[U-Boot] DM for ci_udc
I’m running into linking issues when enabling CONFIG_DM_USB_GADGET with CONFIG_CI_UDC because dm_usb_gadget_handle_interrupts is not available. That made me look into what’s required to port ci_udc to driver model. I have a few conceptual questions about this:
1. Some other USB gadget drivers (dwc3-generic, ti-musb) seem to create a wrapper driver that binds either the gadget or the host-mode driver to the USB device, depending on the configured mode. Is this the desired approach?
2. I’m working with a i.MX6 (7) device so the host-mode driver is ehci-mx6, but I’ve seen that ci_udc is also used with other host-mode drivers. How would a wrapper work in this case where there are multiple possible host-mode drivers but one gadget driver?
3. Any tips and hints are welcome :)
Best regards, Sven
+CC Lukasz, UDC is his stuff.
Hi Sven, Marek, Jean-Jacques,
- Some other USB gadget drivers (dwc3-generic, ti-musb) seem to
I think that we shall follow the already in-tree pattern. Jean-Jacques Hiblot (CC'ed) did a great job on porting / developing this code (moreover there is a u-boot command - bind/unbind which allows binding usb devices)
- I’m working with a i.MX6 (7) device so the host-mode driver is
As fair as I understood the "bind/unbind" command would allow you to do it [1]. Jean-Jacques am I right here ?
- Any tips and hints are welcome :)
I can offer myself as a tester for imx6q (as I do have a few of them queued for the DM/DTS conversion).
Note: [1] - https://lists.denx.de/pipermail/u-boot/2018-June/333105.html
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
This approach has the advantage to support both modes and select one at runtime usually based on DT configuration.
It could also go further and support a true OTG, but most application do not require it and it would probably be more complex.
In this UDCcase the bind/unbind commands are used only to bind the UDC ethernet (usbether). Other operations, like DFU, bind the UDC by themselves.
The wrapper, the UDC driver and the host driver are separate driver. You have the ci_udc driver completely separate from the wrapper.
The wrapper itself must somehow be aware of the host and of the udc driver. it could be hard-coded (DWC3 case) or it could get this info from the compatible in the DT
Bind/unbind commands could be used if no wrapper is provided, because the role of the wrapper is primarily to bind one driver or the other. But the wrapper usually also performs some kind of HW initialization, so I would keep a wrapper driver.
JJ
Lukasz Majewski
Hi Sven,
Did you make any progress with getting ci_udc to work with DM in SPL on i.MX? The reason I'm asking is, that I need the SDP feature and I also want to use DM for USB.
Thanks, Frieder
On Mon, May 20, 2019 at 7:13 AM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Sven,
I started a wrapper a while ago. I posted an RFC to the mailing list, but i never heard anything. As of right now, my wrapper only supports the host side, but it could easily be adapter to add the gadget.
https://patchwork.ozlabs.org/patch/1076080/
adam
Thanks, Frieder _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
participants (6)
Adam Ford
Jean-Jacques Hiblot
Lukasz Majewski
Schrempf Frieder
Sven Schwermer
