[U-Boot] [PATCH v5] Marvell Kirkwood family SOC support
Kirkwood family controllers are highly integrated SOCs based on Feroceon-88FR131/Sheeva-88SV131 cpu core.
SOC versions supported:- 1) 88F6281-A0 define CONFIG_KW88F6281_A0 2) 88F6192-A0 define CONFIG_KW88F6192_A0
Other supported features:- 1) get_random_hex() fucntion 2) SPI port controller driver 3) PCI Express port initialization
Contributors: Yotam Admon yotam@marvell.com Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit rshitrit@marvell.com Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log: v2: crated arch-kirkwood and moved some header files there renamed and moved spi.c to drivers/spi/ renamed and moved serial.c to drivers/serial/ doimage utility removed soc_init.S renamed as lowlevel_init.S debug prints removed
v3: lowlevel_init.S converted to lowlevel_init.c removed BITxx macros, removed entire assembly code Added CONFIG_ARCH_LOWLEVE_INIT support for arm926ejs core updated as per review commens for v2
v4: updated as per review comments for v3 print_cpuinfo used to display Soc info arch_misc_init support created and used for lib_arm mandatory readl/write macros used asm/cache.h asm/arch/spi.h asm//arch/serial.h created and used
v5: updated as per review comments for v4 cosmetic updates, arch_misc_init and arch_cpu_init used start.S updated to call arch_lowlevel_init in case if lowlevl_init is skipped bug fix in cpu.c
cpu/arm926ejs/kirkwood/Makefile | 50 +++++ cpu/arm926ejs/kirkwood/config.mk | 25 +++ cpu/arm926ejs/kirkwood/cpu.c | 287 +++++++++++++++++++++++++++++ cpu/arm926ejs/kirkwood/cpu.h | 99 ++++++++++ cpu/arm926ejs/kirkwood/dram.c | 57 ++++++ cpu/arm926ejs/kirkwood/lowlevel_init.S | 43 +++++ cpu/arm926ejs/kirkwood/timer.c | 159 ++++++++++++++++ cpu/arm926ejs/start.S | 9 +- drivers/serial/Makefile | 1 + drivers/serial/kirkwood_serial.c | 128 +++++++++++++ drivers/spi/Makefile | 1 + drivers/spi/kirkwood_spi.c | 167 +++++++++++++++++ include/asm-arm/arch-kirkwood/kirkwood.h | 118 ++++++++++++ include/asm-arm/arch-kirkwood/kw88f6192.h | 37 ++++ include/asm-arm/arch-kirkwood/kw88f6281.h | 37 ++++ include/asm-arm/arch-kirkwood/serial.h | 89 +++++++++ include/asm-arm/arch-kirkwood/spi.h | 39 ++++ include/asm-arm/cache.h | 49 +++++ include/asm-arm/config.h | 4 + include/common.h | 1 + lib_arm/board.c | 4 + 21 files changed, 1402 insertions(+), 2 deletions(-) create mode 100644 cpu/arm926ejs/kirkwood/Makefile create mode 100644 cpu/arm926ejs/kirkwood/config.mk create mode 100644 cpu/arm926ejs/kirkwood/cpu.c create mode 100644 cpu/arm926ejs/kirkwood/cpu.h create mode 100644 cpu/arm926ejs/kirkwood/dram.c create mode 100644 cpu/arm926ejs/kirkwood/lowlevel_init.S create mode 100644 cpu/arm926ejs/kirkwood/timer.c create mode 100644 drivers/serial/kirkwood_serial.c create mode 100644 drivers/spi/kirkwood_spi.c create mode 100644 include/asm-arm/arch-kirkwood/kirkwood.h create mode 100644 include/asm-arm/arch-kirkwood/kw88f6192.h create mode 100644 include/asm-arm/arch-kirkwood/kw88f6281.h create mode 100644 include/asm-arm/arch-kirkwood/serial.h create mode 100644 include/asm-arm/arch-kirkwood/spi.h create mode 100644 include/asm-arm/cache.h
diff --git a/cpu/arm926ejs/kirkwood/Makefile b/cpu/arm926ejs/kirkwood/Makefile new file mode 100644 index 0000000..db41d7c --- /dev/null +++ b/cpu/arm926ejs/kirkwood/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS-y = dram.o +COBJS-y += cpu.o +COBJS-y += timer.o + +SOBJS = lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm926ejs/kirkwood/config.mk b/cpu/arm926ejs/kirkwood/config.mk new file mode 100644 index 0000000..000eeb4 --- /dev/null +++ b/cpu/arm926ejs/kirkwood/config.mk @@ -0,0 +1,25 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +PLATFORM_CPPFLAGS += -march=armv5te diff --git a/cpu/arm926ejs/kirkwood/cpu.c b/cpu/arm926ejs/kirkwood/cpu.c new file mode 100644 index 0000000..035d18f --- /dev/null +++ b/cpu/arm926ejs/kirkwood/cpu.c @@ -0,0 +1,287 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <u-boot/md5.h> + +void reset_cpu(unsigned long ignored) +{ + writel(readl(KW_REG_CPU_RSTOUTN_MASK) | (1 << 2), + KW_REG_CPU_RSTOUTN_MASK); + writel(readl(KW_REG_CPU_SYS_SOFT_RST) | 1, KW_REG_CPU_SYS_SOFT_RST); + while (1) ; +} + +/* + * Generates Ramdom hex number reading some time varient system registers + * and using md5 algorithm + */ +unsigned char get_random_hex(void) +{ + int i; + u32 inbuf[16]; + u8 outbuf[16]; + + /* + * in case of 88F6281/88F6192 A0, + * Bit7 need to reset to generate random values in KW_REG_UNDOC_0x1470 + * Soc reg offsets KW_REG_UNDOC_0x1470 and KW_REG_UNDOC_0x1478 are reserved regs and + * Does not have names at this moment (no errata available) + */ + writel(readl(KW_REG_UNDOC_0x1478) | (1 << 7), KW_REG_UNDOC_0x1478); + for (i = 0; i < 16; i++) { + inbuf[i] = readl(KW_REG_UNDOC_0x1470); + } + md5((u8 *) inbuf, 64, outbuf); + return outbuf[outbuf[7] % 0x0f]; +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of 1’s followed by + * sequence of 0’s. The number of 1’s specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +static unsigned int kw_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + + for (i = 0; i < (sizeval / 0x10000); i++) { + j |= (1 << i); + } + return (0x0000ffff & j); +} + +/* prepares data to be loaded in win_Ctrl register */ +#define KWCPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (kw_winctrl_calcsize(size) << 16)) + +/* + * kw_config_adr_windows - Configure address Windows + * + * There are 7 address windows supported by Kirkwood Soc to addess different + * devices. Each window can be configured for size, BAR and remap addr + * Below configuration is standard for most of the cases + * + * Reference Documentation: + * Mbus-L to Mbus Bridge Registers Configuration. + * (Sec 25.1 and 25.3 of Datasheet) + */ +int kw_config_adr_windows(void) +{ + writel(KWCPU_WIN_CTRL_DATA(0xc0000, KWCPU_TARGET_PCIE, + KWCPU_ATTR_PCIE_MEM, KWCPU_WIN_ENABLE), + KW_REG_WIN_CTRL(0)); + + writel(0x90000000, KW_REG_WIN_BASE(0)); + writel(0x90000000, KW_REG_WIN_REMAP_LOW(0)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(0)); + + writel(KWCPU_WIN_CTRL_DATA(0x70000, KWCPU_TARGET_MEMORY, + KWCPU_ATTR_NANDFLASH, KWCPU_WIN_ENABLE), + KW_REG_WIN_CTRL(1)); + writel(0xF9000000, KW_REG_WIN_BASE(1)); + writel(0xF9000000, KW_REG_WIN_REMAP_LOW(1)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(1)); + + writel(KWCPU_WIN_CTRL_DATA(0x80000, KWCPU_TARGET_PCIE, + KWCPU_ATTR_PCIE_IO, KWCPU_WIN_ENABLE), + KW_REG_WIN_CTRL(2)); + writel(0xF0000000, KW_REG_WIN_BASE(2)); + writel(0xC0000000, KW_REG_WIN_REMAP_LOW(2)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(2)); + + writel(KWCPU_WIN_CTRL_DATA(0x80000, KWCPU_TARGET_MEMORY, + KWCPU_ATTR_SPIFLASH, KWCPU_WIN_ENABLE), + KW_REG_WIN_CTRL(3)); + writel(0xF8000000, KW_REG_WIN_BASE(3)); + writel(0x00000000, KW_REG_WIN_REMAP_LOW(3)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(3)); + + writel(KWCPU_WIN_CTRL_DATA(0x80000, KWCPU_TARGET_MEMORY, + KWCPU_ATTR_BOOTROM, KWCPU_WIN_ENABLE), + KW_REG_WIN_CTRL(4)); + writel(0xFF000000, KW_REG_WIN_BASE(4)); + writel(0x00000000, KW_REG_WIN_REMAP_LOW(4)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(4)); + + writel(KWCPU_WIN_CTRL_DATA(0xb0000, KWCPU_TARGET_MEMORY, + KWCPU_ATTR_SPIFLASH, KWCPU_WIN_DISABLE), + KW_REG_WIN_CTRL(5)); + writel(0xE8000000, KW_REG_WIN_BASE(5)); + writel(0x00000000, KW_REG_WIN_REMAP_LOW(5)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(5)); + + writel(KWCPU_WIN_CTRL_DATA(0xb0000, KWCPU_TARGET_MEMORY, + KWCPU_ATTR_BOOTROM, KWCPU_WIN_DISABLE), + KW_REG_WIN_CTRL(6)); + writel(0xF0000000, KW_REG_WIN_BASE(6)); + writel(0x00000000, KW_REG_WIN_REMAP_LOW(6)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(6)); + + writel(KWCPU_WIN_CTRL_DATA(0x0, KWCPU_TARGET_SASRAM, KWCPU_ATTR_SASRAM, + KWCPU_WIN_ENABLE), KW_REG_WIN_CTRL(7)); + writel(0xFB000000, KW_REG_WIN_BASE(7)); + writel(0x00000000, KW_REG_WIN_REMAP_LOW(7)); + writel(0x00000000, KW_REG_WIN_REMAP_HIGH(7)); + + return 0; +} + +/* + * kw_config_gpio - GPIO configuration + */ +void kw_config_gpio(u32 gpp0_oe_val, u32 gpp1_oe_val, u32 gpp0_oe, u32 gpp1_oe) +{ + /* Init GPIOS to default values as per board requirement */ + writel(gpp0_oe_val, KW_REG_GPP0_DATA_OUT); + writel(gpp1_oe_val, KW_REG_GPP1_DATA_OUT); + writel(gpp0_oe, KW_REG_GPP0_DATA_OUT_EN); + writel(gpp1_oe, KW_REG_GPP1_DATA_OUT_EN); +} + +/* + * kw_config_mpp - Multi-Purpose Pins Functionality configuration + * + * Each MPP can be configured to different functionality through + * MPP control register, ref (sec 6.1 of kirkwood h/w specification) + * + * There are maximum 64 Multi-Pourpose Pins on Kirkwood + * Each MPP functionality can be configuration by a 4bit value + * of MPP control reg, the value and associated functionality depends + * upon used SoC varient + */ +int kw_config_mpp(u32 mpp0_7, u32 mpp8_15, u32 mpp16_23, u32 mpp24_31, + u32 mpp32_39, u32 mpp40_47, u32 mpp48_55) +{ + /* program mpp registers */ + writel(mpp0_7, KW_REG_MPP_CONTROL0); + writel(mpp8_15, KW_REG_MPP_CONTROL1); + writel(mpp16_23, KW_REG_MPP_CONTROL2); + writel(mpp24_31, KW_REG_MPP_CONTROL3); + writel(mpp32_39, KW_REG_MPP_CONTROL4); + writel(mpp40_47, KW_REG_MPP_CONTROL5); + writel(mpp48_55, KW_REG_MPP_CONTROL6); + return 0; +} + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + char *name = "Unknown"; + + switch (readl(KW_REG_DEVICE_ID) & 0x03) { + case 1: + name = "88F6192_A0"; + break; + case 2: + name = "88F6281_A0"; + break; + default: + break; + } + printf("SoC: Kirkwood %s\n", name); + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + u32 reg; + + kw_config_adr_windows(); + +#ifdef CONFIG_KIRKWOOD_RGMII_PAD_1V8 + /* + * Configures the I/O voltage of the pads connected to Egigabit + * Ethernet interface to 1.8V + * By defult it is set to 3.3V + */ + reg = readl(KW_REG_MPP_OUT_DRV_REG); + reg |= (1 << 7); + writel(reg, KW_REG_MPP_OUT_DRV_REG); +#endif +#ifdef CONFIG_KIRKWOOD_EGIGA_INIT + /* + * Set egiga port0/1 in normal functional mode + * This is required becasue on kirkwood by default ports are in reset mode + * OS egiga driver may not have provision to set them in normal mode + * and if u-boot is build without network support, network may fail at OS level + */ + reg = readl((KW_EGIGA0_BASE + 0x44c)); /* PORT_SERIAL_CONTROL1_REG */ + reg &= ~(1 << 4); /* Clear PortReset Bit */ + writel(reg, (KW_EGIGA0_BASE + 0x44c)); /* PORT_SERIAL_CONTROL1_REG */ + reg = readl((KW_EGIGA1_BASE + 0x44c)); /* PORT_SERIAL_CONTROL1_REG */ + reg &= ~(1 << 4); /* Clear PortReset Bit */ + writel(reg, (KW_EGIGA1_BASE + 0x44c)); /* PORT_SERIAL_CONTROL1_REG */ +#endif +#ifdef CONFIG_KIRKWOOD_PCIE_INIT + /* + * Enable PCI Express Port0 + */ + reg = readl(KW_REG_CPU_CTRL_STAT); + reg |= (1 << 0); /* Set PEX0En Bit */ + writel(reg, KW_REG_CPU_CTRL_STAT); +#endif + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +/* + * SOC specific misc init + */ +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ + volatile u32 temp; + + /*CPU streaming & write allocate */ + temp = readfr_extra_feature_reg(); + temp &= ~(1 << 28); /* disable wr alloc */ + writefr_extra_feature_reg(temp); + + temp = readfr_extra_feature_reg(); + temp &= ~(1 << 29); /* streaming disabled */ + writefr_extra_feature_reg(temp); + + /* L2Cache settings */ + temp = readfr_extra_feature_reg(); + /* Disable L2C pre fetch - Set bit 24 */ + temp |= (1 << 24); + /* enable L2C - Set bit 22 */ + temp |= (1 << 22); + writefr_extra_feature_reg(temp); + + icache_enable(); + /* Change reset vector to address 0x0 */ + temp = get_cr(); + set_cr(temp & ~CR_V); + + return 0; +} +#endif /* CONFIG_ARCH_MISC_INIT */ diff --git a/cpu/arm926ejs/kirkwood/cpu.h b/cpu/arm926ejs/kirkwood/cpu.h new file mode 100644 index 0000000..6cdf8b8 --- /dev/null +++ b/cpu/arm926ejs/kirkwood/cpu.h @@ -0,0 +1,99 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _KWCPU_H +#define _KWCPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ +enum memory_bank { + BANK0, + BANK1, + BANK2, + BANK3 +}; + +enum kwcpu_winen { + KWCPU_WIN_DISABLE, + KWCPU_WIN_ENABLE +}; + +enum kwcpu_target { + KWCPU_TARGET_RESERVED, + KWCPU_TARGET_MEMORY, + KWCPU_TARGET_1RESERVED, + KWCPU_TARGET_SASRAM, + KWCPU_TARGET_PCIE +}; + +enum kwcpu_attrib { + KWCPU_ATTR_SASRAM = 0x01, + KWCPU_ATTR_NANDFLASH = 0x2f, + KWCPU_ATTR_SPIFLASH = 0x1e, + KWCPU_ATTR_BOOTROM = 0x1d, + KWCPU_ATTR_PCIE_IO = 0xe0, + KWCPU_ATTR_PCIE_MEM = 0xe8 +}; + +/* + * read feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr":"=r" + (val)::"cc"); + return val; +} + +/* + * write feroceon/sheeva core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr"::"r" + (val):"cc"); + isb(); +} + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +unsigned char get_random_hex(void); +unsigned int kw_sdram_bar(enum memory_bank bank); +unsigned int kw_sdram_bs(enum memory_bank bank); +int kw_config_adr_windows(void); +void kw_config_gpio(unsigned int gpp0_oe_val, unsigned int gpp1_oe_val, + unsigned int gpp0_oe, unsigned int gpp1_oe); +int kw_config_mpp(unsigned int mpp0_7, unsigned int mpp8_15, + unsigned int mpp16_23, unsigned int mpp24_31, + unsigned int mpp32_39, unsigned int mpp40_47, + unsigned int mpp48_55); +#endif /* __ASSEMBLY__ */ + +#endif /* _KWCPU_H */ diff --git a/cpu/arm926ejs/kirkwood/dram.c b/cpu/arm926ejs/kirkwood/dram.c new file mode 100644 index 0000000..9abdca2 --- /dev/null +++ b/cpu/arm926ejs/kirkwood/dram.c @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> + +#define KW_REG_CPUCS_WIN_BAR(x) (KW_REGISTER(0x1500) + (x * 0x08)) +#define KW_REG_CPUCS_WIN_SZ(x) (KW_REGISTER(0x1504) + (x * 0x08)) +/* + * kw_sdram_bar - reads SDRAM Base Address Register + */ +u32 kw_sdram_bar(enum memory_bank bank) +{ + u32 result = 0; + u32 enable = 0x01 & readl(KW_REG_CPUCS_WIN_SZ(bank)); + + if ((!enable) || (bank > BANK3)) + return 0; + + result = readl(KW_REG_CPUCS_WIN_BAR(bank)); + return result; +} + +/* + * kw_sdram_bs - reads SDRAM Bank size + */ +u32 kw_sdram_bs(enum memory_bank bank) +{ + u32 result = 0; + u32 enable = 0x01 & readl(KW_REG_CPUCS_WIN_SZ(bank)); + + if ((!enable) || (bank > BANK3)) + return 0; + result = 0xff000000 & readl(KW_REG_CPUCS_WIN_SZ(bank)); + result += 0x01000000; + return result; +} diff --git a/cpu/arm926ejs/kirkwood/lowlevel_init.S b/cpu/arm926ejs/kirkwood/lowlevel_init.S new file mode 100644 index 0000000..d81ad05 --- /dev/null +++ b/cpu/arm926ejs/kirkwood/lowlevel_init.S @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <asm/cache.h> + + .globl arch_lowlevel_init +arch_lowlevel_init: + /* Linux expects` the internal registers to be at 0xf1000000 */ + ldr r1, = KW_OFFSET_REG + ldr r3, = KW_REGS_PHY_BASE + str r3,[r1] + + /* Enable L2 cache in write through mode */ + ldr r1, = KW_REG_CPU_L2_CONFIG + ldr r2, [r1] + orr r2, r2, #0x18 + str r2, [r1] + + asm_invalidate_l2_cache + + mov pc, lr diff --git a/cpu/arm926ejs/kirkwood/timer.c b/cpu/arm926ejs/kirkwood/timer.c new file mode 100644 index 0000000..034acb9 --- /dev/null +++ b/cpu/arm926ejs/kirkwood/timer.c @@ -0,0 +1,159 @@ +/* + * Copyright (C) Marvell International Ltd. and its affiliates + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG KW_REG_TMR_CTRL +#define CNTMR_RELOAD_REG(tmrnum) (KW_REG_TMR_RELOAD + tmrnum*8) +#define CNTMR_VAL_REG(tmrnum) (KW_REG_TMR_VAL + tmrnum*8) + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define TIMER0_NUM 0 +#define TIMER1_NUM 1 +#define WATCHDOG_NUM 2 + +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / \ + (CONFIG_SYS_TCLK / 1000)) + +static ulong timestamp; +static ulong lastdec; + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = READ_TIMER; + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += + lastdec + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +void udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current) ; + while ((TIMER_LOAD_VAL - delayticks) < + readl(CNTMR_VAL_REG(UBOOT_CNTR))) ; + } else { + while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) > + (current - delayticks)) ; + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrCtrl; + + /* load value onto counter\timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* set the counter to load in the first time */ + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* set control for timer \ cunter and enable */ + /* read control register */ + cntmrCtrl = readl(CNTMR_CTRL_REG); + cntmrCtrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); /* enable cnt\timer */ + cntmrCtrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); /* Auto mode */ + + writel(cntmrCtrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + reset_timer_masked(); + + return 0; +} diff --git a/cpu/arm926ejs/start.S b/cpu/arm926ejs/start.S index ed4932a..bdbb7e0 100644 --- a/cpu/arm926ejs/start.S +++ b/cpu/arm926ejs/start.S @@ -139,7 +139,7 @@ reset: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !defined (CONFIG_SKIP_LOWLEVEL_INIT) || defined (CONFIG_ARCH_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -201,7 +201,7 @@ _start_armboot: * ************************************************************************* */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !defined (CONFIG_SKIP_LOWLEVEL_INIT) || defined (CONFIG_ARCH_LOWLEVEL_INIT) cpu_init_crit: /* * flush v4 I/D caches @@ -224,7 +224,12 @@ cpu_init_crit: * Go setup Memory and board specific bits prior to relocation. */ mov ip, lr /* perserve link reg across call */ +#ifdef CONFIG_ARCH_LOWLEVEL_INIT + bl arch_lowlevel_init /* go setup arch specific init */ +#endif /* CONFIG_ARCH_LOWLEVEL_INIT */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT bl lowlevel_init /* go setup pll,mux,memory */ +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ mov lr, ip /* restore link */ mov pc, lr /* back to my caller */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 14c818d..9174ec6 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libserial.a COBJS-$(CONFIG_ARM_DCC) += arm_dcc.o COBJS-$(CONFIG_AT91RM9200_USART) += at91rm9200_usart.o COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o +COBJS-$(CONFIG_KIRKWOOD_SERIAL) += kirkwood_serial.o COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-$(CONFIG_NS9750_UART) += ns9750_serial.o COBJS-$(CONFIG_SYS_NS16550) += ns16550.o diff --git a/drivers/serial/kirkwood_serial.c b/drivers/serial/kirkwood_serial.c new file mode 100644 index 0000000..2f79d59 --- /dev/null +++ b/drivers/serial/kirkwood_serial.c @@ -0,0 +1,128 @@ +/* + * Copyright (C) Marvell International Ltd. and its affiliates + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/arch/serial.h> + +/* static variables */ +#if defined (CONFIG_CONS_INDEX) /* comes from board config */ +#if (CONFIG_CONS_INDEX == 0 ) +static volatile struct kw_uart_port *p_uart_port = + (void *)KW_REGISTER(KW_UART0_BASE); +#elif (CONFIG_CONS_INDEX == 1 ) +static volatile struct kw_uart_port *p_uart_port = + (void *)KW_REGISTER(KW_UART1_BASE); +#endif +#else +#error CONFIG_CONS_INDEX not defined correctly +#endif + +#define CONFIG_KW_UART_PORTS { (void *)KW_UART0_BASE, \ + (void *)KW_UART1_BASE } + +/* + * Serial init banner is kept simplest one + * if required can be created good one + */ +int serial_init(void) +{ + serial_setbrg(); + printf + ("\n*************************************************************"); + return (0); +} + +static void kw_uart_putc(u8 c) +{ + while ((p_uart_port->lsr & LSR_THRE) == 0) ; + p_uart_port->thr = c; + return; +} + +void serial_putc(const char c) +{ + if (c == '\n') + kw_uart_putc('\r'); + + kw_uart_putc(c); +} + +int serial_getc(void) +{ + while ((p_uart_port->lsr & LSR_DR) == 0) ; + return (p_uart_port->rbr); +} + +int serial_tstc(void) +{ + return ((p_uart_port->lsr & LSR_DR) != 0); +} + +void serial_setbrg(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + int clock_divisor = (CONFIG_SYS_TCLK / 16) / gd->baudrate; + + p_uart_port->ier = 0x00; + p_uart_port->lcr = LCR_DIVL_EN; /* Access baud rate */ + p_uart_port->dll = clock_divisor & 0xff; /* 9600 baud */ + p_uart_port->dlm = (clock_divisor >> 8) & 0xff; + p_uart_port->lcr = LCR_8N1; /* 8 data, 1 stop, no parity */ + /* Clear & enable FIFOs */ + p_uart_port->fcr = FCR_FIFO_EN | FCR_RXSR | FCR_TXSR; + return; +} + +void serial_puts(const char *s) +{ + while (*s) { + serial_putc(*s++); + } +} + +#ifdef CONFIG_CMD_KGDB +void kgdb_serial_init(void) +{ +} + +void putDebugChar(int c) +{ + serial_putc(c); +} + +void putDebugStr(const char *str) +{ + serial_puts(str); +} + +int getDebugChar(void) +{ + return serial_getc(); +} + +void kgdb_interruptible(int yes) +{ + return; +} +#endif /* CONFIG_CMD_KGDB */ diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 1350f3e..7ffa47d 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libspi.a COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o +COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c new file mode 100644 index 0000000..f7a70ce --- /dev/null +++ b/drivers/spi/kirkwood_spi.c @@ -0,0 +1,167 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * Derived from drivers/spi/mpc8xxx_spi.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/arch/spi.h> + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct spi_slave *slave; + u32 data; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + slave = malloc(sizeof(struct spi_slave)); + if (!slave) + return NULL; + + slave->bus = bus; + slave->cs = cs; + + writel(0x00000002, KW_REG_SPI_CTRL); + /* program spi clock prescaller using max_hz */ + data = ((CONFIG_SYS_TCLK / 2) / max_hz) & 0x0000000f; + debug("data = 0x%08x \n", data); + writel(0x00000210 | data, KW_REG_SPI_CONFIG); + writel(0x00000001, KW_REG_SPI_IRQ_CAUSE); + writel(0x00000000, KW_REG_SPI_IRQ_MASK); + + /* program mpp registers to select SPI_CSn */ + if (cs) + writel((readl(KW_REG_MPP_CONTROL0) & 0x0fffffff) | + 0x20000000, KW_REG_MPP_CONTROL0); + else + writel((readl(KW_REG_MPP_CONTROL0) & 0xfffffff0) | + 0x00000002, KW_REG_MPP_CONTROL0); + + return slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +#ifndef CONFIG_SPI_CS_IS_VALID +/* + * you can define this function board specific + * define above CONFIG in board specific config file and + * provide the function in board specific src file + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && (cs == 0 || cs == 1)); +} +#endif + +void spi_cs_activate(struct spi_slave *slave) +{ + writel(readl(KW_REG_SPI_CTRL) | 1, KW_REG_SPI_CTRL); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + writel(readl(KW_REG_SPI_CTRL) & ~1, KW_REG_SPI_CTRL); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + unsigned int tmpdout, tmpdin; + int tm, isread = 0; + + debug("spi_xfer: slave %u:%u dout %08X din %08X bitlen %u\n", + slave->bus, slave->cs, dout, din, bitlen); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + /* + * handle data in 8-bit chunks + * TBD: 2byte xfer mode to be enabled + */ + while (bitlen > 4) { + debug("loopstart bitlen %d\n", bitlen); + tmpdout = 0; + /*1 byte xfer mode */ + writel(readl(KW_REG_SPI_CONFIG) & ~(1 << 5), KW_REG_SPI_CONFIG); + /* Shift data so it's msb-justified */ + if (dout) + tmpdout = *(u32 *) dout & 0x0ff; + + writel(0x0, KW_REG_SPI_IRQ_CAUSE); /* clear bit */ + writel(tmpdout, KW_REG_SPI_DATA_OUT); /* Write the data out */ + debug("*** spi_xfer: ... %08x written, bitlen %d\n", + tmpdout, bitlen); + + /* + * Wait for SPI transmit to get out + * or time out (1 second = 1000 ms) + * The NE event must be read and cleared first + */ + for (tm = 0, isread = 0; tm < KW_SPI_TIMEOUT; ++tm) { + if (readl(KW_REG_SPI_IRQ_CAUSE)) { + isread = 1; + tmpdin = readl(KW_REG_SPI_DATA_IN); + debug + ("*** spi_xfer: din %08X ... %08x read\n", + din, tmpdin); + + if (din) { + *((u8 *) din) = (u8) tmpdin; + din += 1; + } + if (dout) + dout += 1; + bitlen -= 8; + } + if (isread) + break; + } + if (tm >= KW_SPI_TIMEOUT) + printf("*** spi_xfer: Time out during SPI transfer\n"); + + debug("loopend bitlen %d\n", bitlen); + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +} diff --git a/include/asm-arm/arch-kirkwood/kirkwood.h b/include/asm-arm/arch-kirkwood/kirkwood.h new file mode 100644 index 0000000..d06ec35 --- /dev/null +++ b/include/asm-arm/arch-kirkwood/kirkwood.h @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * Header file for the Marvell's Feroceon CPU core. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ASM_ARCH_KIRKWOOD_H +#define _ASM_ARCH_KIRKWOOD_H + +#ifndef __ASSEMBLY__ +#include <asm/types.h> +#include <asm/io.h> +#endif /* __ASSEMBLY__ */ + +#if defined (CONFIG_FEROCEON_88FR131) || defined (CONFIG_SHEEVA_88SV131) +#if defined (CONFIG_KIRKWOOD) +#include <../cpu/arm926ejs/kirkwood/cpu.h> + +/* SOC specific definations */ +#define INTREG_BASE 0xd0000000 +#define KW_REGISTER(x) (KW_REGS_PHY_BASE | x) +#define KW_OFFSET_REG (INTREG_BASE | 0x20080) + +/* undocumented registers */ +#define KW_REG_UNDOC_0x1470 (KW_REGISTER(0x1470)) +#define KW_REG_UNDOC_0x1478 (KW_REGISTER(0x1478)) + +#define KW_UART0_BASE (KW_REGISTER(0x12000)) /* UArt 0 */ +#define KW_UART1_BASE (KW_REGISTER(0x13000)) /* UArt 1 */ + +/* Controler environment registers offsets */ +#define KW_REG_MPP_CONTROL0 (KW_REGISTER(0x10000)) +#define KW_REG_MPP_CONTROL1 (KW_REGISTER(0x10004)) +#define KW_REG_MPP_CONTROL2 (KW_REGISTER(0x10008)) +#define KW_REG_MPP_CONTROL3 (KW_REGISTER(0x1000C)) +#define KW_REG_MPP_CONTROL4 (KW_REGISTER(0x10010)) +#define KW_REG_MPP_CONTROL5 (KW_REGISTER(0x10014)) +#define KW_REG_MPP_CONTROL6 (KW_REGISTER(0x10018)) +#define KW_REG_MPP_SMPL_AT_RST (KW_REGISTER(0x10030)) +#define KW_REG_DEVICE_ID (KW_REGISTER(0x10034)) +#define KW_REG_MPP_OUT_DRV_REG (KW_REGISTER(0x100E0)) + +#define KW_REG_GPP0_DATA_OUT (KW_REGISTER(0x10100)) +#define KW_REG_GPP0_DATA_OUT_EN (KW_REGISTER(0x10104)) +#define KW_REG_GPP0_BLINK_EN (KW_REGISTER(0x10108)) +#define KW_REG_GPP0_DATA_IN_POL (KW_REGISTER(0x1010C)) +#define KW_REG_GPP0_DATA_IN (KW_REGISTER(0x10110)) +#define KW_REG_GPP0_INT_CAUSE (KW_REGISTER(0x10114)) +#define KW_REG_GPP0_INT_MASK (KW_REGISTER(0x10118)) +#define KW_REG_GPP0_INT_LVL (KW_REGISTER(0x1011c)) + +#define KW_REG_GPP1_DATA_OUT (KW_REGISTER(0x10140)) +#define KW_REG_GPP1_DATA_OUT_EN (KW_REGISTER(0x10144)) +#define KW_REG_GPP1_BLINK_EN (KW_REGISTER(0x10148)) +#define KW_REG_GPP1_DATA_IN_POL (KW_REGISTER(0x1014C)) +#define KW_REG_GPP1_DATA_IN (KW_REGISTER(0x10150)) +#define KW_REG_GPP1_INT_CAUSE (KW_REGISTER(0x10154)) +#define KW_REG_GPP1_INT_MASK (KW_REGISTER(0x10158)) +#define KW_REG_GPP1_INT_LVL (KW_REGISTER(0x1015c)) + +#define KW_REG_NAND_READ_PARAM (KW_REGISTER(0x10418)) +#define KW_REG_NAND_WRITE_PARAM (KW_REGISTER(0x1041c)) +#define KW_REG_NAND_CTRL (KW_REGISTER(0x10470)) + +#define KW_REG_WIN_CTRL(x) (KW_REGISTER((0x20000 + (x * 0x10)))) +#define KW_REG_WIN_BASE(x) (KW_REGISTER((0x20004 + (x * 0x10)))) +#define KW_REG_WIN_REMAP_LOW(x) (KW_REGISTER((0x20008 + (x * 0x10)))) +#define KW_REG_WIN_REMAP_HIGH(x) (KW_REGISTER((0x2000c + (x * 0x10)))) + +#define KW_REG_CPU_CONFIG (KW_REGISTER(0x20100)) +#define KW_REG_CPU_CTRL_STAT (KW_REGISTER(0x20104)) +#define KW_REG_CPU_RSTOUTN_MASK (KW_REGISTER(0x20108)) +#define KW_REG_CPU_SYS_SOFT_RST (KW_REGISTER(0x2010C)) +#define KW_REG_CPU_AHB_MBUS_CAUSE_INT (KW_REGISTER(0x20110)) +#define KW_REG_CPU_AHB_MBUS_MASK_INT (KW_REGISTER(0x20114)) +#define KW_REG_CPU_FTDLL_CONFIG (KW_REGISTER(0x20120)) +#define KW_REG_CPU_L2_CONFIG (KW_REGISTER(0x20128)) +#define KW_REG_L2_RAM_TIMING0 (KW_REGISTER(0x20134)) +#define KW_REG_L2_RAM_TIMING1 (KW_REGISTER(0x20138)) + +#define KW_REG_TMR_CTRL (KW_REGISTER(0x20300)) +#define KW_REG_TMR_RELOAD (KW_REGISTER(0x20310)) +#define KW_REG_TMR_VAL (KW_REGISTER(0x20314)) + +#define KW_REG_PCIE_BASE (KW_REGISTER(0x40000)) + +#define KW_EGIGA0_BASE (KW_REGISTER(0x72000)) +#define KW_EGIGA1_BASE (KW_REGISTER(0x76000)) + +#if defined (CONFIG_KW88F6281) +#include "kw88f6281.h" +#endif /* CONFIG_KW88F6281 */ +#if defined (CONFIG_KW88F6192) +#include "kw88f6192.h" +#endif /* CONFIG_KW88F6192 */ +#endif /* CONFIG_KIRKWOOD */ +#endif /* CONFIG_FEROCEON_88FR131 */ +#endif /* _ASM_ARCH_KIRKWOOD_H */ diff --git a/include/asm-arm/arch-kirkwood/kw88f6192.h b/include/asm-arm/arch-kirkwood/kw88f6192.h new file mode 100644 index 0000000..000fc16 --- /dev/null +++ b/include/asm-arm/arch-kirkwood/kw88f6192.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * Header file for Feroceon CPU core 88FR131 Based KW88F6192 SOC. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_KW88F6192_H +#define _CONFIG_KW88F6192_H + +/* SOC specific definations */ +#define KW88F6192_REGS_PHYS_BASE 0xf1000000 +#define KW_REGS_PHY_BASE KW88F6192_REGS_PHYS_BASE + +/* TCLK Core Clock defination */ +#define CONFIG_SYS_TCLK 166000000 /* 166MHz */ + +#endif /* _CONFIG_KW88F6192_H */ diff --git a/include/asm-arm/arch-kirkwood/kw88f6281.h b/include/asm-arm/arch-kirkwood/kw88f6281.h new file mode 100644 index 0000000..270d931 --- /dev/null +++ b/include/asm-arm/arch-kirkwood/kw88f6281.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * Header file for Feroceon CPU core 88FR131 Based KW88F6281 SOC. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ASM_ARCH_KW88F6281_H +#define _ASM_ARCH_KW88F6281_H + +/* SOC specific definations */ +#define KW88F6281_REGS_PHYS_BASE 0xf1000000 +#define KW_REGS_PHY_BASE KW88F6281_REGS_PHYS_BASE + +/* TCLK Core Clock defination*/ +#define CONFIG_SYS_TCLK 200000000 /* 200MHz */ + +#endif /* _ASM_ARCH_KW88F6281_H */ diff --git a/include/asm-arm/arch-kirkwood/serial.h b/include/asm-arm/arch-kirkwood/serial.h new file mode 100644 index 0000000..5fd3b31 --- /dev/null +++ b/include/asm-arm/arch-kirkwood/serial.h @@ -0,0 +1,89 @@ +/* + * Copyright (C) Marvell International Ltd. and its affiliates + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __KW_SERIAL_H__ +#define __KW_SERIAL_H__ + +/* registers feilds */ +#define FCR_FIFO_EN (1 << 0) /* fifo enable */ +#define FCR_RXSR (1 << 1) /* receiver soft reset */ +#define FCR_TXSR (1 << 2) /* transmitter soft reset */ +#define MCR_RTS (1 << 1) /* ready to send */ + +#define LCR_WLS_OFFS 0 +#define LCR_WLS_MASK (0x3 << LCR_WLS_OFFS) /* character length mask */ +#define LCR_WLS_5 (0x0 << LCR_WLS_OFFS) /* 5 bit character length */ +#define LCR_WLS_6 (0x1 << LCR_WLS_OFFS) /* 6 bit character length */ +#define LCR_WLS_7 (0x2 << LCR_WLS_OFFS) /* 7 bit character length */ +#define LCR_WLS_8 (0x3 << LCR_WLS_OFFS) /* 8 bit character length */ +#define LCR_STP_OFFS 2 +#define LCR_1_STB (0x0 << LCR_STP_OFFS) /* Number of stop Bits */ +#define LCR_2_STB (0x1 << LCR_STP_OFFS) /* Number of stop Bits */ +#define LCR_PEN 0x8 /* Parity enable */ +#define LCR_PS_OFFS 4 +#define LCR_EPS (0x1 << LCR_PS_OFFS) /* Even Parity Select */ +#define LCR_OPS (0x0 << LCR_PS_OFFS) /* Odd Parity Select */ +#define LCR_SBRK_OFFS 0x6 +#define LCR_SBRK (0x1 << LCR_SBRK_OFFS) /* Set Break */ +#define LCR_DIVL_OFFS 7 +#define LCR_DIVL_EN (0x1 << LCR_DIVL_OFFS) /* Divisior latch enable */ + +#define LSR_DR (1 << 0) /* Data ready */ +#define LSR_OE (1 << 1) /* Overrun */ +#define LSR_PE (1 << 2) /* Parity error */ +#define LSR_FE (1 << 3) /* Framing error */ +#define LSR_BI (1 << 4) /* Break */ +#define LSR_THRE (1 << 5) /* Xmit holding register empty */ +#define LSR_TEMT (1 << 6) /* Xmitter empty */ +#define LSR_ERR (1 << 7) /* Error */ + +/* useful defaults for LCR*/ +#define LCR_8N1 LCR_WLS_8 | LCR_1_STB + +/* This structure describes the registers offsets for one UART port/channel */ +struct kw_uart_port { + u8 rbr; /* 0 = 0-3 */ + u8 pad1[3]; + u8 ier; /* 1 = 4-7 */ + u8 pad2[3]; + u8 fcr; /* 2 = 8-b */ + u8 pad3[3]; + u8 lcr; /* 3 = c-f */ + u8 pad4[3]; + u8 mcr; /* 4 = 10-13 */ + u8 pad5[3]; + u8 lsr; /* 5 = 14-17 */ + u8 pad6[3]; + u8 msr; /* 6 =18-1b */ + u8 pad7[3]; + u8 scr; /* 7 =1c-1f */ + u8 pad8[3]; +}; + +/* aliases - for registers which has the same offsets */ +#define thr rbr +#define iir fcr +#define dll rbr +#define dlm ier + +#endif /* __KW_SERIAL_H__ */ diff --git a/include/asm-arm/arch-kirkwood/spi.h b/include/asm-arm/arch-kirkwood/spi.h new file mode 100644 index 0000000..0fd9131 --- /dev/null +++ b/include/asm-arm/arch-kirkwood/spi.h @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * Derived from drivers/spi/mpc8xxx_spi.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __KW_SPI_H__ +#define __KW_SPI_H__ + +/* SPI Registers on kirkwood SOC */ +#define KW_REG_SPI_CTRL KW_REGISTER(0x10600) +#define KW_REG_SPI_CONFIG KW_REGISTER(0x10604) +#define KW_REG_SPI_DATA_OUT KW_REGISTER(0x10608) +#define KW_REG_SPI_DATA_IN KW_REGISTER(0x1060c) +#define KW_REG_SPI_IRQ_CAUSE KW_REGISTER(0x10610) +#define KW_REG_SPI_IRQ_MASK KW_REGISTER(0x10614) + +#define KW_SPI_TIMEOUT 10000 +#endif __KW_SPI_H__ diff --git a/include/asm-arm/cache.h b/include/asm-arm/cache.h new file mode 100644 index 0000000..07eef4c --- /dev/null +++ b/include/asm-arm/cache.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ASM_CACHE_H +#define _ASM_CACHE_H + +#ifndef __ASSEMBLY__ +#include <asm/system.h> + +/* + * Invalidate L2 Cache using co-proc instruction + */ +static inline void invalidate_l2_cache(void) +{ + unsigned int val=0; + + asm volatile("mcr p15, 1, %0, c15, c11, 0 @ invl l2 cache" + : : "r" (val) : "cc"); + isb(); +} +#else +.macro asm_invalidate_l2_cache + mov r0, #0 + mcr p15, 1, r0, c15, c11, 0 +.endm +#endif /* __ASSEMBLY__ */ + +#endif /* _ASM_CACHE_H */ diff --git a/include/asm-arm/config.h b/include/asm-arm/config.h index 049c44e..5d52f15 100644 --- a/include/asm-arm/config.h +++ b/include/asm-arm/config.h @@ -21,4 +21,8 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#if defined (CONFIG_KIRKWOOD) +#include <asm-arm/arch-kirkwood/kirkwood.h> +#endif /* CONFIG_KIRKWOOD */ + #endif diff --git a/include/common.h b/include/common.h index 30fff7d..9e4b859 100644 --- a/include/common.h +++ b/include/common.h @@ -294,6 +294,7 @@ void pciinfo (int, int); #endif #endif
+int arch_misc_init (void); int misc_init_f (void); int misc_init_r (void);
diff --git a/lib_arm/board.c b/lib_arm/board.c index 5d05d9b..b8db60d 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -393,6 +393,10 @@ void start_armboot (void)
console_init_r (); /* fully init console as a device */
+#if defined(CONFIG_ARCH_MISC_INIT) + /* miscellaneous arch dependent initialisations */ + arch_misc_init (); +#endif #if defined(CONFIG_MISC_INIT_R) /* miscellaneous platform dependent initialisations */ misc_init_r ();
Prafulla Wadaskar
