[u-boot PATCH] phy: omap-usb2-phy: disable phy charger detect
AM654x PG1.0 has a silicon bug that D+ is pulled high after POR, which could cause enumeration failure with some USB hubs. Disabling the USB2_PHY Charger Detect function will put D+ into the normal state.
Using property "ti,dis-chg-det-quirk" in the DT usb2-phy node to enable this workaround for AM654x PG1.0.
Signed-off-by: Bin Liu b-liu@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Roger Quadros rogerq@ti.com --- drivers/phy/omap-usb2-phy.c | 33 ++++++++++++++++++++++++++++----- 1 file changed, 28 insertions(+), 5 deletions(-)
diff --git a/drivers/phy/omap-usb2-phy.c b/drivers/phy/omap-usb2-phy.c index 0793b97dd5..adc454ddd4 100644 --- a/drivers/phy/omap-usb2-phy.c +++ b/drivers/phy/omap-usb2-phy.c @@ -17,6 +17,7 @@ #include <linux/err.h>
#define OMAP_USB2_CALIBRATE_FALSE_DISCONNECT BIT(0) +#define OMAP_USB2_DISABLE_CHG_DET BIT(1)
#define OMAP_DEV_PHY_PD BIT(0) #define OMAP_USB2_PHY_PD BIT(28) @@ -33,6 +34,10 @@ #define AM654_USB2_VBUS_DET_EN BIT(5) #define AM654_USB2_VBUSVALID_DET_EN BIT(4)
+#define USB2PHY_CHRG_DET 0x14 +#define USB2PHY_USE_CHG_DET_REG BIT(29) +#define USB2PHY_DIS_CHG_DET BIT(28) + DECLARE_GLOBAL_DATA_PTR;
struct omap_usb2_phy { @@ -160,6 +165,12 @@ static int omap_usb2_phy_init(struct phy *usb_phy) writel(val, priv->phy_base + USB2PHY_ANA_CONFIG1); }
+ if (priv->flags & OMAP_USB2_DISABLE_CHG_DET) { + val = readl(priv->phy_base + USB2PHY_CHRG_DET); + val |= USB2PHY_USE_CHG_DET_REG | USB2PHY_DIS_CHG_DET; + writel(val, priv->phy_base + USB2PHY_CHRG_DET); + } + return 0; }
@@ -197,13 +208,25 @@ int omap_usb2_phy_probe(struct udevice *dev) if (!data) return -EINVAL;
- if (data->flags & OMAP_USB2_CALIBRATE_FALSE_DISCONNECT) { - priv->phy_base = dev_read_addr_ptr(dev); + priv->phy_base = dev_read_addr_ptr(dev);
- if (!priv->phy_base) - return -EINVAL; + if (!priv->phy_base) + return -EINVAL; + + if (data->flags & OMAP_USB2_CALIBRATE_FALSE_DISCONNECT) priv->flags |= OMAP_USB2_CALIBRATE_FALSE_DISCONNECT; - } + + /* + * AM654x PG1.0 has a silicon bug that D+ is pulled high after + * POR, which could cause enumeration failure with some USB hubs. + * Disabling the USB2_PHY Charger Detect function will put D+ + * into the normal state. + * + * Using property "ti,dis-chg-det-quirk" in the DT usb2-phy node + * to enable this workaround for AM654x PG1.0. + */ + if (dev_read_bool(dev, "ti,dis-chg-det-quirk")) + priv->flags |= OMAP_USB2_DISABLE_CHG_DET;
regmap = syscon_regmap_lookup_by_phandle(dev, "syscon-phy-power"); if (!IS_ERR(regmap)) {
Applied to u-boot-ti next.
Thanks and regards, Lokesh
Lokesh Vutla
Roger Quadros
