[PATCH v2 1/5] phy: phy-mtk-tphy: remove macros to prepare bitfield value
Prefer to make use of FIELD_PREP() macro to prepare bitfield value, then no need local macros anymore.
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- v2: new patch --- drivers/phy/phy-mtk-tphy.c | 122 ++++++++++++++----------------------- 1 file changed, 47 insertions(+), 75 deletions(-)
diff --git a/drivers/phy/phy-mtk-tphy.c b/drivers/phy/phy-mtk-tphy.c index 2dd964f7b2..24e6124b76 100644 --- a/drivers/phy/phy-mtk-tphy.c +++ b/drivers/phy/phy-mtk-tphy.c @@ -14,6 +14,7 @@ #include <asm/io.h> #include <dm/device_compat.h> #include <dm/devres.h> +#include <linux/bitfield.h> #include <linux/bitops.h> #include <linux/delay.h>
@@ -48,14 +49,12 @@ #define U3P_USBPHYACR5 0x014 #define PA5_RG_U2_HSTX_SRCAL_EN BIT(15) #define PA5_RG_U2_HSTX_SRCTRL GENMASK(14, 12) -#define PA5_RG_U2_HSTX_SRCTRL_VAL(x) ((0x7 & (x)) << 12) #define PA5_RG_U2_HS_100U_U3_EN BIT(11)
#define U3P_USBPHYACR6 0x018 #define PA6_RG_U2_BC11_SW_EN BIT(23) #define PA6_RG_U2_OTG_VBUSCMP_EN BIT(20) #define PA6_RG_U2_SQTH GENMASK(3, 0) -#define PA6_RG_U2_SQTH_VAL(x) (0xf & (x))
#define U3P_U2PHYACR4 0x020 #define P2C_RG_USB20_GPIO_CTL BIT(9) @@ -72,11 +71,9 @@ #define P2C_FORCE_SUSPENDM BIT(18) #define P2C_FORCE_TERMSEL BIT(17) #define P2C_RG_DATAIN GENMASK(13, 10) -#define P2C_RG_DATAIN_VAL(x) ((0xf & (x)) << 10) #define P2C_RG_DMPULLDOWN BIT(7) #define P2C_RG_DPPULLDOWN BIT(6) #define P2C_RG_XCVRSEL GENMASK(5, 4) -#define P2C_RG_XCVRSEL_VAL(x) ((0x3 & (x)) << 4) #define P2C_RG_SUSPENDM BIT(3) #define P2C_RG_TERMSEL BIT(2) #define P2C_DTM0_PART_MASK \ @@ -104,72 +101,53 @@
#define U3P_U3_PHYA_REG0 0x000 #define P3A_RG_CLKDRV_OFF GENMASK(3, 2) -#define P3A_RG_CLKDRV_OFF_VAL(x) ((0x3 & (x)) << 2)
#define U3P_U3_PHYA_REG1 0x004 #define P3A_RG_CLKDRV_AMP GENMASK(31, 29) -#define P3A_RG_CLKDRV_AMP_VAL(x) ((0x7 & (x)) << 29)
#define U3P_U3_PHYA_REG6 0x018 #define P3A_RG_TX_EIDLE_CM GENMASK(31, 28) -#define P3A_RG_TX_EIDLE_CM_VAL(x) ((0xf & (x)) << 28)
#define U3P_U3_PHYA_REG9 0x024 #define P3A_RG_RX_DAC_MUX GENMASK(5, 1) -#define P3A_RG_RX_DAC_MUX_VAL(x) ((0x1f & (x)) << 1)
#define U3P_U3_PHYA_DA_REG0 0x100 #define P3A_RG_XTAL_EXT_PE2H GENMASK(17, 16) -#define P3A_RG_XTAL_EXT_PE2H_VAL(x) ((0x3 & (x)) << 16) #define P3A_RG_XTAL_EXT_PE1H GENMASK(13, 12) -#define P3A_RG_XTAL_EXT_PE1H_VAL(x) ((0x3 & (x)) << 12) #define P3A_RG_XTAL_EXT_EN_U3 GENMASK(11, 10) -#define P3A_RG_XTAL_EXT_EN_U3_VAL(x) ((0x3 & (x)) << 10)
#define U3P_U3_PHYA_DA_REG4 0x108 #define P3A_RG_PLL_DIVEN_PE2H GENMASK(21, 19) #define P3A_RG_PLL_BC_PE2H GENMASK(7, 6) -#define P3A_RG_PLL_BC_PE2H_VAL(x) ((0x3 & (x)) << 6)
#define U3P_U3_PHYA_DA_REG5 0x10c #define P3A_RG_PLL_BR_PE2H GENMASK(29, 28) -#define P3A_RG_PLL_BR_PE2H_VAL(x) ((0x3 & (x)) << 28) #define P3A_RG_PLL_IC_PE2H GENMASK(15, 12) -#define P3A_RG_PLL_IC_PE2H_VAL(x) ((0xf & (x)) << 12)
#define U3P_U3_PHYA_DA_REG6 0x110 #define P3A_RG_PLL_IR_PE2H GENMASK(19, 16) -#define P3A_RG_PLL_IR_PE2H_VAL(x) ((0xf & (x)) << 16)
#define U3P_U3_PHYA_DA_REG7 0x114 #define P3A_RG_PLL_BP_PE2H GENMASK(19, 16) -#define P3A_RG_PLL_BP_PE2H_VAL(x) ((0xf & (x)) << 16)
#define U3P_U3_PHYA_DA_REG20 0x13c #define P3A_RG_PLL_DELTA1_PE2H GENMASK(31, 16) -#define P3A_RG_PLL_DELTA1_PE2H_VAL(x) ((0xffff & (x)) << 16)
#define U3P_U3_PHYA_DA_REG25 0x148 #define P3A_RG_PLL_DELTA_PE2H GENMASK(15, 0) -#define P3A_RG_PLL_DELTA_PE2H_VAL(x) (0xffff & (x))
#define U3P_U3_PHYD_LFPS1 0x00c #define P3D_RG_FWAKE_TH GENMASK(21, 16) -#define P3D_RG_FWAKE_TH_VAL(x) ((0x3f & (x)) << 16)
#define U3P_U3_PHYD_CDR1 0x05c #define P3D_RG_CDR_BIR_LTD1 GENMASK(28, 24) -#define P3D_RG_CDR_BIR_LTD1_VAL(x) ((0x1f & (x)) << 24) #define P3D_RG_CDR_BIR_LTD0 GENMASK(12, 8) -#define P3D_RG_CDR_BIR_LTD0_VAL(x) ((0x1f & (x)) << 8)
#define U3P_U3_PHYD_RXDET1 0x128 #define P3D_RG_RXDET_STB2_SET GENMASK(17, 9) -#define P3D_RG_RXDET_STB2_SET_VAL(x) ((0x1ff & (x)) << 9)
#define U3P_U3_PHYD_RXDET2 0x12c #define P3D_RG_RXDET_STB2_SET_P3 GENMASK(8, 0) -#define P3D_RG_RXDET_STB2_SET_P3_VAL(x) (0x1ff & (x))
#define U3P_SPLLC_XTALCTL3 0x018 #define XC3_RG_U3_XTAL_RX_PWD BIT(9) @@ -179,60 +157,45 @@ #define PHYD_CTRL_SIGNAL_MODE4 0x1c /* CDR Charge Pump P-path current adjustment */ #define RG_CDR_BICLTD1_GEN1_MSK GENMASK(23, 20) -#define RG_CDR_BICLTD1_GEN1_VAL(x) ((0xf & (x)) << 20) #define RG_CDR_BICLTD0_GEN1_MSK GENMASK(11, 8) -#define RG_CDR_BICLTD0_GEN1_VAL(x) ((0xf & (x)) << 8)
#define PHYD_DESIGN_OPTION2 0x24 /* Symbol lock count selection */ #define RG_LOCK_CNT_SEL_MSK GENMASK(5, 4) -#define RG_LOCK_CNT_SEL_VAL(x) ((0x3 & (x)) << 4)
#define PHYD_DESIGN_OPTION9 0x40 /* COMWAK GAP width window */ #define RG_TG_MAX_MSK GENMASK(20, 16) -#define RG_TG_MAX_VAL(x) ((0x1f & (x)) << 16) /* COMINIT GAP width window */ #define RG_T2_MAX_MSK GENMASK(13, 8) -#define RG_T2_MAX_VAL(x) ((0x3f & (x)) << 8) /* COMWAK GAP width window */ #define RG_TG_MIN_MSK GENMASK(7, 5) -#define RG_TG_MIN_VAL(x) ((0x7 & (x)) << 5) /* COMINIT GAP width window */ #define RG_T2_MIN_MSK GENMASK(4, 0) -#define RG_T2_MIN_VAL(x) (0x1f & (x))
#define ANA_RG_CTRL_SIGNAL1 0x4c /* TX driver tail current control for 0dB de-empahsis mdoe for Gen1 speed */ #define RG_IDRV_0DB_GEN1_MSK GENMASK(13, 8) -#define RG_IDRV_0DB_GEN1_VAL(x) ((0x3f & (x)) << 8)
#define ANA_RG_CTRL_SIGNAL4 0x58 #define RG_CDR_BICLTR_GEN1_MSK GENMASK(23, 20) -#define RG_CDR_BICLTR_GEN1_VAL(x) ((0xf & (x)) << 20) /* Loop filter R1 resistance adjustment for Gen1 speed */ #define RG_CDR_BR_GEN2_MSK GENMASK(10, 8) -#define RG_CDR_BR_GEN2_VAL(x) ((0x7 & (x)) << 8)
#define ANA_RG_CTRL_SIGNAL6 0x60 /* I-path capacitance adjustment for Gen1 */ #define RG_CDR_BC_GEN1_MSK GENMASK(28, 24) -#define RG_CDR_BC_GEN1_VAL(x) ((0x1f & (x)) << 24) #define RG_CDR_BIRLTR_GEN1_MSK GENMASK(4, 0) -#define RG_CDR_BIRLTR_GEN1_VAL(x) (0x1f & (x))
#define ANA_EQ_EYE_CTRL_SIGNAL1 0x6c /* RX Gen1 LEQ tuning step */ #define RG_EQ_DLEQ_LFI_GEN1_MSK GENMASK(11, 8) -#define RG_EQ_DLEQ_LFI_GEN1_VAL(x) ((0xf & (x)) << 8)
#define ANA_EQ_EYE_CTRL_SIGNAL4 0xd8 #define RG_CDR_BIRLTD0_GEN1_MSK GENMASK(20, 16) -#define RG_CDR_BIRLTD0_GEN1_VAL(x) ((0x1f & (x)) << 16)
#define ANA_EQ_EYE_CTRL_SIGNAL5 0xdc #define RG_CDR_BIRLTD0_GEN3_MSK GENMASK(4, 0) -#define RG_CDR_BIRLTD0_GEN3_VAL(x) (0x1f & (x))
enum mtk_phy_version { MTK_TPHY_V1 = 1, @@ -282,7 +245,8 @@ static void u2_phy_instance_init(struct mtk_tphy *tphy, /* switch to USB function, and enable usb pll */ clrsetbits_le32(u2_banks->com + U3P_U2PHYDTM0, P2C_FORCE_UART_EN | P2C_FORCE_SUSPENDM, - P2C_RG_XCVRSEL_VAL(1) | P2C_RG_DATAIN_VAL(0)); + FIELD_PREP(P2C_RG_XCVRSEL, 1) | + FIELD_PREP(P2C_RG_DATAIN, 0));
clrbits_le32(u2_banks->com + U3P_U2PHYDTM1, P2C_RG_UART_EN); setbits_le32(u2_banks->com + U3P_USBPHYACR0, PA0_RG_USB20_INTR_EN); @@ -295,11 +259,12 @@ static void u2_phy_instance_init(struct mtk_tphy *tphy, /* DP/DM BC1.1 path Disable */ clrsetbits_le32(u2_banks->com + U3P_USBPHYACR6, PA6_RG_U2_BC11_SW_EN | PA6_RG_U2_SQTH, - PA6_RG_U2_SQTH_VAL(2)); + FIELD_PREP(PA6_RG_U2_SQTH, 2));
/* set HS slew rate */ clrsetbits_le32(u2_banks->com + U3P_USBPHYACR5, - PA5_RG_U2_HSTX_SRCTRL, PA5_RG_U2_HSTX_SRCTRL_VAL(4)); + PA5_RG_U2_HSTX_SRCTRL, + FIELD_PREP(PA5_RG_U2_HSTX_SRCTRL, 4));
dev_dbg(tphy->dev, "%s(%d)\n", __func__, instance->index); } @@ -351,28 +316,31 @@ static void u3_phy_instance_init(struct mtk_tphy *tphy,
/* gating XSQ */ clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG0, - P3A_RG_XTAL_EXT_EN_U3, P3A_RG_XTAL_EXT_EN_U3_VAL(2)); + P3A_RG_XTAL_EXT_EN_U3, + FIELD_PREP(P3A_RG_XTAL_EXT_EN_U3, 2));
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_REG9, - P3A_RG_RX_DAC_MUX, P3A_RG_RX_DAC_MUX_VAL(4)); + P3A_RG_RX_DAC_MUX, FIELD_PREP(P3A_RG_RX_DAC_MUX, 4));
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_REG6, - P3A_RG_TX_EIDLE_CM, P3A_RG_TX_EIDLE_CM_VAL(0xe)); + P3A_RG_TX_EIDLE_CM, + FIELD_PREP(P3A_RG_TX_EIDLE_CM, 0xe));
clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_CDR1, P3D_RG_CDR_BIR_LTD0 | P3D_RG_CDR_BIR_LTD1, - P3D_RG_CDR_BIR_LTD0_VAL(0xc) | - P3D_RG_CDR_BIR_LTD1_VAL(0x3)); + FIELD_PREP(P3D_RG_CDR_BIR_LTD0, 0xc) | + FIELD_PREP(P3D_RG_CDR_BIR_LTD1, 0x3));
clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_LFPS1, - P3D_RG_FWAKE_TH, P3D_RG_FWAKE_TH_VAL(0x34)); + P3D_RG_FWAKE_TH, FIELD_PREP(P3D_RG_FWAKE_TH, 0x34));
clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_RXDET1, - P3D_RG_RXDET_STB2_SET, P3D_RG_RXDET_STB2_SET_VAL(0x10)); + P3D_RG_RXDET_STB2_SET, + FIELD_PREP(P3D_RG_RXDET_STB2_SET, 0x10));
clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_RXDET2, P3D_RG_RXDET_STB2_SET_P3, - P3D_RG_RXDET_STB2_SET_P3_VAL(0x10)); + FIELD_PREP(P3D_RG_RXDET_STB2_SET_P3, 0x10));
dev_dbg(tphy->dev, "%s(%d)\n", __func__, instance->index); } @@ -387,45 +355,47 @@ static void pcie_phy_instance_init(struct mtk_tphy *tphy,
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG0, P3A_RG_XTAL_EXT_PE1H | P3A_RG_XTAL_EXT_PE2H, - P3A_RG_XTAL_EXT_PE1H_VAL(0x2) | - P3A_RG_XTAL_EXT_PE2H_VAL(0x2)); + FIELD_PREP(P3A_RG_XTAL_EXT_PE1H, 0x2) | + FIELD_PREP(P3A_RG_XTAL_EXT_PE2H, 0x2));
/* ref clk drive */ clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_REG1, P3A_RG_CLKDRV_AMP, - P3A_RG_CLKDRV_AMP_VAL(0x4)); + FIELD_PREP(P3A_RG_CLKDRV_AMP, 0x4)); clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_REG0, P3A_RG_CLKDRV_OFF, - P3A_RG_CLKDRV_OFF_VAL(0x1)); + FIELD_PREP(P3A_RG_CLKDRV_OFF, 0x1));
/* SSC delta -5000ppm */ clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG20, P3A_RG_PLL_DELTA1_PE2H, - P3A_RG_PLL_DELTA1_PE2H_VAL(0x3c)); + FIELD_PREP(P3A_RG_PLL_DELTA1_PE2H, 0x3c));
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG25, P3A_RG_PLL_DELTA_PE2H, - P3A_RG_PLL_DELTA_PE2H_VAL(0x36)); + FIELD_PREP(P3A_RG_PLL_DELTA_PE2H, 0x36));
/* change pll BW 0.6M */ clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG5, P3A_RG_PLL_BR_PE2H | P3A_RG_PLL_IC_PE2H, - P3A_RG_PLL_BR_PE2H_VAL(0x1) | - P3A_RG_PLL_IC_PE2H_VAL(0x1)); + FIELD_PREP(P3A_RG_PLL_BR_PE2H, 0x1) | + FIELD_PREP(P3A_RG_PLL_IC_PE2H, 0x1)); clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG4, P3A_RG_PLL_DIVEN_PE2H | P3A_RG_PLL_BC_PE2H, - P3A_RG_PLL_BC_PE2H_VAL(0x3)); + FIELD_PREP(P3A_RG_PLL_BC_PE2H, 0x3));
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG6, - P3A_RG_PLL_IR_PE2H, P3A_RG_PLL_IR_PE2H_VAL(0x2)); + P3A_RG_PLL_IR_PE2H, + FIELD_PREP(P3A_RG_PLL_IR_PE2H, 0x2)); clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG7, - P3A_RG_PLL_BP_PE2H, P3A_RG_PLL_BP_PE2H_VAL(0xa)); + P3A_RG_PLL_BP_PE2H, + FIELD_PREP(P3A_RG_PLL_BP_PE2H, 0xa));
/* Tx Detect Rx Timing: 10us -> 5us */ clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_RXDET1, P3D_RG_RXDET_STB2_SET, - P3D_RG_RXDET_STB2_SET_VAL(0x10)); + FIELD_PREP(P3D_RG_RXDET_STB2_SET, 0x10)); clrsetbits_le32(u3_banks->phyd + U3P_U3_PHYD_RXDET2, P3D_RG_RXDET_STB2_SET_P3, - P3D_RG_RXDET_STB2_SET_P3_VAL(0x10)); + FIELD_PREP(P3D_RG_RXDET_STB2_SET_P3, 0x10));
/* wait for PCIe subsys register to active */ udelay(3000); @@ -438,36 +408,38 @@ static void sata_phy_instance_init(struct mtk_tphy *tphy,
clrsetbits_le32(u3_banks->phyd + ANA_RG_CTRL_SIGNAL6, RG_CDR_BIRLTR_GEN1_MSK | RG_CDR_BC_GEN1_MSK, - RG_CDR_BIRLTR_GEN1_VAL(0x6) | - RG_CDR_BC_GEN1_VAL(0x1a)); + FIELD_PREP(RG_CDR_BIRLTR_GEN1_MSK, 0x6) | + FIELD_PREP(RG_CDR_BC_GEN1_MSK, 0x1a)); clrsetbits_le32(u3_banks->phyd + ANA_EQ_EYE_CTRL_SIGNAL4, RG_CDR_BIRLTD0_GEN1_MSK, - RG_CDR_BIRLTD0_GEN1_VAL(0x18)); + FIELD_PREP(RG_CDR_BIRLTD0_GEN1_MSK, 0x18)); clrsetbits_le32(u3_banks->phyd + ANA_EQ_EYE_CTRL_SIGNAL5, RG_CDR_BIRLTD0_GEN3_MSK, - RG_CDR_BIRLTD0_GEN3_VAL(0x06)); + FIELD_PREP(RG_CDR_BIRLTD0_GEN3_MSK, 0x06)); clrsetbits_le32(u3_banks->phyd + ANA_RG_CTRL_SIGNAL4, RG_CDR_BICLTR_GEN1_MSK | RG_CDR_BR_GEN2_MSK, - RG_CDR_BICLTR_GEN1_VAL(0x0c) | - RG_CDR_BR_GEN2_VAL(0x07)); + FIELD_PREP(RG_CDR_BICLTR_GEN1_MSK, 0x0c) | + FIELD_PREP(RG_CDR_BR_GEN2_MSK, 0x07)); clrsetbits_le32(u3_banks->phyd + PHYD_CTRL_SIGNAL_MODE4, RG_CDR_BICLTD0_GEN1_MSK | RG_CDR_BICLTD1_GEN1_MSK, - RG_CDR_BICLTD0_GEN1_VAL(0x08) | - RG_CDR_BICLTD1_GEN1_VAL(0x02)); + FIELD_PREP(RG_CDR_BICLTD0_GEN1_MSK, 0x08) | + FIELD_PREP(RG_CDR_BICLTD1_GEN1_MSK, 0x02)); clrsetbits_le32(u3_banks->phyd + PHYD_DESIGN_OPTION2, RG_LOCK_CNT_SEL_MSK, - RG_LOCK_CNT_SEL_VAL(0x02)); + FIELD_PREP(RG_LOCK_CNT_SEL_MSK, 0x02)); clrsetbits_le32(u3_banks->phyd + PHYD_DESIGN_OPTION9, RG_T2_MIN_MSK | RG_TG_MIN_MSK | RG_T2_MAX_MSK | RG_TG_MAX_MSK, - RG_T2_MIN_VAL(0x12) | RG_TG_MIN_VAL(0x04) | - RG_T2_MAX_VAL(0x31) | RG_TG_MAX_VAL(0x0e)); + FIELD_PREP(RG_T2_MIN_MSK, 0x12) | + FIELD_PREP(RG_TG_MIN_MSK, 0x04) | + FIELD_PREP(RG_T2_MAX_MSK, 0x31) | + FIELD_PREP(RG_TG_MAX_MSK, 0x0e)); clrsetbits_le32(u3_banks->phyd + ANA_RG_CTRL_SIGNAL1, RG_IDRV_0DB_GEN1_MSK, - RG_IDRV_0DB_GEN1_VAL(0x20)); + FIELD_PREP(RG_IDRV_0DB_GEN1_MSK, 0x20)); clrsetbits_le32(u3_banks->phyd + ANA_EQ_EYE_CTRL_SIGNAL1, RG_EQ_DLEQ_LFI_GEN1_MSK, - RG_EQ_DLEQ_LFI_GEN1_VAL(0x03)); + FIELD_PREP(RG_EQ_DLEQ_LFI_GEN1_MSK, 0x03)); }
static void pcie_phy_instance_power_on(struct mtk_tphy *tphy,
The T-PHY controller is designed to use use PLL integer mode, but in fact use fractional mode for some ones on mt8195 by mistake, this causes signal degradation (e.g. eye diagram test fail), fix it by switching PLL to 26Mhz from default 48Mhz to improve signal quality.
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- v2: use FIELD_PREP() macro --- drivers/phy/phy-mtk-tphy.c | 91 +++++++++++++++++++++++++++++++++----- 1 file changed, 81 insertions(+), 10 deletions(-)
diff --git a/drivers/phy/phy-mtk-tphy.c b/drivers/phy/phy-mtk-tphy.c index 24e6124b76..1883f9f83e 100644 --- a/drivers/phy/phy-mtk-tphy.c +++ b/drivers/phy/phy-mtk-tphy.c @@ -44,8 +44,12 @@
#define U3P_USBPHYACR0 0x000 #define PA0_RG_U2PLL_FORCE_ON BIT(15) +#define PA0_USB20_PLL_PREDIV GENMASK(7, 6) #define PA0_RG_USB20_INTR_EN BIT(5)
+#define U3P_USBPHYACR2 0x008 +#define PA2_RG_U2PLL_BW GENMASK(21, 19) + #define U3P_USBPHYACR5 0x014 #define PA5_RG_U2_HSTX_SRCAL_EN BIT(15) #define PA5_RG_U2_HSTX_SRCTRL GENMASK(14, 12) @@ -62,6 +66,14 @@ #define P2C_U2_GPIO_CTR_MSK \ (P2C_RG_USB20_GPIO_CTL | P2C_USB20_GPIO_MODE)
+#define U3P_U2PHYA_RESV 0x030 +#define P2R_RG_U2PLL_FBDIV_26M 0x1bb13b +#define P2R_RG_U2PLL_FBDIV_48M 0x3c0000 + +#define U3P_U2PHYA_RESV1 0x044 +#define P2R_RG_U2PLL_REFCLK_SEL BIT(5) +#define P2R_RG_U2PLL_FRA_EN BIT(3) + #define U3P_U2PHYDTM0 0x068 #define P2C_FORCE_UART_EN BIT(26) #define P2C_FORCE_DATAIN BIT(23) @@ -202,6 +214,17 @@ enum mtk_phy_version { MTK_TPHY_V2, };
+struct tphy_pdata { + enum mtk_phy_version version; + + /* + * workaround only for mt8195: + * u2phy should use integer mode instead of fractional mode of + * 48M PLL, fix it by switching PLL to 26M from default 48M + */ + bool sw_pll_48m_to_26m; +}; + struct u2phy_banks { void __iomem *misc; void __iomem *fmreg; @@ -232,11 +255,32 @@ struct mtk_phy_instance { struct mtk_tphy { struct udevice *dev; void __iomem *sif_base; - enum mtk_phy_version version; + const struct tphy_pdata *pdata; struct mtk_phy_instance **phys; int nphys; };
+/* workaround only for mt8195 */ +static void u2_phy_pll_26m_set(struct mtk_tphy *tphy, + struct mtk_phy_instance *instance) +{ + struct u2phy_banks *u2_banks = &instance->u2_banks; + + if (!tphy->pdata->sw_pll_48m_to_26m) + return; + + clrsetbits_le32(u2_banks->com + U3P_USBPHYACR0, PA0_USB20_PLL_PREDIV, + FIELD_PREP(PA0_USB20_PLL_PREDIV, 0)); + + clrsetbits_le32(u2_banks->com + U3P_USBPHYACR2, PA2_RG_U2PLL_BW, + FIELD_PREP(PA2_RG_U2PLL_BW, 3)); + + writel(P2R_RG_U2PLL_FBDIV_26M, u2_banks->com + U3P_U2PHYA_RESV); + + setbits_le32(u2_banks->com + U3P_U2PHYA_RESV1, + P2R_RG_U2PLL_FRA_EN | P2R_RG_U2PLL_REFCLK_SEL); +} + static void u2_phy_instance_init(struct mtk_tphy *tphy, struct mtk_phy_instance *instance) { @@ -266,6 +310,8 @@ static void u2_phy_instance_init(struct mtk_tphy *tphy, PA5_RG_U2_HSTX_SRCTRL, FIELD_PREP(PA5_RG_U2_HSTX_SRCTRL, 4));
+ u2_phy_pll_26m_set(tphy, instance); + dev_dbg(tphy->dev, "%s(%d)\n", __func__, instance->index); }
@@ -350,7 +396,7 @@ static void pcie_phy_instance_init(struct mtk_tphy *tphy, { struct u3phy_banks *u3_banks = &instance->u3_banks;
- if (tphy->version != MTK_TPHY_V1) + if (tphy->pdata->version != MTK_TPHY_V1) return;
clrsetbits_le32(u3_banks->phya + U3P_U3_PHYA_DA_REG0, @@ -634,11 +680,14 @@ static int mtk_phy_xlate(struct phy *phy, return -EINVAL; }
- if (tphy->version == MTK_TPHY_V1) { + switch (tphy->pdata->version) { + case MTK_TPHY_V1: phy_v1_banks_init(tphy, instance); - } else if (tphy->version == MTK_TPHY_V2) { + break; + case MTK_TPHY_V2: phy_v2_banks_init(tphy, instance); - } else { + break; + default: dev_err(phy->dev, "phy version is not supported\n"); return -EINVAL; } @@ -668,13 +717,12 @@ static int mtk_tphy_probe(struct udevice *dev) return -ENOMEM;
tphy->dev = dev; - tphy->version = dev_get_driver_data(dev); + tphy->pdata = (void *)dev_get_driver_data(dev);
/* v1 has shared banks for usb/pcie mode, */ /* but not for sata mode */ - if (tphy->version == MTK_TPHY_V1) { + if (tphy->pdata->version == MTK_TPHY_V1) tphy->sif_base = dev_read_addr_ptr(dev); - }
dev_for_each_subnode(subnode, dev) { struct mtk_phy_instance *instance; @@ -709,9 +757,32 @@ static int mtk_tphy_probe(struct udevice *dev) return 0; }
+static struct tphy_pdata tphy_v1_pdata = { + .version = MTK_TPHY_V1, +}; + +static struct tphy_pdata tphy_v2_pdata = { + .version = MTK_TPHY_V2, +}; + +static struct tphy_pdata mt8195_pdata = { + .version = MTK_TPHY_V2, + .sw_pll_48m_to_26m = true, +}; + static const struct udevice_id mtk_tphy_id_table[] = { - { .compatible = "mediatek,generic-tphy-v1", .data = MTK_TPHY_V1, }, - { .compatible = "mediatek,generic-tphy-v2", .data = MTK_TPHY_V2, }, + { + .compatible = "mediatek,generic-tphy-v1", + .data = (ulong)&tphy_v1_pdata, + }, + { + .compatible = "mediatek,generic-tphy-v2", + .data = (ulong)&tphy_v2_pdata, + }, + { + .compatible = "mediatek,mt8195-tphy", + .data = (ulong)&mt8195_pdata, + }, { } };
There are 4 USB controllers on MT8195, the controllers (IP1~IP3, exclude IP0) have a wrong default SOF/ITP interval which is calculated from the frame counter clock 24Mhz by default, but in fact, the frame counter clock is 48Mhz, so we shall set the accurate interval according to 48Mhz for those controllers.
Note: The first controller no need set it, but if set it, shall change tphy's pll at the same time.
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- v2: use FIELD_PREP() suggested by Marek --- drivers/usb/host/xhci-mtk.c | 49 ++++++++++++++++++++++++++++++++++++- 1 file changed, 48 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/xhci-mtk.c b/drivers/usb/host/xhci-mtk.c index 3838a990ec..63dfb793c6 100644 --- a/drivers/usb/host/xhci-mtk.c +++ b/drivers/usb/host/xhci-mtk.c @@ -14,8 +14,9 @@ #include <power/regulator.h> #include <usb.h> #include <usb/xhci.h> -#include <linux/errno.h> +#include <linux/bitfield.h> #include <linux/compat.h> +#include <linux/errno.h> #include <linux/iopoll.h>
/* IPPC (IP Port Control) registers */ @@ -50,6 +51,25 @@ #define IPPC_U3_CTRL(p) (IPPC_U3_CTRL_0P + ((p) * 0x08)) #define IPPC_U2_CTRL(p) (IPPC_U2_CTRL_0P + ((p) * 0x08))
+/* xHCI CSR */ +#define LS_EOF_CFG 0x930 +#define LSEOF_OFFSET 0x89 + +#define FS_EOF_CFG 0x934 +#define FSEOF_OFFSET 0x2e + +#define SS_GEN1_EOF_CFG 0x93c +#define SSG1EOF_OFFSET 0x78 + +#define HFCNTR_CFG 0x944 +#define ITP_DELTA_CLK_MASK GENMASK(5, 1) +#define FRMCNT_LEV1_RANG_MASK GENMASK(19, 8) + +#define SS_GEN2_EOF_CFG 0x990 +#define SSG2EOF_OFFSET 0x3c + +#define XSEOF_OFFSET_MASK GENMASK(11, 0) + struct mtk_xhci { struct xhci_ctrl ctrl; /* Needs to come first in this struct! */ struct xhci_hccr *hcd; @@ -65,6 +85,30 @@ struct mtk_xhci { u32 u2p_dis_msk; };
+/* + * workaround for mt8195: + * MT8195 has 4 controllers, the controller1~3's default SOF/ITP interval + * is calculated from the frame counter clock 24M, but in fact, the clock + * is 48M. + */ +static void xhci_mtk_set_frame_interval(struct mtk_xhci *mtk) +{ + void __iomem *mac = (void __iomem *)mtk->hcd; + + if (!ofnode_device_is_compatible(dev_ofnode(mtk->dev), "mediatek,mt8195-xhci")) + return; + + clrsetbits_le32(mac + HFCNTR_CFG, + ITP_DELTA_CLK_MASK | FRMCNT_LEV1_RANG_MASK, + FIELD_PREP(ITP_DELTA_CLK_MASK, 0xa) | + FIELD_PREP(FRMCNT_LEV1_RANG_MASK, 0x12b)); + + clrsetbits_le32(mac + LS_EOF_CFG, XSEOF_OFFSET_MASK, LSEOF_OFFSET); + clrsetbits_le32(mac + FS_EOF_CFG, XSEOF_OFFSET_MASK, FSEOF_OFFSET); + clrsetbits_le32(mac + SS_GEN1_EOF_CFG, XSEOF_OFFSET_MASK, SSG1EOF_OFFSET); + clrsetbits_le32(mac + SS_GEN2_EOF_CFG, XSEOF_OFFSET_MASK, SSG2EOF_OFFSET); +} + static int xhci_mtk_host_enable(struct mtk_xhci *mtk) { int u3_ports_disabed = 0; @@ -278,6 +322,8 @@ static int xhci_mtk_probe(struct udevice *dev) if (ret) goto ssusb_init_err;
+ xhci_mtk_set_frame_interval(mtk); + mtk->ctrl.quirks = XHCI_MTK_HOST; hcor = (struct xhci_hcor *)((uintptr_t)mtk->hcd + HC_LENGTH(xhci_readl(&mtk->hcd->cr_capbase))); @@ -308,6 +354,7 @@ static int xhci_mtk_remove(struct udevice *dev)
static const struct udevice_id xhci_mtk_ids[] = { { .compatible = "mediatek,mtk-xhci" }, + { .compatible = "mediatek,mt8195-xhci" }, { } };
Feel free to pull the entire series via mediatek tree, so it would go in together.
Hi Marek,
Could you help to apply this series patch, seems no mediatek tree, thanks a lot
On 3/2/23 07:23, Chunfeng Yun (云春峰) wrote:
Hi Marek,
+CC Tom, it would be good to set up Mediatek tree.
Applied to usb/next, thanks.
Add a new compatible for mt8195 to add a workaround for hardware issue.
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- v2: no change --- doc/device-tree-bindings/phy/phy-mtk-tphy.txt | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/device-tree-bindings/phy/phy-mtk-tphy.txt b/doc/device-tree-bindings/phy/phy-mtk-tphy.txt index 8cd23d8c0b..3042c39d09 100644 --- a/doc/device-tree-bindings/phy/phy-mtk-tphy.txt +++ b/doc/device-tree-bindings/phy/phy-mtk-tphy.txt @@ -8,6 +8,7 @@ Required properties (controller (parent) node): - compatible : should be one of "mediatek,generic-tphy-v1" "mediatek,generic-tphy-v2" + "mediatek,mt8195-tphy"
- #address-cells: the number of cells used to represent physical base addresses.
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- v2: no change --- doc/device-tree-bindings/usb/mediatek,mtk-xhci.txt | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/usb/mediatek,mtk-xhci.txt b/doc/device-tree-bindings/usb/mediatek,mtk-xhci.txt index 2a298f7b16..e26e9618eb 100644 --- a/doc/device-tree-bindings/usb/mediatek,mtk-xhci.txt +++ b/doc/device-tree-bindings/usb/mediatek,mtk-xhci.txt @@ -3,7 +3,9 @@ MediaTek xHCI The device node for USB3 host controller on MediaTek SoCs.
Required properties: - - compatible : should be "mediatek,mtk-xhci" + - compatible : should be one of + "mediatek,mtk-xhci" + "mediatek,mt8195-xhci" - reg : specifies physical base address and size of the registers - reg-names: should be "mac" for xHCI MAC and "ippc" for IP port control - power-domains : a phandle to USB power domain node to control USB's
Chunfeng Yun
Chunfeng Yun (云春峰)
