[U-Boot] [PATCH v3 00/17] nand: remove direct acces to nand_info array
This is a preparation required for adding Nand DM support. This series introduces new API get_nand_dev_by_index() to avoid direct acces to nand_info array and updates u-boot to use it. As result, nand_info array is made static in the last patch.
Changes in v3: - preparation patches separated from original series. - fixed BeagleBoard-xM boot failure which has Nand enabled, but no Nand devices are presented on board physically. - all current direct users were converted to use get_nand_dev_by_index() and nand_info array was made static finally.
link on v2 [1]: - https://www.mail-archive.com/u-boot@lists.denx.de/msg237747.html
Grygorii Strashko (16): common: env_nand: use get_nand_dev_by_index() dfu: dfu_nand: use get_nand_dev_by_index() cmd: bootm: use get_nand_dev_by_index() cmd: jffs2: use get_nand_dev_by_index() common: use get_nand_dev_by_index() fs: use get_nand_dev_by_index() cmd: nand: remove direct access to struct mtd_info->priv net: phy: cortina: use get_nand_dev_by_index() net: fm: use get_nand_dev_by_index() mtd: nand: drv: use get_nand_dev_by_index() cmd: mvebu: bubt: use get_nand_dev_by_index() board: atmel: use get_nand_dev_by_index() board: ronetix: use get_nand_dev_by_index() board: BuR: use get_nand_dev_by_index() board: toradex: use get_nand_dev_by_index() mtd: nand: make nand_info array static
Mugunthan V N (1): cmd: nand: abstract global variable usage for dm conversion
board/BuR/common/common.c | 3 +- board/atmel/at91sam9261ek/at91sam9261ek.c | 2 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 2 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- board/ronetix/pm9261/pm9261.c | 2 +- board/ronetix/pm9263/pm9263.c | 2 +- board/toradex/colibri_t20/colibri_t20.c | 2 +- board/toradex/common/tdx-cfg-block.c | 12 +++-- cmd/bootm.c | 2 +- cmd/jffs2.c | 7 +-- cmd/mvebu/bubt.c | 14 +++-- cmd/nand.c | 69 ++++++++++++++----------- common/env_nand.c | 33 +++++++----- common/fb_nand.c | 2 +- common/splash_source.c | 5 +- drivers/dfu/dfu_nand.c | 12 ++--- drivers/mtd/nand/fsmc_nand.c | 2 +- drivers/mtd/nand/nand.c | 23 ++++++--- drivers/mtd/nand/omap_gpmc.c | 7 +-- drivers/mtd/nand/zynq_nand.c | 2 +- drivers/net/fm/fm.c | 3 +- drivers/net/phy/cortina.c | 3 +- fs/jffs2/jffs2_1pass.c | 9 +++- fs/jffs2/jffs2_nand_1pass.c | 6 ++- fs/yaffs2/yaffs_uboot_glue.c | 8 ++- include/nand.h | 10 +++- 32 files changed, 153 insertions(+), 103 deletions(-)
nand_info is used all over the file so abstract it with get_nand_dev_by_index() which will help for DM conversion.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- cmd/nand.c | 69 +++++++++++++++++++++++++------------------- drivers/mtd/nand/nand.c | 21 ++++++++++---- drivers/mtd/nand/omap_gpmc.c | 7 ++--- include/nand.h | 9 ++++++ 4 files changed, 65 insertions(+), 41 deletions(-)
diff --git a/cmd/nand.c b/cmd/nand.c index c16ec77..f2b440e 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -115,20 +115,20 @@ free_dat:
static int set_dev(int dev) { - if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[dev]) { - puts("No such device\n"); - return -1; - } + struct mtd_info *mtd = get_nand_dev_by_index(dev); + + if (!mtd) + return -ENODEV;
if (nand_curr_device == dev) return 0;
- printf("Device %d: %s", dev, nand_info[dev]->name); + printf("Device %d: %s", dev, mtd->name); puts("... is now current device\n"); nand_curr_device = dev;
#ifdef CONFIG_SYS_NAND_SELECT_DEVICE - board_nand_select_device(nand_info[dev]->priv, dev); + board_nand_select_device(mtd->priv, dev); #endif
return 0; @@ -188,7 +188,7 @@ int do_nand_env_oob(cmd_tbl_t *cmdtp, int argc, char *const argv[]) { int ret; uint32_t oob_buf[ENV_OFFSET_SIZE/sizeof(uint32_t)]; - struct mtd_info *mtd = nand_info[0]; + struct mtd_info *mtd = get_nand_dev_by_index(0); char *cmd = argv[1];
if (CONFIG_SYS_MAX_NAND_DEVICE == 0 || !mtd) { @@ -213,9 +213,10 @@ int do_nand_env_oob(cmd_tbl_t *cmdtp, int argc, char *const argv[]) if (argc < 3) goto usage;
+ mtd = get_nand_dev_by_index(idx); /* We don't care about size, or maxsize. */ if (mtd_arg_off(argv[2], &idx, &addr, &maxsize, &maxsize, - MTD_DEV_TYPE_NAND, nand_info[idx]->size)) { + MTD_DEV_TYPE_NAND, mtd->size)) { puts("Offset or partition name expected\n"); return 1; } @@ -283,9 +284,14 @@ usage:
static void nand_print_and_set_info(int idx) { - struct mtd_info *mtd = nand_info[idx]; - struct nand_chip *chip = mtd_to_nand(mtd); + struct mtd_info *mtd; + struct nand_chip *chip; + + mtd = get_nand_dev_by_index(idx); + if (!mtd) + return;
+ chip = mtd_to_nand(mtd); printf("Device %d: ", idx); if (chip->numchips > 1) printf("%dx ", chip->numchips); @@ -348,7 +354,7 @@ static void adjust_size_for_badblocks(loff_t *size, loff_t offset, int dev) /* We grab the nand info object here fresh because this is usually * called after arg_off_size() which can change the value of dev. */ - struct mtd_info *mtd = nand_info[dev]; + struct mtd_info *mtd = get_nand_dev_by_index(dev); loff_t maxoffset = offset + *size; int badblocks = 0;
@@ -397,10 +403,8 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (strcmp(cmd, "info") == 0) {
putc('\n'); - for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { - if (nand_info[i]) - nand_print_and_set_info(i); - } + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_print_and_set_info(i); return 0; }
@@ -432,12 +436,11 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * one before these commands can run, even if a partition specifier * for another device is to be used. */ - if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE || - !nand_info[dev]) { + mtd = get_nand_dev_by_index(dev); + if (!mtd) { puts("\nno devices available\n"); return 1; } - mtd = nand_info[dev];
if (strcmp(cmd, "bad") == 0) { printf("\nDevice %d bad blocks:\n", dev); @@ -496,13 +499,13 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* skip first two or three arguments, look for offset and size */ if (mtd_arg_off_size(argc - o, argv + o, &dev, &off, &size, &maxsize, MTD_DEV_TYPE_NAND, - nand_info[dev]->size) != 0) + mtd->size) != 0) return 1;
if (set_dev(dev)) return 1;
- mtd = nand_info[dev]; + mtd = get_nand_dev_by_index(dev);
memset(&opts, 0, sizeof(opts)); opts.offset = off; @@ -565,13 +568,13 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
if (mtd_arg_off(argv[3], &dev, &off, &size, &maxsize, MTD_DEV_TYPE_NAND, - nand_info[dev]->size)) + mtd->size)) return 1;
if (argc > 4 && !str2long(argv[4], &pagecount)) { printf("'%s' is not a number\n", argv[4]); @@ -588,7 +591,7 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (mtd_arg_off_size(argc - 3, argv + 3, &dev, &off, &size, &maxsize, MTD_DEV_TYPE_NAND, - nand_info[dev]->size) != 0) + mtd->size) != 0) return 1;
if (set_dev(dev)) @@ -600,7 +603,7 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) rwsize = size; }
if (!s || !strcmp(s, ".jffs2") || !strcmp(s, ".e") || !strcmp(s, ".i")) { @@ -760,13 +763,15 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
if (mtd_arg_off_size(argc - 2, argv + 2, &dev, &off, &size, &maxsize, MTD_DEV_TYPE_NAND, - nand_info[dev]->size) < 0) + mtd->size) < 0) return 1;
- if (!nand_unlock(nand_info[dev], off, size, allexcept)) { + mtd = get_nand_dev_by_index(dev); + + if (!nand_unlock(mtd, off, size, allexcept)) { puts("NAND flash successfully unlocked\n"); } else { puts("Error unlocking NAND flash, " @@ -929,6 +934,7 @@ static int do_nandboot(cmd_tbl_t *cmdtp, int flag, int argc, char *boot_device = NULL; int idx; ulong addr, offset = 0; + struct mtd_info *mtd; #if defined(CONFIG_CMD_MTDPARTS) struct mtd_device *dev; struct part_info *part; @@ -948,8 +954,10 @@ static int do_nandboot(cmd_tbl_t *cmdtp, int flag, int argc, addr = simple_strtoul(argv[1], NULL, 16); else addr = CONFIG_SYS_LOAD_ADDR; - return nand_load_image(cmdtp, nand_info[dev->id->num], - part->offset, addr, argv[0]); + + mtd = get_nand_dev_by_index(dev->id->num); + return nand_load_image(cmdtp, mtd, part->offset, + addr, argv[0]); } } #endif @@ -991,14 +999,15 @@ usage:
idx = simple_strtoul(boot_device, NULL, 16);
- if (idx < 0 || idx >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[idx]) { + mtd = get_nand_dev_by_index(idx); + if (!mtd) { printf("\n** Device %d not available\n", idx); bootstage_error(BOOTSTAGE_ID_NAND_AVAILABLE); return 1; } bootstage_mark(BOOTSTAGE_ID_NAND_AVAILABLE);
- return nand_load_image(cmdtp, nand_info[idx], offset, addr, argv[0]); + return nand_load_image(cmdtp, mtd, offset, addr, argv[0]); }
U_BOOT_CMD(nboot, 4, 1, do_nandboot, diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c index 0551241..9d14fda 100644 --- a/drivers/mtd/nand/nand.c +++ b/drivers/mtd/nand/nand.c @@ -19,7 +19,6 @@ DECLARE_GLOBAL_DATA_PTR;
int nand_curr_device = -1;
- struct mtd_info *nand_info[CONFIG_SYS_MAX_NAND_DEVICE];
#ifndef CONFIG_SYS_NAND_SELF_INIT @@ -31,12 +30,21 @@ static char dev_name[CONFIG_SYS_MAX_NAND_DEVICE][8];
static unsigned long total_nand_size; /* in kiB */
+struct mtd_info *get_nand_dev_by_index(int dev) +{ + if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[dev] || + !nand_info[dev]->name) + return NULL; + + return nand_info[dev]; +} + int nand_mtd_to_devnum(struct mtd_info *mtd) { int i;
- for (i = 0; i < ARRAY_SIZE(nand_info); i++) { - if (mtd && nand_info[i] == mtd) + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { + if (mtd && get_nand_dev_by_index(i) == mtd) return i; }
@@ -101,8 +109,9 @@ static void create_mtd_concat(void) int i;
for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { - if (nand_info[i] != NULL) { - nand_info_list[nand_devices_found] = nand_info[i]; + struct mtd_info *mtd = get_nand_dev_by_index(i); + if (mtd != NULL) { + nand_info_list[nand_devices_found] = mtd; nand_devices_found++; } } @@ -148,7 +157,7 @@ void nand_init(void) /* * Select the chip in the board/cpu specific driver */ - board_nand_select_device(mtd_to_nand(nand_info[nand_curr_device]), + board_nand_select_device(mtd_to_nand(get_nand_dev_by_index(nand_curr_device)), nand_curr_device); #endif
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index f4f0de3..b540bc3 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -894,17 +894,14 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, int __maybe_unused omap_nand_switch_ecc(uint32_t hardware, uint32_t eccstrength) { struct nand_chip *nand; - struct mtd_info *mtd; + struct mtd_info *mtd = get_nand_dev_by_index(nand_curr_device); int err = 0;
- if (nand_curr_device < 0 || - nand_curr_device >= CONFIG_SYS_MAX_NAND_DEVICE || - !nand_info[nand_curr_device]) { + if (!mtd) { printf("nand: error: no NAND devices found\n"); return -ENODEV; }
- mtd = nand_info[nand_curr_device]; nand = mtd_to_nand(mtd); nand->options |= NAND_OWN_BUFFERS; nand->options &= ~NAND_SUBPAGE_READ; diff --git a/include/nand.h b/include/nand.h index b6eb223..6c785a0 100644 --- a/include/nand.h +++ b/include/nand.h @@ -145,3 +145,12 @@ int spl_nand_erase_one(int block, int page);
/* platform specific init functions */ void sunxi_nand_init(void); + +/* + * get_nand_dev_by_index - Get the nand info based in index. + * + * @dev - index to the nand device. + * + * returns pointer to the nand device info structure or NULL on failure. + */ +struct mtd_info *get_nand_dev_by_index(int dev);
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- common/env_nand.c | 33 +++++++++++++++++++++------------ 1 file changed, 21 insertions(+), 12 deletions(-)
diff --git a/common/env_nand.c b/common/env_nand.c index 2e28171..133ecfb 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -130,17 +130,22 @@ static int writeenv(size_t offset, u_char *buf) size_t end = offset + CONFIG_ENV_RANGE; size_t amount_saved = 0; size_t blocksize, len; + struct mtd_info *mtd; u_char *char_ptr;
- blocksize = nand_info[0]->erasesize; + mtd = get_nand_dev_by_index(0); + if (!mtd) + return 1; + + blocksize = mtd->erasesize; len = min(blocksize, (size_t)CONFIG_ENV_SIZE);
while (amount_saved < CONFIG_ENV_SIZE && offset < end) { - if (nand_block_isbad(nand_info[0], offset)) { + if (nand_block_isbad(mtd, offset)) { offset += blocksize; } else { char_ptr = &buf[amount_saved]; - if (nand_write(nand_info[0], offset, &len, char_ptr)) + if (nand_write(mtd, offset, &len, char_ptr)) return 1;
offset += blocksize; @@ -161,13 +166,15 @@ struct env_location { static int erase_and_write_env(const struct env_location *location, u_char *env_new) { + struct mtd_info *mtd; int ret = 0;
- if (!nand_info[0]) + mtd = get_nand_dev_by_index(0); + if (!mtd) return 1;
printf("Erasing %s...\n", location->name); - if (nand_erase_opts(nand_info[0], &location->erase_opts)) + if (nand_erase_opts(mtd, &location->erase_opts)) return 1;
printf("Writing to %s... ", location->name); @@ -248,22 +255,24 @@ static int readenv(size_t offset, u_char *buf) size_t end = offset + CONFIG_ENV_RANGE; size_t amount_loaded = 0; size_t blocksize, len; + struct mtd_info *mtd; u_char *char_ptr;
- blocksize = nand_info[0]->erasesize; + blocksize = mtd->erasesize; len = min(blocksize, (size_t)CONFIG_ENV_SIZE);
while (amount_loaded < CONFIG_ENV_SIZE && offset < end) { - if (nand_block_isbad(nand_info[0], offset)) { + if (nand_block_isbad(mtd, offset)) { offset += blocksize; } else { char_ptr = &buf[amount_loaded]; - if (nand_read_skip_bad(nand_info[0], offset, + if (nand_read_skip_bad(mtd, offset, &len, NULL, - nand_info[0]->size, char_ptr)) + mtd->size, char_ptr)) return 1;
offset += blocksize; @@ -390,12 +399,12 @@ void env_relocate_spec(void) ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE);
#if defined(CONFIG_ENV_OFFSET_OOB) + struct mtd_info *mtd = get_nand_dev_by_index(0); /* * If unable to read environment offset from NAND OOB then fall through * to the normal environment reading code below */ - if (nand_info[0] && !get_nand_env_oob(nand_info[0], - &nand_env_oob_offset)) { + if (mtd && !get_nand_env_oob(mtd, &nand_env_oob_offset)) { printf("Found Environment offset in OOB..\n"); } else { set_default_env("!no env offset in OOB");
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/dfu/dfu_nand.c | 12 +++++------- 1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/dfu/dfu_nand.c b/drivers/dfu/dfu_nand.c index 23f1571..97cd608 100644 --- a/drivers/dfu/dfu_nand.c +++ b/drivers/dfu/dfu_nand.c @@ -37,15 +37,15 @@ static int nand_block_op(enum dfu_op op, struct dfu_entity *dfu, lim = dfu->data.nand.start + dfu->data.nand.size - start; count = *len;
+ mtd = get_nand_dev_by_index(nand_curr_device); + if (nand_curr_device < 0 || nand_curr_device >= CONFIG_SYS_MAX_NAND_DEVICE || - !nand_info[nand_curr_device]) { + !mtd) { printf("%s: invalid nand device\n", __func__); return -1; }
- mtd = nand_info[nand_curr_device]; - if (op == DFU_OP_READ) { ret = nand_read_skip_bad(mtd, start, &count, &actual, lim, buf); @@ -143,18 +143,16 @@ static int dfu_flush_medium_nand(struct dfu_entity *dfu)
/* in case of ubi partition, erase rest of the partition */ if (dfu->data.nand.ubi) { - struct mtd_info *mtd; + struct mtd_info *mtd = get_nand_dev_by_index(nand_curr_device); nand_erase_options_t opts;
- mtd = nand_info[nand_curr_device]; - memset(&opts, 0, sizeof(opts)); off = dfu->offset; if ((off & (mtd->erasesize - 1)) != 0) {
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- cmd/bootm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/bootm.c b/cmd/bootm.c index 953a57d..daf15d9 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -465,7 +465,7 @@ static int do_imls_nand(void) printf("\n");
for (nand_dev = 0; nand_dev < CONFIG_SYS_MAX_NAND_DEVICE; nand_dev++) { - mtd = nand_info[nand_dev]; + mtd = get_nand_dev_by_index(nand_dev); if (!mtd->name || !mtd->size) continue;
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- cmd/jffs2.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/cmd/jffs2.c b/cmd/jffs2.c index f00d53a..162c8fe 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -166,8 +166,9 @@ static int mtd_device_validate(u8 type, u8 num, u32 *size) #endif } else if (type == MTD_DEV_TYPE_NAND) { #if defined(CONFIG_JFFS2_NAND) && defined(CONFIG_CMD_NAND) - if (num < CONFIG_SYS_MAX_NAND_DEVICE) { - *size = nand_info[num]->size; + struct mtd_info *mtd = get_nand_dev_by_index(num); + if (mtd) { + *size = mtd->size; return 0; }
@@ -244,7 +245,7 @@ static inline u32 get_part_sector_size_nand(struct mtdids *id) #if defined(CONFIG_JFFS2_NAND) && defined(CONFIG_CMD_NAND) struct mtd_info *mtd;
- mtd = nand_info[id->num]; + mtd = get_nand_dev_by_index(id->num);
return mtd->erasesize; #else
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- common/fb_nand.c | 2 +- common/splash_source.c | 5 +++-- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/common/fb_nand.c b/common/fb_nand.c index c8c79e9..3d027d4 100644 --- a/common/fb_nand.c +++ b/common/fb_nand.c @@ -59,7 +59,7 @@ static int fb_nand_lookup(const char *partname, return -EINVAL; }
- *mtd = nand_info[dev->id->num]; + *mtd = get_nand_dev_by_index(dev->id->num);
return 0; } diff --git a/common/splash_source.c b/common/splash_source.c index a5eeb3f..7c9b7b5 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -47,9 +47,10 @@ static int splash_sf_read_raw(u32 bmp_load_addr, int offset, size_t read_size) #ifdef CONFIG_CMD_NAND static int splash_nand_read_raw(u32 bmp_load_addr, int offset, size_t read_size) { - return nand_read_skip_bad(nand_info[nand_curr_device], offset, + struct mtd_info *mtd = get_nand_dev_by_index(nand_curr_device); + return nand_read_skip_bad(mtd, offset, &read_size, NULL, - nand_info[nand_curr_device]->size, + mtd->size, (u_char *)bmp_load_addr); } #else
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- fs/jffs2/jffs2_1pass.c | 9 +++++++-- fs/jffs2/jffs2_nand_1pass.c | 6 +++++- fs/yaffs2/yaffs_uboot_glue.c | 8 ++++++-- 3 files changed, 18 insertions(+), 5 deletions(-)
diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index ed60c5b..4c6dfbf 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -175,10 +175,15 @@ static u32 nand_cache_off = (u32)-1; static int read_nand_cached(u32 off, u32 size, u_char *buf) { struct mtdids *id = current_part->dev->id; + struct mtd_info *mtd; u32 bytes_read = 0; size_t retlen; int cpy_bytes;
+ mtd = get_nand_dev_by_index(id->num); + if (!mtd) + return -1; + while (bytes_read < size) { if ((off + bytes_read < nand_cache_off) || (off + bytes_read >= nand_cache_off+NAND_CACHE_SIZE)) { @@ -195,8 +200,8 @@ static int read_nand_cached(u32 off, u32 size, u_char *buf) }
retlen = NAND_CACHE_SIZE; - if (nand_read(nand_info[id->num], nand_cache_off, - &retlen, nand_cache) != 0 || + if (nand_read(mtd, nand_cache_off, + &retlen, nand_cache) != 0 || retlen != NAND_CACHE_SIZE) { printf("read_nand_cached: error reading nand off %#x size %d bytes\n", nand_cache_off, NAND_CACHE_SIZE); diff --git a/fs/jffs2/jffs2_nand_1pass.c b/fs/jffs2/jffs2_nand_1pass.c index d94c48f..1d63fc9 100644 --- a/fs/jffs2/jffs2_nand_1pass.c +++ b/fs/jffs2/jffs2_nand_1pass.c @@ -796,7 +796,11 @@ jffs2_1pass_build_lists(struct part_info * part) u32 counterN = 0;
struct mtdids *id = part->dev->id; - mtd = nand_info[id->num]; + mtd = get_nand_dev_by_index(id->num); + if (!mtd) { + error("\nno NAND devices available\n"); + return 0; + }
/* if we are building a list we need to refresh the cache. */ jffs_init_1pass_list(part); diff --git a/fs/yaffs2/yaffs_uboot_glue.c b/fs/yaffs2/yaffs_uboot_glue.c index 25aa6d1..347424e 100644 --- a/fs/yaffs2/yaffs_uboot_glue.c +++ b/fs/yaffs2/yaffs_uboot_glue.c @@ -166,11 +166,15 @@ void cmd_yaffs_devconfig(char *_mp, int flash_dev, char *mp = NULL; struct nand_chip *chip;
+ mtd = get_nand_dev_by_index(flash_dev); + if (!mtd) { + error("\nno NAND devices available\n"); + return; + } + dev = calloc(1, sizeof(*dev)); mp = strdup(_mp);
- mtd = nand_info[flash_dev]; - if (!dev || !mp) { /* Alloc error */ printf("Failed to allocate memory\n");
Replace direct access to struct mtd_info->priv with proper accessor mtd_to_nand().
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- cmd/nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/nand.c b/cmd/nand.c index f2b440e..d9de978 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -128,7 +128,7 @@ static int set_dev(int dev) nand_curr_device = dev;
#ifdef CONFIG_SYS_NAND_SELECT_DEVICE - board_nand_select_device(mtd->priv, dev); + board_nand_select_device(mtd_to_nand(mtd), dev); #endif
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/net/phy/cortina.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index fd130d5..e0e9ed9 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -139,7 +139,8 @@ void cs4340_upload_firmware(struct phy_device *phydev) size_t fw_length = CONFIG_CORTINA_FW_LENGTH;
addr = malloc(CONFIG_CORTINA_FW_LENGTH); - ret = nand_read(nand_info[0], (loff_t)CONFIG_CORTINA_FW_ADDR, + ret = nand_read(get_nand_dev_by_index(0), + (loff_t)CONFIG_CORTINA_FW_ADDR, &fw_length, (u_char *)addr); if (ret == -EUCLEAN) { printf("NAND read of Cortina firmware at 0x%x failed %d\n",
On Fri, Feb 10, 2017 at 2:22 PM, Grygorii Strashko grygorii.strashko@ti.com wrote:
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/net/fm/fm.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 89f0d6a..9fe34ad 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -357,7 +357,8 @@ int fm_init_common(int index, struct ccsr_fman *reg) size_t fw_length = CONFIG_SYS_QE_FMAN_FW_LENGTH; void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH);
- rc = nand_read(nand_info[0], (loff_t)CONFIG_SYS_FMAN_FW_ADDR, + rc = nand_read(get_nand_dev_by_index(0), + (loff_t)CONFIG_SYS_FMAN_FW_ADDR, &fw_length, (u_char *)addr); if (rc == -EUCLEAN) { printf("NAND read of FMAN firmware at offset 0x%x failed %d\n",
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/mtd/nand/fsmc_nand.c | 2 +- drivers/mtd/nand/zynq_nand.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/fsmc_nand.c b/drivers/mtd/nand/fsmc_nand.c index a1f2cba..d5d1056 100644 --- a/drivers/mtd/nand/fsmc_nand.c +++ b/drivers/mtd/nand/fsmc_nand.c @@ -409,7 +409,7 @@ int fsmc_nand_switch_ecc(uint32_t eccstrength) * Nomadik SoC is currently supporting this fsmc_nand_switch_ecc() * function, as it doesn't need to switch to a different ECC layout. */ - mtd = nand_info[nand_curr_device]; + mtd = get_nand_dev_by_index(nand_curr_device); nand = mtd_to_nand(mtd);
/* Setup the ecc configurations again */ diff --git a/drivers/mtd/nand/zynq_nand.c b/drivers/mtd/nand/zynq_nand.c index cb3340d..948f059 100644 --- a/drivers/mtd/nand/zynq_nand.c +++ b/drivers/mtd/nand/zynq_nand.c @@ -1008,7 +1008,7 @@ static int zynq_nand_init(struct nand_chip *nand_chip, int devnum) }
xnand->nand_base = (void __iomem *)ZYNQ_NAND_BASEADDR; - mtd = (struct mtd_info *)&nand_info[0]; + mtd = get_nand_dev_by_index(0);
nand_chip->priv = xnand; mtd->priv = nand_chip;
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- cmd/mvebu/bubt.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index b752927..bb9b7ed 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -309,24 +309,22 @@ static int is_spi_active(void) #ifdef CONFIG_CMD_NAND static int nand_burn_image(size_t image_size) { + struct mtd_info *mtd; int ret, block_size; - nand_info_t *nand; - int dev = nand_curr_device;
- if ((dev < 0) || (dev >= CONFIG_SYS_MAX_NAND_DEVICE) || - (!nand_info[dev].name)) { + mtd = get_nand_dev_by_index(nand_curr_device); + if (!mtd) { puts("\nno devices available\n"); return -ENOMEDIUM; } - nand = &nand_info[dev]; - block_size = nand->erasesize; + block_size = mtd->erasesize;
/* Align U-Boot size to currently used blocksize */ image_size = ((image_size + (block_size - 1)) & (~(block_size - 1)));
/* Erase the U-BOOT image space */ printf("Erasing 0x%x - 0x%x:...", 0, (int)image_size); - ret = nand_erase(nand, 0, image_size); + ret = nand_erase(mtd, 0, image_size); if (ret) { printf("Error!\n"); goto error; @@ -336,7 +334,7 @@ static int nand_burn_image(size_t image_size) /* Write the image to flash */ printf("Writing image:..."); printf("&image_size = 0x%p\n", (void *)&image_size); - ret = nand_write(nand, 0, &image_size, (void *)get_load_addr()); + ret = nand_write(mtd, 0, &image_size, (void *)get_load_addr()); if (ret) printf("Error!\n"); else
Cc: Stelian Pop stelian@popies.net Cc: Bo Shen voice.shen@atmel.com Cc: Josh Wu josh.wu@atmel.com Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/atmel/at91sam9261ek/at91sam9261ek.c | 2 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 2 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- 9 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 6398bcb..4e443d9 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -212,7 +212,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20 ); diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 04e5812..b0e075a 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -191,7 +191,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; #ifndef CONFIG_SYS_NO_FLASH flash_size = 0; for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 6871916..0f1484b 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -272,7 +272,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20 ); diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index fc4f50d..682a983 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -124,7 +124,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20); diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 994f246..334e5e3 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -151,7 +151,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20 ); diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index b0d440d..c697bc9 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -196,7 +196,7 @@ void lcd_show_board_info(void) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20); diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index fa90270..9dd5241 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -207,7 +207,7 @@ void lcd_show_board_info(void) nand_size = 0; #ifdef CONFIG_NAND_ATMEL for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; #endif lcd_printf("%ld MB SDRAM, %lld MB NAND\n", dram_size >> 20, nand_size >> 20); diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index 23ec274..afbe374 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -191,7 +191,7 @@ void lcd_show_board_info(void) nand_size = 0; #ifdef CONFIG_NAND_ATMEL for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; #endif lcd_printf("%ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20); diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 72bad23..a0902fb 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -187,7 +187,7 @@ void lcd_show_board_info(void) nand_size = 0; #ifdef CONFIG_NAND_ATMEL for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i]->size; + nand_size += get_nand_dev_by_index(i)->size; #endif lcd_printf("%ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20);
Cc: Ilko Iliev iliev@ronetix.at Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/ronetix/pm9261/pm9261.c | 2 +- board/ronetix/pm9263/pm9263.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index e2cb94e..2d3c0a8 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -194,7 +194,7 @@ void lcd_show_board_info(void)
flash_size = 0; for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index e9f9b67..49c74ad 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -293,7 +293,7 @@ void lcd_show_board_info(void)
Cc: Hannes Schmelzer oe5hpm@oevsv.at Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/BuR/common/common.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index e947e54..cd084d9 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -259,7 +259,8 @@ static int load_devicetree(void) } #ifdef CONFIG_NAND dtbsize = 0x20000; - rc = nand_read_skip_bad(nand_info[0], 0x40000, (size_t *)&dtbsize, + rc = nand_read_skip_bad(get_nand_dev_by_index(0), 0x40000, + (size_t *)&dtbsize, NULL, 0x20000, (u_char *)dtbaddr); #else char *dtbname = getenv("dtb");
- rc = nand_read_skip_bad(get_nand_dev_by_index(0), 0x40000,
#else char *dtbname = getenv("dtb"); -- 2.10.1.dirty
Reviewed-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
On 21 February 2017 at 04:53, Hannes Schmelzer Hannes.Schmelzer@br-automation.com wrote:
Cc: Lucas Stach dev@lynxeye.de Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/toradex/colibri_t20/colibri_t20.c | 2 +- board/toradex/common/tdx-cfg-block.c | 12 ++++++++---- 2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/board/toradex/colibri_t20/colibri_t20.c b/board/toradex/colibri_t20/colibri_t20.c index 7d574fb..71b8fd3 100644 --- a/board/toradex/colibri_t20/colibri_t20.c +++ b/board/toradex/colibri_t20/colibri_t20.c @@ -69,7 +69,7 @@ int checkboard(void) { printf("Model: Toradex Colibri T20 %dMB V%s\n", (gd->ram_size == 0x10000000) ? 256 : 512, - (nand_info[0]->erasesize >> 10 == 512) ? + (get_nand_dev_by_index(0)->erasesize >> 10 == 512) ? ((gd->ram_size == 0x10000000) ? "1.1B" : "1.1C") : "1.2A");
return 0; diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 0014ce8..7722b92 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -153,8 +153,10 @@ static int read_tdx_cfg_block_from_nand(unsigned char *config_block) size_t size = TDX_CFG_BLOCK_MAX_SIZE;
/* Read production parameter config block from NAND page */ - return nand_read_skip_bad(nand_info[0], CONFIG_TDX_CFG_BLOCK_OFFSET, - &size, NULL, TDX_CFG_BLOCK_MAX_SIZE, config_block); + return nand_read_skip_bad(get_nand_dev_by_index(0), + CONFIG_TDX_CFG_BLOCK_OFFSET, + &size, NULL, TDX_CFG_BLOCK_MAX_SIZE, + config_block); }
static int write_tdx_cfg_block_to_nand(unsigned char *config_block) @@ -162,7 +164,8 @@ static int write_tdx_cfg_block_to_nand(unsigned char *config_block) size_t size = TDX_CFG_BLOCK_MAX_SIZE;
/* Write production parameter config block to NAND page */ - return nand_write_skip_bad(nand_info[0], CONFIG_TDX_CFG_BLOCK_OFFSET, + return nand_write_skip_bad(get_nand_dev_by_index(0), + CONFIG_TDX_CFG_BLOCK_OFFSET, &size, NULL, TDX_CFG_BLOCK_MAX_SIZE, config_block, WITH_WR_VERIFY); } @@ -425,7 +428,8 @@ static int do_cfgblock_create(cmd_tbl_t *cmdtp, int flag, int argc, * empty (config block invalid...) */ printf("NAND erase block %d need to be erased before creating a Toradex config block\n", - CONFIG_TDX_CFG_BLOCK_OFFSET / nand_info[0]->erasesize); + CONFIG_TDX_CFG_BLOCK_OFFSET / + get_nand_dev_by_index(0)->erasesize); goto out; #elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) /*
Looks reasonable to me.
Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- (get_nand_dev_by_index(0)->erasesize >> 10 == 512) ?
((gd->ram_size == 0x10000000) ? "1.1B" : "1.1C") : "1.2A"); return 0; diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 0014ce8..7722b92 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -153,8 +153,10 @@ static int read_tdx_cfg_block_from_nand(unsigned char *config_block) size_t size = TDX_CFG_BLOCK_MAX_SIZE; /* Read production parameter config block from NAND page */
config_block);
- return nand_read_skip_bad(get_nand_dev_by_index(0),
&size, NULL,
config_block);
} static int write_tdx_cfg_block_to_nand(unsigned char *config_block) @@ -162,7 +164,8 @@ static int write_tdx_cfg_block_to_nand(unsigned char *config_block) size_t size = TDX_CFG_BLOCK_MAX_SIZE; /* Write production parameter config block to NAND page */
- return nand_write_skip_bad(get_nand_dev_by_index(0),
erasesize);
Make make nand_info array static, since all direct users of nand_info array have been converted to use get_nand_dev_by_index() API.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/mtd/nand/nand.c | 2 +- include/nand.h | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c index 9d14fda..e567d61 100644 --- a/drivers/mtd/nand/nand.c +++ b/drivers/mtd/nand/nand.c @@ -19,7 +19,7 @@ DECLARE_GLOBAL_DATA_PTR;
-struct mtd_info *nand_info[CONFIG_SYS_MAX_NAND_DEVICE]; +static struct mtd_info *nand_info[CONFIG_SYS_MAX_NAND_DEVICE];
#ifndef CONFIG_SYS_NAND_SELF_INIT static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; diff --git a/include/nand.h b/include/nand.h index 6c785a0..3b9d3c6 100644 --- a/include/nand.h +++ b/include/nand.h @@ -43,7 +43,6 @@ extern int board_nand_init(struct nand_chip *nand); #endif
extern int nand_curr_device; -extern struct mtd_info *nand_info[];
static inline int nand_read(struct mtd_info *info, loff_t ofs, size_t *len, u_char *buf)
participants (5)
Grygorii Strashko
Hannes Schmelzer
Joe Hershberger
Marcel Ziswiler
