[U-Boot] [PATCH v4 17/29] zynq: Add zynq_zc770 xm010 board support
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013
ZC770 XM010: - 1Gb DDR3 - 1Mb SST SPI flash - 128 Mb Quad-SPI Flash - 8 Mb SST SI flash - Full size SD/MMC card cage - 10/100/1000 Ethernet - USB-UART
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- boards.cfg | 1 + include/configs/zynq_zc770.h | 30 ++++++++++++++++++++++++++++++ 2 files changed, 31 insertions(+) create mode 100644 include/configs/zynq_zc770.h
diff --git a/boards.cfg b/boards.cfg index 1c7cdf3..4e88dfe 100644 --- a/boards.cfg +++ b/boards.cfg @@ -357,6 +357,7 @@ Active arm armv7 vf610 freescale vf610twr Active arm armv7 zynq xilinx zynq zynq_zc70x - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_zed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_microzed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com +Active arm armv7 zynq xilinx zynq zynq_zc770_xm010 zynq_zc770:ZC770_XM010 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7:arm720t tegra114 nvidia dalmore dalmore - Tom Warren twarren@nvidia.com Active arm armv7:arm720t tegra20 avionic-design medcom-wide medcom-wide - Thierry Reding thierry.reding@avionic-design.de Active arm armv7:arm720t tegra20 avionic-design plutux plutux - Thierry Reding thierry.reding@avionic-design.de diff --git a/include/configs/zynq_zc770.h b/include/configs/zynq_zc770.h new file mode 100644 index 0000000..8589d9d --- /dev/null +++ b/include/configs/zynq_zc770.h @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2013 Xilinx, Inc. + * + * Configuration settings for the Xilinx Zynq ZC770 board. + * See zynq-common.h for Zynq common configs + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ZYNQ_ZC770_H +#define __CONFIG_ZYNQ_ZC770_H + +#define CONFIG_SYS_SDRAM_SIZE (1024 * 1024 * 1024) + +#define CONFIG_SYS_NO_FLASH + +#if defined(CONFIG_ZC770_XM010) +# define CONFIG_ZYNQ_SERIAL_UART1 +# define CONFIG_ZYNQ_GEM0 +# define CONFIG_ZYNQ_GEM_PHY_ADDR0 7 +# define CONFIG_ZYNQ_SDHCI0 +# define CONFIG_ZYNQ_SPI + +#else +# define CONFIG_ZYNQ_SERIAL_UART0 +#endif + +#include <configs/zynq-common.h> + +#endif /* __CONFIG_ZYNQ_ZC770_H */
