[PATCH v1 0/5] Tegra panel improvements
The current patch set improves the logic of existing panels and bridge used by Tegra 3 devices and brings support for additional DSI panels used by Tegra 4 devices.
New and existing drivers are fully reusable, contain no device specific parts, and are written according to existing datasheets.
Anton Bambura (1): video: panel: add Samsung LTL106HL02 MIPI DSI panel driver
Svyatoslav Ryhel (4): video: panel: add LG LG070WX3 MIPI DSI panel driver video: endeavoru-panel: shift the init sequence by one step earlier video: bridge: ssd2825: shift the init sequence by one step earlier video: renesas: shift the init sequence by one step earlier
drivers/video/Kconfig | 17 +++ drivers/video/Makefile | 2 + drivers/video/bridge/ssd2825.c | 82 +++++++------ drivers/video/endeavoru-panel.c | 128 ++++++++++---------- drivers/video/lg-ld070wx3.c | 186 +++++++++++++++++++++++++++++ drivers/video/renesas-r61307.c | 93 ++++++++------- drivers/video/renesas-r69328.c | 81 +++++++------ drivers/video/samsung-ltl106hl02.c | 157 ++++++++++++++++++++++++ 8 files changed, 571 insertions(+), 175 deletions(-) create mode 100644 drivers/video/lg-ld070wx3.c create mode 100644 drivers/video/samsung-ltl106hl02.c
The LD070WX3 is a Color Active Matrix Liquid Crystal Display with an integral Light Emitting Diode (LED) backlight system. The matrix employs a-Si Thin Film Transistor as the active element. It is a transmissive type display operating in the normally Black mode. This TFT-LCD has 7.0 inches diagonally measured active display area with WXGA resolution (800 by 1280 pixel array).
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/Kconfig | 8 ++ drivers/video/Makefile | 1 + drivers/video/lg-ld070wx3.c | 186 ++++++++++++++++++++++++++++++++++++ 3 files changed, 195 insertions(+) create mode 100644 drivers/video/lg-ld070wx3.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index e2016d73d1..05567a0095 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -522,6 +522,14 @@ config VIDEO_LCD_ORISETECH_OTM8009A Say Y here if you want to enable support for Orise Technology otm8009a 480x800 dsi 2dl panel.
+config VIDEO_LCD_LG_LD070WX3 + bool "LD070WX3 DSI LCD panel support" + depends on PANEL && BACKLIGHT + select VIDEO_MIPI_DSI + help + Say Y here if you want to enable support for LG LD070WX3 + 800x1280 DSI video mode panel. + config VIDEO_LCD_RAYDIUM_RM68200 bool "RM68200 DSI LCD panel support" select VIDEO_MIPI_DSI diff --git a/drivers/video/Makefile b/drivers/video/Makefile index fdc2937632..bb6d9b74b9 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -58,6 +58,7 @@ obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_ENDEAVORU) += endeavoru-panel.o obj-$(CONFIG_VIDEO_LCD_HIMAX_HX8394) += himax-hx8394.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o +obj-$(CONFIG_VIDEO_LCD_LG_LD070WX3) += lg-ld070wx3.o obj-$(CONFIG_VIDEO_LCD_ORISETECH_OTM8009A) += orisetech_otm8009a.o obj-$(CONFIG_VIDEO_LCD_RAYDIUM_RM68200) += raydium-rm68200.o obj-$(CONFIG_VIDEO_LCD_RENESAS_R61307) += renesas-r61307.o diff --git a/drivers/video/lg-ld070wx3.c b/drivers/video/lg-ld070wx3.c new file mode 100644 index 0000000000..610a06ffe7 --- /dev/null +++ b/drivers/video/lg-ld070wx3.c @@ -0,0 +1,186 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * LG LD070WX3-SL01 DSI panel driver + * + * Copyright (c) 2023 Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <backlight.h> +#include <dm.h> +#include <panel.h> +#include <log.h> +#include <mipi_dsi.h> +#include <linux/delay.h> +#include <power/regulator.h> + +struct lg_ld070wx3_priv { + struct udevice *vdd; + struct udevice *vcc; + + struct udevice *backlight; +}; + +static struct display_timing default_timing = { + .pixelclock.typ = 70000000, + .hactive.typ = 800, + .hfront_porch.typ = 32, + .hback_porch.typ = 48, + .hsync_len.typ = 8, + .vactive.typ = 1280, + .vfront_porch.typ = 5, + .vback_porch.typ = 3, + .vsync_len.typ = 1, +}; + +static void dcs_write_one(struct mipi_dsi_device *dsi, u8 cmd, u8 data) +{ + mipi_dsi_dcs_write(dsi, cmd, &data, 1); +} + +static int lg_ld070wx3_enable_backlight(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + struct mipi_dsi_device *dsi = plat->device; + int ret; + + ret = mipi_dsi_dcs_soft_reset(dsi); + if (ret < 0) { + log_debug("%s: failed to soft reset panel: %d\n", + __func__, ret); + return ret; + } + + /* Delay before sending new command after soft reset */ + mdelay(20); + + /* Differential input impedance selection */ + dcs_write_one(dsi, 0xAE, 0x0B); + + /* Enter test mode 1 and 2*/ + dcs_write_one(dsi, 0xEE, 0xEA); + dcs_write_one(dsi, 0xEF, 0x5F); + + /* Increased MIPI CLK driving ability */ + dcs_write_one(dsi, 0xF2, 0x68); + + /* Exit test mode 1 and 2 */ + dcs_write_one(dsi, 0xEE, 0x00); + dcs_write_one(dsi, 0xEF, 0x00); + + return 0; +} + +static int lg_ld070wx3_set_backlight(struct udevice *dev, int percent) +{ + struct lg_ld070wx3_priv *priv = dev_get_priv(dev); + int ret; + + ret = backlight_enable(priv->backlight); + if (ret) + return ret; + + return backlight_set_brightness(priv->backlight, percent); +} + +static int lg_ld070wx3_timings(struct udevice *dev, + struct display_timing *timing) +{ + memcpy(timing, &default_timing, sizeof(*timing)); + return 0; +} + +static int lg_ld070wx3_of_to_plat(struct udevice *dev) +{ + struct lg_ld070wx3_priv *priv = dev_get_priv(dev); + int ret; + + ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (ret) { + log_debug("%s: cannot get backlight: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vdd-supply", &priv->vdd); + if (ret) { + log_debug("%s: cannot get vdd-supply: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vcc-supply", &priv->vcc); + if (ret) { + log_debug("%s: cannot get vcc-supply: ret = %d\n", + __func__, ret); + return ret; + } + + return 0; +} + +static int lg_ld070wx3_hw_init(struct udevice *dev) +{ + struct lg_ld070wx3_priv *priv = dev_get_priv(dev); + int ret; + + ret = regulator_set_enable_if_allowed(priv->vcc, 1); + if (ret) { + log_debug("%s: enabling vcc-supply failed (%d)\n", + __func__, ret); + return ret; + } + + ret = regulator_set_enable_if_allowed(priv->vdd, 1); + if (ret) { + log_debug("%s: enabling vdd-supply failed (%d)\n", + __func__, ret); + return ret; + } + + /* + * According to spec delay between enabling supply is 0, + * for regulators to reach required voltage ~5ms needed. + * MIPI interface signal for setup requires additional + * 110ms which in total results in 115ms. + */ + mdelay(115); + + return 0; +} + +static int lg_ld070wx3_probe(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + + /* fill characteristics of DSI data link */ + plat->lanes = 4; + plat->format = MIPI_DSI_FMT_RGB888; + plat->mode_flags = MIPI_DSI_MODE_VIDEO; + + return lg_ld070wx3_hw_init(dev); +} + +static const struct panel_ops lg_ld070wx3_ops = { + .enable_backlight = lg_ld070wx3_enable_backlight, + .set_backlight = lg_ld070wx3_set_backlight, + .get_display_timing = lg_ld070wx3_timings, +}; + +static const struct udevice_id lg_ld070wx3_ids[] = { + { .compatible = "lg,ld070wx3-sl01" }, + { } +}; + +U_BOOT_DRIVER(lg_ld070wx3) = { + .name = "lg_ld070wx3", + .id = UCLASS_PANEL, + .of_match = lg_ld070wx3_ids, + .ops = &lg_ld070wx3_ops, + .of_to_plat = lg_ld070wx3_of_to_plat, + .probe = lg_ld070wx3_probe, + .plat_auto = sizeof(struct mipi_dsi_panel_plat), + .priv_auto = sizeof(struct lg_ld070wx3_priv), +};
LTL106HL02 is a color active matrix TFT (Thin Film Transistor) liquid crystal display (LCD) that uses amorphous silicon TFT as switching devices. This model is composed of a TFT LCD panel, a driver circuit and a backlight unit. The resolution of a 10.6" contains 1920 x 1080 pixels and can display up to 16,8M color with wide viewing angle.
Co-developed-by: Jonas Schwöbel jonasschwoebel@yahoo.de Signed-off-by: Jonas Schwöbel jonasschwoebel@yahoo.de Co-developed-by: Svyatoslav Ryhel clamor95@gmail.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com Signed-off-by: Anton Bambura jenneron@protonmail.com --- drivers/video/Kconfig | 9 ++ drivers/video/Makefile | 1 + drivers/video/samsung-ltl106hl02.c | 157 +++++++++++++++++++++++++++++ 3 files changed, 167 insertions(+) create mode 100644 drivers/video/samsung-ltl106hl02.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 05567a0095..52b515197d 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -555,6 +555,15 @@ config VIDEO_LCD_RENESAS_R69328 IPS-LCD module with Renesas R69328 IC. The panel has a 720x1280 resolution and uses 24 bit RGB per pixel.
+config VIDEO_LCD_SAMSUNG_LTL106HL02 + tristate "Samsung LTL106HL02 1920x1080 DSI video mode panel" + depends on PANEL && BACKLIGHT + select VIDEO_MIPI_DSI + help + Say Y here if you want to enable support for Samsung LTL106HL02 + LCD module found in Microsoft Surface 2. The panel has a FullHD + resolution (1920x1080). + config VIDEO_LCD_SSD2828 bool "SSD2828 bridge chip" ---help--- diff --git a/drivers/video/Makefile b/drivers/video/Makefile index bb6d9b74b9..f3f70cd04a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -63,6 +63,7 @@ obj-$(CONFIG_VIDEO_LCD_ORISETECH_OTM8009A) += orisetech_otm8009a.o obj-$(CONFIG_VIDEO_LCD_RAYDIUM_RM68200) += raydium-rm68200.o obj-$(CONFIG_VIDEO_LCD_RENESAS_R61307) += renesas-r61307.o obj-$(CONFIG_VIDEO_LCD_RENESAS_R69328) += renesas-r69328.o +obj-$(CONFIG_VIDEO_LCD_SAMSUNG_LTL106HL02) += samsung-ltl106hl02.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_LCD_TDO_TL070WSH30) += tdo-tl070wsh30.o obj-$(CONFIG_VIDEO_MCDE_SIMPLE) += mcde_simple.o diff --git a/drivers/video/samsung-ltl106hl02.c b/drivers/video/samsung-ltl106hl02.c new file mode 100644 index 0000000000..5e6c11c4be --- /dev/null +++ b/drivers/video/samsung-ltl106hl02.c @@ -0,0 +1,157 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Samsung LTL106HL02-001 DSI panel driver + * + * Copyright (c) 2020 Anton Bambura jenneron@protonmail.com + * Copyright (c) 2023 Svyatoslav Ryhel clamor95@gmail.com + * Copyright (c) 2024 Jonas Schwöbel jonasschwoebel@yahoo.de + */ + +#include <backlight.h> +#include <dm.h> +#include <panel.h> +#include <log.h> +#include <mipi_dsi.h> +#include <asm/gpio.h> +#include <linux/delay.h> +#include <power/regulator.h> + +struct samsung_ltl106hl02_priv { + struct udevice *vdd; + struct udevice *backlight; + + struct gpio_desc reset_gpio; +}; + +static struct display_timing default_timing = { + .pixelclock.typ = 137000000, + .hactive.typ = 1920, + .hfront_porch.typ = 32, + .hback_porch.typ = 64, + .hsync_len.typ = 32, + .vactive.typ = 1080, + .vfront_porch.typ = 2, + .vback_porch.typ = 26, + .vsync_len.typ = 3, +}; + +static int samsung_ltl106hl02_enable_backlight(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + struct mipi_dsi_device *dsi = plat->device; + int ret; + + ret = mipi_dsi_dcs_exit_sleep_mode(dsi); + if (ret < 0) { + log_debug("%s: failed to exit sleep mode: %d\n", + __func__, ret); + return ret; + } + mdelay(70); + + ret = mipi_dsi_dcs_set_display_on(dsi); + if (ret < 0) { + log_debug("%s: failed to enable display: %d\n", + __func__, ret); + return ret; + } + mdelay(5); + + return 0; +} + +static int samsung_ltl106hl02_set_backlight(struct udevice *dev, int percent) +{ + struct samsung_ltl106hl02_priv *priv = dev_get_priv(dev); + int ret; + + ret = backlight_enable(priv->backlight); + if (ret) + return ret; + + return backlight_set_brightness(priv->backlight, percent); +} + +static int samsung_ltl106hl02_timings(struct udevice *dev, + struct display_timing *timing) +{ + memcpy(timing, &default_timing, sizeof(*timing)); + return 0; +} + +static int samsung_ltl106hl02_of_to_plat(struct udevice *dev) +{ + struct samsung_ltl106hl02_priv *priv = dev_get_priv(dev); + int ret; + + ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (ret) { + log_debug("%s: cannot get backlight: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vdd-supply", &priv->vdd); + if (ret) + log_debug("%s: cannot get vdd-supply: error %d\n", + __func__, ret); + + ret = gpio_request_by_name(dev, "reset-gpios", 0, + &priv->reset_gpio, GPIOD_IS_OUT); + if (ret) + log_debug("%s: cannot get reset-gpios: error %d\n", + __func__, ret); + + return 0; +} + +static int samsung_ltl106hl02_hw_init(struct udevice *dev) +{ + struct samsung_ltl106hl02_priv *priv = dev_get_priv(dev); + + dm_gpio_set_value(&priv->reset_gpio, 1); + regulator_set_enable_if_allowed(priv->vdd, 1); + + /* Dataheets states at least 8.5 msec for vdd stabilization */ + mdelay(10); + + dm_gpio_set_value(&priv->reset_gpio, 0); + + return 0; +} + +static int samsung_ltl106hl02_probe(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + + /* fill characteristics of DSI data link */ + plat->lanes = 4; + plat->format = MIPI_DSI_FMT_RGB888; + plat->mode_flags = MIPI_DSI_MODE_VIDEO; + + return samsung_ltl106hl02_hw_init(dev); +} + +static const struct panel_ops samsung_ltl106hl02_ops = { + .enable_backlight = samsung_ltl106hl02_enable_backlight, + .set_backlight = samsung_ltl106hl02_set_backlight, + .get_display_timing = samsung_ltl106hl02_timings, +}; + +static const struct udevice_id samsung_ltl106hl02_ids[] = { + { .compatible = "samsung,ltl106hl02-001" }, + { } +}; + +U_BOOT_DRIVER(samsung_ltl106hl02) = { + .name = "samsung_ltl106hl02", + .id = UCLASS_PANEL, + .of_match = samsung_ltl106hl02_ids, + .ops = &samsung_ltl106hl02_ops, + .of_to_plat = samsung_ltl106hl02_of_to_plat, + .probe = samsung_ltl106hl02_probe, + .plat_auto = sizeof(struct mipi_dsi_panel_plat), + .priv_auto = sizeof(struct samsung_ltl106hl02_priv), +};
Shift all setup stages one step earlier to better fit the existing uclass.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/endeavoru-panel.c | 128 +++++++++++++++++--------------- 1 file changed, 68 insertions(+), 60 deletions(-)
diff --git a/drivers/video/endeavoru-panel.c b/drivers/video/endeavoru-panel.c index 79a272128b..1bff641434 100644 --- a/drivers/video/endeavoru-panel.c +++ b/drivers/video/endeavoru-panel.c @@ -57,61 +57,8 @@ static void dcs_write_one(struct mipi_dsi_device *dsi, u8 cmd, u8 data)
static int endeavoru_panel_enable_backlight(struct udevice *dev) { - struct endeavoru_panel_priv *priv = dev_get_priv(dev); - int ret; - - ret = dm_gpio_set_value(&priv->reset_gpio, 1); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(5); - - ret = regulator_set_enable_if_allowed(priv->vddio, 1); - if (ret) { - log_err("error enabling iovcc-supply (%d)\n", ret); - return ret; - } - mdelay(1); - - ret = regulator_set_enable_if_allowed(priv->vdd, 1); - if (ret) { - log_err("error enabling vcc-supply (%d)\n", ret); - return ret; - } - mdelay(20); - - ret = dm_gpio_set_value(&priv->reset_gpio, 0); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(2); - - /* Reset panel */ - ret = dm_gpio_set_value(&priv->reset_gpio, 1); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(1); - - ret = dm_gpio_set_value(&priv->reset_gpio, 0); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(25); - - return 0; -} - -static int endeavoru_panel_set_backlight(struct udevice *dev, int percent) -{ - struct endeavoru_panel_priv *priv = dev_get_priv(dev); struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); struct mipi_dsi_device *dsi = plat->device; - int ret;
dcs_write_one(dsi, 0xc2, 0x08);
@@ -160,18 +107,22 @@ static int endeavoru_panel_set_backlight(struct udevice *dev, int percent) dcs_write_one(dsi, 0x55, 0x80); dcs_write_one(dsi, 0x5e, 0x06);
- ret = backlight_enable(priv->backlight); - if (ret) - return ret; - /* Set backlight */ dcs_write_one(dsi, 0x51, 0x96);
- ret = backlight_set_brightness(priv->backlight, percent); + return 0; +} + +static int endeavoru_panel_set_backlight(struct udevice *dev, int percent) +{ + struct endeavoru_panel_priv *priv = dev_get_priv(dev); + int ret; + + ret = backlight_enable(priv->backlight); if (ret) return ret;
- return 0; + return backlight_set_brightness(priv->backlight, percent); }
static int endeavoru_panel_timings(struct udevice *dev, @@ -217,6 +168,63 @@ static int endeavoru_panel_of_to_plat(struct udevice *dev) return 0; }
+static int endeavoru_panel_hw_init(struct udevice *dev) +{ + struct endeavoru_panel_priv *priv = dev_get_priv(dev); + int ret; + + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(5); + + ret = regulator_set_enable_if_allowed(priv->vddio, 1); + if (ret) { + log_debug("%s: error enabling iovcc-supply (%d)\n", + __func__, ret); + return ret; + } + mdelay(1); + + ret = regulator_set_enable_if_allowed(priv->vdd, 1); + if (ret) { + log_debug("%s: error enabling vcc-supply (%d)\n", + __func__, ret); + return ret; + } + mdelay(20); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(2); + + /* Reset panel */ + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(1); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(25); + + return 0; +} + static int endeavoru_panel_probe(struct udevice *dev) { struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); @@ -226,7 +234,7 @@ static int endeavoru_panel_probe(struct udevice *dev) plat->format = MIPI_DSI_FMT_RGB888; plat->mode_flags = MIPI_DSI_MODE_VIDEO;
- return 0; + return endeavoru_panel_hw_init(dev); }
static const struct panel_ops endeavoru_panel_ops = {
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/bridge/ssd2825.c | 82 +++++++++++++++++++--------------- 1 file changed, 46 insertions(+), 36 deletions(-)
diff --git a/drivers/video/bridge/ssd2825.c b/drivers/video/bridge/ssd2825.c index cea20dcffa..9783e9e05a 100644 --- a/drivers/video/bridge/ssd2825.c +++ b/drivers/video/bridge/ssd2825.c @@ -351,38 +351,6 @@ static int ssd2825_bridge_enable_panel(struct udevice *dev) struct display_timing *dt = &priv->timing; int ret;
- ret = clk_prepare_enable(priv->tx_clk); - if (ret) { - log_err("error enabling tx_clk (%d)\n", ret); - return ret; - } - - ret = dm_gpio_set_value(&priv->power_gpio, 1); - if (ret) { - log_err("error changing power-gpios (%d)\n", ret); - return ret; - } - mdelay(10); - - ret = dm_gpio_set_value(&priv->reset_gpio, 0); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(10); - - ret = dm_gpio_set_value(&priv->reset_gpio, 1); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(10); - - /* Perform panel HW setup */ - ret = panel_enable_backlight(priv->panel); - if (ret) - return ret; - /* Perform SW reset */ ssd2825_write_register(dev, SSD2825_OPERATION_CTRL_REG, 0x0100);
@@ -417,8 +385,8 @@ static int ssd2825_bridge_enable_panel(struct udevice *dev) SSD2825_CONF_REG_ECD | SSD2825_CONF_REG_EOT); ssd2825_write_register(dev, SSD2825_VC_CTRL_REG, 0x0000);
- /* Set up SW panel configuration */ - ret = panel_set_backlight(priv->panel, BACKLIGHT_DEFAULT); + /* Perform panel setup */ + ret = panel_enable_backlight(priv->panel); if (ret) return ret;
@@ -427,7 +395,10 @@ static int ssd2825_bridge_enable_panel(struct udevice *dev)
static int ssd2825_bridge_set_panel(struct udevice *dev, int percent) { - return 0; + struct ssd2825_bridge_priv *priv = dev_get_priv(dev); + + /* Set up SW panel configuration */ + return panel_set_backlight(priv->panel, percent); }
static int ssd2825_bridge_panel_timings(struct udevice *dev, @@ -440,6 +411,45 @@ static int ssd2825_bridge_panel_timings(struct udevice *dev, return 0; }
+static int ssd2825_bridge_hw_init(struct udevice *dev) +{ + struct ssd2825_bridge_priv *priv = dev_get_priv(dev); + int ret; + + ret = clk_prepare_enable(priv->tx_clk); + if (ret) { + log_debug("%s: error enabling tx_clk (%d)\n", + __func__, ret); + return ret; + } + + ret = dm_gpio_set_value(&priv->power_gpio, 1); + if (ret) { + log_debug("%s: error changing power-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(10); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(10); + + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(10); + + return 0; +} + static int ssd2825_bridge_probe(struct udevice *dev) { struct ssd2825_bridge_priv *priv = dev_get_priv(dev); @@ -496,7 +506,7 @@ static int ssd2825_bridge_probe(struct udevice *dev) return PTR_ERR(priv->tx_clk); }
- return 0; + return ssd2825_bridge_hw_init(dev); }
static const struct panel_ops ssd2825_bridge_ops = {
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/renesas-r61307.c | 93 +++++++++++++++++++--------------- drivers/video/renesas-r69328.c | 81 +++++++++++++++-------------- 2 files changed, 95 insertions(+), 79 deletions(-)
diff --git a/drivers/video/renesas-r61307.c b/drivers/video/renesas-r61307.c index 426fdc6224..1eccaf6b1b 100644 --- a/drivers/video/renesas-r61307.c +++ b/drivers/video/renesas-r61307.c @@ -118,42 +118,6 @@ static struct display_timing default_timing = { };
static int renesas_r61307_enable_backlight(struct udevice *dev) -{ - struct renesas_r61307_priv *priv = dev_get_priv(dev); - int ret; - - ret = regulator_set_enable_if_allowed(priv->vcc, 1); - if (ret) { - log_err("enabling vcc-supply failed (%d)\n", ret); - return ret; - } - mdelay(5); - - ret = regulator_set_enable_if_allowed(priv->iovcc, 1); - if (ret) { - log_err("enabling iovcc-supply failed (%d)\n", ret); - return ret; - } - - ret = dm_gpio_set_value(&priv->reset_gpio, 0); - if (ret) { - log_err("changing reset-gpio failed (%d)\n", ret); - return ret; - } - mdelay(5); - - ret = dm_gpio_set_value(&priv->reset_gpio, 1); - if (ret) { - log_err("changing reset-gpio failed (%d)\n", ret); - return ret; - } - - mdelay(5); - - return 0; -} - -static int renesas_r61307_set_backlight(struct udevice *dev, int percent) { struct renesas_r61307_priv *priv = dev_get_priv(dev); struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); @@ -205,18 +169,23 @@ static int renesas_r61307_set_backlight(struct udevice *dev, int percent) log_err("failed to set display on: %d\n", ret); return ret; } - mdelay(50);
+ return 0; +} + +static int renesas_r61307_set_backlight(struct udevice *dev, int percent) +{ + struct renesas_r61307_priv *priv = dev_get_priv(dev); + int ret; + ret = backlight_enable(priv->backlight); if (ret) return ret;
- ret = backlight_set_brightness(priv->backlight, percent); - if (ret) - return ret; + mdelay(5);
static int renesas_r61307_timings(struct udevice *dev, @@ -266,6 +235,46 @@ static int renesas_r61307_of_to_plat(struct udevice *dev) return 0; }
+static int renesas_r61307_hw_init(struct udevice *dev) +{ + struct renesas_r61307_priv *priv = dev_get_priv(dev); + int ret; + + ret = regulator_set_enable_if_allowed(priv->vcc, 1); + if (ret) { + log_debug("%s: enabling vcc-supply failed (%d)\n", + __func__, ret); + return ret; + } + mdelay(5); + + ret = regulator_set_enable_if_allowed(priv->iovcc, 1); + if (ret) { + log_debug("%s: enabling iovcc-supply failed (%d)\n", + __func__, ret); + return ret; + } + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: changing reset-gpio failed (%d)\n", + __func__, ret); + return ret; + } + mdelay(5); + + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: changing reset-gpio failed (%d)\n", + __func__, ret); + return ret; + } + + mdelay(5); + + return 0; +} + static int renesas_r61307_probe(struct udevice *dev) { struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); @@ -275,7 +284,7 @@ static int renesas_r61307_probe(struct udevice *dev) plat->format = MIPI_DSI_FMT_RGB888; plat->mode_flags = MIPI_DSI_MODE_VIDEO;
- return 0; + return renesas_r61307_hw_init(dev); }
static const struct panel_ops renesas_r61307_ops = { diff --git a/drivers/video/renesas-r69328.c b/drivers/video/renesas-r69328.c index d2f7169468..ecf89ec021 100644 --- a/drivers/video/renesas-r69328.c +++ b/drivers/video/renesas-r69328.c @@ -65,37 +65,6 @@ static struct display_timing default_timing = {
static int renesas_r69328_enable_backlight(struct udevice *dev) { - struct renesas_r69328_priv *priv = dev_get_priv(dev); - int ret; - - ret = dm_gpio_set_value(&priv->enable_gpio, 1); - if (ret) { - log_err("error changing enable-gpios (%d)\n", ret); - return ret; - } - mdelay(5); - - ret = dm_gpio_set_value(&priv->reset_gpio, 0); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - mdelay(5); - - ret = dm_gpio_set_value(&priv->reset_gpio, 1); - if (ret) { - log_err("error changing reset-gpios (%d)\n", ret); - return ret; - } - - mdelay(5); - - return 0; -} - -static int renesas_r69328_set_backlight(struct udevice *dev, int percent) -{ - struct renesas_r69328_priv *priv = dev_get_priv(dev); struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); struct mipi_dsi_device *dsi = plat->device; int ret; @@ -153,18 +122,23 @@ static int renesas_r69328_set_backlight(struct udevice *dev, int percent) log_err("failed to set display on: %d\n", ret); return ret; } - mdelay(50);
+ return 0; +} + +static int renesas_r69328_set_backlight(struct udevice *dev, int percent) +{ + struct renesas_r69328_priv *priv = dev_get_priv(dev); + int ret; + ret = backlight_enable(priv->backlight); if (ret) return ret;
static int renesas_r69328_timings(struct udevice *dev, @@ -203,6 +177,39 @@ static int renesas_r69328_of_to_plat(struct udevice *dev) return 0; }
+static int renesas_r69328_hw_init(struct udevice *dev) +{ + struct renesas_r69328_priv *priv = dev_get_priv(dev); + int ret; + + ret = dm_gpio_set_value(&priv->enable_gpio, 1); + if (ret) { + log_debug("%s: error changing enable-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(5); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(5); + + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: error changing reset-gpios (%d)\n", + __func__, ret); + return ret; + } + + mdelay(5); + + return 0; +} + static int renesas_r69328_probe(struct udevice *dev) { struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); @@ -212,7 +219,7 @@ static int renesas_r69328_probe(struct udevice *dev) plat->format = MIPI_DSI_FMT_RGB888; plat->mode_flags = MIPI_DSI_MODE_VIDEO;
- return 0; + return renesas_r69328_hw_init(dev); }
static const struct panel_ops renesas_r69328_ops = {
Svyatoslav Ryhel
