[U-Boot-Users] FEC problems on MPC5200
Hi everybody,
I've got some ethernet problems with a Lite5200. During tftp transferts, I've got a lot of timeouts. I've put a network analyzer on my ethernet, and I can see that all is ok on the server side (all the frames are sent). It sounds like the Lite5200 missed some frames, because it doen't send the ACK.
Has somebody experienced same problems on a MPC5200 ?
Best regards.
Pierre
I see the same happen with my Lite5200. I get frequent timeouts when loading the kernel with TFTP. It also happens when using the Motorola dbug boot monitor to load via TFTP. Something seems to be wrong. This happens very rarely when I am using our custom mpc823 board to load from the same TFTP server, but with Lite5200 it happens almost every time.
Regards, Jon Benediktsson Marel hf.
I also have the problem with dbug monitor. Is there any timeouts within Linux kernel ?
With other boards (based on MPC860T) we don't have any timeouts.
Regards
Pierre AUBERT p.aubert@staubli.com wrote on 19.03.2004 11:31:38:
TFTP.
I have not observed this problem when using tftp in a Linux bash shell. By this I mean I run tftp from a bash shell, turn on trace and do a 'get' command for a fairly large file. All the sends and acks match up and there is no observed delay in the transfer.
Regards
Yes, we see the same problem, and "bad length" errors. It seems the problem was introduced by one of the patches lately. We're in- vestigating.
Hi everybody,
I've made a lot of tries with the MPC5200 FEC. It appears that timeouts occurs because some ACK frames aren't sent by the MPC5200 (but all is OK in mpc5xxx_fec_send).
The problem disappears if I suppress the full duplex (in fec->eth->x_cntrl and in the reg 0 of the LXT971A). I can submit a patch.
But I have another question: if I suppress all the MII initialization sequence in cpu/mpc5xxx/fec.c, the LXT971A reads its configuration from hardware and network is working fine at 10M and 100M on my Lite5200. The auto-negociation works fine. Then, do we need to keep this (broken ?) init sequence ? Is there something I have missed ?
Best regards
I have the same problem with my board (using MPC8280), but I don't know if is a problem of the network (sometimes also ping fails - the switchs/routers are not configured very well, I think) and/or is a problem of driver.
Enzo
Figini Enzo
Jón Benediktsson
Pierre AUBERT
