RE: [U-Boot-Users] -mrelocatable
I'm attaching a patch I got for GCC3.4 from Paul Brook at CodeSourcery which fixes the relocation problem. I'm assuming the one discussed below is the same one we ran into.
Regards,
Richard W.
I've included a file called er_objs.tar.gz . I contains a somewhat reduced set of objects and the compile line to generate the error. If
you us another linker you will get past the error. As I said before this is for the Q4-2003 release and the Q1-2004 release.
[a0384864@dta0384864 objs]$ ./command_line_for_link_error ./libgcc.a(_udivsi3.oS)(.text+0xec):/work/GNU/CodeSourcery/gcc/gcc/con fi
The following patch should fix this problem. It will be included in future releases.
Paul
--- bfd/elf32-arm.h.orig 2004-04-22 22:11:15.000000000 -0400 +++ bfd/elf32-arm.h 2004-04-22 22:28:37.000000000 -0400 @@ -2229,6 +2229,8 @@ elf32_arm_relocate_section (output_bfd, case R_ARM_PC24: case R_ARM_ABS32: case R_ARM_THM_PC22: + case R_ARM_PLT32: + if (info->shared && ( (!info->symbolic && h->dynindx != -1) @@ -2262,11 +2264,6 @@ elf32_arm_relocate_section (output_bfd, relocation = 0; break;
- case R_ARM_PLT32: - if (h->plt.offset != (bfd_vma)-1) - relocation = 0; - break; - default: if (unresolved_reloc) _bfd_error_handler
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users- admin@lists.sourceforge.net] On Behalf Of Wolfgang Denk Sent: Wednesday, April 07, 2004 5:38 PM To: Jeff Tucker Cc: 'u-boot-users@lists.sourceforge.net' Subject: Re: [U-Boot-Users] -mrelocatable
In message <169996251.1081357990@[192.168.0.230]> you wrote:
Wolfgang posted a couple days ago that you can't build the latest
U-Boot
with old gcc tools. Perhaps you're not really using the latest
compiler
This is WRONG.
It's vice versa: You cannot build OLD U-Boot sources with latest GCC.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de Fascinating is a word I use for the unexpected. -- Spock, "The Squire of Gothos", stardate 2124.5
This SF.Net email is sponsored by: IBM Linux Tutorials Free Linux tutorial presented by Daniel Robbins, President and CEO of GenToo technologies. Learn everything from fundamentals to system administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Woodruff, Richard
