[PATCHv2 1/3] common: SCP03 control (enable and provision of keys)
This Trusted Application allows enabling and provisioning SCP03 keys on TEE controlled secure element (ie, NXP SE050)
For information on SCP03, check the Global Platform HomePage[1] [1] globalplatform.org
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- common/Kconfig | 8 ++++++ common/Makefile | 1 + common/scp03.c | 52 ++++++++++++++++++++++++++++++++++++ include/scp03.h | 19 +++++++++++++ include/tee/optee_ta_scp03.h | 21 +++++++++++++++ 5 files changed, 101 insertions(+) create mode 100644 common/scp03.c create mode 100644 include/scp03.h create mode 100644 include/tee/optee_ta_scp03.h
diff --git a/common/Kconfig b/common/Kconfig index 2bb3798f80..482f123534 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -588,6 +588,14 @@ config AVB_BUF_SIZE
endif # AVB_VERIFY
+config SCP03 + bool "Build SCP03 - Secure Channel Protocol O3 - controls" + depends on OPTEE || SANDBOX + depends on TEE + help + This option allows U-Boot to enable and or provision SCP03 on an OPTEE + controlled Secured Element. + config SPL_HASH bool # "Support hashing API (SHA1, SHA256, etc.)" help diff --git a/common/Makefile b/common/Makefile index daeea67cf2..215b8b26fd 100644 --- a/common/Makefile +++ b/common/Makefile @@ -137,3 +137,4 @@ obj-$(CONFIG_CMD_LOADB) += xyzModem.o obj-$(CONFIG_$(SPL_TPL_)YMODEM_SUPPORT) += xyzModem.o
obj-$(CONFIG_AVB_VERIFY) += avb_verify.o +obj-$(CONFIG_SCP03) += scp03.o diff --git a/common/scp03.c b/common/scp03.c new file mode 100644 index 0000000000..c655283387 --- /dev/null +++ b/common/scp03.c @@ -0,0 +1,52 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021, Foundries.IO + * + */ + +#include <scp03.h> +#include <tee.h> +#include <tee/optee_ta_scp03.h> + +static int scp03_enable(bool provision) +{ + const struct tee_optee_ta_uuid uuid = PTA_SCP03_UUID; + struct tee_open_session_arg session; + struct tee_invoke_arg invoke; + struct tee_param param; + struct udevice *tee = NULL; + + tee = tee_find_device(tee, NULL, NULL, NULL); + if (!tee) + return -ENODEV; + + memset(&session, 0, sizeof(session)); + tee_optee_ta_uuid_to_octets(session.uuid, &uuid); + if (tee_open_session(tee, &session, 0, NULL)) + return -ENODEV; + + memset(¶m, 0, sizeof(param)); + param.attr = TEE_PARAM_ATTR_TYPE_VALUE_INPUT; + param.u.value.a = provision; + + memset(&invoke, 0, sizeof(invoke)); + invoke.func = PTA_CMD_ENABLE_SCP03; + invoke.session = session.session; + + if (tee_invoke_func(tee, &invoke, 1, ¶m)) + return -EIO; + + tee_close_session(tee, session.session); + + return 0; +} + +int tee_enable_scp03(void) +{ + return scp03_enable(false); +} + +int tee_provision_scp03(void) +{ + return scp03_enable(true); +} diff --git a/include/scp03.h b/include/scp03.h new file mode 100644 index 0000000000..034796ada3 --- /dev/null +++ b/include/scp03.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2021, Foundries.IO + * + */ + +#ifndef _SCP03_H +#define _SCP03_H + +/* + * Requests to OPTEE to enable or provision the Secure Channel Protocol on its + * Secure Element + * + * If key provisioning is requested, OPTEE shall generate new SCP03 keys and + * write them to the Secure Element. + */ +int tee_enable_scp03(void); +int tee_provision_scp03(void); +#endif /* _SCP03_H */ diff --git a/include/tee/optee_ta_scp03.h b/include/tee/optee_ta_scp03.h new file mode 100644 index 0000000000..13f9956d98 --- /dev/null +++ b/include/tee/optee_ta_scp03.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: BSD-3-Clause */ +/* + * (C) Copyright 2021, Foundries.IO + * + */ +#ifndef __TA_SCP03_H +#define __TA_SCP03_H + +#define PTA_SCP03_UUID { 0xbe0e5821, 0xe718, 0x4f77, \ + { 0xab, 0x3e, 0x8e, 0x6c, 0x73, 0xa9, 0xc7, 0x35 } } + +/* + * Enable Secure Channel Protocol functionality (SCP03) on the Secure Element. + * Setting the operation value to something different than NULL will trigger + * the SCP03 provisioning request. + * + * in params[0].a = operation + */ +#define PTA_CMD_ENABLE_SCP03 0 + +#endif /*__TA_SCP03_H*/
Enable and provision the SCP03 keys on a TEE controlled secured elemt from the U-Boot shell.
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- cmd/Kconfig | 9 ++++++++ cmd/Makefile | 3 +++ cmd/scp03.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 76 insertions(+) create mode 100644 cmd/scp03.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 928a2a0a2d..4f990249b4 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2021,6 +2021,15 @@ config HASH_VERIFY help Add -v option to verify data against a hash.
+config CMD_SCP03 + bool "scp03 - SCP03 enable and rotate/provision operations" + depends on SCP03 + help + Enables the SCP03 commands to activate I2C channel encryption and + provision the SCP03 keys. + scp03 enable + scp03 provision + config CMD_TPM_V1 bool
diff --git a/cmd/Makefile b/cmd/Makefile index 176bf925fd..a7017e8452 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -193,6 +193,9 @@ obj-$(CONFIG_CMD_BLOB) += blob.o # Android Verified Boot 2.0 obj-$(CONFIG_CMD_AVB) += avb.o
+# Foundries.IO SCP03 +obj-$(CONFIG_CMD_SCP03) += scp03.o + obj-$(CONFIG_ARM) += arm/ obj-$(CONFIG_RISCV) += riscv/ obj-$(CONFIG_SANDBOX) += sandbox/ diff --git a/cmd/scp03.c b/cmd/scp03.c new file mode 100644 index 0000000000..07913dbd3e --- /dev/null +++ b/cmd/scp03.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021, Foundries.IO + * + */ + +#include <common.h> +#include <command.h> +#include <env.h> +#include <scp03.h> + +int do_scp03_enable(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + if (argc != 1) + return CMD_RET_USAGE; + + if (tee_enable_scp03()) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +int do_scp03_provision(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + if (argc != 1) + return CMD_RET_USAGE; + + if (tee_provision_scp03()) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +static struct cmd_tbl cmd_scp03[] = { + U_BOOT_CMD_MKENT(enable, 1, 0, do_scp03_enable, "", ""), + U_BOOT_CMD_MKENT(provision, 1, 0, do_scp03_provision, "", ""), +}; + +static int do_scp03(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct cmd_tbl *cp; + + cp = find_cmd_tbl(argv[1], cmd_scp03, ARRAY_SIZE(cmd_scp03)); + + argc--; + argv++; + + if (!cp || argc > cp->maxargs) + return CMD_RET_USAGE; + + if (flag == CMD_FLAG_REPEAT) + return CMD_RET_FAILURE; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD(scp03, 2, 0, do_scp03, + "Provides a command to enable SCP03 and provision the SCP03 keys\n", + "\tenable - enable SCP03\n" + "\tprovision - provision SCP03\n" +);
Hi Jorge,
Same comments on this one.
Adds support for SCP03 emulation.
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- drivers/tee/optee/Kconfig | 6 ++++ drivers/tee/sandbox.c | 60 +++++++++++++++++++++++++++++++++++++-- 2 files changed, 64 insertions(+), 2 deletions(-)
diff --git a/drivers/tee/optee/Kconfig b/drivers/tee/optee/Kconfig index d489834df9..b7f704a5e6 100644 --- a/drivers/tee/optee/Kconfig +++ b/drivers/tee/optee/Kconfig @@ -22,6 +22,12 @@ config OPTEE_TA_AVB The TA can support the "avb" subcommands "read_rb", "write"rb" and "is_unlocked".
+config OPTEE_TA_SCP03 + bool "Support SCP03 TA" + default y + help + Enables support for the SCP03 Trusted Application (TA) in OP-TEE. + endmenu
endif diff --git a/drivers/tee/sandbox.c b/drivers/tee/sandbox.c index e1ba027fd6..273c23239a 100644 --- a/drivers/tee/sandbox.c +++ b/drivers/tee/sandbox.c @@ -7,6 +7,7 @@ #include <sandboxtee.h> #include <tee.h> #include <tee/optee_ta_avb.h> +#include <tee/optee_ta_scp03.h>
/* * The sandbox tee driver tries to emulate a generic Trusted Exectution @@ -32,7 +33,7 @@ struct ta_entry { struct tee_param *params); };
-#ifdef CONFIG_OPTEE_TA_AVB +#if defined(CONFIG_OPTEE_TA_SCP03) || defined(CONFIG_OPTEE_TA_AVB) static u32 get_attr(uint n, uint num_params, struct tee_param *params) { if (n >= num_params) @@ -44,7 +45,7 @@ static u32 get_attr(uint n, uint num_params, struct tee_param *params) static u32 check_params(u8 p0, u8 p1, u8 p2, u8 p3, uint num_params, struct tee_param *params) { - u8 p[] = { p0, p1, p2, p3}; + u8 p[] = { p0, p1, p2, p3 }; uint n;
for (n = 0; n < ARRAY_SIZE(p); n++) @@ -62,6 +63,55 @@ bad_params:
return TEE_ERROR_BAD_PARAMETERS; } +#endif + +#ifdef CONFIG_OPTEE_TA_SCP03 +static u32 pta_scp03_open_session(struct udevice *dev, uint num_params, + struct tee_param *params) +{ + /* + * We don't expect additional parameters when opening a session to + * this TA. + */ + return check_params(TEE_PARAM_ATTR_TYPE_NONE, TEE_PARAM_ATTR_TYPE_NONE, + TEE_PARAM_ATTR_TYPE_NONE, TEE_PARAM_ATTR_TYPE_NONE, + num_params, params); +} + +static u32 pta_scp03_invoke_func(struct udevice *dev, u32 func, uint num_params, + struct tee_param *params) +{ + u32 res; + static bool enabled; + + switch (func) { + case PTA_CMD_ENABLE_SCP03: + res = check_params(TEE_PARAM_ATTR_TYPE_VALUE_INPUT, + TEE_PARAM_ATTR_TYPE_NONE, + TEE_PARAM_ATTR_TYPE_NONE, + TEE_PARAM_ATTR_TYPE_NONE, + num_params, params); + if (res) + return res; + + if (!enabled) { + printf("SCP03 enabled\n"); + enabled = true; + } else { + printf("SCP03 already enabled, no action\n"); + } + + if (params[0].u.value.a) + printf("SCP03 keys rotated\n"); + + return TEE_SUCCESS; + default: + return TEE_ERROR_NOT_SUPPORTED; + } +} +#endif + +#ifdef CONFIG_OPTEE_TA_AVB
static u32 ta_avb_open_session(struct udevice *dev, uint num_params, struct tee_param *params) @@ -223,6 +273,12 @@ static const struct ta_entry ta_entries[] = { .invoke_func = ta_avb_invoke_func, }, #endif +#ifdef CONFIG_OPTEE_TA_SCP03 + { .uuid = PTA_SCP03_UUID, + .open_session = pta_scp03_open_session, + .invoke_func = pta_scp03_invoke_func, + }, +#endif };
static void sandbox_tee_get_version(struct udevice *dev,
Hi Jorge,
No change log, so this seems to be a resend? Anyway, see earlier comments.
Hi Jorge,
But please see below
endif # AVB_VERIFY
+config SCP03
depends on TEE
help
Why would you want to do that? Please expand this a bit
- (C) Copyright 2021, Foundries.IO
common.h
if (!tee)
return -ENODEV;
return -ENODEV;
Should return the actual error from tee_open_session(). You can't return -ENODEV as there is a device.
return -EIO;
Please return the actual error
- Requests to OPTEE to enable or provision the Secure Channel Protocol on its
- Secure Element
- If key provisioning is requested, OPTEE shall generate new SCP03 keys and
- write them to the Secure Element.
@return
On 07/02/21, Simon Glass wrote:
Hi Jorge,
endif # AVB_VERIFY
+config SCP03
depends on TEE
help
sure
common.h
if (!tee)
return -ENODEV;
return -ENODEV;
Right but there is not a TA responding to the requests (the actual handler for the TEE). But ok, will use EINVAL
return -EIO;
These functions done return a valid error (just <0 on error)
Having said that this is probably the most likely error - the i2c chip (the secure element) not being accessible but I can return something more generic like EFAULT?
Notice that if this fails 99% of the times will mean that the secure element has been bricked in the process.
- Secure Element
@return
ok
Hi Jorge,
On Sun, 7 Feb 2021 at 08:58, Jorge Ramirez-Ortiz, Foundries jorge@foundries.io wrote:
Hi Jorge,
endif # AVB_VERIFY
+config SCP03
depends on TEE
help
sure
common.h
if (!tee)
return -ENODEV;
return -ENODEV;
Then perhaps -ENXIO ?
return -EIO;
Oh that should probably be fixed at some point.
In that case -EIO is fine for now. I think of -EFAULT as a memory fault, although I don't know that we use it much in U-Boot.
OK.
Jorge Ramirez-Ortiz
