[PATCH] am33xx: ignore return value from usb_ether_init()
In 2cb43ef1c223 ("usb: ether: Fix error handling in usb_ether_init") the error handling of usb_ether_init() was changed. Not a single other call site of this function checks its return value, therefore follow suit in the am33xx code.
Do not cause the boot to halt if the usb gadget ethernet initialization fails:
initcall sequence 9ffdbd84 failed at call 808024b9 (err=-19) ### ERROR ### Please RESET the board ###
Signed-off-by: Trevor Woerner twoerner@gmail.com --- arch/arm/mach-omap2/am33xx/board.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index ecc0a592e993..8f772310a1a7 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -270,11 +270,7 @@ int arch_misc_init(void) return ret;
#if defined(CONFIG_DM_ETH) && defined(CONFIG_USB_ETHER) - ret = usb_ether_init(); - if (ret) { - pr_err("USB ether init failed\n"); - return ret; - } + usb_ether_init(); #endif
Hello,
then there is the question what point is there in having a return value in this function at all.
Anyway, it's fine to not check the return value in the caller if there is no use for the error.
Reviewed-by: Michal Suchánek msuchanek@suse.de
- if (ret) {
return ret;
- usb_ether_init();
#endif
2.41.0.327.gaa9166bcc0ba
Can this get added to the next release? I don't see it in -next.
On Thu, Aug 31, 2023 at 6:15 AM Michal Suchánek msuchanek@suse.de wrote:
Hello,
error
of this
code.
fails:
if (ret) {
return ret;
usb_ether_init();
#endif
-- 2.41.0.327.gaa9166bcc0ba
I was going to pick this up for v2024.01 (i.e. the next branch) soon'ish.
Hello,
error
of this
code.
fails:
if (ret) {
return ret;
usb_ether_init();
#endif
Awesome, thanks! :-)
Signed-off-by: Trevor Woerner twoerner@gmail.com Reviewed-by: Michal Suchánek msuchanek@suse.de
Michal Suchánek
Trevor Woerner
