[U-Boot] [PATCH v2] patman: Support using a particular SMTP server
Some environments require providing the '--smtp-server' argument to 'git send-email'. Add support for this.
Changes in v2: - Fix 'get' typo
tools/patman/README | 1 + tools/patman/gitutil.py | 6 +++++- tools/patman/patman.py | 5 ++++- 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 606780e2ed..7917fc8bdc 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -107,6 +107,7 @@ patman.py. For reference, the useful ones (at the moment) shown below ignore_errors: True process_tags: False verbose: True +smtp_server: /path/to/sendmail
diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index 64ac0c8d3d..9905bb0bbd 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -332,7 +332,8 @@ def BuildEmailList(in_list, tag=None, alias=None, raise_on_error=True): return result
def EmailPatches(series, cover_fname, args, dry_run, raise_on_error, cc_fname, - self_only=False, alias=None, in_reply_to=None, thread=False): + self_only=False, alias=None, in_reply_to=None, thread=False, + smtp_server=None): """Email a patch series.
Args: @@ -348,6 +349,7 @@ def EmailPatches(series, cover_fname, args, dry_run, raise_on_error, cc_fname, Should be a message ID that this is in reply to. thread: True to add --thread to git send-email (make all patches reply to cover-letter or first patch in series) + smtp_server: SMTP server to use to send patches
Returns: Git command that was/would be run @@ -405,6 +407,8 @@ def EmailPatches(series, cover_fname, args, dry_run, raise_on_error, cc_fname, to = BuildEmailList([os.getenv('USER')], '--to', alias, raise_on_error) cc = [] cmd = ['git', 'send-email', '--annotate'] + if smtp_server: + cmd.append('--smtp-server=%s' % smtp_server) if in_reply_to: if type(in_reply_to) != str: in_reply_to = in_reply_to.encode('utf-8') diff --git a/tools/patman/patman.py b/tools/patman/patman.py index 8d2c78235a..7c8ba441b3 100755 --- a/tools/patman/patman.py +++ b/tools/patman/patman.py @@ -60,6 +60,8 @@ parser.add_option('--no-check', action='store_false', dest='check_patch', help="Don't check for patch compliance") parser.add_option('--no-tags', action='store_false', dest='process_tags', default=True, help="Don't process subject tags as aliaes") +parser.add_option('--smtp-server', type='str', + help="Specify the SMTP server to 'git send-email'") parser.add_option('-T', '--thread', action='store_true', dest='thread', default=False, help='Create patches as a single thread')
@@ -165,7 +167,8 @@ else: if its_a_go: cmd = gitutil.EmailPatches(series, cover_fname, args, options.dry_run, not options.ignore_bad_tags, cc_file, - in_reply_to=options.in_reply_to, thread=options.thread) + in_reply_to=options.in_reply_to, thread=options.thread, + smtp_server=options.smtp_server) else: print(col.Color(col.RED, "Not sending emails due to errors/warnings"))
Changes in v2:
- Fix 'get' typo
Applied to u-boot-dm.
