG_USB_DA8XX) || \ - defined(CONFIG_USB_BLACKFIN) || defined(CONFIG_USB_AM35X) + defined(CONFIG_USB_BLACKFIN) || defined(CONFIG_USB_AM35X) || \ + defined(CONFIG_USB_AM335X)
int usb_lowlevel_init(void); int usb_lowlevel_stop(void);
This patch adds required configs in config file for am335x_evm to add support for usb host mode. To enable USB device mode, add CONFIG_MUSB_UDC in place of CONFIG_MUSB_HCD
Signed-off-by: Harman Sohanpal harman_sohanpal@ti.com --- include/configs/am335x_evm.h | 41 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 41 insertions(+), 0 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d0fbc88..d19f914 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -165,6 +165,47 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+ +/* + * USB configuration + * Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard + * Enable CONFIG_MUSB_UDC for Device functionalities. + */ +#define CONFIG_USB_AM335X 1 +#define CONFIG_MUSB_HCD 1 + +#ifdef CONFIG_USB_AM335X + +#ifdef CONFIG_MUSB_HCD +#define CONFIG_CMD_USB + +#define CONFIG_USB_STORAGE +#define CONGIG_CMD_STORAGE +#define CONFIG_CMD_FAT + +#ifdef CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_PREBOOT "usb start" +#endif /* CONFIG_USB_KEYBOARD */ + +#endif /* CONFIG_MUSB_HCD */ + +#ifdef CONFIG_MUSB_UDC +/* USB device configuration */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +#endif /* CONFIG_SPL_BUILD */ +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "AM335xEVM" +#endif /* CONFIG_MUSB_UDC */ + +#endif /* CONFIG_USB_AM335X */ + /* Unsupported features */ #undef CONFIG_USE_IRQ
- USB configuration
- Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard
- Enable CONFIG_MUSB_UDC for Device functionalities.
Please don't add the "1" to the defines. Simply define the value, thats enough.
Here again. No "1" please.
Thanks, Stefan
This patch fix the compile warning : implicit declaration of musb_platform_init when CONFIG_MUSB_UDC is defined. The extern musb_platform_init was declared in musb_hcd.h but no such extern function was declared for musb_udc. So a common function has been declared in musb_core.h which can be used for both host mode and device mode.
Signed-off-by: Harman Sohanpal harman_sohanpal@ti.com --- drivers/usb/musb/musb_core.h | 2 ++ drivers/usb/musb/musb_hcd.h | 3 --- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/musb/musb_core.h b/drivers/usb/musb/musb_core.h index a8adcce..14253f0 100644 --- a/drivers/usb/musb/musb_core.h +++ b/drivers/usb/musb/musb_core.h @@ -360,6 +360,8 @@ extern void musb_start(void); extern void musb_configure_ep(const struct musb_epinfo *epinfo, u8 cnt); extern void write_fifo(u8 ep, u32 length, void *fifo_data); extern void read_fifo(u8 ep, u32 length, void *fifo_data); +extern int musb_platform_init(void); +extern void musb_platform_deinit(void);
#if defined(CONFIG_USB_BLACKFIN) /* Every USB register is accessed as a 16-bit even if the value itself diff --git a/drivers/usb/musb/musb_hcd.h b/drivers/usb/musb/musb_hcd.h index dde7d37..5621f7e 100644 --- a/drivers/usb/musb/musb_hcd.h +++ b/drivers/usb/musb/musb_hcd.h @@ -105,8 +105,5 @@ extern unsigned char new[]; #define RH_REQ_ERR -1 #define RH_NACK 0x00
-/* extern functions */ -extern int musb_platform_init(void); -extern void musb_platform_deinit(void);
#endif /* __MUSB_HCD_H__ */
Harman Sohanpal
Stefan Roese
