[U-Boot] Please pull u-boot-ppc4xx
The following changes since commit e7963772eb78a6aa1fa65063d64eab3a8626daac: Marcel Ziswiler (1): muas3001: remove BRG clock node fixup to use common mpc8260 code.
git://www.denx.de/git/u-boot-ppc4xx.git master
Dirk Eibach (1): ppc4xx: Rename compactcenter to intip
Stefan Roese (1): ppc4xx: Big cleanup of PPC4xx defines
MAINTAINERS | 2 +- MAKEALL | 2 +- Makefile | 16 +- board/amcc/acadia/acadia.c | 12 +- board/amcc/acadia/memory.c | 18 +- board/amcc/acadia/pll.c | 52 ++-- board/amcc/bamboo/bamboo.c | 104 +++--- board/amcc/bamboo/flash.c | 2 +- board/amcc/bubinga/bubinga.c | 4 +- board/amcc/bubinga/flash.c | 20 +- board/amcc/canyonlands/canyonlands.c | 4 +- board/amcc/ebony/ebony.c | 32 +- board/amcc/katmai/katmai.c | 6 +- board/amcc/luan/luan.c | 18 +- board/amcc/ocotea/ocotea.c | 48 ++-- board/amcc/redwood/redwood.c | 18 +- board/amcc/sequoia/sequoia.c | 60 ++-- board/amcc/taihu/taihu.c | 6 +- board/amcc/taishan/showinfo.c | 70 ++-- board/amcc/taishan/taishan.c | 44 +- board/amcc/walnut/flash.c | 20 +- board/amcc/yosemite/yosemite.c | 58 ++-- board/amcc/yucca/flash.c | 2 +- board/amcc/yucca/yucca.c | 20 +- board/cray/L1/L1.c | 38 +- board/cray/L1/init.S | 24 +- board/csb272/csb272.c | 18 +- board/csb272/init.S | 50 ++-- board/csb472/csb472.c | 18 +- board/csb472/init.S | 54 ++-- board/dave/PPChameleonEVB/PPChameleonEVB.c | 6 +- board/dave/PPChameleonEVB/flash.c | 8 +- board/eric/eric.c | 2 +- board/eric/flash.c | 20 +- board/eric/init.S | 126 +++--- board/esd/apc405/apc405.c | 26 +- board/esd/ar405/flash.c | 8 +- board/esd/ash405/ash405.c | 2 +- board/esd/ash405/flash.c | 8 +- board/esd/canbt/canbt.c | 8 +- board/esd/canbt/flash.c | 10 +- board/esd/cms700/cms700.c | 2 +- board/esd/cms700/flash.c | 8 +- board/esd/cpci2dp/cpci2dp.c | 12 +- board/esd/cpci2dp/flash.c | 10 +- board/esd/cpci405/cpci405.c | 22 +- board/esd/cpci405/flash.c | 20 +- board/esd/cpciiser4/flash.c | 10 +- board/esd/dp405/dp405.c | 2 +- board/esd/dp405/flash.c | 8 +- board/esd/du405/du405.c | 8 +- board/esd/du405/flash.c | 20 +- board/esd/du440/du440.c | 56 ++-- board/esd/hh405/flash.c | 8 +- board/esd/hh405/hh405.c | 2 +- board/esd/hub405/flash.c | 8 +- board/esd/hub405/hub405.c | 2 +- board/esd/ocrtc/flash.c | 20 +- board/esd/ocrtc/ocrtc.c | 2 +- board/esd/pci405/flash.c | 8 +- board/esd/pci405/pci405.c | 28 +- board/esd/plu405/flash.c | 8 +- board/esd/plu405/plu405.c | 2 +- board/esd/pmc405/pmc405.c | 6 +- board/esd/pmc405de/pmc405de.c | 2 +- board/esd/pmc440/pmc440.c | 66 ++-- board/esd/voh405/flash.c | 8 +- board/esd/voh405/voh405.c | 2 +- board/esd/vom405/flash.c | 8 +- board/esd/vom405/vom405.c | 2 +- board/esd/wuh405/flash.c | 8 +- board/esd/wuh405/wuh405.c | 2 +- board/exbitgen/exbitgen.c | 16 +- board/exbitgen/init.S | 104 +++--- board/g2000/g2000.c | 14 +- board/gdsys/dlvision/dlvision.c | 2 +- board/gdsys/gdppc440etx/gdppc440etx.c | 52 ++-- board/gdsys/{compactcenter => intip}/Makefile | 0 board/gdsys/{compactcenter => intip}/chip_config.c | 0 board/gdsys/{compactcenter => intip}/config.mk | 0 board/gdsys/{compactcenter => intip}/init.S | 0 .../compactcenter.c => intip/intip.c} | 4 +- board/gdsys/{compactcenter => intip}/u-boot.lds | 2 +- board/gdsys/neo/neo.c | 2 +- board/jse/init.S | 14 +- board/jse/jse.c | 8 +- board/jse/sdram.c | 80 ++-- board/korat/korat.c | 64 ++-- board/lwmon5/lwmon5.c | 52 ++-- board/mpl/common/flash.c | 58 ++-- board/mpl/mip405/init.S | 74 ++-- board/mpl/mip405/mip405.c | 132 +++--- board/mpl/pip405/init.S | 74 ++-- board/mpl/pip405/pip405.c | 82 ++-- board/netstal/hcu4/hcu4.c | 2 +- board/netstal/hcu5/hcu5.c | 30 +- board/netstal/hcu5/sdram.c | 4 +- board/netstal/mcu25/mcu25.c | 6 +- board/pcs440ep/pcs440ep.c | 58 ++-- board/prodrive/alpr/alpr.c | 6 +- board/prodrive/p3p440/p3p440.c | 22 +- board/sandburst/common/sb_common.c | 2 +- board/sandburst/karef/karef.c | 36 +- board/sandburst/metrobox/metrobox.c | 36 +- board/sbc405/sbc405.c | 2 +- board/sc3/init.S | 130 +++--- board/sc3/sc3.c | 96 +++--- board/snmc/qs850/flash.c | 16 +- board/snmc/qs860t/flash.c | 16 +- board/tb0229/flash.c | 20 +- board/w7o/init.S | 66 ++-- board/w7o/w7o.c | 16 +- board/xes/xpedite1000/xpedite1000.c | 26 +- board/zeus/zeus.c | 6 +- common/cmd_reginfo.c | 146 ++++---- cpu/ppc4xx/40x_spd_sdram.c | 2 +- cpu/ppc4xx/44x_spd_ddr.c | 20 +- cpu/ppc4xx/4xx_pci.c | 10 +- cpu/ppc4xx/4xx_uart.c | 28 +- cpu/ppc4xx/cpu.c | 38 +- cpu/ppc4xx/cpu_init.c | 68 ++-- cpu/ppc4xx/fdt.c | 4 +- cpu/ppc4xx/sdram.c | 4 +- cpu/ppc4xx/speed.c | 52 ++-- cpu/ppc4xx/start.S | 112 +++--- cpu/ppc4xx/usbdev.c | 4 +- drivers/mtd/nand/ndfc.c | 4 +- drivers/net/4xx_enet.c | 136 +++--- include/configs/W7OLMC.h | 4 +- include/configs/W7OLMG.h | 4 +- include/configs/{compactcenter.h => intip.h} | 8 +- include/ppc405.h | 397 ++++++------------ include/ppc440.h | 432 ++++++-------------- include/ppc4xx.h | 106 +++--- nand_spl/board/amcc/bamboo/sdram.c | 4 +- post/cpu/ppc4xx/ether.c | 50 ++-- post/cpu/ppc4xx/uart.c | 22 +- 137 files changed, 2104 insertions(+), 2415 deletions(-) rename board/gdsys/{compactcenter => intip}/Makefile (100%) rename board/gdsys/{compactcenter => intip}/chip_config.c (100%) rename board/gdsys/{compactcenter => intip}/config.mk (100%) rename board/gdsys/{compactcenter => intip}/init.S (100%) rename board/gdsys/{compactcenter/compactcenter.c => intip/intip.c} (99%) rename board/gdsys/{compactcenter => intip}/u-boot.lds (98%) rename include/configs/{compactcenter.h => intip.h} (98%)
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
